Install Jetpack 4.2 to Jetson TX2
While I am downloading JetPack 4.2 onto Jetson TX 2 with SDK Manager. The Jetson OS fails to download each time with error
14:56:54 INFO : *** Retrying to install. attempt number: 4
14:56:54 DEBUG : running command < sudo rm -rf '/home/attfoundry/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' >
14:56:54 INFO : command finished successfully
14:56:54 INFO : CUDA on Host : download 'CUDA on Host' success
14:56:54 INFO : OpenCV on Host : download 'OpenCV on Host' success
14:56:54 INFO : NVIDIA Nsight Graphics : download 'NVIDIA Nsight Graphics' success
14:56:54 INFO : NVIDIA Nsight Systems : download 'NVIDIA Nsight Systems' success
14:56:54 INFO : VisionWorks on Host : download 'VisionWorks on Host' success
14:56:54 INFO : DevTools Documentation : download 'DevTools Documentation' success
14:56:54 INFO : CUDA Cross Compile Package on Host : download 'CUDA Cross Compile Package on Host' success
14:56:54 INFO : install 'CUDA on Host' success
14:56:54 INFO : install 'OpenCV on Host' success
14:56:54 INFO : install 'NVIDIA Nsight Graphics' success
14:56:55 INFO : install 'NVIDIA Nsight Systems' success
14:56:55 INFO : install 'VisionWorks on Host' success
14:56:55 INFO : install 'DevTools Documentation' success
14:56:55 INFO : install 'CUDA Cross Compile Package on Host' success
14:56:55 INFO : OpenCV on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : OpenCV on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : OpenCV on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : OpenCV on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : cuDNN on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : download 'Drivers for Jetson TX2 & TX2i' success
14:56:55 INFO : Start to install 'Drivers for Jetson TX2 & TX2i'
14:56:55 DEBUG : Drivers for Jetson TX2 & TX2i : running command < cd '/home/attfoundry/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_DRIVERS_TX2_COMP' -v='32.1' -l='/home/attfoundry/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' -L='/home/attfoundry/.nvsdkm/logs/JetPack_4.2_Linux' -p='24406' -t='P3310' -e='/home/attfoundry/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.1.0_aarch64.tbz2' >
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : cuDNN on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : [ Disk Avail:6988.69 GB ]
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Using GenericInstaller to Install NV_L4T_DRIVERS_TX2_COMP
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : NV_L4T_DRIVERS_TX2_COMP include 1 package
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : change working directory to /home/attfoundry/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : [ Package Install Started ]
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : current working directory is /home/attfoundry/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : exec_command [host]:
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : **********************
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : #!/bin/bash
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : set -e
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : function safe_apt_install {
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : echo "*begin $1, $2"
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : tmp_log=/tmp/jetpack_dpkg_log.txt
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : sudo rm -f $tmp_log
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : while [ ${CMD_STATUS} -ne 0 ]; do
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : if grep -q -e "is locked by another process" -e "E: Could not get lock /var/lib" $tmp_log; then
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : echo "Waiting $2 seconds for apt to be available"; sleep ${2}
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : else
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : echo "Unhandled error when running $1"; exit 1
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : fi
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : done
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : }
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : sudo apt-get update || true; sudo apt-get install -y pigz lbzip2
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : tar xpf /home/attfoundry/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.1.0_aarch64.tbz2
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : exec_command: /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh
14:56:55 INFO : cuDNN on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:1 file:/var/cuda-repo-10-0-local-10.0.326-410.108 InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:1 file:/var/cuda-repo-10-0-local-10.0.326-410.108 InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:2 file:/var/cuda-repo-10-0-local-10.0.326-cross-aarch64 InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:2 file:/var/cuda-repo-10-0-local-10.0.326-cross-aarch64 InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:3 file:/var/visionworks-repo InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:3 file:/var/visionworks-repo InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:4 file:/var/visionworks-sfm-repo InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:4 file:/var/visionworks-sfm-repo InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:5 file:/var/visionworks-tracking-repo InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:5 file:/var/visionworks-tracking-repo InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:6 file:/var/cuda-repo-10-0-local-10.0.326-410.108 Release [574 B]
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:7 file:/var/cuda-repo-10-0-local-10.0.326-cross-aarch64 Release [574 B]
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:8 file:/var/visionworks-repo Release [1,999 B]
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:9 file:/var/visionworks-sfm-repo Release [2,003 B]
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Get:10 file:/var/visionworks-tracking-repo Release [2,008 B]
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:11 http://dl.google.com/linux/chrome/deb stable InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Hit:13 https://download.docker.com/linux/ubuntu bionic InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Hit:14 http://dl.google.com/linux/chrome/deb stable Release
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Hit:15 http://us.archive.ubuntu.com/ubuntu bionic InRelease
14:56:55 INFO : VisionWorks on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : VisionWorks on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : Multimedia API : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
14:56:55 INFO : VisionWorks on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Hit:17 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Hit:18 http://security.ubuntu.com/ubuntu bionic-security InRelease
14:56:55 INFO : Drivers for Jetson TX2 & TX2i : Hit:20 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
14:56:56 INFO : TensorRT on Target : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
14:56:56 INFO : CUDA Toolkit for L4T : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
14:56:57 INFO : File System and OS : Found file /home/attfoundry/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
14:56:57 INFO : File System and OS : download 'File System and OS' success
14:56:58 INFO : Drivers for Jetson TX2 & TX2i : Reading package lists...
14:56:58 INFO : Drivers for Jetson TX2 & TX2i : Building dependency tree...
14:56:58 INFO : Drivers for Jetson TX2 & TX2i : Reading state information...
14:56:58 INFO : Drivers for Jetson TX2 & TX2i : lbzip2 is already the newest version (2.5-2).
14:56:58 INFO : Drivers for Jetson TX2 & TX2i : pigz is already the newest version (2.4-1).
14:56:58 INFO : Drivers for Jetson TX2 & TX2i : 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
14:56:59 ERROR : Drivers for Jetson TX2 & TX2i :
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : bzip2: Data integrity error when decompressing.
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : Input file = (stdin), output file = (stdout)
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : It is possible that the compressed file(s) have become corrupted.
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : You can use the -tvv option to test integrity of such files.
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : You can use the `bzip2recover' program to attempt to recover
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : data from undamaged sections of corrupted files.
14:56:59 ERROR : Drivers for Jetson TX2 & TX2i : tar: Unexpected EOF in archive
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : tar: Unexpected EOF in archive
14:56:59 ERROR : Drivers for Jetson TX2 & TX2i : tar: Error is not recoverable: exiting now
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : exit status 2
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : [ Package Install Finished with Error ]
14:56:59 ERROR : Drivers for Jetson TX2 & TX2i : NV_L4T_DRIVERS_TX2_COMP command /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh finished with error
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : [ 3.46 MB used. Disk Avail: 6988.69 GB ]
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : [ NV_L4T_DRIVERS_TX2_COMP Install took 3s ]
14:56:59 INFO : Drivers for Jetson TX2 & TX2i : command /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh finished with error
14:56:59 ERROR : Drivers for Jetson TX2 & TX2i : command terminated with error
14:56:59 ERROR : install 'Drivers for Jetson TX2 & TX2i' failure, command < cd '/home/attfoundry/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_DRIVERS_TX2_COMP' -v='32.1' -l='/home/attfoundry/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310' -L='/home/attfoundry/.nvsdkm/logs/JetPack_4.2_Linux' -p='24406' -t='P3310' -e='/home/attfoundry/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.1.0_aarch64.tbz2' > terminated with error
14:56:59 ERROR : Unavailable components detected, please check log
14:56:59 ERROR : File System and OS Skipped. Due to its dependencies fail to install: Drivers for Jetson TX2 & TX2i,
14:56:59 ERROR : Flash skipped due to component(s) download/install failure
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
You probably ran into a recent Ubuntu bzip2 buggy update. See:
[url]Jetpack 4.2 Xavier Install Failed - Jetson AGX Xavier - NVIDIA Developer Forums
Works for me! Thank you!
