Failed to install SDK components on Jetson TX1 using SDK Manager
Hi
NVIDIA SDK Manager isn’t installing the SDK components on Jetson TX1.
Host: Ubuntu 16.04 LTS
Target: Jetson TX1, JetPack 4.3
We initially had a working installation. It booted correctly a few times, then there was a problem with the boot sequence - it said ‘Failed to start Argus daemon’ - so we decided to flash the OS all over again (thought it would solve the errors with Libargus too, since we had some trouble building the samples). We then started over, from flashing the OS, and ran into this error. The downloads failed the first time, so we cleared the download target directory (SDK Manager tells you the download location for components) and performed the whole download again. It happened correctly this time (the SDK Manager didn’t report an error). We then tried flashing and installing a couple of times - each time we got errors along these lines. Please help.
Error log in the SDK Manager’s terminal starts with:
05:17:02 ERROR : Drivers for Jetson TX1/Nano : W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: file:/var/cuda-repo-9-0-local Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
05:17:02 ERROR : Drivers for Jetson TX1/Nano : Some index files failed to download. They have been ignored, or old ones used instead.
05:17:53 ERROR : OpenCV on Host : download error: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1604/OpenCV-4.1.1-2-gd5a58aa-x86_64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
05:27:56 ERROR : File System and OS : /bin/ls:
05:27:56 ERROR : File System and OS : cannot access '*.dtb'
05:27:56 ERROR : File System and OS : : No such file or directory
05:29:54 ERROR : CUDA on Host : Extracting templates from packages: 66%
05:29:54 ERROR : CUDA on Host : Extracting templates from packages: 100%
05:32:33 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 88%
05:32:33 ERROR : CUDA Cross Compile Package on Host : Extracting templates from packages: 100%
04:21:51 ERROR : Flash Jetson TX1 : Board ID(2180) version(410)
04:25:12 ERROR : Flash Jetson TX1 :
04:25:12 ERROR : Flash Jetson TX1 : 0: RAW: 3727360( 910 blks) ==> 28:3727372
04:25:12 ERROR : Flash Jetson TX1 : 3: SKP: 61440( 15 blks) ==> 3731520:12
04:25:12 ERROR : Flash Jetson TX1 : 4: RAW: 1699840( 415 blks) ==> 3731532:1699852
04:25:12 ERROR : Flash Jetson TX1 : 5: SKP: 31854592( 7777 blks) ==> 5431384:12
04:25:12 ERROR : Flash Jetson TX1 : 6: RAW: 7016448( 1713 blks) ==> 5431396:7016460
and then many more lines similar to the last one, until:
04:25:52 ERROR : Flash Jetson TX1 : 4709: SKP: 81842176( 19981 blks) ==> 4253334744:12
04:25:57 ERROR : Flash Jetson TX1 : 4710: RAW: 243269632( 59392 blks) ==> 4253334756:243269644
04:25:57 ERROR : Flash Jetson TX1 : 4711: SKP: 1769996288( 432128 blks) ==> 4496604400:12
04:25:58 ERROR : Flash Jetson TX1 : -- Total: ---------------------------------------------------
04:36:14 ERROR : command terminated with error
04:36:14 ERROR : failed to query component: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP version: 10.0 for bundle:
04:36:15 ERROR : command terminated with error
04:36:15 ERROR : failed to query component: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP version: 7.6 for bundle:
04:36:17 ERROR : command terminated with error
04:36:17 ERROR : failed to query component: NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP version: 6.0 for bundle:
04:36:18 ERROR : command terminated with error
04:36:18 ERROR : failed to query component: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP version: 4.1.1 for bundle:
04:36:22 ERROR : command terminated with error
04:36:22 ERROR : failed to query component: NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP version: 1.6 for bundle:
04:36:23 ERROR : command terminated with error
04:36:23 ERROR : failed to query component: NV_VPI_TARGET_POST_INSTALL_COMP version: 0.1.0 for bundle:
04:36:25 ERROR : command terminated with error
04:36:25 ERROR : failed to query component: NV_DOCKER_TARGET_POST_INSTALL_COMP version: 0.9.0 for bundle:
04:36:26 ERROR : command terminated with error
04:36:26 ERROR : failed to query component: NV_MULTIMEDIA_API_TARGET_POST_INSTALL_T210_COMP version: 32.3 for bundle:
04:36:28 ERROR : command terminated with error
04:36:28 ERROR : failed to query component: NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP version: 4.0.2 for bundle:
04:37:51 ERROR : CUDA Toolkit for L4T : : command safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb" 5; sleep 5; ; safe_apt_install "sudo apt-get -y install cuda-toolkit-10-0 " 5 finished with error
04:37:51 ERROR : CUDA Toolkit for L4T : command terminated with error
04:37:51 ERROR : CUDA Toolkit for L4T : install 'CUDA Toolkit for L4T' failure, command < cd '/home/ecac-linux/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2180' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_CUDA_TARGET_POST_INSTALL_COMP' -v='10.0' -l='/home/ecac-linux/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2180' -L='/home/ecac-linux/.nvsdkm/logs/JetPack_4.3_Linux' -p='2176' -t='P2180' -e='/home/ecac-linux/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb' > terminated with error
04:37:55 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : : command safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb" 5; sleep 5; finished with error
04:37:55 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : command terminated with error
04:37:56 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : install 'NVIDIA Container Runtime with Docker integration (Beta)' failure, command < cd '/home/ecac-linux/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2180' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_DOCKER_TARGET_POST_INSTALL_COMP' -v='0.9.0' -l='/home/ecac-linux/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2180' -L='/home/ecac-linux/.nvsdkm/logs/JetPack_4.3_Linux' -p='2176' -t='P2180' -e='/home/ecac-linux/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0_beta.1_arm64.deb' > terminated with error
04:37:56 ERROR : Unavailable components detected, please check log
04:37:56 ERROR : cuDNN on Target : cuDNN on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
04:37:56 ERROR : TensorRT on Target : TensorRT on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
04:37:56 ERROR : OpenCV on Target : OpenCV on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
04:37:56 ERROR : VisionWorks on Target : VisionWorks on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
04:37:56 ERROR : VPI : VPI Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
04:37:56 ERROR : Multimedia API : Multimedia API Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
04:37:56 ERROR : DeepStream : DeepStream Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
I too am stuck with the same issue on TX2 - unable to install SDK components after flashing the OS successfully. My environment and the Jetpack version are the same as reported here -
Target: Jetson TX2, JetPack 4.3
18:00:29 INFO : VisionWorks on Target : verifying checksum of Downloads/nvidia/libvisionworks-tracking-repo_0.88.2_arm64.deb
18:00:30 INFO : cuDNN on Target : Found file Downloads/nvidia/libcudnn7-dev_7.6.3.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
18:00:30 INFO : Multimedia API : verifying checksum of Downloads/nvidia/nvidia-l4t-jetson-multimedia-api_32.3.1-20191209230245_arm64.deb
18:00:31 INFO : VisionWorks on Target : Found file Downloads/nvidia/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
18:00:32 INFO : cuDNN on Target : Found file Downloads/nvidia/libcudnn7_7.6.3.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
18:00:35 INFO : VisionWorks on Target : Found file Downloads/nvidia/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
18:00:38 INFO : Multimedia API : Found file Downloads/nvidia/nvidia-l4t-jetson-multimedia-api_32.3.1-20191209230245_arm64.deb with correct checksum, skip downloading.
18:01:01 INFO : TensorRT on Target : Found file Downloads/nvidia/libnvinfer-samples_6.0.1-1+cuda10.0_all.deb with correct checksum, skip downloading.
18:01:06 INFO : CUDA Toolkit for L4T : Found file Downloads/nvidia/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb with correct checksum, skip downloading.
18:01:15 DEBUG : running command < [ `lsusb | grep -c "0955:"` -ne 1 ] >
18:01:16 DEBUG : command terminated with error
18:01:16 INFO : Only one nvidia device detected, as expected.
18:01:16 DEBUG : running command < ip addr | grep 192.168.55.1 >
18:01:16 INFO : inet 192.168.55.100/24 brd 192.168.55.255 scope global dynamic enp0s20f0u3i5
18:01:16 INFO : command finished successfully
18:01:16 DEBUG : running command < nc -z -vv -w 5 192.168.55.1 22 >
18:01:16 INFO : Connection to 192.168.55.1 22 port [tcp/ssh] succeeded!
18:01:16 INFO : Connection to the device via SSH is avaliable.
18:01:16 DEBUG : running command < ssh -F /dev/null -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 nvidia@192.168.55.1 echo hello >
18:01:16 INFO : Warning: Permanently added '192.168.55.1' (ECDSA) to the list of known hosts.
18:01:16 INFO : [target] nvidia@192.168.55.1's password:
18:01:16 INFO :
18:01:18 INFO : hello
18:01:18 INFO : command finished successfully
18:01:18 INFO : Validated its username and password.
18:01:18 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_L4T_CUDA_TARGET_POST_INSTALL_COMP -v=10.0 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:18 INFO : Using GenericInstaller to Query NV_L4T_CUDA_TARGET_POST_INSTALL_COMP
18:01:18 INFO : change working directory to /tmp
18:01:18 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' cuda-toolkit-10-0"
18:01:18 INFO : Target Deb package [{cuda-toolkit-10-0 10.0}] not installed
18:01:18 ERROR : command terminated with error
18:01:18 ERROR : failed to query component: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP version: 10.0 for bundle:
18:01:18 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP -v=7.6 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:18 INFO : Using GenericInstaller to Query NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP
18:01:18 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' libcudnn7"
18:01:18 INFO : Target Deb package [{libcudnn7 7.6.3.28-1+cuda10.0}] not installed
18:01:19 ERROR : failed to query component: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP version: 7.6 for bundle:
18:01:19 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP -v=6.0 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:19 INFO : Using GenericInstaller to Query NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP
18:01:19 INFO : change working directory to /tmp
18:01:19 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' libnvinfer6"
18:01:19 INFO : Target Deb package [{libnvinfer6 6.0.1-1+cuda10.0}] not installed
18:01:19 ERROR : command terminated with error
18:01:19 ERROR : failed to query component: NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP version: 6.0 for bundle:
18:01:19 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP -v=4.1.1 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:19 INFO : Using GenericInstaller to Query NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP
18:01:19 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' libopencv"
18:01:19 INFO : Target Deb package [{libopencv 4.1.1-2-gd5a58aa75}] not installed
18:01:19 ERROR : failed to query component: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP version: 4.1.1 for bundle:
18:01:19 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP -v=1.6 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:19 INFO : Using GenericInstaller to Query NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP
18:01:19 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' libvisionworks"
18:01:19 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' libvisionworks-dev"
18:01:20 INFO : change working directory to /tmp
18:01:20 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' libvisionworks-samples"
18:01:20 INFO : Target Deb package [{libvisionworks 1.6} {libvisionworks-dev 1.6} {libvisionworks-samples 1.6}] not installed
18:01:20 ERROR : command terminated with error
18:01:20 ERROR : failed to query component: NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP version: 1.6 for bundle:
18:01:20 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_VPI_TARGET_POST_INSTALL_COMP -v=0.1.0 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:20 INFO : Using GenericInstaller to Query NV_VPI_TARGET_POST_INSTALL_COMP
18:01:21 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' vpi"
18:01:21 INFO : Target Deb package [{vpi 0.1.0}] not installed
18:01:21 ERROR : command terminated with error
18:01:21 ERROR : failed to query component: NV_VPI_TARGET_POST_INSTALL_COMP version: 0.1.0 for bundle:
18:01:21 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_DOCKER_TARGET_POST_INSTALL_COMP -v=0.9.0 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:21 INFO : Using GenericInstaller to Query NV_DOCKER_TARGET_POST_INSTALL_COMP
18:01:21 INFO : change working directory to /tmp
18:01:21 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' nvidia-container-csv-cuda"
18:01:21 INFO : Target Deb package [{nvidia-container-csv-cuda 10.0.326-1}] not installed
18:01:21 ERROR : failed to query component: NV_DOCKER_TARGET_POST_INSTALL_COMP version: 0.9.0 for bundle:
18:01:21 DEBUG : running command < /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=query -i=NV_MULTIMEDIA_API_TARGET_POST_INSTALL_T186_COMP -v=32.3 -L=.nvsdkm/logs/JetPack_4.3_Linux -c=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 >
18:01:21 INFO : Using GenericInstaller to Query NV_MULTIMEDIA_API_TARGET_POST_INSTALL_T186_COMP
18:01:21 INFO : exec_command: ssh -F /dev/null -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 "dpkg-query -W -f='\${db:Status-abbrev} \${Version}' nvidia-l4t-jetson-multimedia-api"
18:01:22 INFO : Target Deb package [{nvidia-l4t-jetson-multimedia-api 32.3.1-20191209230245}] not installed
18:01:22 ERROR : command terminated with error
18:01:22 ERROR : failed to query component: NV_MULTIMEDIA_API_TARGET_POST_INSTALL_T186_COMP version: 32.3 for bundle:
18:01:22 INFO : Device Mode Host Setup in Target SDK : Start to install 'Device Mode Host Setup in Target SDK'
18:01:22 DEBUG : Device Mode Host Setup in Target SDK : running command < cd 'nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='eyJpZCI6Ik5WX0RFVklDRV9NT0RFX1NFVFVQX1RBUkdFVF9DT01QIiwibmFtZSI6IkRldmljZSBNb2RlIEhvc3QgU2V0dXAgaW4gVGFyZ2V0IFNESyIsImRlc2NyaXB0aW9uIjoiU2V0dXBzIGZvciBkZXZpY2UgbW9kZSBob3N0IHBhcnQgaW4gTDRUICBiZWZvcmUgaW5zdGFsbCB0YXJnZXQgY29tcG9uZW50cywgdG8gbGV0IHRoZSB0YXJnZXQgY2FuIGFjY2VzcyBob3N0IGludGVybmV0LiIsImNvbXBUeXBlIjoidGFyZ2V0IiwiaXNWaXNpYmxlIjpmYWxzZSwiaXNEZXRlY3RhYmxlSW5zdGFsbCI6ZmFsc2UsImlzSW5zdGFsbFBhdGhDdXN0b21pemFibGUiOnRydWUsInZlcnNpb24iOiIxLjAiLCJvcGVyYXRpbmdTeXN0ZW1z
Tried few times with no luck. Please assist.
The SDK components installation still fails for me after doing a fresh install of host OS to Ubuntu 18.04, re-installing SDK manager and attempting again.
Can someone please respond with some fix/workaround for this issue. Thanks
In the very first post #1, does the actual log stop here?
04:21:51 ERROR : Flash Jetson TX1 : Board ID(2180) version(410)
04:25:12 ERROR : Flash Jetson TX1 :
04:25:12 ERROR : Flash Jetson TX1 : 0: RAW: 3727360( 910 blks) ==> 28:3727372
04:25:12 ERROR : Flash Jetson TX1 : 3: SKP: 61440( 15 blks) ==> 3731520:12
04:25:12 ERROR : Flash Jetson TX1 : 4: RAW: 1699840( 415 blks) ==> 3731532:1699852
04:25:12 ERROR : Flash Jetson TX1 : 5: SKP: 31854592( 7777 blks) ==> 5431384:12
04:25:12 ERROR : Flash Jetson TX1 : 6: RAW: 7016448( 1713 blks) ==> 5431396:7016460
Also, is there any possibility you can upgrade the host PC from Ubuntu 16.04 to Ubuntu 18.04? I am not positive if 16.04 is still compatible, but I know that 18.04 is. Even if 16.04 is compatible there have been a lot more people using 18.04, so I know 18.04 will work.
In that log where I quoted the excerpt the “ERROR” might not actually be an error. However, what those steps are doing is converting a very large raw image into a smaller sparse image (smaller, but definitely still large). The conversion of raw to sparse stopped much too early and never completed. The source of the file is nearly the entire size of the TX1’s eMMC, so just under 16GB. The sparse image is around 2GB. I would expect this to stop if the host PC ran out of hard disk space. Assuming the flash is from somewhere in “~/nvidia/nvidia_sdk/”, and so this command (run on the host PC) would give some information about disk capacity:
df -H ~/nvidia/nvidia_sdk/
How much disk space is left at that location?
An earlier log which also could be related to run out of disk space:
05:17:02 ERROR : Drivers for Jetson TX1/Nano : W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: file:/var/cuda-repo-9-0-local Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY F60F4B3D7FA2AF80
05:17:02 ERROR : Drivers for Jetson TX1/Nano : Some index files failed to download. They have been ignored, or old ones used instead.
05:17:53 ERROR : OpenCV on Host : download error: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1604/OpenCV-4.1.1-2-gd5a58aa-x86_64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
05:27:56 ERROR : File System and OS : /bin/ls:
05:27:56 ERROR : File System and OS : cannot access '*.dtb'
05:27:56 ERROR : File System and OS : : No such file or directory
If disk space were filled, then you might end up with truncated downloads before the earlier raw/sparse image conversion ever started. There may be other issues with older Ubuntu 16.04 not present on 18.04.
Quick update :
Did a fresh installation of Ubuntu 18.04 on my host PC once again and the issue is resolved for me. For some reason, it didn’t work the first time I did that. Thanks!
I tried with Ubuntu 18.04, with no success. OS flash happened, with some errors (apparently those errors could be ignored - I’ve put a link to the other thread at the bottom). The SDK components, however, couldn’t be installed. Tried running
and it seems space is not an issue - only 2.7GB out of 9.9GB was used. I did notice another anomaly though. When we tried running the SDK Manager install on 18.04, the board IDs did not match.
The initial part of the error log was the same,nearly 4700 lines similar to the first three of this code section. The anomaly is immediately after, the line that says “Could not detect Nvidia Jetson device”.
11:44:19 ERROR : Flash Jetson TX1 : 4701: SKP: 33554432( 8192 blks) ==> 4411894904:12
11:44:19 ERROR : Flash Jetson TX1 : 4702: RAW: 18214912( 4447 blks) ==> 4411894916:18214924
11:44:20 ERROR : Flash Jetson TX1 : 4703: SKP: 1793724416( 437921 blks) ==> 4430109840:12
11:44:20 ERROR : Flash Jetson TX1 : -- Total: ---------------------------------------------------
11:50:41 ERROR : Could not detect Nvidia Jetson device connected to USB. Verify that: 1. is connected to this host machine with a USB cable. 2. Jetson's Ubuntu OS is up and running. 3. Ubuntu 'System configuration wizard' is completed on the device. This can be validated by running the 'lsusb' command on your host, and look for "0955:7721" (NVIDIA Corp). Or use the 'Manual Setup' instead.
11:50:52 ERROR : Could not connect to the target device. Verify that: 1. The device is connected to this host machine with a USB cable. 2. Ubuntu 'System configuration wizard' is completed on the device. 3. Jetson's Ubuntu OS is up and running. 4. Jetson usb device mode service is started successfully. * See readme file in the auto-mounted "L4T-README" folder for more details.
11:51:02 ERROR : command terminated with error
11:51:02 ERROR : failed to query component: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP version: 10.0 for bundle:
11:51:03 ERROR : command terminated with error
11:51:03 ERROR : failed to query component: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP version: 7.6 for bundle:
11:51:04 ERROR : command terminated with error
11:51:04 ERROR : failed to query component: NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP version: 6.0 for bundle:
11:51:05 ERROR : command terminated with error
11:51:05 ERROR : failed to query component: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP version: 4.1.1 for bundle:
11:51:08 ERROR : command terminated with error
11:51:08 ERROR : failed to query component: NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP version: 1.6 for bundle:
11:51:10 ERROR : command terminated with error
11:51:10 ERROR : failed to query component: NV_VPI_TARGET_POST_INSTALL_COMP version: 0.1.0 for bundle:
11:51:11 ERROR : command terminated with error
11:51:11 ERROR : failed to query component: NV_DOCKER_TARGET_POST_INSTALL_COMP version: 0.9.0 for bundle:
11:51:12 ERROR : command terminated with error
11:51:12 ERROR : failed to query component: NV_MULTIMEDIA_API_TARGET_POST_INSTALL_T210_COMP version: 32.3 for bundle:
11:51:13 ERROR : command terminated with error
11:51:13 ERROR : failed to query component: NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP version: 4.0.2 for bundle:
11:52:44 ERROR : CUDA Toolkit for L4T : : command safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb" 5; sleep 5; ; safe_apt_install "sudo apt-get -y install cuda-toolkit-10-0 " 5 finished with error
11:52:44 ERROR : CUDA Toolkit for L4T : command terminated with error
11:52:44 ERROR : CUDA Toolkit for L4T : install 'CUDA Toolkit for L4T' failure, command < cd '/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_CUDA_TARGET_POST_INSTALL_COMP' -v='10.0' -l='/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' -L='/home/kharade/.nvsdkm/logs/JetPack_4.3_Linux' -p='3078' -t='P2180' -e='/home/kharade/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb' > terminated with error
11:52:49 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : : command safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb" 5; sleep 5; finished with error
11:52:49 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : command terminated with error
11:52:49 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : install 'NVIDIA Container Runtime with Docker integration (Beta)' failure, command < cd '/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_DOCKER_TARGET_POST_INSTALL_COMP' -v='0.9.0' -l='/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' -L='/home/kharade/.nvsdkm/logs/JetPack_4.3_Linux' -p='3078' -t='P2180' -e='/home/kharade/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0_beta.1_arm64.deb' > terminated with error
11:52:49 ERROR : Unavailable components detected, please check log
11:52:49 ERROR : cuDNN on Target : cuDNN on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
11:52:49 ERROR : TensorRT on Target : TensorRT on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
11:52:49 ERROR : OpenCV on Target : OpenCV on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
11:52:49 ERROR : VisionWorks on Target : VisionWorks on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
11:52:49 ERROR : VPI : VPI Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
11:52:49 ERROR : Multimedia API : Multimedia API Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
11:52:49 ERROR : DeepStream : DeepStream Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
11:59:17 ERROR : command terminated with error
11:59:17 ERROR : failed to query component: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP version: 10.0 for bundle:
11:59:17 ERROR : failed to query component: NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP version: 7.6 for bundle:
11:59:18 ERROR : command terminated with error
11:59:18 ERROR : failed to query component: NV_L4T_TENSORRT_NODLA_TARGET_POST_INSTALL_COMP version: 6.0 for bundle:
11:59:19 ERROR : command terminated with error
11:59:19 ERROR : failed to query component: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP version: 4.1.1 for bundle:
11:59:20 ERROR : command terminated with error
11:59:20 ERROR : failed to query component: NV_L4T_VISIONWORKS_TARGET_POST_INSTALL_COMP version: 1.6 for bundle:
11:59:21 ERROR : command terminated with error
11:59:21 ERROR : failed to query component: NV_VPI_TARGET_POST_INSTALL_COMP version: 0.1.0 for bundle:
11:59:22 ERROR : command terminated with error
11:59:22 ERROR : failed to query component: NV_DOCKER_TARGET_POST_INSTALL_COMP version: 0.9.0 for bundle:
11:59:22 ERROR : failed to query component: NV_MULTIMEDIA_API_TARGET_POST_INSTALL_T210_COMP version: 32.3 for bundle:
11:59:23 ERROR : command terminated with error
11:59:23 ERROR : failed to query component: NV_DEEPSTREAM_TARGET_POST_INSTALL_COMP version: 4.0.2 for bundle:
12:00:47 ERROR : CUDA Toolkit for L4T : : command safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb" 5; sleep 5; ; safe_apt_install "sudo apt-get -y install cuda-toolkit-10-0 " 5 finished with error
12:00:47 ERROR : CUDA Toolkit for L4T : command terminated with error
12:00:47 ERROR : CUDA Toolkit for L4T : install 'CUDA Toolkit for L4T' failure, command < cd '/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_CUDA_TARGET_POST_INSTALL_COMP' -v='10.0' -l='/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' -L='/home/kharade/.nvsdkm/logs/JetPack_4.3_Linux' -p='3078' -t='P2180' -e='/home/kharade/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb' > terminated with error
12:00:52 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : : command safe_apt_install "sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb" 5; sleep 5; finished with error
12:00:52 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : command terminated with error
12:00:53 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : install 'NVIDIA Container Runtime with Docker integration (Beta)' failure, command < cd '/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_DOCKER_TARGET_POST_INSTALL_COMP' -v='0.9.0' -l='/home/kharade/nvidia/Nvidia_sdk/JetPack_4.3_Linux_P2180' -L='/home/kharade/.nvsdkm/logs/JetPack_4.3_Linux' -p='3078' -t='P2180' -e='/home/kharade/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0_beta.1_arm64.deb' > terminated with error
12:00:53 ERROR : Unavailable components detected, please check log
12:00:53 ERROR : cuDNN on Target : cuDNN on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
12:00:53 ERROR : TensorRT on Target : TensorRT on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
12:00:53 ERROR : OpenCV on Target : OpenCV on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
12:00:53 ERROR : VisionWorks on Target : VisionWorks on Target Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
12:00:53 ERROR : VPI : VPI Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
12:00:53 ERROR : Multimedia API : Multimedia API Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
12:00:53 ERROR : DeepStream : DeepStream Skipped. Due to its dependencies fail to install: CUDA Toolkit for L4T,
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
 Flash of target hardware was skipped.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2020,
NVIDIA CORPORATION
All rights reserved.
NVIDIA Developer
But the Jetson TX1 was connected, do take a look at line 6:
kharade@kharade-GL553VD:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0a2a Intel Corp.
Bus 001 Device 002: ID 13d3:5654 IMC Networks
Bus 001 Device 004: ID 0b05:1854 ASUSTek Computer, Inc.
Bus 001 Device 009: ID 0955:7020 NVidia Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
SDK Manager says the ID is supposed to be “0955:7721” (NVidia Corp.) but the lsusb command gives us a different ID, “0955:7020” (NVidia Corp.). It isn’t a case of selecting the wrong target - I made sure the target device was Jetson TX1, before starting the SDK Manager install and flash.
So I decided to investigate the ‘Manual Setup’ option that the SDK Manager terminal mentions. I wasn’t able to find an explicit manual setup, but I presume it’s the procedure outlined here -> https://docs.nvidia.com/jetpack-l4t/2_1/content/developertools/mobile/jetpack/jetpack_l4t/2.0/jetpack_l4t_install.htm
But when I opened the first link on the page that is supposed to let us download JetPack installer, all I found there is a link to download SDK manager instead of the JetPack installer. Dead end - so is this even the correct approach to a manual setup?
TL;DR
  • Board ID on the SDK manager terminal and Linux host PC terminal don't match. Why?
  • How do I perform the "Manual Setup" that's mentioned on the SDK Manager terminal?
Thanks for the help.
For more context, we got a ‘cannot find .dtb file’ error while flashing the OS. Is that relevant? The errors in this post showed up during SDK component installation. https://devtalk.nvidia.com/default/topic/1071145/jetson-tx1/error-building-libargus-samples/post/5431140/#5431140 (last two posts in this thread contain information about the dtb error)
@vishnuvenkatesh99: The 0955:7721 is a TX1, the 0955:7720 is a Nano. I don’t know how those could end up wrong. One topic which repeatedly shows up though when no device is detected is the use of a VM. Is your host PC a VM? If not, then is there any kind of customized carrier board involved? Is there anything connected to the TX1 during the flash other than keyboard/monitor/mouse?
We didn’t use a VM for this particular attempt, but we did try using a VM once before for this board (we ended up reflashing the OS a couple of times because some libraries weren’t being installed correctly. The VM was used during a previous attempt, but this most recent one was on a proper Ubuntu 18.04 machine. Could the VM attempt have caused any permanent damage?)
No customized carrier board, just the standard Jetson TX1 Developer Kit.
We also connected a LAN cable to the board, and of course the micro-USB connecting the host to the device.
Thanks for your assistance.
VMs won’t cause damage to hardware. Note that recovery mode is only used during the flash, and that the lsusb output is for recovery mode only. When installing optional packages, e.g., CUDA, the system is fully booted and no longer in recovery mode. Extra packages then install via ssh if the first boot account creation has been completed.
In general, VMs have a tendency to lose connectivity of one kind or another. As connections drop and come back up the parent o/s my decide to keep ownership and the VM will lose its path to the Jetson (either USB or ethernet).
When you say that libraries were not being installed correctly this is quite different than flash failing (unless the library is part of the base operating system and the system won’t even boot). You do need an HDMI monitor and keyboard attached to the Jetson during the flash for the point when flash completes and first time boot account setup runs.
If first time boot and account setup does not succeed, then no packages can be added since ssh to that account is required to continue. Have you monitored with an HDMI monitor to see if first boot account setup has begun? Or even with serial console?
If a flash completes, then right after the flash what is the exact byte size of the file “Linux_for_Tegra/bootloader/system.img.raw”? This should be evenly divisible by 1024 either twice (MiB) or three times (GiB). If the file size is not evenly divisible, then it indicates the image itself was corrupt/truncated. If the image is of valid size, then probably the flash is valid and issues are related to either account setup or steps which occur during optional package installation.
