I am working with an Ubuntu 16.04 host PC (desktop) with 800GB available and a TX2, attempting to flash Jetpack 3.3.
If I take off CUDA and its dependencies, I am able to successfully install everything else and flash it to the TX2.
But… I need CUDA.
If I do everything the same but leave CUDA as “install” rather than “no action,” everything downloads (or at least it says download complete), but it gets stuck in the terminal at the installation with the error
E: Unable to locate package cuda-toolkit-9-0
E: Unable to locate package cuda-cross-aarch64-9-0
Here is the log:
Selecting previously unselected package cuda-repo-ubuntu1604-9-0-local.
(Reading database … 195541 files and directories currently installed.)
Preparing to unpack …/cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb …
Unpacking cuda-repo-ubuntu1604-9-0-local (9.0.252-1) …
dpkg: error processing archive /media/ubuntu/F61A01961A015551/Amy/jetpack_download/cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb (–install):
cannot copy extracted data for ‘./var/cuda-repo-9-0-local/nvidia-384_384.103-0ubuntu1_amd64.deb’ to ‘/var/cuda-repo-9-0-local/nvidia-384_384.103-0ubuntu1_amd64.deb.dpkg-new’: failed to write (No space left on device)
dpkg-deb (subprocess): decompressing archive member: lzma write error: Broken pipe
dpkg-deb: error: subprocess returned error exit status 2
dpkg-deb (subprocess): cannot copy archive member from ‘/media/ubuntu/F61A01961A015551/Amy/jetpack_download/cuda-repo-ubuntu1604-9-0-local_9.0.252-1_amd64.deb’ to decompressor pipe: failed to write (Broken pipe)
Errors were encountered while processing:
gpg: can’t open `/var/cuda-repo-9-0-local/*.pub’: No such file or directory
Ign:1 cdrom://Ubuntu 16.04.4 LTS Xenial Xerus - Release amd64 (20180228) xenial InRelease
Hit:2 cdrom://Ubuntu 16.04.4 LTS Xenial Xerus - Release amd64 (20180228) xenial Release
Hit:4 Index of /ubuntu xenial InRelease
Get:5 Index of /ubuntu xenial-updates InRelease [109 kB]
Get:6 Index of /ubuntu xenial-security InRelease [107 kB]
Get:7 Index of /ubuntu xenial/main amd64 DEP-11 Metadata [733 kB]
Get:8 Index of /ubuntu xenial/main DEP-11 64x64 Icons [409 kB]
Get:9 Index of /ubuntu xenial/restricted amd64 DEP-11 Metadata [186 B]
Get:10 Index of /ubuntu xenial-updates/main amd64 Packages [892 kB]
Get:11 Index of /ubuntu xenial-security/main amd64 Packages [589 kB]
Get:12 Index of /ubuntu xenial-updates/main Translation-en [361 kB]
Get:13 Index of /ubuntu xenial-updates/main amd64 DEP-11 Metadata [320 kB]
Get:14 Index of /ubuntu xenial-updates/main DEP-11 64x64 Icons [235 kB]
Get:15 Index of /ubuntu xenial-updates/restricted amd64 Packages [7,556 B]
Get:16 Index of /ubuntu xenial-updates/restricted Translation-en [2,272 B]
Get:17 Index of /ubuntu xenial-updates/restricted amd64 DEP-11 Metadata [157 B]
Get:18 Index of /ubuntu xenial-security/main Translation-en [245 kB]
Get:19 Index of /ubuntu xenial-security/main amd64 DEP-11 Metadata [67.7 kB]
Get:20 Index of /ubuntu xenial-security/main DEP-11 64x64 Icons [68.0 kB]
Get:21 Index of /ubuntu xenial-security/restricted amd64 Packages [7,204 B]
Get:22 Index of /ubuntu xenial-security/restricted Translation-en [2,152 B]
Get:23 Index of /ubuntu xenial-security/restricted amd64 DEP-11 Metadata [200 B]
** (appstreamcli:5206): CRITICAL **: Error while moving old database out of the way.
AppStream cache update failed.
Fetched 4,156 kB in 1s (2,232 kB/s)
Reading package lists…
Building dependency tree…
Reading state information…
Hit:5 Index of /ubuntu xenial-updates InRelease
Hit:6 Index of /ubuntu xenial-security InRelease
Ign:7 Index of /ubuntu xenial/main arm64 Packages
Ign:8 Index of /ubuntu xenial-updates/main arm64 Packages
Ign:9 Index of /ubuntu xenial-security/main arm64 Packages
Err:7 Index of /ubuntu xenial/main arm64 Packages
404 Not Found [IP: 91.189.88.152 80]
Err:8 Index of /ubuntu xenial-updates/main arm64 Packages
Err:9 Index of /ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 91.189.91.26 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.26 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Thanks in advance!
