Dear linuxdev thanks for your help!
Here are the output from the suggested actions.
ifconfig
enp0s25: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether d8:9d:67:99:fd:f4 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 17 memory 0xd4700000-d4720000
enp0s20u3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.55.100 netmask 255.255.255.0 broadcast 192.168.55.255
inet6 fe80::1d0:2636:7fdd:95dc prefixlen 64 scopeid 0x20
ether 56:68:fa:7e:59:11 txqueuelen 1000 (Ethernet)
RX packets 115 bytes 12394 (12.3 KB)
TX packets 44 bytes 8986 (8.9 KB)
enp0s20u3i5: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 76:dd:69:89:ea:6a txqueuelen 1000 (Ethernet)
RX packets 110 bytes 12476 (12.4 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 266 bytes 21989 (21.9 KB)
TX packets 266 bytes 21989 (21.9 KB)
wlo1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.214 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::f4b0:f5dc:5aa6:c5d2 prefixlen 64 scopeid 0x20
ether 84:3a:4b:3d:ba:6c txqueuelen 1000 (Ethernet)
RX packets 9403 bytes 12085841 (12.0 MB)
TX packets 4216 bytes 429617 (429.6 KB)
route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default api.premiumzone 0.0.0.0 UG 600 0 0 wlo1
link-local 0.0.0.0 255.255.0.0 U 1000 0 0 enp0s20u3
192.168.1.0 0.0.0.0 255.255.255.0 U 600 0 0 wlo1
192.168.55.0 0.0.0.0 255.255.255.0 U 100 0 0 enp0s20u3
sudo -s
… :~# ssh user@192.168.55.1
The authenticity of host ‘192.168.55.1 (192.168.55.1)’ can’t be established.
ECDSA key fingerprint is SHA256:Z3cC1bktw7eKn/QUygJt+ur2pB8UqQUqYCVJLZyqkm4.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added ‘192.168.55.1’ (ECDSA) to the list of known hosts.
user@192.168.55.1’s password:
Welcome to Ubuntu 18.04.2 LTS (GNU/Linux 4.9.140-tegra aarch64)
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the ‘unminimize’ command.
0 packages can be updated.
0 updates are security updates.
Last login: Mon Oct 14 09:00:43 2019 from 192.168.55.100
To run a command as administrator (user “root”), use "sudo ".
See “man sudo_root” for details.
user@192.168.55.1:~ ls
Desktop Documents Downloads examples.desktop Music Pictures Public Templates Videos
user@192.168.55.1:~ exit
logout
Connection to 192.168.55.1 closed.
root@… :~# exit
exit
