I started with SDK Manager 1.1, which went well until I found that the connection with Jet AGX Xavier was not detected. Then I upgrade SDK Manager to 1.2, and only the “Developer Tools” was successfully installed. The terminal log is:
15:13:17 INFO: null
15:13:21 SUMMARY: NVIDIA Nsight Graphics: Install completed successfully.
15:13:21 SUMMARY: NVIDIA Nsight Systems: Install completed successfully.
15:13:21 INFO: Drivers for Jetson: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/T194/Jetson_Linux_R32.4.3_aarch64.tbz2 to /home/xingjian/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2
15:13:21 INFO: File System and OS: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/T194/Tegra_Linux_Sample-Root-Filesystem_R32.4.3_aarch64.tbz2 to /home/xingjian/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.4.3_aarch64.tbz2
15:13:21 INFO: CUDA Toolkit for L4T: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
15:13:21 INFO: OpenCV on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
15:13:21 INFO: OpenCV on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
15:13:21 INFO: OpenCV on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb
15:13:23 INFO: OpenCV on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb
15:13:23 INFO: OpenCV on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb successfully, checksum is correct
15:13:23 INFO: OpenCV on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb
15:13:23 INFO: OpenCV on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
15:13:23 INFO: OpenCV on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb successfully, checksum is correct
15:13:23 INFO: OpenCV on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb
15:13:24 INFO: OpenCV on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
15:13:24 INFO: OpenCV on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb successfully, checksum is correct
15:13:24 INFO: CUDA on Host: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/ubuntu1804/cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40_1.0-1_amd64.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40_1.0-1_amd64.deb
15:13:27 INFO: OpenCV on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb
15:13:27 INFO: OpenCV on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb successfully, checksum is correct
15:13:27 INFO: CUDA Cross Compile Package on Host: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-10-2-local-10.2.89_1.0-1_all.deb
15:13:29 INFO: OpenCV on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb
15:13:29 INFO: OpenCV on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb successfully, checksum is correct
15:13:29 INFO: VPI on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/vpi-lib-0.3.7-cuda10-aarch64-l4t.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-aarch64-l4t.deb
15:13:44 INFO: VPI on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-aarch64-l4t.deb
15:13:44 INFO: VPI on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-aarch64-l4t.deb successfully, checksum is correct
15:13:44 INFO: VPI on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/vpi-dev-0.3.7-cuda10-aarch64-l4t.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-aarch64-l4t.deb
15:13:47 INFO: VPI on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-aarch64-l4t.deb
15:13:47 INFO: VPI on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-aarch64-l4t.deb successfully, checksum is correct
15:13:47 INFO: VPI on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/vpi-samples-0.3.7-cuda10-aarch64-l4t.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-aarch64-l4t.deb
15:13:51 INFO: VPI on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-aarch64-l4t.deb
15:13:51 INFO: VPI on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-aarch64-l4t.deb successfully, checksum is correct
15:13:51 INFO: cuDNN on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
15:14:02 INFO: Drivers for Jetson: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2
15:14:03 INFO: Drivers for Jetson: download /home/xingjian/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2 successfully, checksum is correct
15:14:03 INFO: cuDNN on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/libcudnn8-dev_8.0.0.180-1+cuda10.2_arm64.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/libcudnn8-dev_8.0.0.180-1+cuda10.2_arm64.deb
15:14:03 DEBUG: Drivers for Jetson: using adapter to install NV_L4T_DRIVERS_T194_COMP@JETSON_AGX_XAVIER to /home/xingjian/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
15:14:03 INFO: Drivers for Jetson: [ Disk Avail:11.57 GB ]
15:14:03 INFO: Drivers for Jetson: Using GenericInstaller to Install NV_L4T_DRIVERS_T194_COMP
15:14:03 INFO: Drivers for Jetson: NV_L4T_DRIVERS_T194_COMP include 1 package
15:14:03 INFO: Drivers for Jetson: change working directory to /home/xingjian/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
15:14:03 INFO: Drivers for Jetson: [ Package PreInstall Started ]
15:14:03 INFO: Drivers for Jetson: current working directory is /home/xingjian/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
15:14:03 INFO: Drivers for Jetson: exec_command: sudo rm -rf /home/xingjian/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/
15:14:03 INFO: Drivers for Jetson: [host] [sudo] password for xingjian:
15:14:03 INFO: Drivers for Jetson: [ Package PreInstall Finished Successfully ]
15:14:03 INFO: Drivers for Jetson: [ Package Install Started ]
15:14:03 INFO: Drivers for Jetson: exec_command [host]:
15:14:03 INFO: Drivers for Jetson: **********************
15:14:03 INFO: Drivers for Jetson: #!/bin/bash
15:14:03 INFO: Drivers for Jetson: set -e
15:14:03 INFO: Drivers for Jetson: function safe_apt_install {
15:14:03 INFO: Drivers for Jetson: echo “*begin $1, $2”
15:14:03 INFO: Drivers for Jetson: tmp_log=/tmp/jetpack_dpkg_log.txt
15:14:03 INFO: Drivers for Jetson: sudo rm -f $tmp_log
15:14:03 INFO: Drivers for Jetson: set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
15:14:03 INFO: Drivers for Jetson: while [ ${CMD_STATUS} -ne 0 ]; do
15:14:03 INFO: Drivers for Jetson: if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
15:14:03 INFO: Drivers for Jetson: echo “Waiting $2 seconds for apt to be available”; sleep ${2}
15:14:03 INFO: Drivers for Jetson: else
15:14:03 INFO: Drivers for Jetson: echo “Unhandled error when running $1”; exit 1
15:14:03 INFO: Drivers for Jetson: fi
15:14:03 INFO: Drivers for Jetson: done
15:14:03 INFO: Drivers for Jetson: }
15:14:03 INFO: Drivers for Jetson: sudo apt-get update || true
15:14:03 INFO: Drivers for Jetson: safe_apt_install “sudo apt-get install -y pigz lbzip2” 5
15:14:03 INFO: Drivers for Jetson: tar xf /home/xingjian/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2
15:14:03 INFO: Drivers for Jetson: exec_command: /tmp/tmp_NV_L4T_DRIVERS_T194_COMP.sh
15:14:03 INFO: Drivers for Jetson: Get:1 file:/var/cuda-repo-10-2-local-10.2.89-440.40 InRelease
15:14:03 INFO: Drivers for Jetson: Ign:1 file:/var/cuda-repo-10-2-local-10.2.89-440.40 InRelease
15:14:03 INFO: Drivers for Jetson: Get:2 file:/var/cuda-repo-10-2-local-10.2.89-440.40 Release [574 B]
15:14:04 INFO: Drivers for Jetson: Hit:4 Index of /ubuntu bionic InRelease
15:14:04 INFO: Drivers for Jetson: Get:5 Index of /ubuntu bionic-security InRelease [88.7 kB]
15:14:04 INFO: Drivers for Jetson: Get:6 Index of /ubuntu bionic-updates InRelease [88.7 kB]
15:14:05 INFO: Drivers for Jetson: Get:7 Index of /ubuntu bionic-backports InRelease [74.6 kB]
15:14:05 INFO: Drivers for Jetson: Get:8 Index of /ubuntu bionic-updates/main amd64 Packages [1,007 kB]
15:14:06 INFO: Drivers for Jetson: Get:9 Index of /ubuntu bionic-updates/main i386 Packages [712 kB]
15:14:07 INFO: Drivers for Jetson: Get:10 Index of /ubuntu bionic-updates/universe i386 Packages [1,025 kB]
15:14:07 INFO: Drivers for Jetson: Get:11 Index of /ubuntu bionic-updates/universe amd64 Packages [1,091 kB]
15:14:20 INFO: Drivers for Jetson: Fetched 4,087 kB in 5s (898 kB/s)
15:14:21 INFO: cuDNN on Target: verifying checksum of /home/xingjian/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
15:14:21 INFO: cuDNN on Target: download /home/xingjian/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb successfully, checksum is correct
15:14:21 INFO: cuDNN on Target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/libcudnn8-doc_8.0.0.180-1+cuda10.2_arm64.deb to /home/xingjian/Downloads/nvidia/sdkm_downloads/libcudnn8-doc_8.0.0.180-1+cuda10.2_arm64.deb
15:14:22 INFO: Drivers for Jetson: Reading package lists…
15:14:22 INFO: Drivers for Jetson: *begin sudo apt-get install -y pigz lbzip2, 5
15:14:22 INFO: Drivers for Jetson: Building dependency tree…
15:14:22 INFO: Drivers for Jetson: Reading state information…
15:14:22 INFO: Drivers for Jetson: lbzip2 is already the newest version (2.5-2).
15:14:22 INFO: Drivers for Jetson: pigz is already the newest version (2.4-1).
15:14:22 INFO: Drivers for Jetson: You might want to run ‘apt --fix-broken install’ to correct these.
15:14:22 INFO: Drivers for Jetson: The following packages have unmet dependencies:
15:14:22 INFO: Drivers for Jetson: cuda-libraries-dev-10-2 : Depends: libcublas-dev (>= 10.2.2.89) but it is not going to be installed
15:14:22 INFO: Drivers for Jetson: cuda-samples-10-2 : Depends: libcublas-dev (>= 10.2.2.89) but it is not going to be installed
15:14:22 INFO: Drivers for Jetson: cuda-visual-tools-10-2 : Depends: libcublas-dev (>= 10.2.2.89) but it is not going to be installed
15:14:22 INFO: Drivers for Jetson: E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
15:14:22 INFO: Drivers for Jetson: Unhandled error when running sudo apt-get install -y pigz lbzip2
15:14:22 INFO: Drivers for Jetson: [ Package Install Finished with Error ]
15:14:22 INFO: Drivers for Jetson: [ 20.00 KB released. Disk Avail: 11.57 GB ]
15:14:22 INFO: Drivers for Jetson: [ NV_L4T_DRIVERS_T194_COMP Install took 20s ]
15:14:22 SUMMARY: Drivers for Jetson: Failed to execute commands with GenericInstaller
15:14:22 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
15:14:22 SUMMARY: Multimedia API: Depends on failed component
15:14:22 SUMMARY: TensorRT on Target: Depends on failed component
15:14:22 SUMMARY: VisionWorks on Target: Depends on failed component
15:14:22 SUMMARY: VPI on Target: Depends on failed component
15:14:22 SUMMARY: CUDA Toolkit for L4T: Depends on failed component
15:14:22 SUMMARY: cuDNN on Target: Depends on failed component
15:14:22 SUMMARY: OpenCV on Target: Depends on failed component
15:14:22 SUMMARY: DateTime Target Setup: Depends on failed component
15:14:22 SUMMARY: Device Mode Host Setup in Target SDK: Depends on failed component
15:14:22 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB: Depends on failed component
15:14:23 SUMMARY: VPI on Target: Depends on failed component
15:14:23 SUMMARY: CUDA Toolkit for L4T: Depends on failed component
15:14:23 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
15:14:23 SUMMARY: Multimedia API: Depends on failed component
15:14:23 SUMMARY: TensorRT on Target: Depends on failed component
15:14:23 SUMMARY: VisionWorks on Target: Depends on failed component
15:14:23 SUMMARY: cuDNN on Target: Depends on failed component
15:14:23 SUMMARY: OpenCV on Target: Depends on failed component
15:14:23 SUMMARY: DateTime Target Setup: Depends on failed component
15:14:23 SUMMARY: Device Mode Host Setup in Target SDK: Depends on failed component
15:14:23 SUMMARY: Device Mode Host Setup in Flash: Depends on failed component
Hi yxj1995,
From the log, there seems to be broken packages on your host. You might want to run ‘apt --fix-broken install’ to correct these, then re-install with SDK Manager.
Hello Edward, thank you for the reply. I did run the ‘apt --fix-broken’ and got the some other error, and I swtiched from CUDA 10.0 to 10.2 (the version is indicated in the “STEP 2 - HOST COMPONENTS”) and the installation succeeded.
