I have a Jetson TX1 board and am using Jetpack 2.2. I have attempted to run Jetpack a number of times and each time it fails on “Installing CUDA Toolkit for Ubuntu 14.04 failed”. Below is the log file.
Thanks in advance
Reading database … 186058 files and directories currently installed.)
Preparing to unpack …/cuda-repo-ubuntu1404-7-0-local_7.0-73_amd64.deb …
Unpacking cuda-repo-ubuntu1404-7-0-local (7.0-73) over (7.0-76) …
Setting up cuda-repo-ubuntu1404-7-0-local (7.0-73) …
OK
Get:1 file:/var/cuda-repo-7-0-local InRelease
Ign:1 file:/var/cuda-repo-7-0-local InRelease
Get:2 file:/var/cuda-repo-7-0-local Release [196 B]
Get:3 file:/var/cuda-repo-7-0-local Release.gpg [181 B]
Ign:4 http://archive.canonical.com/ubuntu trusty InRelease
Hit:5 http://ppa.launchpad.net/openjdk-r/ppa/ubuntu trusty InRelease
Get:6 http://archive.canonical.com/ubuntu trusty Release [9,359 B]
Ign:7 http://extras.ubuntu.com/ubuntu trusty InRelease
Hit:8 http://ftp.debian.org/debian unstable InRelease
Get:9 http://extras.ubuntu.com/ubuntu trusty Release [11.9 kB]
Hit:11 http://security.ubuntu.com/ubuntu trusty-security InRelease
Ign:12 http://us.archive.ubuntu.com/ubuntu trusty InRelease
Get:14 http://us.archive.ubuntu.com/ubuntu trusty-updates InRelease [65.9 kB]
Ign:15 http://security.ubuntu.com/ubuntu trusty-security/main armhf Packages
Ign:16 http://security.ubuntu.com/ubuntu trusty-security/restricted armhf Packages
Ign:17 http://security.ubuntu.com/ubuntu trusty-security/universe armhf Packages
Ign:18 http://security.ubuntu.com/ubuntu trusty-security/multiverse armhf Packages
Err:15 http://security.ubuntu.com/ubuntu trusty-security/main armhf Packages
404 Not Found [IP: 91.189.88.149 80]
Hit:19 http://us.archive.ubuntu.com/ubuntu trusty-backports InRelease
Get:20 http://us.archive.ubuntu.com/ubuntu trusty Release [11.9 kB]
Get:21 http://screenshots.getdeb.net trusty-getdeb InRelease [8,145 B]
Hit:23 http://emdebian.org/tools/debian jessie InRelease
Get:24 http://us.archive.ubuntu.com/ubuntu trusty-updates/main Sources [277 kB]
Get:25 http://us.archive.ubuntu.com/ubuntu trusty-updates/main amd64 Packages [789 kB]
Get:26 http://us.archive.ubuntu.com/ubuntu trusty-updates/main i386 Packages [756 kB]
Ign:27 http://us.archive.ubuntu.com/ubuntu trusty-updates/main armhf Packages
Ign:28 http://us.archive.ubuntu.com/ubuntu trusty-updates/restricted armhf Packages
Get:29 http://us.archive.ubuntu.com/ubuntu trusty-updates/universe amd64 Packages [363 kB]
Get:30 http://us.archive.ubuntu.com/ubuntu trusty-updates/universe i386 Packages [364 kB]
Ign:31 http://us.archive.ubuntu.com/ubuntu trusty-updates/universe armhf Packages
Ign:32 http://us.archive.ubuntu.com/ubuntu trusty-updates/multiverse armhf Packages
Ign:33 http://us.archive.ubuntu.com/ubuntu trusty-backports/main armhf Packages
Ign:34 http://us.archive.ubuntu.com/ubuntu trusty-backports/universe armhf Packages
Ign:35 http://us.archive.ubuntu.com/ubuntu trusty-backports/multiverse armhf Packages
Err:27 http://us.archive.ubuntu.com/ubuntu trusty-updates/main armhf Packages
404 Not Found [IP: 91.189.91.26 80]
Err:33 http://us.archive.ubuntu.com/ubuntu trusty-backports/main armhf Packages
Fetched 2,655 kB in 13s (199 kB/s)
Reading package lists…
W: file:///var/cuda-repo-7-0-local/Release.gpg: Signature by key 889BEE522DA690103C4B085ED88C3D385C37D3BE uses weak digest algorithm (SHA1)
W: http://extras.ubuntu.com/ubuntu/dists/trusty/Release.gpg: Signature by key C47415DFF48C09645B78609416126D3A3E5C1192 uses weak digest algorithm (SHA1)
W: http://us.archive.ubuntu.com/ubuntu/dists/trusty/Release.gpg: Signature by key C47415DFF48C09645B78609416126D3A3E5C1192 uses weak digest algorithm (SHA1)
W: http://emdebian.org/tools/debian/dists/jessie/InRelease: Signature by key 084C6C6F39159EDB67969AA87DE089671804772E uses weak digest algorithm (SHA1)
E: Failed to fetch file:/var/cuda-repo-7-0-local/Release No Hash entry in Release file /var/lib/apt/lists/partial/_var_cuda-repo-7-0-local_Release which is considered strong enough for security purposes
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/trusty/Release Unable to find expected entry ‘restricted/source/Sources’ in Release file (Wrong sources.list entry or malformed file)
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/trusty-security/main/binary-armhf/Packages 404 Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/trusty-updates/main/binary-armhf/Packages 404 Not Found [IP: 91.189.91.26 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/trusty-backports/main/binary-armhf/Packages 404 Not Found [IP: 91.189.91.26 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree…
Reading state information…
libc6-armhf-cross is already the newest version (2.21-6cross2).
libgomp1 is already the newest version (6.1.1-8).
libgomp1 set to manually installed.
libgomp1-armhf-cross is already the newest version (6.1.1-4cross1).
libgomp1-armhf-cross set to manually installed.
g+±arm-linux-gnueabihf is already the newest version (4:5.3.1-3).
g+±arm-linux-gnueabihf set to manually installed.
gcc-arm-linux-gnueabihf is already the newest version (4:5.3.1-3).
gcc-arm-linux-gnueabihf set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-toolkit-7-0 : Depends: cuda-samples-7-0 (= 7.0-76) but it is not going to be installed
Depends: cuda-documentation-7-0 (= 7.0-76) but it is not going to be installed
libsfstdc++6-armhf-cross : Depends: libsfgcc1-armhf-cross (>= 4.8.4-2ubuntu1~14.04.1cross0.11.2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
