Can you please let us know the SDK Manager client version? It is expected to be 0.9.12 to install JetPack. The SDK Manager 0.9.12 is available at https://developer.nvidia.com/embedded/dlc/nv-sdk-manager
If you still have problem, can you please attach the full sdkm.log file? Thanks.
I tried to use The SDK Manager 0.9.12.
But, sdk-manager crashed on Ubuntu 18.04.
2019-05-31 01:19:13.951 - info: forking worker process
2019-05-31 01:19:13.959 - info: initializing the download service
2019-05-31 01:19:13.970 - info: forking a child process for the download service pid 65
2019-05-31 01:19:14.007 - info: Initializing download manager with 6
2019-05-31 01:19:14.394 - info: number of download processes set to 6
2019-05-31 01:19:14.455 - info: Begin to create timing task for auto update.
2019-05-31 01:19:14.499 - info: Host OS: Ubuntu1804
2019-05-31 01:19:14.499 - info: packageJson: /opt/nvidia/sdkmanager/resources/app/package.json
2019-05-31 01:19:14.508 - info: download service message loading the download service
initialized download service
got heartbeat request
2019-05-31 01:19:14.508 - info: download process is alive
2019-05-31 01:19:14.509 - error: cannot find a opts object for url undefined
2019-05-31 01:19:14.509 - info: download service is alive
2019-05-31 01:19:14.524 - info: config:
{ mainRepoURL: 'https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json',
PIDServer: 'P',
DevZoneServer: 'P' }
2019-05-31 01:19:14.528 - info: initDevzoneTab...
2019-05-31 01:19:14.531 - info: requesting WebContents...
2019-05-31 01:19:14.542 - info: manifest: {"name":"sdkmanager","version":"0.9.12","revision":"0","buildNumber":"4180","release":false}
2019-05-31 01:19:14.542 - info: Setting GA parameters: title SDK Manager 0.9.12.4180 version 0.9.12 dev: 0 internal: false
2019-05-31 01:19:14.542 - info: autoLogin failed: Aborting auto login since there is no logged in user
2019-05-31 01:19:14.543 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:14.546 - info: mainRepoUrl: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2019-05-31 01:19:14.547 - info: logging in with l1 url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2019-05-31 01:19:14.579 - warn: crontab read failure with Error: Command failed: crontab -l
no crontab for jetpack
2019-05-31 01:19:14.589 - warn: crontab read failure with Error: Command failed: crontab -l
2019-05-31 01:19:14.636 - info: Create timing task for auto update successfully.
2019-05-31 01:19:32.964 - info: Logging in with sso login method…
2019-05-31 01:19:32.979 - info: posting login request. url: https://devzone.auth0.com/oauth/token
2019-05-31 01:19:32.996 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:34.956 - info: get user programs. url: https://developer.nvidia.com/api/assets/v1/current_user_sdk/programs
2019-05-31 01:19:34.959 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:36.210 - info: the DevZone programs that user can access:
2019-05-31 01:19:36.210 - info: { id: xxxxxx, name: GameWorks Registered Developer Program }
2019-05-31 01:19:36.210 - info: { id: yyyyyy, name: NVIDIA Developer Program }
2019-05-31 01:19:36.210 - info: { id: zzzzzz, name: Isaac SDK }
2019-05-31 01:19:36.223 - info: Retrieving Data…
2019-05-31 01:19:36.223 - info: Processing Data…
2019-05-31 01:19:40.097 - info: Usage and platform data collection via Google Analytics sets to false
2019-05-31 01:19:40.099 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:40.101 - info: Loading data from server: l1url. Url: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2019-05-31 01:19:40.122 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:40.209 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/jetpack/.nvsdkm/dist successfully.
2019-05-31 01:19:40.261 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:40.278 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:40.295 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:40.316 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:40.362 - info: sdkml2_drive_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/Linux/sdkml2_drive_linux.json has been downloaded to /home/jetpack/.nvsdkm/dist successfully.
2019-05-31 01:19:40.398 - info: validating product line for target OS: Linux
2019-05-31 01:19:40.398 - info: validating release: DRIVE Software 9.0
2019-05-31 01:19:40.398 - info: validating release: DRIVE Software 8.0
2019-05-31 01:19:40.398 - info: validating release: DRIVE OS 5.1.6.0 PDK
2019-05-31 01:19:40.399 - info: validating release: DRIVE OS 5.1.6.0 SDK
2019-05-31 01:19:40.399 - info: validating release: DRIVE OS 5.1.3.0 PDK
2019-05-31 01:19:40.399 - info: validating release: DRIVE OS 5.1.3.0 SDK
2019-05-31 01:19:40.399 - info: validating release: DRIVE OS 5.1.0.0 PDK
2019-05-31 01:19:40.399 - info: validating release: DRIVE OS 5.1.0.0 SDK
2019-05-31 01:19:40.399 - info: validating release: DRIVE OS 5.0.10.3 SDK with DriveWorks
2019-05-31 01:19:40.399 - info: validating release: DRIVE OS 5.0.10.3 PDK
2019-05-31 01:19:40.399 - warn: No access to devzone program id 879192
2019-05-31 01:19:40.399 - warn: No access to devzone program id -1
2019-05-31 01:19:40.400 - warn: No access to devzone program id -1
2019-05-31 01:19:40.400 - warn: No access to devzone program id 876061
2019-05-31 01:19:40.400 - warn: No access to release DRIVE Software 9.0. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE Software 8.0. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.1.6.0 PDK. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.1.6.0 SDK. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.1.3.0 PDK. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.1.3.0 SDK. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.1.0.0 PDK. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.1.0.0 SDK. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.0.10.3 SDK with DriveWorks. Message undefined
2019-05-31 01:19:40.400 - warn: No access to release DRIVE OS 5.0.10.3 PDK. Message undefined
2019-05-31 01:19:40.402 - info: sdkml2_drive_qnx.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/DRIVE/QNX/sdkml2_drive_qnx.json has been downloaded to /home/jetpack/.nvsdkm/dist successfully.
2019-05-31 01:19:40.434 - info: validating product line for target OS: QNX
2019-05-31 01:19:40.434 - info: validating release: DRIVE OS 5.1.6.0 PDK
2019-05-31 01:19:40.434 - info: validating release: DRIVE OS 5.1.6.0 SDK
2019-05-31 01:19:40.434 - info: validating release: DRIVE OS 5.1.3.0 PDK
2019-05-31 01:19:40.434 - info: validating release: DRIVE OS 5.1.3.0 SDK
2019-05-31 01:19:40.434 - info: validating release: DRIVE OS 5.0.13.2 (with DRIVE AV)
2019-05-31 01:19:40.435 - warn: No access to devzone program id -1
2019-05-31 01:19:40.435 - warn: No access to release DRIVE OS 5.1.6.0 PDK. Message undefined
2019-05-31 01:19:40.435 - warn: No access to release DRIVE OS 5.1.6.0 SDK. Message undefined
2019-05-31 01:19:40.435 - warn: No access to release DRIVE OS 5.1.3.0 PDK. Message undefined
2019-05-31 01:19:40.435 - warn: No access to release DRIVE OS 5.1.3.0 SDK. Message undefined
2019-05-31 01:19:40.435 - warn: No access to release DRIVE OS 5.0.13.2 (with DRIVE AV). Message undefined
2019-05-31 01:19:40.439 - info: sdkml2_jetson_linux.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/Jetson/Linux/sdkml2_jetson_linux.json has been downloaded to /home/jetpack/.nvsdkm/dist successfully.
2019-05-31 01:19:40.440 - info: sdkml2_sdkmanager_linux_deb.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/SDKMANAGER/Linux/sdkml2_sdkmanager_linux_deb.json has been downloaded to /home/jetpack/.nvsdkm/dist successfully.
2019-05-31 01:19:40.461 - info: validating product line for target OS: Linux
2019-05-31 01:19:40.462 - info: validating release: JetPack 4.2.1 EA
2019-05-31 01:19:40.462 - warn: No access to devzone program id 879404
2019-05-31 01:19:40.462 - info: Can access to devzone program id 874688
2019-05-31 01:19:40.468 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:40.474 - warn: No access to release JetPack 4.2.1 EA. Message undefined
2019-05-31 01:19:40.490 - info: validating product line for target OS:
2019-05-31 01:19:40.490 - info: validating release: SDK Manager
2019-05-31 01:19:40.490 - warn: Empty devzone program id, user can access this program
2019-05-31 01:19:41.700 - info: step1 load in ms: 1599.2249999999985
2019-05-31 01:19:41.700 - info: Web server configuration build version 570D165J is set
2019-05-31 01:19:41.716 - info: Checking for update with mainRepoURL: https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json
2019-05-31 01:19:41.743 - info: [Proxy Agent] No proxy agent
2019-05-31 01:19:41.783 - info: sdkml1_repo.json from https://developer.download.nvidia.com/sdkmanager/sdkm-config/main/sdkml1_repo.json has been downloaded to /home/jetpack/.nvsdkm/dist successfully.
2019-05-31 01:19:41.790 - info: [Proxy Agent] No proxy agent
I can’t explain it, but it still looks as if a number of network failures occurred. It could have been as simple as DNS failure. However, I do have a suggestion as follows…
Run this again, but set it just for flash or just package addition to the Jetson (you get to pick). After it fails there will be a file “~/Downloads/nvidia/sdkm_downloads/sdkml3_jetpack_l4t_42.json” (or something close to that name with a “.json” suffix). Save a copy with the file name suffix “.txt”, and attach it here in the forums (on one of your existing posts you can hover your mouse over the quote icon in the upper right and some other icons will show up…the paper clip icon allows file attachment).
You will also find in this file a reference of “compDirectory” with a URL. If you paste this into a browser and go there, then regardless of whether the page exists or not, do you get to the web page where you can log in? I am more curious about whether you can reach the server than whether it allows any particular page access.
I check this point.
sdkml3_jetpack_l4t_42.json has not been downloaded
~/Downloads/nvidia/sdkm_downloads directory has not been created
And, I checked ~/.nvsdkm/dist
$ cd ~/.nvsdkm/dist
$ ls
sdkml1_repo.json sdkml2_drive_linux.json sdkml2_drive_qnx.json sdkml2_jetson_linux.json sdkml2_sdkmanager_linux_deb.json
Because you are already logged in at the base URL entering that full address in your browser should result in the download of that ".deb" file.
Are you able to verify from that host that this step works? If so, then I’d say at least part of networking is valid, and if not, then this is why it is failing. This is essentially what the package download step is doing. Your json would possibly have a different base URL depending on region of the world or if there are version updates. The cuda-repo is just one example of the files needing download. Various P3310 packages might also be needed, and here is an example constructed similar to the previous one, but it appends “P3310/Jetson_Linux_R32.1.0_aarch64.tbz2” instead of the “.deb” and should result in a download if you are already logged in (remember the base address might be different for you): https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P3310/Jetson_Linux_R32.1.0_aarch64.tbz2
I’m not sure what is going on. There are different “.json” files for different manifests, but a manifest is mandatory before SDKM will know what to download. So long as SDKM knows what to download it should work. So long as proxy and firewall are disabled and the above manual download tests succeeded, then there shouldn’t be a network error. Having a crash from CLI tends to imply there is some other problem, but I’m not sure CLI actually works as expected.
My only suggestion at this point, if you need to keep installing, is to completely delete any of the SDK Manager content (including “~/Downloads/nvidia/sdkm_downloads/” if it exists and “~/nvidia/”, and downloading the SDKM itself fresh and installing it again) and flash again, and then try just flash. Before the flash make sure the following host side dependencies are met:
Only after regular flash succeeds, then try to run component install to only the Jetson, starting with an attempt to install CUDA. Then a separate attempt to install everything else to the Jetson, except for samples. Then do the same for the host side if you are interested in that, and don’t install samples until everything else is installed. On the first error or issue add a note here in forums.
From error log
[605:0603/140314.924539:ERROR:bus.cc(395)] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
Looks dbus is not set up correct on your side. What is the output of “# ls -la /var/run/dbus/”?
OS of Host PC is Ubuntu 18.04.2 LTS
SDK manager version is 0.9.12-4180
Target Device is Jetson TX2
I tried to get a working configuration of Dockerfile by manually installing packages to cudagl:10.1-runtime-ubuntu18.04 image from NGC. To run container I used
$ nvidia-docker run -it --rm -e DISPLAY=unix$DISPLAY --privileged -v /dev/bus/usb:/dev/bus/usb -v /tmp/.X11-unix:/tmp/.X11-unix -v ~/sdkmanager-host/:/root/sdkmanager-container nvcr.io/nvidia/cudagl:10.1-runtime-ubuntu18.04.
After installing this packages as root
libgconf-2-4 locales libgtk-3-common libcanberra-gtk3-module libxss1 libnss3
and fixing all dependencies I installed the sdkmanager.
The main window of the sdkmanager running properly, but when I try to login to my profile I have a message
“NVIDIA SDK Manager Crashed Unexpected, relaunch or exit”
After closing message window on terminal I have this
(sdkmanager:47): dbind-WARNING **: 20:08:45.756: Couldn’t connect to accessibility bus: Failed to connect to socket /tmp/dbus-Ep8vsbkyVC: Connection refused
Gtk-Message: 20:19:33.718: GtkDialog mapped without a transient parent. This is discouraged.
