Boot log Pt1
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB3, 15:45:34
Press CTRL-A Z for help on special keys
[0000.095] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.103] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0000.109] I> Boot-mode: Coldboot
[0000.112] I> Chip revision : A02P
[0000.115] I> Bootrom patch version : 15 (correctly patched)
[0000.120] I> ATE fuse revision : 0x200
[0000.123] I> Ram repair fuse : 0x0
[0000.126] I> Ram Code : 0x2
[0000.129] I> rst_source : 0x0
[0000.132] I> rst_level : 0x0
[0000.135] I> Boot-device: eMMC
[0000.150] I> sdmmc DDR50 mode
[0000.154] W> No valid slot number is found in scratch register
[0000.160] W> Return default slot: _a
[0000.163] I> Active Boot chain : 0
[0000.166] I> Boot-device: eMMC
[0000.170] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.178] I> Temperature = 35500
[0000.181] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.185] W> Skipping boost for clk: BPMP_APB
[0000.189] W> Skipping boost for clk: AXI_CBB
[0000.193] W> Skipping boost for clk: AON_CPU_NIC
[0000.197] W> Skipping boost for clk: CAN1
[0000.201] W> Skipping boost for clk: CAN2
[0000.205] I> Boot-device: eMMC
[0000.208] I> Boot-device: eMMC
[0000.217] I> Sdmmc: HS400 mode enabled
[0000.222] I> ECC region[0]: Start:0x0, End:0x0
[0000.226] I> ECC region[1]: Start:0x0, End:0x0
[0000.230] I> ECC region[2]: Start:0x0, End:0x0
[0000.234] I> ECC region[3]: Start:0x0, End:0x0
[0000.239] I> ECC region[4]: Start:0x0, End:0x0
[0000.243] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.248] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.253] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.257] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.262] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.267] E> FAILED: Thermal config
[0000.274] E> FAILED: MEMIO rail config
[0000.293] I> Boot-device: eMMC
[0000.302] I> sdmmc bdev is already initialized
[0000.377] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.385] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-6fc80)
[0000.386] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.387] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.387] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.393] W> device prod register failed
[0000.397] I> gpio framework initialized
[0000.401] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' drir
[0000.408] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'r
[0000.416] I> No valid sdcard_params in mb1_bct
[0000.420] I> Boot-device: eMMC
[0000.423] I> Boot_device: SDMMC_BOOT instance: 3
[0000.432] I> sdmmc-3 params source = boot args
[0000.433] I> sdmmc bdev is already initialized
[0000.436] I> sdmmc-3 params source = boot args
[0000.470] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.486] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.487] W> No valid slot number is found in scratch register
[0000.487] W> Return default slot: _a
[0000.488] I> Active Boot chain : 0
[0000.494] I> parsing oem signed section of bpmp-fw header done
[0000.501] I> bpmp-fw binary init read from storage
[0000.502] I> oem authentication of bpmp-fw header done
[0000.504] I> bpmp-fw binary done read from storage
[0000.505] I> bpmp-fw: Authentication init Done
[0000.512] I> parsing oem signed section of cpubl header done
[0000.518] I> cpubl binary init read from storage
[0000.519] I> bpmp-fw: Authentication Finalize Done
[0000.519] I> oem authentication of cpubl header done
[0000.522] I> cpubl binary done read from storage
[0000.527] I> cpubl: Authentication init Done
[0000.537] I> parsing oem signed section of rce header done
[0000.544] I> rce binary init read from storage
[0000.544] I> Relocating BR-BCT
[0000.545] I> cpubl: Authentication Finalize Done
[0000.548] I> oem authentication of rce header done
[0000.552] I> rce binary done read from storage
[0000.557] I> rce: Authentication init Done
[0000.567] I> parsing oem signed section of ape header done
[0000.574] I> ape binary init read from storage
[0000.574] I> rce: Authentication Finalize Done
[0000.575] I> oem authentication of ape header done
[0000.579] I> ape binary done read from storage
[0000.584] I> ape: Authentication init Done
[0000.594] I> parsing oem signed section of tos header done
[0000.600] I> tos binary init read from storage
[0000.601] I> ape: Authentication Finalize Done
[0000.602] I> oem authentication of tos header done
[0000.606] I> tos binary done read from storage
[0000.610] I> tos: Authentication init Done
[0000.620] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.627] I> bpmp-fw-dtb binary init read from storage
[0000.628] I> tos: Authentication Finalize Done
[0000.631] I> oem authentication of bpmp-fw-dtb header done
[0000.638] I> bpmp-fw-dtb binary done read from storage
[0000.640] I> bpmp-fw-dtb: Authentication init Done
[0000.651] I> parsing oem signed section of cpubl-dtb header done
[0000.657] I> cpubl-dtb binary init read from storage
[0000.658] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.693] I> oem authentication of cpubl-dtb header done
[0000.694] I> cpubl-dtb binary done read from storage
[0000.695] I> cpubl-dtb: Authentication init Done
[0000.701] I> parsing oem signed section of eks header done
[0000.708] I> eks binary init read from storage
[0000.708] I> cpubl-dtb: Authentication Finalize Done
[0000.709] I> oem authentication of eks header done
[0000.710] I> eks binary done read from storage
[0000.710] I> eks: Authentication init Done
[0000.711] I> eks: Authentication Finalize Done
[0000.714] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 02:21:00, Apr 17 2022
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
��mrq initialized
��[0001.218] I> Welcome to Cboot
��fmon_post initialized
��[0001.219] I> Cboot Version: t194-38d30025
[0001.219] I> CPU-BL Params @ 0xf2820000
[0001.220] I> 0) Base:0x00000000 Size:0x00000000
[0001.223] I> 1) Base:0xf1100000 Size:0x00100000
[0001.228] I> 2) Base:0xf2000000 Size:0x00200000
[0001.232] I> 3) Base:0xf1200000 Size:0x00200000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.237] I> 4) Base:0xf1000000 Size:0x00100000
[0001.316] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.321] I> 6) Base:0xf3800000 Size:0x00400000
[0001.325] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.330] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.334] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.338] I> 10) Base:0xf3000000 Size:0x00800000
[0001.343] I> 11) Base:0x40000000 Size:0x00040000
[0001.347] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.352] I> 13) Base:0x40046000 Size:0x00002000
[0001.356] I> 14) Base:0x40048000 Size:0x00002000
��emc_debugfs initialized
dvs_debugfs initialized
��[0001.361] I> 15) Base:0xac000000 Size:0x00004000
��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.370] I> 16) Base:0x4004a000 Size:0x00002000
[0001.420] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.425] I> 18) Base:0x4004c000 Size:0x00002000
[0001.429] I> 19) Base:0xf2200000 Size:0x00600000
[0001.434] I> 20) Base:0x4004e000 Size:0x00002000
[0001.438] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.443] I> 22) Base:0x00000000 Size:0x00000000
[0001.447] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.452] I> 24) Base:0xf6000000 Size:0x02000000
[0001.456] I> 25) Base:0x40050000 Size:0x00002000
[0001.461] I> 26) Base:0x40040000 Size:0x00006000
[0001.465] I> 27) Base:0xf1800000 Size:0x00400000
[0001.470] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.474] I> 29) Base:0xf1400000 Size:0x00400000
[0001.478] I> 30) Base:0x00000000 Size:0x00000000
[0001.483] I> 31) Base:0x00000000 Size:0x00000000
[0001.487] I> 32) Base:0xf8000000 Size:0x08000000
[0001.492] I> 33) Base:0x00000000 Size:0x00000000
[0001.496] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.501] I> 35) Base:0xab000000 Size:0x01000000
[0001.505] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.510] I> 37) Base:0xf2800000 Size:0x00800000
[0001.514] I> 38) Base:0x80000000 Size:0x20000000
[0001.519] I> 39) Base:0xb0000000 Size:0x08000000
[0001.523] I> 40) Base:0x00000000 Size:0x00000000
[0001.528] I> 41) Base:0x00000000 Size:0x00000000
[0001.532] I> 42) Base:0x00000000 Size:0x00000000
[0001.536] I> 43) Base:0x00000000 Size:0x00000000
[0001.541] I> 44) Base:0x00000000 Size:0x00000000
[0001.545] I> 45) Base:0x00000000 Size:0x00000000
[0001.550] GIC-SPI Target CPU: 0
[0001.553] Interrupts Init done
[0001.556] calling constructors
[0001.559] initializing heap
[0001.561] I> Heap: [0xa069ab80 ... 0xab000000]
[0001.565] initializing threads
[0001.568] initializing timers
[0001.571] creating bootstrap completion thread
[0001.575] top of bootstrap2()
[0001.578] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.583] initializing platform
[0001.586] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.591] W> device prod register failed
[0001.595] I> Bl_dtb @0xaaf00000
[0001.601] W> "plugin-manager" doesn't exist, creating
[0001.603] W> "ids" doesn't exist, creating
[0001.607] W> "connection" doesn't exist, creating
[0001.612] W> "configs" doesn't exist, creating
[0001.625] E> failed to read label property for node 227404: 13
[0001.627] E> failed to read reg property for node 227492: 13
[0001.630] E> failed to read label property for node 227544: 13
[0001.635] E> failed to read label property for node 227612: 13
[0001.639] E> failed to read label property for node 227648: 13
[0001.645] E> failed to read label property for node 227684: 13
[0001.651] E> failed to read reg property for node 227752: 13
[0001.656] E> failed to read label property for node 227804: 13
[0001.663] I> Find /i2c@3160000's alias i2c0
[0001.665] I> Reading eeprom i2c=0 address=0x50
[0001.695] I> Device at /i2c@3160000:0x50
[0001.695] I> Reading eeprom i2c=0 address=0x56
[0001.719] I> Device at /i2c@3160000:0x56
[0001.721] I> Find /i2c@3180000's alias i2c2
[0001.721] I> Reading eeprom i2c=2 address=0x54
[0001.723] E> I2C: slave not found in slaves.
[0001.723] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start t.
[0001.724] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.724] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 a.
[0001.733] E> eeprom: Failed to read I2C slave device
[0001.738] I> Eeprom read failed 0x3526070d
[0001.742] I> Reading eeprom i2c=2 address=0x57
[0001.747] E> I2C: slave not found in slaves.
[0001.751] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.758] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.764] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.773] E> eeprom: Failed to read I2C slave device
[0001.778] I> Eeprom read failed 0x3526070d
[0001.782] I> Reading eeprom i2c=2 address=0x52
[0001.787] E> I2C: slave not found in slaves.
[0001.791] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.798] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.804] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.814] E> eeprom: Failed to read I2C slave device
[0001.818] I> Eeprom read failed 0x3526070d
[0001.824] I> Find /i2c@c240000's alias i2c1
[0001.826] I> Reading eeprom i2c=1 address=0x52
[0001.832] E> I2C: slave not found in slaves.
[0001.835] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.843] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.848] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.858] E> eeprom: Retry to read I2C slave device.
[0001.863] E> I2C: slave not found in slaves.
[0001.867] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.874] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.880] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.889] E> eeprom: Failed to read I2C slave device
[0001.894] I> Eeprom read failed 0x3526070d
[0001.898] I> Reading eeprom i2c=1 address=0x50
[0001.903] E> I2C: slave not found in slaves.
[0001.907] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.915] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.920] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.930] E> eeprom: Retry to read I2C slave device.
[0001.934] E> I2C: slave not found in slaves.
[0001.938] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.946] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.952] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.961] E> eeprom: Failed to read I2C slave device
[0001.966] I> Eeprom read failed 0x3526070d
[0001.970] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0001.975] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.986] I> create_pm_ids: id: 2822-0000-700-J, len: 15
[0001.991] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.003] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.010] W> "i2c@3160000" doesn't exist, creating
[0002.014] W> "module@0x50" doesn't exist, creating
[0002.019] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0002.026] W> "module@0x56" doesn't exist, creating
[0002.032] I> Adding plugin-manager/cvm
[0002.034] W> "chip-id" doesn't exist, creating
[0002.038] I> Adding plugin-manager/chip-id/A02P
[0002.043] I> Plugin-manager override starting
[0002.048] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.055] I> node /plugin-manager/fragement-soft-wdt matches
[0002.063] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.067] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.080] I> Disable plugin-manager status in FDT
[0002.080] I> Plugin-manager override finished successfully
[0002.081] I> gpio framework initialized
[0002.085] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' drir
[0002.092] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'r
[0002.099] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.106] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.114] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.120] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.126] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.134] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.142] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.148] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.156] I> fixed regulator driver initialized
[0002.168] I> register 'maxim' power off handle
[0002.169] I> virtual i2c enabled
[0002.169] I> registered 'maxim,max20024' pmic
[0002.170] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.177] I> Boot-device: eMMC
[0002.180] I> Boot_device: SDMMC_BOOT instance: 3
[0002.188] I> sdmmc-3 params source = boot args
[0002.189] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.194] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.205] I> create_pm_ids: id: 2822-0000-700-J, len: 15
[0002.210] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.221] I> sdmmc bdev is already initialized
[0002.225] I> sdmmc-3 params source = boot args
[0002.256] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.268] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.280] I> enabling 'vdd-hdmi-5v0' regulator
[0002.285] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.286] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.286] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.290] E> invalid display type
[0002.294] E> invalid display type
[0002.295] E> cannot find any other nvdisp nodes
[0002.296] E> no valid display unit config found in dtb
[0002.297] W> display init failed
[0002.297] I> Load in CBoot Boot Options partition and parse it
[0002.308] E> Error -9 when finding node with path /boot-configuration
[0002.309] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO fil.
[0002.316] I> Using default boot order
[0002.319] I> boot-dev-order :-
[0002.322] I> 1.sd
[0002.324] I> 2.usb
[0002.326] I> 3.nvme
[0002.328] I> 4.emmc
[0002.330] I> 5.net
[0002.331] I> Hit any key to stop autoboot: 4 3 2 1
[0004.339] initializing target
[0004.339] calling apps_init()
[0004.340] starting app kernel_boot_app
[0004.359] I> found decompressor handler: lz4-legacy
[0004.360] I> decompressing BMP blob ...
[0004.371] I> Kernel type = Normal
[0004.371] I> ########## SD (0) boot ##########
[0004.372] I> No sdcard
[0004.372] I> sdcard-0 params source = DT-BL
[0004.372] E> Blockdev open: exit error
[0004.373] E> SD boot failed, err: 724238353
[0004.373] I> ########## USB (0) boot ##########
[0004.378] W> No valid slot number is found in scratch register
[0004.378] W> Return default slot: _a
[0004.387] I> Validate XUSB-FW ...
[0004.387] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x28000
[0004.392] I> Encryption fuse is not ON
[0004.394] I> USB Firmware Version: 60.09 release
[0004.454] I> regulator of usb2-0 already enabled
[0004.461] I> regulator of usb2-1 already enabled
[0004.469] I> regulator of usb2-2 already enabled
[0004.479] I> enabling 'vdd-5v-sata' regulator
[0005.484] E> failed to initialize xhci controller
[0005.485] E> Error in init of XUSB host driver, err: 79790026
[0005.485] W> Failed to initialize device 5-0
[0005.485] E> USB boot failed, err: 2037973030
[0005.486] I> ########## NVME (0) boot ##########
[0005.486] I> Initializing nvme device instance 0
[0005.486] I> Initializing nvme controller
[0005.491] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0005.497] I> vpcie3v3-supply not found
[0005.500] I> vpcie12v-supply not found
[0005.504] W> Failed to get nvidia,plat-gpios
[0005.508] I> tegrabl_pcie_soc_preinit: (0):
[0005.512] I> Unpowergate
[0005.515] I> tegrabl_car_clk_disable(0) ...
[0005.519] I> tegrabl_car_rst_set(CORE, 0) ...
[0005.523] I> tegrabl_car_rst_set(APB, 0) ...
[0005.527] I> tegrabl_car_clk_enable(0) ...
[0005.531] I> tegrabl_car_rst_clear(APB, 0) ...
[0005.535] I> tegrabl_set_ctrl_state(0)
[0005.539] I> CLR PCIE_APB:6
[0005.541] I> tegrabl_pcie_soc_init: (0):
[0005.545] I> APPL initialization ...
[0005.548] I> poweron phys
[0005.551] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0005.557] I> tegrabl_power_on_phy: power on phy @0x3e30000
[0005.563] I> tegrabl_power_on_phy: power on phy @0x3e40000
[0005.568] I> tegrabl_power_on_phy: power on phy @0x3e50000
[0005.573] I> tegrabl_power_on_phy: power on phy @0x3e60000
[0005.706] I> PCIe controller-0 link is up
[0005.706] I> tegra_pcie_info[0].cfg0_base = 0x38000000
[0005.706] I> tegra_pcie_info[0].cfg1_base = 0x38020000
[0005.707] I> tegra_pcie_info[0].atu_dma_base = 0x38040000
[0005.707] I> tegra_pcie_bus[0].mem = 0x38200000
[0005.708] I> Scanning busnr: 0 devfn: 0
[0005.708] I> PCIe IDs: 0x1ad010de
[0005.711] I> PCIe RID_CC: 0x60400a1
[0005.714] I> Scanning busnr: 1 devfn: 0
[0005.718] I> PCIe IDs: 0xa808144d
[0005.721] I> PCIe RID_CC: 0x1080200
[0005.724] I> PCI Config: I/O=0x38100000, Memory=0x38200000
[0005.730] I> MEM64 bar_num=0 bar=0x38200000
[0005.734] I> Number of PCIe devices detected: 2
[0005.738] I> NVME page size: 4096
[0005.742] I> NVMe serial number: S463NF0M809563P
[0005.746] I> NVMe model number: Samsung SSD 970 PRO 512GB
[0005.753] I> NVMe firmware revision: 1B2QEXP7
[0005.758] I> block_count: 1000215216
[0005.760] I> supported_lba: 0
[0005.763] I> block_size_log2: 0x9
[0005.766] I> tegrabl_create_io_queue_cmd: queue size: 2
[0005.772] I> tegrabl_create_io_queue_cmd: queue size: 2
[0005.777] I> nvme device id 000a0000
[0005.780] I> nvme-0 params source =
[0005.784] I> Found 11 partitions in NVME (instance 0)
[0005.788] I> Look for boot partition
[0005.792] I> Fallback: assuming 0th partition is boot partition
[0005.804] I> Detect filesystem
[0005.806] I> Loading kernel-bootctrl from partition
[0005.806] I> Loading partition kernel-bootctrl at 0xa4320000 from device(0xa)
[0005.813] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0005.819] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0005.826] I> Loading extlinux.conf ...
[0005.830] I> Loading extlinux.conf binary from rootfs ...
[0005.835] I> rootfs path: /nvme/boot/extlinux/extlinux.conf
[0005.841] I> ext4_read_data_from_extent:298: Total file read should not be lare
[0005.849] E> file /nvme/boot/extlinux/extlinux.conf read failed!!
[0005.855] W> Failed to load extlinux.conf binary from rootfs (err=202113305)
[0005.862] E> Failed to find/load /boot/extlinux/extlinux.conf
[0005.868] I> Loading kernel ...
[0005.871] I> No kernel binary path
[0005.874] I> Continue to load from partition ...
[0005.879] W> No valid slot number is found in scratch register
[0005.884] W> Return default slot: _a
[0005.888] I> A/B: bin_type (37) slot 0
[0005.891] I> Loading kernel from partition
[0005.895] I> Loading partition kernel at 0xa4320000 from device(0xa)
[0006.225] I> Validate kernel ...
[0006.225] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0006.605] I> Encryption fuse is not ON
[0006.640] I> Checking boot.img header magic ... [0006.640] I> [OK]
[0006.640] I> Loading kernel-dtb ...
[0006.640] I> No kernel-dtb binary path
[0006.641] I> Continue to load from partition ...
[0006.641] W> No valid slot number is found in scratch register
[0006.642] W> Return default slot: _a
[0006.642] I> A/B: bin_type (38) slot 0
[0006.645] I> Loading kernel-dtb from partition
[0006.649] I> Loading partition kernel-dtb at 0x91000000 from device(0xa)
[0006.659] I> Validate kernel-dtb ...
[0006.660] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0006.669] I> Encryption fuse is not ON
[0006.671] I> PCIe (0) link is UP
[0006.683] I> removable_boot_load_kernel_and_dtb: force NVME bdev to close !!!
[0006.684] I> Kernel hdr @0xa4320000
[0006.684] I> Kernel dtb @0x90000000
[0006.686] I> decompressor handler not found
[0006.690] I> Copying kernel image (34484232 bytes) from 0xa4320800 to 0x800800e
[0006.709] I> Move ramdisk (len: 7238366) from 0xa6404000 to 0x92000000
[0006.713] I> Updated bpmp info to DTB
[0006.714] I> Ramdisk: Base: 0x92000000; Size: 0x6e72de
[0006.714] I> Updated initrd info to DTB
[0006.718] W> WARN: Fail to override "console=none" in commandline
[0006.724] I> Active rootfs suffix:
[0006.727] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0006.735] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0006.742] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0006.749] W> No valid slot number is found in scratch register
[0006.755] W> Return default slot: _a
[0006.758] I> Active slot suffix:
[0006.761] I> add_boot_slot_suffix: slot_suffix =
[0006.766] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/nvme0n1p1 rw root
[0006.803] I> Updated bootarg info to DTB
[0006.807] W> MAC addr invalid!
[0006.810] E> Failed to get WIFI MAC address
[0006.814] W> MAC addr invalid!
[0006.817] E> Failed to get Bluetooth MAC address
[0006.821] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:05:b5:93
[0006.828] W> "plugin-manager" doesn't exist, creating
[0006.832] I> Adding /chosen/plugin-manager/cvm
[0006.836] W> "chip-id" doesn't exist, creating
[0006.841] I> Adding /chosen/plugin-manager/chip-id
[0006.845] W> "configs" doesn't exist, creating
[0006.849] I> Adding /chosen/plugin-manager/configs
[0006.854] W> "ids" doesn't exist, creating
[0006.858] I> Adding /chosen/plugin-manager/ids
[0006.863] W> "odm-data" doesn't exist, creating
[0006.867] I> Adding /chosen/plugin-manager/odm-data
[0006.874] W> "memory" doesn't exist, creating
[0006.876] I> [0] START: 0x80000000, END: 0xac000000
[0006.880] I> [1] START: 0xac004000, END: 0xf0ad0000
[0006.885] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0006.890] I> dram_block larger than 80000000
[0006.894] I> [3] START: 0x100000000, END: 0x880000000
[0006.899] I> added [base:0x80000000, size:0x2c000000] to /memory
[0006.905] I> added [base:0xac200000, size:0x44800000] to /memory
[0006.910] I> added [base:0x100000000, size:0x780000000] to /memory
[0006.917] I> Updated memory info to DTB
[0006.920] E> add_disp_param: failed to get display params for du=0
[0006.927] W> "reset" doesn't exist, creating
[0006.931] I> Adding ecid(00000001646406490000000011008100) to DT
[0006.936] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0006.941] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0006.946] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0006.950] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0006.955] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0006.960] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0006.965] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0006.969] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0006.975] W> "misc-data" doesn't exist, creating
[0006.979] I> Boot-device: eMMC
[0006.981] I> Add boot-sdmmc to plugin-manager/misc-data
[0006.987] I> Add storage-sdmmc to plugin-manager/misc-data
[0006.992] W> Unknown storage device
[0006.996] I> Add serial number:1421720004340 as DT property
[0007.002] I> Plugin-manager override starting
[0007.005] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0007.012] I> node /plugin-manager/fragement-soft-wdt matches
[0007.020] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0007.024] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0007.037] I> Disable plugin-manager status in FDT
[0007.038] I> Plugin-manager override finished successfully
[0007.038] I> tegrabl_load_kernel_and_dtb: Done
[0007.042] E> tegrabl_display_clear: display is not initialized
[0007.048] W> Boot logo display failed...
[0007.051] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5374-d5000) (2
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible s
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nt
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatiblm
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa6
[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/nvme0n1p1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 30088(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 by)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 byt)
[ 0.000000] Memory: 31925496K/33298432K available (15358K kernel code, 2956K)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 )
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 )
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 )
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 )
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 )
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 )
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 )
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 )
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 )
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 )
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf20000000 ( 512 )
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc800000000 ( 32768 )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (p.
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[ 0.010532] Console: colour dummy device 80x25
[ 0.012427] console [tty0] enabled
[ 0.015600] bootconsole [tegra_comb_uart0] disabled
[ 0.020851] kmemleak: Kernel memory leak detector disabled
[ 0.020887] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.020927] pid_max: default: 32768 minimum: 301
[ 0.022012] Security Framework initialized
[ 0.022572] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.022601] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 byt)
[ 0.024657] ftrace: allocating 47098 entries in 184 pages
[ 0.424810] sched-energy: Sched-energy-costs installed from DT
[ 0.424847] ASID allocator initialised with 65536 entries
[ 0.466318] tegra-id: chipid=21917.
[ 0.466347] tegra-id: opt_subrevision=1.
[ 0.466403] Tegra Revision: A02p SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.466447] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9i
[ 0.466511] DTB Build time: Apr 17 2022 02:42:31
[ 0.518779] CPU1: Booted secondary processor [4e0f0040]
[ 0.551806] CPU2: Booted secondary processor [4e0f0040]
[ 0.584000] CPU3: Booted secondary processor [4e0f0040]
[ 0.616258] CPU4: Booted secondary processor [4e0f0040]
[ 0.648211] CPU5: Booted secondary processor [4e0f0040]
[ 0.680732] CPU6: Booted secondary processor [4e0f0040]
[ 0.712574] CPU7: Booted secondary processor [4e0f0040]
[ 0.712837] Brought up 8 CPUs
[ 0.713074] SMP: Total of 8 processors activated.
[ 0.713112] CPU features: detected feature: Privileged Access Never
[ 0.713161] CPU features: detected feature: LSE atomic instructions
[ 0.713202] CPU features: detected feature: User Access Override
[ 0.713230] CPU features: detected feature: 32-bit EL0 Support
[ 0.715093] CPU: All CPU(s) started at EL2
[ 0.715183] alternatives: patching kernel code
[ 0.724471] devtmpfs: initialized
[ 0.788441] Initilizing CustomIPI irq domain
[ 0.788714] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.788754] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.798671] pinctrl core: initialized pinctrl subsystem
[ 0.798975] OS set in device tree is not L4T.
[ 0.799286] regulator-dummy: no parameters
[ 0.799605] Initializing plugin-manager
[ 0.799669] Plugin module not found
[ 0.799719] Plugin-manager status disabled
[ 0.801288] NET: Registered protocol family 16
[ 0.802687] pstore: using zlib compression
[ 0.803399] console [pstore-1] enabled
[ 0.803425] pstore: Registered ramoops as persistent store backend
[ 0.803452] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.820954] cpuidle: using governor menu
[ 0.822365] bpmp: waiting for handshake
[ 0.822423] bpmp: handshake completed
[ 0.822464] bpmp: synchronizing channels
[ 0.822494] bpmp: channels synchronized
[ 0.822542] bpmp: mail init ok
[ 0.825682] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.825920] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.825950] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.825976] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.826024] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.826050] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.826103] t19x-arm-smmu 12000000.iommu: stream matching with 128 regist0
[ 0.826138] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000)!
[ 0.826193] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 onl)
[ 0.826222] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.826268] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.830383] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84)
[ 0.830440] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.833605] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atoms
[ 0.836230] tegra_aon_clk_init: ok
[ 0.836264] Registering BPMP clocks...
[ 0.836385] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.837439] Serial: AMBA PL011 UART driver
[ 0.837620] tegra_powergate_init: DONE
[ 0.837673] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9i
[ 0.837710] DTB Build time: Apr 17 2022 02:42:31
[ 0.842105] Tegra reboot handler registered.
[ 0.850312] iommu: Adding device 14180000.pcie to group 0
[ 0.851063] iommu: Adding device 14100000.pcie to group 1
[ 0.851814] iommu: Adding device 14140000.pcie to group 2
[ 0.852524] iommu: Adding device 141a0000.pcie to group 3
[ 0.854015] iommu: Adding device 2490000.ether_qos to group 4
[ 0.854596] iommu: Adding device 3100000.serial to group 5
[ 0.855177] iommu: Adding device 3110000.serial to group 6
[ 0.855656] iommu: Adding device 3140000.serial to group 7
[ 0.856255] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.856438] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.856488] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.856512] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.856534] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.856625] tegra-pmc: PMC Prod config success
[ 0.856920] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registerd
[ 0.856965] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.857358] iommu: Adding device 3460000.sdhci to group 8
[ 0.857964] iommu: Adding device 3400000.sdhci to group 9
[ 0.858631] iommu: Adding device 2450000.ufshci to group 10
[ 0.859356] iommu: Adding device 3210000.spi to group 11
[ 0.859874] iommu: Adding device c260000.spi to group 12
[ 0.860991] iommu: Adding device 3160000.i2c to group 13
[ 0.861493] iommu: Adding device c240000.i2c to group 14
[ 0.861950] iommu: Adding device 3180000.i2c to group 15
[ 0.862418] iommu: Adding device 3190000.i2c to group 16
[ 0.863064] iommu: Adding device 31b0000.i2c to group 17
[ 0.863569] iommu: Adding device 31c0000.i2c to group 18
[ 0.864014] iommu: Adding device c250000.i2c to group 19
[ 0.864455] iommu: Adding device 31e0000.i2c to group 20
[ 0.865409] iommu: Adding device sound to group 21
[ 0.865959] iommu: Adding device 3510000.hda to group 22
[ 0.866602] iommu: Adding device bc00000.rtcpu to group 23
[ 0.868839] iommu: Adding device 13e10000.host1x to group 24
[ 0.869273] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.869774] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.870185] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.870640] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.871053] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.871485] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.871928] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.872343] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.872900] iommu: Adding device 15340000.vic to group 33
[ 0.873372] iommu: Adding device 15380000.nvjpg to group 34
[ 0.873752] iommu: Adding device 15500000.tsec to group 35
[ 0.874095] iommu: Adding device 15100000.tsecb to group 36
[ 0.874390] iommu: Adding device 15480000.nvdec to group 37
[ 0.874676] iommu: Adding device 15140000.nvdec1 to group 38
[ 0.874974] iommu: Adding device 154c0000.nvenc to group 39
[ 0.875298] iommu: Adding device 15a80000.nvenc1 to group 40
[ 0.875737] iommu: Adding device 15880000.nvdla0 to group 41
[ 0.876176] iommu: Adding device 158c0000.nvdla1 to group 42
[ 0.876766] iommu: Adding device 15200000.nvdisplay to group 43
[ 0.880839] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000()
[ 0.880938] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.881679] iommu: Adding device 15210000.nvdisplay to group 44
[ 0.881786] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.882265] iommu: Adding device 15220000.nvdisplay to group 45
[ 0.882332] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.884505] iommu: Adding device 15c10000.vi to group 46
[ 0.884716] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.885209] iommu: Adding device 14800000.isp to group 47
[ 0.886167] iommu: Adding device 16000000.pva0 to group 48
[ 0.886807] iommu: Adding device 16800000.pva1 to group 49
[ 0.887255] iommu: Adding device 15810000.se to group 50
[ 0.887684] iommu: Adding device 15820000.se to group 51
[ 0.888056] iommu: Adding device 15830000.se to group 52
[ 0.888361] iommu: Adding device 15840000.se to group 53
[ 0.888663] iommu: Adding device c1a0000.aon to group 54
[ 0.890551] iommu: Adding device d000000.bpmp to group 55
[ 0.890987] bpmp: ping status is 0
[ 0.891127] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b55
[ 0.894771] bpmp d000000.bpmp: probe ok
[ 0.896744] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.897258] iommu: Adding device smmu_test to group 56
[ 0.898383] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[ 0.898428] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[ 0.898469] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[ 0.898510] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[ 0.898547] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[ 0.898584] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[ 0.898621] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[ 0.898658] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[ 0.898694] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[ 0.898729] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[ 0.898765] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[ 0.898801] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[ 0.898836] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[ 0.898873] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[ 0.898909] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[ 0.898945] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[ 0.898981] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[ 0.899109] mc-err: mcerr ops are set to t19x
[ 0.905390] iommu: Adding device 2600000.dma to group 57
[ 0.911023] gpio gpiochip0: gpio-line-names specifies 210 line names but thep
[ 0.912145] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.912473] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpioc)
[ 0.920466] gpio gpiochip1: gpio-line-names specifies 30 line names but therp
[ 0.920580] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.920907] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpioc)
[ 0.923590] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.923644] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.923672] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.924705] iommu: Adding device 3550000.xudc to group 58
[ 0.925478] iommu: Adding device 3610000.xhci to group 59
[ 0.927964] arm64_ras arm64_ras: probed
[ 0.928495] ras_fhi_enable: FHI 479 enabled on CPU0
[ 0.928563] ras_fhi_enable: FHI 480 enabled on CPU1
[ 0.928674] ras_fhi_enable: FHI 481 enabled on CPU2
[ 0.928783] ras_fhi_enable: FHI 482 enabled on CPU3
[ 0.928850] ras_fhi_enable: FHI 483 enabled on CPU4
[ 0.928927] ras_fhi_enable: FHI 484 enabled on CPU5
[ 0.929025] ras_fhi_enable: FHI 485 enabled on CPU6
[ 0.929108] ras_fhi_enable: FHI 486 enabled on CPU7
[ 0.929359] carmel_ras_enable: RAS enabled on cpu0
[ 0.929586] carmel_ras_enable: RAS enabled on cpu1
[ 0.929821] carmel_ras_enable: RAS enabled on cpu2
[ 0.930068] carmel_ras_enable: RAS enabled on cpu3
[ 0.930284] carmel_ras_enable: RAS enabled on cpu4
[ 0.930524] carmel_ras_enable: RAS enabled on cpu5
[ 0.930729] carmel_ras_enable: RAS enabled on cpu6
[ 0.930936] carmel_ras_enable: RAS enabled on cpu7
[ 0.931071] carmel_ras carmel_ras: probed
[ 0.932470] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 488, noc_nonsecure_i>
[ 0.933100] tegra-cbb c600000.aon-noc: noc_secure_irq = 490, noc_nonsecure_i>
[ 0.934138] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 492, noc_nonsecure_>
[ 0.935142] tegra-cbb be00000.rce-noc: noc_secure_irq = 494, noc_nonsecure_i>
[ 0.936124] tegra-cbb b600000.sce-noc: noc_secure_irq = 496, noc_nonsecure_i>
[ 0.936560] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.939696] vdd-3v3-cvb: 3300 mV
[ 0.940044] vdd-1v8-cvb: 1800 mV
[ 0.940564] vdd-1v8-sd: 1800 mV
[ 0.940935] vdd-epb-1v0: 1000 mV
[ 0.941345] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.941635] vdd-sdmmc1-sw: 3300 mV
[ 0.942036] avdd-cam-2v8: 2800 mV
[ 0.942408] vdd-sata-1v5: 1500 mV
[ 0.942751] vdd-1v8-slt: 1800 mV
[ 0.943075] vdd-3v3-slt: 3300 mV
[ 0.943457] vdd-fan: 5000 mV
[ 0.943890] vdd-hdmi-5v0: 5000 mV
[ 0.944290] vdd_sys_en: 1200 mV
[ 0.944757] vdd-5v-sata: 5000 mV
[ 0.945263] vdd-3v3-pcie: 3300 mV
[ 0.945735] vdd-12v-pcie: 1200 mV
[ 0.946137] vdd-ac-bat: 5000 mV
[ 0.946373] vdd-5v-sata: supplied by vdd-ac-bat
[ 0.977490] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.982032] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.982422] SCSI subsystem initialized
[ 0.982926] usbcore: registered new interface driver usbfs
[ 0.982990] usbcore: registered new interface driver hub
[ 0.983079] usbcore: registered new device driver usb
[ 0.994388] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/de
[ 0.997348] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.004900] vdd-1v0: at 1000 mV
[ 1.008986] vdd-1v8-hs: at 1800 mV
[ 1.013003] vdd-1v8-ls: at 1800 mV
[ 1.017022] vdd-1v8-ao: at 1800 mV
[ 1.021012] vddio-ddr-1v1: at 1100 mV
[ 1.024801] vdd-rtc: at 800 mV
[ 1.026128] spmic-ldo1: at 2375 mV
[ 1.032837] vdd-ao-3v3: at 3300 mV
[ 1.040873] vddio-emmc-3v3: at 3300 mV
[ 1.042335] spmic-ldo4: at 1587 mV
[ 1.049320] vdd-usb-3v3: at 3300 mV
[ 1.057349] vddio-sdmmc1-3v3: at 3300 mV
[ 1.061367] vdd-csi-1v2: at 1200 mV
[ 1.063061] spmic-ldo8: at 1800 mV
[ 1.068183] GPIO line 246 (gpio_default) hogged as output/high
[ 1.069615] GPIO line 247 (gpio_default) hogged as output/high
[ 1.070033] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpioc)
[ 1.070439] max77620 4-003c: max77620 probe successful
[ 1.071146] media: Linux media interface: v0.10
[ 1.071240] Linux video capture interface: v2.00
[ 1.072651] pps_core: LinuxPPS API ver. 1 registered
[ 1.072674] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 1.072736] PTP clock support registered
[ 1.073008] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.073343] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.073402] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.075928] trusty trusty: trusty version: Built: 02:25:37 Apr 17 2022
[ 1.076024] trusty trusty: selected api version: 3 (requested 3)
[ 1.077037] Advanced Linux Sound Architecture Driver Initialized.
[ 1.077717] Bluetooth: Core ver 2.22
[ 1.077774] NET: Registered protocol family 31
[ 1.077798] Bluetooth: HCI device and connection manager initialized
[ 1.077823] Bluetooth: HCI socket layer initialized
[ 1.077845] Bluetooth: L2CAP socket layer initialized
[ 1.077887] Bluetooth: SCO socket layer initialized
[ 1.080515] camchar: rtcpu character device driver loaded
[ 1.082327] clocksource: Switched to clocksource arch_sys_counter
[ 1.133910] VFS: Disk quotas dquot_6.6.0
[ 1.134018] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.134482] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.135912] tegra-carveouts tegra-carveouts: assigned reserved memory node gs
[ 1.135994] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vp0
[ 1.136297] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.136322] dma_declare_coherent_resizable_cma_memory:373: resizable cma heal
[ 1.136376] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.136409] nvmap_page_pool_init: Total RAM pages: 8169790
[ 1.136434] nvmap_page_pool_init: nvmap page pool size: 1021223 pages (3989 )
[ 1.136650] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.137076] misc nvmap: created heap vpr base 0x00000000c6000000 size (68812)
[ 1.139589] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.153582] thermal thermal_zone0: Registering thermal zone thermal_zone0 fom
[ 1.153877] thermal thermal_zone1: Registering thermal zone thermal_zone1 fom
[ 1.154180] thermal thermal_zone2: Registering thermal zone thermal_zone2 fom
[ 1.154434] thermal thermal_zone3: Registering thermal zone thermal_zone3 fom
[ 1.154689] thermal thermal_zone4: Registering thermal zone thermal_zone4 foe
[ 1.154843] thermal thermal_zone5: Registering thermal zone thermal_zone5 foa
[ 1.154994] thermal thermal_zone6: Registering thermal zone thermal_zone6 foa
[ 1.156187] la/ptsa driver initialized.
[ 1.156532] NET: Registered protocol family 2
[ 1.156667] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.164124] TCP established hash table entries: 262144 (order: 9, 2097152 by)
[ 1.165528] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.166161] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.166235] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.166759] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.167379] NET: Registered protocol family 1
[ 1.167952] RPC: Registered named UNIX socket transport module.
[ 1.167975] RPC: Registered udp transport module.
[ 1.167998] RPC: Registered tcp transport module.
[ 1.168019] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.168257] Trying to unpack rootfs image as initramfs...
[ 1.387457] Freeing initrd memory: 7068K
[ 1.407214] random: fast init done
[ 1.411291] host1x 13e10000.host1x: initialized
[ 1.414114] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[ 1.418958] audit: initializing netlink subsys (disabled)
[ 1.419041] audit: type=2000 audit(1.020:1): initialized
[ 1.419788] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.430582] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.431861] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.432523] 9p: Installing v9fs 9p2000 file system support
[ 1.438171] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 1.438351] io scheduler noop registered
[ 1.438657] io scheduler cfq registered (default)
[ 1.442774] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.475049] iommu: Adding device 2993000.adsp to group 60
[ 1.592237] iommu: Adding device aconnect@2a41000:adsp_audio to group 61
[ 1.593203] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.607193] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.607642] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.608237] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.608719] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.611670] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:e
[ 1.612018] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_isos
[ 1.612075] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0
[ 1.615504] tsec 15500000.tsec: initialized
[ 1.617472] tsec 15100000.tsecb: initialized
[ 1.621845] nvdec 15480000.nvdec: initialized
[ 1.624536] nvdec 15140000.nvdec1: initialized
[ 1.631036] falcon 15340000.vic: initialized
[ 1.632966] falcon 15380000.nvjpg: initialized
[ 1.634939] falcon 154c0000.nvenc: initialized
[ 1.637023] falcon 15a80000.nvenc1: initialized
[ 1.639918] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.641505] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.643208] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.644764] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.646377] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.647870] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.649414] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.650946] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.654583] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.659946] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.660370] scare-pigeon 14b00000.isp-thi: initialized
[ 1.670359] pva 16000000.pva0: initialized
[ 1.701822] pva 16800000.pva1: initialized
[ 1.732358] nvdla 15880000.nvdla0: initialized
[ 1.762380] nvdla 158c0000.nvdla1: initialized
[ 1.763976] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.764017] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.764075] tegradccommon 15200000.dc_common: dma mapping done
[ 1.764835] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/so2
[ 1.764909] generic_infoframe_type: 0x87
[ 1.765026] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.765102] tegradc 15200000.nvdisplay: Display dc.ffffff800bce0000 register0
[ 1.769021] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = s
[ 1.769053] tegra_nvdisp_bandwidth_register_max_config: max config EMC floorz
[ 1.769076] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = z
[ 1.769309] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.769334] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.772394] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdd
[ 1.772433] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd)d
[ 1.776102] tegradc 15200000.nvdisplay: probed
[ 1.776789] Console: switching to colour frame buffer device 80x30
[ 1.776866] tegradc 15200000.nvdisplay: fb registered
[ 1.777170] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 1.777690] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 1.777966] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 1.778158] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FF5
[ 1.778212] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.778536] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.778592] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.778926] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.778962] tegra_cec 3960000.tegra_cec: probed
[ 1.789810] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 chans
[ 1.790654] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check dd
[ 1.790685] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initid
[ 1.791046] kfuse 3830000.kfuse: initialized
[ 1.797458] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.800267] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 51, base_baud =T
[ 1.801414] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 52, base_baud =T
[ 1.802420] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 53, base_baud =T
[ 2.794415] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.794426] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 4.319262] console [ttyTCU0] enabled
[ 4.323317] [drm] Initialized
[ 4.339509] brd: module loaded
[ 4.345560] loop: module loaded
[ 4.345708] tegra_profiler: version: 1.145, samples/io: 49/28
[ 4.346070] tegra_profiler: auth: init
[ 4.346773] nct1008_nct72 4-004c: starting parse dt
[ 4.347135] THERMAL EST: found 3 subdevs
[ 4.347139] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.347157] nct1008_nct72 4-004c: success parsing dt
[ 4.347279] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.368070] THERMAL EST num_resources: 0
[ 4.372002] [THERMAL EST subdev 0]
[ 4.375245] [THERMAL EST subdev 1]
[ 4.378654] [THERMAL EST subdev 2]
[ 4.382064] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.382642] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 4.383339] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 4.399508] thermal thermal_zone7: Registering thermal zone thermal_zone7 fot
[ 4.408143] THERMAL EST: thz register success.
[ 4.412556] THERMAL EST: end of probe, return err: 0
[ 4.417985] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.419976] nct1008_nct72 4-004c: initial LOC temp: 38000
[ 4.420484] nct1008_nct72 4-004c: initial EXT temp: 49500
[ 4.421452] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 4.422370] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 4.445864] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vd
[ 4.457716] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 461
[ 4.463022] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.478970] sd: No Scsi addr parsed to reserve index
[ 4.479159] hisi_sas: driver version v1.6
