(Reading database … 196391 files and directories currently installed.)
Preparing to unpack …/cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb …
Unpacking cuda-repo-ubuntu1604-9-0-local (9.0.252-1) …
dpkg: error processing archive /media/ubuntu/343C1A063C19C3B0/jetpack/jetpack_download/cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb (–install):
cannot copy extracted data for ‘./var/cuda-repo-9-0-local/cuda-visual-tools-9-0_9.0.252-1_amd64.deb’ to ‘/var/cuda-repo-9-0-local/cuda-visual-tools-9-0_9.0.252-1_amd64.deb.dpkg-new’: failed to write (No space left on device)
dpkg-deb (subprocess): decompressing archive member: lzma write error: Broken pipe
dpkg-deb: error: subprocess returned error exit status 2
dpkg-deb (subprocess): cannot copy archive member from ‘/media/ubuntu/343C1A063C19C3B0/jetpack/jetpack_download/cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb’ to decompressor pipe: failed to write (Broken pipe)
Errors were encountered while processing:
gpg: can’t open `/var/cuda-repo-9-0-local/*.pub’: No such file or directory
Ign:1 cdrom://Ubuntu 16.04.5 LTS Xenial Xerus - Release amd64 (20180731) xenial InRelease
Hit:2 cdrom://Ubuntu 16.04.5 LTS Xenial Xerus - Release amd64 (20180731) xenial Release
Get:4 Index of /ubuntu xenial-security InRelease [107 kB]
Hit:5 Index of /ubuntu xenial InRelease
Get:6 Index of /ubuntu xenial-updates InRelease [109 kB]
Ign:7 Index of /ubuntu xenial-security/main arm64 Packages
Err:7 Index of /ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 91.189.88.149 80]
Ign:8 Index of /ubuntu xenial/main arm64 Packages
Ign:9 Index of /ubuntu xenial-updates/main arm64 Packages
Err:8 Index of /ubuntu xenial/main arm64 Packages
404 Not Found [IP: 91.189.88.161 80]
Err:9 Index of /ubuntu xenial-updates/main arm64 Packages
Fetched 106 kB in 5min 5s (346 B/s)
Reading package lists…
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.161 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.161 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree…
Reading state information…
E: Unable to locate package cuda-toolkit-9-0
Hit:4 Index of /ubuntu xenial InRelease
Get:5 Index of /ubuntu xenial-security InRelease [107 kB]
Ign:7 Index of /ubuntu xenial/main arm64 Packages
Ign:8 Index of /ubuntu xenial-updates/main arm64 Packages
Ign:9 Index of /ubuntu xenial-security/main arm64 Packages
Err:7 Index of /ubuntu xenial/main arm64 Packages
404 Not Found [IP: 91.189.88.152 80]
Err:8 Index of /ubuntu xenial-updates/main arm64 Packages
Err:9 Index of /ubuntu xenial-security/main arm64 Packages
Fetched 216 kB in 4s (47.5 kB/s)
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Unable to locate package cuda-cross-aarch64-9-0
iam new to jetson tx2 . my host machine Unable to locate package cuda-toolkit-9-0 . how i can fix this problem
We have newer JetPack version. Could you try if it fixes your issue?
[url]https://developer.nvidia.com/embedded/jetpack[/url]
