[code]buntu 18.04.3 LTS localhost.localdomain ttyS0
localhost login: [0000.240] [L4T TegraBoot] (version 00.00.2018.01-l4t-39a9dc3d)
[0000.245] Processing in cold boot mode Bootloader 2
[0000.250] A02 Bootrom Patch rev = 1023
[0000.254] Power-up reason: pmc por
[0000.257] No Battery Present
[0000.259] pmic max77620 reset reason
[0000.263] pmic max77620 NVERC : 0x40
[0000.266] RamCode = 0
[0000.269] Platform has DDR4 type RAM
[0000.272] max77620 disabling SD1 Remote Sense
[0000.276] Setting DDR voltage to 1125mv
[0000.280] Serial Number of Pmic Max77663: 0x210bed
[0000.288] Entering ramdump check
[0000.291] Get RamDumpCarveOut = 0x0
[0000.294] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.299] Last reboot was clean, booting normally!
[0000.304] Sdram initialization is successful
[0000.308] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.314] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.320] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.326] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.331] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.337] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.343] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.349] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.365] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.371] Platform-DebugCarveout: 0
[0000.374] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.380] Non secure mode, and RB not enabled.
[0000.397] Csd NumOfBlocks=0
[0000.590] *** Booting BFS0.
[0000.596] Using BFS PT to query partitions
[0001.185] *** Booting KFS0.
[0001.189] Using GPT Primary to query partitions
[0001.194] Loading Tboot-CPU binary
[0001.201] Verifying TBC in OdmNonSecureSBK mode
[0001.211] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.218] Bootloader downloaded successfully.
[0001.222] Downloaded Tboot-CPU binary to 0xa0000258
[0001.227] MAX77620_GPIO5 configured
[0001.230] CPU power rail is up
[0001.233] CPU clock enabled
[0001.237] Performing RAM repair
[0001.240] Updating A64 Warmreset Address to 0xa00002e9
[0001.245] Loading NvTbootBootloaderDTB
[0001.262] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0001.327] Bootloader DTB Load Address: 0x83000000
[0001.332] Loading NvTbootKernelDTB
[0001.349] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0001.414] Kernel DTB Load Address: 0x83100000
[0001.419] Loading cboot binary
[0001.430] Verifying EBT in OdmNonSecureSBK mode
[0001.472] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.479] Bootloader downloaded successfully.
[0001.483] Next binary entry address: 0x92c00258
[0001.488] BoardId: 3448
[0001.492] Overriding pmu board id with proc board id
[0001.497] Display board id is not available
[0001.509] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.561] /bpmp deleted
[0001.563] SC7EntryFw header found loaded at 0xff700000
[0001.752] OVR2 PMIC
[0001.754] Bpmp FW successfully loaded
[0001.759] WB0 init successfully at 0xff780000
[0001.763] Set NvDecSticky Bits
[0001.766] GSC2 address ff53fffc value c0edbbcc
[0001.773] GSC MC Settings done
[0001.776] TOS Image length 53680
[0001.779] Monitor size 53680
[0001.782] OS size 0
[0001.787] Secure Os AES-CMAC Verification Success!
[0001.792] TOS image cipher info: plaintext
[0001.795] Loading and Validation of Secure OS Successful
[0001.811] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.816] NvTbootPackSdramParams: start.
[0001.821] NvTbootPackSdramParams: done.
[0001.825] Tegraboot started after 169963 us
[0001.829] Basic modules init took 1368290 us
[0001.833] Sec Bootdevice Read Time = 549 ms, Read Size = 14457 KB
[0001.839] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.844] Next stage binary read took 7394 us
[0001.848] Carveout took -19270 us
[0001.852] CPU initialization took 342619 us
[0001.856] Total time taken by TegraBoot 1699033 us
[0001.860] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:39:57, Dec 9 2019
ERROR: Error initializing runtime service trusty_fast
[0001.983] RamCode = 0
[0001.987] LPDDR4 Training: Read DT: Number of tables = 2
[0001.992] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.005] EMC Training Successful
[0002.008] 408000 not found in DVFS table
[0002.015] RamCode = 0
[0002.018] DT Write: emc-table@204000 succeeded
[0002.023] DT Write: emc-table@1600000 succeeded
[0002.028] LPDDR4 Training: Write DT: Number of tables = 2
[0002.086]
[0002.087] Debug Init done
[0002.089] Marked DTB cacheable
[0002.092] Bootloader DTB loaded at 0x83000000
[0002.097] Marked DTB cacheable
[0002.100] Kernel DTB loaded at 0x83100000
[0002.104] DeviceTree Init done
[0002.119] Pinmux applied successfully
[0002.124] gicd_base: 0x50041000
[0002.127] gicc_base: 0x50042000
[0002.130] Interrupts Init done
[0002.134] Using base:0x60005090 & irq:208 for tick-timer
[0002.140] Using base:0x60005098 for delay-timer
[0002.144] platform_init_timer: DONE
[0002.147] Timer(tick) Init done
[0002.151] osc freq = 38400 khz
[0002.155]
[0002.156] Welcome to L4T Cboot
[0002.159]
[0002.161] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0002.166] calling constructors
[0002.168] initializing heap
[0002.171] initializing threads
[0002.174] initializing timers
[0002.177] creating bootstrap completion thread
[0002.181] top of bootstrap2()
[0002.184] CPU: ARM Cortex A57
[0002.187] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.192] initializing platform
[0002.246] Config for emmc ddr50 mode completed
[0002.250] sdmmc bdev is already initialized
[0002.254] Enable APE clock
[0002.257] Un-powergate APE partition
[0002.260] of_register: registering tegra_udc to of_hal
[0002.265] of_register: registering inv20628-driver to of_hal
[0002.271] of_register: registering ads1015-driver to of_hal
[0002.277] of_register: registering lp8557-bl-driver to of_hal
[0002.282] of_register: registering bq2419x_charger to of_hal
[0002.288] of_register: registering bq27441_fuel_gauge to of_hal
[0002.300] gpio framework initialized
[0002.303] of_register: registering tca9539_gpio to of_hal
[0002.308] of_register: registering tca9539_gpio to of_hal
[0002.314] of_register: registering i2c_bus_driver to of_hal
[0002.319] of_register: registering i2c_bus_driver to of_hal
[0002.325] of_register: registering i2c_bus_driver to of_hal
[0002.330] pmic framework initialized
[0002.334] of_register: registering max77620_pmic to of_hal
[0002.339] regulator framework initialized
[0002.343] of_register: registering tps65132_bl_driver to of_hal
[0002.349] initializing target
[0002.355] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.366] fixed regulator driver initialized
[0002.383] initializing OF layer
[0002.386] NCK carveout not present
[0002.389] Skipping dts_overrides
[0002.394] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.410] I2C Bus Init done
[0002.413] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.423] I2C Bus Init done
[0002.426] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.436] I2C Bus Init done
[0002.439] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.449] I2C Bus Init done
[0002.452] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.462] I2C Bus Init done
[0002.465] of_children_init: Ops found for compatible string maxim,max77620
[0002.475] max77620_init using irq 118
[0002.480] register ‘maxim,max77620’ pmic
[0002.484] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.491] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.501] I2C Bus Init done
[0002.505] NCK carveout not present
[0002.515] Find /i2c@7000c000’s alias i2c0
[0002.518] get eeprom at 1-a0, size 256, type 0
[0002.527] Find /i2c@7000c500’s alias i2c2
[0002.531] get eeprom at 3-a0, size 256, type 0
[0002.536] get eeprom at 3-ae, size 256, type 0
[0002.540] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.545] I2C slave not started
[0002.548] I2C write failed
[0002.551] Writing offset failed
[0002.554] eeprom_init: EEPROM read failed
[0002.558] pm_ids_update: eeprom init failed
[0002.562] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.592] pm_ids_update: The pm board id is 3448-0002-400
[0002.599] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.607] pm_ids_update: pm id update successful
[0002.611] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.641] pm_ids_update: The pm board id is 3449-0000-400
[0002.648] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.656] pm_ids_update: pm id update successful
[0002.686] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.692] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.701] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.706] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.715] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d1:73
[0002.721] Plugin Manager: Parse ODM data 0x00094000
[0002.732] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0002.756] Find /i2c@7000c000’s alias i2c0
[0002.760] get eeprom at 1-a0, size 256, type 0
[0002.769] Find /i2c@7000c500’s alias i2c2
[0002.773] get eeprom at 3-a0, size 256, type 0
[0002.777] get eeprom at 3-ae, size 256, type 0
[0002.781] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.787] I2C slave not started
[0002.790] I2C write failed
[0002.792] Writing offset failed
[0002.795] eeprom_init: EEPROM read failed
[0002.799] pm_ids_update: eeprom init failed
[0002.803] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.833] pm_ids_update: The pm board id is 3448-0002-400
[0002.840] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.847] pm_ids_update: pm id update successful
[0002.852] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.882] pm_ids_update: The pm board id is 3449-0000-400
[0002.888] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.895] pm_ids_update: pm id update successful
[0002.926] Add serial number:1423019114890 as DT property
[0002.934] Applying platform configs
[0002.940] platform-init is not present. Skipping
[0002.945] calling apps_init()
[0002.961] Found 17 GPT partitions in “sdmmc3_user”
[0002.965] Proceeding to Cold Boot
[0002.969] starting app android_boot_app
[0002.972] Device state: unlocked
[0002.975] display console init
[0002.984] could not find regulator
[0002.987] hdmi cable connected
[0003.003] edid read success
[0003.020] DT entry for leds-pwm not found
[0003.024] edid read success
[0003.027] width = 640, height = 480, frequency = 25174825
[0003.032] width = 640, height = 480, frequency = 25174825
[0003.038] width = 640, height = 480, frequency = 25174825
[0003.043] width = 640, height = 480, frequency = 25174825
[0003.048] width = 3840, height = 2160, frequency = 533250000
[0003.054] width = 3840, height = 2160, frequency = 262750000
[0003.060] width = 2560, height = 1440, frequency = 241500000
[0003.065] width = 1920, height = 1080, frequency = 148351648
[0003.071] width = 1280, height = 720, frequency = 74175824
[0003.076] width = 720, height = 480, frequency = 26973026
[0003.082] width = 1920, height = 1080, frequency = 148351648
[0003.087] width = 1280, height = 720, frequency = 74175824
[0003.093] width = 640, height = 480, frequency = 25174825
[0003.098] width = 720, height = 576, frequency = 26973026
[0003.104] width = 3840, height = 2160, frequency = 296703296
[0003.109] width = 3840, height = 2160, frequency = 593406593
[0003.115] width = 3840, height = 2160, frequency = 296703296
[0003.121] width = 3840, height = 2160, frequency = 296703296
[0003.126] width = 3840, height = 2160, frequency = 296703296
[0003.132] Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.140] tmds-config node not found
[0003.144] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0003.158] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0003.166] could not find regulator
[0003.169] could not find regulator
[0003.173] could not find regulator
[0003.201] using default cmu settings
[0003.205] dc_hdmi_enable, starting HDMI initialisation
[0003.211] dc_hdmi_enable, HDMI initialisation complete
[0003.216] list and configure display window
[0003.224] display console init completed
[0003.236] subnode volume_up is not found !
[0003.240] subnode back is not found !
[0003.243] subnode volume_down is not found !
[0003.247] subnode menu is not found !
[0003.251] Gpio keyboard init success
[0003.298] found decompressor handler: lz4-legacy
[0003.312] decompressing blob (type 1)…
[0003.348] load_bmp_blob: panelresolution=1080 type=3
[0003.397] decompressor handler not found
[0003.401] load_firmware_blob: Firmware blob loaded, entries=2
[0003.407] -------> se_aes_verify_sbk_clear: 747
[0003.411] se_aes_verify_sbk_clear: Error
[0003.415] bl_battery_charging: connected to external power supply
[0003.423] xusb is supported
[0003.429] error while finding nvidia,portmap
[0003.933] xusb blob version 0 size 124416
[0003.937] firmware size 124416
[0003.942] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.957] xhci0: 64 bytes context size, 32-bit DMA
[0003.997] usbus0: 5.0Gbps Super Speed USB v3.0
[0004.017] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.667] uhub0: 9 ports with 9 removable, self powered
[0005.667] failed to get HID devices
[0005.670] failed to init xhci or no usb device attached
[0005.684] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0005.692] MSC Partition not found
[0005.701] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0005.709] USP partition read failed!
[0005.712] blob_init: blob-partition USP header read failed
[0005.718] android_boot Unable to update recovery partition
[0005.723] kfs_getpartname: name = LNX
[0005.727] Loading kernel from LNX
[0005.791] load kernel from storage
[0005.800] decompressor handler not found
[0005.820] Successfully loaded kernel and ramdisk images
[0005.826] load_bmp_blob: panelresolution=1080 type=3
[0006.321] display bmp image done
[0006.324] NCK carveout not present
[0006.327] Skipping dts_overrides
[0006.330] NCK carveout not present
[0006.340] Find /i2c@7000c000’s alias i2c0
[0006.344] get eeprom at 1-a0, size 256, type 0
[0006.353] Find /i2c@7000c500’s alias i2c2
[0006.357] get eeprom at 3-a0, size 256, type 0
[0006.361] get eeprom at 3-ae, size 256, type 0
[0006.366] pm_ids_update: Updating 1,a0, size 256, type 0
[0006.371] I2C slave not started
[0006.374] I2C write failed
[0006.376] Writing offset failed
[0006.380] eeprom_init: EEPROM read failed
[0006.383] pm_ids_update: eeprom init failed
[0006.388] pm_ids_update: Updating 3,a0, size 256, type 0
[0006.418] pm_ids_update: The pm board id is 3448-0002-400
[0006.424] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0006.432] pm_ids_update: pm id update successful
[0006.437] pm_ids_update: Updating 3,ae, size 256, type 0
[0006.467] pm_ids_update: The pm board id is 3449-0000-400
[0006.473] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0006.481] pm_ids_update: pm id update successful
[0006.512] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.518] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0006.526] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.532] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0006.540] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d1:73
[0006.547] Plugin Manager: Parse ODM data 0x00094000
[0006.557] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.575] Add serial number:1423019114890 as DT property
[0006.584] “bpmp” doesn’t exist, creating
[0006.589] Updated bpmp info to DTB
[0006.594] Updated initrd info to DTB
[0006.598] “proc-board” doesn’t exist, creating
[0006.603] Updated board info to DTB
[0006.607] “pmu-board” doesn’t exist, creating
[0006.612] Updated board info to DTB
[0006.615] “display-board” doesn’t exist, creating
[0006.621] Updated board info to DTB
[0006.624] “reset” doesn’t exist, creating
[0006.629] Updated reset info to DTB
[0006.632] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 consol
[0006.671] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.687] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.703] Updated bootarg info to DTB
[0006.706] Adding uuid 00000001644568040000000006fd8400 to DT
[0006.712] Adding eks info 0 to DT
[0006.718] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.724] Updated memory info to DTB
[0006.732] set vdd_core voltage to 1075 mv
[0006.736] setting ‘vdd-core’ regulator to 1075000 micro volts
[0006.757] Found secure-pmc; disable BPMP
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Failed to get idcodes
*** Warning - spi_flash_probe() failed, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Card did not respond to voltage select!
** Bad device mmc 1 **
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 118 ms (5.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 231 ms (22.7 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 807 ms (40.4 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,1152t
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831776fe
Starting kernel …
[ 1.092674] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.248240] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.248269] imx219 7-0010: board setup failed
[ 1.272061] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.272092] imx219 8-0010: board setup failed
[ 1.853003] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.472570] systemd-journald[1991]: File /var/log/journal/3a932db73bc046febb6bca626bb9c58e/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 3.293217] using random self ethernet address
[ 3.314802] using random host ethernet address
[ 3.543931] systemd-journald[1991]: File /var/log/journal/3a932db73bc046febb6bca626bb9c58e/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 3.750046] random: crng init done
[ 3.753483] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.135557] using random self ethernet address
[ 4.142943] using random host ethernet address
Ubuntu 18.04.3 LTS localhost ttyS0
localhost login: [0011.418] Enabled early print
[0011.421] [L4T TegraBoot] (version 00.00.2018.01-l4t-1463e5a5)
[0011.426] Processing in recovery mode
[0011.430] A02 Bootrom Patch rev = 1023
[0011.433] Power-up reason: pmc por
[0011.436] Established communication link with host
[0012.442] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0012.449] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0012.458] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
[0072.936] Odmdata from BCT: 0x00094000
[0072.940] DebugPort= 0x3
[0072.949] BoardId read from EEPROM/NCT: 3448
[0072.953] BoardID = 3448, SKU = 0x2
[0072.980] NvTbootInit_Porg: Setting GPIO_A6 for HDMI …
[0072.985] max77620 setting MBLPD bit
[0072.989] No Battery Present
[0072.992] RamCode = 0
[0072.994] Platform has DDR4 type RAM
[0072.997] max77620 disabling SD1 Remote Sense
[0073.002] Setting DDR voltage to 1125mv
[0073.006] Serial Number of Pmic Max77663: 0x210bed
[0073.013] Entering ramdump check
[0073.016] Get RamDumpCarveOut = 0x0
[0073.020] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0073.025] Last reboot was clean, booting normally!
[0073.029] Sdram initialization is successful
[0073.034] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0073.040] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0073.045] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0073.051] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0073.057] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0073.063] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0073.069] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0073.075] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0073.091] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0073.097] Platform-DebugCarveout: 0
[0073.100] Downloaded BCT successfully
[0073.298] Downloaded Bootloader successfully
[0073.349] Downloaded rp1 successfully
[0073.379] MAX77620_GPIO5 configured
[0073.382] CPU power rail is up
[0073.385] CPU clock enabled
[0073.389] Performing RAM repair
[0073.392] Updating A64 Warmreset Address to 0x92c002e9
[0073.398] Enable APE clock/reset
[0073.401] Error in NvTbootGetTOSBinaryLength: 0x11 !
[0073.406] Loading Secure OS image failed.
[0073.410] Set NvDecSticky Bits
[0073.413] GSC2 address ff53fffc value c0edbbcc
[0073.419] GSC MC Settings done
[0073.424] Next binary entry address: 0x92c00258
[0073.428] BoardId: 3448
[0073.431] Overriding pmu board id with proc board id
[0073.435] Display board id is not available
[0073.440] Starting CPU & Halting co-processor
[0075.213]
[0075.215] Debug Init done
[0075.218] Marked DTB cacheable
[0075.221] Bootloader DTB loaded at 0x83000400
[0075.225] DeviceTree Init done
[0075.238] Pinmux applied successfully
[0075.243] gicd_base: 0x50041000
[0075.246] gicc_base: 0x50042000
[0075.249] Interrupts Init done
[0075.253] Using base:0x60005090 & irq:208 for tick-timer
[0075.258] Using base:0x60005098 for delay-timer
[0075.263] platform_init_timer: DONE
[0075.266] Timer(tick) Init done
[0075.270] osc freq = 38400 khz
[0075.274]
[0075.275] Welcome to L4T Cboot
[0075.278]
[0075.279] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0075.284] calling constructors
[0075.287] initializing heap
[0075.290] initializing threads
[0075.293] initializing timers
[0075.296] creating bootstrap completion thread
[0075.300] top of bootstrap2()
[0075.303] CPU: ARM Cortex A57
[0075.306] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0075.311] initializing platform
[0075.437] Config for emmc ddr50 mode completed
[0075.441] sdmmc bdev is already initialized
[0075.445] of_register: registering tegra_udc to of_hal
[0075.450] of_register: registering inv20628-driver to of_hal
[0075.456] of_register: registering ads1015-driver to of_hal
[0075.461] of_register: registering lp8557-bl-driver to of_hal
[0075.467] of_register: registering bq2419x_charger to of_hal
[0075.473] of_register: registering bq27441_fuel_gauge to of_hal
[0075.484] gpio framework initialized
[0075.488] of_register: registering tca9539_gpio to of_hal
[0075.493] of_register: registering tca9539_gpio to of_hal
[0075.499] of_register: registering i2c_bus_driver to of_hal
[0075.504] of_register: registering i2c_bus_driver to of_hal
[0075.510] of_register: registering i2c_bus_driver to of_hal
[0075.515] pmic framework initialized
[0075.519] of_register: registering max77620_pmic to of_hal
[0075.524] regulator framework initialized
[0075.528] of_register: registering tps65132_bl_driver to of_hal
[0075.534] initializing target
[0075.540] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0075.551] fixed regulator driver initialized
[0075.568] initializing OF layer
[0075.572] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0075.589] I2C Bus Init done
[0075.592] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0075.602] I2C Bus Init done
[0075.605] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0075.615] I2C Bus Init done
[0075.618] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0075.628] I2C Bus Init done
[0075.631] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0075.641] I2C Bus Init done
[0075.644] of_children_init: Ops found for compatible string maxim,max77620
[0075.654] max77620_init using irq 118
[0075.659] register ‘maxim,max77620’ pmic
[0075.663] gpio_driver_register: register ‘max77620-gpio’ driver
[0075.669] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0075.680] I2C Bus Init done
[0075.684] Applying platform configs
[0075.691] platform-init is not present. Skipping
[0075.695] calling apps_init()
[0075.711] Found 17 GPT partitions in “sdmmc3_user”
[0075.716] Proceeding to flashing Server
[0075.720] usbdcd_reinit Initialize driver to use already enumerated device
[0075.727] nv3p_priv_usbf_open USB configuration success
[0075.770] Writing GPT partition
[0075.774] Erasing Boot device
[0075.777] device_write_gpt: Erasing boot device sdmmc3_boot
[0075.811] Erasing Storage Device
[0076.770] Sanitizing Storage Device
[0076.779] Writing protective mbr
[0076.788] Writing primary GPT
[0076.827] Writing secondary GPT
[0076.850] Found 17 GPT partitions in “sdmmc3_user”
[0076.855] Writing NVC partition
[0076.885] partition NVC write successful.
[0076.889] Writing PT partition
[0076.911] partition PT write successful.
[0076.916] Writing TBC partition
[0076.980] partition TBC write successful.
[0076.985] Writing RP1 partition
[0077.053] partition RP1 write successful.
[0077.058] Writing EBT partition
[0077.139] partition EBT write successful.
[0077.144] Writing WB0 partition
[0077.204] partition WB0 write successful.
[0077.208] Writing BPF partition
[0077.268] partition BPF write successful.
[0077.273] Writing NVC-1 partition
[0077.352] partition NVC-1 write successful.
[0077.358] Writing PT-1 partition
[0077.430] partition PT-1 write successful.
[0077.435] Writing TBC-1 partition
[0077.509] partition TBC-1 write successful.
[0077.514] Writing RP1-1 partition
[0077.595] partition RP1-1 write successful.
[0077.600] Writing EBT-1 partition
[0077.694] partition EBT-1 write successful.
[0077.699] Writing WB0-1 partition
[0077.771] partition WB0-1 write successful.
[0077.776] Writing BPF-1 partition
[0077.848] partition BPF-1 write successful.
[0077.854] Writing VER_b partition
[0077.916] partition VER_b write successful.
[0077.921] Writing VER partition
[0077.984] partition VER write successful.
[0077.989] Writing APP partition
[0465.638] partition APP write successful.
[0465.643] Writing DTB partition
[0465.695] partition DTB write successful.
[0465.700] Writing TOS partition
[0465.743] partition TOS write successful.
[0465.750] Writing EKS partition
[0465.791] partition EKS write successful.
[0465.795] Writing LNX partition
[0465.847] partition LNX write successful.
[0465.852] Writing DTB-1 partition
[0465.904] partition DTB-1 write successful.
[0465.909] Writing TOS-1 partition
[0465.952] partition TOS-1 write successful.
[0465.957] Writing EKS-1 partition
[0465.998] partition EKS-1 write successful.
[0466.003] Writing LNX-1 partition
[0466.054] partition LNX-1 write successful.
[0466.060] Writing BMP partition
[0466.107] partition BMP write successful.
[0466.112] Writing RP4 partition
[0466.158] partition RP4 write successful.
[0466.173] Writing BCT partition
[0466.565] partition BCT write successful.
[0466.578] Change state to cold boot mode
[0466.582] Flushing data to stroage
[0000.201] [L4T TegraBoot] (version 00.00.2018.01-l4t-39a9dc3d)
[0000.207] Processing in cold boot mode Bootloader 2
[0000.212] A02 Bootrom Patch rev = 1023
[0000.215] Power-up reason: software reset
[0000.219] No Battery Present
[0000.222] pmic max77620 reset reason
[0000.225] pmic max77620 NVERC : 0x0
[0000.228] RamCode = 0
[0000.230] Platform has DDR4 type RAM
[0000.234] max77620 disabling SD1 Remote Sense
[0000.238] Setting DDR voltage to 1125mv
[0000.242] Serial Number of Pmic Max77663: 0x210bed
[0000.250] Entering ramdump check
[0000.253] Get RamDumpCarveOut = 0x0
[0000.256] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.261] Last reboot was clean, booting normally!
[0000.266] Sdram initialization is successful
[0000.270] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.276] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.282] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.288] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.293] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.299] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.305] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.311] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.327] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.333] Platform-DebugCarveout: 0
[0000.336] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.342] Non secure mode, and RB not enabled.
[0000.359] Csd NumOfBlocks=0
[0000.552] *** Booting BFS0.
[0000.558] Using BFS PT to query partitions
[0001.222] *** Booting KFS0.
[0001.226] Using GPT Primary to query partitions
[0001.231] Loading Tboot-CPU binary
[0001.238] Verifying TBC in OdmNonSecureSBK mode
[0001.248] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.255] Bootloader downloaded successfully.
[0001.259] Downloaded Tboot-CPU binary to 0xa0000258
[0001.264] MAX77620_GPIO5 configured
[0001.267] CPU power rail is up
[0001.270] CPU clock enabled
[0001.274] Performing RAM repair
[0001.277] Updating A64 Warmreset Address to 0xa00002e9
[0001.282] Loading NvTbootBootloaderDTB
[0001.299] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0001.365] Bootloader DTB Load Address: 0x83000000
[0001.369] Loading NvTbootKernelDTB
[0001.386] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0001.451] Kernel DTB Load Address: 0x83100000
[0001.457] Loading cboot binary
[0001.468] Verifying EBT in OdmNonSecureSBK mode
[0001.509] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.516] Bootloader downloaded successfully.
[0001.521] Next binary entry address: 0x92c00258
[0001.525] BoardId: 3448
[0001.530] Overriding pmu board id with proc board id
[0001.535] Display board id is not available
[0001.546] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.598] /bpmp deleted
[0001.601] SC7EntryFw header found loaded at 0xff700000
[0001.789] OVR2 PMIC
[0001.791] Bpmp FW successfully loaded
[0001.796] WB0 init successfully at 0xff780000
[0001.800] Set NvDecSticky Bits
[0001.804] GSC2 address ff53fffc value c0edbbcc
[0001.810] GSC MC Settings done
[0001.813] TOS Image length 53680
[0001.816] Monitor size 53680
[0001.819] OS size 0
[0001.824] Secure Os AES-CMAC Verification Success!
[0001.829] TOS image cipher info: plaintext
[0001.833] Loading and Validation of Secure OS Successful
[0001.848] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.853] NvTbootPackSdramParams: start.
[0001.858] NvTbootPackSdramParams: done.
[0001.862] Tegraboot started after 130489 us
[0001.866] Basic modules init took 1446070 us
[0001.870] Sec Bootdevice Read Time = 626 ms, Read Size = 14457 KB
[0001.876] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.881] Next stage binary read took 7391 us
[0001.886] Carveout took -19265 us
[0001.889] CPU initialization took 342371 us
[0001.893] Total time taken by TegraBoot 1776567 us
[0001.898] Starting CPU & Halting co-processor
[0002.020] RamCode = 0
[0002.024] LPDDR4 Training: Read DT: Number of tables = 2
[0002.029] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.042] EMC Training Successful
[0002.045] 408000 not found in DVFS table
[0002.052] RamCode = 0
[0002.055] DT Write: emc-table@204000 succeeded
[0002.061] DT Write: emc-table@1600000 succeeded
[0002.065] LPDDR4 Training: Write DT: Number of tables = 2
[0002.124]
[0002.125] Debug Init done
[0002.127] Marked DTB cacheable
[0002.130] Bootloader DTB loaded at 0x83000000
[0002.135] Marked DTB cacheable
[0002.138] Kernel DTB loaded at 0x83100000
[0002.142] DeviceTree Init done
[0002.157] Pinmux applied successfully
[0002.162] gicd_base: 0x50041000
[0002.165] gicc_base: 0x50042000
[0002.168] Interrupts Init done
[0002.172] Using base:0x60005090 & irq:208 for tick-timer
[0002.178] Using base:0x60005098 for delay-timer
[0002.182] platform_init_timer: DONE
[0002.186] Timer(tick) Init done
[0002.189] osc freq = 38400 khz
[0002.193]
[0002.195] Welcome to L4T Cboot
[0002.198]
[0002.199] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0002.204] calling constructors
[0002.207] initializing heap
[0002.209] initializing threads
[0002.212] initializing timers
[0002.215] creating bootstrap completion thread
[0002.219] top of bootstrap2()
[0002.222] CPU: ARM Cortex A57
[0002.225] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.230] initializing platform
[0002.284] Config for emmc ddr50 mode completed
[0002.288] sdmmc bdev is already initialized
[0002.292] Enable APE clock
[0002.295] Un-powergate APE partition
[0002.298] of_register: registering tegra_udc to of_hal
[0002.304] of_register: registering inv20628-driver to of_hal
[0002.309] of_register: registering ads1015-driver to of_hal
[0002.315] of_register: registering lp8557-bl-driver to of_hal
[0002.320] of_register: registering bq2419x_charger to of_hal
[0002.326] of_register: registering bq27441_fuel_gauge to of_hal
[0002.338] gpio framework initialized
[0002.341] of_register: registering tca9539_gpio to of_hal
[0002.346] of_register: registering tca9539_gpio to of_hal
[0002.352] of_register: registering i2c_bus_driver to of_hal
[0002.357] of_register: registering i2c_bus_driver to of_hal
[0002.363] of_register: registering i2c_bus_driver to of_hal
[0002.368] pmic framework initialized
[0002.372] of_register: registering max77620_pmic to of_hal
[0002.377] regulator framework initialized
[0002.381] of_register: registering tps65132_bl_driver to of_hal
[0002.387] initializing target
[0002.393] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.404] fixed regulator driver initialized
[0002.421] initializing OF layer
[0002.424] NCK carveout not present
[0002.427] Skipping dts_overrides
[0002.432] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.448] I2C Bus Init done
[0002.451] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.461] I2C Bus Init done
[0002.464] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.474] I2C Bus Init done
[0002.477] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.487] I2C Bus Init done
[0002.490] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.500] I2C Bus Init done
[0002.503] of_children_init: Ops found for compatible string maxim,max77620
[0002.513] max77620_init using irq 118
[0002.518] register ‘maxim,max77620’ pmic
[0002.522] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.529] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.539] I2C Bus Init done
[0002.543] NCK carveout not present
[0002.553] Find /i2c@7000c000’s alias i2c0
[0002.557] get eeprom at 1-a0, size 256, type 0
[0002.565] Find /i2c@7000c500’s alias i2c2
[0002.569] get eeprom at 3-a0, size 256, type 0
[0002.574] get eeprom at 3-ae, size 256, type 0
[0002.578] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.583] I2C slave not started
[0002.586] I2C write failed
[0002.589] Writing offset failed
[0002.592] eeprom_init: EEPROM read failed
[0002.596] pm_ids_update: eeprom init failed
[0002.600] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.630] pm_ids_update: The pm board id is 3448-0002-400
[0002.637] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.645] pm_ids_update: pm id update successful
[0002.649] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.679] pm_ids_update: The pm board id is 3449-0000-400
[0002.686] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.694] pm_ids_update: pm id update successful
[0002.724] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.730] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.738] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.744] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.753] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d1:73
[0002.759] Plugin Manager: Parse ODM data 0x00094000
[0002.769] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0002.794] Find /i2c@7000c000’s alias i2c0
[0002.798] get eeprom at 1-a0, size 256, type 0
[0002.807] Find /i2c@7000c500’s alias i2c2
[0002.810] get eeprom at 3-a0, size 256, type 0
[0002.815] get eeprom at 3-ae, size 256, type 0
[0002.819] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.825] I2C slave not started
[0002.828] I2C write failed
[0002.830] Writing offset failed
[0002.833] eeprom_init: EEPROM read failed
[0002.837] pm_ids_update: eeprom init failed
[0002.841] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.871] pm_ids_update: The pm board id is 3448-0002-400
[0002.878] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.885] pm_ids_update: pm id update successful
[0002.889] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.919] pm_ids_update: The pm board id is 3449-0000-400
[0002.926] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.933] pm_ids_update: pm id update successful
[0002.964] Add serial number:1423019114890 as DT property
[0002.971] Applying platform configs
[0002.978] platform-init is not present. Skipping
[0002.983] calling apps_init()
[0002.998] Found 17 GPT partitions in “sdmmc3_user”
[0003.003] Proceeding to Cold Boot
[0003.006] starting app android_boot_app
[0003.010] Device state: unlocked
[0003.013] display console init
[0003.022] could not find regulator
[0003.025] hdmi cable connected
[0003.041] edid read success
[0003.058] DT entry for leds-pwm not found
[0003.062] edid read success
[0003.065] width = 640, height = 480, frequency = 25174825
[0003.070] width = 640, height = 480, frequency = 25174825
[0003.076] width = 640, height = 480, frequency = 25174825
[0003.081] width = 640, height = 480, frequency = 25174825
[0003.086] width = 3840, height = 2160, frequency = 533250000
[0003.092] width = 3840, height = 2160, frequency = 262750000
[0003.098] width = 2560, height = 1440, frequency = 241500000
[0003.103] width = 1920, height = 1080, frequency = 148351648
[0003.109] width = 1280, height = 720, frequency = 74175824
[0003.114] width = 720, height = 480, frequency = 26973026
[0003.120] width = 1920, height = 1080, frequency = 148351648
[0003.126] width = 1280, height = 720, frequency = 74175824
[0003.131] width = 640, height = 480, frequency = 25174825
[0003.136] width = 720, height = 576, frequency = 26973026
[0003.142] width = 3840, height = 2160, frequency = 296703296
[0003.147] width = 3840, height = 2160, frequency = 593406593
[0003.153] width = 3840, height = 2160, frequency = 296703296
[0003.159] width = 3840, height = 2160, frequency = 296703296
[0003.164] width = 3840, height = 2160, frequency = 296703296
[0003.170] Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.178] tmds-config node not found
[0003.182] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0003.197] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0003.204] could not find regulator
[0003.207] could not find regulator
[0003.211] could not find regulator
[0003.239] using default cmu settings
[0003.243] dc_hdmi_enable, starting HDMI initialisation
[0003.249] dc_hdmi_enable, HDMI initialisation complete
[0003.254] list and configure display window
[0003.263] display console init completed
[0003.274] subnode volume_up is not found !
[0003.278] subnode back is not found !
[0003.281] subnode volume_down is not found !
[0003.285] subnode menu is not found !
[0003.289] Gpio keyboard init success
[0003.336] found decompressor handler: lz4-legacy
[0003.351] decompressing blob (type 1)…
[0003.386] load_bmp_blob: panelresolution=1080 type=3
[0003.436] decompressor handler not found
[0003.439] load_firmware_blob: Firmware blob loaded, entries=2
[0003.445] -------> se_aes_verify_sbk_clear: 747
[0003.450] se_aes_verify_sbk_clear: Error
[0003.454] bl_battery_charging: connected to external power supply
[0003.461] xusb is supported
[0003.467] error while finding nvidia,portmap
[0003.971] xusb blob version 0 size 124416
[0003.975] firmware size 124416
[0003.980] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.995] xhci0: 64 bytes context size, 32-bit DMA
[0004.035] usbus0: 5.0Gbps Super Speed USB v3.0
[0004.055] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.705] uhub0: 9 ports with 9 removable, self powered
[0005.705] failed to get HID devices
[0005.708] failed to init xhci or no usb device attached
[0005.722] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0005.730] MSC Partition not found
[0005.739] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0005.747] USP partition read failed!
[0005.750] blob_init: blob-partition USP header read failed
[0005.756] android_boot Unable to update recovery partition
[0005.761] kfs_getpartname: name = LNX
[0005.765] Loading kernel from LNX
[0005.829] load kernel from storage
[0005.839] decompressor handler not found
[0005.858] Successfully loaded kernel and ramdisk images
[0005.864] load_bmp_blob: panelresolution=1080 type=3
[0006.358] display bmp image done
[0006.362] NCK carveout not present
[0006.365] Skipping dts_overrides
[0006.368] NCK carveout not present
[0006.378] Find /i2c@7000c000’s alias i2c0
[0006.382] get eeprom at 1-a0, size 256, type 0
[0006.391] Find /i2c@7000c500’s alias i2c2
[0006.395] get eeprom at 3-a0, size 256, type 0
[0006.399] get eeprom at 3-ae, size 256, type 0
[0006.403] pm_ids_update: Updating 1,a0, size 256, type 0
[0006.409] I2C slave not started
[0006.412] I2C write failed
[0006.414] Writing offset failed
[0006.417] eeprom_init: EEPROM read failed
[0006.421] pm_ids_update: eeprom init failed
[0006.425] pm_ids_update: Updating 3,a0, size 256, type 0
[0006.456] pm_ids_update: The pm board id is 3448-0002-400
[0006.462] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0006.470] pm_ids_update: pm id update successful
[0006.475] pm_ids_update: Updating 3,ae, size 256, type 0
[0006.505] pm_ids_update: The pm board id is 3449-0000-400
[0006.511] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0006.519] pm_ids_update: pm id update successful
[0006.550] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.556] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0006.564] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.570] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0006.578] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d1:73
[0006.585] Plugin Manager: Parse ODM data 0x00094000
[0006.595] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.612] Add serial number:1423019114890 as DT property
[0006.622] “bpmp” doesn’t exist, creating
[0006.627] Updated bpmp info to DTB
[0006.632] Updated initrd info to DTB
[0006.635] “proc-board” doesn’t exist, creating
[0006.641] Updated board info to DTB
[0006.644] “pmu-board” doesn’t exist, creating
[0006.650] Updated board info to DTB
[0006.653] “display-board” doesn’t exist, creating
[0006.659] Updated board info to DTB
[0006.662] “reset” doesn’t exist, creating
[0006.667] Updated reset info to DTB
[0006.670] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 consol
[0006.709] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.724] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.740] Updated bootarg info to DTB
[0006.744] Adding uuid 00000001644568040000000006fd8400 to DT
[0006.750] Adding eks info 0 to DT
[0006.756] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.761] Updated memory info to DTB
[0006.770] set vdd_core voltage to 1075 mv
[0006.774] setting ‘vdd-core’ regulator to 1075000 micro volts
[0006.795] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1…
701 bytes read in 117 ms (4.9 KiB/s)
1: primary kernel
5487751 bytes read in 230 ms (22.8 MiB/s)
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SM9
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb0000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d32616 u102400
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29328(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562224K/4159488K available (15230K kernel code, 2926K rwdata, 6620K rodata, 8576K init, 609K bss, 122128K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001824] Console: colour dummy device 80x25
[ 0.002686] console [tty0] enabled
[ 0.002714] kmemleak: Kernel memory leak detector disabled
[ 0.002746] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002776] pid_max: default: 32768 minimum: 301
[ 0.003240] Security Framework initialized
[ 0.003479] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003499] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004762] ftrace: allocating 47001 entries in 184 pages
[ 0.178260] ASID allocator initialised with 65536 entries
[ 0.216192] tegra-id: chipid=22117.
[ 0.216273] tegra-id: opt_subrevision=0.
[ 0.216303] Tegra Speedo/IDDQ fuse revision 4
[ 0.216318] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216334] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.216350] Tegra: CPU Speedo Value 2044, SoC Speedo Value 1954, GPU Speedo Value 2062
[ 0.216371] Tegra: CPU IDDQ Value 1660, SoC IDDQ Value 1920, GPU IDDQ Value 2395
[ 0.216406] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.216434] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.216468] DTB Build time: Dec 9 2019 22:51:55
[ 0.265076] CPU1: Booted secondary processor [411fd071]
[ 0.297019] CPU2: Booted secondary processor [411fd071]
[ 0.328979] CPU3: Booted secondary processor [411fd071]
[ 0.329069] Brought up 4 CPUs
[ 0.329135] SMP: Total of 4 processors activated.
[ 0.329153] CPU features: detected feature: 32-bit EL0 Support
[ 0.329432] CPU: All CPU(s) started at EL2
[ 0.329463] alternatives: patching kernel code
[ 0.337847] devtmpfs: initialized
[ 0.375810] Initilizing CustomIPI irq domain
[ 0.376248] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.376294] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.387814] pinctrl core: initialized pinctrl subsystem
[ 0.388555] OS set in device tree is not L4T.
[ 0.389004] regulator-dummy: no parameters
[ 0.389369] Initializing plugin-manager
[ 0.389501] Plugin module not found
[ 0.389744] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.390338] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.390862] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.391575] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.392020] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.392676] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.394882] node /plugin-manager/fragement@11 match with board >=3448-0002-300
[ 0.398491] NET: Registered protocol family 16
[ 0.399866] pstore: using zlib compression
[ 0.400562] console [pstore-1] enabled
[ 0.400580] pstore: Registered ramoops as persistent store backend
[ 0.400599] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417092] cpuidle: using governor menu
[ 0.421508] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.423202] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.423248] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425632] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.428290] tegra_powergate_init: DONE
[ 0.428328] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.428365] DTB Build time: Dec 9 2019 22:51:55
[ 0.430210] Tegra reboot handler registered.
[ 0.434830] iommu: Adding device tegra-carveouts to group 0
[ 0.435009] platform tegra-carveouts: domain=ffffffc0f9b5f318 allocates as[0]=ffffffc0f94240a8
[ 0.435402] iommu: Adding device smmu_test to group 1
[ 0.435473] platform smmu_test: domain=ffffffc0f9b5f558 allocates as[0]=ffffffc0f9424110
[ 0.436347] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.436427] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.436498] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.436522] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.436558] mc-err: mcerr ops are set to t21x
[ 0.446520] iommu: Adding device 70090000.xusb to group 2
[ 0.446844] iommu: Adding device 70006000.serial to group 3
[ 0.446938] platform 70006000.serial: domain=ffffffc0f94bd618 allocates as[0]=ffffffc0f9424178
[ 0.447391] iommu: Adding device 70006040.serial to group 4
[ 0.447679] iommu: Adding device 70006200.serial to group 5
[ 0.447926] iommu: Adding device sound to group 6
[ 0.447989] platform sound: domain=ffffffc0f94bdb58 allocates as[0]=ffffffc0f94241e0
[ 0.448581] iommu: Adding device 7000d400.spi to group 7
[ 0.448868] iommu: Adding device 7000d600.spi to group 8
[ 0.449283] iommu: Adding device 50000000.host1x to group 9
[ 0.449581] iommu: Adding device 54080000.vi to group 10
[ 0.449985] iommu: Adding device 54600000.isp to group 11
[ 0.450255] iommu: Adding device 54680000.isp to group 12
[ 0.450542] iommu: Adding device tegradc.0 to group 13
[ 0.450636] platform tegradc.0: domain=ffffffc0f94ca918 allocates as[0]=ffffffc0f9424248
[ 0.454835] platform tegradc.0: IOVA linear map 0x0000000092cb0000(800000)
[ 0.455247] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.455620] iommu: Adding device tegradc.1 to group 14
[ 0.455694] platform tegradc.1: domain=ffffffc0f94cab58 allocates as[0]=ffffffc0f94242b0
[ 0.459888] platform tegradc.1: IOVA linear map 0x0000000092cb0000(800000)
[ 0.460297] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.460553] iommu: Adding device 54340000.vic to group 15
[ 0.460785] iommu: Adding device 544c0000.nvenc to group 16
[ 0.461001] iommu: Adding device 54500000.tsec to group 17
[ 0.461260] iommu: Adding device 54100000.tsecb to group 18
[ 0.461480] iommu: Adding device 54480000.nvdec to group 19
[ 0.461690] iommu: Adding device 54380000.nvjpg to group 20
[ 0.462781] iommu: Adding device 546c0000.i2c to group 21
[ 0.463132] iommu: Adding device 57000000.gpu to group 22
[ 0.463202] platform 57000000.gpu: domain=ffffffc0f94d8b58 allocates as[0]=ffffffc0f9424318
[ 0.463262] platform 57000000.gpu: domain=ffffffc0f94d8b58 allocates as[1]=ffffffc0f9424380
[ 0.463322] platform 57000000.gpu: domain=ffffffc0f94d8b58 allocates as[2]=ffffffc0f94243e8
[ 0.463382] platform 57000000.gpu: domain=ffffffc0f94d8b58 allocates as[3]=ffffffc0f9424450
[ 0.464290] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.464330] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.464357] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.464378] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.464396] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.517189] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.517222] tegra-pmc: Clear bootloader IO dpd settings
[ 0.517254] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.517337] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.517662] iommu: Adding device 70012000.se to group 23
[ 0.518511] iommu: Adding device 7000c000.i2c to group 24
[ 0.518839] iommu: Adding device 7000c400.i2c to group 25
[ 0.519174] iommu: Adding device 7000c500.i2c to group 26
[ 0.519504] iommu: Adding device 7000c700.i2c to group 27
[ 0.519818] iommu: Adding device 7000d000.i2c to group 28
[ 0.520169] iommu: Adding device 7000d100.i2c to group 29
[ 0.520506] iommu: Adding device sdhci-tegra.3 to group 30
[ 0.520584] platform sdhci-tegra.3: domain=ffffffc0f955dcd8 allocates as[0]=ffffffc0f94244b8
[ 0.521707] iommu: Adding device 700d0000.xudc to group 31
[ 0.526112] vdd-ac-bat: 5000 mV
[ 0.526560] vdd-5v0-sys: 5000 mV
[ 0.527716] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.527807] vdd-5v0-hdmi: 5000 mV
[ 0.528275] vdd-1v8-sys: 1800 mV
[ 0.528686] vdd-fan: supplied by vdd-5v0-sys
[ 0.528737] vdd-fan: 5000 mV
[ 0.529239] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.529311] vdd-usb-vbus: 5000 mV
[ 0.529927] vdd-usb-vbus2: 5000 mV
[ 0.558423] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.561033] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.562170] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.562207] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.562257] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.562643] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.570925] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.571335] SCSI subsystem initialized
[ 0.571848] usbcore: registered new interface driver usbfs
[ 0.571920] usbcore: registered new interface driver hub
[ 0.572014] usbcore: registered new device driver usb
[ 0.576067] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.580235] random: fast init done
[ 0.580425] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.581463] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.584243] vdd-ddr-1v1: 1150 mV
[ 0.588241] vdd-pre-reg-1v35: 1350 mV
[ 0.592238] vdd-1v8: 1800 mV
[ 0.596239] avdd-sys-1v2: 1200 mV
[ 0.600239] vdd-pex-1v0: 1050 mV
[ 0.600895] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.601460] max77620-ldo3: at 3100 mV
[ 0.604247] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.604796] max77620-ldo5: at 3100 mV
[ 0.608238] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.612236] avdd-1v05-pll: 1050 mV
[ 0.616237] avdd-io-hdmi-dp: 1050 mV
[ 0.618895] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.619206] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.619539] max77620 4-003c: max77620 probe successful
[ 0.622315] media: Linux media interface: v0.10
[ 0.622397] Linux video capture interface: v2.00
[ 0.623315] pps_core: LinuxPPS API ver. 1 registered
[ 0.623342] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.623383] PTP clock support registered
[ 0.627098] tegra_fiq_debugger_init: found FIQ source (IRQ 97)
[ 0.633661] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.634545] Advanced Linux Sound Architecture Driver Initialized.
[ 0.635233] Bluetooth: Core ver 2.22
[ 0.635304] NET: Registered protocol family 31
[ 0.635322] Bluetooth: HCI device and connection manager initialized
[ 0.635351] Bluetooth: HCI socket layer initialized
[ 0.635372] Bluetooth: L2CAP socket layer initialized
[ 0.635411] Bluetooth: SCO socket layer initialized
[ 0.637246] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.637290] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.637352] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.637380] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.640673] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.641882] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.641973] vdd-3v3-sys: 3300 mV
[ 0.642294] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.644320] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.644800] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.644857] vdd-3v3-sd: 3300 mV
[ 0.645858] avdd-io-edp-1v05: supplied by avdd-1v05-pl
