Hi.
Since several days ago, I can’t flash Jetpack4.4DP through SDK manager.
Here is my log file.
• 13:53:03 INFO : Automatic trying to flash the target device with Manual Flash option...
• 13:53:03 DEBUG : running command < [ `lsusb | grep -c "0955:"` -ne 1 ] >
• 13:53:03 DEBUG : command terminated with error
• 13:53:03 INFO : Only one NVIDIA device detected, as expected.
• 13:53:03 DEBUG : running command < lsusb | grep 0955:7020 >
• 13:53:03 INFO : Jetson device is in recovery mode.
• 13:53:03 DEBUG : running command < lsusb | grep 0955:7019 >
• 13:53:03 INFO : Bus 001 Device 008: ID 0955:7019 NVidia Corp.
• 13:53:03 INFO : command finished successfully
• 13:53:03 INFO : Verified, 0955:7019 detected in recovery mode.
• 13:53:03 INFO : Device Mode Host Setup in Flash : Start to install 'Device Mode Host Setup in Flash'
• 13:53:03 DEBUG : Device Mode Host Setup in Flash : using adapter to install NV_DEVICE_MODE_SETUP_IMAGE_COMP@JETSON_AGX_XAVIER to /home/jhai/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER
• 13:53:03 INFO : Device Mode Host Setup in Flash : [ Disk Avail:361.56 GB ]
• 13:53:03 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_DEVICE_MODE_SETUP_IMAGE_COMP
• 13:53:03 INFO : Device Mode Host Setup in Flash : change working directory to /home/jhai/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER
• 13:53:03 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
• 13:53:03 INFO : Device Mode Host Setup in Flash : current working directory is /home/jhai/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER
• 13:53:03 INFO : Device Mode Host Setup in Flash : exec_command [host]:
• 13:53:03 INFO : Device Mode Host Setup in Flash : **********************
• 13:53:03 INFO : Device Mode Host Setup in Flash : #!/bin/bash
• 13:53:03 INFO : Device Mode Host Setup in Flash : set -e
• 13:53:03 INFO : Device Mode Host Setup in Flash : set +e
• 13:53:03 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk '/default via/ {print $5; exit}')
• 13:53:03 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == '' ]]; then
• 13:53:03 INFO : Device Mode Host Setup in Flash : echo 'Can not found route default $eth_port_name, device mode setup failed!'
• 13:53:03 INFO : Device Mode Host Setup in Flash : exit 0
• 13:53:03 INFO : Device Mode Host Setup in Flash : fi
• 13:53:03 INFO : Device Mode Host Setup in Flash : echo 'Found route default' $eth_port_name', setting up device mode'
• 13:53:03 INFO : Device Mode Host Setup in Flash : setup_t='192.168.55.0/24'
• 13:53:03 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
• 13:53:03 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
• 13:53:03 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
• 13:53:03 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
• 13:53:03 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
• 13:53:03 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == *'Got answer'* ]]; then
• 13:53:03 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS 8.8.8.8!'
• 13:53:03 INFO : Device Mode Host Setup in Flash : else
• 13:53:03 INFO : Device Mode Host Setup in Flash : echo 'Default google DNS is not working, trying to find a valid server in local host settings!'
• 13:53:03 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep 'DNS' | grep -o '[^:]*$')
• 13:53:03 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
• 13:53:03 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
• 13:53:03 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == *'Got answer'* ]]; then
• 13:53:03 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 13:53:03 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 13:53:03 INFO : Device Mode Host Setup in Flash : echo 'Device mode on host successfuly set with DNS' $dns'!'
• 13:53:03 INFO : Device Mode Host Setup in Flash : done
• 13:53:03 INFO : Device Mode Host Setup in Flash : echo 'Can not found a valid DNS server, device mode setup failed!'
• 13:53:03 INFO : Device Mode Host Setup in Flash : echo 'If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.'
• 13:53:03 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_IMAGE_COMP.sh
• 13:53:03 INFO : Device Mode Host Setup in Flash : Found route default enp0s31f6, setting up device mode
• 13:53:03 INFO : Device Mode Host Setup in Flash : [host] [sudo] password for jhai:
• 13:53:03 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
• 13:53:03 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 8.8.8.8!
• 13:53:03 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
• 13:53:03 INFO : Device Mode Host Setup in Flash : [ 12.00 KB used. Disk Avail: 361.56 GB ]
• 13:53:03 INFO : Device Mode Host Setup in Flash : [ NV_DEVICE_MODE_SETUP_IMAGE_COMP Install took 0s ]
• 13:53:03 INFO : Device Mode Host Setup in Flash : command finished successfully
• 13:53:03 INFO : Device Mode Host Setup in Flash : Install 'Device Mode Host Setup in Flash' success
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : Start to install 'Flash Jetson AGX Xavier 16GB/32GB'
• 13:53:03 DEBUG : Flash Jetson AGX Xavier 16GB/32GB : using adapter to install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER to /home/jhai/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ Disk Avail:361.56 GB ]
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : Using GenericInstaller to Install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : change working directory to /home/jhai/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ Component Install Started ]
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : current working directory is /home/jhai/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER/Linux_for_Tegra
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : exec_command [host]:
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : **********************
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : #!/bin/bash
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : set -e
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : if [ -e ./bootloader/system.img ]; then
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : echo sudo ./flash.sh --no-systemimg jetson-xavier mmcblk0p1
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : sudo ./flash.sh --no-systemimg jetson-xavier mmcblk0p1
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : else
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : echo sudo ./flash.sh jetson-xavier mmcblk0p1
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : sudo ./flash.sh jetson-xavier mmcblk0p1
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : fi
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : sleep 20
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : exec_command: /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : ###############################################################################
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : # L4T BSP Information:
• 13:53:03 INFO : Flash Jetson AGX Xavier 16GB/32GB : # R32 , REVISION: 4.2
• 13:53:08 INFO : Flash Jetson AGX Xavier 16GB/32GB : Error: probing the target board failed.
• 13:53:08 INFO : Flash Jetson AGX Xavier 16GB/32GB : Make sure the target board is connected through
• 13:53:08 INFO : Flash Jetson AGX Xavier 16GB/32GB : USB port and is in recovery mode.
• 13:53:08 ERROR : Flash Jetson AGX Xavier 16GB/32GB : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh; [error]: exit status 1
• 13:53:08 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ Component Install Finished with Error ]
• 13:53:08 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ 4.00 KB used. Disk Avail: 361.56 GB ]
• 13:53:08 INFO : Flash Jetson AGX Xavier 16GB/32GB : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 5s ]
• 13:53:08 ERROR : Flash Jetson AGX Xavier 16GB/32GB : [error]: Run commands failed at step Install: command /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh finished with error
• 13:53:08 ERROR : Flash Jetson AGX Xavier 16GB/32GB : command terminated with error
• 13:53:08 ERROR : Flash Jetson AGX Xavier 16GB/32GB : Install 'Flash Jetson AGX Xavier 16GB/32GB' failure, command < using adapter to install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER to /home/jhai/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_AGX_XAVIER > terminated with error.
• 13:53:08 INFO : Device Mode Host Setup in Target SDK : Install 'Device Mode Host Setup in Target SDK' Skipped
• 13:53:08 INFO : DateTime Target Setup : Install 'DateTime Target Setup' Skipped
• 13:53:08 INFO : CUDA Toolkit for L4T : Install 'CUDA Toolkit for L4T' Skipped
• 13:53:09 INFO : cuDNN on Target : Install 'cuDNN on Target' Skipped
• 13:53:09 INFO : TensorRT on Target : Install 'TensorRT on Target' Skipped
• 13:53:09 INFO : OpenCV on Target : Install 'OpenCV on Target' Skipped
• 13:53:09 INFO : VisionWorks on Target : Install 'VisionWorks on Target' Skipped
• 13:53:09 INFO : VPI on Target : Install 'VPI on Target' Skipped
• 13:53:09 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Install 'NVIDIA Container Runtime with Docker integration (Beta)' Skipped
• 13:53:09 INFO : Multimedia API : Install 'Multimedia API' Skipped
• 13:53:09 INFO : DeepStream : Install 'DeepStream' Skipped
• 13:53:10 INFO : All done!
I can fine jetson board with ‘lsusb’ command.
And also, I don’t use VM.
My host PC is Ubuntu 18.04.
Can anyone helps me?
thanks!
