Here are the bottom so many lines of it anyway. Can’t find a way to link the file pointer into here.
[code]2019-07-27 08:43:59.691 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:43:59.927 - info: 53042900339b60f8f4da17e7f8e873ea /home/david/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:43:59.927 - info: 5729cc195d365335991c58abd75e0c99 /home/david/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:43:59.927 - info: a6a9e37a31ceea0981a4f2622b4cce53 /home/david/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:43:59.927 - info: 0f3345fe86f29e14b056df400bdd9458 /home/david/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:43:59.927 - info: e8f021ea1fad99d99f0f551d7ea3146a /home/david/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.1.6-1+cuda10.0_all.deb
2019-07-27 08:43:59.927 - info: 0e12b2f53c7cbe4233c2da73f7d8e6b4 /home/david/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
2019-07-27 08:43:59.927 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.1.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:43:59.928 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.1.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:43:59.929 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.1.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:43:59.929 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.1.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:43:59.930 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.1.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
2019-07-27 08:43:59.930 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:00.156 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/P3448-0000/uff-converter-tf_5.1.6-1+cuda10.0_arm64.deb retry chain number 1
2019-07-27 08:44:00.158 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libopencv_3.3.1-2-g31ccdfe11_arm64.deb retry chain number 1
2019-07-27 08:44:00.160 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb retry chain number 1
2019-07-27 08:44:00.164 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb retry chain number 1
2019-07-27 08:44:00.166 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb retry chain number 1
2019-07-27 08:44:00.167 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/tensorrt.csv retry chain number 1
2019-07-27 08:44:00.287 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:44:00.287 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:44:00.290 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.290 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.311 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.311 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.313 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.313 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.315 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.315 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.317 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/tensorrt.csv
2019-07-27 08:44:00.317 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/tensorrt.csv
2019-07-27 08:44:00.317 - info: b6310b19820a8b844d36dc597d2bf835 /home/david/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.1.6-1+cuda10.0_arm64.deb
2019-07-27 08:44:00.317 - info: dd5b571c08a0098141203daec2ea1acc /home/david/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.317 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.1.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:00.318 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:00.551 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/visionworks.csv retry chain number 1
2019-07-27 08:44:00.552 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cudnn.csv retry chain number 1
2019-07-27 08:44:00.866 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/visionworks.csv
2019-07-27 08:44:00.866 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/visionworks.csv
2019-07-27 08:44:00.973 - info: 35776ce159afa78a0fe727d4a3c5b6fa /home/david/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.973 - info: d29571f888a59dd290da2650dc202623 /home/david/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.973 - info: e45328e07c8c8affa4f240f8045224a2 /home/david/Downloads/nvidia/sdkm_downloads/tensorrt.csv
2019-07-27 08:44:00.973 - info: 4f28a7792425b5e1470d5aa73c2a470d /home/david/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb
2019-07-27 08:44:00.973 - info: 36226c350ae160154e7ddac9054dcbcf /home/david/Downloads/nvidia/sdkm_downloads/visionworks.csv
2019-07-27 08:44:00.973 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:00.974 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:00.975 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/tensorrt.csv with correct checksum, skip downloading.
2019-07-27 08:44:00.975 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:00.976 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/visionworks.csv with correct checksum, skip downloading.
2019-07-27 08:44:01.226 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda.csv retry chain number 1
2019-07-27 08:44:01.227 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libnvidia-container0_0.9.0~beta.1_arm64.deb retry chain number 1
2019-07-27 08:44:01.229 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libnvidia-container-tools_0.9.0~beta.1_arm64.deb retry chain number 1
2019-07-27 08:44:01.230 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/nvidia-container-runtime-hook_0.9.0_beta.1-1_arm64.deb retry chain number 1
2019-07-27 08:44:01.231 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/nvidia-container-runtime_0.9.0_beta.1+docker18.09.2-1_arm64.deb retry chain number 1
2019-07-27 08:44:01.235 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/cudnn.csv
2019-07-27 08:44:01.235 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/cudnn.csv
2019-07-27 08:44:01.367 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/cuda.csv
2019-07-27 08:44:01.367 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/cuda.csv
2019-07-27 08:44:01.371 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.9.0~beta.1_arm64.deb
2019-07-27 08:44:01.371 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.9.0~beta.1_arm64.deb
2019-07-27 08:44:01.374 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0~beta.1_arm64.deb
2019-07-27 08:44:01.374 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0~beta.1_arm64.deb
2019-07-27 08:44:01.377 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime-hook_0.9.0_beta.1-1_arm64.deb
2019-07-27 08:44:01.377 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime-hook_0.9.0_beta.1-1_arm64.deb
2019-07-27 08:44:01.378 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_0.9.0_beta.1+docker18.09.2-1_arm64.deb
2019-07-27 08:44:01.378 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_0.9.0_beta.1+docker18.09.2-1_arm64.deb
2019-07-27 08:44:01.378 - info: 4e940a0228f6f5e833b790cdfbadc587 /home/david/Downloads/nvidia/sdkm_downloads/cudnn.csv
2019-07-27 08:44:01.378 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/cudnn.csv with correct checksum, skip downloading.
2019-07-27 08:44:01.655 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/nvidia-docker2_0.9.0_beta.1+docker18.09.2-1_arm64.deb retry chain number 1
2019-07-27 08:44:01.769 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/nvidia-docker2_0.9.0_beta.1+docker18.09.2-1_arm64.deb
2019-07-27 08:44:01.769 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/nvidia-docker2_0.9.0_beta.1+docker18.09.2-1_arm64.deb
2019-07-27 08:44:01.775 - info: fb0c10c402cedd491d335ae7c06abe38 /home/david/Downloads/nvidia/sdkm_downloads/cuda.csv
2019-07-27 08:44:01.775 - info: eea9689265c917e0f7a0343d3dbb9104 /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime-hook_0.9.0_beta.1-1_arm64.deb
2019-07-27 08:44:01.775 - info: f7a3983260a0f22d0b3fd84829952794 /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0~beta.1_arm64.deb
2019-07-27 08:44:01.775 - info: c343f119238659c724732da212163e83 /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.9.0~beta.1_arm64.deb
2019-07-27 08:44:01.775 - info: d0d30b50f48f05f6263caf43136c90da /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_0.9.0_beta.1+docker18.09.2-1_arm64.deb
2019-07-27 08:44:01.776 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/cuda.csv with correct checksum, skip downloading.
2019-07-27 08:44:01.780 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime-hook_0.9.0_beta.1-1_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:01.781 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0~beta.1_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:01.781 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.9.0~beta.1_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:01.782 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/nvidia-container-runtime_0.9.0_beta.1+docker18.09.2-1_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:02.084 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libvisionworks-repo_1.6.0.500n_arm64.deb retry chain number 1
2019-07-27 08:44:02.085 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libvisionworks-sfm-repo_0.90.4_arm64.deb retry chain number 1
2019-07-27 08:44:02.086 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/libvisionworks-tracking-repo_0.88.2_arm64.deb retry chain number 1
2019-07-27 08:44:02.087 - info: Download for: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/P3448-0000/Tegra_Multimedia_API_R32.2.0_aarch64.tbz2 retry chain number 1
2019-07-27 08:44:02.200 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb
2019-07-27 08:44:02.200 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb
2019-07-27 08:44:02.220 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb
2019-07-27 08:44:02.221 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb
2019-07-27 08:44:02.224 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb
2019-07-27 08:44:02.224 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb
2019-07-27 08:44:02.227 - info: get checksum by system command for /home/david/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.2.0_aarch64.tbz2
2019-07-27 08:44:02.228 - info: running md5sum /home/david/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.2.0_aarch64.tbz2
2019-07-27 08:44:02.374 - info: b78d6f3cdc1a8b6623979394e7242341 /home/david/Downloads/nvidia/sdkm_downloads/nvidia-docker2_0.9.0_beta.1+docker18.09.2-1_arm64.deb
2019-07-27 08:44:02.374 - info: 647b0ae86a00745fc6d211545a9fcefe /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb
2019-07-27 08:44:02.374 - info: 7630f0309c883cc6d8a1ab5a712938a5 /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb
2019-07-27 08:44:02.374 - info: e70d49ff115bc5782a3d07b572b5e3c0 /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb
2019-07-27 08:44:02.374 - info: f1e70a4fb5e2d333779b28f92224b4bf /home/david/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.2.0_aarch64.tbz2
2019-07-27 08:44:02.374 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/nvidia-docker2_0.9.0_beta.1+docker18.09.2-1_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:02.376 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:02.376 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:02.377 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
2019-07-27 08:44:02.377 - info: Found file /home/david/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.2.0_aarch64.tbz2 with correct checksum, skip downloading.
2019-07-27 08:44:02.504 - info: Download for all files is complete
2019-07-27 08:44:24.384 - info: [INPUT] “[ lsusb | grep -c \"NVidia Corp\" -ne 1 ] && echo SDKM_END_CODE_SUCCESS_ab2861e0-aa36-47b1-be1f-54022348dd6c || echo SDKM_END_CODE_FAILURE_ab2861e0-aa36-47b1-be1f-54022348dd6c\r”
2019-07-27 08:44:24.528 - info: cmd finished success SDKM_END_CODE_SUCCESS_ab2861e0-aa36-47b1-be1f-54022348dd6c
2019-07-27 08:44:24.528 - info: command finished successfully
2019-07-27 08:44:24.671 - info: [INPUT] “[ lsusb | grep -c \"NVidia Corp\" -gt 1 ] && echo SDKM_END_CODE_SUCCESS_82c744b3-e1b3-45c6-b471-5cdf70a8e910 || echo SDKM_END_CODE_FAILURE_82c744b3-e1b3-45c6-b471-5cdf70a8e910\r”
2019-07-27 08:44:24.813 - info: cmd finished failure SDKM_END_CODE_FAILURE_82c744b3-e1b3-45c6-b471-5cdf70a8e910
2019-07-27 08:44:24.813 - error: command terminated with error
2019-07-27 08:44:24.948 - error: Could not detect Nvidia Jetson device connected to USB.
*To validate if the device is in connected correctly, run ‘lsusb’ command on your host, and look for “0955:7f21: NVidia Corp”.
2019-07-27 08:44:33.352 - info: skip install Device Mode Host Setup in Target SDK
2019-07-27 08:44:33.352 - info: install ‘Device Mode Host Setup in Target SDK’ Skipped
2019-07-27 08:44:33.481 - info: skip install DateTime Target Setup
2019-07-27 08:44:33.481 - info: install ‘DateTime Target Setup’ Skipped
2019-07-27 08:44:33.610 - info: skip install Bzip2 Patch Setup In Target
2019-07-27 08:44:33.610 - info: install ‘Bzip2 Patch Setup In Target’ Skipped
2019-07-27 08:44:33.743 - info: skip install CUDA Toolkit for L4T
2019-07-27 08:44:33.743 - info: install ‘CUDA Toolkit for L4T’ Skipped
2019-07-27 08:44:33.871 - info: skip install cuDNN on Target
2019-07-27 08:44:33.872 - info: install ‘cuDNN on Target’ Skipped
2019-07-27 08:44:34.001 - info: skip install TensorRT on Target
2019-07-27 08:44:34.001 - info: install ‘TensorRT on Target’ Skipped
2019-07-27 08:44:34.135 - info: skip install OpenCV on Target
2019-07-27 08:44:34.135 - info: install ‘OpenCV on Target’ Skipped
2019-07-27 08:44:34.263 - info: skip install VisionWorks on Target
2019-07-27 08:44:34.263 - info: install ‘VisionWorks on Target’ Skipped
2019-07-27 08:44:34.392 - info: skip install NVIDIA Container Runtime with Docker integration (Beta)
2019-07-27 08:44:34.392 - info: install ‘NVIDIA Container Runtime with Docker integration (Beta)’ Skipped
2019-07-27 08:44:34.527 - info: skip install Multimedia API
2019-07-27 08:44:34.527 - info: install ‘Multimedia API’ Skipped
2019-07-27 08:44:35.685 - info: The overall duration (Download + Install) is 00:00:39
2019-07-27 08:44:35.686 - info:
*** Download Summary ***
- Bundle: JetPack 4.2.1 (rev.1) Linux for Jetson Nano (Developer Kit version)
- Download server: Devzone
- Download started on: Sat Jul 27 2019 08:43:56 GMT-0500 (CDT).
- Download ended on: Sat Jul 27 2019 08:44:02 GMT-0500 (CDT).
- Download duration: 48.011s.
- Average total download speed: 0B/s = total downloaded bytes / download duration.
- Average total bandwidth: 446.42MB/s, average accumulation of all file chunks speed, downloaded concurrently.
- Average file chunks download speed: 62.43MB/s, average of all downloaded file chunks speed.
- Max 6 concurrent files using 6 threads.
Total 32 files:
- 4.23GB downloaded of 4.23GB
- 0 downloaded, 32 cached, 0 failed
Details:
- cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb: Cached.
- libcudnn7_7.5.0.56-1+cuda10.0_arm64.deb: Cached.
- libcudnn7-dev_7.5.0.56-1+cuda10.0_arm64.deb: Cached.
- libcudnn7-doc_7.5.0.56-1+cuda10.0_arm64.deb: Cached.
- libnvinfer5_5.1.6-1+cuda10.0_arm64.deb: Cached.
- libnvinfer-dev_5.1.6-1+cuda10.0_arm64.deb: Cached.
- libnvinfer-samples_5.1.6-1+cuda10.0_all.deb: Cached.
- tensorrt_5.1.6.1-1+cuda10.0_arm64.deb: Cached.
- python-libnvinfer_5.1.6-1+cuda10.0_arm64.deb: Cached.
- python-libnvinfer-dev_5.1.6-1+cuda10.0_arm64.deb: Cached.
- python3-libnvinfer_5.1.6-1+cuda10.0_arm64.deb: Cached.
- python3-libnvinfer-dev_5.1.6-1+cuda10.0_arm64.deb: Cached.
- graphsurgeon-tf_5.1.6-1+cuda10.0_arm64.deb: Cached.
- uff-converter-tf_5.1.6-1+cuda10.0_arm64.deb: Cached.
- libopencv_3.3.1-2-g31ccdfe11_arm64.deb: Cached.
- libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb: Cached.
- libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb: Cached.
- libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb: Cached.
- libvisionworks-repo_1.6.0.500n_arm64.deb: Cached.
- libvisionworks-sfm-repo_0.90.4_arm64.deb: Cached.
- libvisionworks-tracking-repo_0.88.2_arm64.deb: Cached.
- deepstream-4.0_4.0-1_arm64.deb: Cached.
- tensorrt.csv: Cached.
- visionworks.csv: Cached.
- cudnn.csv: Cached.
- cuda.csv: Cached.
- libnvidia-container0_0.9.0~beta.1_arm64.deb: Cached.
- libnvidia-container-tools_0.9.0~beta.1_arm64.deb: Cached.
- nvidia-container-runtime-hook_0.9.0_beta.1-1_arm64.deb: Cached.
- nvidia-container-runtime_0.9.0_beta.1+docker18.09.2-1_arm64.deb: Cached.
- nvidia-docker2_0.9.0_beta.1+docker18.09.2-1_arm64.deb: Cached.
- Tegra_Multimedia_API_R32.2.0_aarch64.tbz2: Cached.
*** End of Download Summary ***
2019-07-27 08:44:35.687 - info:
Install summary of 18 components:
Install started on: 08:21:43 GMT-0500 (CDT).
Install ended on: Sat Jul 27 2019 08:44:35 GMT-0500 (CDT).
Install duration: 00:19:34 .
Install idle time: 00:00:04 .
Real install duration (duration - idle time): 00:19:30 .
Install 8 components.
- Already Install 7 components.
Install failed 0 files.
Install skipped 10 files.
Install details:
- NV_CUDA_HOST_COMP@host: Already Installed.
- NV_CUDA_HOST_CROSS_COMP@host: Already Installed.
- NV_OPENCV_HOST_COMP@host: Already Installed.
- NV_VISIONWORKS_HOST_COMP@host: Already Installed.
- NV_NVIDIA_NSIGHT_GRAPHICS_L4T_COMP@host: Already Installed.
- NV_NVIDIA_SYSTEM_PROFILER_L4T_COMP@host: Already Installed.
- NV_DEVTOOLS_DOCS_L4T_COMP@host: Already Installed.
- NV_L4T_DEVICE_MODE_SETUP_COMP_IN_TARGET@P3448-0000: Skipped.
- NV_L4T_DATETIME_TARGET_SETUP_COMP@P3448-0000: Skipped.
- UBUNTU_BZIP2_PATCH_IN_TARGET@P3448-0000: Skipped.
- NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@P3448-0000: Skipped.
- NV_L4T_CUDNN_TARGET_POST_INSTALL_NANO_TX1_COMP@P3448-0000: Skipped.
- NV_L4T_TENSORRT_TARGET_POST_INSTALL_NANO_TX1_COMP@P3448-0000: Skipped.
- NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@P3448-0000: Skipped.
- NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP@P3448-0000: Skipped.
- NV_DOCKER_TARGET_POST_INSTALL_COMP@P3448-0000: Skipped.
- NV_DEEPSTREAM_TARGET_POST_INSTALL_NANO_TX1_COMP@P3448-0000: Installed - 00:01:26 -start: 08:36:02 GMT-0500 (CDT) - end: 08:37:28 GMT-0500 (CDT).
- NV_MULTIMEDIA_API_TARGET_POST_INSTALL_NANO_TX1_COMP@P3448-0000: Skipped.
2019-07-27 08:44:35.687 - info: All done!
2019-07-27 08:44:36.021 - info:
********************** Completed install for bundle JetPack 4.2.1 (rev.1) Linux for Jetson Nano (Developer Kit version) time: 27-Jul-2019-08.44:36 is succeeded: true **********************
2019-07-27 08:44:36.025 - info: updateData level3 data
2019-07-27 08:44:36.026 - info: engine init InstallProxy
2019-07-27 08:44:36.026 - info: Initializing download manager with 6
2019-07-27 08:44:36.041 - info: looking for install adapter from /opt/nvidia/sdkmanager/resources/app/output/installUtils
2019-07-27 08:44:36.350 - info: [Download Service]:got heartbeat request
2019-07-27 08:44:36.350 - info: download service is alive
2019-07-27 08:44:36.351 - info: Replay file new log has been started.
2019-07-27 08:44:36.356 - info: GroupDataMap constructMap
2019-07-27 08:44:36.424 - info: running /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=10.0 -L=/home/david/.nvsdkm/logs/Linux_GA -c=eyJpZCI6Ik5WX0NVREFfSE9TVF9DT01QIiwibmFtZSI6IkNVREEgb24gSG9zdCIsImRlc2NyaXB0aW9uIjoiQ1VEQSB0byBiZSBpbnN0YWxsZWQgb24gaG9zdC4gQ1VEQSBpcyBhIHBhcmFsbGVsIGNvbXB1dGluZyBwbGF0Zm9ybSBhbmQgcHJvZ3JhbW1pbmcgbW9kZWwgaW52ZW50ZWQgYnkgTlZJRElBLiBJdCBlbmFibGVzIGRyYW1hdGljIGluY3JlYXNlcyBpbiBjb21wdXRpbmcgcGVyZm9ybWFuY2UgYnkgaGFybmVzc2luZyB0aGUgcG93ZXIgb2YgdGhlIGdyYXBoaWNzIHByb2Nlc3NpbmcgdW5pdCAoR1BVKS4iLCJjb21wVHlwZSI6Imhvc3QiLCJpc1Zpc2libGUiOnRydWUsImxpY2Vuc2VJZCI6Ik5WX0pFVFBBQ0tfQ1VEQV9FVUxBIiwiaXNEZXRlY3RhYmxlSW5zdGFsbCI6dHJ1ZSwiaXNJbnN0YWxsUGF0aEN1c3RvbWl6YWJsZSI6dHJ1ZSwidmVyc2lvbiI6IjEwLjAiLCJvcGVyYXRpbmdTeXN0ZW1zIjpbInVidW50dTE4MDQiXSwiaW5zdGFsbFNpemVNQiI6NDg5MSwiZG93bmxvYWRGaWxlcyI6W3sidXJsIjoidWJ1bnR1MTgwNC9jdWRhLXJlcG8tdWJ1bnR1MTgwNC0xMC0wLWxvY2FsLTEwLjAuMzI2LTQxMC4xMDhfMS4wLTFfYW1kNjQuZGViIiwiZmlsZU5hbWUiOiJjdWRhLXJlcG8tdWJ1bnR1MTgwNC0xMC0wLWxvY2FsLTEwLjAuMzI2LTQxMC4xMDhfMS4wLTFfYW1kNjQuZGViIiwic2l6ZSI6MTU4MjY2NzMyMCwiY2hlY2tzdW0iOiIwMzk2MjM5MTA4ZDQ2YWI2ODJmYjkwNDY4ZWE5MzdiNiIsImNoZWNrc3VtVHlwZSI6Im1kNSIsImluc3RhbGxQYXJhbWV0ZXJzIjp7Imluc3RhbGxUeXBlIjoiZGViX3JlcG8iLCJhZGRpdGlvbmFsUGFyYW1ldGVycyI6eyJwYWNrYWdlc0luZm8iOlt7Im5hbWUiOiJjdWRhLXRvb2xraXQtMTAtMCIsInZlcnNpb24iOiIxMC4wLjMyNiJ9XSwiYXB0U3dpdGNoIjoiLS1hbGxvdy1kb3duZ3JhZGVzIiwicG9zdFVuaW5zdGFsbENvbW1hbmRzIjpbeyJ1c2VyQ29tbWFuZCI6InN1ZG8gYXB0LWdldCAteSBwdXJnZSBjdWRhLWxpY2Vuc2UtMTAtMCJ9LHsidXNlckNvbW1hbmQiOiJzdWRvIGFwdC1nZXQgLXkgcHVyZ2UgY3VkYS1yZXBvLXVidW50dTE4MDQtMTAtMC1sb2NhbCoifSx7InVzZXJDb21tYW5kIjoic3VkbyBhcHQta2V5IGRlbCAkKGFwdC1rZXkgbGlzdCB8IGdyZXAgY3VkYXRvb2xzIC1CIDF8IGdyZXAgJ3B1YicgfCBjdXQgLWQgJyAnIC1mIDQgfCBjdXQgLWQvIC1mIDIpIn0seyJ1c2VyQ29tbWFuZCI6InN1ZG8gcm0gLXJmIC91c3IvbG9jYWwvY3VkYS0xMC4wIn0seyJ1c2VyQ29tbWFuZCI6InN1ZG8gcm0gLXJmIC91c3Ivc2hhcmUvZG9jL2N1ZGEqMTAtMCJ9XX19fV0sInRhcmdldElkcyI6WyJQMjg4OCIsIlAzMzEwIiwiUDM0ODktMDAwMCIsIlAzNDg5LTAwODAiLCJQMzQ0OC0wMDAwIiwiUDM0NDgtMDAyMCIsIlAyMTgwIl0sImRlcGVuZGVuY2llcyI6W10sImV4dGVybmFsX2RlcGVuZGVuY2llcyI6W10sInRhcmdldElEIjoiaG9zdCIsIl9pZCI6Ik5WX0NVREFfSE9TVF9DT01QQGhvc3QiLCJwYXJlbnRJRCI6Ik5WX0NVREFfSE9TVF9HUk9VUCIsIl9wYXJlbnRJRCI6Ik5WX0NVREFfSE9TVF9HUk9VUEBob3N0In0=
2019-07-27 08:44:36.424 - info: running /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_CROSS_COMP -v=10.0 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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
2019-07-27 08:44:36.424 - info: running /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_OPENCV_HOST_COMP -v=3.3.1 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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
2019-07-27 08:44:36.425 - info: running /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_VISIONWORKS_HOST_COMP -v=1.6 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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
2019-07-27 08:44:36.425 - info: running /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_NVIDIA_NSIGHT_GRAPHICS_L4T_COMP -v=2019.2 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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
2019-07-27 08:44:36.425 - info: running /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_NVIDIA_SYSTEM_PROFILER_L4T_COMP -v=2019.4 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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
2019-07-27 08:44:36.580 - info: Using GenericInstaller to Query NV_CUDA_HOST_COMP
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ cuda-toolkit-10-0
NV_CUDA_HOST_COMP cuda-repo-ubuntu1804-10-0-local-10.0.326-410.108_1.0-1_amd64.deb installed successfully.
2019-07-27 08:44:36.582 - info: Using GenericInstaller to Query NV_CUDA_HOST_CROSS_COMP
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ cuda-cross-aarch64-10-0
NV_CUDA_HOST_CROSS_COMP cuda-repo-cross-aarch64-10-0-local-10.0.326_1.0-1_all.deb installed successfully.
2019-07-27 08:44:36.582 - info: Using GenericInstaller to Query NV_OPENCV_HOST_COMP
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv
NV_OPENCV_HOST_COMP libopencv_3.3.1-2-gb3f86dcd5_amd64.deb installed successfully.
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv-dev
NV_OPENCV_HOST_COMP libopencv-dev_3.3.1-2-gb3f86dcd5_amd64.deb installed successfully.
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv-python
2019-07-27 08:44:36.583 - info: Using GenericInstaller to Query NV_VISIONWORKS_HOST_COMP
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libvisionworks
2019-07-27 08:44:36.583 - info: Using GenericInstaller to Query NV_NVIDIA_NSIGHT_GRAPHICS_L4T_COMP
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ nsight-graphics-for-l4t
2019-07-27 08:44:36.583 - info: finishing /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=10.0 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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 with exit code 0
2019-07-27 08:44:36.584 - info: finishing /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_CROSS_COMP -v=10.0 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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 with exit code 0
2019-07-27 08:44:36.588 - info: exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libvisionworks-dev
2019-07-27 08:44:36.588 - info: Using GenericInstaller to Query NV_NVIDIA_SYSTEM_PROFILER_L4T_COMP
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ nsightsystems-2019.4.1
2019-07-27 08:44:36.611 - info: NV_OPENCV_HOST_COMP libopencv-python_3.3.1-2-gb3f86dcd5_amd64.deb installed successfully.
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv-samples
2019-07-27 08:44:36.615 - info: NV_NVIDIA_NSIGHT_GRAPHICS_L4T_COMP 2019_06_23_2352-26660552-NVIDIA_Nomad_2019.2.19174.2352_Release_External-L4T.linux.deb installed successfully.
2019-07-27 08:44:36.616 - info: finishing /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_NVIDIA_NSIGHT_GRAPHICS_L4T_COMP -v=2019.2 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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 with exit code 0
2019-07-27 08:44:36.620 - info: NV_NVIDIA_SYSTEM_PROFILER_L4T_COMP NsightSystems-linux-public-2019.4.1.10-a76094a.deb installed successfully.
2019-07-27 08:44:36.621 - info: finishing /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_NVIDIA_SYSTEM_PROFILER_L4T_COMP -v=2019.4 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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 with exit code 0
2019-07-27 08:44:36.623 - info: exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libvisionworks-samples
2019-07-27 08:44:36.647 - info: NV_OPENCV_HOST_COMP libopencv-samples_3.3.1-2-gb3f86dcd5_amd64.deb installed successfully.
2019-07-27 08:44:36.648 - info: finishing /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_OPENCV_HOST_COMP -v=3.3.1 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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 with exit code 0
2019-07-27 08:44:36.658 - info: NV_VISIONWORKS_HOST_COMP libvisionworks-repo_1.6.0.500n_amd64.deb installed successfully.
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libvisionworks-sfm
2019-07-27 08:44:36.699 - info: exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libvisionworks-sfm-dev
2019-07-27 08:44:36.733 - info: NV_VISIONWORKS_HOST_COMP libvisionworks-sfm-repo_0.90.4_amd64.deb installed successfully.
exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libvisionworks-tracking
2019-07-27 08:44:36.767 - info: exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libvisionworks-tracking-dev
2019-07-27 08:44:36.805 - info: NV_VISIONWORKS_HOST_COMP libvisionworks-tracking-repo_0.88.2_amd64.deb installed successfully.
2019-07-27 08:44:36.807 - info: finishing /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_VISIONWORKS_HOST_COMP -v=1.6 -L=/home/david/.nvsdkm/logs/Linux_GA -c=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 with exit code 0
2019-07-27 08:44:36.810 - info: updateData level3 data
2019-07-27 08:44:36.811 - info: engine init InstallProxy
2019-07-27 08:44:36.811 - info: Initializing download manager with 6
2019-07-27 08:44:36.814 - info: looking for install adapter from /opt/nvidia/sdkmanager/resources/app/output/installUtils
2019-07-27 08:44:36.815 - info: [Download Service]:got heartbeat request
2019-07-27 08:44:36.816 - info: download service is alive
2019-07-27 08:44:36.816 - info: Replay file new log has been started.
2019-07-27 08:44:36.818 - info: GroupDataMap constructMap
2019-07-27 08:44:36.890 - warn: comp NV_L4T_DRIVERS_TX2_COMP filtered out, due to supported targetIDs [P3310,P3489-0000,P3489-0080], not include P3448-0000
2019-07-27 08:44:36.890 - warn: comp NV_L4T_FILE_SYSTEM_AND_OS_TX2_COMP filtered out, due to invalid dependencies: [NV_L4T_DRIVERS_TX2_COMP 32.2]
2019-07-27 08:44:36.890 - warn: comp NV_L4T_DRIVERS_XAVIER_COMP filtered out, due to supported targetIDs [P2888], not include P3448-0000
2019-07-27 08:44:36.890 - warn: comp NV_L4T_FILE_SYSTEM_AND_OS_XAVIER_COMP filtered out, due to invalid dependencies: [NV_L4T_DRIVERS_XAVIER_COMP 32.2]
2019-07-27 08:44:36.892 - warn: comp NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP filtered out, due to invalid dependencies: [NV_L4T_FILE_SYSTEM_AND_OS_TX2_COMP 32.2,NV_L4T_DRIVERS_TX2_COMP 32.2]
2019-07-27 08:44:36.892 - warn: comp NV_L4T_FLASH_TX2I_WITH_OS_IMAGE_COMP filtered out, due to invalid dependencies: [NV_L4T_FILE_SYSTEM_AND_OS_TX2_COMP 32.2,NV_L4T_DRIVERS_TX2_COMP 32.2]
2019-07-27 08:44:36.892 - warn: comp NV_L4T_FLASH_TX2_4GB_WITH_OS_IMAGE_COMP filtered out, due to invalid dependencies: [NV_L4T_FILE_SYSTEM_AND_OS_TX2_COMP 32.2,NV_L4T_DRIVERS_TX2_COMP 32.2]
2019-07-27 08:44:36.892 - warn: comp NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP filtered out, due to invalid dependencies: [NV_L4T_FILE_SYSTEM_AND_OS_XAVIER_COMP 32.2,NV_L4T_DRIVERS_XAVIER_COMP 32.2]
2019-07-27 08:44:36.893 - warn: comp NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [P3448-0020], not include P3448-0000
2019-07-27 08:44:36.893 - warn: comp NV_L4T_FLASH_TX1_WITH_OS_IMAGE_COMP filtered out, due to supported targetIDs [P2180], not include P3448-0000
2019-07-27 08:44:36.895 - warn: comp NV_L4T_CUDNN_TARGET_POST_INSTALL_TX2_COMP filtered out, due to supported targetIDs [P3310,P3489-0080,P3489-0000], not include P3448-0000
2019-07-27 08:44:36.895 - warn: comp NV_L4T_CUDNN_TARGET_POST_INSTALL_XAVIER_COMP filtered out, due to supported targetIDs [P2888], not include P3448-0000
2019-07-27 08:44:36.896 - warn: comp NV_L4T_TENSORRT_TARGET_POST_INSTALL_TX2_COMP filtered out, due to invalid dependencies: [NV_L4T_CUDNN_TARGET_POST_INSTALL_TX2_COMP 7.5]
2019-07-27 08:44:36.896 - warn: comp NV_L4T_TENSORRT_TARGET_POST_INSTALL_XAVIER_COMP filtered out, due to invalid dependencies: [NV_L4T_CUDNN_TARGET_POST_INSTALL_XAVIER_COMP 7.5]
2019-07-27 08:44:36.898 - warn: comp NV_DEEPSTREAM_TARGET_POST_INSTALL_TX2_COMP filtered out, due to invalid dependencies: [NV_L4T_TENSORRT_TARGET_POST_INSTALL_TX2_COMP 5.1]
2019-07-27 08:44:36.898 - warn: comp NV_DEEPSTREAM_TARGET_POST_INSTALL_XAVIER_COMP filtered out, due to invalid dependencies: [NV_L4T_TENSORRT_TARGET_POST_INSTALL_XAVIER_COMP 5.1]
2019-07-27 08:44:36.899 - warn: comp NV_MULTIMEDIA_API_TARGET_POST_INSTALL_TX2_COMP filtered out, due to invalid dependencies: [NV_L4T_TENSORRT_TARGET_POST_INSTALL_TX2_COMP 5.1]
2019-07-27 08:44:36.899 - warn: comp NV_MULTIMEDIA_API_TARGET_POST_INSTALL_XAVIER_COMP filtered out, due to invalid dependencies: [NV_L4T_TENSORRT_TARGET_POST_INSTALL_XAVIER_COMP 5.1]
2019-07-27 08:44:46.439 - info: cleaning up engine
2019-07-27 08:44:46.440 - info: installManager cleanup
2019-07-27 08:44:46.440 - info: cleanning up the downloader
2019-07-27 08:44:46.444 - info: [Download Service]:exiting download service
2019-07-27 08:44:46.454 - info: download service terminated due to receipt of signal SIGTERM with code: null
2019-07-30 00:44:13.040 - info: GPU hardware acceleration is disabled.
2019-07-30 00:44:13.043 - info:
*********************************** SDK Manager initialized ***********************************
2019-07-30 00:44:13.043 - info: Time: 2019-07-30_00:44:13
2019-07-30 00:44:13.043 - info: Client: UI
2019-07-30 00:44:13.043 - info: **********************************************************************
2019-07-30 00:44:13.043 - info: images path /opt/nvidia/sdkmanager/resources/app/output/dist/electron/images/
2019-07-30 00:44:19.265 - info: forking worker process
2019-07-30 00:44:19.291 - info: initializing the download service
2019-07-30 00:44:19.313 - info: forking a child process for the download service pid 7135
2019-07-30 00:44:19.425 - info: Initializing download manager with 6
2019-07-30 00:44:20.828 - info: updateData level3 data
2019-07-30 00:44:20.937 - info: Begin to create timing task for auto update.
2019-07-30 00:44:21.189 - info: engine init InstallProxy
2019-07-30 00:44:21.190 - info: Initializing download manager with 6
2019-07-30 00:44:21.198 - warn: installProxy initialization: did not get expected details from engine. Expected {product title, target os, and edition}. Got {title: null, OS: null, edition: }
2019-07-30 00:44:21.205 - info: looking for install adapter from /opt/nvidia/sdkmanager/resources/app/output/installUtils
2019-07-30 00:44:21.225 - info: [Download Service]:loading the download service
2019-07-30 00:44:21.225 - info: [Download Service]:initialized download service
2019-07-30 00:44:21.237 - info: download service is alive
2019-07-30 00:44:21.396 - info: [Download Service]:got heartbeat request
2019-07-30 00:44:21.421 - info: Replay file new log has been started.
2019-07-30 00:44:21.435 - info: GroupDataMap constructMap
2019-07-30 00:44:21.537 - info: running /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_CUDA_HOST_COMP -v=10.0 -L=/home/david/.nvsdkm/logs/Linux_GA -c=eyJpZCI6Ik5WX0NVREFfSE9TVF9DT01QIiwibmFtZSI6IkNVREEgb24gSG9zdCIsImRlc2NyaXB0aW9uIjoiQ1VEQSB0byBiZSBpbnN0YWxsZWQgb24gaG9zdC4gQ1VEQSBpcyBhIHBhcmFsbGVsIGNvbXB1dGluZyBwbGF0Zm9ybSBhbmQgcHJvZ3JhbW1pbmcgbW9kZWwgaW52ZW50ZWQgYnkgTlZJRElBLiBJdCBlbmFibGVzIGRyYW1hdGljIGluY3JlYXNlcyBpbiBjb21wdXRpbmcgcGVyZm9ybWFuY2UgYnkgaGFybmVzc2luZyB0aGUgcG93ZXIg
