Trying to install JetPack-L4T-3.2-linux-x64_b196 on host PC but wont install CUDA …. Please advise!
End of error message:
Ign:109 http://archive.ubuntu.com/ubuntu xenial-security/multiverse arm64 Packages
Fetched 570 kB in 8s (63.7 kB/s)
Reading package lists…
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
cuda-toolkit-9-0 : Depends: cuda-samples-9-0 (>= 9.0.252) but it is not going to be installed
Depends: cuda-documentation-9-0 (>= 9.0.252) but it is not going to be installed
Depends: cuda-visual-tools-9-0 (>= 9.0.252) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Get:1 file:/var/cuda-repo-9-0-local InRelease
Ign:1 file:/var/cuda-repo-9-0-local InRelease
Get:2 file:/var/cuda-repo-9-0-local Release [574 B]
Hit:4 http://ppa.launchpad.net/bladerf/bladerf/ubuntu xenial InRelease
Hit:8 http://ppa.launchpad.net/ettusresearch/uhd/ubuntu xenial InRelease
Hit:9 http://archive.canonical.com/ubuntu xenial InRelease
Hit:11 http://ppa.launchpad.net/gqrx/gqrx-sdr/ubuntu xenial InRelease
Get:5 http://archive.ubuntu.com/ubuntu xenial InRelease [247 kB]
Hit:12 http://ppa.launchpad.net/myriadrf/drivers/ubuntu xenial InRelease
Hit:13 http://ppa.launchpad.net/myriadrf/gnuradio/ubuntu xenial InRelease
Get:6 http://archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
Get:7 http://archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
Get:10 http://archive.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Get:14 http://archive.ubuntu.com/ubuntu xenial/multiverse Sources [179 kB]
Get:15 http://archive.ubuntu.com/ubuntu xenial/main Sources [868 kB]
Get:16 http://archive.ubuntu.com/ubuntu xenial/universe Sources [7,728 kB]
Get:17 http://archive.ubuntu.com/ubuntu xenial/restricted Sources [4,808 B]
Get:18 http://archive.ubuntu.com/ubuntu xenial/main amd64 Packages [1,201 kB]
Get:19 http://archive.ubuntu.com/ubuntu xenial/main i386 Packages [1,196 kB]
Ign:20 http://archive.ubuntu.com/ubuntu xenial/main arm64 Packages
Get:21 http://archive.ubuntu.com/ubuntu xenial/main Translation-en_GB [426 kB]
Get:22 http://archive.ubuntu.com/ubuntu xenial/main Translation-en [568 kB]
Get:23 http://archive.ubuntu.com/ubuntu xenial/main amd64 DEP-11 Metadata [733 kB]
Get:24 http://archive.ubuntu.com/ubuntu xenial/main DEP-11 64x64 Icons [409 kB]
Get:25 http://archive.ubuntu.com/ubuntu xenial/restricted amd64 Packages [8,344 B]
Get:26 http://archive.ubuntu.com/ubuntu xenial/restricted i386 Packages [8,684 B]
Get:27 http://archive.ubuntu.com/ubuntu xenial/restricted Translation-en_GB [2,556 B]
Get:28 http://archive.ubuntu.com/ubuntu xenial/restricted Translation-en [2,908 B]
Get:29 http://archive.ubuntu.com/ubuntu xenial/restricted amd64 DEP-11 Metadata [186 B]
Get:30 http://archive.ubuntu.com/ubuntu xenial/universe amd64 Packages [7,532 kB]
Get:31 http://archive.ubuntu.com/ubuntu xenial/universe i386 Packages [7,512 kB]
Ign:32 http://archive.ubuntu.com/ubuntu xenial/universe arm64 Packages
Get:33 http://archive.ubuntu.com/ubuntu xenial/universe Translation-en_GB [3,040 kB]
Get:34 http://archive.ubuntu.com/ubuntu xenial/universe Translation-en [4,354 kB]
Get:35 http://archive.ubuntu.com/ubuntu xenial/universe amd64 DEP-11 Metadata [3,410 kB]
Get:36 http://archive.ubuntu.com/ubuntu xenial/universe DEP-11 64x64 Icons [7,448 kB]
Get:37 http://archive.ubuntu.com/ubuntu xenial/multiverse amd64 Packages [144 kB]
Get:38 http://archive.ubuntu.com/ubuntu xenial/multiverse i386 Packages [140 kB]
Ign:39 http://archive.ubuntu.com/ubuntu xenial/multiverse arm64 Packages
Get:40 http://archive.ubuntu.com/ubuntu xenial/multiverse Translation-en_GB [88
1 kB]
Get:41 http://archive.ubuntu.com/ubuntu xenial/multiverse Translation-en [106 kB]
Get:42 http://archive.ubuntu.com/ubuntu xenial/multiverse amd64 DEP-11 Metadata [63.8 kB]
Get:43 http://archive.ubuntu.com/ubuntu xenial/multiverse DEP-11 64x64 Icons [230 kB]
Get:44 http://archive.ubuntu.com/ubuntu xenial-updates/multiverse Sources [8,404 B]
Get:45 http://archive.ubuntu.com/ubuntu xenial-updates/main Sources [305 kB]
Get:46 http://archive.ubuntu.com/ubuntu xenial-updates/universe Sources [203 kB]
Get:47 http://archive.ubuntu.com/ubuntu xenial-updates/restricted Sources [2,524 B]
Get:48 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages [775 kB]
Get:49 http://archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages [713 kB]
Ign:50 http://archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
Get:51 http://archive.ubuntu.com/ubuntu xenial-updates/main Translation-en [321 kB]
Get:52 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 DEP-11 Metadata [319 kB]
Get:53 http://archive.ubuntu.com/ubuntu xenial-updates/main DEP-11 64x64 Icons [224 kB]
Get:54 http://archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 Packages [7,560 B]
Get:55 http://archive.ubuntu.com/ubuntu xenial-updates/restricted i386 Packages [7,524 B]
Get:56 http://archive.ubuntu.com/ubuntu xenial-updates/restricted Translation-en [2,272 B]
Get:57 http://archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 DEP-11 Metadata [157 B]
Get:58 http://archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages [627 kB]
Get:59 http://archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [577 kB]
Ign:60 http://archive.ubuntu.com/ubuntu xenial-updates/universe arm64 Packages
Get:61 http://archive.ubuntu.com/ubuntu xenial-updates/universe Translation-en [252 kB]
Get:62 http://archive.ubuntu.com/ubuntu xenial-updates/universe amd64 DEP-11 Metadata [246 kB]
Get:63 http://archive.ubuntu.com/ubuntu xenial-updates/universe DEP-11 64x64 Icons [331 kB]
Get:64 http://archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 Packages [16.4 kB]
Get:65 http://archive.ubuntu.com/ubuntu xenial-updates/multiverse i386 Packages [15.5 kB]
Ign:66 http://archive.ubuntu.com/ubuntu xenial-updates/multiverse arm64 Packages
Get:67 http://archive.ubuntu.com/ubuntu xenial-updates/multiverse Translation-en [8,344 B]
Get:68 http://archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata [5,964 B]
Get:69 http://archive.ubuntu.com/ubuntu xenial-updates/multiverse DEP-11 64x64 Icons [14.3 kB]
Get:70 http://archive.ubuntu.com/ubuntu xenial-backports/main Sources [3,436 B]
Get:71 http://archive.ubuntu.com/ubuntu xenial-backports/universe Sources [5,820 B]
Get:72 http://archive.ubuntu.com/ubuntu xenial-backports/main amd64 Packages [4,844 B]
Get:73 http://archive.ubuntu.com/ubuntu xenial-backports/main i386 Packages [4,836 B]
Ign:74 http://archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
Get:75 http://archive.ubuntu.com/ubuntu xenial-backports/main Translation-en [3,220 B]
Get:76 http://archive.ubuntu.com/ubuntu xenial-backports/main amd64 DEP-11 Metadata [3,324 B]
Get:77 http://archive.ubuntu.com/ubuntu xenial-backports/main DEP-11 64x64 Icons [29 B]
Get:78 http://archive.ubuntu.com/ubuntu xenial-backports/restricted amd64 DEP-11 Metadata [194 B]
Get:79 http://archive.ubuntu.com/ubuntu xenial-backports/universe amd64 Packages [7,400 B]
Get:80 http://archive.ubuntu.com/ubuntu xenial-backports/universe i386 Packages [7,080 B]
Ign:81 http://archive.ubuntu.com/ubuntu xenial-backports/universe arm64 Packages
Get:82 http://archive.ubuntu.com/ubuntu xenial-backports/universe Translation-en [3,996 B]
Get:83 http://archive.ubuntu.com/ubuntu xenial-backports/universe amd64 DEP-11 Metadata [5,084 B]
Get:84 http://archive.ubuntu.com/ubuntu xenial-backports/universe DEP-11 64x64 Icons [2,717 B]
Get:85 http://archive.ubuntu.com/ubuntu xenial-backports/multiverse amd64 DEP-11 Metadata [216 B]
Get:86 http://archive.ubuntu.com/ubuntu xenial-backports/multiverse DEP-11 64x64 Icons [29 B]
Get:87 http://archive.ubuntu.com/ubuntu xenial-security/multiverse Sources [2,120 B]
Get:88 http://archive.ubuntu.com/ubuntu xenial-security/main Sources [122 kB]
Get:89 http://archive.ubuntu.com/ubuntu xenial-security/universe Sources [65.0 kB]
Get:90 http://archive.ubuntu.com/ubuntu xenial-security/restricted Sources [2,116 B]
Get:91 http://archive.ubuntu.com/ubuntu xenial-security/main amd64 Packages [491 kB]
Get:92 http://archive.ubuntu.com/ubuntu xenial-security/main i386 Packages [437 kB]
Ign:93 http://archive.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Get:94 http://archive.ubuntu.com/ubuntu xenial-security/main Translation-en [212 kB]
Get:95 http://archive.ubuntu.com/ubuntu xenial-security/main amd64 DEP-11 Metadata [67.7 kB]
Get:96 http://archive.ubuntu.com/ubuntu xenial-security/main DEP-11 64x64 Icons [68.0 kB]
Get:97 http://archive.ubuntu.com/ubuntu xenial-security/restricted amd64 Packages [7,224 B]
Get:98 http://archive.ubuntu.com/ubuntu xenial-security/restricted i386 Packages [7,224 B]
Get:99 http://archive.ubuntu.com/ubuntu xenial-security/restricted Translation-en [2,152 B]
Get:100 http://archive.ubuntu.com/ubuntu xenial-security/restricted amd64 DEP-11 Metadata [200 B]
Get:101 http://archive.ubuntu.com/ubuntu xenial-security/universe amd64 Packages [347 kB]
Get:102 http://archive.ubuntu.com/ubuntu xenial-security/universe i386 Packages [300 kB]
Ign:103 http://archive.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
Get:104 http://archive.ubuntu.com/ubuntu xenial-security/universe Translation-en [130 kB]
Get:105 http://archive.ubuntu.com/ubuntu xenial-security/universe amd64 DEP-11 Metadata [107 kB]
Get:106 http://archive.ubuntu.com/ubuntu xenial-security/universe DEP-11 64x64 Icons [147 kB]
Get:107 http://archive.ubuntu.com/ubuntu xenial-security/multiverse amd64 Packages [3,464 B]
Get:108 http://archive.ubuntu.com/ubuntu xenial-security/multiverse i386 Packages [3,624 B]
Get:110 http://archive.ubuntu.com/ubuntu xenial-security/multiverse Translation-en [1,744 B]
Get:111 http://archive.ubuntu.com/ubuntu xenial-security/multiverse amd64 DEP-11 Metadata [212 B]
Get:112 http://archive.ubuntu.com/ubuntu xenial-security/multiverse DEP-11 64x64 Icons [29 B]
Err:20 http://archive.ubuntu.com/ubuntu xenial/main arm64 Packages
Err:50 http://archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
Err:74 http://archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
Err:93 http://archive.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Fetched 570 kB in 8s (64.1 kB/s)
cuda-cross-aarch64-9-0 : Depends: g+±aarch64-linux-gnu but it is not installable
