I try ubuntu 14.04-16.04 but all the os same error .
I try Jetpack 3.0-3.2 two of them .
Am i miss something?
Error is:
Version: 8.0
DashedVersion: 8-0
root 5396 0.0 0.0 265096 2780 ? Ssl 12:48 0:00 /media/ubuntu/OS_Install/asd//_installer/sudo_daemon -installer=5349 -d=/media/ubuntu/OS_Install/asd//_installer/tmp
0
/media/ubuntu/OS_Install/asd//_installer/run_command -c="apt-get remove --purge -y cuda.8-0" -d=/media/ubuntu/OS_Install/asd//_installer/tmp
Reading package lists…
Building dependency tree…
Reading state information…
Package ‘cuda-cudart-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-driver-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-misc-headers-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-cusolver-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-cublas-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-cufft-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-curand-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-cusparse-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-npp-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-cudart-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-driver-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-misc-headers-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-nvrtc-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-cusolver-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-cublas-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-cufft-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-curand-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-cusparse-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-npp-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-nvml-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-nvgraph-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-cudart-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-driver-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-misc-headers-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-nvrtc-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-cusolver-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-cublas-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-cufft-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-curand-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-cusparse-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-npp-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-nvml-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-nvgraph-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-cufft-8-0’ is not installed, so not removed
Package ‘cuda-visual-tools-8-0’ is not installed, so not removed
Package ‘cuda-8-0’ is not installed, so not removed
Package ‘cuda-cross-armhf-8-0’ is not installed, so not removed
Package ‘cuda-minimal-build-8-0’ is not installed, so not removed
Package ‘cuda-misc-headers-8-0’ is not installed, so not removed
Package ‘cuda-cufft-dev-8-0’ is not installed, so not removed
Package ‘cuda-cross-aarch64-8-0’ is not installed, so not removed
Package ‘cuda-cusparse-dev-8-0’ is not installed, so not removed
Package ‘cuda-nvml-dev-8-0’ is not installed, so not removed
Package ‘cuda-license-8-0’ is not installed, so not removed
Package ‘cuda-nvgraph-8-0’ is not installed, so not removed
Package ‘cuda-gdb-src-8-0’ is not installed, so not removed
Package ‘cuda-nvrtc-8-0’ is not installed, so not removed
Package ‘cuda-npp-dev-8-0’ is not installed, so not removed
Package ‘cuda-cusparse-8-0’ is not installed, so not removed
Package ‘cuda-nvrtc-dev-8-0’ is not installed, so not removed
Package ‘cuda-documentation-8-0’ is not installed, so not removed
Package ‘cuda-driver-dev-8-0’ is not installed, so not removed
Package ‘cuda-nvgraph-dev-8-0’ is not installed, so not removed
Package ‘cuda-curand-8-0’ is not installed, so not removed
Package ‘cuda-cusolver-dev-8-0’ is not installed, so not removed
Package ‘cuda-toolkit-8-0’ is not installed, so not removed
Package ‘cuda-cusolver-8-0’ is not installed, so not removed
Package ‘cuda-cudart-dev-8-0’ is not installed, so not removed
Package ‘cuda-command-line-tools-8-0’ is not installed, so not removed
Package ‘cuda-core-8-0’ is not installed, so not removed
Package ‘cuda-curand-dev-8-0’ is not installed, so not removed
Package ‘cuda-runtime-8-0’ is not installed, so not removed
Package ‘cuda-cublas-8-0’ is not installed, so not removed
Package ‘cuda-cublas-dev-8-0’ is not installed, so not removed
Package ‘cuda-npp-8-0’ is not installed, so not removed
Package ‘cuda-cross-ppc64el-8-0’ is not installed, so not removed
Package ‘cuda-demo-suite-8-0’ is not installed, so not removed
Package ‘cuda-samples-8-0’ is not installed, so not removed
Package ‘cuda-cudart-8-0’ is not installed, so not removed
The following packages will be REMOVED:
cuda-repo-ubuntu1604-8-0-local
0 upgraded, 0 newly installed, 1 to remove and 57 not upgraded.
After this operation, 1,918 MB disk space will be freed.
(Reading database … 195624 files and directories currently installed.)
Removing cuda-repo-ubuntu1604-8-0-local (8.0.64-1) …
Purging configuration files for cuda-repo-ubuntu1604-8-0-local (8.0.64-1) …
root 5396 0.0 0.0 265096 2804 ? Ssl 12:48 0:00 /media/ubuntu/OS_Install/asd//_installer/sudo_daemon -installer=5349 -d=/media/ubuntu/OS_Install/asd//_installer/tmp
0
/media/ubuntu/OS_Install/asd//_installer/run_command -c=“dpkg -i --force-overwrite /media/ubuntu/OS_Install/asd/jetpack_download/cuda-repo-ubuntu1604-8-0-local_8.0.64-1_amd64.deb;apt-get update; apt-get -y --force-yes install cuda-toolkit-8-0;” -d=/media/ubuntu/OS_Install/asd//_installer/tmp -l=/media/ubuntu/OS_Install/asd/_installer/logs/64_TX2//cuda_host_tx2.log
Selecting previously unselected package cuda-repo-ubuntu1604-8-0-local.
(Reading database … 195541 files and directories currently installed.)
Preparing to unpack …/cuda-repo-ubuntu1604-8-0-local_8.0.64-1_amd64.deb …
Unpacking cuda-repo-ubuntu1604-8-0-local (8.0.64-1) …
Setting up cuda-repo-ubuntu1604-8-0-local (8.0.64-1) …
OK
Ign:1 cdrom://Ubuntu 16.04.4 LTS Xenial Xerus - Release amd64 (20180228) xenial InRelease
Get:2 file:/var/cuda-repo-8-0-local InRelease
Hit:3 cdrom://Ubuntu 16.04.4 LTS Xenial Xerus - Release amd64 (20180228) xenial Release
Ign:2 file:/var/cuda-repo-8-0-local InRelease
Get:4 file:/var/cuda-repo-8-0-local Release [574 B]
Hit:7 Index of /ubuntu xenial InRelease
Hit:8 Index of /ubuntu xenial-updates InRelease
Hit:9 Index of /ubuntu xenial-security InRelease
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-toolkit-8-0 : Depends: cuda-samples-8-0 (>= 8.0.64) but it is not going to be installed
Depends: cuda-documentation-8-0 (>= 8.0.64) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
dpkg-query: package ‘cuda-toolkit-8-0’ is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
0
Version: 8.0
DashedVersion: 8-0
root 5396 0.0 0.0 273292 2832 ? Ssl 12:48 0:00 /media/ubuntu/OS_Install/asd//_installer/sudo_daemon -installer=5349 -d=/media/ubuntu/OS_Install/asd//_installer/tmp
0
root 5396 0.0 0.0 273292 2872 ? Ssl 12:48 0:00 /media/ubuntu/OS_Install/asd//_installer/sudo_daemon -installer=5349 -d=/media/ubuntu/OS_Install/asd//_installer/tmp
0
OK
Hit:8 Index of /ubuntu xenial-security InRelease
Hit:9 Index of /ubuntu xenial-updates InRelease
0
