Thank you. There were too many characters for the full log, but here is most of the log files, skipping the middle section of the install log. I can email the files to you if that is preferred.
JetPack.log:
04-17 18:37:13.7 E: fopen failed with file local.db, errno = 2
04-17 18:37:15.7 W: One invalid entry
04-17 18:39:33.8 N: Install com.nvidia.nvtools.battle 2.5; Install com.nvidia.nvtools.quadd 4.0; Install com.nvidia.docs.jetpack 3.2; Install com.nvidia.docs.devtools 3.2; Install com.nvidia.middleware.visionworks_docs 1.6; Install com.nvidia.l4t.driver4os_64_tx2 28.2; Install com.nvidia.l4t.filesystem_64_tx2 28.2; Install com.nvidia.l4t.flash_64_tx2 28.2; Install com.nvidia.cuda.l4t_64_tx2 9.0; Install com.nvidia.middleware.cudnn_64_tx2 7.0; Install com.nvidia.gie.l4t_64_tx2 3.0; Install org.opencv.middleware.ocv_l4t_64_tx2 3.3.1; Install com.nvidia.middleware.visionworks_target_64_tx2 1.6; Install com.nvidia.middleware.visionworks_target_sfm_64_tx2 0.90; Install com.nvidia.middleware.visionworks_target_tracking_64_tx2 0.88; Install com.nvidia.mmapi.l4t_64_tx2 28.2;
04-17 18:42:13.9 E: Failure when receiving data from the peer
04-17 18:43:28.3 E: Failure when receiving data from the peer
04-17 18:59:48.3 N: Install com.nvidia.nvtools.battle 2.5; Install com.nvidia.nvtools.quadd 4.0; Install com.nvidia.docs.jetpack 3.2; Install com.nvidia.docs.devtools 3.2; Install com.nvidia.middleware.visionworks_docs 1.6; Install com.nvidia.cuda.host 9.0; Install com.nvidia.l4t.driver4os_64_tx2 28.2; Install com.nvidia.l4t.filesystem_64_tx2 28.2; Install com.nvidia.l4t.flash_64_tx2 28.2; Install com.nvidia.cuda.l4t_64_tx2 9.0; Install com.nvidia.middleware.cudnn_64_tx2 7.0; Install com.nvidia.gie.l4t_64_tx2 3.0; Install org.opencv.middleware.ocv_l4t_64_tx2 3.3.1; Install com.nvidia.middleware.visionworks_target_64_tx2 1.6; Install com.nvidia.middleware.visionworks_target_sfm_64_tx2 0.90; Install com.nvidia.middleware.visionworks_target_tracking_64_tx2 0.88; Install com.nvidia.mmapi.l4t_64_tx2 28.2;
04-17 19:53:55.6 E: Failure when receiving data from the peer
04-17 19:55:58.8 E: Failure when receiving data from the peer
04-20 11:04:39.0 E: fopen failed with file local.db, errno = 2
04-20 11:04:42.8 W: One invalid entry
04-20 11:04:51.2 N: Install com.nvidia.nvtools.battle 2.5; Install com.nvidia.nvtools.quadd 4.0; Install com.nvidia.docs.jetpack 3.2; Install com.nvidia.docs.devtools 3.2; Install com.nvidia.middleware.visionworks_docs 1.6; Install com.nvidia.cuda.host 9.0; Install org.opencv.middleware.ocv_64_host 3.3.1; Install com.nvidia.middleware.visionworks_host 1.6; Install com.nvidia.middleware.visionworks_host_sfm 0.90; Install com.nvidia.middleware.visionworks_host_tracking 0.88; Install com.nvidia.l4t.driver4os_64_tx2 28.2; Install com.nvidia.l4t.filesystem_64_tx2 28.2; Install com.nvidia.l4t.flash_64_tx2 28.2; Install com.nvidia.cuda.l4t_64_tx2 9.0; Install com.nvidia.cuda.compile_cuda_64_tx2 9.0; Install com.nvidia.middleware.cudnn_64_tx2 7.0; Install com.nvidia.gie.l4t_64_tx2 3.0; Install org.opencv.middleware.ocv_l4t_64_tx2 3.3.1; Install com.nvidia.middleware.visionworks_target_64_tx2 1.6; Install com.nvidia.middleware.visionworks_target_sfm_64_tx2 0.90; Install com.nvidia.middleware.visionworks_target_tracking_64_tx2 0.88; Install com.nvidia.mmapi.l4t_64_tx2 28.2;
04-20 11:32:53.4 E: Failure when receiving data from the peer
04-20 11:46:48.0 N: Installing Tegra Graphics Debugger 2.5 succeeded.
04-20 11:46:55.0 N: Installing NVIDIA System Profiler 4.0 succeeded.
04-20 11:46:55.6 N: Installing JetPack Documentation 3.2 succeeded.
04-20 11:46:57.4 N: Installing DevTools Documentation 3.2 succeeded.
04-20 11:46:58.1 N: Installing VisionWorks References 1.6 succeeded.
04-20 11:48:14.6 E: Installing CUDA Toolkit 9.0 failed.
Return Code: 1
Error installing cuda-toolkit-9-0 cuda-cross-aarch64-9-0 to host, please check /home/jbob/jet/_installer/logs/cuda_host_9.0.log for more details
Terminal_Installer.log:
root 2003 0.2 0.0 330900 2960 ? Ssl 11:04 0:05 /home/jbob/jet/_installer/sudo_daemon -installer=1834 -d=/home/jbob/jet/_installer/tmp
0
/home/jbob/jet//_installer/run_command -c="/home/jbob/jet/jetpack_download/2017_11_28_1956-23204764-NVIDIA_Tegra_Graphics_Debugger_2.5.17332.1956_Release_External_tgd-l4t_linux-l4t.run --nox11 -- -noprompt" -d=/home/jbob/jet//_installer/tmp -l=/home/jbob/jet/_installer/logs//install_tegra_graphics_debugger.log
Verifying archive integrity... All good.
Uncompressing NVIDIA Tegra Graphics Debugger 100%
'pkg/CrashReporter' -> '/usr/local/Tegra-Graphics-Debugger-2.5/CrashReporter'
'pkg/EULA.txt' -> '/usr/local/Tegra-Graphics-Debugger-2.5/EULA.txt'
'pkg/Plugins' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins'
'pkg/Plugins/platforms' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/platforms'
'pkg/Plugins/platforms/libqxcb.so' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/platforms/libqxcb.so'
'pkg/Plugins/CorePlugin' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/CorePlugin'
'pkg/Plugins/CorePlugin/LightTheme.js' -> '/usr/local/Tegra-Graphics-Debugger-2
5/Plugins/CorePlugin/LightTheme.js'
'pkg/Plugins/CorePlugin/BlueTheme.js' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/CorePlugin/BlueTheme.js'
'pkg/Plugins/CorePlugin/DarkTheme.js' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/CorePlugin/DarkTheme.js'
'pkg/Plugins/CorePlugin/Manifest.js' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/CorePlugin/Manifest.js'
'pkg/Plugins/CorePlugin/libCorePlugin.so' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/CorePlugin/libCorePlugin.so'
'pkg/Plugins/BattlePlugin' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin'
'pkg/Plugins/BattlePlugin/EnableBlue.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/EnableBlue.png'
'pkg/Plugins/BattlePlugin/Disconnect.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/Disconnect.png'
'pkg/Plugins/BattlePlugin/DefaultPerfWorksSignals.js' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/DefaultPerfWorksSignals.js'
'pkg/Plugins/BattlePlugin/Ubuntu-R.ttf' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/Ubuntu-R.ttf'
'pkg/Plugins/BattlePlugin/DefaultNVPMAPISignals.js' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/DefaultNVPMAPISignals.js'
'pkg/Plugins/BattlePlugin/Resume.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/Resume.png'
'pkg/Plugins/BattlePlugin/ShaderEdit.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ShaderEdit.png'
'pkg/Plugins/BattlePlugin/EnableGreen.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/EnableGreen.png'
'pkg/Plugins/BattlePlugin/Connect.png' -> '/usr/local/Tegra-Graphics-Debugger-2
5/Plugins/BattlePlugin/Connect.png'
'pkg/Plugins/BattlePlugin/EnableAlpha.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/EnableAlpha.png'
'pkg/Plugins/BattlePlugin/ExpandAll.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ExpandAll.png'
'pkg/Plugins/BattlePlugin/SelectPerfMarkers.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/SelectPerfMarkers.png'
'pkg/Plugins/BattlePlugin/LDPreload.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/LDPreload.png'
'pkg/Plugins/BattlePlugin/ToggleWireframe.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ToggleWireframe.png'
'pkg/Plugins/BattlePlugin/ShaderPromote.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ShaderPromote.png'
'pkg/Plugins/BattlePlugin/Manifest.js' -> '/usr/local/Tegra-Graphics-Debugger-2
5/Plugins/BattlePlugin/Manifest.js'
'pkg/Plugins/BattlePlugin/ActivateEditedShaders.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ActivateEditedShaders.png'
'pkg/Plugins/BattlePlugin/Save.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/Save.png'
'pkg/Plugins/BattlePlugin/LockWindow.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/LockWindow.png'
'pkg/Plugins/BattlePlugin/CollapseAll.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/CollapseAll.png'
'pkg/Plugins/BattlePlugin/libBattlePlugin.so' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/libBattlePlugin.so'
'pkg/Plugins/BattlePlugin/EditStateBuckets.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/EditStateBuckets.png'
'pkg/Plugins/BattlePlugin/ActivateOriginalShaders.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ActivateOriginalShaders.png'
'pkg/Plugins/BattlePlugin/Configure.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/Configure.png'
'pkg/Plugins/BattlePlugin/ShaderCompile.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ShaderCompile.png'
'pkg/Plugins/BattlePlugin/CaptureFrame.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/CaptureFrame.png'
'pkg/Plugins/BattlePlugin/FlipImageVertical.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/FlipImageVertical.png'
'pkg/Plugins/BattlePlugin/CloneWindow.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/CloneWindow.png'
'pkg/Plugins/BattlePlugin/ShowShaderUsages.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/ShowShaderUsages.png'
'pkg/Plugins/BattlePlugin/Refresh.png' -> '/usr/local/Tegra-Graphics-Debugger-2
5/Plugins/BattlePlugin/Refresh.png'
'pkg/Plugins/BattlePlugin/Injector.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/Injector.png'
'pkg/Plugins/BattlePlugin/CaptureNextFrame.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/CaptureNextFrame.png'
'pkg/Plugins/BattlePlugin/EnableRed.png' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/BattlePlugin/EnableRed.png'
'pkg/Plugins/xcbglintegrations' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/xcbglintegrations'
'pkg/Plugins/xcbglintegrations/libqxcb-glx-integration.so' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/xcbglintegrations/libqxcb-glx-integration.so'
'pkg/Plugins/imageformats' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/imageformats'
'pkg/Plugins/imageformats/libqgif.so' -> '/usr/local/Tegra-Graphics-Debugger-2.5/Plugins/imageformats/libqgif.so'
Ign:36 http://us.archive.ubuntu.com/ubuntu xenial/main Translation-en
Get:37 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 DEP-11 Metadata [733 kB]
Ign:38 http://us.archive.ubuntu.com/ubuntu xenial/main DEP-11 64x64 Icons
Get:39 http://us.archive.ubuntu.com/ubuntu xenial/restricted amd64 Packages [8,344 B]
Ign:40 http://us.archive.ubuntu.com/ubuntu xenial/restricted i386 Packages
Get:41 http://us.archive.ubuntu.com/ubuntu xenial/restricted Translation-en [2,908 B]
Ign:42 http://us.archive.ubuntu.com/ubuntu xenial/restricted amd64 DEP-11 Metadata
Get:43 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages [7,532 kB]
Ign:44 http://us.archive.ubuntu.com/ubuntu xenial/universe i386 Packages
Get:45 http://us.archive.ubuntu.com/ubuntu xenial/universe Translation-en [4,354 kB]
Ign:46 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 DEP-11 Metadata
Get:47 http://us.archive.ubuntu.com/ubuntu xenial/universe DEP-11 64x64 Icons [7,448 kB]
Ign:48 http://us.archive.ubuntu.com/ubuntu xenial/multiverse amd64 Packages
Get:49 http://us.archive.ubuntu.com/ubuntu xenial/multiverse i386 Packages [140 kB]
Ign:50 http://us.archive.ubuntu.com/ubuntu xenial/multiverse Translation-en
Get:51 http://us.archive.ubuntu.com/ubuntu xenial/multiverse amd64 DEP-11 Metadata [63.8 kB]
Ign:52 http://us.archive.ubuntu.com/ubuntu xenial/multiverse DEP-11 64x64 Icons
Get:15 http://us.archive.ubuntu.com/ubuntu xenial-updates/main Translation-en [314 kB]
Ign:17 http://us.archive.ubuntu.com/ubuntu xenial-updates/main DEP-11 64x64 Icons
Get:19 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted i386 Packages [7,524 B]
Ign:21 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 DEP-11 Metadata
Get:23 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [574 kB]
Ign:25 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 DEP-11 Metadata
Get:27 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 Packages [16.2 kB]
Ign:29 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse Translation-en
Get:31 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse DEP-11 64x64 Icons [14.3 kB]
Ign:33 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe amd64 DEP-11 Metadata
Get:34 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 Packages [1,201 kB]
Get:38 http://us.archive.ubuntu.com/ubuntu xenial/main DEP-11 64x64 Icons [409 kB]
Get:42 http://us.archive.ubuntu.com/ubuntu xenial/restricted amd64 DEP-11 Metadata [186 B]
Get:46 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 DEP-11 Metadata [3,410 kB]
Get:50 http://us.archive.ubuntu.com/ubuntu xenial/multiverse Translation-en [106 kB]
Err:17 http://us.archive.ubuntu.com/ubuntu xenial-updates/main DEP-11 64x64 Icons
400 Bad Request [IP: 91.189.91.26 80]
Get:25 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 DEP-11 Metadata [332 kB]
Get:29 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse Translation-en [8,565 B]
Get:33 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe amd64 DEP-11 Metadata [5,357 B]
Get:36 http://us.archive.ubuntu.com/ubuntu xenial/main Translation-en [799 kB]
Get:40 http://us.archive.ubuntu.com/ubuntu xenial/restricted i386 Packages [14.5 kB]
Get:44 http://us.archive.ubuntu.com/ubuntu xenial/universe i386 Packages [9,804 kB]
Get:48 http://us.archive.ubuntu.com/ubuntu xenial/multiverse amd64 Packages [176 kB]
Err:52 http://us.archive.ubuntu.com/ubuntu xenial/multiverse DEP-11 64x64 Icons
Fetched 4,952 kB in 28s (173 kB/s)
Reading package lists...
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/dep11/icons-64x64.tar 400 Bad Request [IP: 91.189.91.26 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/multiverse/dep11/icons-64x64.tar 400 Bad Request [IP: 91.189.91.26 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-toolkit-9-0 : Depends: cuda-samples-9-0 (>= 9.0.252) but it is not going to be installed
Depends: cuda-documentation-9-0 (>= 9.0.252) but it is not going to be installed
Depends: cuda-visual-tools-9-0 (>= 9.0.252) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Get:1 file:/var/cuda-repo-9-0-local InRelease
Ign:1 file:/var/cuda-repo-9-0-local InRelease
Get:2 file:/var/cuda-repo-9-0-local Release [574 B]
Hit:6 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:7 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease
Get:4 http://us.archive.ubuntu.com/ubuntu xenial InRelease [247 kB]
Ign:8 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Ign:9 http://security.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
Ign:10 http://security.ubuntu.com/ubuntu xenial-security/multiverse arm64 Packages
Get:5 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [102 kB]
Ign:11 http://us.archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
Ign:12 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe arm64 Packages
Ign:13 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
Err:8 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 91.189.88.162 80]
Get:14 http://us.archive.ubuntu.com/ubuntu xenial/main i386 Packages [1,196 kB]
Ign:15 http://us.archive.ubuntu.com/ubuntu xenial/main arm64 Packages
Get:16 http://us.archive.ubuntu.com/ubuntu xenial/main Translation-en [568 kB]
Ign:17 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 DEP-11 Metadata
Get:18 http://us.archive.ubuntu.com/ubuntu xenial/main DEP-11 64x64 Icons [409 kB]
Ign:19 http://us.archive.ubuntu.com/ubuntu xenial/restricted amd64 Packages
Get:20 http://us.archive.ubuntu.com/ubuntu xenial/restricted i386 Packages [8,684 B]
Ign:21 http://us.archive.ubuntu.com/ubuntu xenial/restricted Translation-en
Get:22 http://us.archive.ubuntu.com/ubuntu xenial/restricted amd64 DEP-11 Metadata [186 B]
Ign:23 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
Get:24 http://us.archive.ubuntu.com/ubuntu xenial/universe i386 Packages [7,512 kB]
Ign:25 http://us.archive.ubuntu.com/ubuntu xenial/universe arm64 Packages
Get:26 http://us.archive.ubuntu.com/ubuntu xenial/universe Translation-en [4,354 kB]
Ign:27 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 DEP-11 Metadata
Get:28 http://us.archive.ubuntu.com/ubuntu xenial/universe DEP-11 64x64 Icons [7,448 kB]
Ign:29 http://us.archive.ubuntu.com/ubuntu xenial/multiverse amd64 Packages
Get:30 http://us.archive.ubuntu.com/ubuntu xenial/multiverse i386 Packages [140 kB]
Ign:31 http://us.archive.ubuntu.com/ubuntu xenial/multiverse arm64 Packages
Get:32 http://us.archive.ubuntu.com/ubuntu xenial/multiverse Translation-en [106 kB]
Ign:33 http://us.archive.ubuntu.com/ubuntu xenial/multiverse amd64 DEP-11 Metadata
Get:34 http://us.archive.ubuntu.com/ubuntu xenial/multiverse DEP-11 64x64 Icons [230 kB]
Ign:35 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
Get:36 http://us.archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages [701 kB]
Ign:37 http://us.archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
Get:38 http://us.archive.ubuntu.com/ubuntu xenial-updates/main Translation-en [314 kB]
Ign:39 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 DEP-11 Metadata
Get:40 http://us.archive.ubuntu.com/ubuntu xenial-updates/main DEP-11 64x64 Icons [232 kB]
Ign:41 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 Packages
Get:42 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted i386 Packages [7,524 B]
Ign:43 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted Translation-en
Get:44 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 DEP-11 Metadata [157 B]
Ign:45 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages
Get:46 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [574 kB]
Ign:47 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe arm64 Packages
Get:48 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe Translation-en [250 kB]
Ign:49 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 DEP-11 Metadata
Get:50 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe DEP-11 64x64 Icons [322 kB]
Ign:51 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 Packages
Get:52 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse i386 Packages [15.3 kB]
Ign:53 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse arm64 Packages
Get:54 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse Translation-en [8,076 B]
Ign:55 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata
Get:56 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse DEP-11 64x64 Icons [14.3 kB]
Get:19 http://us.archive.ubuntu.com/ubuntu xenial/restricted amd64 Packages [8,344 B]
Get:23 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages [7,532 kB]
Get:27 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 DEP-11 Metadata [3,410 kB]
Get:35 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages [757 kB]
Get:39 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 DEP-11 Metadata [319 kB]
Get:43 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted Translation-en [2,272 B]
Get:51 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 Packages [16.2 kB]
Get:55 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata [5,972 B]
Err:17 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 DEP-11 Metadata
400 Bad Request [IP: 91.189.91.23 80]
Get:21 http://us.archive.ubuntu.com/ubuntu xenial/restricted Translation-en [3,019 B]
Get:29 http://us.archive.ubuntu.com/ubuntu xenial/multiverse amd64 Packages [176 kB]
Err:11 http://us.archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
404 Not Found [IP: 91.189.91.23 80]
Get:41 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 Packages [13.1 kB]
Get:45 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages [800 kB]
Get:49 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 DEP-11 Metadata [332 kB]
Err:37 http://us.archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
Fetched 2,420 kB in 39s (61.7 kB/s)
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.162 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/dep11/Components-amd64.yml 400 Bad Request [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 400 Bad Request [IP: 91.189.91.23 80]
cuda-cross-aarch64-9-0 : Depends: g++-aarch64-linux-gnu but it is not installable
