Install JetPack4.2 through SDKManager error when installing OpenCVonHost:
16:56:58 INFO : OpenCV on Host : exec_command: sudo dpkg -i /home/ai/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gd6a8916_amd64.deb
16:57:00 INFO : OpenCV on Host : (Reading database … 584570 files and directories currently installed.)
16:57:00 INFO : OpenCV on Host : Preparing to unpack …/libopencv_3.3.1-2-gd6a8916_amd64.deb …
16:57:00 INFO : OpenCV on Host : Unpacking libopencv (3.3.1-2-gd6a8916) over (3.3.1-2-gd6a8916) …
16:57:01 INFO : OpenCV on Host : Setting up libopencv (3.3.1-2-gd6a8916) …
16:57:01 INFO : OpenCV on Host : Processing triggers for libc-bin (2.23-0ubuntu10) …
16:57:02 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv
16:57:02 INFO : OpenCV on Host : NV_OPENCV_HOST_COMP libopencv_3.3.1-2-gd6a8916_amd64.deb installed successfully.
16:57:02 INFO : OpenCV on Host : [ Package Install Finished Successfully ]
16:57:02 INFO : OpenCV on Host : [ Package Install Started ]
16:57:02 INFO : OpenCV on Host : deb installer start to install
16:57:02 INFO : OpenCV on Host : exec_command: dpkg -f /home/ai/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Package | tr -d ’
16:57:02 INFO : OpenCV on Host : ’
16:57:02 INFO : OpenCV on Host : exec_command: dpkg -f /home/ai/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb Version | tr -d ’
16:57:02 INFO : OpenCV on Host : deb file /home/ai/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb, package name [libopencv-dev], package version [3.3.1-2-gd6a8916]
16:57:02 INFO : OpenCV on Host : infer package info from file name libopencv-dev_3.3.1-2-gd6a8916_amd64.deb [ name: libopencv-dev, version: 3.3.1-2-gd6a8916 ]
16:57:02 INFO : OpenCV on Host : exec_command: sudo dpkg -i /home/ai/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb
16:57:02 ERROR : OpenCV on Host : dpkg: considering removing libopencv-calib3d-dev:amd64 in favour of libopencv-dev …
16:57:02 INFO : OpenCV on Host : dpkg: no, cannot proceed with removal of libopencv-calib3d-dev:amd64 (–auto-deconfigure will help):
16:57:02 INFO : OpenCV on Host : libopencv-contrib-dev:amd64 depends on libopencv-calib3d-dev (= 2.4.9.1+dfsg-1.5ubuntu1.1)
16:57:02 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 is to be removed.
16:57:02 INFO : OpenCV on Host : dpkg: regarding …/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb containing libopencv-dev:
16:57:02 INFO : OpenCV on Host : libopencv-dev conflicts with libopencv-calib3d-dev
16:57:02 INFO : OpenCV on Host : libopencv-calib3d-dev:amd64 (version 2.4.9.1+dfsg-1.5ubuntu1.1) is present and installed.
16:57:02 INFO : OpenCV on Host : dpkg: error processing archive /home/ai/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb (–install):
16:57:02 INFO : OpenCV on Host : conflicting packages - not installing libopencv-dev
16:57:02 ERROR : OpenCV on Host : Errors were encountered while processing:
16:57:02 INFO : OpenCV on Host : /home/ai/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gd6a8916_amd64.deb
16:57:02 INFO : OpenCV on Host : exit status 1
16:57:02 INFO : OpenCV on Host : exec_command: sudo apt-get check
16:57:03 INFO : OpenCV on Host : Reading package lists…
16:57:03 INFO : OpenCV on Host : Building dependency tree…
16:57:03 INFO : OpenCV on Host : Reading state information…
16:57:04 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv-dev
16:57:04 INFO : OpenCV on Host : [ Package Install Finished with Error ]
16:57:04 ERROR : OpenCV on Host : NV_OPENCV_HOST_COMP package [{libopencv-dev 3.3.1}] not installed
16:57:04 INFO : OpenCV on Host : [ 8.00 KB used. Disk Avail: 352.28 GB ]
16:57:04 INFO : OpenCV on Host : [ NV_OPENCV_HOST_COMP Install took 6s ]
16:57:04 INFO : OpenCV on Host : package [{libopencv-dev 3.3.1}] not installed
16:57:04 ERROR : OpenCV on Host : command terminated with error
16:57:04 ERROR : OpenCV on Host : install ‘OpenCV on Host’ failure, command…
