SDK Manager don't work
Hi everyone, i’m trying to install the jetpack 4.2.1 using the unique method sdkmanager. But after to install in 2 computers with ubuntu 16.04 then installer have different problems and stopped it trying compile Os image… in 96.9%
Is incredible that 2 computers have the same problem, then it means that the system is not good. I was using the old method from older versions of jetpack and never i had this kind of problem.
Please NVIDIA developers we need to come back or if you can provide a solution for the sdkmanager installer?
Hi gabriel.gianic7m2,
Thanks for reporting.
Does it stuck at 96.9% and the bar not moving or it actually fails with error messages. Is there any error message you can see? Also it would be great if you can provide the logs, so we can see the problem more clear.
21:34:24 INFO : Drivers for Jetson TX2 & TX2i : 404 Not Found [Mirror: Index of /ubuntu]
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : Ign:47 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/main arm64 Packages
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : Fetched 4,074 kB in 5min 5s (13.3 kB/s)
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : Reading package lists…
21:34:25 ERROR : Drivers for Jetson TX2 & TX2i : E: Failed to fetch mirror://mirrors.ubuntu.com/mirrors.txt/dists/xenial/main/binary-arm64/Packages 404 Not Found [Mirror: Index of /ubuntu]
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : E: Failed to fetch mirror://mirrors.ubuntu.com/mirrors.txt/dists/xenial-proposed/universe/binary-arm64/Packages 404 Not Found [Mirror: Index of /ubuntu]
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : E: Some index files failed to download. They have been ignored, or old ones used instead.
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : *begin sudo apt-get install -y pigz lbzip2, 5
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : Building dependency tree…
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : Reading state information…
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : Package pigz is not available, but is referred to by another package.
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : This may mean that the package is missing, has been obsoleted, or
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : is only available from another source
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : E: Package ‘pigz’ has no installation candidate
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : E: Unable to locate package lbzip2
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : Unhandled error when running sudo apt-get install -y pigz lbzip2
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : exit status 1
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : [ Package Install Finished with Error ]
21:34:25 ERROR : Drivers for Jetson TX2 & TX2i : NV_L4T_DRIVERS_TX2_COMP command /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh finished with error
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : [ 572.00 KB used. Disk Avail: 736.05 GB ]
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : [ NV_L4T_DRIVERS_TX2_COMP Install took 5m6s ]
21:34:25 INFO : Drivers for Jetson TX2 & TX2i : command /tmp/tmp_NV_L4T_DRIVERS_TX2_COMP.sh finished with error
21:34:25 ERROR : Drivers for Jetson TX2 & TX2i : command terminated with error
21:34:25 ERROR : install ‘Drivers for Jetson TX2 & TX2i’ failure, command < cd ‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘eyJpZCI6Ik5WX0w0VF9EUklWRVJTX1RYMl9DT01QIiwibmFtZSI6IkRyaXZlcnMgZm9yIEpldHNvbiBUWDIgJiBUWDJpIiwiZGVzY3JpcHRpb24iOiJOVklESUEgVGVncmEgTGludXggRHJpdmVyIFBhY2thZ2UiLCJjb21wVHlwZSI6InRhcmdldF9pbWFnZSIsImlzVmlzaWJsZSI6dHJ1ZSwibGljZW5zZUlkIjoiTlZfSkVUUEFDS19PU19FVUxBIiwiaXNEZXRlY3RhYmxlSW5zdGFsbCI6ZmFsc2UsImlzSW5zdGFsbFBhdGhDdXN0b21pemFibGUiOnRydWUsInZlcnNpb24iOiIzMi4yIiwib3BlcmF0aW5nU3lzdGVtcyI6WyJ1YnVudHUxNjA0IiwidWJ1bnR1MTgwNCJdLCJpbnN0YWxsU2l6ZU1CIjozNTYsImRvd25sb2FkRmlsZXMiOlt7InVybCI6IlAzMzEwL0pldHNvbl9MaW51eF9SMzIuMi4wX2FhcmNoNjQudGJ6MiIsImZpbGVOYW1lIjoiSmV0c29uX0xpbnV4X1IzMi4yLjBfYWFyY2g2NC50YnoyIiwic2l6ZSI6MTMwOTYwMDE2LCJjaGVja3N1bSI6ImZhYTRmYjBjZjc0MjA2MTZkYWE2ZDFlOTA4NWJlMDIxIiwiY2hlY2tzdW1UeXBlIjoibWQ1IiwiaW5zdGFsbFBhcmFtZXRlcnMiOnsiaW5zdGFsbFR5cGUiOiJjbWQiLCJhZGRpdGlvbmFsUGFyYW1ldGVycyI6eyJpbnN0YWxsRGlyIjoie3tUQVJHRVRfUk9PVH19L3t7QlVORExFX1RJVExFfX1fe3tCT0FSRF9JRH19IiwiaW5zdGFsbENvbW1hbmRzIjpbeyJleGVjQmFzaCI6WyJzdWRvIGFwdC1nZXQgdXBkYXRlIHx8IHRydWUiLCJzYWZlX2FwdF9pbnN0YWxsIFwic3VkbyBhcHQtZ2V0IGluc3RhbGwgLXkgcGlneiBsYnppcDJcIiA1IiwidGFyIHhwZiB7e0ZJTEVfUEFUSH19Il19XX19LCJjYWNoZWRVcmwiOiJodHRwczovL2RldmVsb3Blci5udmlkaWEuY29tL2Fzc2V0cy9lbWJlZGRlZC9zZWN1cmUvdG9vbHMvZmlsZXMvamV0cGFjay1zZGtzL2pldHBhY2stNC4yLjEtZ2EvSkVUUEFDS180MjFfYjk3L1AzMzEwL0pldHNvbl9MaW51eF9SMzIuMi4wX2FhcmNoNjQudGJ6MiIsImN1cnJlbnREb3dubG9hZGVkVXJsIjoiaHR0cHM6Ly9kZXZlbG9wZXIubnZpZGlhLmNvbS9hc3NldHMvZW1iZWRkZWQvc2VjdXJlL3Rvb2xzL2ZpbGVzL2pldHBhY2stc2Rrcy9qZXRwYWNrLTQuMi4xLWdhL0pFVFBBQ0tfNDIxX2I5Ny9QMzMxMC9KZXRzb25fTGludXhfUjMyLjIuMF9hYXJjaDY0LnRiejIifV0sInRhcmdldElkcyI6WyJQMzMxMCIsIlAzNDg5LTAwMDAiLCJQMzQ4OS0wMDgwIl0sImRlcGVuZGVuY2llcyI6W3siaWQiOiJVQlVOVFVfQlpJUDJfUEFUQ0hfSU5fVEFSR0VUX0lNQUdFIiwib3BlcmF0b3IiOiI9PSIsInZlciI6IjEuMCIsIl9pZCI6IlVCVU5UVV9CWklQMl9QQVRDSF9JTl9UQVJHRVRfSU1BR0VAUDMzMTAifV0sImV4dGVybmFsX2RlcGVuZGVuY2llcyI6W10sInRhcmdldElEIjoiUDMzMTAiLCJfaWQiOiJOVl9MNFRfRFJJVkVSU19UWDJfQ09NUEBQMzMxMCIsInBhcmVudElEIjoiTlZfSkVUUEFDS19MNFRfSU1BR0VfU0VUVVBfVEFSR0VUX0dST1VQIiwiX3BhcmVudElEIjoiTlZfSkVUUEFDS19MNFRfSU1BR0VfU0VUVVBfVEFSR0VUX0dST1VQQFAzMzEwIiwiaW5zdGFsbFN0YXR1cyI6Im5vbmUiLCJhY3Rpb24iOjEsImRvd25sb2FkRXJyb3JzIjpbXSwidmVyaWZ5IjpmYWxzZSwiZXhlYyI6Ii9ob21lL2dpYW5pZy9udmlkaWEvc2RrbV9kb3dubG9hZHMvSmV0c29uX0xpbnV4X1IzMi4yLjBfYWFyY2g2NC50YnoyIiwiYnVuZGxlVGl0bGUiOiJKZXRQYWNrXzQuMi4xX0xpbnV4X0dBIiwiaW5zdGFsbFBhdGgiOiIvaG9tZS9naWFuaWcvbnZpZGlhL252aWRpYV9zZGsvSmV0UGFja180LjIuMV9MaW51eF9HQV9QMzMxMCIsImluc3RhbGxSb290IjoiL2hvbWUvZ2lhbmlnL252aWRpYS9udmlkaWFfc2RrIiwiYm9hcmRJRCI6IlAzMzEwIiwidGFyZ2V0QWNjZXNzSW5mbyI6eyJ1c2VyIjoibnZpZGlhIiwicGFzc3dvcmQiOiJudmlkaWEiLCJob3N0IjoiMTkyLjE2OC41NS4xIiwicG9ydCI6IjIyIn0sImlzRHJ5UnVuIjpmYWxzZX0=’ -i=‘NV_L4T_DRIVERS_TX2_COMP’ -v=‘32.2’ -l=‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ -L=‘/home/gianig/.nvsdkm/logs/JetPack_4.2.1_Linux_GA’ -p=‘23895’ -t=‘P3310’ -e=‘/home/gianig/nvidia/sdkm_downloads/Jetson_Linux_R32.2.0_aarch64.tbz2’ > terminated with error
21:34:25 ERROR : Unavailable components detected, please check log
21:34:25 ERROR : File System and OS Skipped. Due to its dependencies fail to install: Drivers for Jetson TX2 & TX2i,
The logs showing:
From those, seems like both of the systems you have either get an apt-get problem or network problem.
SDK Manager can not resolve those system setting problems. Please resolve those problems first then try SDK Manager again.
Below method may help but not guaranteed working:
Make sure you are not under any firewall that blocking upper links in the log.
try command:
sudo apt-get -y update
sudo apt-get -y dist-upgrade
Hi now the system freeze in 15.83% of the installation
DETAILS TERMINAL
Component Name: All
Message Type: All
Filter text here…
21:24:35 INFO : null
21:24:37 INFO : Bzip2 Patch Setup In Target Image : download ‘Bzip2 Patch Setup In Target Image’ success
21:24:37 INFO : Start to install ‘Bzip2 Patch Setup In Target Image’
21:24:37 DEBUG : Bzip2 Patch Setup In Target Image : running command < cd ‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE’ -v=‘1.0’ -l=‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ -L=‘/home/gianig/.nvsdkm/logs/JetPack_4.2.1_Linux_GA’ -p=‘22584’ -t=‘P3310’ -e=‘/home/gianig/nvidia/sdkm_downloads’ >
21:24:37 INFO : Bzip2 Patch Setup In Target Image : [ Disk Avail:737.46 GB ]
21:24:37 INFO : Bzip2 Patch Setup In Target Image : Using GenericInstaller to Install UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE
21:24:37 INFO : Bzip2 Patch Setup In Target Image : change working directory to /home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310
21:24:37 INFO : Bzip2 Patch Setup In Target Image : [ Component Install Started ]
21:24:37 INFO : Bzip2 Patch Setup In Target Image : current working directory is /home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310
21:24:37 INFO : Bzip2 Patch Setup In Target Image : exec_command [host]:
21:24:37 INFO : Bzip2 Patch Setup In Target Image : **********************
21:24:37 INFO : Bzip2 Patch Setup In Target Image : #!/bin/bash
21:24:37 INFO : Bzip2 Patch Setup In Target Image : set -e
21:24:37 INFO : Bzip2 Patch Setup In Target Image : function safe_apt_install {
21:24:37 INFO : Bzip2 Patch Setup In Target Image : echo “*begin $1, $2”
21:24:37 INFO : Bzip2 Patch Setup In Target Image : tmp_log=/tmp/jetpack_dpkg_log.txt
21:24:37 INFO : Bzip2 Patch Setup In Target Image : sudo rm -f $tmp_log
21:24:37 INFO : Bzip2 Patch Setup In Target Image : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
21:24:37 INFO : Bzip2 Patch Setup In Target Image : while [ ${CMD_STATUS} -ne 0 ]; do
21:24:37 INFO : Bzip2 Patch Setup In Target Image : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
21:24:37 INFO : Bzip2 Patch Setup In Target Image : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
21:24:37 INFO : Bzip2 Patch Setup In Target Image : else
21:24:37 INFO : Bzip2 Patch Setup In Target Image : echo “Unhandled error when running $1”; exit 1
21:24:37 INFO : Bzip2 Patch Setup In Target Image : fi
21:24:37 INFO : Bzip2 Patch Setup In Target Image : done
21:24:37 INFO : Bzip2 Patch Setup In Target Image : }
21:24:37 INFO : Bzip2 Patch Setup In Target Image : bzip2Version=dpkg -l bzip2 | tail -n 1 | awk '{ printf $3 }'
21:24:37 INFO : Bzip2 Patch Setup In Target Image : libbzip2Version=dpkg -l libbz2-1.0 | tail -n 1 | awk '{ printf $3 }'
21:24:37 INFO : Bzip2 Patch Setup In Target Image : if [[ “$bzip2Version” != ‘1.0.6-8’ || “$libbzip2Version” != ‘1.0.6-8’ ]]; then
21:24:37 INFO : Bzip2 Patch Setup In Target Image : sudo apt-get update
21:24:37 INFO : Bzip2 Patch Setup In Target Image : safe_apt_install "sudo apt-get install -y --allow-downgrades bzip2=1.0.6-8 libbz2-1.0=1.0.6-8 " 5
21:24:37 INFO : Bzip2 Patch Setup In Target Image : exit 0
21:24:37 INFO : Bzip2 Patch Setup In Target Image : exec_command: /tmp/tmp_UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE.sh
21:24:38 INFO : Bzip2 Patch Setup In Target Image : [host] [sudo] password for gianig:
21:24:40 INFO : Bzip2 Patch Setup In Target Image : Hit:1 Index of linux/ubuntu/ xenial InRelease
21:24:40 INFO : Bzip2 Patch Setup In Target Image : Get:2 Index of /ubuntu xenial-security InRelease [109 kB]
21:24:41 INFO : Drivers for Jetson TX2 & TX2i : Found file /home/gianig/nvidia/sdkm_downloads/Jetson_Linux_R32.2.0_aarch64.tbz2 with correct checksum, skip downloading.
21:24:41 INFO : Drivers for Jetson TX2 & TX2i : download ‘Drivers for Jetson TX2 & TX2i’ success
21:24:41 INFO : Bzip2 Patch Setup In Target Image : Ign:3 http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1604/x86_64 InRelease
21:24:41 INFO : Bzip2 Patch Setup In Target Image : Hit:4 http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1604/x86_64 Release
21:24:41 INFO : Bzip2 Patch Setup In Target Image : Get:5 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed InRelease [260 kB]
21:24:41 INFO : Bzip2 Patch Setup In Target Image : Get:6 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates InRelease [109 kB]
21:24:42 INFO : Bzip2 Patch Setup In Target Image : Get:7 Index of /ubuntu xenial-security/multiverse amd64 DEP-11 Metadata [2,464 B]
21:24:42 INFO : Bzip2 Patch Setup In Target Image : Get:9 Index of /ubuntu xenial-security/universe amd64 Packages [451 kB]
21:24:42 INFO : Bzip2 Patch Setup In Target Image : Get:10 Index of /ubuntu xenial-security/universe Translation-en [184 kB]
21:24:42 INFO : Bzip2 Patch Setup In Target Image : Get:11 Index of /ubuntu xenial-security/universe amd64 DEP-11 Metadata [124 kB]
21:24:43 INFO : Bzip2 Patch Setup In Target Image : Get:12 Index of /ubuntu xenial-security/universe DEP-11 64x64 Icons [194 kB]
21:24:43 INFO : Bzip2 Patch Setup In Target Image : Get:13 Index of /ubuntu xenial-security/main amd64 DEP-11 Metadata [73.7 kB]
21:24:43 INFO : Bzip2 Patch Setup In Target Image : Get:14 Index of /ubuntu xenial-security/main DEP-11 64x64 Icons [73.2 kB]
21:24:49 INFO : File System and OS : Found file /home/gianig/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.0_aarch64.tbz2 with correct checksum, skip downloading.
21:24:49 INFO : File System and OS : download ‘File System and OS’ success
I continue with the same problem. I change my network. I donwload manually the file tegra_root but the problem continue. Really i don’t kwow what happen. I’m in italy.
23:00:42 INFO : null
23:00:46 INFO : Bzip2 Patch Setup In Target Image : download ‘Bzip2 Patch Setup In Target Image’ success
23:00:46 INFO : Start to install ‘Bzip2 Patch Setup In Target Image’
23:00:46 DEBUG : Bzip2 Patch Setup In Target Image : running command < cd ‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE’ -v=‘1.0’ -l=‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ -L=‘/home/gianig/.nvsdkm/logs/JetPack_4.2.1_Linux_GA’ -p=‘8931’ -t=‘P3310’ -e=‘/home/gianig/nvidia/sdkm_downloads’ >
23:00:46 INFO : Bzip2 Patch Setup In Target Image : [ Disk Avail:738.59 GB ]
23:00:46 INFO : Bzip2 Patch Setup In Target Image : Using GenericInstaller to Install UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE
23:00:46 INFO : Bzip2 Patch Setup In Target Image : change working directory to /home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310
23:00:46 INFO : Bzip2 Patch Setup In Target Image : [ Component Install Started ]
23:00:46 INFO : Bzip2 Patch Setup In Target Image : current working directory is /home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310
23:00:46 INFO : Bzip2 Patch Setup In Target Image : exec_command [host]:
23:00:46 INFO : Bzip2 Patch Setup In Target Image : **********************
23:00:46 INFO : Bzip2 Patch Setup In Target Image : #!/bin/bash
23:00:46 INFO : Bzip2 Patch Setup In Target Image : set -e
23:00:46 INFO : Bzip2 Patch Setup In Target Image : function safe_apt_install {
23:00:46 INFO : Bzip2 Patch Setup In Target Image : echo “*begin $1, $2”
23:00:46 INFO : Bzip2 Patch Setup In Target Image : tmp_log=/tmp/jetpack_dpkg_log.txt
23:00:46 INFO : Bzip2 Patch Setup In Target Image : sudo rm -f $tmp_log
23:00:46 INFO : Bzip2 Patch Setup In Target Image : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
23:00:46 INFO : Bzip2 Patch Setup In Target Image : while [ ${CMD_STATUS} -ne 0 ]; do
23:00:46 INFO : Bzip2 Patch Setup In Target Image : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
23:00:46 INFO : Bzip2 Patch Setup In Target Image : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
23:00:46 INFO : Bzip2 Patch Setup In Target Image : else
23:00:46 INFO : Bzip2 Patch Setup In Target Image : echo “Unhandled error when running $1”; exit 1
23:00:46 INFO : Bzip2 Patch Setup In Target Image : fi
23:00:46 INFO : Bzip2 Patch Setup In Target Image : done
23:00:46 INFO : Bzip2 Patch Setup In Target Image : }
23:00:46 INFO : Bzip2 Patch Setup In Target Image : bzip2Version=dpkg -l bzip2 | tail -n 1 | awk '{ printf $3 }'
23:00:46 INFO : Bzip2 Patch Setup In Target Image : libbzip2Version=dpkg -l libbz2-1.0 | tail -n 1 | awk '{ printf $3 }'
23:00:46 INFO : Bzip2 Patch Setup In Target Image : if [[ “$bzip2Version” != ‘1.0.6-8’ || “$libbzip2Version” != ‘1.0.6-8’ ]]; then
23:00:46 INFO : Bzip2 Patch Setup In Target Image : sudo apt-get update
23:00:46 INFO : Bzip2 Patch Setup In Target Image : safe_apt_install "sudo apt-get install -y --allow-downgrades bzip2=1.0.6-8 libbz2-1.0=1.0.6-8 " 5
23:00:46 INFO : Bzip2 Patch Setup In Target Image : exit 0
23:00:46 INFO : Bzip2 Patch Setup In Target Image : exec_command: /tmp/tmp_UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE.sh
23:00:46 INFO : Bzip2 Patch Setup In Target Image : [host] [sudo] password for gianig:
23:00:46 INFO : Drivers for Jetson TX2 & TX2i : Found file /home/gianig/nvidia/sdkm_downloads/Jetson_Linux_R32.2.0_aarch64.tbz2 with correct checksum, skip downloading.
23:00:46 INFO : Drivers for Jetson TX2 & TX2i : download ‘Drivers for Jetson TX2 & TX2i’ success
23:00:46 INFO : Bzip2 Patch Setup In Target Image : Get:1 Index of /ubuntu xenial-security InRelease [109 kB]
23:00:46 INFO : Bzip2 Patch Setup In Target Image : Hit:2 Index of linux/ubuntu/ xenial InRelease
23:00:46 INFO : Bzip2 Patch Setup In Target Image : Ign:3 http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1604/x86_64 InRelease
23:00:46 INFO : Bzip2 Patch Setup In Target Image : Hit:4 http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1604/x86_64 Release
23:00:46 INFO : Bzip2 Patch Setup In Target Image : Get:5 mirror://mirrors.ubuntu.com/mirrors.txt xenial InRelease [247 kB]
23:00:46 INFO : Bzip2 Patch Setup In Target Image : Get:6 Index of /ubuntu xenial-security/multiverse i386 Packages [5,764 B]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Ign:8 Index of /ubuntu xenial-security/multiverse arm64 Packages
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:9 Index of /ubuntu xenial-security/multiverse amd64 DEP-11 Metadata [2,464 B]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:10 Index of /ubuntu xenial-security/universe amd64 Packages [451 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:11 Index of /ubuntu xenial-security/universe i386 Packages [391 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Ign:12 Index of /ubuntu xenial-security/universe arm64 Packages
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:13 Index of /ubuntu xenial-security/universe Translation-en [184 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:14 Index of /ubuntu xenial-security/universe amd64 DEP-11 Metadata [124 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:15 Index of /ubuntu xenial-security/universe DEP-11 64x64 Icons [194 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:16 Index of /ubuntu xenial-security/restricted i386 Packages [7,224 B]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:17 Index of /ubuntu xenial-security/main i386 Packages [576 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Ign:18 Index of /ubuntu xenial-security/main arm64 Packages
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:19 Index of /ubuntu xenial-security/main amd64 DEP-11 Metadata [73.8 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:20 Index of /ubuntu xenial-security/main DEP-11 64x64 Icons [73.2 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:21 Index of linux/ubuntu/ xenial/stable arm64 Packages [8,788 B]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:22 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed InRelease [260 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:23 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates InRelease [109 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Err:8 Index of /ubuntu xenial-security/multiverse arm64 Packages
23:00:47 INFO : Bzip2 Patch Setup In Target Image : 404 Not Found [IP: 91.189.88.162 80]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:24 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main amd64 Packages [1,201 kB]
23:00:47 INFO : Bzip2 Patch Setup In Target Image : Get:25 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main i386 Packages [1,196 kB]
23:00:48 INFO : File System and OS : Found file /home/gianig/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.0_aarch64.tbz2 with correct checksum, skip downloading.
23:00:48 INFO : File System and OS : download ‘File System and OS’ success
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Ign:26 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main arm64 Packages
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:27 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main Translation-en [568 kB]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:28 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main Translation-en_GB [426 kB]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:29 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main amd64 DEP-11 Metadata [733 kB]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:30 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main DEP-11 64x64 Icons [409 kB]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:31 mirror://mirrors.ubuntu.com/mirrors.txt xenial/restricted amd64 Packages [8,344 B]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:32 mirror://mirrors.ubuntu.com/mirrors.txt xenial/restricted i386 Packages [8,684 B]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:33 mirror://mirrors.ubuntu.com/mirrors.txt xenial/restricted Translation-en [2,908 B]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:34 mirror://mirrors.ubuntu.com/mirrors.txt xenial/restricted Translation-en_GB [2,556 B]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:35 mirror://mirrors.ubuntu.com/mirrors.txt xenial/restricted amd64 DEP-11 Metadata [186 B]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:36 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse amd64 Packages [144 kB]
23:00:49 INFO : Bzip2 Patch Setup In Target Image : Get:37 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse i386 Packages [140 kB]
23:00:50 INFO : Bzip2 Patch Setup In Target Image : Ign:38 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse arm64 Packages
23:00:51 INFO : Bzip2 Patch Setup In Target Image : Get:39 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse Translation-en [106 kB]
23:00:51 INFO : Bzip2 Patch Setup In Target Image : Get:40 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse Translation-en_GB [88.1 kB]
23:00:51 INFO : Bzip2 Patch Setup In Target Image : Get:41 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse amd64 DEP-11 Metadata [63.8 kB]
23:00:51 INFO : Bzip2 Patch Setup In Target Image : Get:42 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse DEP-11 64x64 Icons [230 kB]
23:00:51 INFO : Bzip2 Patch Setup In Target Image : Get:43 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe amd64 Packages [7,532 kB]
23:00:51 INFO : Bzip2 Patch Setup In Target Image : Get:44 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe i386 Packages [7,512 kB]
23:00:52 INFO : Bzip2 Patch Setup In Target Image : Ign:45 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe arm64 Packages
23:00:52 INFO : Bzip2 Patch Setup In Target Image : Get:46 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe Translation-en [4,354 kB]
23:00:52 INFO : Bzip2 Patch Setup In Target Image : Get:47 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe Translation-en_GB [3,040 kB]
23:00:52 INFO : Bzip2 Patch Setup In Target Image : Get:48 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe amd64 DEP-11 Metadata [3,410 kB]
23:00:52 INFO : Bzip2 Patch Setup In Target Image : Get:49 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe DEP-11 64x64 Icons [7,448 kB]
23:00:53 INFO : Bzip2 Patch Setup In Target Image : Get:50 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/universe i386 Packages [3,740 B]
23:00:53 INFO : Bzip2 Patch Setup In Target Image : Ign:51 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/universe arm64 Packages
23:00:53 INFO : Bzip2 Patch Setup In Target Image : Get:52 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/main i386 Packages [33.4 kB]
23:00:54 INFO : Bzip2 Patch Setup In Target Image : Ign:53 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/main arm64 Packages
23:00:54 INFO : Bzip2 Patch Setup In Target Image : Get:54 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/main amd64 DEP-11 Metadata [10.7 kB]
23:00:54 INFO : Bzip2 Patch Setup In Target Image : Get:55 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/multiverse i386 Packages [15.8 kB]
23:00:55 INFO : Bzip2 Patch Setup In Target Image : Ign:56 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/multiverse arm64 Packages
23:00:55 INFO : Bzip2 Patch Setup In Target Image : Get:57 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/multiverse amd64 DEP-11 Metadata [5,976 B]
23:00:55 INFO : Bzip2 Patch Setup In Target Image : Get:58 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/multiverse DEP-11 64x64 Icons [14.3 kB]
23:00:55 INFO : Bzip2 Patch Setup In Target Image : Get:59 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe amd64 Packages [758 kB]
23:00:55 INFO : Bzip2 Patch Setup In Target Image : Get:60 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe i386 Packages [692 kB]
23:00:56 INFO : Bzip2 Patch Setup In Target Image : Ign:61 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe arm64 Packages
23:00:56 INFO : Bzip2 Patch Setup In Target Image : Get:62 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe Translation-en [317 kB]
23:00:56 INFO : Bzip2 Patch Setup In Target Image : Get:63 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe amd64 DEP-11 Metadata [274 kB]
23:00:56 INFO : Bzip2 Patch Setup In Target Image : Get:64 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe DEP-11 64x64 Icons [411 kB]
23:00:56 INFO : Bzip2 Patch Setup In Target Image : Get:65 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/restricted i386 Packages [7,580 B]
23:00:56 INFO : Bzip2 Patch Setup In Target Image : Get:66 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main amd64 Packages [1,000 kB]
23:00:56 INFO : Bzip2 Patch Setup In Target Image : Get:67 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main i386 Packages [845 kB]
23:01:03 INFO : Bzip2 Patch Setup In Target Image : Ign:68 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main arm64 Packages
23:01:04 INFO : Bzip2 Patch Setup In Target Image : Get:69 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main amd64 DEP-11 Metadata [323 kB]
23:01:04 INFO : Bzip2 Patch Setup In Target Image : Get:70 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main DEP-11 64x64 Icons [214 kB]
23:01:05 INFO : Bzip2 Patch Setup In Target Image : Ign:26 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main arm64 Packages
23:01:06 INFO : Bzip2 Patch Setup In Target Image : Ign:38 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse arm64 Packages
23:01:08 INFO : Bzip2 Patch Setup In Target Image : Ign:45 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe arm64 Packages
23:01:09 INFO : Bzip2 Patch Setup In Target Image : Ign:51 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/universe arm64 Packages
23:03:09 INFO : Bzip2 Patch Setup In Target Image : Ign:53 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/main arm64 Packages
23:03:10 INFO : Bzip2 Patch Setup In Target Image : Ign:56 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/multiverse arm64 Packages
23:03:11 INFO : Bzip2 Patch Setup In Target Image : Ign:61 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe arm64 Packages
23:03:12 INFO : Bzip2 Patch Setup In Target Image : Ign:68 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main arm64 Packages
23:03:17 INFO : Bzip2 Patch Setup In Target Image : Ign:26 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main arm64 Packages
23:03:19 INFO : Bzip2 Patch Setup In Target Image : Ign:38 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse arm64 Packages
23:03:20 INFO : Bzip2 Patch Setup In Target Image : Ign:45 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe arm64 Packages
23:03:21 INFO : Bzip2 Patch Setup In Target Image : Ign:51 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/universe arm64 Packages
23:03:21 INFO : Bzip2 Patch Setup In Target Image : Ign:53 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/main arm64 Packages
23:03:22 INFO : Bzip2 Patch Setup In Target Image : Ign:56 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/multiverse arm64 Packages
23:03:23 INFO : Bzip2 Patch Setup In Target Image : Ign:61 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe arm64 Packages
23:03:23 INFO : Bzip2 Patch Setup In Target Image : Ign:68 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main arm64 Packages
23:03:24 INFO : Bzip2 Patch Setup In Target Image : Err:26 mirror://mirrors.ubuntu.com/mirrors.txt xenial/main arm64 Packages
23:03:24 INFO : Bzip2 Patch Setup In Target Image : 404 Not Found [Mirror: Index of /ubuntu]
23:03:25 INFO : Bzip2 Patch Setup In Target Image : Ign:38 mirror://mirrors.ubuntu.com/mirrors.txt xenial/multiverse arm64 Packages
23:03:26 INFO : Bzip2 Patch Setup In Target Image : Ign:45 mirror://mirrors.ubuntu.com/mirrors.txt xenial/universe arm64 Packages
23:03:27 INFO : Bzip2 Patch Setup In Target Image : Err:51 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/universe arm64 Packages
23:03:27 INFO : Bzip2 Patch Setup In Target Image : 404 Not Found [Mirror: Index of /ubuntu]
23:03:27 INFO : Bzip2 Patch Setup In Target Image : Ign:53 mirror://mirrors.ubuntu.com/mirrors.txt xenial-proposed/main arm64 Packages
23:03:28 INFO : Bzip2 Patch Setup In Target Image : Err:56 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/multiverse arm64 Packages
23:03:28 INFO : Bzip2 Patch Setup In Target Image : 404 Not Found [Mirror: Index of /ubuntu]
23:03:29 INFO : Bzip2 Patch Setup In Target Image : Ign:61 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/universe arm64 Packages
23:03:34 INFO : Bzip2 Patch Setup In Target Image : Ign:68 mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates/main arm64 Packages
23:03:37 INFO : Bzip2 Patch Setup In Target Image : Fetched 734 kB in 2min 48s (4,364 B/s)
23:03:37 INFO : Bzip2 Patch Setup In Target Image : Reading package lists…
23:03:37 ERROR : Bzip2 Patch Setup In Target Image : E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/multiverse/binary-arm64/Packages 404 Not Found [IP: 91.189.88.162 80]
23:03:37 ERROR : Bzip2 Patch Setup In Target Image : E: Failed to fetch mirror://mirrors.ubuntu.com/mirrors.txt/dists/xenial/main/binary-arm64/Packages 404 Not Found [Mirror: Index of /ubuntu]
23:03:37 INFO : Bzip2 Patch Setup In Target Image : E: Failed to fetch mirror://mirrors.ubuntu.com/mirrors.txt/dists/xenial-proposed/universe/binary-arm64/Packages 404 Not Found [Mirror: Index of /ubuntu]
23:03:37 INFO : Bzip2 Patch Setup In Target Image : E: Failed to fetch mirror://mirrors.ubuntu.com/mirrors.txt/dists/xenial-updates/multiverse/binary-arm64/Packages 404 Not Found [Mirror: Index of /ubuntu]
23:03:37 INFO : Bzip2 Patch Setup In Target Image : E: Some index files failed to download. They have been ignored, or old ones used instead.
23:03:37 INFO : Bzip2 Patch Setup In Target Image : *begin sudo apt-get install -y --allow-downgrades bzip2=1.0.6-8 libbz2-1.0=1.0.6-8 , 5
23:03:37 INFO : Bzip2 Patch Setup In Target Image : Building dependency tree…
23:03:37 INFO : Bzip2 Patch Setup In Target Image : Reading state information…
23:03:37 INFO : Bzip2 Patch Setup In Target Image : E: Version ‘1.0.6-8’ for ‘bzip2’ was not found
23:03:37 INFO : Bzip2 Patch Setup In Target Image : E: Version ‘1.0.6-8’ for ‘libbz2-1.0’ was not found
23:03:37 INFO : Bzip2 Patch Setup In Target Image : Unhandled error when running sudo apt-get install -y --allow-downgrades bzip2=1.0.6-8 libbz2-1.0=1.0.6-8
23:03:37 INFO : Bzip2 Patch Setup In Target Image : exit status 1
23:03:37 INFO : Bzip2 Patch Setup In Target Image : [ Component Install Finished with Error ]
23:03:37 ERROR : Bzip2 Patch Setup In Target Image : UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE command /tmp/tmp_UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE.sh finished with error
23:03:37 INFO : Bzip2 Patch Setup In Target Image : [ 332.00 KB used. Disk Avail: 738.59 GB ]
23:03:37 INFO : Bzip2 Patch Setup In Target Image : [ UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE Install took 2m51s ]
23:03:37 INFO : Bzip2 Patch Setup In Target Image : command /tmp/tmp_UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE.sh finished with error
23:03:37 ERROR : Bzip2 Patch Setup In Target Image : command terminated with error
23:03:37 ERROR : install ‘Bzip2 Patch Setup In Target Image’ failure, command < cd ‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE’ -v=‘1.0’ -l=‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ -L=‘/home/gianig/.nvsdkm/logs/JetPack_4.2.1_Linux_GA’ -p=‘8931’ -t=‘P3310’ -e=‘/home/gianig/nvidia/sdkm_downloads’ > terminated with error
23:03:37 ERROR : Unavailable components detected, please check log
23:03:37 ERROR : Drivers for Jetson TX2 & TX2i Skipped. Due to its dependencies fail to install: Bzip2 Patch Setup In Target Image,
23:03:37 ERROR : File System and OS Skipped. Due to its dependencies fail to install: Bzip2 Patch Setup In Target Image,
23:03:38 ERROR : Flash skipped due to component(s) download/install failure
23:05:34 INFO : *** Retrying to install. attempt number: 2
23:05:34 DEBUG : running command < sudo rm -rf ‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ >
23:05:34 INFO : command finished successfully
23:05:34 INFO : Bzip2 Patch Setup In Target Image : download ‘Bzip2 Patch Setup In Target Image’ success
23:05:34 INFO : Start to install ‘Bzip2 Patch Setup In Target Image’
23:05:34 DEBUG : Bzip2 Patch Setup In Target Image : running command < cd ‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE’ -v=‘1.0’ -l=‘/home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310’ -L=‘/home/gianig/.nvsdkm/logs/JetPack_4.2.1_Linux_GA’ -p=‘8931’ -t=‘P3310’ -e=‘/home/gianig/nvidia/sdkm_downloads’ >
23:05:34 INFO : Bzip2 Patch Setup In Target Image : [ Disk Avail:738.59 GB ]
23:05:34 INFO : Bzip2 Patch Setup In Target Image : Using GenericInstaller to Install UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE
23:05:34 INFO : Bzip2 Patch Setup In Target Image : change working directory to /home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310
23:05:34 INFO : Bzip2 Patch Setup In Target Image : [ Component Install Started ]
23:05:34 INFO : Bzip2 Patch Setup In Target Image : current working directory is /home/gianig/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310
23:05:34 INFO : Bzip2 Patch Setup In Target Image : exec_command [host]:
23:05:34 INFO : Bzip2 Patch Setup In Target Image : **********************
23:05:34 INFO : Bzip2 Patch Setup In Target Image : #!/bin/bash
23:05:34 INFO : Bzip2 Patch Setup In Target Image : set -e
23:05:34 INFO : Bzip2 Patch Setup In Target Image : function safe_apt_install {
23:05:34 INFO : Bzip2 Patch Setup In Target Image : echo “*begin $1, $2”
23:05:34 INFO : Bzip2 Patch Setup In Target Image : tmp_log=/tmp/jetpack_dpkg_log.txt
23:05:34 INFO : Bzip2 Patch Setup In Target Image : sudo rm -f $tmp_log
23:05:34 INFO : Bzip2 Patch Setup In Target Image : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
23:05:34 INFO : Bzip2 Patch Setup In Target Image : while [ ${CMD_STATUS} -ne 0 ]; do
23:05:34 INFO : Bzip2 Patch Setup In Target Image : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
23:05:34 INFO : Bzip2 Patch Setup In Target Image : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
23:05:34 INFO : Bzip2 Patch Setup In Target Image : else
23:05:34 INFO : Bzip2 Patch Setup In Target Image : echo “Unhandled error when running $1”; exit 1
23:05:34 INFO : Bzip2 Patch Setup In Target Image : fi
23:05:34 INFO : Bzip2 Patch Setup In Target Image : done
23:05:34 INFO : Bzip2 Patch Setup In Target Image : }
23:05:34 INFO : Bzip2 Patch Setup In Target Image : bzip2Version=dpkg -l bzip2 | tail -n 1 | awk '{ printf $3 }'
23:05:34 INFO : Bzip2 Patch Setup In Target Image : libbzip2Version=dpkg -l libbz2-1.0 | tail -n 1 | awk '{ printf $3 }'
23:05:35 INFO : Bzip2 Patch Setup In Target Image : if [[ “$bzip2Version” != ‘1.0.6-8’ || “$libbzip2Version” != ‘1.0.6-8’ ]]; then
23:05:35 INFO : Bzip2 Patch Setup In Target Image : sudo apt-get update
23:05:35 INFO : Bzip2 Patch Setup In Target Image : safe_apt_install "sudo apt-get install -y --allow-downgrades bzip2=1.0.6-8 libbz2-1.0=1.0.6-8 " 5
23:05:35 INFO : Bzip2 Patch Setup In Target Image : fi
23:05:35 INFO : Bzip2 Patch Setup In Target Image : exit 0
23:05:35 INFO : Bzip2 Patch Setup In Target Image : **********************
23:05:35 INFO : Bzip2 Patch Setup In Target Image : exec_command: /tmp/tmp_UBUNTU_BZIP2_PATCH_IN_TARGET_IMAGE.sh
23:05:35 INFO : Drivers for Jetson TX2 & TX2i : Found file /home/gianig/nvidia/sdkm_downloads/Jetson_Linux_R32.2.0_aarch64.tbz2 with correct checksum, skip downloading.
23:05:35 INFO : Drivers for Jetson TX2 & TX2i : download ‘Drivers for Jetson TX2 & TX2i’ success
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:1 Index of /ubuntu xenial-security InRelease [109 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Hit:2 Index of linux/ubuntu/ xenial InRelease
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Ign:3 http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1604/x86_64 InRelease
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Hit:4 http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1604/x86_64 Release
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:6 Index of /ubuntu xenial-security/multiverse i386 Packages [5,764 B]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Ign:7 Index of /ubuntu xenial-security/multiverse arm64 Packages
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:8 Index of /ubuntu xenial-security/multiverse amd64 DEP-11 Metadata [2,464 B]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:9 Index of /ubuntu xenial-security/universe amd64 Packages [451 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:10 Index of /ubuntu xenial-security/universe i386 Packages [391 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Ign:11 Index of /ubuntu xenial-security/universe arm64 Packages
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:12 Index of /ubuntu xenial-security/universe Translation-en [184 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:13 Index of /ubuntu xenial-security/universe amd64 DEP-11 Metadata [124 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:14 Index of /ubuntu xenial-security/universe DEP-11 64x64 Icons [194 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:15 Index of /ubuntu xenial-security/restricted i386 Packages [7,224 B]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:16 Index of /ubuntu xenial-security/main i386 Packages [576 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Ign:17 Index of /ubuntu xenial-security/main arm64 Packages
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:18 Index of /ubuntu xenial-security/main amd64 DEP-11 Metadata [73.8 kB]
23:05:35 INFO : Bzip2 Patch Setup In Target Image : Get:19 Index of /ubuntu xenial-security/main DEP-11 64x64 Icons [73.2 kB]
23:05:36 INFO : Bzip2 Patch Setup In Target Image : Err:7 Index of /ubuntu xenial-security/multiverse arm64 Packages
23:05:36 INFO : Bzip2 Patch Setup In Target Image : 404 Not Found [IP: 91.189.88.149 80]
23:05:36 INFO : Bzip2 Patch Setup In Target Image : Ign:11 Index of /ubuntu xenial-security/universe arm64 Packages
23:05:36 INFO : Bzip2 Patch Setup In Target Image : Ign:17 Index of /ubuntu xenial-security/main arm64 Packages
23:05:36 INFO : File System and OS : Found file /home/gianig/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.0_aarch64.tbz2 with correct checksum, skip downloading.
23:05:36 INFO : File System and OS : download ‘File System and OS’ success
Just a thought on this:
21:34:25 ERROR : Drivers for Jetson TX2 & TX2i : E: Failed to fetch mirror://mirrors.ubuntu.com/mirrors.txt/dists/xenial/main/binary-arm64/Packages 404 Not Found [Mirror: http://archive.ubuntu.com/ubuntu/]
The URL this shows is:
…not sure if that is some sort of scripted code (I could be interpreting this wrong) which gets expanded from the mirrors.txt, but by itself it isn’t valid since “mirrors.txt/dists/…” is improperly formed and mirrors.txt would be a file without anything such as “/dists/…” following it.
On the other hand, this is valid:
If you then try to follow that path by appending to the working part, this subset is also valid:
http://archive.ubuntu.com/ubuntu/dists/xenial/main/
Once you try to continue into the arm64 binaries there will be a failure. Looks like those servers no longer serve arm64. I don’t know enough about how the URLs are generated to know why it is using that URL…either this URL used to work, but the servers changed, or something just looking for arm64 on a server which never had this architecture. Bad URL:
http://archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64
