Problems installing Jetpack on Jetson TX2
The only one that seems to work is enp0s29f7u2 and then using ‘ssh nvidia@192.168.55.1’ … I am then ‘inside’ the Jetson.
I know the message is saying 'Determining the IP address of target ……", but could it be something to do with my internet connection? My modem is bluetooth. There’s no RJ45 connection socket :(
JetPack is designed to use the wired ethernet, so other networks may be completely ignored. It is ok for your host to use WiFi, but the Jetson should use wired. This probably doesn’t even matter because if you use JetPack without flashing you will need to manually enter the address. Check the console tab and see if it is asking for an IP address. You should be allowed to manually enter the address where the ssh worked.
I actually made a small bit of progress.
I unchecked the ‘Flash OS’ button and clicked ‘install’ on everything else … and the connection worked.
I could not copy and paste error message, just a screen shot:
… Public GDG Cuda key not installed :(
I copied and pasted ‘sudo apt-key add /var/cuda-repo-9-0-local/7fa2af80.pub’ into terminal, entered password when prompted and recieved an ‘OK’. I’ve no idea if it worked or not :(
Carried on with install but more errors came up :(
Does everybody else have all these crazy/ridiculous problems or is it just me ???
I see I’ve been trying to install this stuff for 2 weeks now :(
I faced something similar (check this topic).
It can be a challenge to get it working, so it isn’t just you. I still suspect that there is some stage during your procedure in which there is a “console” tab you would see a password prompt in…but it may not be on the console tab so you might not see it.
Also, on the host PC, make sure you install package “ssh-askpass”. This is for cases of a GUI password prompt for ssh. If the host is Ubuntu, then “sudo apt-get install ssh-askpass”. Although this probably isn’t the issue, before you start JetPack, run this command in the same terminal from which you start JetPack (this is just making sure a GUI prompt is not missed):
export SSH_ASKPASS=/usr/bin/ssh-askpass
# ...start JetPack now...
It can be a challenge to get it working, so it isn’t just you. … Thank God … I was beginning to think that I’d contracted some kind of progressive dementia. I’ll try and keep going …
Anyway, I seem to have transmitted a large folder called ‘Cuda-l4t’ of size 604.9 MB, with the following errors:
How do I resolve the errors? (I’m not a linux expert) … Or should they be ignored? … Thanks!
code
Configuration file '/etc/apt/sources.list.d/cuda-9-0-local.list', does not exist on system.
Installing new config file as you requested.
W: GPG error: file:/var/cuda-repo-9-0-local  Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
W: The repository 'file:/var/cuda-repo-9-0-local  Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-updates/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-security/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Unable to locate package libfreeimage-dev
E: Unable to locate package libopenmpi-dev
E: Unable to locate package openmpi-bin
W: GPG error: file:/var/nv-tensorrt-repo-ga-cuda9.0-trt3.0.4-20180208  Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
W: The repository 'file:/var/nv-tensorrt-repo-ga-cuda9.0-trt3.0.4-20180208  Release' is not signed.
I am having very similar problems, as in my thread https://devtalk.nvidia.com/default/topic/1036359/jetson-tx2/errors-during-adding-of-nvidia-repository-and-installing-nvidia-drivers-/
However, I was able to install Jetpack up to this point as in these guides
https://docs.nvidia.com/ngc/ngc-titan-setup-guide/index.html
It is just when trying to install the drivers that I get all of the failed to fetch errors.
sudo apt-get update && sudo apt-get install -y --no-install-recommends cuda-drivers
Get:1 file:/var/cuda-repo-9-0-local  InRelease
Ign:1 file:/var/cuda-repo-9-0-local  InRelease
Get:2 file:/var/visionworks-repo  InRelease
Ign:2 file:/var/visionworks-repo  InRelease
Get:3 file:/var/visionworks-sfm-repo  InRelease
Ign:3 file:/var/visionworks-sfm-repo  InRelease
Get:4 file:/var/visionworks-tracking-repo  InRelease
Ign:4 file:/var/visionworks-tracking-repo  InRelease
Get:5 file:/var/cuda-repo-9-0-local  Release [574 B]
Get:6 file:/var/visionworks-repo  Release [1,999 B]
Get:7 file:/var/visionworks-sfm-repo  Release [2,003 B]
Get:8 file:/var/visionworks-tracking-repo  Release [2,008 B]
Hit:13 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Ign:15 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:18 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64  InRelease
Hit:19 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64  Release
Ign:20 http://us.archive.ubuntu.com/ubuntu xenial/main arm64 Packages
Ign:21 http://us.archive.ubuntu.com/ubuntu xenial/universe arm64 Packages
Ign:22 http://us.archive.ubuntu.com/ubuntu xenial/multiverse arm64 Packages
Hit:23 http://dl.google.com/linux/chrome/deb stable Release
Get:16 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Get:14 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
Get:17 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
Get:26 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages [785 kB]
Get:27 http://us.archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages [720 kB]
Ign:28 http://us.archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
Get:29 http://us.archive.ubuntu.com/ubuntu xenial-updates/main Translation-en [325 kB]
Get:30 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 DEP-11 Metadata [319 kB]
Get:31 http://us.archive.ubuntu.com/ubuntu xenial-updates/main DEP-11 64x64 Icons [224 kB]
Get:32 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages [632 kB]
Get:33 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [578 kB]
Ign:34 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe arm64 Packages
Get:35 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe Translation-en [254 kB]
Get:36 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 DEP-11 Metadata [246 kB]
Get:37 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe DEP-11 64x64 Icons [331 kB]
Ign:38 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse arm64 Packages
Get:39 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata [5,964 B]
Ign:40 http://us.archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
Get:41 http://us.archive.ubuntu.com/ubuntu xenial-backports/main amd64 DEP-11 Metadata [3,328 B]
Ign:42 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe arm64 Packages
Get:43 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe amd64 DEP-11 Metadata [5,096 B]
Err:20 http://us.archive.ubuntu.com/ubuntu xenial/main arm64 Packages
  404  Not Found [IP: 91.189.91.23 80]
Get:44 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages [501 kB]
Err:28 http://us.archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
Get:45 http://security.ubuntu.com/ubuntu xenial-security/main i386 Packages [445 kB]
Ign:46 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Get:47 http://security.ubuntu.com/ubuntu xenial-security/main Translation-en [216 kB]
Get:48 http://security.ubuntu.com/ubuntu xenial-security/main amd64 DEP-11 Metadata [67.7 kB]
Get:49 http://security.ubuntu.com/ubuntu xenial-security/main DEP-11 64x64 Icons [68.0 kB]
Get:50 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 Packages [352 kB]
Get:51 http://security.ubuntu.com/ubuntu xenial-security/universe i386 Packages [302 kB]
Ign:52 http://security.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
Get:53 http://security.ubuntu.com/ubuntu xenial-security/universe Translation-en [131 kB]
Get:54 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 DEP-11 Metadata [107 kB]
Err:40 http://us.archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
Get:55 http://security.ubuntu.com/ubuntu xenial-security/universe DEP-11 64x64 Icons [147 kB]
Ign:56 http://security.ubuntu.com/ubuntu xenial-security/multiverse arm64 Packages
Err:46 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
  404  Not Found [IP: 91.189.88.149 80]
Fetched 323 kB in 2s (154 kB/s)
Reading package lists... Done
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages  404  Not Found [IP: 91.189.88.149 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
