Unboxed nvidia agx xavier - impossible to flash
Good morning Community … I have bought and working on 2 jetson nano for college jobs and never had any problems. I then bought a jetson xavier agx and the problems have increased a lot to the point that I don’t know how to get out of it.
I tried to make the flash with version 4.1 but I am attaching the problem and I do not complete…
I tried to do the flash with version 4.6 but I am attaching the problem and I do not go forward
can you help me? I spent a lot of money but it seems like an impossible tool to start using
Thank you in advance
J
jetpack4.1_Errors (288.5 KB)
jetpack4.6_Errors (6.9 KB)
Just some questions
  1. Is this your first time using this host to flash the board? Or did this host ever flash another jetson device before? Is that jetson nano flashed by this host with sdkmanager? (sdcard image is not included).
  2. Could you use this method to dump the log when the flash process is running?
    NVIDIA Xavier - Serial Console
Also, jetpack “4.1” is a little bit too old. Please also try some new version like 4.5.
Hi WayneWWW
Many Thanks you for your answer.
  1. The Host pc was used only for flashing Nvidia Agx Xavier itself. I tested version 4.1 and then 4.6 in sequence and attached are the logs.
  2. I’ll try to flash with version 4.5. and using your suggested method…I’ll collect the logs…and I’ll post everything just finished
Thanks…
So you cannot guarantee whehter this host is able to flash any jetson device with sdkmanager, right?
Correct… I cannot guarantee…
At the same time I Tried to flash using Jetpack 4.5 but I received an Error
16:55:16 ERROR: Flash Jetson AGX Xavier - flash: 66029 blocks
16:55:22 ERROR: Flash Jetson AGX Xavier - flash: 66822 blocks
my log…
16:55:11 INFO: Flash Jetson AGX Xavier - flash: [ 10.6120 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader mts_c10_prod_cr.bin zerosbk
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 10.6143 ] adding BCH for mts_c10_prod_cr.bin
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 10.7789 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 10.8992 ] adding BCH for bpmp_t194.bin
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.0007 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.1145 ] adding BCH for tegra194-a02-bpmp-p2888-a01.dtb
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.1625 ] Assuming zero filled SBK key
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.2105 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p2888-a01_sigheader.dtb.encrypt tegra194-a02-bpmp-p2888-a01_sigheader.dtb.hash zerosbk
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.2450 ] tegrahost_v2 --chip 0x19 --align spe_t194.bin
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.2787 ] adding BCH for spe_t194.bin
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.3460 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.3915 ] adding BCH for tos-trusty_t194.img
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.4827 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
16:55:12 INFO: Flash Jetson AGX Xavier - flash: [ 11.5466 ] adding BCH for eks.img
16:55:13 INFO: Flash Jetson AGX Xavier - flash: [ 11.6065 ] tegrahost_v2 --chip 0x19 --align tegra194-p2888-0001-p2822-0000.dtb
16:55:13 INFO: Flash Jetson AGX Xavier - flash: [ 11.6301 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
16:55:13 INFO: Flash Jetson AGX Xavier - flash: [ 11.7520 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
16:55:13 INFO: Flash Jetson AGX Xavier - flash: [ 11.7720 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin
16:55:13 INFO: Flash Jetson AGX Xavier - flash: [ 11.7974 ] adding BCH for nvtboot_recovery_cpu_t194.bin
16:55:13 INFO: Flash Jetson AGX Xavier - flash: [ 11.8403 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194_sigheader.bin.encrypt nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
16:55:15 INFO: Flash Jetson AGX Xavier - flash: [ 12.2467 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/giulio/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
16:55:15 INFO: Flash Jetson AGX Xavier - flash: [ 14.1484 ]
16:55:15 INFO: Flash Jetson AGX Xavier - flash: saving flash command in flashcmd.txt
16:55:15 INFO: Flash Jetson AGX Xavier - flash: /tmp/tmp.7Tnw2zI5RR ~/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
16:55:16 INFO: Flash Jetson AGX Xavier - flash: writing boot image config in bootimg.cfg
16:55:16 INFO: Flash Jetson AGX Xavier - flash: /tmp/tmp.7Tnw2zI5RR/initrd /tmp/tmp.7Tnw2zI5RR ~/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
16:55:22 INFO: Flash Jetson AGX Xavier - flash: /tmp/tmp.7Tnw2zI5RR ~/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
16:55:23 INFO: Flash Jetson AGX Xavier - flash: flashimg0=boot0.img
16:55:23 INFO: Flash Jetson AGX Xavier - flash: Cleaning up…
16:55:23 INFO: Flash Jetson AGX Xavier - flash: Finish generating flash package.
16:55:23 INFO: Flash Jetson AGX Xavier - flash: /home/giulio/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --skipuid --usb-instance 1-4 --device-instance 0 --flash-only --external-device sda1 -c “tools/kernel_flash/flash_l4t_external.xml” jetson-agx-xavier-devkit sda1
16:55:25 INFO: Flash Jetson AGX Xavier - flash: **********************************************
16:55:25 INFO: Flash Jetson AGX Xavier - flash: ~/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader ~/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
16:55:26 INFO: Flash Jetson AGX Xavier - flash: ~/JetPack4.5/JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
16:55:26 INFO: Flash Jetson AGX Xavier - flash: ./tegraflash.py --bl nvtboot_recovery_cpu_t194_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “rcmboot” --cfg secureflash.xml --chip 0x19 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “mb2_bootloader nvtboot_recovery_t194_sigheader.bin.encrypt; mts_preboot preboot_c10_prod_cr_sigheader.bin.encrypt; mts_mce mce_c10_prod_cr_sigheader.bin.encrypt; mts_proper mts_c10_prod_cr_sigheader.bin.encrypt; bpmp_fw bpmp_t194_sigheader.bin.encrypt; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a01_sigheader.dtb.encrypt; spe_fw spe_t194_sigheader.bin.encrypt; tlk tos-trusty_t194_sigheader.img.encrypt; eks eks_sigheader.img.encrypt; kernel boot0.img; kernel_dtb kernel_tegra194-p2888-0001-p2822-0000.dtb; bootloader_dtb tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt” --instance 1-4 --skipuid
16:55:26 INFO: Flash Jetson AGX Xavier - flash: Welcome to Tegra Flash
16:55:26 INFO: Flash Jetson AGX Xavier - flash: [ 0.0120 ] Boot Rom communication failed
16:55:26 INFO: Flash Jetson AGX Xavier - flash: Cleaning up…
16:55:26 ERROR: Flash Jetson AGX Xavier - flash: command terminated with error
16:55:26 SUMMARY: DateTime Target Setup - target: Depends on failed component
Could you choose to flash emmc instead of nvme? Also, this is still jetpack4.6.1 log… not jetpack4.5…
Also, this is not the serial log I am talking about.
Hi WayneWWW … luckily I fixed the problem.
First i changed ubuntu host, preparing a new machine. then i downloaded and installed jetpack 4.5 as you suggested. Everything was successful. Now I need to switch to the jetpack 4.6 version: which option do you suggest me to follow? to connect host with jetson using the usb cable or directly in ssh? I would not like to be in trouble again … thanks in advance
I don’t understand your problem. Our flash tool only supports to flash board with usb cable.
The internet interface (ssh) is only for installing sdk e.g. CUDA/TensorRT. These software do not affect the OS. Just like you don’t need CUDA to be installed for your Windows to run.
