I just spent a day trying to flash the XAVIER to put the 4.4 but at the same time doing a factory original restoration. I can’t do it. On the SDK Manager, I always have the same error at the time of FLASH.
I confirm that I respect the documentation:
OFF power
connecting USB to the host
Click on Force Recovery
Click Power and Force Receive
and hold 2 buttons.
I have to do it wrong, where is my mistake?
It is the first time that I do this, because the first time it was summer 2019 I had just received it, and it worked perfectly.
Can you confirm that the procedure formats Xavier well because I would also like to leave on a clean basis.
Logs:
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : exec_command: /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : sudo ./flash.sh jetson-xavier mmcblk0p1
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : ###############################################################################
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : # L4T BSP Information:
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : # R32 , REVISION: 4.2
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : # Target Board Information:
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : # Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : # OpMode: production, Boot Authentication: NS,
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : copying soft_fuses(/home/hergo/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
- 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : ./tegraflash.py --chip 0x19 --applet “/home/hergo/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
*** 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : Reading board information failed.**
*** 11:20:52 ERROR : Flash Jetson AGX Xavier 16GB/32GB : /usr/bin/env:**
*** 11:20:52 ERROR : Flash Jetson AGX Xavier 16GB/32GB : ‘python’: No such file or directory**
*** 11:20:52 ERROR : Flash Jetson AGX Xavier 16GB/32GB : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh; [error]: exit status 1**
*** 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ Component Install Finished with Error ]**
*** 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ 12.00 KB used. Disk Avail: 43.52 GB ]**
*** 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 0s ]**
*** 11:20:52 ERROR : Flash Jetson AGX Xavier 16GB/32GB : [error]: Run commands failed at step Install: command /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh finished with error**
*** 11:20:52 INFO : Flash Jetson AGX Xavier 16GB/32GB :**
*** 11:20:52 ERROR : Flash Jetson AGX Xavier 16GB/32GB : command terminated with error**
*** 11:20:52 ERROR : Flash Jetson AGX Xavier 16GB/32GB : Install ‘Flash Jetson AGX Xavier 16GB/32GB’ failure, command < using adapter to install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER to /home/hergo/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER > terminated with error.** - 11:20:52 INFO : Device Mode Host Setup in Target SDK : Install ‘Device Mode Host Setup in Target SDK’ Skipped
- 11:20:52 INFO : DateTime Target Setup : Install ‘DateTime Target Setup’ Skipped
- 11:20:52 INFO : CUDA Toolkit for L4T : Install ‘CUDA Toolkit for L4T’ Skipped
- 11:20:52 INFO : cuDNN on Target : Install ‘cuDNN on Target’ Skipped
- 11:20:52 INFO : TensorRT on Target : Install ‘TensorRT on Target’ Skipped
- 11:20:52 INFO : OpenCV on Target : Install ‘OpenCV on Target’ Skipped
- 11:20:52 INFO : VisionWorks on Target : Install ‘VisionWorks on Target’ Skipped
- 11:20:52 INFO : VPI on Target : Install ‘VPI on Target’ Skipped
- 11:20:52 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Install ‘NVIDIA Container Runtime with Docker integration (Beta)’ Skipped
- 11:20:52 INFO : Multimedia API : Install ‘Multimedia API’ Skipped
- 11:20:52 INFO : DeepStream : Install ‘DeepStream’ Skipped
- 11:20:53 INFO : All done!
