Please help. I cannot get Jetpack to install on my Ubuntu Linux host system.
Details:
Installing JetPack L4T 2.2.1
for Jetson TX1 (64 bit)
on Ubuntu 16.04 LTS host (4x Intel i7-6500U cores @ 2.5 GHz, 16GB RAM, 80GB disk with 65 GB free).
I successfully started the installer, set configuration, and downloaded all listed packages.
After all the downloads, approximately 10 minutes, it begins installing packages. The following 3 packages, “Tegra Graphics Debugger” (2.2.16124), “Tegra System Profiler” (2.6.20651219), and “Documentation” (2.2.1) appear to install successfully, but the next item, “CUDA Toolkit for Ubuntu 14.04”, runs for awhile and then fails with the following message in the Terminal area:
E: Unable to locate package cuda-toolkit-7-0
dpkg-query: package ‘cuda-toolkit-7-0’ is not installed and no information is available
Use dpkg --info (=dpkg-deb --info) to examine files
and dpkg --contents (=dpkg-deb --contents) to list their contents.
Here is the Log file:
(Reading database … 173373 files and directories currently installed.)
Preparing to unpack …/cuda-repo-ubuntu1404-7-0-local_7.0-76_amd64.deb …
Unpacking cuda-repo-ubuntu1404-7-0-local (7.0-76) over (7.0-76) …
Setting up cuda-repo-ubuntu1404-7-0-local (7.0-76) …
OK
Get:1 file:/var/cuda-repo-7-0-local InRelease
Ign:1 file:/var/cuda-repo-7-0-local InRelease
Get:2 file:/var/cuda-repo-7-0-local Release [196 B]
Get:3 file:/var/cuda-repo-7-0-local Release.gpg [181 B]
Hit:4 Index of /ubuntu xenial-security InRelease
Hit:5 Index of /ubuntu xenial InRelease
Hit:6 Index of /ubuntu xenial-updates InRelease
Hit:7 Index of /ubuntu xenial-backports InRelease
Reading package lists…
W: file:///var/cuda-repo-7-0-local/Release.gpg: Signature by key 889BEE522DA690103C4B085ED88C3D385C37D3BE uses weak digest algorithm (SHA1)
E: Failed to fetch file:/var/cuda-repo-7-0-local/Release No Hash entry in Release file /var/lib/apt/lists/partial/_var_cuda-repo-7-0-local_Release which is considered strong enough for security purposes
E: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree…
Reading state information…
