JetPack 4.2 — L4T R32.1 release for Jetson AGX Xavier, Jetson TX2, and Jetson Nano
NVIDIA has released JetPack 4.2 and L4T R32.1, including support for the new Jetson Nano Developer Kit.
Jetson Nano Developer Kit users can simply download this SD card image and follow the steps in the Getting Started with Jetson Nano guide.
Optionally, the new NVIDIA SDK Manager can be used to install JetPack 4.2, including developer tools with support for cross-compilation.
For more information, please refer to the JetPack Release Notes and L4T Release Notes.
JetPack 4.2 components:
  • L4T R32.1 (K4.9)
  • Ubuntu 18.04 LTS aarch64
  • CUDA 10.0
  • cuDNN 7.3.1
  • TensorRT 5.0.6
  • VisionWorks 1.6
  • OpenCV 3.3.1
Download JetPack…https://developer.nvidia.com/embedded/jetpack
Release Notes…https://developer.nvidia.com/embedded/jetpack-notes
L4T Release Notes…https://developer.nvidia.com/embedded/dlc/l4t-release-notes-32-1
L4T R32.1 Page…https://developer.nvidia.com/embedded/linux-tegra
Hi,how to download 4.2 ? The web shows it still is 4.1.1
Hi zidoumeng,
JetPack4.2 is ready now, please use the new NVIDIA SDK Manager to install JetPack.
Hi kayccc,
I plan to flash jetson tx2, just installed the SDK manager and logined, but it shows me that there’s no any sdk for me.
This is the information showed to me:
OOPS!
No SDKs are available for your account
Verify that your NVIDIA account is registered to the correct development program on developer.nvidia.com.
RETRY
Thanks in advance.
Problem fixed.
I registered a new account which worked for me. But I don’t know why the previous account doesn’t have the privilege to access jetson sdk.
Sorry for the spam.
Got the same problem when started SDKManager
OOPS!
RETRY
Register a new account, but the sdkmanager is always trying to log in using the old account ID and password. How to change the entries, or uninstall?
Hi ,installed SDKmanager & all terms,when flash TX2 ,there are errors :
Flash Jetson tx2Lcommand terminated witn error .
i tried three times.and couldnot find any help from sdk document.
Hi zidoumeng, please post a new topic about this on the Jetson TX2 forum along with the error log, please.
Hi tmx3, can you say what program IDs are listed in the “user-name menu item” → “membership programs” dialog?
We are currently working to resolve a potential issue with our China CDN that may be affecting the login, so please hold tight.
The new sdkmanager looks amazing! Way better looking than the original jetpack!
NVIDIA DEVELOPER PROGRAME with ID 874688. Thanks for your quick efforts to solve this problem!
Hi 93339475, we have received reports that the issue should be fixed now for China users, other users in the region have been able to use SDK Manager now. Can you try again and see if the issue is resolved? If not, please let us know. Thanks!
Hi there
Apologies if im not in the correct forum, if im not please take me out of this forum and place me in the correct forum.
Im new to single board computers and still learning.
I know SBC’s require an “image” to load at startup / when turned on.
My reason for buying a SBC is to play console, arcade games, watch utube, netflics, listen to mp3’s and browse the internet.
Are there any images available for Jetson Nano that will allow me to do this?
From what i understand the emulators for playing roms are integrated in the image but can be updated when new versions are released.
KODI has to be installed after the image have been installed from what i understand.
I appreciate any information,
Thank you for reading.
The default for the Jetson Nano is Linux (specifically, Ubuntu 18.04). Most of the software which can be downloaded from official Ubuntu servers will run on the Nano, although not all. Some software available only as a binary package or only for a desktop PC architecture won’t run on a Nano without porting to the arm64/aarch64/ARMv8-a architecture.
Kodi should work, but I haven’t tried it. I’ve seen it work in the past on other Jetsons. You might find emulators problematic because the emulator itself would have to work on this architecture, but I think most emulators run on a desktop PC architecture.
You can probably watch many movies and videos, especially youtube. I don’t know if Netflix or some of the other things you list might require something the Jetson lacks. Basically I suspect you just need to try it and find out since many different media use different CODECs even if the file name format is the same.
Hello I’m trying to install but I got errors
firs my host machine already have cuda cuDnn because I Have another GPU.
When I’m installing in the host I get an error in Cuda and Opencv
CUDA Cross Compile Package on Host : cuda-cross-aarch64-10-0 : Depends: cuda-toolkit-10-0 (>= 10.0.166) but 10.0.130-1 is to be installed
16:35:46 ERROR : CUDA Cross Compile Package on Host : E: Unable to correct problems, you have held broken packages.
16:35:46 INFO : CUDA Cross Compile Package on Host : exit status 100
16:35:46 INFO : CUDA Cross Compile Package on Host : [ Package Install Finished with Error ]
16:35:46 ERROR : CUDA Cross Compile Package on Host : NV_CUDA_HOST_CROSS_COMP apt install failed
16:35:46 INFO : CUDA Cross Compile Package on Host : [ 24.00 KB used. Disk Avail: 99.74 GB ]
16:35:46 INFO : CUDA Cross Compile Package on Host : [ NV_CUDA_HOST_CROSS_COMP Install took 16s ]
16:35:46 INFO : CUDA Cross Compile Package on Host : apt install failed
16:35:46 ERROR : CUDA Cross Compile Package on Host : command terminated with error
16:35:46 ERROR : CUDA Cross Compile Package on Host : install 'CUDA Cross Compile Package on Host' failure, command < cd '/home/diego/nvidia/nvidia_sdk/JetPack_4.2_Linux' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_CUDA_HOST_CROSS_COMP' -v='10.0' -l='/home/diego/nvidia/nvidia_sdk/JetPack_4.2_Linux' -L='/home/diego/.nvsdkm/logs/JetPack_4.2_Linux' -p='1980' -t='P3310' -e='/home/diego/Downloads/nvidia/sdkm_downloads/cuda-repo-cross-aarch64-10-0-local-10.0.166_1.0-1_all.deb' > terminated with error
opencv
ERROR : OpenCV on Host : /sbin/ldconfig.real:
16:32:58 ERROR : OpenCV on Host : /usr/local/cuda-10.0/targets/x86_64-linux/lib/libcudnn.so.6 is not a symbolic link
16:32:59 INFO : OpenCV on Host : exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' libopencv
16:32:59 INFO : OpenCV on Host : NV_OPENCV_HOST_COMP libopencv_3.3.1-2-gd6a8916_amd64.deb installed successfully.
16:32:59 INFO : OpenCV on Host : [ Package Install Finished Successfully ]
16:32:59 INFO : OpenCV on Host : [ Package Install Started ]
16:32:59 INFO : OpenCV on Host : deb installer start to install
16:32:59 INFO : OpenCV on Host : exec_command: dpkg -f /home/diego/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Package | tr -d '
16:32:59 INFO : OpenCV on Host : '
16:32:59 INFO : OpenCV on Host : exec_command: dpkg -f /home/diego/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Version | tr -d '
16:32:59 INFO : OpenCV on Host : deb file /home/diego/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb, package name [libopencv-dev], package version [3.3.1-2-gd6a8916]
16:32:59 INFO : OpenCV on Host : infer package info from file name libopencv-dev_3.3.1-2-gd6a8916_amd64.deb [ name: libopencv-dev, version: 3.3.1-2-gd6a8916 ]
16:32:59 INFO : OpenCV on Host : exec_command: sudo dpkg -i /home/diego/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb
16:32:59 ERROR : OpenCV on Host : dpkg: considering removing libopencv-calib3d-dev:amd64 in favour of libopencv-dev ...
16:32:59 ERROR : OpenCV on Host : dpkg: no, cannot proceed with removal of libopencv-calib3d-dev:amd64 (--auto-deconfigure will help):
16:32:59 INFO : OpenCV on Host : libopencv-contrib-dev:amd64 depends on libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
16:32:59 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 is to be removed.
16:32:59 ERROR : OpenCV on Host : dpkg: regarding .../libopencv-dev_3.3.1-2-gd6a8916_amd64.deb containing libopencv-dev:
16:32:59 INFO : OpenCV on Host : libopencv-dev conflicts with libopencv-calib3d-dev
16:32:59 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 (version 2.4.9.1+dfsg-1.5ubuntu1.1) is present and installed.
16:32:59 ERROR : OpenCV on Host : dpkg: error processing archive /home/diego/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb (--install):
16:32:59 INFO : OpenCV on Host : conflicting packages - not installing libopencv-dev
16:32:59 ERROR : OpenCV on Host : Errors were encountered while processing:
16:32:59 ERROR : OpenCV on Host : /home/diego/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb
16:32:59 INFO : OpenCV on Host : exit status 1
16:32:59 INFO : OpenCV on Host : exec_command: sudo apt-get check
16:33:01 INFO : OpenCV on Host : Reading package lists...
16:33:01 INFO : OpenCV on Host : Building dependency tree...
16:33:01 INFO : OpenCV on Host : Reading state information...
16:33:01 INFO : OpenCV on Host : exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' libopencv-dev
16:33:01 INFO : OpenCV on Host : [ Package Install Finished with Error ]
16:33:01 ERROR : OpenCV on Host : NV_OPENCV_HOST_COMP package [{libopencv-dev 3.3.1}] not installed
16:33:01 INFO : OpenCV on Host : [ 115.26 MB used. Disk Avail: 101.30 GB ]
16:33:01 INFO : OpenCV on Host : [ NV_OPENCV_HOST_COMP Install took 11s ]
16:33:01 INFO : OpenCV on Host : package [{libopencv-dev 3.3.1}] not installed
16:33:01 ERROR : OpenCV on Host : command terminated with error
16:33:01 ERROR : OpenCV on Host : install 'OpenCV on Host' failure, command < cd '/home/diego/nvidia/nvidia_sdk/JetPack_4.2_Linux' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_OPENCV_HOST_COMP' -v='3.3.1' -l='/home/diego/nvidia/nvidia_sdk/JetPack_4.2_Linux' -L='/home/diego/.nvsdkm/logs/JetPack_4.2_Linux' -p='1980' -t='P3310' -e='/home/diego/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb' > terminated with error
after that, the Jetson tx2 turning on and the installation stuck in 50%
Hi alberto, can you re-post your issue to a new topic in the Jetson TX2 forum? Thanks.
Hi hello
can you please stress upon the “Added support for more USB wireless adapters” in jetpack 4.2
what all USB adapters are supported ??
is edimax-7811Un USB adapter a plug and play one pls elaborate??
Hi
I have flashed my TX2i withe the new Jetpack , worked good.
And then i needed to go back to use Jetpack 3.2.1 but the flashing process has stack and now i can not flash the TX2i withe the old Jetpacke where i have all my configurations.
see terminal plot:
~/jetpack/64_TX2/Linux_for_Tegra$ sudo ./flash.sh jetson-tx2i mmcblk0p1
# L4T BSP Information:
# R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64,
# DATE: Thu May 17 07:29:06 UTC 2018
# Target Board Information:
# Name: jetson-tx2i, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x18 --applet "/home/nvidia/jetpack/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.2030 ] Generating RCM messages
[   0.2414 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/nvidia/jetpack/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[   0.2801 ] RCM 0 is saved as rcm_0.rcm
[   0.2961 ] RCM 1 is saved as rcm_1.rcm
[   0.2961 ] List of rcm files are saved in rcm_list.xml
[   0.2961 ]
[   0.2962 ] Signing RCM messages
[   0.3401 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.3637 ] Assuming zero filled SBK key
[   0.3695 ]
[   0.3696 ] Copying signature to RCM mesages
[   0.3718 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[   0.3742 ]
[   0.3743 ] Boot Rom communication
[   0.3756 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[   0.3770 ] RCM version 0X180001
[   0.3882 ] Boot Rom communication completed
[   2.6823 ]
[   2.6860 ] tegrarcm_v2 --isapplet
[   2.7021 ] USB communication failed.Check if device is in recovery
[   3.9457 ]
[   3.9610 ] tegradevflash_v2 --iscpubl
[   3.9640 ] CPU Bootloader is not running on device.
[   3.9695 ]
[   4.9959 ] Retrieving EEPROM data
[   4.9962 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nvidia/jetpack/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
[   4.9975 ] Applet version 01.00.0000
[   5.1148 ]
[   5.1164 ] tegradevflash_v2 --oem platformdetails eeprom cvm /home/nvidia/jetpack/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
the flashing process stacks on the last line.
Is there a way to make it work back withe Jetpack 3.2.1 ?
Hi Roman, can you post this as a new topic on the Jetson TX2 forum? Thanks.
PLease Help me
