When running Jetpack 2.0 I encounter this error message during the process of flashing the Jetson TK1(when I have put it in the forced recovery mode):
Error: CUDA cannot be installed on device. Please use apt-get command in a terminal to make sure following packages are installed correctly on device before continuing:
cuda-toolkit-7-0 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
After these packages are installed on device, press Enter key to continue
Upon trying to install cuda-toolkit-7-0 I got an error of inability to get the file. I then downloaded cuda-toolkit-7-0_7.0-28_amd64.deb but the system could not get the file. I then downloaded cuda-repo-ubuntu1404-7-0-local_7.0-28_amd64.deb, libfreeimage-dev_3.15.1-1_amd64.deb, libgomp1_4.8.2-19ubuntu1_amd64.deb, libopenmpi-dev_1.6.5-8_amd64.deb and openmpi-bin_1.6.5-8_amd64.deb. I installed them but upon pressing enter as instructed the XTerm could not continue.
I canceled the process and tried reinstalling it but experienced the same problem.
How can I go about this?
Thank you.
