I try install JetPack 3.3
Downloading allways stop on this moment:
sent 605,000,076 bytes received 35 bytes 11,523,811.64 bytes/sec
total size is 604,852,294 speedup is 1.00
nvidia:
nvidia: \00\00\00\00\00\00\00\00\00\00\00\00
Selecting previously unselected package cuda-repo-l4t-9-0-local.
(Reading database …
(Reading database … 5%
(Reading database … 10%
(Reading database … 15%
(Reading database … 20%
(Reading database … 25%
(Reading database … 30%
(Reading database … 35%
(Reading database … 40%
(Reading database … 45%
(Reading database … 50%
(Reading database … 55%
(Reading database … 60%
(Reading database … 65%
(Reading database … 70%
(Reading database … 75%
(Reading database … 80%
(Reading database … 85%
(Reading database … 90%
(Reading database … 95%
(Reading database … 100%
(Reading database … 149227 files and directories currently installed.)
Preparing to unpack …/cuda-repo-l4t-9-0-local_9.0.252-1_arm64.deb …
Unpacking cuda-repo-l4t-9-0-local (9.0.252-1) …
Setting up cuda-repo-l4t-9-0-local (9.0.252-1) …
The public CUDA GPG key does not appear to be installed.
To install the key, run this command:
sudo apt-key add /var/cuda-repo-9-0-local/7fa2af80.pub
OK
0% [Working]
Get:1 file:/var/cuda-repo-9-0-local InRelease
0% [1 InRelease 0 B]
Ign:1 file:/var/cuda-repo-9-0-local InRelease
0% [Working]
Get:2 file:/var/cuda-repo-9-0-local Release [574 B]
0% [Working]
Err:3 Index of /ubuntu-ports xenial InRelease
Could not resolve ‘ports.ubuntu.com’
0% [Working]
Err:4 Index of /ubuntu-ports xenial-updates InRelease
0% [Working]
Err:5 Index of /ubuntu-ports xenial-security InRelease
0% [Working]
0% [2 Release 0 B/574 B 0%]
84% [Working]
Get:6 file:/var/cuda-repo-9-0-local Release.gpg [819 B]
37% [6 Release.gpg 0 B/819 B 0%]
37% [Working]
84% [Working]
84% [6 Release.gpg gpgv 574 B]
23% [Working]
Get:7 file:/var/cuda-repo-9-0-local Packages [7,617 B]
23% [7 Packages 0 B/7,617 B 0%]
91% [Working]
91% [7 Packages store 0 B]
93% [Working]
Reading package lists… 0%
Reading package lists… 1%
Reading package lists… Done
Building dependency tree… 0%
Building dependency tree… 50%
Reading state information… 0%
Reading state information… Done
Connection to 192.168.8.100 closed.
dpkg-query: package ‘cuda-toolkit-9-0’ is not installed and no information is available
dpkg-query: package ‘libfreeimage-dev’ is not installed and no information is available
dpkg-query: package ‘libopenmpi-dev’ is not installed and no information is available
dpkg-query: package ‘openmpi-bin’ is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
1
Error: CUDA cannot be installed on device. This may be caused by other apt-get command running on device when installing CUDA. Please use apt-get command in a terminal to make sure following packages are installed correctly on device before continuing:
cuda-toolkit-9-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
After these packages are installed on device, press Enter key to continue
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database …
OK
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
1
0
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 149227 files and directories currently installed.)
Preparing to unpack .../cuda-repo-l4t-9-0-local_9.0.252-1_arm64.deb ...
Unpacking cuda-repo-l4t-9-0-local (9.0.252-1) ...
Setting up cuda-repo-l4t-9-0-local (9.0.252-1) ...
OK
0% [Working]
0% [Working]
0% [Working]
Err:3 http://ports.ubuntu.com/ubuntu-ports xenial InRelease
Could not resolve 'ports.ubuntu.com'
0% [Working]
Err:4 http://ports.ubuntu.com/ubuntu-ports xenial-updates InRelease
0% [Working]
Err:5 http://ports.ubuntu.com/ubuntu-ports xenial-security InRelease
0% [Working]
84% [Working]
37% [Working]
84% [Working]
23% [Working]
91% [Working]
93% [Working]
Reading package lists... 0%
Reading package lists... 1%
Reading package lists... Done
Building dependency tree... 0%
Building dependency tree... 50%
Reading state information... 0%
Reading state information... Done
dpkg-query: package 'cuda-toolkit-9-0' is not installed and no information is available
dpkg-query: package 'libfreeimage-dev' is not installed and no information is available
dpkg-query: package 'libopenmpi-dev' is not installed and no information is available
dpkg-query: package 'openmpi-bin' is not installed and no information is available
1
i install all pockets by myself on jetson TX1(after i connected it by Wi-Fi only)
Press “Enter button” on my laptop, and nothing change…
I use sheme 2 when Laptop connect to internet by Wi-fi, but jetson connect to Laptob by another router without internet.
Ip of wifi is 192.168.1.XXX
IP from route3r may be 192.168.8.XXX
network error in these subnets are impossible
