Hi
I have an error installing jetpack 3.1 to Nvidia TX1.CUDA in jetpack cannot connect to tx1, here is error message:
Connection to 192.168.182.83 closed
dpkg-query: package cuda-toolkit-8-0
is not installed and no information is available
dpkg-query: package libfreeimage-dev
dpkg-query: package libopenmpi-dev
dpkg-query: package openmpi-bin
Use dpkg --info (= dpkg-deb --info) to examine archive files,
And dpkg–contents (=dpkg-deb --contents) to list their contents.
1
Error:CUDA cannot be installed on device. This may be caused by other apt-get command running on device when installing CUDA, Please use apt-get command in a terminal to make sure following packages are installed correctly on device before continuing:
cuda-toolkit-8-0 libfreeimage-dev libopenmpi-dev openmpi-bin
After these packages are installed on device, press Enter key to continue
I guess my host Ubuntu version is 14.04, but Jetpack 3.1 need to host Ubuntu 16.04. Otherwise, my tx1 ubuntu version is 14.04, but when I following the jetpack 3.1 installation steps, and my tx1 renew 16.04. Can cuda 8.0 install on only 16.04 on host? If I install old jetpack version to host(ex: jetpack 2.3.1), can solve this problem?
