11:13:31 INFO : OpenCV on Host : [ Package Install Started ]
11:13:31 INFO : OpenCV on Host : deb installer start to install
11:13:31 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gd6a8916_amd64.deb Package | tr -d ’
11:13:31 INFO : OpenCV on Host : ’
11:13:31 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gd6a8916_amd64.deb Version | tr -d ’
11:13:31 INFO : OpenCV on Host : deb file /home/feng/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gd6a8916_amd64.deb, package name [libopencv], package version [3.3.1-2-gd6a8916]
11:13:31 INFO : OpenCV on Host : infer package info from file name libopencv_3.3.1-2-gd6a8916_amd64.deb [ name: libopencv, version: 3.3.1-2-gd6a8916 ]
11:13:31 INFO : OpenCV on Host : (Reading database … 431409 files and directories currently installed.)
11:13:31 INFO : OpenCV on Host : Preparing to unpack …/libopencv_3.3.1-2-gd6a8916_amd64.deb …
11:13:31 INFO : OpenCV on Host : Unpacking libopencv (3.3.1-2-gd6a8916) over (3.3.1-2-gd6a8916) …
11:13:31 INFO : OpenCV on Host : Setting up libopencv (3.3.1-2-gd6a8916) …
11:13:32 INFO : OpenCV on Host : Processing triggers for libc-bin (2.23-0ubuntu11) …
11:13:32 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=’{db:Status-abbrev} {Version}’ libopencv
11:13:32 INFO : OpenCV on Host : NV_OPENCV_HOST_COMP libopencv_3.3.1-2-gd6a8916_amd64.deb installed successfully.
11:13:32 INFO : OpenCV on Host : [ Package Install Finished Successfully ]
11:13:32 INFO : OpenCV on Host : [ Package Install Started ]
11:13:32 INFO : OpenCV on Host : deb installer start to install
11:13:32 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Package | tr -d ’
11:13:32 INFO : OpenCV on Host : ’
11:13:32 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Version | tr -d ’
11:13:32 INFO : OpenCV on Host : deb file /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb, package name [libopencv-dev], package version [3.3.1-2-gd6a8916]
11:13:32 INFO : OpenCV on Host : infer package info from file name libopencv-dev_3.3.1-2-gd6a8916_amd64.deb [ name: libopencv-dev, version: 3.3.1-2-gd6a8916 ]
11:13:32 ERROR : OpenCV on Host : dpkg: considering removing libopencv-calib3d-dev:amd64 in favour of libopencv-dev …
11:13:32 INFO : OpenCV on Host : dpkg: no, cannot proceed with removal of libopencv-calib3d-dev:amd64 (–auto-deconfigure will help):
11:13:32 INFO : OpenCV on Host : libopencv-contrib-dev:amd64 depends on libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
11:13:32 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 is to be removed.
11:13:32 INFO : OpenCV on Host : dpkg: regarding …/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb containing libopencv-dev:
11:13:32 INFO : OpenCV on Host : libopencv-dev conflicts with libopencv-calib3d-dev
11:13:32 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 (version 2.4.9.1+dfsg-1.5ubuntu1.1) is present and installed.
11:13:32 ERROR : OpenCV on Host : dpkg: error processing archive /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb (–install):
11:13:32 INFO : OpenCV on Host : conflicting packages - not installing libopencv-dev
11:13:32 ERROR : OpenCV on Host : Errors were encountered while processing:
11:13:32 INFO : OpenCV on Host : /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb
11:13:32 INFO : OpenCV on Host : Reading package lists…
11:13:33 INFO : OpenCV on Host : Building dependency tree…
11:13:33 INFO : OpenCV on Host : Reading state information…
11:13:33 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=’{db:Status-abbrev} {Version}’ libopencv-dev
11:13:33 INFO : OpenCV on Host : [ Package Install Finished with Error ]
11:13:33 ERROR : OpenCV on Host : NV_OPENCV_HOST_COMP package [{libopencv-dev 3.3.1}] not installed
11:13:33 INFO : OpenCV on Host : [ 12.00 KB used. Disk Avail: 319.27 GB ]
11:13:33 INFO : OpenCV on Host : [ NV_OPENCV_HOST_COMP Install took 2s ]
11:13:33 INFO : OpenCV on Host : package [{libopencv-dev 3.3.1}] not installed
11:13:33 ERROR : OpenCV on Host : command terminated with error
11:13:33 ERROR : install ‘OpenCV on Host’ failure, command < cd ‘/home/feng/nvidia/nvidia_sdk/JetPack_4.2_Linux’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_OPENCV_HOST_COMP’ -v=‘3.3.1’ -l=’/home/feng/nvidia/nvidia_sdk/JetPack_4.2_Linux’ -L=’/home/feng/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘13528’ -t=‘host’ -e=’/home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb’ > terminated with error
11:13:33 INFO : Start to install ‘OpenCV on Host’
11:13:33 DEBUG : OpenCV on Host : running command < cd ‘/home/feng/nvidia/nvidia_sdk/JetPack_4.2_Linux’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘eyJpZCI6Ik5WX09QRU5DVl9IT1NUX0NPTVAiLCJuYW1lIjoiT3BlbkNWIG9uIEhvc3QiLCJkZXNjcmlwdGlvbiI6Ik9wZW5DViBmb3IgSG9zdCIsImNvbXBUeXBlIjoiaG9zdCIsImlzVmlzaWJsZSI6dHJ1ZSwibGljZW5zZUlkIjoiTlZfSkVUUEFDS19WSVNJT05XT1JLU19PUEVOQ1ZfRVVMQSIsImlzRGV0ZWN0YWJsZUluc3RhbGwiOnRydWUsImlzSW5zdGFsbFBhdGhDdXN0b21pemFibGUiOmZhbHNlLCJ2ZXJzaW9uIjoiMy4zLjEiLCJvcGVyYXRpbmdTeXN0ZW1zIjpbInVidW50dTE2MDQiXSwiaW5zdGFsbFNpemVNQiI6MTU4LCJkb3dubG9hZEZpbGVzIjpbeyJ1cmwiOiJ1YnVudHUxNjA0L2xpYm9wZW5jdl8zLjMuMS0yLWdkNmE4OTE2X2FtZDY0LmRlYiIsImZpbGVOYW1lIjoibGlib3BlbmN2XzMuMy4xLTItZ2Q2YTg5MTZfYW1kNjQuZGViIiwic2l6ZSI6Mjc4MDMwNzgsImNoZWNrc3VtIjoiMDgyZTFhOGI5NTUyNTRmZGNlNTY0MTU2NDczZGY3ZjYiLCJjaGVja3N1bVR5cGUiOiJtZDUiLCJpbnN0YWxsUGFyYW1ldGVycyI6eyJpbnN0YWxsVHlwZSI6ImRlYiIsImFkZGl0aW9uYWxQYXJhbWV0ZXJzIjp7InBhY2thZ2VzSW5mbyI6W3sibmFtZSI6ImxpYm9wZW5jdiIsInZlcnNpb24iOiIzLjMuMSJ9XSwicHJlSW5zdGFsbENvbW1hbmRzIjpbeyJ1c2VyQ29tbWFuZCI6InN1ZG8gYXB0LWdldCBpbnN0YWxsIC15IGxpYnRiYi1kZXYifV19fSwiY2FjaGVkVXJsIjoiaHR0cHM6Ly9kZXZlbG9wZXIubnZpZGlhLmNvbS9hc3NldHMvZW1iZWRkZWQvc2VjdXJlL3Rvb2xzL2ZpbGVzL2pldHBhY2stc2Rrcy9qZXRwYWNrLTQuMi9KRVRQQUNLXzQyX2IxNTgvdWJ1bnR1MTYwNC9saWJvcGVuY3ZfMy4zLjEtMi1nZDZhODkxNl9hbWQ2NC5kZWIifSx7InVybCI6InVidW50dTE2MDQvbGlib3BlbmN2LWRldl8zLjMuMS0yLWdkNmE4OTE2X2FtZDY0LmRlYiIsImZpbGVOYW1lIjoibGlib3BlbmN2LWRldl8zLjMuMS0yLWdkNmE4OTE2X2FtZDY0LmRlYiIsInNpemUiOjExNDEyOTYsImNoZWNrc3VtIjoiNTQ3Y2VlYjBiMjUyNGI4YmVkZGE3MjFiZWFlNjA3NGIiLCJjaGVja3N1bVR5cGUiOiJtZDUiLCJpbnN0YWxsUGFyYW1ldGVycyI6eyJpbnN0YWxsVHlwZSI6ImRlYiIsImFkZGl0aW9uYWxQYXJhbWV0ZXJzIjp7InBhY2thZ2VzSW5mbyI6W3sibmFtZSI6ImxpYm9wZW5jdi1kZXYiLCJ2ZXJzaW9uIjoiMy4zLjEifV19fSwiY2FjaGVkVXJsIjoiaHR0cHM6Ly9kZXZlbG9wZXIubnZpZGlhLmNvbS9hc3NldHMvZW1iZWRkZWQvc2VjdXJlL3Rvb2xzL2ZpbGVzL2pldHBhY2stc2Rrcy9qZXRwYWNrLTQuMi9KRVRQQUNLXzQyX2IxNTgvdWJ1bnR1MTYwNC9saWJvcGVuY3YtZGV2XzMuMy4xLTItZ2Q2YTg5MTZfYW1kNjQuZGViIn0seyJ1cmwiOiJ1YnVudHUxNjA0L2xpYm9wZW5jdi1weXRob25fMy4zLjEtMi1nZDZhODkxNl9hbWQ2NC5kZWIiLCJmaWxlTmFtZSI6ImxpYm9wZW5jdi1weXRob25fMy4zLjEtMi1nZDZhODkxNl9hbWQ2NC5kZWIiLCJzaXplIjoxNzIxNzU0LCJjaGVja3N1bSI6IjVjMzJlYjJlNmY2MTAyMmY0YzgyYWY3ZmI0MTkxYTViIiwiY2hlY2tzdW1UeXBlIjoibWQ1IiwiaW5zdGFsbFBhcmFtZXRlcnMiOnsiaW5zdGFsbFR5cGUiOiJkZWIiLCJhZGRpdGlvbmFsUGFyYW1ldGVycyI6eyJwYWNrYWdlc0luZm8iOlt7Im5hbWUiOiJsaWJvcGVuY3YtcHl0aG9uIiwidmVyc2lvbiI6IjMuMy4xIn1dfX0sImNhY2hlZFVybCI6Imh0dHBzOi8vZGV2ZWxvcGVyLm52aWRpYS5jb20vYXNzZXRzL2VtYmVkZGVkL3NlY3VyZS90b29scy9maWxlcy9qZXRwYWNrLXNka3MvamV0cGFjay00LjIvSkVUUEFDS180Ml9iMTU4L3VidW50dTE2MDQvbGlib3BlbmN2LXB5dGhvbl8zLjMuMS0yLWdkNmE4OTE2X2FtZDY0LmRlYiJ9LHsidXJsIjoidWJ1bnR1MTYwNC9saWJvcGVuY3Ytc2FtcGxlc18zLjMuMS0yLWdkNmE4OTE2X2FtZDY0LmRlYiIsImZpbGVOYW1lIjoibGlib3BlbmN2LXNhbXBsZXNfMy4zLjEtMi1nZDZhODkxNl9hbWQ2NC5kZWIiLCJzaXplIjoxODIxNjgsImNoZWNrc3VtIjoiZTBkYjdkZWJjMTMwYjA2YzcwOTljOGEyNDk3YzNiYzEiLCJjaGVja3N1bVR5cGUiOiJtZDUiLCJpbnN0YWxsUGFyYW1ldGVycyI6eyJpbnN0YWxsVHlwZSI6ImRlYiIsImFkZGl0aW9uYWxQYXJhbWV0ZXJzIjp7InBhY2thZ2VzSW5mbyI6W3sibmFtZSI6ImxpYm9wZW5jdi1zYW1wbGVzIiwidmVyc2lvbiI6IjMuMy4xIn1dfX0sImNhY2hlZFVybCI6Imh0dHBzOi8vZGV2ZWxvcGVyLm52aWRpYS5jb20vYXNzZXRzL2VtYmVkZGVkL3NlY3VyZS90b29scy9maWxlcy9qZXRwYWNrLXNka3MvamV0cGFjay00LjIvSkVUUEFDS180Ml9iMTU4L3VidW50dTE2MDQvbGlib3BlbmN2LXNhbXBsZXNfMy4zLjEtMi1nZDZhODkxNl9hbWQ2NC5kZWIifV0sInRhcmdldElkcyI6WyJQMzMxMCIsIlAzNDg5LTAwMDAiLCJQMjg4OCIsIlAzNDQ4LTAwMDAiXSwiZGVwZW5kZW5jaWVzIjpbeyJpZCI6Ik5WX0NVREFfSE9TVF9DT01QIiwib3BlcmF0b3IiOiI9PSIsInZlciI6IjEwLjAiLCJfaWQiOiJOVl9DVURBX0hPU1RfQ09NUEBob3N0In1dLCJleHRlcm5hbF9kZXBlbmRlbmNpZXMiOltdLCJ0YXJnZXRJRCI6Imhvc3QiLCJfaWQiOiJOVl9PUEVOQ1ZfSE9TVF9DT01QQGhvc3QiLCJwYXJlbnRJRCI6Ik5WX0NPTVBVVEVSVklTSU9OX0hPU1RfR1JPVVAiLCJfcGFyZW50SUQiOiJOVl9DT01QVVRFUlZJU0lPTl9IT1NUX0dST1VQQGhvc3QiLCJpbnN0YWxsUGF0aCI6Ii9ob21lL2ZlbmcvbnZpZGlhL252aWRpYV9zZGsvSmV0UGFja180LjJfTGludXgiLCJpbnN0YWxsU3RhdHVzIjoibm9uZSIsImFjdGlvbiI6MSwiZG93bmxvYWRFcnJvcnMiOltdLCJ2ZXJpZnkiOmZhbHNlLCJleGVjIjoiL2hvbWUvZmVuZy9Eb3dubG9hZHMvbnZpZGlhL3Nka21fZG93bmxvYWRzL2xpYm9wZW5jdi1kZXZfMy4zLjEtMi1nZDZhODkxNl9hbWQ2NC5kZWIiLCJidW5kbGVUaXRsZSI6IkpldFBhY2tfNC4yX0xpbnV4IiwiaW5zdGFsbFJvb3QiOiIvaG9tZS9mZW5nL252aWRpYS9udmlkaWFfc2RrIiwiYm9hcmRJRCI6IiIsInRhcmdldEFjY2Vzc0luZm8iOnsidXNlciI6Im52aWRpYSIsInBhc3N3b3JkIjoibnZpZGlhIiwiaG9zdCI6IjE5Mi4xNjguNTUuMSIsInBvcnQiOiIyMiJ9LCJpc0RyeVJ1biI6ZmFsc2UsInRpbWVvdXRDQiI6bnVsbH0=’ -i=‘NV_OPENCV_HOST_COMP’ -v=‘3.3.1’ -l=’/home/feng/nvidia/nvidia_sdk/JetPack_4.2_Linux’ -L=’/home/feng/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘13528’ -t=‘host’ -e=’/home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb’ >
11:13:34 INFO : OpenCV on Host : [ Disk Avail:319.27 GB ]
11:13:34 INFO : OpenCV on Host : Using GenericInstaller to Install NV_OPENCV_HOST_COMP
11:13:34 INFO : OpenCV on Host : NV_OPENCV_HOST_COMP include 4 package
11:13:34 INFO : OpenCV on Host : [ Package PreInstall Started ]
11:13:34 INFO : OpenCV on Host : current working directory is /home/feng/nvidia/nvidia_sdk/JetPack_4.2_Linux
11:13:34 INFO : OpenCV on Host : exec_command: sudo apt-get install -y libtbb-dev
11:13:34 INFO : OpenCV on Host : Reading package lists…
11:13:34 INFO : OpenCV on Host : Building dependency tree…
11:13:34 INFO : OpenCV on Host : Reading state information…
11:13:34 INFO : OpenCV on Host : libtbb-dev is already the newest version (4.4~20151115-0ubuntu3).
11:13:34 INFO : OpenCV on Host : 0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
11:13:34 INFO : OpenCV on Host : [ Package PreInstall Finished Successfully ]
11:13:34 INFO : OpenCV on Host : [ Package Install Started ]
11:13:34 INFO : OpenCV on Host : deb installer start to install
11:13:34 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gd6a8916_amd64.deb Package | tr -d ’
11:13:34 INFO : OpenCV on Host : ’
11:13:34 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gd6a8916_amd64.deb Version | tr -d ’
11:13:34 INFO : OpenCV on Host : deb file /home/feng/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gd6a8916_amd64.deb, package name [libopencv], package version [3.3.1-2-gd6a8916]
11:13:34 INFO : OpenCV on Host : infer package info from file name libopencv_3.3.1-2-gd6a8916_amd64.deb [ name: libopencv, version: 3.3.1-2-gd6a8916 ]
11:13:34 INFO : OpenCV on Host : (Reading database … 431409 files and directories currently installed.)
11:13:34 INFO : OpenCV on Host : Preparing to unpack …/libopencv_3.3.1-2-gd6a8916_amd64.deb …
11:13:34 INFO : OpenCV on Host : Unpacking libopencv (3.3.1-2-gd6a8916) over (3.3.1-2-gd6a8916) …
11:13:35 INFO : OpenCV on Host : Setting up libopencv (3.3.1-2-gd6a8916) …
11:13:35 INFO : OpenCV on Host : Processing triggers for libc-bin (2.23-0ubuntu11) …
11:13:35 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=’{db:Status-abbrev} {Version}’ libopencv
11:13:35 INFO : OpenCV on Host : NV_OPENCV_HOST_COMP libopencv_3.3.1-2-gd6a8916_amd64.deb installed successfully.
11:13:35 INFO : OpenCV on Host : [ Package Install Finished Successfully ]
11:13:35 INFO : OpenCV on Host : [ Package Install Started ]
11:13:35 INFO : OpenCV on Host : deb installer start to install
11:13:35 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Package | tr -d ’
11:13:35 INFO : OpenCV on Host : ’
11:13:35 INFO : OpenCV on Host : exec_command: dpkg -f /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Version | tr -d ’
11:13:35 INFO : OpenCV on Host : deb file /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb, package name [libopencv-dev], package version [3.3.1-2-gd6a8916]
11:13:35 INFO : OpenCV on Host : infer package info from file name libopencv-dev_3.3.1-2-gd6a8916_amd64.deb [ name: libopencv-dev, version: 3.3.1-2-gd6a8916 ]
11:13:35 ERROR : OpenCV on Host : dpkg: considering removing libopencv-calib3d-dev:amd64 in favour of libopencv-dev …
11:13:35 INFO : OpenCV on Host : dpkg: no, cannot proceed with removal of libopencv-calib3d-dev:amd64 (–auto-deconfigure will help):
11:13:35 INFO : OpenCV on Host : libopencv-contrib-dev:amd64 depends on libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
11:13:35 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 is to be removed.
11:13:35 INFO : OpenCV on Host : dpkg: regarding …/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb containing libopencv-dev:
11:13:35 INFO : OpenCV on Host : libopencv-dev conflicts with libopencv-calib3d-dev
11:13:35 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 (version 2.4.9.1+dfsg-1.5ubuntu1.1) is present and installed.
11:13:35 INFO : OpenCV on Host : dpkg: error processing archive /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb (–install):
11:13:35 INFO : OpenCV on Host : conflicting packages - not installing libopencv-dev
11:13:35 ERROR : OpenCV on Host : Errors were encountered while processing:
11:13:35 INFO : OpenCV on Host : /home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb
11:13:35 INFO : OpenCV on Host : Reading package lists…
11:13:36 INFO : OpenCV on Host : Building dependency tree…
11:13:36 INFO : OpenCV on Host : Reading state information…
11:13:36 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=’{db:Status-abbrev} {Version}’ libopencv-dev
11:13:36 INFO : OpenCV on Host : [ Package Install Finished with Error ]
11:13:36 ERROR : OpenCV on Host : NV_OPENCV_HOST_COMP package [{libopencv-dev 3.3.1}] not installed
11:13:36 INFO : OpenCV on Host : [ 20.00 KB used. Disk Avail: 319.27 GB ]
11:13:36 INFO : OpenCV on Host : [ NV_OPENCV_HOST_COMP Install took 2s ]
11:13:36 INFO : OpenCV on Host : package [{libopencv-dev 3.3.1}] not installed
11:13:36 ERROR : OpenCV on Host : command terminated with error
11:13:36 ERROR : install ‘OpenCV on Host’ failure, command < cd ‘/home/feng/nvidia/nvidia_sdk/JetPack_4.2_Linux’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_OPENCV_HOST_COMP’ -v=‘3.3.1’ -l=’/home/feng/nvidia/nvidia_sdk/JetPack_4.2_Linux’ -L=’/home/feng/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘13528’ -t=‘host’ -e=’/home/feng/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb’ > terminated with error
11:13:36 ERROR : Unavailable components detected, please check log
11:13:36 ERROR : VisionWorks on Host Skipped. Due to its dependencies fail to install: OpenCV on Host,
11:13:36 ERROR : File System and OS Skipped. Due to its dependencies fail to install: Drivers for Jetson AGX,
11:13:36 ERROR : Flash skipped due to component(s) download/install failure
Hi dqpijsj,
Please refer to this similar issue:
https://devtalk.nvidia.com/default/topic/1056381/jetson-agx-xavier/jetpack-4-2-xavier-install-failed/post/5356095
