Hi! When I install JetPack 2.2, L4T 24.1, 64bit, I got error.
Error: CUDA cannot be installed in device. This may be caused by other apt-get command running on device when installing CUDA. Please use apt-get command in a terminal to make sure following packages are installed correctly on device before continuing:
cuda-toolkit-7-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
After these packages are installed on device, press Enter key to continue
I try to install these softwares ,but failed.
It shows " Some packages could not be installed . This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming"
“E:Unable to correct problems, you have held broken packages.”
I try to “sudo apt-get update” ,but it tells me “failed to fetch bzip2:/…/…” “E:Some index files failed to download. they have been ignored, or old ones used instead.”
How can I do next ?
