Thank you for answering.
I got the serial console log.
Do you know what the problem is?
There is a system configuration log on the last line, but the system configuration is completed on the GUI, but no more logs are output.
[0000.260] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.265] Processing in cold boot mode Bootloader 2
[0000.270] A02 Bootrom Patch rev = 1023
[0000.274] Power-up reason: pmc por
[0000.277] No Battery Present
[0000.279] pmic max77620 reset reason
[0000.283] pmic max77620 NVERC : 0x40
[0000.286] RamCode = 0
[0000.288] Platform has DDR4 type RAM
[0000.292] max77620 disabling SD1 Remote Sense
[0000.296] Setting DDR voltage to 1125mv
[0000.300] Serial Number of Pmic Max77663: 0x1009f0
[0000.308] Entering ramdump check
[0000.311] Get RamDumpCarveOut = 0x0
[0000.314] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.319] Last reboot was clean, booting normally!
[0000.324] Sdram initialization is successful
[0000.328] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.334] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.340] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.346] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.351] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.357] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.363] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.369] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.385] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.391] Platform-DebugCarveout: 0
[0000.394] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.400] Non secure mode, and RB not enabled.
[0000.417] Csd NumOfBlocks=0
[0000.612] *** Booting BFS0.
[0000.614] Read PT from (0:3)
[0000.620] Using BFS PT to query partitions
[0000.625] PT: Partition LNX NOT found !
[0001.224] *** Booting KFS0.
[0001.227] BoardID = 3448, SKU = 0x2
[0001.230] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.236] Read GPT from (0:3)
[0001.243] Using GPT Primary to query partitions
[0001.248] Loading Tboot-CPU binary
[0001.255] Verifying TBC in OdmNonSecureSBK mode
[0001.265] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.272] Bootloader downloaded successfully.
[0001.276] Downloaded Tboot-CPU binary to 0xa0000258
[0001.282] MAX77620_GPIO5 configured
[0001.285] CPU power rail is up
[0001.288] CPU clock enabled
[0001.291] Performing RAM repair
[0001.294] Updating A64 Warmreset Address to 0xa00002e9
[0001.299] BoardID = 3448, SKU = 0x2
[0001.303] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.309] Loading NvTbootBootloaderDTB
[0001.326] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0001.399] Bootloader DTB Load Address: 0x83000000
[0001.404] BoardID = 3448, SKU = 0x2
[0001.407] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.413] Loading NvTbootKernelDTB
[0001.429] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0001.502] Kernel DTB Load Address: 0x83100000
[0001.506] BoardID = 3448, SKU = 0x2
[0001.510] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.517] Loading cboot binary
[0001.528] Verifying EBT in OdmNonSecureSBK mode
[0001.570] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.577] Bootloader downloaded successfully.
[0001.581] BoardID = 3448, SKU = 0x2
[0001.584] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.590] PT: Partition NCT NOT found !
[0001.594] Warning: Find Partition via PT Failed
[0001.598] Next binary entry address: 0x92c00258
[0001.603] BoardId: 3448
[0001.607] Overriding pmu board id with proc board id
[0001.612] Display board id is not available
[0001.617] BoardID = 3448, SKU = 0x2
[0001.620] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.633] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.690] /bpmp deleted
[0001.692] SC7EntryFw header found loaded at 0xff700000
[0001.887] OVR2 PMIC
[0001.889] Bpmp FW successfully loaded
[0001.893] BoardID = 3448, SKU = 0x2
[0001.896] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.903] WB0 init successfully at 0xff780000
[0001.907] Set NvDecSticky Bits
[0001.911] GSC2 address ff53fffc value c0edbbcc
[0001.917] GSC MC Settings done
[0001.920] BoardID = 3448, SKU = 0x2
[0001.924] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.930] TOS Image length 53680
[0001.933] Monitor size 53680
[0001.936] OS size 0
[0001.941] Secure Os AES-CMAC Verification Success!
[0001.946] TOS image cipher info: plaintext
[0001.950] Loading and Validation of Secure OS Successful
[0001.966] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.970] NvTbootPackSdramParams: start.
[0001.975] NvTbootPackSdramParams: done.
[0001.979] Tegraboot started after 190305 us
[0001.983] Basic modules init took 1475182 us
[0001.987] Sec Bootdevice Read Time = 558 ms, Read Size = 14649 KB
[0001.993] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.999] Next stage binary read took 7373 us
[0002.003] Carveout took -28680 us
[0002.006] CPU initialization took 382955 us
[0002.010] Total time taken by TegraBoot 1836830 us
[0002.015] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:37:40, Feb 19 2021
ERROR: Error initializing runtime service trusty_fast
[0002.137] RamCode = 0
[0002.142] LPDDR4 Training: Read DT: Number of tables = 2
[0002.147] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.160] EMC Training Successful
[0002.163] 408000 not found in DVFS table
[0002.169] RamCode = 0
[0002.173] DT Write: emc-table@204000 succeeded
[0002.178] DT Write: emc-table@1600000 succeeded
[0002.182] LPDDR4 Training: Write DT: Number of tables = 2
[0002.243]
[0002.245] Debug Init done
[0002.247] Marked DTB cacheable
[0002.250] Bootloader DTB loaded at 0x83000000
[0002.255] Marked DTB cacheable
[0002.258] Kernel DTB loaded at 0x83100000
[0002.262] DeviceTree Init done
[0002.275] Pinmux applied successfully
[0002.279] gicd_base: 0x50041000
[0002.283] gicc_base: 0x50042000
[0002.285] Interrupts Init done
[0002.290] Using base:0x60005090 & irq:208 for tick-timer
[0002.295] Using base:0x60005098 for delay-timer
[0002.299] platform_init_timer: DONE
[0002.303] Timer(tick) Init done
[0002.307] osc freq = 38400 khz
[0002.310]
[0002.311] Welcome to L4T Cboot
[0002.314]
[0002.316] Cboot Version: 00.00.2018.01-t210-39562017
[0002.321] calling constructors
[0002.323] initializing heap
[0002.326] initializing threads
[0002.329] initializing timers
[0002.332] creating bootstrap completion thread
[0002.336] top of bootstrap2()
[0002.339] CPU: ARM Cortex A57
[0002.342] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.347] initializing platform
[0002.401] Config for emmc ddr50 mode completed
[0002.405] sdmmc bdev is already initialized
[0002.409] Enable APE clock
[0002.412] Un-powergate APE partition
[0002.415] of_register: registering tegra_udc to of_hal
[0002.420] of_register: registering inv20628-driver to of_hal
[0002.426] of_register: registering ads1015-driver to of_hal
[0002.432] of_register: registering lp8557-bl-driver to of_hal
[0002.437] of_register: registering bq2419x_charger to of_hal
[0002.443] of_register: registering bq27441_fuel_gauge to of_hal
[0002.455] gpio framework initialized
[0002.458] of_register: registering tca9539_gpio to of_hal
[0002.463] of_register: registering tca9539_gpio to of_hal
[0002.469] of_register: registering i2c_bus_driver to of_hal
[0002.474] of_register: registering i2c_bus_driver to of_hal
[0002.480] of_register: registering i2c_bus_driver to of_hal
[0002.485] pmic framework initialized
[0002.489] of_register: registering max77620_pmic to of_hal
[0002.494] regulator framework initialized
[0002.498] of_register: registering tps65132_bl_driver to of_hal
[0002.504] initializing target
[0002.510] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.521] fixed regulator driver initialized
[0002.539] initializing OF layer
[0002.542] NCK carveout not present
[0002.545] Skipping dts_overrides
[0002.549] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.566] I2C Bus Init done
[0002.569] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.579] I2C Bus Init done
[0002.582] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.592] I2C Bus Init done
[0002.595] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.605] I2C Bus Init done
[0002.608] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.618] I2C Bus Init done
[0002.621] of_children_init: Ops found for compatible string maxim,max77620
[0002.631] max77620_init using irq 118
[0002.636] register ‘maxim,max77620’ pmic
[0002.640] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.646] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.657] I2C Bus Init done
[0002.661] NCK carveout not present
[0002.670] Find /i2c@7000c000’s alias i2c0
[0002.674] get eeprom at 1-a0, size 256, type 0
[0002.683] Find /i2c@7000c500’s alias i2c2
[0002.687] get eeprom at 3-a0, size 256, type 0
[0002.691] get eeprom at 3-ae, size 256, type 0
[0002.696] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.701] I2C slave not started
[0002.704] I2C write failed
[0002.707] Writing offset failed
[0002.710] eeprom_init: EEPROM read failed
[0002.714] pm_ids_update: eeprom init failed
[0002.718] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.748] pm_ids_update: The pm board id is 3448-0002-400
[0002.755] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.763] pm_ids_update: pm id update successful
[0002.768] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.798] pm_ids_update: The pm board id is 3449-0000-400
[0002.804] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.812] pm_ids_update: pm id update successful
[0002.842] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.848] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.856] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.862] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.870] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2f:d8:ca
[0002.877] Plugin Manager: Parse ODM data 0x000a4000
[0002.889] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.904] Find /i2c@7000c000’s alias i2c0
[0002.908] get eeprom at 1-a0, size 256, type 0
[0002.917] Find /i2c@7000c500’s alias i2c2
[0002.920] get eeprom at 3-a0, size 256, type 0
[0002.925] get eeprom at 3-ae, size 256, type 0
[0002.929] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.934] I2C slave not started
[0002.937] I2C write failed
[0002.940] Writing offset failed
[0002.943] eeprom_init: EEPROM read failed
[0002.947] pm_ids_update: eeprom init failed
[0002.951] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.981] pm_ids_update: The pm board id is 3448-0002-400
[0002.988] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.994] pm_ids_update: pm id update successful
[0002.999] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.029] pm_ids_update: The pm board id is 3449-0000-400
[0003.035] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0003.042] pm_ids_update: pm id update successful
[0003.073] Add serial number:1421421077842 as DT property
[0003.080] Applying platform configs
[0003.087] platform-init is not present. Skipping
[0003.092] calling apps_init()
[0003.113] Found 17 GPT partitions in “sdmmc3_user”
[0003.118] Proceeding to Cold Boot
[0003.121] starting app android_boot_app
[0003.125] Device state: unlocked
[0003.128] display console init
[0003.136] could not find regulator
[0003.139] hdmi cable connected
[0003.155] edid read success
[0003.157] width = 640, height = 480, frequency = 25174825
[0003.163] width = 640, height = 480, frequency = 25174825
[0003.168] width = 1920, height = 1080, freDT entry for leds-pwm not found
q[0003.178] uency = 148500000
[0003.181] Best mode Width = 640, Height = 480, freq = 25174825
[0003.189] tmds-config node not found
[0003.193] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0003.207] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0003.215] could not find regulator
[0003.218] could not find regulator
[0003.222] could not find regulator
[0003.250] using default cmu settings
[0003.254] dc_hdmi_enable, starting HDMI initialisation
[0003.260] dc_hdmi_enable, HDMI initialisation complete
[0003.265] list and configure display window
[0003.270] display console init completed
[0003.277] subnode volume_up is not found !
[0003.281] subnode back is not found !
[0003.285] subnode volume_down is not found !
[0003.289] subnode menu is not found !
[0003.293] Gpio keyboard init success
[0003.341] found decompressor handler: lz4-legacy
[0003.356] decompressing blob (type 1)…
[0003.423] load_bmp_blob: panelresolution=480 type=0
[0003.473] decompressor handler not found
[0003.477] load_firmware_blob: Firmware blob loaded, entries=2
[0003.483] XUSB blob version 0 size 124416 @ 0x92df928c
[0003.489] -------> se_aes_verify_sbk_clear: 747
[0003.493] se_aes_verify_sbk_clear: Error
[0003.497] SE operation failed
[0003.500] bl_battery_charging: connected to external power supply
[0003.516] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0003.523] MSC Partition not found
[0003.533] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0003.540] USP partition read failed!
[0003.544] blob_init: blob-partition USP header read failed
[0003.549] android_boot Unable to update recovery partition
[0003.555] kfs_getpartname: name = LNX
[0003.558] Loading kernel from LNX
[0003.654] load kernel from storage
[0003.664] decompressor handler not found
[0003.698] Successfully loaded kernel and ramdisk images
[0003.703] board ID = D78, board SKU = 2
[0003.708] load_bmp_blob: panelresolution=480 type=0
[0003.781] display bmp image done
[0003.785] NCK carveout not present
[0003.788] Skipping dts_overrides
[0003.791] NCK carveout not present
[0003.801] Find /i2c@7000c000’s alias i2c0
[0003.805] get eeprom at 1-a0, size 256, type 0
[0003.814] Find /i2c@7000c500’s alias i2c2
[0003.817] get eeprom at 3-a0, size 256, type 0
[0003.822] get eeprom at 3-ae, size 256, type 0
[0003.826] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.832] I2C slave not started
[0003.835] I2C write failed
[0003.837] Writing offset failed
[0003.840] eeprom_init: EEPROM read failed
[0003.844] pm_ids_update: eeprom init failed
[0003.848] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.878] pm_ids_update: The pm board id is 3448-0002-400
[0003.885] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0003.894] pm_ids_update: pm id update successful
[0003.898] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.928] pm_ids_update: The pm board id is 3449-0000-400
[0003.935] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0003.942] pm_ids_update: pm id update successful
[0003.973] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.979] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.987] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.992] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.001] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2f:d8:ca
[0004.007] Plugin Manager: Parse ODM data 0x000a4000
[0004.019] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.028] Add serial number:1421421077842 as DT property
[0004.037] “bpmp” doesn’t exist, creating
[0004.042] Updated bpmp info to DTB
[0004.047] Updated initrd info to DTB
[0004.051] “proc-board” doesn’t exist, creating
[0004.057] Updated board info to DTB
[0004.060] “pmu-board” doesn’t exist, creating
[0004.066] Updated board info to DTB
[0004.069] “display-board” doesn’t exist, creating
[0004.075] Updated board info to DTB
[0004.079] “reset” doesn’t exist, creating
[0004.083] Updated reset info to DTB
[0004.087] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1
[0004.126] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.132] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0004.148] Updated bootarg info to DTB
[0004.152] Adding uuid 00000001643073030400000011fe00c0 to DT
[0004.158] Adding eks info 0 to DT
[0004.163] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.169] Updated memory info to DTB
[0004.177] set vdd_core voltage to 1075 mv
[0004.181] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.187] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:46 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… *** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 2 1 0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
879 bytes read in 22 ms (38.1 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 181 ms (37.7 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 777 ms (42.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317e677
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92cb4000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.125726] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.312864] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.312994] imx219 7-0010: board setup failed
[ 1.337198] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.337283] imx219 8-0010: board setup failed
[ 1.905579] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.040360] using random self ethernet address
[ 3.044991] using random host ethernet address
[ 3.262887] random: crng init done
[ 3.266320] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.431618] using random self ethernet address
[ 3.437344] using random host ethernet address
[ 10.463969] Please complete system configuration setup on desktop to proceed…
