I’m running Ubuntu 16.04 and running into issues when I’m trying to install the CUDAToolkit to host. It keeps trying to add an arm64 repository that Xenial doesn’t seem to have.
Version: 9.0
DashedVersion: 9-0
root 18658 0.1 0.0 265364 3372 ? Ssl 08:28 0:02 /home/nvidia/jetpack32final/_installer/sudo_daemon -installer=18533 -d=/home/nvidia/jetpack32final/_installer/tmp
0
/home/nvidia/jetpack32final//_installer/run_command -c="dpkg -i --force-overwrite /home/nvidia/jetpack32final/jetpack_download/cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb; apt-key add /var/cuda-repo-9-0-local/*.pub; apt-get update; apt-get install -y --force-yes cuda-toolkit-9-0; dpkg --add-architecture arm64;apt-get update; apt-get -y --force-yes install cuda-toolkit-9-0 cuda-cross-aarch64-9-0" -d=/home/nvidia/jetpack32final//_installer/tmp -l=/home/nvidia/jetpack32final/_installer/logs//cuda_host_9.0.log
(Reading database ... 301779 files and directories currently installed.)
Preparing to unpack .../cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb ...
Unpacking cuda-repo-ubuntu1604-9-0-local (9.0.252-1) over (9.0.252-1) ...
Setting up cuda-repo-ubuntu1604-9-0-local (9.0.252-1) ...
OK
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://dl.google.com/linux/chrome/deb stable Release
Hit:3 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial InRelease
Hit:4 http://archive.ubuntu.com/ubuntu xenial InRelease
Hit:6 https://download.docker.com/linux/ubuntu xenial InRelease
Hit:7 http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial InRelease
Hit:8 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:9 http://ppa.launchpad.net/mystic-mirage/pycharm/ubuntu xenial InRelease
Ign:10 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Err:10 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
404 Not Found
Ign:11 http://archive.ubuntu.com/ubuntu xenial/main arm64 Packages
Err:11 http://archive.ubuntu.com/ubuntu xenial/main arm64 Packages
404 Not Found
Reading package lists...
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
cuda-toolkit-9-0 is already the newest version (9.0.252-1).
The following packages were automatically installed and are no longer required:
gir1.2-gtk-2.0 libatk1.0-dev libcairo-script-interpreter2 libcairo2-dev
libfontconfig1-dev libfreetype6-dev libgdk-pixbuf2.0-dev libglib2.0-dev
libgtk2.0-dev libgtkglext1 libharfbuzz-dev libharfbuzz-gobject0
libpango1.0-dev libpcre3-dev libpcre32-3 libpcrecpp0v5 libpixman-1-dev
libxcb-shm0-dev libxcomposite-dev libxcursor-dev libxft-dev libxinerama-dev
libxml2-utils libxrandr-dev libxrender-dev linux-headers-4.10.0-28
linux-headers-4.10.0-28-generic linux-image-4.10.0-28-generic
linux-image-extra-4.10.0-28-generic x11proto-composite-dev
x11proto-randr-dev x11proto-render-dev x11proto-xinerama-dev
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Hit:4 https://download.docker.com/linux/ubuntu xenial InRelease
Hit:5 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial InRelease
Hit:6 http://archive.ubuntu.com/ubuntu xenial InRelease
Hit:7 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:8 http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial InRelease
Ign:10 http://archive.ubuntu.com/ubuntu xenial/main arm64 Packages
Ign:11 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Err:10 http://archive.ubuntu.com/ubuntu xenial/main arm64 Packages
404 Not Found
Err:11 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
404 Not Found
E: Unable to locate package cuda-cross-aarch64-9-0
What’s odd is it seems to ignore the repository and then error after it. I am running this out of my home directory. I know there’s some funkiness with file permissions on extraction. I’ve tried removing all arm64 packages and repos with:
I’m having the same problem… below is the last part of the file cuda_host_9.0.log
Any ideas on how to install cuda_cross-aarch64-9-0?
Preparing to unpack .../cuda-toolkit-9-0_9.0.176-1_amd64.deb ...
Unpacking cuda-toolkit-9-0 (9.0.176-1) ...
Setting up cuda-license-9-0 (9.0.176-1) ...
*** LICENSE AGREEMENT ***
By using this software you agree to fully comply with the terms and
conditions of the EULA (End User License Agreement). The EULA is located
at /usr/local/cuda-9.0/doc/EULA.txt. The EULA can also be found at
http://docs.nvidia.com/cuda/eula/index.html. If you do not agree to the
terms and conditions of the EULA, do not use the software.
Setting up cuda-misc-headers-9-0 (9.0.176-1) ...
Setting up cuda-core-9-0 (9.0.176-1) ...
Setting up cuda-cudart-9-0 (9.0.176-1) ...
Setting up cuda-driver-dev-9-0 (9.0.176-1) ...
Setting up cuda-cudart-dev-9-0 (9.0.176-1) ...
Setting up cuda-command-line-tools-9-0 (9.0.176-1) ...
Setting up cuda-cublas-9-0 (9.0.176.2-1) ...
Setting up cuda-cublas-dev-9-0 (9.0.176.2-1) ...
Setting up cuda-cufft-9-0 (9.0.176-1) ...
Setting up cuda-cufft-dev-9-0 (9.0.176-1) ...
Setting up cuda-curand-9-0 (9.0.176-1) ...
Setting up cuda-curand-dev-9-0 (9.0.176-1) ...
Setting up cuda-cusolver-9-0 (9.0.176-1) ...
Setting up cuda-cusolver-dev-9-0 (9.0.176-1) ...
Setting up cuda-cusparse-9-0 (9.0.176-1) ...
Setting up cuda-cusparse-dev-9-0 (9.0.176-1) ...
Setting up cuda-nvrtc-9-0 (9.0.176-1) ...
Setting up cuda-nvrtc-dev-9-0 (9.0.176-1) ...
Setting up cuda-npp-9-0 (9.0.176-1) ...
Setting up cuda-npp-dev-9-0 (9.0.176-1) ...
Setting up cuda-nvgraph-9-0 (9.0.176-1) ...
Setting up cuda-nvgraph-dev-9-0 (9.0.176-1) ...
Setting up cuda-samples-9-0 (9.0.176-1) ...
Setting up cuda-documentation-9-0 (9.0.176-1) ...
Setting up cuda-libraries-dev-9-0 (9.0.176-1) ...
Setting up cuda-nvml-dev-9-0 (9.0.176-1) ...
Setting up cuda-visual-tools-9-0 (9.0.176-1) ...
Setting up cuda-toolkit-9-0 (9.0.176-1) ...
Processing triggers for libc-bin (2.23-0ubuntu10) ...
W: --force-yes is deprecated, use one of the options starting with --allow instead.
Hit:1 http://archive.canonical.com/ubuntu xenial InRelease
Hit:2 http://archive.ubuntu.com/ubuntu xenial InRelease
Ign:3 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:4 http://ppa.launchpad.net/rael-gc/scudcloud/ubuntu xenial InRelease
Hit:5 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:6 http://dl.google.com/linux/chrome/deb stable Release
Hit:7 http://archive.ubuntu.com/ubuntu xenial-backports InRelease
Hit:8 http://deb.torproject.org/torproject.org xenial InRelease
Hit:9 http://archive.ubuntu.com/ubuntu xenial-security InRelease
Ign:10 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 InRelease
Hit:11 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 Release
Hit:12 https://dl.winehq.org/wine-builds/ubuntu xenial InRelease
Hit:13 https://nvidia.github.io/libnvidia-container/ubuntu16.04/amd64 InRelease
Hit:14 https://nvidia.github.io/nvidia-container-runtime/ubuntu16.04/amd64 InRelease
Hit:15 https://download.docker.com/linux/ubuntu xenial InRelease
Get:16 https://nvidia.github.io/nvidia-docker/ubuntu16.04/amd64 InRelease [1 096 B]
Fetched 1 096 B in 1s (621 B/s)
Hi WayneWWW,
yes I’m also using Ubuntu 16.04 and I was using Cuda8 until I decided to retake my Jetson project and saw the new Jetpack3.2 in an email. I did a sudo apt-get update + sudo apt-get install cuda and got the last version installed (9.1.85-1) without any problems and it seems my card drivers were also updated without problems. Restarted and saw that /usr/local/cuda is now pointing to cuda-9.1 but the old cuda-8.0 folder is still there. Then I executed the JetPack-L4T-3.2-linux-x64_b196.run and it seems it installed cuda-9.0.176-1 and now /usr/local/cuda points to cuda-9.0. The problem is that the Jetpack3.2 installer stopped when trying to find cuda-cross-aarch64-9-0 which I can’t find wither on the web.
Below there is some info about my systems as of today.
I think the cause of this issue is from jetpack, which does not detect your cuda 9.1. Jetapck expects a clean environment but it turns out not. We got some issues on 16.04 host when there is pre-installed package. The quick way to resolve this issue is uninstall the cuda 9.1 manually.
Really sorry for inconvenience. I will report this issue to enhance jetpack.
Hi again,
I tried your suggestion, uninstall Cuda 9.1 manually and Ii also erased Cuda 8.0 and Cuda 9.0 and the symbolic links and all references to Cuda from my PATH and LD_LIBRARY_PATH. Then I run the Jetpack installer again and I get the same error.
I guess that if there are no other suggestions I’ll have to try and use JetPack 3.1
Yes, I see it inside /var/cuda-repo-9-0-local but I don’t see that file inside the download folder of Jetpack in my home directory. There are two files inside /var/cuda-repo-9-0-local:
When I tried to install cuda-cross-aarch64-9-0_9.0.252-1_amd64.deb
dpkg: dependency problems prevent configuration of cuda-cross-aarch64-9-0:
cuda-cross-aarch64-9-0 depends on cuda-toolkit-9-0; however:
Package cuda-toolkit-9-0 is not installed.
cuda-cross-aarch64-9-0 depends on g++-aarch64-linux-gnu; however:
Package g++-aarch64-linux-gnu is not installed.
and I had to add additional Ubuntu source archive:
https://launchpad.net/ubuntu xenial main
because there is no arm64 directory on the main us.ubuntu.com
This didn’t work for me, it stops after a warning saying that there is no Release file in that repository and that the repository can’t be authenticated. It fails to fetch packages and stops.
However the following lines worked:
Thanks for the suggestion!
Boris
PS: I have now a freshly flashed Jetson TX2 but I can’t find any samples or “/home/ubuntu/NVIDIA_CUDA-_Samples/bin/aarch64/linux/release/” folder as it’s described in the instructions manual. Any ideas why or where to find the samples?
I have a laptop I ran 3.2 from…I specifically checked to not delete temporary files after running…I don’t know if this applies to that directory or not. On this laptop the install location was “/home/ubuntu/Jetson_3.2/”. As a result the laptop has:
This of course requires sample code install to be checked and after done not deleted. The Jetson itself is the one which has “/home/ubuntu/NVIDIA_CUDA-9.0_Samples/”.
NOTE: Just realized probably the host would have the “/home/ubuntu/NVIDIA_…” if this laptop had an NVIDIA video card/CUDA…but you did mention aarch64 which would never be installed directly to a bin directory on the host (those CUDA files are a side-effect of installing them to the Jetson).
I have a similar problem. I am installing JetPack 3.2. I get the message:
E: Unable to locate package cuda-toolkit-8-0-82
E: Unable to locate package cuda-cross_aarch64-8-0-82
I have the following in var directory:
cuda-repo-8-0-local
cuda-repo-9-0-local
For this specific case are you attempting to install CUDA to host or to Jetson?
FYI, the CUDA repo package is the one which tells the operating system that the “/var” files are for those package requests. For example, on R28.2 on the Jetson itself there is this file (version changes depending on release…arm64 is for Jetson, amd64 is for host PC, armhf is for older 32-bit ARM):
cuda-repo-l4t-9-0-local_9.0.252-1_arm64.deb
(R28.2.1 is out, I haven’t looked yet to see what the exact repo file name is)
Installing the files in “/var” purely by copy would leave the operating system not knowing those are packages and thus even if in place those packages would not be visible. Installing via a repo “.deb” package means “apt” tools can find this. JetPack always installs the repo package first. Are you installing via JetPack or trying to install manually? If manually, then it means you didn’t update apt to know the local repo is there.
FYI, the more recent JetPack releases won’t contain the older version 8 CUDA. Are you looking for a specific CUDA release?
