Hello All.
I’ve looked for answers before posting so I hope this have not been asked before.
I’m using a SP6 running Win10 with VMware and Ubuntu 18.04.2 LTS.
During install with both target hardware enabled or disabled I get an error installing openCV.
Here is the report:
21:49:06 INFO : OpenCV on Host : Found file /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gb3f86dcd5_amd64.deb with correct checksum, skip downloading.
•21:49:06 INFO : OpenCV on Host : Found file /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-gb3f86dcd5_amd64.deb with correct checksum, skip downloading.
•21:49:07 INFO : OpenCV on Host : Found file /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb with correct checksum, skip downloading.
•21:49:07 INFO : OpenCV on Host : Found file /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-gb3f86dcd5_amd64.deb with correct checksum, skip downloading.
•21:49:07 INFO : OpenCV on Host : download ‘OpenCV on Host’ success
•21:49:07 INFO : OpenCV on Host : Start to install ‘OpenCV on Host’
•21:49:07 INFO : OpenCV on Host : [host] [sudo] password for robotros:
•21:49:07 DEBUG : OpenCV on Host : running command < cd ‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘e…9’ -i=‘NV_OPENCV_HOST_COMP’ -v=‘3.3.1’ -l=‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ -L=‘/home/robotros/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘6430’ -t=‘’ -e=‘/home/robotros/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gb3f86dcd5_amd64.deb’ >
•21:49:07 INFO : OpenCV on Host : [ Disk Avail:104.76 GB ]
•21:49:07 INFO : OpenCV on Host : Using GenericInstaller to Install NV_OPENCV_HOST_COMP
•21:49:07 INFO : OpenCV on Host : NV_OPENCV_HOST_COMP include 4 package
•21:49:07 INFO : OpenCV on Host : [ Package PreInstall Started ]
•21:49:07 INFO : OpenCV on Host : current working directory is /home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux
•21:49:07 INFO : OpenCV on Host : exec_command: sudo apt-get install -y libtbb-dev
•21:49:07 INFO : OpenCV on Host : Reading package lists…
•21:49:08 INFO : OpenCV on Host : Building dependency tree…
•21:49:08 INFO : OpenCV on Host : Reading state information…
•21:49:08 INFO : OpenCV on Host : libtbb-dev is already the newest version (2017~U7-8).
•21:49:08 INFO : OpenCV on Host : 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
•21:49:08 INFO : OpenCV on Host : [ Package PreInstall Finished Successfully ]
•21:49:08 INFO : OpenCV on Host : [ Package Install Started ]
•21:49:08 INFO : OpenCV on Host : deb installer start to install
•21:49:08 INFO : OpenCV on Host : exec_command: dpkg -f /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb Package | tr -d ’
•21:49:08 INFO : OpenCV on Host : ’
•21:49:08 INFO : OpenCV on Host : exec_command: dpkg -f /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb Version | tr -d ’
•21:49:08 INFO : OpenCV on Host : deb file /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb, package name [libopencv], package version [3.3.1-2-gb3f86dcd5]
•21:49:08 INFO : OpenCV on Host : infer package info from file name libopencv_3.3.1-2-gb3f86dcd5_amd64.deb [ name: libopencv, version: 3.3.1-2-gb3f86dcd5 ]
•21:49:08 INFO : OpenCV on Host : exec_command: sudo dpkg -i /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb
•21:49:09 ERROR : OpenCV on Host : dpkg: considering removing opencv-data in favour of libopencv …
•21:49:09 INFO : OpenCV on Host : dpkg: yes, will remove opencv-data in favour of libopencv
•21:49:09 INFO : OpenCV on Host : (Reading database … 276474 files and directories currently installed.)
•21:49:09 INFO : OpenCV on Host : Preparing to unpack …/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb …
•21:49:09 INFO : OpenCV on Host : Unpacking libopencv (3.3.1-2-gb3f86dcd5) …
•21:49:10 ERROR : OpenCV on Host : dpkg: error processing archive /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb (–install):
•21:49:10 INFO : OpenCV on Host : trying to overwrite ‘/usr/bin/opencv_version’, which is also in package libopencv-dev 3.2.0+dfsg-4ubuntu0.1
•21:49:10 ERROR : OpenCV on Host : Errors were encountered while processing:
•21:49:10 INFO : OpenCV on Host : /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb
•21:49:10 INFO : OpenCV on Host : exit status 1
•21:49:10 INFO : OpenCV on Host : exec_command: sudo apt-get check
•21:49:11 INFO : OpenCV on Host : Reading package lists…
•21:49:11 INFO : OpenCV on Host : Building dependency tree…
•21:49:11 INFO : OpenCV on Host : Reading state information…
•21:49:11 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv
•21:49:12 INFO : OpenCV on Host : [ Package Install Finished with Error ]
•21:49:12 ERROR : OpenCV on Host : NV_OPENCV_HOST_COMP package [{libopencv 3.3.1}] not installed
•21:49:12 INFO : OpenCV on Host : [ 12.00 KB used. Disk Avail: 104.76 GB ]
•21:49:12 INFO : OpenCV on Host : [ NV_OPENCV_HOST_COMP Install took 5s ]
•21:49:12 INFO : OpenCV on Host : package [{libopencv 3.3.1}] not installed
•21:49:12 ERROR : OpenCV on Host : command terminated with error
•21:49:12 ERROR : OpenCV on Host : install ‘OpenCV on Host’ failure, command < cd ‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘…19’ -i=‘NV_OPENCV_HOST_COMP’ -v=‘3.3.1’ -l=‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ -L=‘/home/robotros/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘6430’ -t=‘’ -e=‘/home/robotros/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gb3f86dcd5_amd64.deb’ > terminated with error
•21:49:12 INFO : OpenCV on Host : Start to install ‘OpenCV on Host’
•21:49:12 DEBUG : OpenCV on Host : running command < cd ‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘e…0=’ -i=‘NV_OPENCV_HOST_COMP’ -v=‘3.3.1’ -l=‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ -L=‘/home/robotros/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘6430’ -t=‘’ -e=‘/home/robotros/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gb3f86dcd5_amd64.deb’ >
•21:49:12 INFO : OpenCV on Host : [ Disk Avail:104.76 GB ]
•21:49:12 INFO : OpenCV on Host : Using GenericInstaller to Install NV_OPENCV_HOST_COMP
•21:49:12 INFO : OpenCV on Host : NV_OPENCV_HOST_COMP include 4 package
•21:49:12 INFO : OpenCV on Host : [ Package PreInstall Started ]
•21:49:12 INFO : OpenCV on Host : current working directory is /home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux
•21:49:12 INFO : OpenCV on Host : exec_command: sudo apt-get install -y libtbb-dev
•21:49:12 INFO : OpenCV on Host : Reading package lists…
•21:49:12 INFO : OpenCV on Host : Building dependency tree…
•21:49:12 INFO : OpenCV on Host : Reading state information…
•21:49:13 INFO : OpenCV on Host : libtbb-dev is already the newest version (2017~U7-8).
•21:49:13 INFO : OpenCV on Host : 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
•21:49:13 INFO : OpenCV on Host : [ Package PreInstall Finished Successfully ]
•21:49:13 INFO : OpenCV on Host : [ Package Install Started ]
•21:49:13 INFO : OpenCV on Host : deb installer start to install
•21:49:13 INFO : OpenCV on Host : exec_command: dpkg -f /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb Package | tr -d ’
•21:49:13 INFO : OpenCV on Host : ’
•21:49:13 INFO : OpenCV on Host : exec_command: dpkg -f /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb Version | tr -d ’
•21:49:13 INFO : OpenCV on Host : deb file /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb, package name [libopencv], package version [3.3.1-2-gb3f86dcd5]
•21:49:13 INFO : OpenCV on Host : infer package info from file name libopencv_3.3.1-2-gb3f86dcd5_amd64.deb [ name: libopencv, version: 3.3.1-2-gb3f86dcd5 ]
•21:49:13 INFO : OpenCV on Host : exec_command: sudo dpkg -i /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb
•21:49:13 ERROR : OpenCV on Host : dpkg: considering removing opencv-data in favour of libopencv …
•21:49:13 INFO : OpenCV on Host : dpkg: yes, will remove opencv-data in favour of libopencv
•21:49:13 INFO : OpenCV on Host : (Reading database … 276474 files and directories currently installed.)
•21:49:13 INFO : OpenCV on Host : Preparing to unpack …/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb …
•21:49:13 INFO : OpenCV on Host : Unpacking libopencv (3.3.1-2-gb3f86dcd5) …
•21:49:14 ERROR : OpenCV on Host : dpkg: error processing archive /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb (–install):
•21:49:14 INFO : OpenCV on Host : trying to overwrite ‘/usr/bin/opencv_version’, which is also in package libopencv-dev 3.2.0+dfsg-4ubuntu0.1
•21:49:14 ERROR : OpenCV on Host : Errors were encountered while processing:
•21:49:14 INFO : OpenCV on Host : /home/robotros/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-gb3f86dcd5_amd64.deb
•21:49:14 INFO : OpenCV on Host : exit status 1
•21:49:14 INFO : OpenCV on Host : exec_command: sudo apt-get check
•21:49:15 INFO : OpenCV on Host : Reading package lists…
•21:49:15 INFO : OpenCV on Host : Building dependency tree…
•21:49:15 INFO : OpenCV on Host : Reading state information…
•21:49:15 INFO : OpenCV on Host : exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ libopencv
•21:49:15 INFO : OpenCV on Host : [ Package Install Finished with Error ]
•21:49:15 ERROR : OpenCV on Host : NV_OPENCV_HOST_COMP package [{libopencv 3.3.1}] not installed
•21:49:15 INFO : OpenCV on Host : [ 8.00 KB used. Disk Avail: 104.76 GB ]
•21:49:15 INFO : OpenCV on Host : [ NV_OPENCV_HOST_COMP Install took 4s ]
•21:49:15 INFO : OpenCV on Host : package [{libopencv 3.3.1}] not installed
•21:49:15 ERROR : OpenCV on Host : command terminated with error
•21:49:15 ERROR : OpenCV on Host : install ‘OpenCV on Host’ failure, command < cd ‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘e…0=’ -i=‘NV_OPENCV_HOST_COMP’ -v=‘3.3.1’ -l=‘/home/robotros/nvidia/nvidia_sdk/JetPack_4.2_Linux’ -L=‘/home/robotros/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘6430’ -t=‘’ -e=‘/home/robotros/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-gb3f86dcd5_amd64.deb’ > terminated with error
Any sugestions on how to fix this?
Regards
