Im trying to setup my Jetson TX2
im runing the tool SDK Manager 0.9.11.34.3405 from my Ubuntu 18.04 machine
but ill get errors in step 04
has any1 an idea what im doing wrong?
my jetson is in recovery mode and i see it as an usb device on my host machine
this is the error log:
13:26:04 INFO : null
13:26:11 DEBUG : running command < sudo rm -rf /home/tc/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310 >
13:26:11 INFO : command finished successfully
13:26:11 INFO : OpenCV on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:26:11 INFO : OpenCV on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:26:11 INFO : OpenCV on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:26:11 INFO : OpenCV on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/Jetson_Linux_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : download ‘Drivers for Jetson TX2 & TX2i’ success
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Start to install ‘Drivers for Jetson TX2 & TX2i’
13:26:12 DEBUG : Drivers for Jetson TX2 & TX2i : running command < cd ‘/home/tc/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_DRIVERS_TX2_COMP’ -v=‘32.1’ -l=’/home/tc/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310’ -L=’/home/tc/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘30132’ -t=‘P3310’ -e=’/datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/Jetson_Linux_R32.1.0_aarch64.tbz2’ >
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : [ Disk Avail:7.05 GB ]
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Using GenericInstaller to Install NV_L4T_DRIVERS_TX2_COMP
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : NV_L4T_DRIVERS_TX2_COMP include 1 package
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : enter working directory: /home/tc/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : [ Package Install Started ]
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : current working directory is /home/tc/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : exec_command [host]:
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : **********************
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : #!/bin/bash
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : set -e
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : sudo apt-get update || true; sudo apt-get install -y pigz lbzip2
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : tar xpf /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/Jetson_Linux_R32.1.0_aarch64.tbz2
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : exec_command: /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh
13:26:12 INFO : cuDNN on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : cuDNN on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:1 file:/var/cuda-repo-10-0-local-10.0.166-410.62 InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Ign:1 file:/var/cuda-repo-10-0-local-10.0.166-410.62 InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:2 file:/var/nv-tensorrt-repo-cuda10.0-trt5.0.2.6-ga-20181009 InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Ign:2 file:/var/nv-tensorrt-repo-cuda10.0-trt5.0.2.6-ga-20181009 InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:3 file:/var/cuda-repo-10-0-local-10.0.166-410.62 Release [574 B]
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:4 file:/var/nv-tensorrt-repo-cuda10.0-trt5.0.2.6-ga-20181009 Release [574 B]
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:5 http://graphics.tuxedocomputers.com/ubuntu bionic InRelease
13:26:12 INFO : cuDNN on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:6 http://intel.tuxedocomputers.com/ubuntu bionic InRelease
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:8 http://deb.tuxedocomputers.com/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:9 http://repo.steampowered.com/steam precise InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:10 http://ppa.launchpad.net/ubuntu-mozilla-security/ppa/ubuntu bionic InRelease
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:11 http://deb.playonlinux.com stretch InRelease
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Ign:14 http://dl.google.com/linux/chrome/deb stable InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Ign:15 http://download.opensuse.org/repositories/home:/strycore/xUbuntu_18.04 ./ InRelease
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:16 http://ppa.launchpad.net/alexlarsson/flatpak/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:17 https://download.docker.com/linux/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:18 https://updates.signal.org/desktop/apt xenial InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:19 http://packages.microsoft.com/repos/vscode stable InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:13 http://security.ubuntu.com/ubuntu xenial-security InRelease [109 kB]
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:20 http://dl.google.com/linux/chrome/deb stable Release
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:21 http://download.opensuse.org/repositories/home:/strycore/xUbuntu_18.04 ./ Release [981 B]
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:24 http://ppa.launchpad.net/dawidd0811/neofetch/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:25 http://download.opensuse.org/repositories/home:/strycore/xUbuntu_18.04 ./ Release.gpg [481 B]
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:28 http://ppa.launchpad.net/fingerprint/fingerprint-gui/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:22 http://de.archive.ubuntu.com/ubuntu bionic InRelease [242 kB]
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:30 http://ppa.launchpad.net/fingerprint/fprint/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:31 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:32 http://ppa.launchpad.net/gregory-hainaut/pcsx2.official.ppa/ubuntu bionic InRelease
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Get:23 http://de.archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
13:26:12 INFO : Drivers for Jetson TX2 & TX2i : Hit:33 http://ppa.launchpad.net/inkscape.dev/stable/ubuntu bionic InRelease
13:26:12 INFO : TensorRT on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Get:26 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Ign:34 http://ppa.launchpad.net/kirillshkrogalev/ffmpeg-next/ubuntu bionic InRelease
13:26:13 INFO : VisionWorks on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
13:26:13 INFO : VisionWorks on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Get:27 http://de.archive.ubuntu.com/ubuntu bionic-proposed InRelease [242 kB]
13:26:13 INFO : CUDA Toolkit for L4T : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:35 http://ppa.launchpad.net/linuxgndu/sqlitebrowser/ubuntu bionic InRelease
13:26:13 INFO : VisionWorks on Target : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:36 http://ppa.launchpad.net/linuxuprising/java/ubuntu bionic InRelease
13:26:13 INFO : Multimedia API : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Get:29 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:38 http://ppa.launchpad.net/obsproject/obs-studio/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Ign:40 http://ppa.launchpad.net/octave/stable/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:41 http://ppa.launchpad.net/peterlevi/ppa/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Err:25 http://download.opensuse.org/repositories/home:/strycore/xUbuntu_18.04 ./ Release.gpg
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : The following signatures were invalid: EXPKEYSIG 2F7F0DA5FD5B64B9 home:strycore OBS Project
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:42 http://ppa.launchpad.net/pj-assis/ppa/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:37 https://packages.gitlab.com/gitlab/gitlab-ce/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:43 http://ppa.launchpad.net/scribus/ppa/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Get:44 http://security.ubuntu.com/ubuntu xenial-security/main i386 Packages [534 kB]
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Get:45 http://security.ubuntu.com/ubuntu xenial-security/main armhf Packages [468 kB]
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Ign:45 http://security.ubuntu.com/ubuntu xenial-security/main armhf Packages
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Ign:53 http://ppa.launchpad.net/shutter/ppa/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:54 http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic InRelease
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Err:45 http://security.ubuntu.com/ubuntu xenial-security/main armhf Packages
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : 404 Not Found [IP: 91.189.88.149 80]
13:26:13 INFO : Drivers for Jetson TX2 & TX2i : Hit:55 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Err:56 http://ppa.launchpad.net/kirillshkrogalev/ffmpeg-next/ubuntu bionic Release
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : 404 Not Found [IP: 91.189.95.83 80]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Err:57 http://ppa.launchpad.net/octave/stable/ubuntu bionic Release
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:58 http://de.archive.ubuntu.com/ubuntu bionic/restricted Sources [5,324 B]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:59 http://de.archive.ubuntu.com/ubuntu bionic/multiverse Sources [181 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:60 http://de.archive.ubuntu.com/ubuntu bionic/main Sources [829 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Err:61 http://ppa.launchpad.net/shutter/ppa/ubuntu bionic Release
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:62 http://de.archive.ubuntu.com/ubuntu bionic/universe Sources [9,051 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:63 http://de.archive.ubuntu.com/ubuntu bionic/main amd64 Packages [1,019 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:64 http://de.archive.ubuntu.com/ubuntu bionic/main i386 Packages [1,007 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:65 http://de.archive.ubuntu.com/ubuntu bionic/main armhf Packages [968 kB]
13:26:14 INFO : File System and OS : Found file /datadisk/htw/master_arbeit/hardware/software/setup_folder_manager/Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
13:26:14 INFO : File System and OS : download ‘File System and OS’ success
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:65 http://de.archive.ubuntu.com/ubuntu bionic/main armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:134 http://de.archive.ubuntu.com/ubuntu bionic/restricted armhf Packages [8,360 B]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:134 http://de.archive.ubuntu.com/ubuntu bionic/restricted armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:138 http://de.archive.ubuntu.com/ubuntu bionic/universe armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:139 http://de.archive.ubuntu.com/ubuntu bionic/multiverse armhf Packages [129 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:139 http://de.archive.ubuntu.com/ubuntu bionic/multiverse armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:147 http://de.archive.ubuntu.com/ubuntu bionic-security/main armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:148 http://de.archive.ubuntu.com/ubuntu bionic-security/restricted armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:149 http://de.archive.ubuntu.com/ubuntu bionic-security/universe armhf Packages [242 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:149 http://de.archive.ubuntu.com/ubuntu bionic-security/universe armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:182 http://de.archive.ubuntu.com/ubuntu bionic-security/multiverse armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:183 http://de.archive.ubuntu.com/ubuntu bionic-updates/main armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:184 http://de.archive.ubuntu.com/ubuntu bionic-updates/restricted armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:185 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:186 http://de.archive.ubuntu.com/ubuntu bionic-updates/multiverse armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:187 http://de.archive.ubuntu.com/ubuntu bionic-proposed/main armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:188 http://de.archive.ubuntu.com/ubuntu bionic-proposed/universe armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:138 http://de.archive.ubuntu.com/ubuntu bionic/universe armhf Packages [8,269 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Get:147 http://de.archive.ubuntu.com/ubuntu bionic-security/main armhf Packages [235 kB]
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:202 http://de.archive.ubuntu.com/ubuntu bionic-backports/main armhf Packages
13:26:14 INFO : Drivers for Jetson TX2 & TX2i : Ign:203 http://de.archive.ubuntu.com/ubuntu bionic-backports/universe armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:65 http://de.archive.ubuntu.com/ubuntu bionic/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:134 http://de.archive.ubuntu.com/ubuntu bionic/restricted armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:138 http://de.archive.ubuntu.com/ubuntu bionic/universe armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:139 http://de.archive.ubuntu.com/ubuntu bionic/multiverse armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:147 http://de.archive.ubuntu.com/ubuntu bionic-security/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:148 http://de.archive.ubuntu.com/ubuntu bionic-security/restricted armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:149 http://de.archive.ubuntu.com/ubuntu bionic-security/universe armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:182 http://de.archive.ubuntu.com/ubuntu bionic-security/multiverse armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:183 http://de.archive.ubuntu.com/ubuntu bionic-updates/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:184 http://de.archive.ubuntu.com/ubuntu bionic-updates/restricted armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:202 http://de.archive.ubuntu.com/ubuntu bionic-backports/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:203 http://de.archive.ubuntu.com/ubuntu bionic-backports/universe armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:185 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:186 http://de.archive.ubuntu.com/ubuntu bionic-updates/multiverse armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:187 http://de.archive.ubuntu.com/ubuntu bionic-proposed/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Ign:188 http://de.archive.ubuntu.com/ubuntu bionic-proposed/universe armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Err:65 http://de.archive.ubuntu.com/ubuntu bionic/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : 404 Not Found [IP: 141.30.62.24 80]
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Err:147 http://de.archive.ubuntu.com/ubuntu bionic-security/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Err:183 http://de.archive.ubuntu.com/ubuntu bionic-updates/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Err:187 http://de.archive.ubuntu.com/ubuntu bionic-proposed/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Err:202 http://de.archive.ubuntu.com/ubuntu bionic-backports/main armhf Packages
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : Reading package lists…
13:26:15 ERROR : Drivers for Jetson TX2 & TX2i : W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target Translations (main/i18n/Translation-en_US.UTF-8) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
13:26:15 INFO : Drivers for Jetson TX2 & TX2i : W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/google-chrome.list:3 and /etc/apt/sources.list.d/google.list:1
