JETSON , Xavier Development Kit.
• DeepStream Version
6.0
4.6 (REV.2)
• TensorRT Version
bugs
I follow jetpack install steps. but device can’t booting.
this is install filtered ERROR log msg.
ERROR
22:35:03 INFO: Drivers for Jetson - target_image: echo “Unhandled error when running $1: tr '\n' '; ' <$tmp_log” 1>&2; exit 1
22:35:44 INFO: File System and OS - target_image: echo “Unhandled error when running $1: tr '\n' '; ' <$tmp_log” 1>&2; exit 1
22:42:24 ERROR: CUDA on Host - host: update-alternatives: error: alternative path /opt/nvidia/nsight-systems/2021.1.3/host-linux-x64/nsight-sys doesn’t exist
22:42:24 ERROR: CUDA on Host - host: update-alternatives: error: no alternatives for nsight-sys
22:44:18 INFO: VisionWorks on Host - host: nvvwx_docs/group__nvx__framework__error__management.html
22:44:18 INFO: VisionWorks on Host - host: nvvwx_docs/group__nvx__framework__error__management.js
22:44:18 INFO: VisionWorks on Host - host: nvvwx_docs/mathjax/extensions/TeX/noErrors.js
22:44:23 INFO: VPI on Host - host: echo “Unhandled error when running $1: tr '\n' '; ' <$tmp_log” 1>&2; exit 1
22:44:27 INFO: VPI on Host - host: echo “Unhandled error when running $1: tr '\n' '; ' <$tmp_log” 1>&2; exit 1
22:45:07 INFO: VPI on Host - host: echo “Unhandled error when running $1: tr '\n' '; ' <$tmp_log” 1>&2; exit 1
22:45:07 ERROR: VPI on Host - host: |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
22:45:35 ERROR: NVIDIA Nsight Systems - host: update-alternatives: error: alternative path is not absolute as it should be:
22:46:31 ERROR: Could not detect correct NVIDIA Jetson device connected to USB. Verify that: 1. The device is connected to this host machine with a USB cable. 2. Jetson’s Ubuntu OS is up and running. 3. Ubuntu ‘System configuration wizard’ is completed on the device. 4. Correct target is selected in STEP 1. This can be validated by running the ‘lsusb’ command on your host, and look for (NVIDIA Corp).%{autoFlashExtraWarning}
22:46:32 INFO: Flash Jetson AGX Xavier - flash: echo “Unhandled error when running $1: tr '\n' '; ' <$tmp_log” 1>&2; exit 1
22:46:57 ERROR: Flash Jetson AGX Xavier - flash: Board ID(2888) version(400) sku(0004) revision(K.0)
22:47:00 ERROR: Flash Jetson AGX Xavier - flash: 30412 blocks
22:47:06 ERROR: Flash Jetson AGX Xavier - flash: 66117 blocks
22:47:06 ERROR: Flash Jetson AGX Xavier - flash: 20+0 records in
22:47:06 ERROR: Flash Jetson AGX Xavier - flash: 20+0 records out
22:47:06 ERROR: Flash Jetson AGX Xavier - flash: 20 bytes copied, 0.000188388 s, 106 kB/s
- Jetson OS Image is ready
- Flash Jetson OS
- Boot and execute 1st Setup Wizard > End setup.
- Can’t boot.
