I am trying to figure out the best way to completely remove previously installed JetPack (on the host Ubuntu 16.04).
I have been trying to install JetPack 3.1, 3.0, 2.3.1 on Ubuntu 16.04 host(, mainly because I want to boot from USB drive later and naively editing extlinx.conf is not working for JetPack 3.1 and the exlinx.conf for JetPack 3.1 is different from that in 2.3.1 version, so I followed the JetHack posts to switch to JetPack 2.3.1)
Now the problem is when installing JetPack 2.3.1 AFTER having uninstalled JetPack 3.1, I will not be able to install cuda-toolkit-8.0 on the host Ubuntu 16.04:
At first I got error message like:
'file:/var/cuda-repo-8-0-local Release' does not have a Release file
And after remove file:/var/cuda-repo-8-0-local from app list, I still get unresolved/umet dependencies:
the following packages have unmet dependencies:
cuda-toolkit-8-0 : depends: cuda-samples-8-0 (>= 8.0.64) but it is not going to be installed
depends: cuda-documentation-8-0 (>= 8.0.64) but it is not going to be installed
e: unable to correct problems, you have held broken packages.
I can’t answer the JetPack question, but realize that the procedure for changing some of the values which were previously in extlinux.conf changed with R28.1. You might mention what it was you wanted to change but which did not…perhaps you don’t need to abandon R28.1.
Thanks Carolyuu:
Actually my “dpkg -l | grep cuda” outputs nothing from the start.
While my “sudo apt update” outputs following errors:
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.26 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.26 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Then I tried installing JetPack 2.3.1 on Ubuntu 16.04, and on the CUDA step, I still get following pop-up on installation, which stop the installtion:
Installing CUDA Toolkit for Ubuntu 16.04 8.0.34 failed.
Return Code: 1
Error installing cuda to host, please check /home/yerong/local/jetpack2/_installer/logs/cuda_host_tx1.log for more details
And at the end of the log file I recevied:
Fetched 459 kB in 1s (296 kB/s)
Reading package lists...
W: file:///var/cuda-repo-8-0-local/Release.gpg: Signature by key 889BEE522DA690103C4B085ED88C3D385C37D3BE uses weak digest algorithm (SHA1)
W: Invalid 'Date' entry in Release file /var/lib/apt/lists/partial/_var_cuda-repo-8-0-local_Release
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.161 80]
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-toolkit-8-0 : Depends: cuda-samples-8-0 (>= 8.0.64) but it is not going to be installed
Depends: cuda-documentation-8-0 (>= 8.0.64) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
There does exist a binary-amd64 subdirectory, but binary-arm64 does not exist. If you look within “/etc/apt/sources.list” the paths you have do not exist by default. Was your sources.list modified?
'universe' distribution component is already enabled for all sources.
And then “sudo apt-get update” still reports errors:
Ign:25 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Ign:31 http://security.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
Err:25 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 2001:67c:1560:8001::14 80]
Fetched 204 kB in 2s (95.3 kB/s)
Reading package lists... Done
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1562::19 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1562::19 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1560:8001::14 80]
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://us.archive.ubuntu.com/ubuntu/ xenial main restricted universe
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://us.archive.ubuntu.com/ubuntu/ xenial-updates main restricted universe
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://security.ubuntu.com/ubuntu xenial-security main restricted
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://security.ubuntu.com/ubuntu xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://security.ubuntu.com/ubuntu xenial-security multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
I found the error is caused by the JetPack2.3 installation script is querying a different version of cuda that its unpacked cuda. For instance in my /var/cuda-repo-8-0-local/ folder I have:
After this operation, 2,097 MB of additional disk space will be used.
Get:1 file:/var/cuda-repo-8-0-local cuda-license-8-0 8.0.64-1 [27.6 kB]
Err:1 file:/var/cuda-repo-8-0-local cuda-license-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-license-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:2 file:/var/cuda-repo-8-0-local cuda-misc-headers-8-0 8.0.64-1 [1,078 kB]
Err:2 file:/var/cuda-repo-8-0-local cuda-misc-headers-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-misc-headers-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:3 file:/var/cuda-repo-8-0-local cuda-core-8-0 8.0.64-1 [20.0 MB]
Err:3 file:/var/cuda-repo-8-0-local cuda-core-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-core-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:4 file:/var/cuda-repo-8-0-local cuda-cudart-8-0 8.0.64-1 [135 kB]
Err:4 file:/var/cuda-repo-8-0-local cuda-cudart-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cudart-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:5 file:/var/cuda-repo-8-0-local cuda-driver-dev-8-0 8.0.64-1 [14.1 kB]
Err:5 file:/var/cuda-repo-8-0-local cuda-driver-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-driver-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:6 file:/var/cuda-repo-8-0-local cuda-cudart-dev-8-0 8.0.64-1 [1,071 kB]
Err:6 file:/var/cuda-repo-8-0-local cuda-cudart-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cudart-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:7 file:/var/cuda-repo-8-0-local cuda-command-line-tools-8-0 8.0.64-1 [26.1 MB]
Err:7 file:/var/cuda-repo-8-0-local cuda-command-line-tools-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-command-line-tools-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:8 file:/var/cuda-repo-8-0-local cuda-cublas-8-0 8.0.64-1 [27.2 MB]
Err:8 file:/var/cuda-repo-8-0-local cuda-cublas-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cublas-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:9 file:/var/cuda-repo-8-0-local cuda-cublas-dev-8-0 8.0.64-1 [57.4 MB]
Err:9 file:/var/cuda-repo-8-0-local cuda-cublas-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cublas-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:10 file:/var/cuda-repo-8-0-local cuda-cufft-8-0 8.0.64-1 [117 MB]
Err:10 file:/var/cuda-repo-8-0-local cuda-cufft-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cufft-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:11 file:/var/cuda-repo-8-0-local cuda-cufft-dev-8-0 8.0.64-1 [94.8 MB]
Err:11 file:/var/cuda-repo-8-0-local cuda-cufft-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cufft-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:12 file:/var/cuda-repo-8-0-local cuda-curand-8-0 8.0.64-1 [43.7 MB]
Err:12 file:/var/cuda-repo-8-0-local cuda-curand-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-curand-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:13 file:/var/cuda-repo-8-0-local cuda-curand-dev-8-0 8.0.64-1 [67.7 MB]
Err:13 file:/var/cuda-repo-8-0-local cuda-curand-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-curand-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:14 file:/var/cuda-repo-8-0-local cuda-cusolver-8-0 8.0.64-1 [29.3 MB]
Err:14 file:/var/cuda-repo-8-0-local cuda-cusolver-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cusolver-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:15 file:/var/cuda-repo-8-0-local cuda-cusolver-dev-8-0 8.0.64-1 [6,816 kB]
Err:15 file:/var/cuda-repo-8-0-local cuda-cusolver-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cusolver-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:16 file:/var/cuda-repo-8-0-local cuda-cusparse-8-0 8.0.64-1 [28.8 MB]
Err:16 file:/var/cuda-repo-8-0-local cuda-cusparse-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cusparse-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:17 file:/var/cuda-repo-8-0-local cuda-cusparse-dev-8-0 8.0.64-1 [29.6 MB]
Err:17 file:/var/cuda-repo-8-0-local cuda-cusparse-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-cusparse-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:18 file:/var/cuda-repo-8-0-local cuda-nvrtc-8-0 8.0.64-1 [9,584 kB]
Err:18 file:/var/cuda-repo-8-0-local cuda-nvrtc-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-nvrtc-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:19 file:/var/cuda-repo-8-0-local cuda-nvrtc-dev-8-0 8.0.64-1 [10.8 kB]
Err:19 file:/var/cuda-repo-8-0-local cuda-nvrtc-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-nvrtc-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:20 file:/var/cuda-repo-8-0-local cuda-npp-8-0 8.0.64-1 [157 MB]
Err:20 file:/var/cuda-repo-8-0-local cuda-npp-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-npp-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:21 file:/var/cuda-repo-8-0-local cuda-npp-dev-8-0 8.0.64-1 [82.3 MB]
Err:21 file:/var/cuda-repo-8-0-local cuda-npp-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-npp-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:22 file:/var/cuda-repo-8-0-local cuda-samples-8-0 8.0.64-1 [101 MB]
Err:22 file:/var/cuda-repo-8-0-local cuda-samples-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-samples-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:23 file:/var/cuda-repo-8-0-local cuda-documentation-8-0 8.0.64-1 [113 MB]
Err:23 file:/var/cuda-repo-8-0-local cuda-documentation-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-documentation-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:24 file:/var/cuda-repo-8-0-local cuda-nvgraph-8-0 8.0.64-1 [2,948 kB]
Err:24 file:/var/cuda-repo-8-0-local cuda-nvgraph-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-nvgraph-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:25 file:/var/cuda-repo-8-0-local cuda-nvgraph-dev-8-0 8.0.64-1 [3,028 kB]
Err:25 file:/var/cuda-repo-8-0-local cuda-nvgraph-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-nvgraph-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:26 file:/var/cuda-repo-8-0-local cuda-nvml-dev-8-0 8.0.64-1 [48.4 kB]
Err:26 file:/var/cuda-repo-8-0-local cuda-nvml-dev-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-nvml-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:27 file:/var/cuda-repo-8-0-local cuda-visual-tools-8-0 8.0.64-1 [286 MB]
Err:27 file:/var/cuda-repo-8-0-local cuda-visual-tools-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-visual-tools-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
Get:28 file:/var/cuda-repo-8-0-local cuda-toolkit-8-0 8.0.64-1 [2,900 B]
Err:28 file:/var/cuda-repo-8-0-local cuda-toolkit-8-0 8.0.64-1
File not found - /var/cuda-repo-8-0-local/./cuda-toolkit-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
W: --force-yes is deprecated, use one of the options starting with --allow instead.
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-license-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-license-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-misc-headers-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-misc-headers-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-core-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-core-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cudart-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cudart-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-driver-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-driver-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cudart-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cudart-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-command-line-tools-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-command-line-tools-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cublas-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cublas-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cublas-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cublas-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cufft-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cufft-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cufft-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cufft-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-curand-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-curand-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-curand-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-curand-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cusolver-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cusolver-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cusolver-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cusolver-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cusparse-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cusparse-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-cusparse-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-cusparse-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-nvrtc-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-nvrtc-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-nvrtc-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-nvrtc-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-npp-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-npp-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-npp-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-npp-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-samples-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-samples-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-documentation-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-documentation-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-nvgraph-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-nvgraph-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-nvgraph-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-nvgraph-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-nvml-dev-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-nvml-dev-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-visual-tools-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-visual-tools-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-8-0-local/./cuda-toolkit-8-0_8.0.64-1_amd64.deb File not found - /var/cuda-repo-8-0-local/./cuda-toolkit-8-0_8.0.64-1_amd64.deb (2: No such file or directory)
This means JetPack 2.3 is actually looking for /var/cuda-repo-8-0-local/cuda-curand-8-0_8.0.64-1_amd64.deb
I’ll see what I can add in the other link you gave for USB boot…I don’t want to have multiple threads for the same thing.
“amd64.deb” is not a Jetson package…this is for a desktop PC and is not capable of being used on arm64/aarch64. The fact that your Jetson is trying to use this is worrisome…I’m not sure how your Jetson came to think it was a desktop PC :P Were those files in “/usr/local” installed via JetPack? Something has mixed up your package system.
It proves a cuda conflict: since for a while I was trying to install cuada 8.0.64 on desktop and ubuntu (desktop) kept asking for that version of cuda, while jetson is installing a different version of it. (e.g. JetPack 2.3.1 is installing cuda 8.0.34 and JetPack 3.0 is installing cuda 8.0.84)
