I tried to use the new SDK Manager to install JetPack 4.2 to TX2 but failed.
Here is the error log:
DETAILS TERMINAL
14:33:47 INFO : null
14:33:51 DEBUG : running command < sudo rm -rf /home/lp057/Documents/SDK Manager Download/JetPack_4.2_Linux_P3310 >
14:33:51 INFO : command finished successfully
14:33:51 INFO : OpenCV on Target : Found file /home/lp057/Documents/SDK Manager Download/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:33:51 INFO : OpenCV on Target : Found file /home/lp057/Documents/SDK Manager Download/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:33:51 INFO : OpenCV on Target : Found file /home/lp057/Documents/SDK Manager Download/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : OpenCV on Target : Found file /home/lp057/Documents/SDK Manager Download/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Found file /home/lp057/Documents/SDK Manager Download/Jetson_Linux_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : download 'Drivers for Jetson TX2 & TX2i' success
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Start to install 'Drivers for Jetson TX2 & TX2i'
14:33:52 DEBUG : Drivers for Jetson TX2 & TX2i : running command < cd '/home/lp057/Documents/SDK Manager Download/JetPack_4.2_Linux_P3310' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_DRIVERS_TX2_COMP' -v='32.1' -l='/home/lp057/Documents/SDK Manager Download/JetPack_4.2_Linux_P3310' -L='/home/lp057/.nvsdkm/logs/JetPack_4.2_Linux' -p='18533' -t='P3310' -e='/home/lp057/Documents/SDK Manager Download/Jetson_Linux_R32.1.0_aarch64.tbz2' >
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : [ Disk Avail:9.37 GB ]
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Using GenericInstaller to Install NV_L4T_DRIVERS_TX2_COMP
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : NV_L4T_DRIVERS_TX2_COMP include 1 package
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : enter working directory: /home/lp057/Documents/SDK Manager Download/JetPack_4.2_Linux_P3310
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : [ Package Install Started ]
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : current working directory is /home/lp057/Documents/SDK Manager Download/JetPack_4.2_Linux_P3310
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : exec_command [host]:
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : **********************
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : #!/bin/bash
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : set -e
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : sudo apt-get update || true; sudo apt-get install -y pigz lbzip2
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : tar xpf /home/lp057/Documents/SDK Manager Download/Jetson_Linux_R32.1.0_aarch64.tbz2
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : exec_command: /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh
14:33:52 INFO : cuDNN on Target : Found file /home/lp057/Documents/SDK Manager Download/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Get:1 file:/var/cuda-repo-10-0-local-10.0.117-410.38 InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Ign:1 file:/var/cuda-repo-10-0-local-10.0.117-410.38 InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Get:2 file:/var/cuda-repo-9-0-local InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Ign:2 file:/var/cuda-repo-9-0-local InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Get:3 file:/var/cuda-repo-10-0-local-10.0.117-410.38 Release [574 B]
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Get:4 file:/var/cuda-repo-9-0-local Release [574 B]
14:33:52 INFO : cuDNN on Target : Found file /home/lp057/Documents/SDK Manager Download/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Ign:6 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Hit:7 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 Release
14:33:52 INFO : cuDNN on Target : Found file /home/lp057/Documents/SDK Manager Download/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Ign:10 http://dl.google.com/linux/chrome/deb stable InRelease
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Hit:11 https://repo.skype.com/deb stable InRelease
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Hit:12 http://dl.google.com/linux/chrome/deb stable Release
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Hit:13 http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu xenial InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Hit:15 http://us.archive.ubuntu.com/ubuntu xenial InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Hit:19 http://ppa.launchpad.net/webupd8team/java/ubuntu xenial InRelease
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Get:17 http://security.ubuntu.com/ubuntu xenial-security InRelease [109 kB]
14:33:52 INFO : Drivers for Jetson TX2 & TX2i : Get:16 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:20 http://us.archive.ubuntu.com/ubuntu xenial/main arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:21 http://us.archive.ubuntu.com/ubuntu xenial/universe arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:22 http://us.archive.ubuntu.com/ubuntu xenial/multiverse arm64 Packages
14:33:53 INFO : TensorRT on Target : Found file /home/lp057/Documents/SDK Manager Download/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:18 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
14:33:53 INFO : CUDA Toolkit for L4T : Found file /home/lp057/Documents/SDK Manager Download/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
14:33:53 INFO : VisionWorks on Target : Found file /home/lp057/Documents/SDK Manager Download/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
14:33:53 INFO : VisionWorks on Target : Found file /home/lp057/Documents/SDK Manager Download/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
14:33:53 INFO : VisionWorks on Target : Found file /home/lp057/Documents/SDK Manager Download/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:23 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages [925 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:24 http://us.archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages [807 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:25 http://us.archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:26 http://us.archive.ubuntu.com/ubuntu xenial-updates/main Translation-en [372 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:27 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 DEP-11 Metadata [318 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:28 http://us.archive.ubuntu.com/ubuntu xenial-updates/main DEP-11 64x64 Icons [232 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:29 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 Packages [7,616 B]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:30 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted i386 Packages [7,580 B]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:31 http://us.archive.ubuntu.com/ubuntu xenial-updates/restricted Translation-en [2,272 B]
14:33:53 INFO : Multimedia API : Found file /home/lp057/Documents/SDK Manager Download/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:32 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages [626 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:33 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages [740 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:34 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [678 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:35 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:36 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe Translation-en [307 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:37 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 DEP-11 Metadata [252 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:38 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe DEP-11 64x64 Icons [350 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:39 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 Packages [16.7 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:40 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse i386 Packages [15.8 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:41 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:42 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata [5,960 B]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:43 http://security.ubuntu.com/ubuntu xenial-security/main i386 Packages [524 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:44 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:45 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse DEP-11 64x64 Icons [14.3 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:46 http://us.archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:47 http://us.archive.ubuntu.com/ubuntu xenial-backports/main amd64 DEP-11 Metadata [3,328 B]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:48 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:49 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe amd64 DEP-11 Metadata [5,104 B]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:50 http://security.ubuntu.com/ubuntu xenial-security/main Translation-en [259 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:51 http://security.ubuntu.com/ubuntu xenial-security/main amd64 DEP-11 Metadata [67.9 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:52 http://security.ubuntu.com/ubuntu xenial-security/main DEP-11 64x64 Icons [64.6 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:53 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 Packages [430 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:54 http://security.ubuntu.com/ubuntu xenial-security/universe i386 Packages [374 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Ign:55 http://security.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:56 http://security.ubuntu.com/ubuntu xenial-security/universe Translation-en [173 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Get:57 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 DEP-11 Metadata [116 kB]
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : Err:20 http://us.archive.ubuntu.com/ubuntu xenial/main arm64 Packages
14:33:53 INFO : Drivers for Jetson TX2 & TX2i : 404 Not Found [IP: 2001:67c:1562::16 80]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:22 http://us.archive.ubuntu.com/ubuntu xenial/multiverse arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:25 http://us.archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Get:58 http://security.ubuntu.com/ubuntu xenial-security/universe DEP-11 64x64 Icons [173 kB]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Get:59 http://security.ubuntu.com/ubuntu xenial-security/multiverse amd64 Packages [5,604 B]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Get:60 http://security.ubuntu.com/ubuntu xenial-security/multiverse i386 Packages [5,764 B]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:61 http://security.ubuntu.com/ubuntu xenial-security/multiverse arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Get:62 http://security.ubuntu.com/ubuntu xenial-security/multiverse Translation-en [2,676 B]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Get:63 http://security.ubuntu.com/ubuntu xenial-security/multiverse amd64 DEP-11 Metadata [2,464 B]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Get:64 http://security.ubuntu.com/ubuntu xenial-security/multiverse DEP-11 64x64 Icons [2,638 B]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:44 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:55 http://security.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:35 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:41 http://us.archive.ubuntu.com/ubuntu xenial-updates/multiverse arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:46 http://us.archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Ign:48 http://us.archive.ubuntu.com/ubuntu xenial-backports/universe arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Err:25 http://us.archive.ubuntu.com/ubuntu xenial-updates/main arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : 404 Not Found [IP: 2001:67c:1562::16 80]
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Err:46 http://us.archive.ubuntu.com/ubuntu xenial-backports/main arm64 Packages
14:33:54 INFO : File System and OS : Found file /home/lp057/Documents/SDK Manager Download/Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
14:33:54 INFO : File System and OS : download 'File System and OS' success
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : Err:44 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
14:33:54 INFO : Drivers for Jetson TX2 & TX2i : 404 Not Found [IP: 2001:67c:1360:8001::21 80]
14:33:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:55 http://security.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
14:33:55 INFO : Drivers for Jetson TX2 & TX2i : Ign:61 http://security.ubuntu.com/ubuntu xenial-security/multiverse arm64 Packages
14:33:55 INFO : Drivers for Jetson TX2 & TX2i : Fetched 325 kB in 2s (111 kB/s)
14:33:56 INFO : Drivers for Jetson TX2 & TX2i : Reading package lists...
14:33:56 ERROR : Drivers for Jetson TX2 & TX2i : E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1562::16 80]
14:33:56 INFO : Drivers for Jetson TX2 & TX2i : E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1562::16 80]
14:33:56 INFO : Drivers for Jetson TX2 & TX2i : E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1562::16 80]
14:33:56 INFO : Drivers for Jetson TX2 & TX2i : E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 2001:67c:1360:8001::21 80]
14:33:56 INFO : Drivers for Jetson TX2 & TX2i : E: Some index files failed to download. They have been ignored, or old ones used instead.
14:33:56 INFO : Drivers for Jetson TX2 & TX2i : Building dependency tree...
14:33:56 INFO : Drivers for Jetson TX2 & TX2i : Reading state information...
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : lbzip2 is already the newest version (2.5-1).
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : pigz is already the newest version (2.3.1-2).
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : The following packages were automatically installed and are no longer required:
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : android-libbacktrace android-libbase android-libcutils android-libext4-utils
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : android-libf2fs-utils android-liblog android-libselinux android-libsparse
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : android-libunwind android-libutils android-libziparchive
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-command-line-tools-10-1 cuda-compiler-10-1 cuda-cudart-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-cudart-dev-10-1 cuda-cufft-10-1 cuda-cufft-dev-10-1 cuda-cuobjdump-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-cupti-10-1 cuda-curand-10-1 cuda-curand-dev-10-1 cuda-cusolver-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-cusolver-dev-10-1 cuda-cusparse-10-1 cuda-cusparse-dev-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-documentation-10-1 cuda-driver-dev-10-1 cuda-gdb-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-gpu-library-advisor-10-1 cuda-libraries-10-1 cuda-libraries-dev-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-license-10-1 cuda-memcheck-10-1 cuda-misc-headers-10-1 cuda-npp-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-npp-dev-10-1 cuda-nsight-10-1 cuda-nsight-compute-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-nsight-systems-10-1 cuda-nvcc-10-1 cuda-nvdisasm-10-1 cuda-nvgraph-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-nvgraph-dev-10-1 cuda-nvjpeg-10-1 cuda-nvjpeg-dev-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-nvml-dev-10-1 cuda-nvprof-10-1 cuda-nvprune-10-1 cuda-nvrtc-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-nvrtc-dev-10-1 cuda-nvtx-10-1 cuda-nvvp-10-1 cuda-samples-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-sanitizer-api-10-1 cuda-toolkit-10-1 cuda-tools-10-1
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : cuda-visual-tools-10-1 libcublas-dev libcublas10 libf2fs0
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : Use 'sudo apt autoremove' to remove them.
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
14:33:57 ERROR : Drivers for Jetson TX2 & TX2i : tar: /home/lp057/Documents/SDK: Cannot open
14:33:57 ERROR : Drivers for Jetson TX2 & TX2i : : No such file or directory
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : tar:
14:33:57 ERROR : Drivers for Jetson TX2 & TX2i : Error is not recoverable: exiting now
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : exit status 2
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : [ Package Install Finished with Error ]
14:33:57 ERROR : Drivers for Jetson TX2 & TX2i : NV_L4T_DRIVERS_TX2_COMP command /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh finished with error
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : [ 28.00 KB used. Disk Avail: 9.37 GB ]
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : [ NV_L4T_DRIVERS_TX2_COMP Install took 5s ]
14:33:57 INFO : Drivers for Jetson TX2 & TX2i : command /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh finished with error
14:33:57 ERROR : Drivers for Jetson TX2 & TX2i : command terminated with error
14:33:57 ERROR : Drivers for Jetson TX2 & TX2i : install 'Drivers for Jetson TX2 & TX2i' failure, command < cd '/home/lp057/Documents/SDK Manager Download/JetPack_4.2_Linux_P3310' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='eyJpZCI6Ik5WX0w0VF9EUklWRVJTX1RYMl9DT01QIiwibmFtZSI6IkRyaXZlcnMgZm9yIEpldHNvbiBUWDIgJiBUWDJpIiwiZGVzY3JpcHRpb24iOiJOVklESUEgVGVncmEgTGludXggRHJpdmVyIFBhY2thZ2UiLCJjb21wVHlwZSI6InRhcmdldF9pbWFnZSIsImlzVmlzaWJsZSI6dHJ1ZSwibGljZW5zZUlkIjoiTlZfSkVUUEFDS19PU19FVUxBIiwiaXNEZXRlY3RhYmxlSW5zdGFsbCI6ZmFsc2UsImlzSW5zdGFsbFBhdGhDdXN0b21pemFibGUiOnRydWUsInZlcnNpb24iOiIzMi4xIiwib3BlcmF0aW5nU3lzdGVtcyI6WyJ1YnVudHUxNjA0IiwidWJ1bnR1MTgwNCJdLCJpbnN0YWxsU2l6ZU1CIjoxNTYsImRvd25sb2FkRmlsZXMiOlt7InVybCI6IlAzMzEwL0pldHNvbl9MaW51eF9SMzIuMS4wX2FhcmNoNjQudGJ6MiIsImZpbGVOYW1lIjoiSmV0c29uX0xpbnV4X1IzMi4xLjBfYWFyY2g2NC50YnoyIiwic2l6ZSI6MTI1Nzk5NTAyLCJjaGVja3N1bSI6Ijg4MWZlZGVlMDZhNzQ0Njk1M2EwNjRiNTc0MjI3OTgwIiwiY2hlY2tzdW1UeXBlIjoibWQ1IiwiaW5zdGFsbFBhcmFtZXRlcnMiOnsiaW5zdGFsbFR5cGUiOiJjbWQiLCJhZGRpdGlvbmFsUGFyYW1ldGVycyI6eyJpbnN0YWxsRGlyIjoie3tUQVJHRVRfUk9PVH19L3t7QlVORExFX1RJVExFfX1fe3tCT0FSRF9JRH19IiwiaW5zdGFsbENvbW1hbmRzIjpbeyJleGVjQmFzaCI6WyJzdWRvIGFwdC1nZXQgdXBkYXRlIHx8IHRydWU7IHN1ZG8gYXB0LWdldCBpbnN0YWxsIC15IHBpZ3ogbGJ6aXAyIiwidGFyIHhwZiB7e0ZJTEVfUEFUSH19Il19XX19LCJjYWNoZWRVcmwiOiJodHRwczovL2RldmVsb3Blci5udmlkaWEuY29tL2Fzc2V0cy9lbWJlZGRlZC9zZWN1cmUvdG9vbHMvZmlsZXMvamV0cGFjay1zZGtzL2pldHBhY2stNC4yL0pFVFBBQ0tfNDJfYjE1OC9QMzMxMC9KZXRzb25fTGludXhfUjMyLjEuMF9hYXJjaDY0LnRiejIifV0sInRhcmdldElkcyI6WyJQMzMxMCIsIlAzNDg5LTAwMDAiXSwiZGVwZW5kZW5jaWVzIjpbXSwiZXh0ZXJuYWxfZGVwZW5kZW5jaWVzIjpbXSwicGFyZW50SUQiOiJOVl9KRVRQQUNLX0w0VF9JTUFHRV9TRVRVUF9UQVJHRVRfR1JPVVAiLCJhY3Rpb24iOjEsImluc3RhbGxQYXRoIjoiL2hvbWUvbHAwNTcvRG9jdW1lbnRzL1NESyBNYW5hZ2VyIERvd25sb2FkL0pldFBhY2tfNC4yX0xpbnV4X1AzMzEwIiwiZG93bmxvYWRFcnJvcnMiOltdLCJ2ZXJpZnkiOmZhbHNlLCJleGVjIjoiL2hvbWUvbHAwNTcvRG9jdW1lbnRzL1NESyBNYW5hZ2VyIERvd25sb2FkL0pldHNvbl9MaW51eF9SMzIuMS4wX2FhcmNoNjQudGJ6MiIsImJ1bmRsZVRpdGxlIjoiSmV0UGFja180LjJfTGludXgiLCJpbnN0YWxsUm9vdCI6Ii9ob21lL2xwMDU3L0RvY3VtZW50cy9TREsgTWFuYWdlciBEb3dubG9hZCIsImJvYXJkSUQiOiJQMzMxMCIsInRhcmdldEFjY2Vzc0luZm8iOnsidXNlciI6Im52aWRpYSIsInBhc3N3b3JkIjoibnZpZGlhIiwiaG9zdCI6IjE5Mi4xNjguNTUuMSIsInBvcnQiOiIyMiJ9fQ==' -i='NV_L4T_DRIVERS_TX2_COMP' -v='32.1' -l='/home/lp057/Documents/SDK Manager Download/JetPack_4.2_Linux_P3310' -L='/home/lp057/.nvsdkm/logs/JetPack_4.2_Linux' -p='18533' -t='P3310' -e='/home/lp057/Documents/SDK Manager Download/Jetson_Linux_R32.1.0_aarch64.tbz2' > terminated with error
14:33:57 ERROR : Unavailable components detected, please check log
14:33:57 ERROR : File System and OS : Skipped. Due to its dependencies fail to install: Drivers for Jetson TX2 & TX2i,
14:33:57 ERROR : Device Mode Host Setup in Flash : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : Flash Jetson TX2 : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : Device Mode Host Setup in Target SDK : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : DateTime Target Setup : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : CUDA Toolkit for L4T : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : cuDNN on Target : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : TensorRT on Target : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : OpenCV on Target : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : VisionWorks on Target : Flash skipped due to component(s) download/install failure
14:33:57 ERROR : Multimedia API : Flash skipped due to component(s) download/install failure
INSTALLATION FAILED
Review terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2019,
NVIDIA CORPORATION
All rights reserved.
NVIDIA Developer
I tried to connect through Ethernet and microUSB. Both did not work. I also tried to put it into and out of recovery mode. No good news either. The host PC runs Ubuntu 16.04.
Anyone has idea?
Thank you very much!
