Jetson Nano boot errors after flashing with jetpack 4.2.1
Hello, I have been trying to successfully install jetpack 4.2.1 on my Jetson Nano developer kit Model # P3450. I initially tried to use the SDKManager to do the manual installation utilizing USB Recovery mode, however it would stall during the Initialize APP with System.img step.
I have then tried to do the same manual installation utilizing the command line with the directions to use the flash.sh file. By doing that, Flashing appears to be successful, with the prompt to reboot in order to complete setup.
However, when I reboot the device, And plug it into an HDMI Monitor and a USB Keyboard, I get the following messages on the screen:
[1.08] tegradc tegradc.1: dpd enable lookup fail: -19
cp: not writing through dangling symlink 'etc/resolv.conf'
And does not continue from there.
For a little more information:
I preformatted the 32GB SD card to be a single ext4 partition
The device has been set to use a 5V 4A Barrel Jack power supply, and the micro-USB has been plugged into the host machine
Device showed up using the lsusb command
command line flash.sh displays that the flash ran successfully
Any idea on what could be the issue?
Hi mbarbou1,
Creating system.img has nothing to do with jetson nano but your host. May I know what is your host environment?
I have tried on 2 different host machines, neither worked using the GUI but the later worked when I did it through the command line, although that resulted in described behavior above:
  1. PopOS! 18.04 LTS with CUDA 10.0 installed, GTX 970 (Self Built)
  2. Ubuntu 18.04 LTS, no CUDA installed, AMD RX 540 (Intel 8th Gen NUC)
No host was done on a VM, any idea why could be the issue?
On the Nano, what do you see from “cat /run/resolvconf/resolv.conf”? Often DHCP modifies the resolv.conf, and a symbolic link points to this from “/etc/” to point at the “/run” version.
How would I go about running that on the Nano? The nano doesn’t seem to boot or allow my to input commands in the slightest.
If the unit doesn’t boot, then you probably need to post a serial console boot log. See:
https://www.jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
FYI, I would bet something went wrong with the flash or SD card image copy. However, if you mount your SD card to a desktop PC running Linux, and you cd to the mount point, then to “./run/resolvconf/”, do you see “resolv.conf” there after “ls”? If so, what shows up from “cat ./resolv.conf”?
To some extent, for testing purposes, it may not matter if the SD card is running on the Jetson, or if the SD is on a host computer. I am curious if the “run/resolvconf/” directory exists, and if it does, the content of the “resolv.conf” there. If something went wrong in your image copy or flash to the SD card, then the host PC might find this as easily as running directly on the Jetson (but the mount point would be somewhere else than “/” if on the PC).
Using my PopOS 18.04 system, I ran ls - l in the SDcard/run folder:
emilybarbour@pop-os:/media/emilybarbour/dc21871e-9db4-434c-98b4-713f55f807eb$ ls -l run/
total 64
drwxr-xr-x  2 usbmux nogroup 4096 May 21  2018 dnsmasq
-rw-r--r--  1 root   root       0 Jul 22  2018 firefox-restart-required
drwxr-xr-x  2    122 dialout 4096 Jun 22  2018 gpsd
lrwxrwxrwx  1 root   root      25 Jul 22  2018 initctl -> /run/systemd/initctl/fifo
drwxrwxrwt  3 root   root    4096 Jul 22  2018 lock
drwxr-xr-x  2 root   root    4096 Jul 22  2018 log
drwxr-xr-x  2 root   root    4096 Apr 26  2018 mount
drwxr-xr-x  2 root   root    4096 Jun  4  2018 network
-rw-r--r--  1 root   root      32 Oct 21 21:37 reboot-required
-rw-r--r--  1 root   root     158 Oct 21 21:37 reboot-required.pkgs
drwxr-xr-x  3 root   root    4096 Jun  4  2018 resolvconf
drwxr-xr-x  2 root   root    4096 Jul 22  2018 rpcbind
drwxr-xr-x  2 root   root    4096 Jul 22  2018 sendsigs.omit.d
lrwxrwxrwx  1 root   root       8 Jul 22  2018 shm -> /dev/shm
drwxr-xr-x  2 saned  audio   4096 May 21  2018 speech-dispatcher
drwxr-xr-x  2 root   root    4096 Jul 22  2018 spice-vdagentd
drwx--x--x  3 root   root    4096 Jul 22  2018 sudo
drwxr-xr-x 10 root   root    4096 Jul 22  2018 systemd
drwxr-xr-x  2 root   root    4096 Jul 22  2018 user
-rw-rw-r--  1 root   utmp       0 Apr 26  2018 utmp
Doing ls -l in resolvconf returns:
total 8
-rw-r--r-- 1 root root    0 Apr  9  2019 enable-updates
drwxr-xr-x 2 root root 4096 Jun  4  2018 interface
-rw-r--r-- 1 root root  190 Jun  4  2018 resolv.conf
and cat resolv.conf:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
search nvidia.com
Personally that look incorrect due to length, but I assume you have the actual contents of a correctly created one.
To update, I have re-installed PopOS 18.04 on this machine to clear out any packages I had installed previously, and am trying to use the SDK-manager again to see if it will install correctly
Tried the SDKManager again, it completed installing the OS image this time, but upon boot, the device displayed the Nvidia Logo for about 10 seconds, then displayed the error codes i started this topic with again.
Ill link the logs so that you can look into them if they would be helpful
https://kennesawedu-my.sharepoint.com/:u:/g/personal/mbarbou1_students_kennesaw_edu/ES30GqZ2AGBCuMkrgZmp3w0BOKA7TXFJnrmWmSTNE-IswA?e=g0W4Pn
I will try again using the command line install I found before using the command found here:
https://devtalk.nvidia.com/default/topic/1058463/jetson-nano/cannot-flash-jetsonnano-with-sdk-manager/post/5367692/#5367692
Still gets the same errors. I do not have a Serial to USB device, so I’ll have to acquire that.
@WayneWWW what do you suggest I do to help solve this issue?
We didn’t meet this error before.
“cp: not writing through dangling symlink ‘etc/resolv.conf’”
I wonder if PopOS is the one causing problem. How about using the pure ubntu 18.04 to flash?
You could also bypass the configuration wizard by using this script
https://devtalk.nvidia.com/default/topic/1054926/jetson-nano/jetson-nano-all-usb-ports-suddenly-stopped-working/post/5356153/#5356153
There is a folder “Linux_for_Tegra” after first sdkmanager flash. Please go that directory and run flash script.
You could refer to L4T document from our download center for usage.
From what you showed there shouldn’t be a dangling symlink during runtime. If the error occurs during flash unpacking the sample rootfs, then I could see this being an issue on some flavors of Linux, but not on Ubuntu. Being able to unpack the sample rootfs has some requirements which several Linux distributions meet by default, but some others may for example have a different default alias for various commands. Even so this shouldn’t matter since a filesystem is being unpacked and not created via a “ln -s” command.
SDK Manager itself has more requirements than the underlying flash software. When you mention “PopOS!”, which I am not familiar with, I am thinking perhaps the dangling sym link error is occurring on the host as a result of the “etc/resolv.conf” dangling until the rootfs is mounted on “/” (but this will never be mounted on “/” of the host PC). If some error occurs in writing a filesystem from a host PC, then the error might still exist during boot on the Nano (e.g., incorrect permissions, but this does not seem to be the case).
With an Ubuntu host PC the install should not have any issues, and perhaps the PopOS! won’t have issues, don’t know. I doubt the host is involved in this, but I wanted to mention it.
In order to further debug this most likely you’ll have to have the serial USB cable. Not being able to see the full boot log will make this very difficult.
As a note, normally the resolv.conf has some default (and your resolv.conf is valid as a default), but the DHCP server might cause this to need additional update. You might try booting without any networking, and thus prevent DHCP from being visible, and compare to booting with wired ethernet and a valid DHCP server (a router connected).
Thank you all for your patience, as an update I installed a clean instance of Ubuntu 18.04 on this machine,tried using the SDK manager, and get the same errors still. I will see if microcenter does not have a serial USB cable I can utilize to get a readout of whats going on.
Alright, thank you all, I have the cable and have got a readout for boot, as shown below:
@WayneWWW
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.140] Power-up reason: pmc por
[0000.143] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.149] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.158] max77620 disabling SD1 Remote Sense
[0000.162] Setting DDR voltage to 1125mv
[0000.166] Serial Number of Pmic Max77663: 0xc24c9
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.180] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.185] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.194] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.200] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.229] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.235] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.251] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.314] Csd NumOfBlocks=60653568
[0000.319] Set High speed to 1
[0000.324] Using GPT Primary to query partitions
[0000.330] Loading Tboot-CPU binary
[0000.343] Verifying TBC in OdmNonSecureSBK mode
[0000.353] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.360] Bootloader downloaded successfully.
[0000.364] Downloaded Tboot-CPU binary to 0xa0000258
[0000.369] MAX77620_GPIO5 configured
[0000.372] CPU power rail is up
[0000.375] CPU clock enabled
[0000.379] Performing RAM repair
[0000.382] Updating A64 Warmreset Address to 0xa00002e9
[0000.387] Loading NvTbootBootloaderDTB
[0000.423] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.488] Bootloader DTB Load Address: 0x83000000
[0000.492] Loading NvTbootKernelDTB
[0000.528] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.593] Kernel DTB Load Address: 0x83100000
[0000.598] Loading cboot binary
[0000.642] Verifying EBT in OdmNonSecureSBK mode
[0000.684] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.691] Bootloader downloaded successfully.
[0000.696] Next binary entry address: 0x92c00258
[0000.700] BoardId: 3448
[0000.705] Overriding pmu board id with proc board id
[0000.709] Display board id is not available
[0000.751] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.803] /bpmp deleted
[0000.805] SC7EntryFw header found loaded at 0xff700000
[0000.993] OVR2 PMIC
[0000.995] Bpmp FW successfully loaded
[0000.999] WB0 init successfully at 0xff780000
[0001.003] Set NvDecSticky Bits
[0001.007] GSC2 address ff53fffc value c0edbbcc
[0001.013] GSC MC Settings done
[0001.017] TOS Image length 53680
[0001.020]  Monitor size 53680
[0001.023]  OS size 0
[0001.031] Secure Os AES-CMAC Verification Success!
[0001.036] TOS image cipher info: plaintext
[0001.040] Loading and Validation of Secure OS Successful
[0001.056] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.060] NvTbootPackSdramParams: start.
[0001.065] NvTbootPackSdramParams: done.
[0001.069] Tegraboot started after 53779 us
[0001.073] Basic modules init took 677541 us
[0001.077] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.082] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.089] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.095] Storage Device Read Time = 165 ms, Read Size = 2226 KB
[0001.101] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.106] Next stage binary read took 37841 us
[0001.110] Carveout took -49501 us
[0001.113] CPU initialization took 375612 us
[0001.117] Total time taken by TegraBoot 1041493 us
[0001.122] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):a28d87f09
NOTICE:  BL31: Built : 21:10:01, Aug 12 2019
ERROR:   Error initializing runtime service trusty_fast
[0001.244] RamCode = 0
[0001.249] LPDDR4 Training: Read DT: Number of tables = 2
[0001.254] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.267] EMC Training Successful
[0001.270] 408000 not found in DVFS table
[0001.276] RamCode = 0
[0001.280] DT Write: emc-table@204000 succeeded
[0001.285] DT Write: emc-table@1600000 succeeded
[0001.289] LPDDR4 Training: Write DT: Number of tables = 2
[0001.329]
[0001.330] Debug Init done
[0001.333] Marked DTB cacheable
[0001.336] Bootloader DTB loaded at 0x83000000
[0001.341] Marked DTB cacheable
[0001.344] Kernel DTB loaded at 0x83100000
[0001.348] DeviceTree Init done
[0001.359] Pinmux applied successfully
[0001.364] gicd_base: 0x50041000
[0001.367] gicc_base: 0x50042000
[0001.370] Interrupts Init done
[0001.374] Using base:0x60005090 & irq:208 for tick-timer
[0001.379] Using base:0x60005098 for delay-timer
[0001.384] platform_init_timer: DONE
[0001.387] Timer(tick) Init done
[0001.391] osc freq = 38400 khz
[0001.395]
[0001.396] welcome to cboot
[0001.399]
[0001.400] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.405] calling constructors
[0001.408] initializing heap
[0001.411] initializing threads
[0001.413] initializing timers
[0001.416] creating bootstrap completion thread
[0001.421] top of bootstrap2()
[0001.424] CPU: ARM Cortex A57
[0001.426] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.431] initializing platform
[0001.434] Scratch reg 37 & 271 initial value set..
[0001.441] cboot:secure-pmc present
[0001.444] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.448] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.453] Macronix QSPI chip present
[0001.456] SPI device register
[0001.459] init boot device
[0001.462] allocating memory for boot device(SPI)
[0001.467] registering boot device
[0001.476] sdmmc node status = okay
[0001.479] sdcard instance = 0
[0001.482] sdcard gpio handle 0x56
[0001.485] sdcard gpio pin 0xc9
[0001.488] sdcard gpio flags 0x0
[0001.491] vmmc-supply 0x99
[0001.494] Instance: 0
[0001.496] Allocating memory for context
[0001.500] enabling clock
[0001.502] sd card init
[0001.504] Check card present and stable
[0001.508] Send command 0
[0001.525] Send command 3
[0001.529] Set RCA for the card
[0001.532] Query card specific data by command 9
[0001.538] Parse CSD data
[0001.541] Send command 7
[0001.551] Calling sd device register
[0001.554] Init sdcard
[0001.557] Allocating memory for boot device
[0001.561] Registering user device
[0001.574] Enable APE clock
[0001.576] Un-powergate APE partition
[0001.580] of_register: registering tegra_udc to of_hal
[0001.585] of_register: registering tegra_udc to of_hal
[0001.590] of_register: registering inv20628-driver to of_hal
[0001.596] of_register: registering ads1015-driver to of_hal
[0001.601] of_register: registering lp8557-bl-driver to of_hal
[0001.607] of_register: registering bq2419x_charger to of_hal
[0001.613] of_register: registering cpc to of_hal
[0001.617] of_register: registering bq27441_fuel_gauge to of_hal
[0001.629] gpio framework initialized
[0001.632] of_register: registering tca9539_gpio to of_hal
[0001.637] of_register: registering tca9539_gpio to of_hal
[0001.643] of_register: registering i2c_bus_driver to of_hal
[0001.648] of_register: registering i2c_bus_driver to of_hal
[0001.654] of_register: registering i2c_bus_driver to of_hal
[0001.660] of_register: registering i2c_bus_driver to of_hal
[0001.665] pmic framework initialized
[0001.669] of_register: registering max77620_pmic to of_hal
[0001.674] regulator framework initialized
[0001.678] of_register: registering tps65132_bl_driver to of_hal
[0001.684] initializing target
[0001.690] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.698] fixed regulator driver initialized
[0001.715] initializing OF layer
[0001.718] NCK carveout not present
[0001.721] Skipping dts_overrides
[0001.726] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.742] I2C Bus Init done
[0001.745] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.755] I2C Bus Init done
[0001.758] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.768] I2C Bus Init done
[0001.770] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.781] I2C Bus Init done
[0001.783] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.794] I2C Bus Init done
[0001.796] of_children_init: Ops found for compatible string maxim,max77620
[0001.806] max77620_init using irq 118
[0001.811] register 'maxim,max77620' pmic
[0001.816] gpio_driver_register: register 'max77620-gpio' driver
[0001.822] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.832] I2C Bus Init done
[0001.836] NCK carveout not present
[0001.839] shim_invoke: No NCT, Calling dts updates
[0001.850] Find /i2c@7000c000's alias i2c0
[0001.854] get eeprom at 1-a0, size 256, type 0
[0001.863] Find /i2c@7000c500's alias i2c2
[0001.867] get eeprom at 3-a0, size 256, type 0
[0001.871] get eeprom at 3-ae, size 256, type 0
[0001.876] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.881] I2C slave not started
[0001.884] I2C write failed
[0001.886] Writing offset failed
[0001.890] eeprom_init: EEPROM read failed
[0001.893] pm_ids_update: eeprom init failed
[0001.898] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.928] pm_ids_update: The pm board id is 3448-0000-200
[0001.934] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0001.942] pm_ids_update: pm id update successful
[0001.946] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.977] pm_ids_update: The pm board id is 3449-0000-200
[0001.983] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0001.991] pm_ids_update: pm id update successful
[0002.021] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.027] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.035] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.041] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.049] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e4:12:b3
[0002.056] Plugin Manager: Parse ODM data 0x00094000
[0002.066] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootw
[0002.087] Find /i2c@7000c000's alias i2c0
[0002.091] get eeprom at 1-a0, size 256, type 0
[0002.100] Find /i2c@7000c500's alias i2c2
[0002.103] get eeprom at 3-a0, size 256, type 0
[0002.108] get eeprom at 3-ae, size 256, type 0
[0002.112] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.117] I2C slave not started
[0002.121] I2C write failed
[0002.123] Writing offset failed
[0002.126] eeprom_init: EEPROM read failed
[0002.130] pm_ids_update: eeprom init failed
[0002.134] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.164] pm_ids_update: The pm board id is 3448-0000-200
[0002.171] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.178] pm_ids_update: pm id update successful
[0002.182] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.212] pm_ids_update: The pm board id is 3449-0000-200
[0002.219] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.226] pm_ids_update: pm id update successful
[0002.256] Chip UID is 000000016441b746240000000bfe8440
[0002.261] Add serial number:042121902251204084fe as DT property
[0002.270] Applying platform configs
[0002.276] platform-init is not present. Skipping
[0002.281] calling apps_init()
[0002.301] Found 14 GPT partitions in "sd0"
[0002.305] Proceeding to Cold Boot
[0002.308] starting app android_boot_app
[0002.312] Device state: unlocked
[0002.315] display console init
[0002.323] could not find regulator
[0002.326] hdmi cable connected
[0002.342] edid read success
[0002.344] width = 640, height = 480, frequency = 25174825
[0002.350] width = 640, height = 480, frequency = 25174825
[0002.355] wDT entry for leds-pwm not found
i[0002.363] dth = 1920, height = 1080, frequency = 148500000
[0002.368] Best mode Width = 640, Height = 480, freq = 25174825
[0002.375] tmds-config node not found
[0002.380] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltageps
[0002.394] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.402] could not find regulator
[0002.405] could not find regulator
[0002.408] could not find regulator
[0002.437] using default cmu settings
[0002.441] dc_hdmi_enable, starting HDMI initialisation
[0002.447] dc_hdmi_enable, HDMI initialisation complete
[0002.452] list and configure display window
[0002.457] display console init completed
[0002.464] subnode volume_up is not found !
[0002.468] subnode back is not found !
[0002.471] subnode volume_down is not found !
[0002.476] subnode menu is not found !
[0002.479] Gpio keyboard init success
[0002.523] found decompressor handler: lz4-legacy
[0002.538] decompressing blob (type 1)...
[0002.571] load_bmp_blob: panelresolution=480 type=0
[0002.622] decompressor handler not found
[0002.626] load_firmware_blob: Firmware blob loaded, entries=2
[0002.632] se_aes_verify_sbk_clear: Error
[0002.635] bl_battery_charging: connected to external power supply
[0002.643] xusb is supported
[0002.649] error while finding nvidia,portmap
[0002.654] could not find regulator
[0003.157] xusb blob version 0 size 124416
[0003.161] firmware size 124416
[0003.166] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.176] xhci0: 64 bytes context size, 32-bit DMA
[0003.216] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.236] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on u0
[0003.886] uhub0: 9 ports with 9 removable, self powered
[0004.886] failed to get HID devices
[0004.890] failed to init xhci or no usb device attached
[0004.900] device_query_partition_size: failed to open partition sd0:MSC !
[0004.907] MSC Partition not found
[0004.913] device_query_partition_size: failed to open partition sd0:USP !
[0004.920] USP partition read failed!
[0004.923] blob_init: blob-partition USP header read failed
[0004.929] android_boot Unable to update recovery partition
[0004.934] kfs_getpartname: name = LNX
[0004.938] Loading kernel from LNX
[0004.998] Verifying boot image in OdmNonSecureSBK mode
[0005.041] kernel load address: 0x80080000, size: 482032 bytes
[0005.047] ramdisk load address: 0x84100000, size: 0 bytes
[0005.052] load kernel from storage
[0005.064] decompressor handler not found
[0005.122] Successfully loaded kernel and ramdisk images
[0005.128] load_bmp_blob: panelresolution=480 type=0
[0005.202] display bmp image done
[0005.205] NCK carveout not present
[0005.208] Skipping dts_overrides
[0005.211] NCK carveout not present
[0005.215] shim_invoke: No NCT, Calling dts updates
[0005.226] Find /i2c@7000c000's alias i2c0
[0005.230] get eeprom at 1-a0, size 256, type 0
[0005.239] Find /i2c@7000c500's alias i2c2
[0005.243] get eeprom at 3-a0, size 256, type 0
[0005.247] get eeprom at 3-ae, size 256, type 0
[0005.252] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.257] I2C slave not started
[0005.260] I2C write failed
[0005.263] Writing offset failed
[0005.266] eeprom_init: EEPROM read failed
[0005.270] pm_ids_update: eeprom init failed
[0005.274] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.304] pm_ids_update: The pm board id is 3448-0000-200
[0005.311] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.318] pm_ids_update: pm id update successful
[0005.323] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.353] pm_ids_update: The pm board id is 3449-0000-200
[0005.359] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0005.367] pm_ids_update: pm id update successful
[0005.397] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.403] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.411] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.417] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.426] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e4:12:b3
[0005.432] Plugin Manager: Parse ODM data 0x00094000
[0005.442] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootw
[0005.457] Add serial number:042121902251204084fe as DT property
[0005.466] "bpmp" doesn't exist, creating
[0005.472] Updated bpmp info to DTB
[0005.477] Updated initrd info to DTB
[0005.480] "proc-board" doesn't exist, creating
[0005.485] Updated board info to DTB
[0005.489] "pmu-board" doesn't exist, creating
[0005.494] Updated board info to DTB
[0005.497] "display-board" doesn't exist, creating
[0005.503] Updated board info to DTB
[0005.506] "reset" doesn't exist, creating
[0005.511] Updated reset info to DTB
[0005.514] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype
[0005.553] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console
[0005.566] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0005.579] Updated bootarg info to DTB
[0005.582] Adding uuid 000000016441b746240000000bfe8440 to DT
[0005.588] Adding eks info 0 to DT
[0005.594] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.600] Updated memory info to DTB
[0005.605] Updated system-lp0-disable info to DTB
[0005.613] set vdd_core voltage to 1075 mv
[0005.617] setting 'vdd-core' regulator to 1075000 micro volts
[0005.636] could not find regulator
[0005.640] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Aug 12 2019 - 21:10:20 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM:  4 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 124 ms (4.9 KiB/s)
L4T boot options
1:      primary kernel
Enter choice: 1:        primary kernel
Retrieving file: /boot/initrd
5562384 bytes read in 564 ms (9.4 MiB/s)
Retrieving file: /boot/Image
34179080 bytes read in 2933 ms (11.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resizt
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
   reserving fdt memory region: addr=80000000 size=20000
   Using Device Tree in place at 0000000083100000, end 0000000083177282
Starting kernel ...
<hit enter to activate fiq debugger>
[    1.061137] tegradc tegradc.1: dpd enable lookup fail:-19
[  363.767967] cgroup: cgroup2: unknown option "nsdelegate"
Hopefully that can help us get to the bottom of this.
Looks like it hangs with the GPU software immediately upon loading the kernel. Not even the echo of kernel command line shows up, which is unusual. I can’t personally nail it down any closer, but it appears that either the Image being loaded has issues, or the SD card from which the Image is being loaded has issues.
Is there any chance you have a different micro-SD card (best if different brand) to test? There are a lot of SD cards which don’t always seem to work well for boot even if they work for data.
I don’t have another SD card at the moment sadly, and it would take a few weeks for me to get one.
I will note that this exact SD card was what the machine was using to boot for the last year on an older version of jetpack, can’t remember which version other than it was the intial SD card image whenever we received our pre-order unit.
I don’t have access to the machine at the moment but I’ll update the thread when I can see what manufacturer of SD card im using.
If you can test what happens by putting an older release on it again, at least temporarily, that too would be useful information.
@linuxdev @ WayneWWW I have the SD card in my hands, it is a MicroCenter branded Class 10 32GB micro SD card. I have a 64GB Sandisk Class 10 on me as well, though I would like to avoid having to wipe the contents of that drive. I will be installing JP 4.2 on the MicroCenter SD Card to see if I can’t get it to boot.
What an anti-climatic ending.
Used etcher to install jetpack 4.2.1 on the SanDisk SDHC card. Worked perfectly, currently typing this post on the jetson nano.
My guess is that during the inital flashing of JP 4.2.1 on the original MicroCenter brand SD card, it somehow got bricked. Ah well, I finally have a working device which is what maters most.
We should take away from this that you need to be very careful using the SDKManager to flash the jetson nano, as that is what I can summize bricked the card. Furthermore, I would probably stick away from off brand SD cards, purely for consistencies sake.
Thanks @linuxdev and @WayneWWW for the help in debugging. I’ll go ahead and mark this as the answer to this topic.
Hi mbarbou1,
Did you bypass the password configuration by using the tool from #11? Is this log under such case?
