o writing through dangling symlink "etc/resolv.comf'
6.365795] group: group2: unknown option "nsdelegate"
7.424271] iwlwifi0003:01:00.0: Direct firmware load for iwlwifi-8265-26 .ucode failed with error -2
7.424537] iwlwifi 0003:01:00.0: Falling back to user he _per
7.598303] using random self ethernet address
7.598504] using random host ethernet address
7.853940] random: crng init done
7.854078] random: 7 random warning (S)
missed due to ratelimiting
7.932911] scsi2:0:0:0: Direct-Access
SanDisk
Ultra USB 3,0
1.00 PQ:
O ANSI 6
7.937430] sd2:0:0:0: (sda) 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
7.940151] sd2:0:0:0:
Ida] Write Protect is off
7.942973] sd2:0:0:01
Lsda) Write cache: disabled, read cache: enabled, doesn't support PO or FUA
7.979254] sd 2:0:0:0: (da] Attached SCSI removable disk
B.238771] using random selt ethernet address
8.238918] using random host ethernet address
8.621397] iwlwifi0003:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
8.621402] iwlwifi0003:01:00.0: Falling back to user helper
8.890469] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error
=2
8.890474] iwlwifi 0003:01:00.0: Faling back to user he Aper
8.902398]
iwlwifi 0003:01:00.0: Direct firmware load tor iwlwifi-8265-23.ucode failed with error
8.902402] iwlwifi0003:01:00.0: Falling back to user helper
9.465916] thermal thermal_zone8: failed to read out thermal zone (-5)
0.710508] uvcvideo 1-1.4.3:1.0: Ent ity type for ent.ity Extension 4 was not initialized!
0.7107471 uxcv icieo 1-1.4.3:1.0: Ent ity type for ent ity Extens ion 6 was not init ialized!
0.710926] uvcvideo 1-1.4.3:1.0: Entity type for entity Extension 7 was not initialized!
0.711112 uvcvideo 1-1.4.3:1.0: Entity type for entity Processing 2 was not initialized!
0.711292] uvcvideo 1-1.4.3:1.0: Entity type or entity Extension 3 was not initialized!
0.711481) uvcvideo 1-1.4.3:1.0: Entity type for entity Camera 1 was not initialized!
0.731387J uvcviceo 1-1.4.4:1.0: Ent ity type for entity Extens ion 4 uas not init ialized!
0.731652J uvcvideo 1-1.4.4:1.0: Ent ity type for ent ity Extension 6 was not init ializedl
0.7816491 uvcVi0€0 1-1.4.4:1.0: Ent ity type tor entity Extens ion 7 was not initialized!
0.732048] uvcvideo 1-1.4.4:1.01 Entity type for entity Processing 2 was not
0.732267] uvcvideo 1-1.4.4:1.0: Entity
inltlalizedh
type for entity Extension 3 was not initialized!
0.732468] uvcvideo 1-1.4.4:1.0: Entity type for entity Camera 1 was not initialized!
ctrl+ alt + F1 ~F6 to switch console.
Check the /var/log/Xorg.0.log
I can’t get into the terminal, the screen keeps flashing, the following is the log file I exported from sdkmanager
15:45:10.247 - info: SDK Manager started running at: 2022-05-24 15:45:10.246
15:45:10.249 - info: SDK Manager log file name: sdkm-2022-05-24-15-45-10.log
15:45:10.249 - info: SDK Manager client version: 1.8.0
15:45:10.249 - info: SDK Manager is running in GUI mode
15:45:11.824 - info: Current DB Version: 17
15:45:12.255 - info: Created symlink /home/py/.nvsdkm/sdkm-2022-05-24-15-45-10.log => /home/py/.nvsdkm/sdkm.log
15:45:12.037 - warn: Registering a callback with no name for event: Session started
15:45:12.741 - info: /etc/os-release NAME="Ubuntu"
VERSION="20.04.4 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.4 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
15:45:12.760 - info: /etc/issue Ubuntu 20.04.4 LTS \n \l
15:45:12.762 - info: /etc/lsb-release DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.4 LTS"
15:45:12.768 - info: codeNameCounts in /etc/apt/sources.list { focal: 10 }
15:45:12.771 - warn: Registering a callback with no name for event: System settings table changed after getting machineInfo
15:45:13.107 - info: User agent for http requests: SDKM/1.8.0.10363 (ubuntu2004)
15:45:13.195 - warn: Registering a callback with no name for event: Session started
15:45:13.330 - info: Initializing hwDataManager
15:45:13.346 - info: Loading HW family: Jetson
15:45:13.447 - info: Loading HW family: DRIVE
15:45:13.461 - info: Loading HW family: Switch
15:45:13.480 - info: Loading HW family: DOCA
15:45:13.508 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.508 - warn: Registering a callback with no name for event: Report component install/uninstall error messages
15:45:13.508 - warn: Registering a callback with no name for event: Report component install/uninstall error code/type
15:45:13.509 - info: downloadMetrics.reset
15:45:13.509 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.509 - warn: Registering a callback with no name for event: Session resumed
15:45:13.510 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.510 - warn: Registering a callback with no name for event: Session status initialization is complete
15:45:13.510 - warn: Registering a callback with no name for event: Session started
15:45:13.510 - warn: Registering a callback with no name for event: Session ended
15:45:13.510 - warn: Registering a callback with no name for event: File init download status
15:45:13.510 - warn: Registering a callback with no name for event: File pending download
15:45:13.510 - warn: Registering a callback with no name for event: File started downloading
15:45:13.510 - warn: Registering a callback with no name for event: File finished downloading
15:45:13.510 - warn: Registering a callback with no name for event: File checksum verifying
15:45:13.510 - warn: Registering a callback with no name for event: Component init status
15:45:13.510 - warn: Registering a callback with no name for event: Component started action
15:45:13.510 - warn: Registering a callback with no name for event: Component finished pausing download
15:45:13.510 - warn: Registering a callback with no name for event: Component finished resuming download
15:45:13.510 - warn: Registering a callback with no name for event: Component finished action
15:45:13.510 - warn: Registering a callback with no name for event: Terminal output
15:45:13.510 - warn: Registering a callback with no name for event: Device connection retry is complete
15:45:13.511 - warn: Registering a callback with no name for event: Session started
15:45:13.511 - warn: Registering a callback with no name for event: Component finished action
15:45:13.512 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.512 - warn: Registering a callback with no name for event: Component finished action
15:45:13.513 - info: Forking worker process
15:45:13.517 - info: Initializing the download service
15:45:13.522 - info: Download service pid is: 18334
15:45:13.523 - warn: Registering a callback with no name for event: File download in progress
15:45:13.523 - warn: Registering a callback with no name for event: File finished downloading
15:45:13.524 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.524 - warn: Registering a callback with no name for event: Session started
15:45:13.524 - warn: Registering a callback with no name for event: File download in progress
15:45:13.524 - warn: Registering a callback with no name for event: File finished downloading
15:45:13.524 - warn: Registering a callback with no name for event: File reset downloaded size
15:45:13.524 - warn: Registering a callback with no name for event: File download size updated
15:45:13.524 - warn: Registering a callback with no name for event: Component init status
15:45:13.524 - warn: Registering a callback with no name for event: Component started action
15:45:13.524 - warn: Registering a callback with no name for event: Component progress for action
15:45:13.524 - warn: Registering a callback with no name for event: Component finished action
15:45:13.525 - info: Download manager can use up to 12 download threads per file
15:45:13.525 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.631 - info: create .sdkm.bashrc under /home/py/.nvsdkm/.sdkm.bashrc
15:45:13.638 - warn: Registering a callback with no name for event: Session ended
15:45:13.639 - info: installMetrics.reset
15:45:13.639 - warn: Registering a callback with no name for event: Session started
15:45:13.639 - info: uninstallMetrics.reset
15:45:13.640 - warn: Registering a callback with no name for event: HW device was added
15:45:13.640 - warn: Registering a callback with no name for event: HW device was removed
15:45:13.642 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.644 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:13.644 - warn: Registering a callback with no name for event: Component finished action
15:45:13.644 - warn: Registering a callback with no name for event: File finished downloading
15:45:13.644 - warn: Registering a callback with no name for event: Component finished downloading
15:45:13.644 - warn: Registering a callback with no name for event: Session started
15:45:13.644 - warn: Registering a callback with no name for event: Session before ended
15:45:13.644 - warn: Registering a callback with no name for event: Session ended
15:45:13.644 - warn: Registering a callback with no name for event: Session resumed
15:45:13.644 - warn: Registering a callback with no name for event: Session paused
15:45:13.644 - warn: Registering a callback with no name for event: Session complete when pausing
15:45:13.816 - info: Device Detection Service Started.
15:45:14.677 - warn: Registering a callback with no name for event: File started downloading
15:45:14.677 - warn: Registering a callback with no name for event: File download in progress
15:45:14.677 - warn: Registering a callback with no name for event: File checksum verifying
15:45:14.677 - warn: Registering a callback with no name for event: File finished downloading
15:45:14.886 - warn: Registering a callback with no name for event: Active bundle loaded
15:45:14.886 - warn: Registering a callback with no name for event: Session ended
15:45:14.887 - warn: Registering a callback with no name for event: Detected devices updated
15:45:14.891 - warn: Registering a callback with no name for event: Session status initialization is complete
15:45:14.891 - warn: Registering a callback with no name for event: Session ended
15:45:14.891 - warn: Registering a callback with no name for event: Terminal output
15:45:14.891 - warn: Registering a callback with no name for event: Login progress
15:45:14.892 - warn: Registering a callback with no name for event: undefined
15:45:14.892 - warn: Registering a callback with no name for event: Component download in progress
15:45:14.892 - warn: Registering a callback with no name for event: Component progress for action
15:45:14.892 - warn: Registering a callback with no name for event: Component started action
15:45:14.892 - warn: Registering a callback with no name for event: File started downloading
15:45:14.892 - warn: Registering a callback with no name for event: Component init status
15:45:14.892 - warn: Registering a callback with no name for event: Component finished pausing download
15:45:14.892 - warn: Registering a callback with no name for event: Component finished resuming download
15:45:14.892 - warn: Registering a callback with no name for event: Component finished downloading
15:45:14.892 - warn: Registering a callback with no name for event: Group finished downloading
15:45:14.892 - warn: Registering a callback with no name for event: Component finished action
15:45:14.892 - warn: Registering a callback with no name for event: Session paused
15:45:14.892 - warn: Registering a callback with no name for event: Session resumed
15:45:14.898 - info: Logger level is set to: info
15:45:15.149 - warn: Registering a callback with no name for event: Login progress
15:45:15.150 - warn: Registering a callback with no name for event: CLI Abort
15:45:15.150 - warn: Registering a callback with no name for event: Session ended
15:45:15.232 - info: Front-end main function (startMain) was called
15:45:15.331 - info: Creating auto update task
15:45:15.359 - info: Host OS: ubuntu2004
15:45:15.361 - info: packageJson: /opt/nvidia/sdkmanager/resources/app/package.json
15:45:15.436 - info: [Download Service]:Download service is initializing
15:45:15.436 - info: [Download Service]:Download service was initialized
15:45:15.436 - info: [Download Service]:Got heartbeat request
15:45:15.436 - info: [Download Service] Download service is alive
15:45:15.702 - info: Application configuration is: {
mainRepoURL: [Getter/Setter],
PIDServer: [Getter/Setter],
DevZoneServer: [Getter/Setter],
StarfleetServer: [Getter/Setter]
15:45:15.757 - info: trying to autologin with already signed in user
15:45:15.759 - info: token has not yet expired, validating with starfleet
15:45:15.759 - info: Logging in...
15:45:15.760 - info: Event: Login Progress: Authenticating with NVIDIA server...
15:45:15.763 - info: manifest: {"name":"sdkmanager","releaseVersion":"1.8.0","releaseRevision":"0","releaseBuild":"10363","release":false,"chrome":"78.0.3904.113"}
15:45:15.763 - info: Telemetry parameters are: title: SDK Manager 1.8.0.10363 version: 1.8.0 dev: 0 internal: false
15:45:15.769 - info: Telemetry: allow = Allow. isGDPRAllowed=true
15:45:15.769 - info: Initializing Telemetry visitor. Application: SDK Manager 1.8.0.10363. Version: 1.8.0.10363. clientMode: UI. isDevelopmentEnvironment: 0. NV User: false
15:45:15.770 - info: Initialized Telemetry for SDK Manager. TrackID: UA-59254929-54. UserID: e298615f-660f-5e7d-bfac-23c14d9d9b08.
15:45:15.770 - info: Telemetry: setting custom dimensions: UserType, SDKMode, SDKMVersion External UI 1.8.0.10363
15:45:15.770 - info: Setting custom dimension: UserType - cd5, External
15:45:15.770 - info: Setting custom dimension: SDKMode - cd6, UI
15:45:15.770 - info: Setting custom dimension: SDKMVersion - cd8, 1.8.0.10363
15:45:15.771 - info: Telemetry: setting user os custom dimensions: ubuntu2004
15:45:15.771 - info: Setting custom dimension: UserOS - cd16, ubuntu2004
15:45:15.806 - info: Total memory: 7.51 GB
15:45:15.807 - info: Screen res: 1920 x 1080, scaleFactor 1
15:45:15.811 - info: mainRepoUrl: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
15:45:15.813 - info: logging in with l1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
15:45:16.163 - info: Create timing task for auto update successfully.
15:45:16.398 - info: User programs URL is: https://developer.nvidia.com/api/assets/v1/current_user_sdk/programs
15:45:16.398 - info: start to get devzone user info
15:45:19.445 - info: get devzone user info takes 3.047 sec
15:45:19.445 - info: the DevZone programs that user can access:
15:45:19.446 - info: { id: 878431, name: Technology Access Group }
15:45:19.446 - info: { id: 874688, name: NVIDIA Developer Program }
15:45:19.446 - info: the userID of the user: 4585589
15:45:19.447 - info: User profile URL is: https://api-prod.nvidia.com/services/eupservice/v1/user/getProfile
15:45:19.447 - info: start to get user profile from EUP
15:45:19.882 - info: get user profile from EUP takes 0.435 sec
15:45:19.894 - info: Event: Login Complete: Succeeded
15:45:19.895 - info: Retrieving Data...
15:45:19.896 - info: Processing Data...
15:45:19.908 - info: Checking for GDPR allow. gdprAllow: Allow. client version: 1.8.0.10363. Last seen client: 1.8.0.10363
15:45:19.911 - info: LastSeenSDKMClientVersion is set to 1.8.0.10363
15:45:19.914 - info: mainRepoUrl: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
15:45:19.917 - info: Loading data from server: l1. Url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
15:45:19.917 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
15:45:19.918 - info: Logging into Telemetry server: starfleet
15:45:19.918 - info: Setting custom dimension: LoginServer - cd10, Starfleet
15:45:19.972 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.054 sec
15:45:19.973 - info: Initial product lines number before validation: 8
15:45:19.974 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/Linux/sdkml2_drive_linux.json
15:45:19.974 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/Jetson/Linux/sdkml2_jetson_linux.json
15:45:19.974 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/Switch/Linux/sdkml2_switch_linux.json
15:45:19.974 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/DOCA/Linux/sdkml2_doca_linux.json
15:45:19.974 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/Deepstream/Linux/sdkml2_deepstream_linux.json
15:45:19.974 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/Cuda/Linux/sdkml2_cuda_linux.json
15:45:19.974 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKMANAGER/Linux/sdkml2_sdkmanager_linux.json
15:45:20.023 - info: sdkml2_drive_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/Linux/sdkml2_drive_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.049 sec
15:45:20.024 - info: validating product line for target OS: Linux
15:45:20.026 - info:
15:45:20.026 - info: validating release: DRIVE OS 5.2.6 SDK
15:45:20.026 - warn: No access to devzone program id 879192
15:45:20.026 - warn: No access to release DRIVE OS 5.2.6 SDK.
15:45:20.026 - info: validating release: DRIVE Software 10.0
15:45:20.026 - warn: No access to release DRIVE Software 10.0.
15:45:20.026 - warn: No access to devzone program id -1
15:45:20.027 - info: validating release: DRIVE OS 5.2.3 SDK
15:45:20.027 - warn: No access to devzone program id -1
15:45:20.027 - warn: No access to release DRIVE OS 5.2.3 SDK.
15:45:20.027 - info: validating release: DRIVE OS 5.2.0 SDK
15:45:20.027 - warn: No access to devzone program id 879192
15:45:20.027 - warn: No access to release DRIVE OS 5.2.0 SDK.
15:45:20.027 - info: validating release: DRIVE OS 5.1.15 with DriveWorks
15:45:20.027 - warn: No access to release DRIVE OS 5.1.15 with DriveWorks.
15:45:20.027 - info: validating release: DRIVE OS 5.1.15.0 SDK
15:45:20.027 - warn: No access to release DRIVE OS 5.1.15.0 SDK.
15:45:20.027 - info: validating release: DRIVE OS 5.0.10.3 SDK with DriveWorks
15:45:20.027 - warn: No access to devzone program id 876061
15:45:20.027 - warn: No access to release DRIVE OS 5.0.10.3 SDK with DriveWorks.
15:45:20.027 - info: validating release: DRIVE OS 5.0.10.3 PDK
15:45:20.027 - warn: No access to release DRIVE OS 5.0.10.3 PDK.
15:45:20.028 - info:
15:45:20.028 - info: validating release: OpenDDS
15:45:20.028 - warn: No access to devzone program id -1
15:45:20.028 - warn: No access to release OpenDDS.
15:45:20.028 - warn: No access to devzone program id 879192
15:45:20.028 - info: validating release: PDK
15:45:20.028 - warn: No access to release PDK.
15:45:20.029 - info: validating release: PDK
15:45:20.029 - warn: No access to devzone program id -1
15:45:20.029 - warn: No access to release PDK.
15:45:20.029 - info: validating release: ROS Example
15:45:20.029 - warn: No access to devzone program id 879192
15:45:20.029 - warn: No access to release ROS Example.
15:45:20.030 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/QNX/sdkml2_drive_qnx.json
15:45:20.040 - info: sdkml2_doca_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DOCA/Linux/sdkml2_doca_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.066 sec
15:45:20.040 - info: sdkml2_switch_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/Switch/Linux/sdkml2_switch_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.066 sec
15:45:20.041 - info: sdkml2_jetson_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/Jetson/Linux/sdkml2_jetson_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.067 sec
15:45:20.041 - info: validating product line for target OS: Linux
15:45:20.042 - info:
15:45:20.042 - info: validating release: DOCA 1.3.0
15:45:20.042 - warn: No access to devzone program id 895349
15:45:20.042 - warn: No access to release DOCA 1.3.0.
15:45:20.042 - info: validating release: DOCA 1.2.1
15:45:20.042 - warn: No access to release DOCA 1.2.1.
15:45:20.042 - info: validating release: DOCA 1.1.1
15:45:20.042 - warn: No access to release DOCA 1.1.1.
15:45:20.042 - info: validating product line for target OS: Linux
15:45:20.042 - info: validating release: Switch SDK 4.5.2204
15:45:20.043 - warn: No access to devzone program id 897734
15:45:20.043 - warn: No access to release Switch SDK 4.5.2204.
15:45:20.043 - info:
15:45:20.043 - info: validating release: Switch SDK 4.5.2028
15:45:20.043 - warn: No access to release Switch SDK 4.5.2028.
15:45:20.043 - info: validating release: Switch SDK 4.5.1204
15:45:20.043 - warn: No access to release Switch SDK 4.5.1204.
15:45:20.043 - info: validating release: Switch SDK 4.5.1152
15:45:20.043 - warn: No access to release Switch SDK 4.5.1152.
15:45:20.043 - info: validating release: Switch SDK 4.5.1006
15:45:20.043 - warn: No access to release Switch SDK 4.5.1006.
15:45:20.043 - info: validating release: Switch SDK 4.4.3326
15:45:20.043 - warn: No access to release Switch SDK 4.4.3326.
15:45:20.043 - info: validating release: Switch SDK 4.4.3210
15:45:20.043 - warn: No access to release Switch SDK 4.4.3210.
15:45:20.044 - info: validating release: Switch SDK 4.4.3102
15:45:20.044 - warn: No access to devzone program id 897734
15:45:20.044 - warn: No access to release Switch SDK 4.4.3102.
15:45:20.045 - info: validating product line for target OS: Linux
15:45:20.046 - info:
15:45:20.046 - info: validating release: JetPack 5.0.1 DP
15:45:20.046 - info: Can access to devzone program id 874688
15:45:20.046 - info: validating release: JetPack 5.0 DP
15:45:20.046 - info: validating release: JetPack 5.0 EA
15:45:20.046 - warn: No access to devzone program id 906422
15:45:20.046 - warn: No access to release JetPack 5.0 EA.
15:45:20.046 - info: validating release: JetPack 4.6.2
15:45:20.046 - info: validating release: JetPack 4.6.1
15:45:20.047 - info:
15:45:20.047 - info: validating release: JetPack 4.6
15:45:20.047 - info: Can access to devzone program id 874688
15:45:20.047 - info: validating release: JetPack 4.5.1
15:45:20.047 - info: validating release: JetPack 3.3.4
15:45:20.047 - info: validating release: DeepStream
15:45:20.047 - info: validating release: Rivermax
15:45:20.048 - warn: No access to devzone program id 896242
15:45:20.048 - warn: No access to release Rivermax.
15:45:20.048 - info:
15:45:20.048 - info: validating release: Rivermax
15:45:20.048 - info: validating release: Clara Holoscan
15:45:20.048 - warn: No access to devzone program id 887788
15:45:20.048 - warn: No access to release Clara Holoscan.
15:45:20.048 - info: Event: Login Progress: Loading and processing available products...
15:45:20.054 - info: sdkml2_cuda_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/Cuda/Linux/sdkml2_cuda_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.08 sec
15:45:20.054 - info: sdkml2_deepstream_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/Deepstream/Linux/sdkml2_deepstream_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.08 sec
15:45:20.055 - info: validating product line for target OS: Linux
15:45:20.055 - info: validating release: CUDA Toolkit 11.6
15:45:20.055 - warn: No access to devzone program id 895349
15:45:20.055 - warn: No access to release CUDA Toolkit 11.6.
15:45:20.056 - info: validating product line for target OS: Linux
15:45:20.056 - info: validating release: DeepStream 6.1
15:45:20.056 - info: Can access to devzone program id 874688
15:45:20.056 - info: Event: Login Progress: Loading and processing available products...
15:45:20.057 - info: sdkml2_sdkmanager_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKMANAGER/Linux/sdkml2_sdkmanager_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.083 sec
15:45:20.057 - info: validating product line for target OS:
15:45:20.058 - info:
15:45:20.058 - info: validating release: SDK Manager
15:45:20.058 - info: Empty devzone program id, need to validate l3 url
15:45:20.058 - info: start to download https://developer.download.nvidia.com/sdkmanager/client_update/sdkml3_sdkm_1.8.0_linux.json
15:45:20.058 - info: Validate l3 url successfully
15:45:20.058 - info: Event: Login Progress: Loading and processing available products...
15:45:20.074 - info: sdkml2_drive_qnx.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/QNX/sdkml2_drive_qnx.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.044 sec
15:45:20.075 - info: validating product line for target OS: QNX
15:45:20.075 - info: validating release: DRIVE OS 5.2.12 SDK
15:45:20.075 - warn: No access to devzone program id -1
15:45:20.075 - warn: No access to release DRIVE OS 5.2.12 SDK.
15:45:20.075 - info: validating release: DRIVE OS 5.2.9 SDK
15:45:20.075 - warn: No access to release DRIVE OS 5.2.9 SDK.
15:45:20.075 - info: validating release: DRIVE OS 5.2.6 SDK
15:45:20.075 - warn: No access to release DRIVE OS 5.2.6 SDK.
15:45:20.076 - info: validating release: DRIVE OS 5.2.3 SDK
15:45:20.076 - warn: No access to devzone program id -1
15:45:20.076 - warn: No access to release DRIVE OS 5.2.3 SDK.
15:45:20.076 - info: validating release: DRIVE OS 5.2.0 SDK
15:45:20.076 - warn: No access to release DRIVE OS 5.2.0 SDK.
15:45:20.076 - info: validating release: DRIVE OS 5.1.15.0 SDK
15:45:20.077 - warn: No access to devzone program id -1
15:45:20.077 - warn: No access to release DRIVE OS 5.1.15.0 SDK.
15:45:20.077 - info:
15:45:20.077 - info: validating release: OpenDDS
15:45:20.077 - warn: No access to release OpenDDS.
15:45:20.077 - info: validating release: PDK
15:45:20.077 - warn: No access to release PDK.
15:45:20.078 - info: validating release: PDK
15:45:20.078 - warn: No access to devzone program id -1
15:45:20.078 - warn: No access to release PDK.
15:45:20.078 - info: validating release: SAFETY SDK
15:45:20.078 - warn: No access to release SAFETY SDK.
15:45:20.079 - warn: no hostOperatingSystemsSupportFor in json
15:45:20.129 - warn: Could not detect any BlueField-2 board. Command failed: cat /sys/class/infiniband/mlx5_0/board_id
cat: /sys/class/infiniband/mlx5_0/board_id: No such file or directory
15:45:20.129 - info: Event: Detected devices list is updated
15:45:20.137 - info: Selecting Jetson product
15:45:20.138 - info: step1 load in ms: 221.63000000000466
15:45:20.139 - info: Web server configuration build version 1003D584J23C132DOCA is set
15:45:20.159 - info: cleaning the group map
15:45:20.159 - info: BundleData constructMap
15:45:20.160 - warn: comp NV_L4T_DRIVERS_T194_COMP filtered out, due to supported targetIDs [CLARA_AGX_DEVKIT_TARGETS,JETSON_AGX_XAVIER_TARGETS,JETSON_XAVIER_NX_TARGETS], not include JETSON_AGX_ORIN_TARGETS
15:45:20.162 - info: Skipping optional dependency for NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP (NV_L4T_DRIVERS_T194_COMP)
15:45:20.162 - warn: comp NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP filtered out, due to supported targetIDs [CLARA_AGX_DEVKIT_TARGETS,JETSON_AGX_XAVIER_TARGETS,JETSON_XAVIER_NX_TARGETS], not include JETSON_AGX_ORIN_TARGETS
15:45:20.164 - info: comp NV_L4T_FLASH_ORIN_WITH_OS_IMAGE_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.164 - info: Skipping optional dependency for NV_L4T_FLASH_CLARA_XAVIER_WITH_OS_IMAGE_COMP (NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP)
15:45:20.164 - warn: comp NV_L4T_FLASH_CLARA_XAVIER_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [CLARA_AGX_DEVKIT_TARGETS], not include JETSON_AGX_ORIN_TARGETS
15:45:20.164 - info: Skipping optional dependency for NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP (NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP)
15:45:20.164 - warn: comp NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [JETSON_AGX_XAVIER_TARGETS], not include JETSON_AGX_ORIN_TARGETS
15:45:20.164 - info: Skipping optional dependency for NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP (NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP)
15:45:20.164 - warn: comp NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [JETSON_XAVIER_NX_TARGETS], not include JETSON_AGX_ORIN_TARGETS
15:45:20.164 - warn: comp NV_L4T_FLASH_CLARA_ORIN_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [CLARA_HOLOSCAN_DEVKIT_TARGETS], not include JETSON_AGX_ORIN_TARGETS
15:45:20.165 - info: comp NV_DATETIME_SETUP_TARGET_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.166 - info: comp NV_L4T_CUDA_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.169 - info: comp NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.171 - info: comp NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.172 - info: comp NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.174 - info: comp NV_L4T_VPI_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.176 - info: comp NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.176 - warn: comp NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP filtered out, due to supported targetIDs [CLARA_AGX_DEVKIT_TARGETS,JETSON_AGX_XAVIER_TARGETS,JETSON_XAVIER_NX_TARGETS], not include JETSON_AGX_ORIN_TARGETS
15:45:20.178 - info: comp NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T234_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.179 - info: comp NV_L4T_NVIDIA_NSIGHT_GRAPHICS_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.183 - info: comp NV_L4T_NVIDIA_NSIGHT_SYSTEMS_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.185 - info: comp NV_L4T_NVIDIA_NSIGHT_DLD_TARGET_POST_INSTALL_COMP filtered out for installed bundle, due to record not found in local database
15:45:20.186 - warn: no hostOperatingSystemsSupportFor in json
15:45:20.192 - info: Checking for update with mainRepoURL: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
15:45:20.194 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
15:45:20.298 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.104 sec
15:45:20.299 - info: start to download https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKMANAGER/Linux/sdkml2_sdkmanager_linux.json
15:45:20.347 - info: sdkml2_sdkmanager_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKMANAGER/Linux/sdkml2_sdkmanager_linux.json has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 0.048 sec
15:45:20.349 - info: packageJson: /opt/nvidia/sdkmanager/resources/app/package.json
15:45:25.056 - info: Event: Detected devices list is updated
15:45:25.067 - info: Selecting Jetson product
15:45:26.058 - warn: Could not detect any BlueField-2 board. Command failed: cat /sys/class/infiniband/mlx5_0/board_id
15:45:26.058 - info: Event: Detected devices list is updated
15:45:27.223 - info: Event: Detected devices list is updated
15:45:27.235 - info: Selecting Jetson product
15:45:28.241 - info: Release notes warning: no tooltip was specified for JetPack 4.6.2.
15:45:28.242 - info: Release notes warning: no tooltip was specified for JetPack 4.6.2.
15:45:28.242 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:29.840 - info: Release notes warning: no tooltip was specified for JetPack 4.6.2.
15:45:29.840 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:35.029 - info: urlPreprocess: get accessible URL for https://docs.nvidia.com/jetson/archives/jetpack-archived/jetpack-46/release-notes/index.html
15:45:35.034 - info: Release notes warning: no tooltip was specified for JetPack 4.6.2.
15:45:35.034 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:35.035 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:35.041 - info: Release notes warning: no tooltip was specified for JetPack 4.6.2.
15:45:35.041 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:35.042 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:39.829 - info: Release notes warning: no tooltip was specified for JetPack 4.6.2.
15:45:39.830 - info: Release notes warning: no tooltip was specified for JetPack 4.6.2.
15:45:39.832 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:39.833 - info: Release notes warning: no tooltip was specified for JetPack 3.3.4.
15:45:42.216 - info: Event: Step3 load started
15:45:42.217 - info: initializeGroups. User selections: Product: Jetson Version: 5.0.1 selectedHWConfig: host_target selectedTargetID: JETSON_AGX_XAVIER_TARGETS selectedOS: Linux
15:45:42.236 - info: Setting custom dimension: ProductVersion - cd1, 5.0.1
15:45:42.236 - info: Setting custom dimension: ProductHW - cd2, host_target.JETSON_AGX_XAVIER_TARGETS
15:45:42.236 - info: Setting custom dimension: ProductOS - cd3, Linux
15:45:42.236 - info: Setting custom dimension: ProductName - cd7, Jetson
15:45:42.236 - info: Setting custom dimension: BundleName - cd9, JetPack 5.0.1 DP
15:45:42.237 - info: loading l3 data from repo url: [
'https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.0.1-dp/Jetson_501_b115/sdkml3_jetpack_501_dp.json'
15:45:42.237 - info: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.0.1-dp/Jetson_501_b115/sdkml3_jetpack_501_dp.json
15:45:42.238 - info: EulaFolder: /opt/nvidia/sdkmanager/Eula/
15:45:45.543 - info: sdkml3_jetpack_501_dp.json from https://developer.download.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.0.1-dp/Jetson_501_b115/sdkml3_jetpack_501_dp.json?P2LAGtjNHgSU_AdNAlSSt712ZnlYAoTu_a3BcPh4OEJkMmqLg_Ad0adYhS8ZfZRKO7s3G3fyXcWK76nK1h_OBzH8OFF2abNEGX5C2A9BRkmBik5DXiwBPbYqS5_KjQTTODesTv-y5dDMjjQm98_46yUTGZnZ9nnZOV5nfA9C7bo4yy5LFsdPgVNhTWQriM7-UIaL59o-AWwMnBsV3rqbFXIAunKK-kGF_Yo has been downloaded to /home/py/.nvsdkm/dist successfully. Time used 3.306 sec
15:45:45.556 - info: cleaning the group map
15:45:45.556 - info: BundleData constructMap
15:45:45.557 - warn: comp NV_L4T_DRIVERS_T234_COMP filtered out, due to supported targetIDs [JETSON_AGX_ORIN_TARGETS,CLARA_HOLOSCAN_DEVKIT_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.557 - info: Skipping optional dependency for NV_L4T_FILE_SYSTEM_AND_OS_T234_COMP (NV_L4T_DRIVERS_T234_COMP)
15:45:45.557 - warn: comp NV_L4T_FILE_SYSTEM_AND_OS_T234_COMP filtered out, due to supported targetIDs [JETSON_AGX_ORIN_TARGETS,CLARA_HOLOSCAN_DEVKIT_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.557 - info: Skipping optional dependency for NV_L4T_FLASH_ORIN_WITH_OS_IMAGE_COMP (NV_L4T_FILE_SYSTEM_AND_OS_T234_COMP)
15:45:45.557 - warn: comp NV_L4T_FLASH_ORIN_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [JETSON_AGX_ORIN_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.557 - warn: comp NV_L4T_FLASH_CLARA_XAVIER_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [CLARA_AGX_DEVKIT_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.558 - warn: comp NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [JETSON_XAVIER_NX_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.558 - info: Skipping optional dependency for NV_L4T_FLASH_CLARA_ORIN_WITH_OS_IMAGE_COMP (NV_L4T_FILE_SYSTEM_AND_OS_T234_COMP)
15:45:45.558 - warn: comp NV_L4T_FLASH_CLARA_ORIN_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [CLARA_HOLOSCAN_DEVKIT_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.561 - warn: comp NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T234_COMP filtered out, due to supported targetIDs [JETSON_AGX_ORIN_TARGETS,CLARA_HOLOSCAN_DEVKIT_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.561 - warn: comp NV_L4T_NVIDIA_NSIGHT_DLD_TARGET_POST_INSTALL_COMP filtered out, due to supported targetIDs [JETSON_AGX_ORIN_TARGETS], not include JETSON_AGX_XAVIER_TARGETS
15:45:45.561 - info: Event: Active bundle loaded: Jetson - 5.0.1, detected HW ID: JETSON_AGX_XAVIER
15:45:45.562 - info: downloadMetrics.reset
15:45:45.562 - info: InstallProxy is initializing
15:45:45.562 - warn: installProxy initialization: did not get expected details from engine. Expected {product title, target os, and edition}. Got {title: JetPack 5.0.1 DP, OS: Linux, edition: }
15:45:45.562 - info: looking for install adapter from /opt/nvidia/sdkmanager/resources/app/output/installUtils
15:45:45.562 - info: Install proxy initialized successfully
15:45:45.583 - info: Setting AdditionalSDKSelection with value:
15:45:45.583 - info: Setting custom dimension: AdditionalSDKSelection - cd13,
15:45:45.583 - info: Session initial status: install percent: 80. (18 out of 0)
15:45:45.589 - info: initializeGroups ended successfully. Duration: 00:00:03
15:45:45.589 - info: Event: Step3 load complete: Succeeded
15:45:45.619 - info: Event: NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: pending_install
15:45:45.647 - info: NV_L4T_DRIVERS_T194_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R34.1.1_aarch64.tbz2
15:45:45.660 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R34.1.1_aarch64.tbz2
15:45:45.660 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R34.1.1_aarch64.tbz2
15:45:45.662 - info: NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R34.1.1_aarch64.tbz2
15:45:45.664 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R34.1.1_aarch64.tbz2
15:45:45.664 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R34.1.1_aarch64.tbz2
15:45:45.666 - info: stdout: Querying the install status of 'CUDA on Host' (NV_CUDA_HOST_COMP)
INSTALLUTIL_CURRENT_FILE cuda-repo-ubuntu2004-11-4-local_11.4.14-470.88-1_amd64.deb
exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' cuda-toolkit-11-4
15:45:45.666 - info: stdout: Querying the install status of 'CUDA Cross Compile Package on Host' (NV_CUDA_CROSS_HOST_COMP)
INSTALLUTIL_CURRENT_FILE cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.14-1_all.deb
exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' cuda-cross-aarch64-11-4
15:45:45.681 - info: stdout: exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' cuda-cross-aarch64-11-4
15:45:45.689 - info: stdout: exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' cuda-toolkit-11-4
15:45:45.695 - info: stdout: Host Deb package [{cuda-cross-aarch64-11-4 11.4}] not installed; [deb_name]: cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.14-1_all.deb
15:45:45.695 - info: Component: NV_CUDA_CROSS_HOST_COMP version: 11.4 for bundle: JetPack_5.0.1_DP_Linux is not installed
15:45:45.696 - info: NV_CUDA_CROSS_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.14-1_all.deb
15:45:45.697 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.14-1_all.deb
15:45:45.697 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.14-1_all.deb
15:45:45.703 - info: stdout: Host Deb package [{cuda-toolkit-11-4 11.4}] not installed; [deb_name]: cuda-repo-ubuntu2004-11-4-local_11.4.14-470.88-1_amd64.deb
15:45:45.703 - info: Component: NV_CUDA_HOST_COMP version: 11.4 for bundle: JetPack_5.0.1_DP_Linux is not installed
15:45:45.704 - info: NV_CUDA_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu2004-11-4-local_11.4.14-470.88-1_amd64.deb
15:45:45.705 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu2004-11-4-local_11.4.14-470.88-1_amd64.deb
15:45:45.705 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu2004-11-4-local_11.4.14-470.88-1_amd64.deb
15:45:52.595 - info: Event: Device APX was unplugged from usb port.
15:45:53.821 - info: Event: Detected devices list is updated
15:45:53.857 - info: Selecting Jetson product
15:46:24.860 - info: Event: Device Linux_for_Tegra was plugged to usb port.
15:46:26.880 - warn: Command failed: ip addr show dev enxb2139da7d6aa | grep inet6
15:46:26.880 - warn: Could not get Jetson NetworkInterfaceByUsbPort.
15:46:26.925 - info: 5280a7a1a3684889d61e90ab469507bc /home/py/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R34.1.1_aarch64.tbz2
15:46:26.925 - info: NV_L4T_DRIVERS_T194_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R34.1.1_aarch64.tbz2 with correct checksum, skip downloading.
15:46:26.930 - info: Event: NV_L4T_DRIVERS_T194_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:46:26.947 - info: NV_VPI_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-cuda11-x86_64-linux.deb
15:46:26.949 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-cuda11-x86_64-linux.deb
15:46:26.949 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-cuda11-x86_64-linux.deb
15:46:26.950 - info: NV_VPI_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-cuda11-x86_64-linux.deb
15:46:26.952 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-cuda11-x86_64-linux.deb
15:46:26.952 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-cuda11-x86_64-linux.deb
15:46:26.953 - info: NV_VPI_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-cross-aarch64-l4t-2.0.14-cuda11-x86_64-linux.deb
15:46:26.954 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-cross-aarch64-l4t-2.0.14-cuda11-x86_64-linux.deb
15:46:26.954 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-cross-aarch64-l4t-2.0.14-cuda11-x86_64-linux.deb
15:46:26.955 - info: NV_VPI_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-cuda11-x86_64-linux.deb
15:46:26.956 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-cuda11-x86_64-linux.deb
15:46:26.956 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-cuda11-x86_64-linux.deb
15:46:26.956 - info: NV_VPI_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-cuda11-x86_64-linux.deb
15:46:26.959 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-cuda11-x86_64-linux.deb
15:46:26.959 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-cuda11-x86_64-linux.deb
15:46:26.959 - info: NV_VPI_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-cuda11-x86_64-linux.deb
15:46:26.962 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-cuda11-x86_64-linux.deb
15:46:26.962 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-cuda11-x86_64-linux.deb
15:46:27.750 - info: da111aea4b4d9c68bff2dc6880e78741 /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-cuda11-x86_64-linux.deb
15:46:27.750 - info: NV_VPI_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-cuda11-x86_64-linux.deb with correct checksum, skip downloading.
15:46:27.763 - info: NV_VPI_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-cuda11-x86_64-linux-ubuntu2004.deb
15:46:27.769 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-cuda11-x86_64-linux-ubuntu2004.deb
15:46:27.769 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-cuda11-x86_64-linux-ubuntu2004.deb
15:46:28.355 - info: dba87daf1a5db1d6719efe2da163e597 /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-cuda11-x86_64-linux.deb
15:46:28.356 - info: NV_VPI_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-cuda11-x86_64-linux.deb with correct checksum, skip downloading.
15:46:28.370 - info: 68531ae6f96d50f3d83df52cead0efdb /home/py/Downloads/nvidia/sdkm_downloads/vpi-cross-aarch64-l4t-2.0.14-cuda11-x86_64-linux.deb
15:46:28.371 - info: 6b6dbadbad0e02f4523b7780fafbb5a8 /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-cuda11-x86_64-linux.deb
15:46:28.371 - info: NV_VPI_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-cross-aarch64-l4t-2.0.14-cuda11-x86_64-linux.deb with correct checksum, skip downloading.
15:46:28.372 - info: NV_VPI_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-cuda11-x86_64-linux.deb with correct checksum, skip downloading.
15:46:28.532 - info: e20721727a22104e64f88c5c88b1bb7a /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-cuda11-x86_64-linux.deb
15:46:28.533 - info: NV_VPI_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-cuda11-x86_64-linux.deb with correct checksum, skip downloading.
15:46:28.707 - info: 8a9889d07e250dab2790290afb886970 /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-cuda11-x86_64-linux.deb
15:46:28.707 - info: NV_VPI_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-cuda11-x86_64-linux.deb with correct checksum, skip downloading.
15:46:30.438 - info: 0bffc551cc6144cd9c044c7d02a0bb5b /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-cuda11-x86_64-linux-ubuntu2004.deb
15:46:30.439 - info: NV_VPI_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-cuda11-x86_64-linux-ubuntu2004.deb with correct checksum, skip downloading.
15:46:30.450 - info: Event: NV_VPI_HOST_COMP@host - init status is: downloaded
15:46:30.577 - info: stdout: Querying the install status of 'NVIDIA Nsight Graphics' (NV_L4T_NVIDIA_NSIGHT_GRAPHICS_HOST_COMP)
INSTALLUTIL_CURRENT_FILE NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_x64.deb
exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' nsight-graphics-for-embeddedlinux-2022.2.0.0
15:46:30.919 - info: stdout: exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' nsight-graphics-for-embeddedlinux-2022.2.0.0
15:46:30.934 - info: stdout: Host Deb package [{nsight-graphics-for-embeddedlinux-2022.2.0.0 2022.2.0.0}] not installed; [deb_name]: NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_x64.deb
15:46:30.934 - info: Component: NV_L4T_NVIDIA_NSIGHT_GRAPHICS_HOST_COMP version: 2022.2 for bundle: JetPack_5.0.1_DP_Linux is not installed
15:46:30.935 - info: NV_L4T_NVIDIA_NSIGHT_GRAPHICS_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_x64.deb
15:46:30.938 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_x64.deb
15:46:30.938 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_x64.deb
15:46:35.474 - info: Event: Detected devices list is updated
15:46:35.516 - info: Selecting Jetson product
15:46:49.242 - info: Destorying eula view. eula warning timer is null: true
15:46:50.369 - info: 59020ab2b02d1bfa16d75b78e2830a40 /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.14-1_all.deb
15:46:50.369 - info: NV_CUDA_CROSS_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-ubuntu2004-11-4-local_11.4.14-1_all.deb with correct checksum, skip downloading.
15:46:50.370 - info: Event: NV_CUDA_CROSS_HOST_COMP@host - init status is: downloaded
15:46:50.388 - info: stdout: Querying the install status of 'NVIDIA Nsight Systems' (NV_L4T_NVIDIA_NSIGHT_SYSTEMS_HOST_COMP)
INSTALLUTIL_CURRENT_FILE NsightSystems-linux-public-2022.2.3.16-dc64487.deb
exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' nsight-systems-2022.2.3
15:46:51.964 - info: stdout: exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' nsight-systems-2022.2.3
15:46:51.979 - info: stdout: Host Deb package [{nsight-systems-2022.2.3 2022.2.3.16-dc64487}] not installed; [deb_name]: NsightSystems-linux-public-2022.2.3.16-dc64487.deb
15:46:51.979 - info: Component: NV_L4T_NVIDIA_NSIGHT_SYSTEMS_HOST_COMP version: 2022.2 for bundle: JetPack_5.0.1_DP_Linux is not installed
15:46:51.980 - info: url from json is a full http link - https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.0.1-dp/Jetson_501_b118/NsightSystems-linux-public-2022.2.3.16-dc64487.deb
15:46:51.980 - info: NV_L4T_NVIDIA_NSIGHT_SYSTEMS_HOST_COMP@host: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/NsightSystems-linux-public-2022.2.3.16-dc64487.deb
15:46:51.981 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/NsightSystems-linux-public-2022.2.3.16-dc64487.deb
15:46:51.981 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/NsightSystems-linux-public-2022.2.3.16-dc64487.deb
15:46:54.071 - info: a82b3fc02db60db55f6f94247526fa97 /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_x64.deb
15:46:54.071 - info: NV_L4T_NVIDIA_NSIGHT_GRAPHICS_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_x64.deb with correct checksum, skip downloading.
15:46:54.072 - info: Event: NV_L4T_NVIDIA_NSIGHT_GRAPHICS_HOST_COMP@host - init status is: downloaded
15:46:54.073 - info: Event: NV_DATETIME_SETUP_TARGET_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: pending_install
15:46:54.075 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb
15:46:54.076 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb
15:46:54.076 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb
15:47:18.577 - info: f578078829b8e52ffe7adadcb5a6dc41 /home/py/Downloads/nvidia/sdkm_downloads/NsightSystems-linux-public-2022.2.3.16-dc64487.deb
15:47:18.577 - info: NV_L4T_NVIDIA_NSIGHT_SYSTEMS_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/NsightSystems-linux-public-2022.2.3.16-dc64487.deb with correct checksum, skip downloading.
15:47:18.578 - info: Event: NV_L4T_NVIDIA_NSIGHT_SYSTEMS_HOST_COMP@host - init status is: downloaded
15:47:18.580 - info: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/cudnn-local-repo-ubuntu2004-8.3.2.49_1.0-1_arm64.deb
15:47:18.581 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/cudnn-local-repo-ubuntu2004-8.3.2.49_1.0-1_arm64.deb
15:47:18.581 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/cudnn-local-repo-ubuntu2004-8.3.2.49_1.0-1_arm64.deb
15:47:39.901 - info: 84feca111e8e7a67f0c9337c3be0663f /home/py/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R34.1.1_aarch64.tbz2
15:47:39.901 - info: NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R34.1.1_aarch64.tbz2 with correct checksum, skip downloading.
15:47:39.902 - info: Event: NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:47:39.906 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.906 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.906 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.906 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.906 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.906 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.907 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.907 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.907 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.907 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.907 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.907 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.907 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.908 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.908 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:39.908 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.908 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:39.908 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:41.474 - info: c19930d39ca9accfd069a15de41855d6 /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:41.474 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers8_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:41.476 - info: 6cd7002e22b2cbe572bb935f2e0738e9 /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:41.476 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvonnxparsers-dev_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:41.478 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:41.479 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:41.479 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:41.480 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:41.484 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:41.484 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:41.552 - info: 5742b7dd3bb2cff1482afce5da606569 /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:41.553 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers-dev_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:41.554 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-bin_8.4.0-1+cuda11.4_arm64.deb
15:47:41.555 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-bin_8.4.0-1+cuda11.4_arm64.deb
15:47:41.555 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-bin_8.4.0-1+cuda11.4_arm64.deb
15:47:41.726 - info: a27719e0edf5a146a74fc53adbdebd2e /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-bin_8.4.0-1+cuda11.4_arm64.deb
15:47:41.726 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-bin_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:41.728 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-doc_8.4.0-1+cuda11.4_all.deb
15:47:41.729 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-doc_8.4.0-1+cuda11.4_all.deb
15:47:41.729 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-doc_8.4.0-1+cuda11.4_all.deb
15:47:41.908 - info: 78219ec554b683e9fd13219f9eb28844 /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers8_8.4.0-1+cuda11.4_arm64.deb
15:47:41.908 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvparsers8_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:41.910 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_8.4.0-1+cuda11.4_all.deb
15:47:41.910 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_8.4.0-1+cuda11.4_all.deb
15:47:41.911 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_8.4.0-1+cuda11.4_all.deb
15:47:44.018 - info: c869b1f4576571a602a04d17ca0965af /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:44.018 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin-dev_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:44.020 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/tensorrt_8.4.0.11-1+cuda11.4_arm64.deb
15:47:44.020 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/tensorrt_8.4.0.11-1+cuda11.4_arm64.deb
15:47:44.021 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/tensorrt_8.4.0.11-1+cuda11.4_arm64.deb
15:47:44.037 - info: 9188058cb64e5ef595dc4e9aa5064d2c /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin8_8.4.0-1+cuda11.4_arm64.deb
15:47:44.037 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin8_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:44.039 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_8.4.0-1+cuda11.4_arm64.deb
15:47:44.040 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_8.4.0-1+cuda11.4_arm64.deb
15:47:44.040 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_8.4.0-1+cuda11.4_arm64.deb
15:47:44.048 - info: 1ff67b7eb0aa2afa528d41914226e750 /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-doc_8.4.0-1+cuda11.4_all.deb
15:47:44.048 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-doc_8.4.0-1+cuda11.4_all.deb with correct checksum, skip downloading.
15:47:44.050 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:44.050 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:44.051 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:44.057 - info: 43a2298d411eecc04c631b243047a4ae /home/py/Downloads/nvidia/sdkm_downloads/tensorrt_8.4.0.11-1+cuda11.4_arm64.deb
15:47:44.058 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/tensorrt_8.4.0.11-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:44.059 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.060 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.060 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.070 - info: 3c3020804f2037d64fdfe945a026dbc3 /home/py/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.071 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:44.073 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/uff-converter-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.074 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/uff-converter-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.075 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/uff-converter-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.083 - info: e7f2baa63b09a50a0fb8de2e29c4e0c4 /home/py/Downloads/nvidia/sdkm_downloads/uff-converter-tf_8.4.0-1+cuda11.4_arm64.deb
15:47:44.084 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/uff-converter-tf_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:44.117 - info: 62b8f2d2a958d99bc2d1325e8696ecc8 /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_8.4.0-1+cuda11.4_arm64.deb
15:47:44.117 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:45.581 - info: 2074cb67a2abea4e5932c847010af4e0 /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:45.582 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:55.926 - info: 1a6fe801c40621e860c655bcbc8557d2 /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer8_8.4.0-1+cuda11.4_arm64.deb
15:47:55.926 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer8_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:47:57.145 - info: 667939284bfe4e7d8ae82c1aa8b9ace9 /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb
15:47:57.145 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_8.4.0-1+cuda11.4_arm64.deb with correct checksum, skip downloading.
15:48:24.072 - info: 47073aad30899f8aafe48d72535b3156 /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_8.4.0-1+cuda11.4_all.deb
15:48:24.073 - info: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_8.4.0-1+cuda11.4_all.deb with correct checksum, skip downloading.
15:48:24.073 - info: Event: NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:48:24.091 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
15:48:24.092 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
15:48:24.092 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
15:48:24.094 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb
15:48:24.094 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb
15:48:24.095 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb
15:48:24.095 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb
15:48:24.096 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb
15:48:24.096 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb
15:48:24.097 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb
15:48:24.098 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb
15:48:24.098 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb
15:48:24.099 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb
15:48:24.100 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb
15:48:24.100 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb
15:48:25.355 - info: 4e775dc14040f5b52fbaa458eb00e08a /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb
15:48:25.355 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb with correct checksum, skip downloading.
15:48:25.371 - info: 4b18111df07d7f500bde29f67d45fc91 /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb
15:48:25.371 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb with correct checksum, skip downloading.
15:48:25.406 - info: 5b6f58870bec28f801059be49bb13b7a /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb
15:48:25.406 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb with correct checksum, skip downloading.
15:48:26.004 - info: f99402f8d4fd0845dc7058758e67fb28 /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb
15:48:26.004 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb with correct checksum, skip downloading.
15:48:26.505 - info: fca6cfb72c761b47849e20528bc62a54 /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
15:48:26.505 - info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb with correct checksum, skip downloading.
15:48:26.505 - info: Event: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:48:26.506 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-aarch64-l4t.deb
15:48:26.506 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-aarch64-l4t.deb
15:48:26.506 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-aarch64-l4t.deb
15:48:26.507 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-aarch64-l4t.deb
15:48:26.507 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-aarch64-l4t.deb
15:48:26.507 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-aarch64-l4t.deb
15:48:26.508 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-aarch64-l4t.deb
15:48:26.508 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-aarch64-l4t.deb
15:48:26.508 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-aarch64-l4t.deb
15:48:26.508 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-aarch64-l4t.deb
15:48:26.508 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-aarch64-l4t.deb
15:48:26.509 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-aarch64-l4t.deb
15:48:26.509 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-aarch64-l4t.deb
15:48:26.509 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-aarch64-l4t.deb
15:48:26.509 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-aarch64-l4t.deb
15:48:26.509 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-aarch64-l4t.deb
15:48:26.509 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-aarch64-l4t.deb
15:48:26.509 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-aarch64-l4t.deb
15:48:27.470 - info: 2634fc92e7c1f24872f04070e1fceb4c /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-aarch64-l4t.deb
15:48:27.470 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-samples-2.0.14-aarch64-l4t.deb with correct checksum, skip downloading.
15:48:28.014 - info: aad0c70dcb6b938c15f3eb20f801fda6 /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-aarch64-l4t.deb
15:48:28.015 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-dev-2.0.14-aarch64-l4t.deb with correct checksum, skip downloading.
15:48:28.055 - info: 735f4b8707e2e20008a53bdcf86eff85 /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-aarch64-l4t.deb
15:48:28.055 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.0.14-aarch64-l4t.deb with correct checksum, skip downloading.
15:48:28.058 - info: 3145843b4b98ead9e76eb0214769791e /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-aarch64-l4t.deb
15:48:28.058 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.0.14-aarch64-l4t.deb with correct checksum, skip downloading.
15:48:28.102 - info: fd1003d890cb3f778d9a10c7ec651b44 /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-aarch64-l4t.deb
15:48:28.103 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-lib-2.0.14-aarch64-l4t.deb with correct checksum, skip downloading.
15:48:28.477 - info: e91090660d79075a713cdd2189342188 /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-aarch64-l4t.deb
15:48:28.478 - info: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/vpi-demos-2.0.14-aarch64-l4t.deb with correct checksum, skip downloading.
15:48:28.478 - info: Event: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:48:28.481 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.11.0+jetpack_arm64.deb
15:48:28.481 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.11.0+jetpack_arm64.deb
15:48:28.481 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.11.0+jetpack_arm64.deb
15:48:28.481 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.9.0-1_arm64.deb
15:48:28.482 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.9.0-1_arm64.deb
15:48:28.482 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.9.0-1_arm64.deb
15:48:28.482 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_1.9.0-1_arm64.deb
15:48:28.482 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_1.9.0-1_arm64.deb
15:48:28.482 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_1.9.0-1_arm64.deb
15:48:28.482 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.9.0-1_arm64.deb
15:48:28.483 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.9.0-1_arm64.deb
15:48:28.483 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.9.0-1_arm64.deb
15:48:28.483 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.9.0-1_all.deb
15:48:28.483 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.9.0-1_all.deb
15:48:28.483 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.9.0-1_all.deb
15:48:28.483 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.10.0-1_all.deb
15:48:28.484 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.10.0-1_all.deb
15:48:28.484 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.10.0-1_all.deb
15:48:28.494 - info: 5fe2f0fe3889cf14ec053303d3808c8b /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.9.0-1_all.deb
15:48:28.494 - info: cc802eb70898c522253cb877a9aeb2a7 /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_1.9.0-1_arm64.deb
15:48:28.494 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_3.9.0-1_all.deb with correct checksum, skip downloading.
15:48:28.494 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_1.9.0-1_arm64.deb with correct checksum, skip downloading.
15:48:28.495 - info: da10085f9ecf50c3f7ad17eff7a34d6b /home/py/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.10.0-1_all.deb
15:48:28.495 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/nvidia-docker2_2.10.0-1_all.deb with correct checksum, skip downloading.
15:48:29.461 - info: 109a4245d65ccb04aea790fb98357e49 /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.11.0+jetpack_arm64.deb
15:48:29.461 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.11.0+jetpack_arm64.deb with correct checksum, skip downloading.
15:48:29.639 - info: 1cee6f13757094b00c6f6e4c9791fffa /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.9.0-1_arm64.deb
15:48:29.640 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.9.0-1_arm64.deb with correct checksum, skip downloading.
15:48:29.646 - info: c6c39f123bb2cf346f08328fd87d013d /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.9.0-1_arm64.deb
15:48:29.646 - info: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.9.0-1_arm64.deb with correct checksum, skip downloading.
15:48:29.646 - info: Event: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:48:29.648 - info: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_34.1.1-20220516211757_arm64.deb
15:48:29.649 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_34.1.1-20220516211757_arm64.deb
15:48:29.649 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_34.1.1-20220516211757_arm64.deb
15:48:36.109 - info: 4eaf8b2e9006d8718ecdb9634e8d1fcf /home/py/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_34.1.1-20220516211757_arm64.deb
15:48:36.109 - info: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_34.1.1-20220516211757_arm64.deb with correct checksum, skip downloading.
15:48:36.109 - info: Event: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:48:36.110 - info: NV_L4T_NVIDIA_NSIGHT_GRAPHICS_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_arm64.deb
15:48:36.110 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_arm64.deb
15:48:36.110 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_arm64.deb
15:48:37.417 - info: Event: Device Linux_for_Tegra was unplugged from usb port.
15:48:38.619 - info: Event: Detected devices list is updated
15:48:38.638 - info: Selecting Jetson product
15:48:38.640 - info: Selecting Jetson product
15:48:39.084 - info: Event: Device Linux_for_Tegra was plugged to usb port.
15:48:47.613 - info: Event: Device Linux_for_Tegra was unplugged from usb port.
15:48:47.623 - info: Event: Detected devices list is updated
15:48:47.633 - info: Selecting Jetson product
15:48:47.634 - info: Selecting Jetson product
15:48:47.742 - info: 1cf76e32042295b69748dea8b5c8057d /home/py/Downloads/nvidia/sdkm_downloads/cudnn-local-repo-ubuntu2004-8.3.2.49_1.0-1_arm64.deb
15:48:47.743 - info: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/cudnn-local-repo-ubuntu2004-8.3.2.49_1.0-1_arm64.deb with correct checksum, skip downloading.
15:48:47.743 - info: Event: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:48:47.743 - info: url from json is a full http link - https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-5.0.1-dp/Jetson_501_b118/nsight-systems-2022.2.3_2022.2.3.16-1_arm64.deb
15:48:47.745 - info: NV_L4T_NVIDIA_NSIGHT_SYSTEMS_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: verifying checksum of /home/py/Downloads/nvidia/sdkm_downloads/nsight-systems-2022.2.3_2022.2.3.16-1_arm64.deb
15:48:47.745 - info: get checksum by system command for /home/py/Downloads/nvidia/sdkm_downloads/nsight-systems-2022.2.3_2022.2.3.16-1_arm64.deb
15:48:47.745 - info: running md5sum /home/py/Downloads/nvidia/sdkm_downloads/nsight-systems-2022.2.3_2022.2.3.16-1_arm64.deb
15:48:49.813 - info: Event: Device APX was plugged to usb port.
15:48:50.679 - info: Event: Device APX was unplugged from usb port.
15:48:50.717 - info: Event: Detected devices list is updated
15:48:50.822 - info: Selecting Jetson product
15:48:50.826 - info: Selecting Jetson product
15:48:54.180 - info: 5cb33441211f4321eeff00e4ad443524 /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu2004-11-4-local_11.4.14-470.88-1_amd64.deb
15:48:54.180 - info: NV_CUDA_HOST_COMP@host: Found file /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu2004-11-4-local_11.4.14-470.88-1_amd64.deb with correct checksum, skip downloading.
15:48:54.181 - info: Event: NV_CUDA_HOST_COMP@host - init status is: downloaded
15:48:57.874 - info: 24a3c722b3fcc3bd7810dc2a272e9d44 /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_arm64.deb
15:48:57.874 - info: NV_L4T_NVIDIA_NSIGHT_GRAPHICS_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/NVIDIA_Nsight_Graphics_L4T_Public_2022.2.22104_arm64.deb with correct checksum, skip downloading.
15:48:57.875 - info: Event: NV_L4T_NVIDIA_NSIGHT_GRAPHICS_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:48:58.561 - info: Event: Detected devices list is updated
15:48:58.594 - info: Selecting Jetson product
15:48:58.602 - info: Selecting Jetson product
15:49:02.025 - info: f744f53314eebf7192587b468966ed46 /home/py/Downloads/nvidia/sdkm_downloads/nsight-systems-2022.2.3_2022.2.3.16-1_arm64.deb
15:49:02.026 - info: NV_L4T_NVIDIA_NSIGHT_SYSTEMS_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/nsight-systems-2022.2.3_2022.2.3.16-1_arm64.deb with correct checksum, skip downloading.
15:49:02.026 - info: Event: NV_L4T_NVIDIA_NSIGHT_SYSTEMS_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:49:02.164 - info: 291e46d116a3283e7e2e77e22c7a5145 /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb
15:49:02.164 - info: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Found file /home/py/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb with correct checksum, skip downloading.
15:49:02.165 - info: Event: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - init status is: downloaded
15:49:02.167 - info: Event: Session status init is complete
15:49:09.450 - info: exporting logs from /home/py/.nvsdkm
15:49:11.301 - info: Exported 28 log files to /home/py/Downloads/nvidia/sdkm_downloads/SDKM_logs_2022-05-24_15-49-05.zip
15:49:21.693 - info: exporting logs from /home/py/.nvsdkm
15:49:21.854 - info: Exported 28 log files to /home/py/Downloads/SDKM_logs_2022-05-24_15-49-17.zip
15:49:22.577 - info: Event: Device Linux_for_Tegra was plugged to usb port.
15:49:24.433 - info: Event: Detected devices list is updated
15:49:24.455 - info: Selecting Jetson product
15:49:24.456 - info: Selecting Jetson product
15:49:24.457 - info: Selecting Jetson product
15:49:24.524 - info: Event: Detected devices list is updated
15:49:24.535 - info: Selecting Jetson product
15:49:24.537 - info: Selecting Jetson product
15:52:15.361 - info: exporting logs from /home/py/.nvsdkm
Please use the uart console to access the board.
~$ sudo minicom -D /dev/ttyUSB3 -8 -b 115200
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB3, 16:08:58
Press CTRL-A Z for help on special keys
[0000.674] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.683] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.688] I> Boot-mode: Coldboot
[0000.691] I> Chip revision : A02P
[0000.694] I> Bootrom patch version : 15 (correctly patched)
[0000.699] I> ATE fuse revision : 0x200
[0000.703] I> Ram repair fuse : 0x1
[0000.706] I> Ram Code : 0x2
[0000.709] I> rst_source : 0x0
[0000.711] I> rst_level : 0x0
[0000.715] I> Boot-device: eMMC
[0000.730] I> sdmmc DDR50 mode
[0000.734] I> Active Boot chain : 1
[0000.737] I> Boot-device: eMMC
[0000.741] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.749] I> Temperature = 40000
[0000.752] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.756] W> Skipping boost for clk: BPMP_APB
[0000.760] W> Skipping boost for clk: AXI_CBB
[0000.764] W> Skipping boost for clk: AON_CPU_NIC
[0000.768] W> Skipping boost for clk: CAN1
[0000.772] W> Skipping boost for clk: CAN2
[0000.776] I> Boot-device: eMMC
[0000.779] I> Boot-device: eMMC
[0000.788] I> Sdmmc: HS400 mode enabled
[0000.793] I> ECC region[0]: Start:0x0, End:0x0
[0000.797] I> ECC region[1]: Start:0x0, End:0x0
[0000.801] I> ECC region[2]: Start:0x0, End:0x0
[0000.805] I> ECC region[3]: Start:0x0, End:0x0
[0000.809] I> ECC region[4]: Start:0x0, End:0x0
[0000.813] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.819] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.824] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.828] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.833] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.838] E> FAILED: Thermal config
[0000.845] E> FAILED: MEMIO rail config
[0000.863] I> Boot-device: eMMC
[0000.873] I> sdmmc bdev is already initialized
[0000.949] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.957] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.958] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.958] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.959] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.965] W> device prod register failed
[0000.969] I> Boot-device: eMMC
[0000.971] I> Boot_device: SDMMC_BOOT instance: 3
[0000.977] I> sdmmc-3 params source = boot args
[0000.980] I> sdmmc bdev is already initialized
[0000.985] I> sdmmc-3 params source = boot args
[0000.993] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.999] I> Found 42 partitions in SDMMC_USER (instance 3)
[0001.000] I> Active Boot chain : 1
[0001.003] I> parsing oem signed section of bpmp-fw header done
[0001.009] I> bpmp-fw binary init read from storage
[0001.014] I> oem authentication of bpmp-fw header done
[0001.020] I> bpmp-fw binary done read from storage
[0001.023] I> bpmp-fw: Authentication init Done
[0001.028] I> parsing oem signed section of cpubl header done
[0001.033] I> cpubl binary init read from storage
[0001.037] I> bpmp-fw: Authentication Finalize Done
[0001.042] I> oem authentication of cpubl header done
[0001.047] I> cpubl binary done read from storage
[0001.051] I> cpubl: Authentication init Done
[0001.056] I> parsing oem signed section of rce header done
[0001.061] I> rce binary init read from storage
[0001.065] I> Relocating BR-BCT
[0001.068] I> cpubl: Authentication Finalize Done
[0001.072] I> oem authentication of rce header done
[0001.077] I> rce binary done read from storage
[0001.081] I> rce: Authentication init Done
[0001.086] I> parsing oem signed section of ape header done
[0001.090] I> ape binary init read from storage
[0001.095] I> rce: Authentication Finalize Done
[0001.099] I> oem authentication of ape header done
[0001.104] I> ape binary done read from storage
[0001.108] I> ape: Authentication init Done
[0001.113] I> parsing oem signed section of tos header done
[0001.117] I> tos binary init read from storage
[0001.122] I> ape: Authentication Finalize Done
[0001.126] I> oem authentication of tos header done
[0001.130] I> tos binary done read from storage
[0001.135] I> tos: Authentication init Done
[0001.139] I> parsing oem signed section of bpmp-fw-dtb header done
[0001.145] I> bpmp-fw-dtb binary init read from storage
[0001.150] I> tos: Authentication Finalize Done
[0001.156] I> oem authentication of bpmp-fw-dtb header done
[0001.162] I> bpmp-fw-dtb binary done read from storage
[0001.164] I> bpmp-fw-dtb: Authentication init Done
[0001.169] I> parsing oem signed section of cpubl-dtb header done
[0001.175] I> cpubl-dtb binary init read from storage
[0001.180] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.218] I> oem authentication of cpubl-dtb header done
[0001.218] I> cpubl-dtb binary done read from storage
[0001.219] I> cpubl-dtb: Authentication init Done
[0001.221] I> parsing oem signed section of eks header done
[0001.221] I> eks binary init read from storage
[0001.222] I> cpubl-dtb: Authentication Finalize Done
[0001.223] I> oem authentication of eks header done
[0001.226] I> eks binary done read from storage
[0001.231] I> eks: Authentication init Done
[0001.235] I> eks: Authentication Finalize Done
[0001.239] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
��mrq initialized
��[0001.743] I> Welcome to Cboot
��fmon_post initialized
��[0001.743] I> Cboot Version: t194-cfa2bc91
[0001.743] I> CPU-BL Params @ 0xf2820000
[0001.744] I> 0) Base:0x00000000 Size:0x00000000
[0001.748] I> 1) Base:0xf1100000 Size:0x00100000
[0001.752] I> 2) Base:0xf2000000 Size:0x00200000
[0001.756] I> 3) Base:0xf1200000 Size:0x00200000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.761] I> 4) Base:0xf1000000 Size:0x00100000
[0001.840] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.845] I> 6) Base:0xf3800000 Size:0x00400000
[0001.849] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.854] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.858] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.863] I> 10) Base:0xf3000000 Size:0x00800000
[0001.867] I> 11) Base:0x40000000 Size:0x00040000
[0001.872] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.876] I> 13) Base:0x40046000 Size:0x00002000
[0001.881] I> 14) Base:0x40048000 Size:0x00002000��emc_debugfs initialized
dvs_debugfs initialized
[0001.890] I> 15) Base:0xac000000 Size:0x00004000��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.940] I> 16) Base:0x4004a000 Size:0x00002000
[0001.945] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.949] I> 18) Base:0x4004c000 Size:0x00002000
[0001.954] I> 19) Base:0xf2200000 Size:0x00600000
[0001.958] I> 20) Base:0x4004e000 Size:0x00002000
[0001.962] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.967] I> 22) Base:0x00000000 Size:0x00000000
[0001.971] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.976] I> 24) Base:0xf6000000 Size:0x02000000
[0001.980] I> 25) Base:0x40050000 Size:0x00002000
[0001.985] I> 26) Base:0x40040000 Size:0x00006000
[0001.989] I> 27) Base:0xf1800000 Size:0x00400000
[0001.994] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.998] I> 29) Base:0xf1400000 Size:0x00400000
[0002.003] I> 30) Base:0x00000000 Size:0x00000000
[0002.007] I> 31) Base:0x00000000 Size:0x00000000
[0002.012] I> 32) Base:0xf8000000 Size:0x08000000
[0002.016] I> 33) Base:0x00000000 Size:0x00000000
[0002.021] I> 34) Base:0xf3c00000 Size:0x01000000
[0002.025] I> 35) Base:0xab000000 Size:0x01000000
[0002.029] I> 36) Base:0xa0000000 Size:0x0b000000
[0002.034] I> 37) Base:0xf2800000 Size:0x00800000
[0002.038] I> 38) Base:0x80000000 Size:0x20000000
[0002.043] I> 39) Base:0xb0000000 Size:0x08000000
[0002.047] I> 40) Base:0x00000000 Size:0x00000000
[0002.052] I> 41) Base:0x00000000 Size:0x00000000
[0002.056] I> 42) Base:0x00000000 Size:0x00000000
[0002.061] I> 43) Base:0x00000000 Size:0x00000000
[0002.065] I> 44) Base:0x00000000 Size:0x00000000
[0002.070] I> 45) Base:0x00000000 Size:0x00000000
[0002.074] GIC-SPI Target CPU: 0
[0002.077] Interrupts Init done
[0002.080] calling constructors
[0002.083] initializing heap
[0002.085] I> Heap: [0xa0699b80 ... 0xab000000]
[0002.090] initializing threads
[0002.093] initializing timers
[0002.095] creating bootstrap completion thread
[0002.100] top of bootstrap2()
[0002.102] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0002.107] initializing platform
[0002.110] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0002.116] W> device prod register failed
[0002.119] I> Bl_dtb @0xaaf00000
[0002.126] W> "plugin-manager" doesn't exist, creating
[0002.127] W> "ids" doesn't exist, creating
[0002.132] W> "connection" doesn't exist, creating
[0002.136] W> "configs" doesn't exist, creating
[0002.150] E> failed to read label property for node 227172: 13
[0002.153] E> failed to read reg property for node 227260: 13
[0002.155] E> failed to read label property for node 227312: 13
[0002.159] E> failed to read label property for node 227380: 13
[0002.164] E> failed to read label property for node 227416: 13
[0002.170] E> failed to read label property for node 227452: 13
[0002.176] E> failed to read reg property for node 227520: 13
[0002.181] E> failed to read label property for node 227572: 13
[0002.187] I> Find /i2c@3160000's alias i2c0
[0002.189] I> Reading eeprom i2c=0 address=0x50
[0002.219] I> Device at /i2c@3160000:0x50
[0002.219] I> Reading eeprom i2c=0 address=0x56
[0002.243] I> Device at /i2c@3160000:0x56
[0002.245] I> Find /i2c@3180000's alias i2c2
[0002.245] I> Reading eeprom i2c=2 address=0x54
[0002.247] E> I2C: slave not found in slaves.
[0002.247] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0002.248] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.248] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instan.
[0002.257] E> eeprom: Failed to read I2C slave device
[0002.262] I> Eeprom read failed 0x3526070d
[0002.266] I> Reading eeprom i2c=2 address=0x57
[0002.271] E> I2C: slave not found in slaves.
[0002.275] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.282] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.288] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instan.
[0002.297] E> eeprom: Failed to read I2C slave device
[0002.302] I> Eeprom read failed 0x3526070d
[0002.306] I> Reading eeprom i2c=2 address=0x52
[0002.311] E> I2C: slave not found in slaves.
[0002.315] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.323] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.328] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instan.
[0002.338] E> eeprom: Failed to read I2C slave device
[0002.342] I> Eeprom read failed 0x3526070d
[0002.347] I> Find /i2c@c240000's alias i2c1
[0002.350] I> Reading eeprom i2c=1 address=0x52
[0002.356] E> I2C: slave not found in slaves.
[0002.359] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.367] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.372] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instan.
[0002.382] E> eeprom: Retry to read I2C slave device.
[0002.387] E> I2C: slave not found in slaves.
[0002.391] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.398] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.404] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instan.
[0002.413] E> eeprom: Failed to read I2C slave device
[0002.418] I> Eeprom read failed 0x3526070d
[0002.422] I> Reading eeprom i2c=1 address=0x50
[0002.427] E> I2C: slave not found in slaves.
[0002.431] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.439] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.444] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instan.
[0002.454] E> eeprom: Retry to read I2C slave device.
[0002.459] E> I2C: slave not found in slaves.
[0002.462] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.470] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.476] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instan.
[0002.485] E> eeprom: Failed to read I2C slave device
[0002.490] I> Eeprom read failed 0x3526070d
[0002.494] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.499] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,displ3
[0002.510] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.516] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,displ3
[0002.527] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.535] W> "i2c@3160000" doesn't exist, creating
[0002.538] W> "module@0x50" doesn't exist, creating
[0002.543] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0002.550] W> "module@0x56" doesn't exist, creating
[0002.556] I> Adding plugin-manager/cvm
[0002.558] W> "chip-id" doesn't exist, creating
[0002.562] I> Adding plugin-manager/chip-id/A02P
[0002.567] I> Plugin-manager override starting
[0002.572] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.580] I> node /plugin-manager/fragement-soft-wdt matches
[0002.589] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.593] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.604] I> Disable plugin-manager status in FDT
[0002.604] I> Plugin-manager override finished successfully
[0002.605] I> gpio framework initialized
[0002.609] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.616] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.623] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.630] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.638] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.644] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.650] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.658] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.666] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.672] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.680] I> fixed regulator driver initialized
[0002.691] I> register 'maxim' power off handle
[0002.692] I> virtual i2c enabled
[0002.692] I> registered 'maxim,max20024' pmic
[0002.694] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.701] I> Boot-device: eMMC
[0002.704] I> Boot_device: SDMMC_BOOT instance: 3
[0002.712] I> sdmmc-3 params source = boot args
[0002.713] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.718] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,displ3
[0002.729] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.734] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,displ3
[0002.745] I> sdmmc bdev is already initialized
[0002.749] I> sdmmc-3 params source = boot args
[0002.781] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.793] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.803] I> enabling 'vdd-hdmi-5v0' regulator
[0002.808] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.809] I> hdmi cable connected
[0002.811] W> set volts not configured for 'vdd-1v0'
[0002.813] W> set volts not configured for 'vdd-1v8-hs'
[0002.814] I> retrieved tmds range from prod_list_hdmi_soc
[0002.818] E> invalid display type
[0002.821] E> invalid display type
[0002.823] E> cannot find any other nvdisp nodes
[0002.826] E> I2C: slave not found in slaves.
[0002.826] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.829] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.834] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instan.
[0002.844] E> could not read edid
[0002.851] I> hdmi_enable, starting HDMI initialisation
[0002.856] I> hdmi_enable, HDMI initialisation complete
[0002.866] I> Load in CBoot Boot Options partition and parse it
[0002.872] E> Error -9 when finding node with path /boot-configuration
[0002.873] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.876] I> Using default boot order
[0002.880] I> boot-dev-order :-
[0002.883] I> 1.sd
[0002.884] I> 2.usb
[0002.886] I> 3.nvme
[0002.888] I> 4.emmc
[0002.890] I> 5.net
[0002.892] I> Hit any key to stop autoboot: 4 3 2 1
[0004.900] initializing target
[0004.900] calling apps_init()
[0004.901] starting app kernel_boot_app
[0004.920] I> found decompressor handler: lz4-legacy
[0004.921] I> decompressing BMP blob ...
[0004.931] I> Kernel type = Normal
[0004.932] I> ########## SD (0) boot ##########
[0004.932] I> No sdcard
[0004.932] I> -0 params source =
[0004.933] E> Blockdev open: exit error
[0004.933] E> SD boot failed, err: 724238353
[0004.933] I> ########## USB (0) boot ##########
[0004.944] I> Validate XUSB-FW ...
[0004.945] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x28000
[0004.946] I> Encryption fuse is not ON
[0004.947] I> USB Firmware Version: 60.09 release
[0005.004] I> regulator of usb2-0 already enabled
[0005.011] I> regulator of usb2-1 already enabled
[0005.018] I> regulator of usb2-2 already enabled
[0005.027] I> enabling 'vdd-5v-sata' regulator
[0006.031] E> failed to initialize xhci controller
[0006.032] E> Error in init of XUSB host driver, err: 79790026
[0006.032] W> Failed to initialize device 5-0
[0006.033] E> USB boot failed, err: 2037973030
[0006.033] I> ########## NVME (0) boot ##########
[0006.033] I> Initializing nvme device instance 0
[0006.034] I> Initializing nvme controller
[0006.038] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0006.044] I> vpcie3v3-supply not found
[0006.048] I> vpcie12v-supply not found
[0006.051] W> Failed to get nvidia,plat-gpios
[0006.055] I> tegrabl_pcie_soc_preinit: (0):
[0006.059] I> Unpowergate
[0006.062] I> tegrabl_car_clk_disable(0) ...
[0006.066] I> tegrabl_car_rst_set(CORE, 0) ...
[0006.070] I> tegrabl_car_rst_set(APB, 0) ...
[0006.074] I> tegrabl_car_clk_enable(0) ...
[0006.078] I> tegrabl_car_rst_clear(APB, 0) ...
[0006.082] I> tegrabl_set_ctrl_state(0)
[0006.086] I> CLR PCIE_APB:6
[0006.089] I> tegrabl_pcie_soc_init: (0):
[0006.092] I> APPL initialization ...
[0006.096] I> poweron phys
[0006.098] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0006.105] I> tegrabl_power_on_phy: power on phy @0x3e30000
[0006.110] I> tegrabl_power_on_phy: power on phy @0x3e40000
[0006.115] I> tegrabl_power_on_phy: power on phy @0x3e50000
[0006.121] I> tegrabl_power_on_phy: power on phy @0x3e60000
[0007.226] C> Failed to link up controller-0
[0007.227] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0007.227] I> Failed to initialize SoC Host PCIe controller
[0007.227] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x12
[0007.228] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0007.228] W> Failed to open NVME-0, err = 80800612
[0007.233] W> Failed to initialize device 10-0
[0007.237] E> NVME (0) boot failed, err: 0x80800612
[0007.242] I> ########## NVME (1) boot ##########
[0007.246] I> Initializing nvme device instance 1
[0007.251] I> Initializing nvme controller
[0007.255] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0007.261] I> vpcie3v3-supply not found
[0007.265] I> vpcie12v-supply not found
[0007.268] W> Failed to get nvidia,plat-gpios
[0007.272] I> tegrabl_pcie_soc_preinit: (1):
[0007.276] I> Unpowergate
[0007.279] I> tegrabl_car_clk_disable(1) ...
[0007.283] I> tegrabl_car_rst_set(CORE, 1) ...
[0007.287] I> tegrabl_car_rst_set(APB, 1) ...
[0007.291] I> tegrabl_car_clk_enable(1) ...
[0007.295] I> tegrabl_car_rst_clear(APB, 1) ...
[0007.299] I> tegrabl_set_ctrl_state(1)
[0007.303] I> CLR PCIE_APB:6
[0007.306] I> tegrabl_pcie_soc_init: (1):
[0007.309] I> APPL initialization ...
[0007.313] I> poweron phys
[0007.315] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0007.322] I> tegrabl_power_on_phy: power on phy @0x3e10000
[0007.428] I> PCIe controller-1 link is up
[0007.429] I> tegra_pcie_info[1].cfg0_base = 0x30000000
[0007.429] I> tegra_pcie_info[1].cfg1_base = 0x30020000
[0007.430] I> tegra_pcie_info[1].atu_dma_base = 0x30040000
[0007.430] I> tegra_pcie_bus[1].mem = 0x30200000
[0007.430] I> Scanning busnr: 0 devfn: 0
[0007.431] I> PCIe IDs: 0x1ad210de
[0007.434] I> PCIe RID_CC: 0x60400a1
[0007.437] I> Scanning busnr: 1 devfn: 0
[0007.441] I> PCIe IDs: 0x91711b4b
[0007.444] I> PCIe RID_CC: 0x1060113
[0007.447] I> PCI Config: I/O=0x30100000, Memory=0x30200000
[0007.453] I> IO bar_num=0 bar=0x30100000
[0007.456] I> IO bar_num=1 bar=0x30100008
[0007.460] I> IO bar_num=2 bar=0x30100010
[0007.464] I> IO bar_num=3 bar=0x30100018
[0007.468] I> IO bar_num=4 bar=0x30100020
[0007.471] I> MEM bar_num=5 bar=0x30200000
[0007.475] I> Number of PCIe devices detected: 2
[0007.480] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(1); error=0x0
[0007.487] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0007.493] W> Failed to open NVME-1, err = 80800612
[0007.497] W> Failed to initialize device 10-1
[0007.502] E> NVME (1) boot failed, err: 0x80800612
[0007.506] I> ########## NVME (2) boot ##########
[0007.511] I> Initializing nvme device instance 2
[0007.515] I> Initializing nvme controller
[0007.519] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0007.525] I> vpcie3v3-supply not found
[0007.529] I> vpcie12v-supply not found
[0007.533] W> Failed to get nvidia,plat-gpios
[0007.537] I> tegrabl_pcie_soc_preinit: (2):
[0007.541] I> Unpowergate
[0007.543] I> tegrabl_car_clk_disable(2) ...
[0007.547] I> tegrabl_car_rst_set(CORE, 2) ...
[0007.551] I> tegrabl_car_rst_set(APB, 2) ...
[0007.555] I> tegrabl_car_clk_enable(2) ...
[0007.559] I> tegrabl_car_rst_clear(APB, 2) ...
[0007.564] I> tegrabl_set_ctrl_state(2)
[0007.567] I> CLR PCIE_APB:6
[0007.570] I> tegrabl_pcie_soc_init: (2):
[0007.574] I> APPL initialization ...
[0007.577] I> poweron phys
[0007.580] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0007.586] I> tegrabl_power_on_phy: controller 2 not available
[0007.591] E> Failed to power on phy on controller-2
[0007.596] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0007.601] I> Failed to initialize SoC Host PCIe controller
[0007.606] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0007.613] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0007.619] W> Failed to open NVME-2, err = 80800601
[0007.624] W> Failed to initialize device 10-2
[0007.628] E> NVME (2) boot failed, err: 0x80800601
[0007.633] I> ########## NVME (3) boot ##########
[0007.637] I> Initializing nvme device instance 3
[0007.642] I> Initializing nvme controller
[0007.646] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0007.652] I> vpcie3v3-supply not found
[0007.656] I> vpcie12v-supply not found
[0007.659] W> Failed to get nvidia,plat-gpios
[0007.663] I> tegrabl_pcie_soc_preinit: (3):
[0007.667] I> Unpowergate
[0007.670] I> tegrabl_car_clk_disable(3) ...
[0007.674] I> tegrabl_car_rst_set(CORE, 3) ...
[0007.678] I> tegrabl_car_rst_set(APB, 3) ...
[0007.682] I> tegrabl_car_clk_enable(3) ...
[0007.686] I> tegrabl_car_rst_clear(APB, 3) ...
[0007.690] I> tegrabl_set_ctrl_state(3)
[0007.694] I> CLR PCIE_APB:6
[0007.697] I> tegrabl_pcie_soc_init: (3):
[0007.700] I> APPL initialization ...
[0007.704] I> poweron phys
[0007.706] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0007.713] I> tegrabl_power_on_phy: power on phy @0x3e80000
[0007.832] I> PCIe controller-3 link is up
[0007.832] I> tegra_pcie_info[3].cfg0_base = 0x34000000
[0007.832] I> tegra_pcie_info[3].cfg1_base = 0x34020000
[0007.833] I> tegra_pcie_info[3].atu_dma_base = 0x34040000
[0007.833] I> tegra_pcie_bus[3].mem = 0x34200000
[0007.834] I> Scanning busnr: 0 devfn: 0
[0007.834] I> PCIe IDs: 0x1ad210de
[0007.837] I> PCIe RID_CC: 0x60400a1
[0007.840] I> Scanning busnr: 1 devfn: 0
[0007.844] I> PCIe IDs: 0x24fd8086
[0007.847] I> PCIe RID_CC: 0x2800078
[0007.850] I> PCI Config: I/O=0x34100000, Memory=0x34200000
[0007.856] I> MEM64 bar_num=0 bar=0x34200000
[0007.860] I> Number of PCIe devices detected: 2
[0007.864] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(3); error=0x0
[0007.871] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0007.877] W> Failed to open NVME-3, err = 80800612
[0007.882] W> Failed to initialize device 10-3
[0007.886] E> NVME (3) boot failed, err: 0x80800612
[0007.891] I> ########## NVME (4) boot ##########
[0007.895] I> Initializing nvme device instance 4
[0007.900] I> Initializing nvme controller
[0007.904] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0007.910] I> vpcie3v3-supply not found
[0007.913] I> vpcie12v-supply not found
[0007.917] W> Failed to get nvidia,plat-gpios
[0007.921] I> tegrabl_pcie_soc_preinit: (4):
[0007.925] I> Unpowergate
[0007.928] I> tegrabl_car_clk_disable(4) ...
[0007.932] I> tegrabl_car_rst_set(CORE, 4) ...
[0007.936] I> tegrabl_car_rst_set(APB, 4) ...
[0007.940] I> tegrabl_car_clk_enable(4) ...
[0007.944] I> tegrabl_car_rst_clear(APB, 4) ...
[0007.948] I> tegrabl_set_ctrl_state(4)
[0007.952] I> CLR PCIE_APB:6
[0007.954] I> tegrabl_pcie_soc_init: (4):
[0007.958] I> APPL initialization ...
[0007.962] I> poweron phys
[0007.964] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0007.970] I> tegrabl_power_on_phy: controller 4 not available
[0007.976] E> Failed to power on phy on controller-4
[0007.981] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0007.986] I> Failed to initialize SoC Host PCIe controller
[0007.991] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x1
[0007.997] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0008.004] W> Failed to open NVME-4, err = 80800601
[0008.008] W> Failed to initialize device 10-4
[0008.013] E> NVME (4) boot failed, err: 0x80800601
[0008.017] I> ########## NVME (5) boot ##########
[0008.022] I> Initializing nvme device instance 5
[0008.026] I> Initializing nvme controller
[0008.031] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0008.037] I> i=0, reg_phandle=0x1b
[0008.042] I> reg_voltage=3300000
[0008.043] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1b, 3300000)
[0008.054] I> enabling 'vdd-3v3-pcie' regulator
[0008.055] I> i=1, reg_phandle=0x1c
[0008.060] I> reg_voltage=1200000
[0008.061] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1c, 1200000)
[0008.072] I> enabling 'vdd-12v-pcie' regulator
[0008.073] I> tegrabl_pcie_soc_preinit: (5):
[0008.076] I> Unpowergate
[0008.079] I> tegrabl_car_clk_disable(5) ...
[0008.083] I> tegrabl_car_rst_set(CORE, 5) ...
[0008.087] I> tegrabl_car_rst_set(APB, 5) ...
[0008.091] I> tegrabl_car_clk_enable(5) ...
[0008.095] I> tegrabl_car_rst_clear(APB, 5) ...
[0008.099] I> tegrabl_set_ctrl_state(5)
[0008.103] I> CLR PCIE_APB:6
[0008.106] I> tegrabl_pcie_soc_init: (5):
[0008.109] I> APPL initialization ...
[0008.113] I> poweron phys
[0008.116] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0008.122] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0008.127] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0008.132] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0008.138] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0008.143] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0008.148] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0008.154] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0008.159] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0009.264] C> Failed to link up controller-5
[0009.265] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0009.265] I> Failed to initialize SoC Host PCIe controller
[0009.266] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0009.266] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0009.267] W> Failed to open NVME-5, err = 80800612
[0009.271] W> Failed to initialize device 10-5
[0009.276] E> NVME (5) boot failed, err: 0x80800612
[0009.280] I> ########## Fixed storage boot ##########
[0009.285] I> Loading kernel-bootctrl from partition
[0009.290] I> Loading partition kernel-bootctrl at 0xa4ae0000 from device(0x1)
[0009.303] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0009.304] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0009.318] I> Already published: 00010003
[0009.318] I> Look for boot partition
[0009.318] I> Fallback: assuming 0th partition is boot partition
[0009.324] I> Detect filesystem
[0009.351] I> Loading extlinux.conf ...
[0009.351] I> Loading extlinux.conf binary from rootfs ...
[0009.352] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0009.400] I> Loading extlinux.conf sig file from rootfs ...
[0009.401] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0015.631] I> lookup_linear_dir:447: Invalid file block num
[0015.632] I> ext2_walk:142: 'extlinux.conf.sig' lookup failed
[0015.632] I> ext4_open_file:666: '/boot/extlinux/extlinux.conf.sig' lookup failed
[0015.633] E> file /sdmmc_user/boot/extlinux/extlinux.conf.sig open failed!!
[0015.633] W> Failed to load extlinux.conf sig file (err=202113041)
[0015.638] I> Validate extlinux.conf ...
[0015.641] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0015.648] E> Stage2Signature validation failed with SHA2!!
[0015.654] C> OEM authentication of extlinux.conf header failed!
[0015.659] W> Failed to validate extlinux.conf binary from rootfs (err=1077936152, fail=1)
[0015.667] W> Security fuse not burned, ignore validation failure
[0015.673] I> restore load_size to 863
[0015.677] I> L4T boot options
[0015.680] I> [1]: "primary kernel"
[0015.683] I> Enter choice:
[0018.686] I> Continuing with default option: 1
[0018.686] I> Loading kernel ...
[0018.686] I> Loading kernel binary from rootfs ...
[0018.687] I> rootfs path: /sdmmc_user/boot/Image
[0018.916] I> Loading kernel sig file from rootfs ...
[0018.916] I> rootfs path: /sdmmc_user/boot/Image.sig
[0018.953] I> overload load_size to 34484232 (from 34484240)
[0018.953] I> Validate kernel ...
[0018.954] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0019.268] I> Encryption fuse is not ON
[0019.298] I> Loading kernel-dtb ...
[0019.299] I> No kernel-dtb binary path
[0019.299] I> Continue to load from partition ...
[0019.299] I> A/B: bin_type (38) slot 1
[0019.299] I> Loading kernel-dtb_b from partition
[0019.300] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x1)
[0019.309] I> Validate kernel-dtb ...
[0019.310] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0019.313] I> Encryption fuse is not ON
[0019.315] I> Loading ramdisk from rootfs ...
[0019.317] I> Loading ramdisk binary from rootfs ...
[0019.322] I> rootfs path: /sdmmc_user/boot/initrd
[0019.413] I> Loading ramdisk sig file from rootfs ...
[0019.414] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0019.444] I> overload load_size to 7238344 (from 7238352)
[0019.445] I> Validate ramdisk ...
[0019.445] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0019.511] I> Encryption fuse is not ON
[0019.525] I> Kernel hdr @0xa4ae0000
[0019.525] I> Kernel dtb @0x90000000
[0019.525] I> decompressor handler not found
[0019.526] I> Copying kernel image (34484232 bytes) from 0xa4ae0000 to 0x80080000 ... [0019.536] I> Doe
[0019.537] I> Updated bpmp info to DTB
[0019.538] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0019.538] I> Updated initrd info to DTB
[0019.539] W> WARN: Fail to override "console=none" in commandline
[0019.539] I> Active rootfs suffix:
[0019.541] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0019.548] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0019.556] I> Active slot suffix: _b
[0019.559] I> add_boot_slot_suffix: slot_suffix = _b
[0019.564] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c
[0019.593] I> Updated bootarg info to DTB
[0019.597] W> MAC addr invalid!
[0019.600] E> Failed to get WIFI MAC address
[0019.604] W> MAC addr invalid!
[0019.607] E> Failed to get Bluetooth MAC address
[0019.611] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3a:86:52
[0019.618] W> "plugin-manager" doesn't exist, creating
[0019.622] I> Adding /chosen/plugin-manager/cvm
[0019.627] W> "chip-id" doesn't exist, creating
[0019.631] I> Adding /chosen/plugin-manager/chip-id
[0019.636] W> "configs" doesn't exist, creating
[0019.640] I> Adding /chosen/plugin-manager/configs
[0019.644] W> "ids" doesn't exist, creating
[0019.648] I> Adding /chosen/plugin-manager/ids
[0019.653] W> "odm-data" doesn't exist, creating
[0019.657] I> Adding /chosen/plugin-manager/odm-data
[0019.665] W> "memory" doesn't exist, creating
[0019.666] I> [0] START: 0x80000000, END: 0xac000000
[0019.671] I> [1] START: 0xac004000, END: 0xf0ad0000
[0019.675] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0019.680] I> dram_block larger than 80000000
[0019.684] I> [3] START: 0x100000000, END: 0x880000000
[0019.689] I> added [base:0x80000000, size:0x2c000000] to /memory
[0019.695] I> added [base:0xac200000, size:0x44800000] to /memory
[0019.701] I> added [base:0x100000000, size:0x780000000] to /memory
[0019.708] I> Updated memory info to DTB
[0019.711] E> add_disp_param: failed to get display params for du=1
[0019.717] W> "reset" doesn't exist, creating
[0019.721] I> Adding ecid(00000001647d02832000000005fe81c0) to DT
[0019.727] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0019.731] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0019.736] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0019.741] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0019.745] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0019.750] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0019.755] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0019.760] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0019.766] W> "misc-data" doesn't exist, creating
[0019.769] I> Boot-device: eMMC
[0019.772] I> Add boot-sdmmc to plugin-manager/misc-data
[0019.777] I> Add storage-sdmmc to plugin-manager/misc-data
[0019.782] W> Unknown storage device
[0019.786] I> Add serial number:1560321001653 as DT property
[0019.792] I> Plugin-manager override starting
[0019.796] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0019.803] I> node /plugin-manager/fragement-soft-wdt matches
[0019.810] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0019.814] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0019.827] I> Disable plugin-manager status in FDT
[0019.827] I> Plugin-manager override finished successfully
[0019.828] I> tegrabl_load_kernel_and_dtb: Done
[0019.856] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 201801
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06aa000
[ 0.000000] Found lut_mem: 00002008@a06a4000
��WARNING: pll_d3 has no dyn ramp
��[ 6.051721] cgroup: cgroup2: unknown option "nsdelegate"
[ 7.064715] using random self ethernet address
[ 7.064894] using random host ethernet address
[ 7.328751] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error 2
[ 7.328983] iwlwifi 0003:01:00.0: Falling back to user helper
[ 7.383560] random: crng init done
[ 7.383702] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.595046] using random self ethernet address
[ 7.595227] using random host ethernet address
[ 8.889608] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error 2
[ 8.889922] iwlwifi 0003:01:00.0: Falling back to user helper
[ 8.894269] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error 2
[ 8.894525] iwlwifi 0003:01:00.0: Falling back to user helper
[ 8.906120] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error 2
[ 8.906340] iwlwifi 0003:01:00.0: Falling back to user helper
[ 9.100601] thermal thermal_zone8: failed to read out thermal zone (-5)
[ 11.680497] Bridge firewalling registered
Ubuntu 18.04.6 LTS py-desktop ttyTCU0
py-desktop login:
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Offline | ttyUSB3
Yes, then dump the Xorg log…
I can’t type anything
Use your host to type something. Not your keyboard on jetson.
On the host I can’t type anything
Try to use other kind of console tool.
