Failed to use Wifi module on NX
Intel Dual Band Wireless-AC 8265 module did not work on NX by default, as we test it. ( the module works well on Nano.)
Does NX (Jetpack 4.4) support Intel Dual Band Wireless-AC 8265?
If yes, what should we do to make it work?
If not, is there any patch or document to make it work?
Thank you,
Hi HuiW,
We should go back to the basic one first. Do you see the device in lspci?
Hi WayneWWW,
Yes. I see the 0005:01:00.0 Intel 8265.
Thank you,
Then could you share the full dmesg? Thanks.
Hi WayneWWW,
Attached please find the file.
nvidia@nvidia-desktop:~$ lspci
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1)
0005:01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
nx_nowifi.log (64.8 KB)
Thank you,
Hi HuiW,
Could you share the result of “ifconfig” and “rfkill list”?
Hi WayneWWW,
message:
nvidia@nvidia-desktop:~$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.16.8.169 netmask 255.255.255.0 broadcast 172.16.8.255
inet6 fe80::92de:5ba4:886b:1923 prefixlen 64 scopeid 0x20
ether 48:b0:2d:05:a0:3a txqueuelen 1000 (Ethernet)
RX packets 16110 bytes 16009238 (16.0 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 7840 bytes 1049951 (1.0 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 35
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 4123 bytes 260837 (260.8 KB)
TX packets 4123 bytes 260837 (260.8 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:83:74:57:59:2d txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:83:74:57:59:2f txqueuelen 1000 (Ethernet)
nvidia@nvidia-desktop:~$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
Thanks for sharing.
phy0: Wireless LAN Soft blocked: no Hard blocked: yes
Looks like something goes wrong here. We will help check.
WayneWWW,
Thank you so much for your great support.
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: yes
simlar issue;
the card previously worked for Xavier and nano
current situation at NX with nano B001 board
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: yes
0005:01:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
Installed with
git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git && cd backport-iwlwifi
make defconfig-iwlwifi-public
sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config
make -j4
sudo make install
dmesg|grep iwlwifi
[    5.474137] Loading modules backported from iwlwifi
[    5.474142] iwlwifi-stack-public:master:8324:9176b151
[    6.460446] iwlwifi 0005:01:00.0: enabling device (0000 -> 0002)
[    6.471340] iwlwifi 0005:01:00.0: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
[    6.471536] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.908383] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-cc-a0-55.ucode failed with error -2
[   66.909744] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.919171] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-cc-a0-54.ucode failed with error -2
[   66.919361] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.920271] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-cc-a0-53.ucode failed with error -2
[   66.920456] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.921475] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-cc-a0-52.ucode failed with error -2
[   66.921659] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.924350] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-cc-a0-51.ucode failed with error -2
[   66.924533] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.926520] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[   66.926699] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.930752] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[   66.930978] iwlwifi 0005:01:00.0: Falling back to user helper
[   66.956381] iwlwifi 0005:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[   66.956394] iwlwifi 0005:01:00.0: Found debug destination: EXTERNAL_DRAM
[   66.956398] iwlwifi 0005:01:00.0: Found debug configuration: 0
[   66.957014] iwlwifi 0005:01:00.0: loaded firmware version 48.4fa0041f.0 cc-a0-48.ucode op_mode iwlmvm
[   66.957089] iwlwifi 0005:01:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[   66.957262] iwlwifi 0005:01:00.0: Falling back to user helper
[   67.219341] iwlwifi 0005:01:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   67.234296] iwlwifi 0005:01:00.0: Applying debug destination EXTERNAL_DRAM
[   67.234686] iwlwifi 0005:01:00.0: Allocated 0x00400000 bytes for firmware monitor.
[   67.332345] iwlwifi 0005:01:00.0: reporting RF_KILL (radio disabled)
[   67.393427] iwlwifi 0005:01:00.0: base HW address: dc:fb:48:02:b1:e7
[   67.419393] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi_1
```    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3193) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Apr 8 18:15:20 PDT 2020
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  180000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] On node 0 totalpages: 2032640
[    0.000000]   DMA zone: 7184 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 459776 pages, LIFO batch:31
[    0.000000]   Normal zone: 24576 pages used for memmap
[    0.000000]   Normal zone: 1572864 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd04000 s61656 r8192 d32552 u102400
[    0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2000880
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1    quiet
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29104(88%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7190452K/8130560K available (15294K kernel code, 2934K rwdata, 6636K rodata, 8576K init, 609K bss, 186444K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff80095f0000   (  6656 KB)
[    0.000000]       .init : 0xffffff80095f0000 - 0xffffff8009e50000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e50000 - 0xffffff800a12d808   (  2935 KB)
[    0.000000]        .bss : 0xffffff800a12d808 - 0xffffff800a1c5f3c   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf08000000   (   128 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc200000000   (  8192 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000593] Console: colour dummy device 80x25
[    0.000606] console [tty0] enabled
[    0.000613] bootconsole [tegra_comb_uart0] disabled
[    0.000627] kmemleak: Kernel memory leak detector disabled
[    0.000644] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000659] pid_max: default: 32768 minimum: 301
[    0.001759] Security Framework initialized
[    0.002326] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.002336] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.003962] ftrace: allocating 47094 entries in 184 pages
[    0.398997] sched-energy: Sched-energy-costs installed from DT
[    0.399017] ASID allocator initialised with 65536 entries
[    0.434058] tegra-id: chipid=21917.
[    0.434070] tegra-id: opt_subrevision=1.
[    0.434096] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.434111] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.434121] DTB Build time: Apr  8 2020 18:20:54
[    0.482117] CPU1: Booted secondary processor [4e0f0040]
[    0.514167] CPU2: Booted secondary processor [4e0f0040]
[    0.546262] CPU3: Booted secondary processor [4e0f0040]
[    0.578553] CPU4: Booted secondary processor [4e0f0040]
[    0.610633] CPU5: Booted secondary processor [4e0f0040]
[    0.610835] Brought up 6 CPUs
[    0.610845] SMP: Total of 6 processors activated.
[    0.610856] CPU features: detected feature: Privileged Access Never
[    0.610865] CPU features: detected feature: LSE atomic instructions
[    0.610871] CPU features: detected feature: User Access Override
[    0.610877] CPU features: detected feature: 32-bit EL0 Support
[    0.612406] CPU: All CPU(s) started at EL2
[    0.612472] alternatives: patching kernel code
[    0.619579] devtmpfs: initialized
[    0.656392] Initilizing CustomIPI irq domain
[    0.656699] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.656719] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.678644] pinctrl core: initialized pinctrl subsystem
[    0.678862] OS set in device tree is not L4T.
[    0.679185] regulator-dummy: no parameters
[    0.679470] Initializing plugin-manager
[    0.679522] Plugin module not found
[    0.679578] Plugin-manager status disabled
[    0.681521] NET: Registered protocol family 16
[    0.682758] pstore: using zlib compression
[    0.682780] console [pstore-1] enabled
[    0.682788] pstore: Registered ramoops as persistent store backend
[    0.682797] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[    0.701353] cpuidle: using governor menu
[    0.702705] bpmp: waiting for handshake
[    0.702717] bpmp: handshake completed
[    0.702747] bpmp: synchronizing channels
[    0.702758] bpmp: channels synchronized
[    0.702764] bpmp: mail init ok
[    0.705816] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.705993] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.705999] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.706006] t19x-arm-smmu 12000000.iommu: 	stage 1 translation
[    0.706012] t19x-arm-smmu 12000000.iommu: 	stage 2 translation
[    0.706018] t19x-arm-smmu 12000000.iommu: 	nested translation
[    0.706026] t19x-arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.706035] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.706041] t19x-arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.706049] t19x-arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.706055] t19x-arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.709448] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e54000)
[    0.709482] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.711836] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.713210] Registering BPMP clocks...
[    0.713315] tegra_bpmp_clk_init: clock init ok (400 clks)
[    0.713970] Serial: AMBA PL011 UART driver
[    0.714127] tegra_powergate_init: DONE
[    0.714193] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.714204] DTB Build time: Apr  8 2020 18:20:54
[    0.717336] Tegra reboot handler registered.
[    0.725520] iommu: Adding device 141a0000.pcie to group 0
[    0.726878] iommu: Adding device 2490000.ether_qos to group 1
[    0.727432] iommu: Adding device 3100000.serial to group 2
[    0.727907] iommu: Adding device 3110000.serial to group 3
[    0.728348] iommu: Adding device 3140000.serial to group 4
[    0.728923] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.729141] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.729165] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.729188] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[    0.729196] tegra-pmc: ### PMC reset status reg: 0x0
[    0.729250] tegra-pmc: PMC Prod config success
[    0.729500] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.729515] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.729901] iommu: Adding device 3460000.sdhci to group 5
[    0.730461] iommu: Adding device 3210000.spi to group 6
[    0.730843] iommu: Adding device 3230000.spi to group 7
[    0.731225] iommu: Adding device 3270000.spi to group 8
[    0.732407] iommu: Adding device 3160000.i2c to group 9
[    0.732774] iommu: Adding device c240000.i2c to group 10
[    0.733198] iommu: Adding device 3180000.i2c to group 11
[    0.733605] iommu: Adding device 3190000.i2c to group 12
[    0.734128] iommu: Adding device 31b0000.i2c to group 13
[    0.734571] iommu: Adding device 31c0000.i2c to group 14
[    0.734970] iommu: Adding device c250000.i2c to group 15
[    0.735348] iommu: Adding device 31e0000.i2c to group 16
[    0.735886] iommu: Adding device sound to group 17
[    0.736377] iommu: Adding device 3510000.hda to group 18
[    0.736959] iommu: Adding device bc00000.rtcpu to group 19
[    0.738790] iommu: Adding device 13e10000.host1x to group 20
[    0.739164] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[    0.739559] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[    0.740020] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[    0.740425] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[    0.740839] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[    0.741212] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[    0.741556] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[    0.741983] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[    0.742484] iommu: Adding device 15340000.vic to group 29
[    0.742884] iommu: Adding device 15380000.nvjpg to group 30
[    0.743268] iommu: Adding device 15500000.tsec to group 31
[    0.743542] iommu: Adding device 15100000.tsecb to group 32
[    0.743941] iommu: Adding device 15480000.nvdec to group 33
[    0.744265] iommu: Adding device 15140000.nvdec1 to group 34
[    0.744556] iommu: Adding device 154c0000.nvenc to group 35
[    0.744830] iommu: Adding device 15a80000.nvenc1 to group 36
[    0.745235] iommu: Adding device 15880000.nvdla0 to group 37
[    0.745653] iommu: Adding device 158c0000.nvdla1 to group 38
[    0.746218] iommu: Adding device 15200000.nvdisplay to group 39
[    0.750334] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    0.750395] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[    0.751030] iommu: Adding device 15210000.nvdisplay to group 40
[    0.751097] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    0.752810] iommu: Adding device 15c10000.vi to group 41
[    0.752964] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    0.753355] iommu: Adding device 14800000.isp to group 42
[    0.754321] iommu: Adding device 16000000.pva0 to group 43
[    0.754845] iommu: Adding device 16800000.pva1 to group 44
[    0.755276] iommu: Adding device 15810000.se to group 45
[    0.755623] iommu: Adding device 15820000.se to group 46
[    0.755934] iommu: Adding device 15830000.se to group 47
[    0.756224] iommu: Adding device 15840000.se to group 48
[    0.756480] iommu: Adding device c1a0000.aon to group 49
[    0.757927] iommu: Adding device d000000.bpmp to group 50
[    0.758280] bpmp: ping status is 0
[    0.758417] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[    0.761615] bpmp d000000.bpmp: probe ok
[    0.763686] tegra-reset 0.bpmp_reset: registered 190 resets.
[    0.764107] iommu: Adding device smmu_test to group 51
[    0.765138] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[    0.765155] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[    0.765171] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[    0.765186] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[    0.765201] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[    0.765218] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[    0.765233] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[    0.765250] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[    0.765265] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[    0.765279] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[    0.765293] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[    0.765332] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[    0.765356] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[    0.765370] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[    0.765385] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[    0.765399] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[    0.765413] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[    0.765482] mc-err: mcerr ops are set to t19x
[    0.771553] iommu: Adding device 2600000.dma to group 52
[    0.777777] GPIO line 339 (wifi-enable) hogged as output/high
[    0.777813] GPIO line 412 (camera-control-output-low) hogged as output/low
[    0.777845] GPIO line 413 (camera-control-output-low) hogged as output/low
[    0.778171] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    0.786333] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    0.786711] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    0.789132] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.789143] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.789847] iommu: Adding device 3550000.xudc to group 53
[    0.790573] iommu: Adding device 3610000.xhci to group 54
[    0.792648] arm64_ras arm64_ras: probed
[    0.793082] ras_fhi_enable: FHI 466 enabled on CPU0
[    0.793128] ras_fhi_enable: FHI 467 enabled on CPU1
[    0.793218] ras_fhi_enable: FHI 468 enabled on CPU2
[    0.793274] ras_fhi_enable: FHI 469 enabled on CPU3
[    0.793338] ras_fhi_enable: FHI 470 enabled on CPU4
[    0.793404] ras_fhi_enable: FHI 471 enabled on CPU5
[    0.793607] carmel_ras_enable: RAS enabled on cpu0
[    0.793780] carmel_ras_enable: RAS enabled on cpu1
[    0.793975] carmel_ras_enable: RAS enabled on cpu2
[    0.794159] carmel_ras_enable: RAS enabled on cpu3
[    0.794342] carmel_ras_enable: RAS enabled on cpu4
[    0.794514] carmel_ras_enable: RAS enabled on cpu5
[    0.794572] carmel_ras carmel_ras: probed
[    0.795704] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 475, noc_nonsecure_irq = 474>
[    0.796213] tegra-cbb c600000.aon-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[    0.797155] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[    0.798117] tegra-cbb be00000.rce-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[    0.799264] tegra-cbb b600000.sce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[    0.799895] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    0.801176] vdd-ac-bat: 5000 mV
[    0.801589] vdd-sdmmc1-sw: 3300 mV
[    0.801888] vdd-1v8-sd: 1800 mV
[    0.802266] vdd-usb2-5v: 5000 mV
[    0.802618] vdd-3v3-cvb: 3300 mV
[    0.802910] vdd-1v8-cvb: 1800 mV
[    0.803250] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.803286] vdd-epb-1v0: 1000 mV
[    0.803655] avdd-cam-2v8: 2800 mV
[    0.803957] vdd-fan: 5000 mV
[    0.804245] vdd-hdmi-5v0: 5000 mV
[    0.804550] vdd_sys_en: 1200 mV
[    0.843588] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.847901] eventlib_kernel: keventlib is initialized, test id: 0
[    0.848230] SCSI subsystem initialized
[    0.848492] libata version 3.00 loaded.
[    0.848773] usbcore: registered new interface driver usbfs
[    0.848828] usbcore: registered new interface driver hub
[    0.848919] usbcore: registered new device driver usb
[    0.860580] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    0.863183] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    0.874483] vdd-1v0: at 1000 mV
[    0.882536] vdd-1v8-hs: at 1800 mV
[    0.890543] vdd-1v8-ls: at 1800 mV
[    0.898640] vdd-1v8-ao: at 1800 mV
[    0.906616] vddio-ddr-1v1: at 1100 mV
[    0.914406] vdd-rtc: at 800 mV
[    0.915735] spmic-ldo1: at 2375 mV
[    0.926444] vdd-ao-3v3: at 3300 mV
[    0.938479] vddio-emmc-3v3: at 3300 mV
[    0.939781] spmic-ldo4: at 1587 mV
[    0.950555] vdd-usb-3v3: at 3300 mV
[    0.959222] vddio-sdmmc1-3v3: at 3300 mV
[    0.963251] vdd-csi-1v2: at 1200 mV
[    0.964753] spmic-ldo8: at 1800 mV
[    0.969624] GPIO line 246 (gpio_default) hogged as output/high
[    0.970990] GPIO line 247 (gpio_default) hogged as output/high
[    0.971307] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[    0.971624] max77620 4-003c: max77620 probe successful
[    0.972194] media: Linux media interface: v0.10
[    0.972284] Linux video capture interface: v2.00
[    0.973829] pps_core: LinuxPPS API ver. 1 registered
[    0.973836] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.973905] PTP clock support registered
[    0.974206] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.974448] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.974478] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.976949] trusty trusty: trusty version: Built: 18:08:23 Apr  8 2020
[    0.977013] trusty trusty: selected api version: 3 (requested 3)
[    0.977961] Advanced Linux Sound Architecture Driver Initialized.
[    0.978509] Bluetooth: Core ver 2.22
[    0.978575] NET: Registered protocol family 31
[    0.978581] Bluetooth: HCI device and connection manager initialized
[    0.978591] Bluetooth: HCI socket layer initialized
[    0.978600] Bluetooth: L2CAP socket layer initialized
[    0.978635] Bluetooth: SCO socket layer initialized
[    0.980914] camchar: rtcpu character device driver loaded
[    0.981312] gpio tegra-gpio wake61 for gpio=201(Z:1)
[    0.981411] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[    0.982874] clocksource: Switched to clocksource arch_sys_counter
[    1.032540] VFS: Disk quotas dquot_6.6.0
[    1.032633] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.033036] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    1.034316] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[    1.034364] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    1.034649] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    1.034656] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    1.034669] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[    1.034676] nvmap_page_pool_init: Total RAM pages: 1986029
[    1.034682] nvmap_page_pool_init: nvmap page pool size: 248253 pages (969 MB)
[    1.034823] nvmap_background_zero_thread: PP zeroing thread starting.
[    1.035354] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    1.037520] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    1.050214] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    1.050412] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    1.050594] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[    1.050769] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[    1.050985] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    1.052155] la/ptsa driver initialized.
[    1.052486] NET: Registered protocol family 2
[    1.053362] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    1.053698] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.054268] TCP: Hash tables configured (established 65536 bind 65536)
[    1.054310] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    1.054425] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    1.054806] NET: Registered protocol family 1
[    1.055438] RPC: Registered named UNIX socket transport module.
[    1.055444] RPC: Registered udp transport module.
[    1.055448] RPC: Registered tcp transport module.
[    1.055453] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.055462] PCI: CLS 0 bytes, default 64
[    1.055670] Trying to unpack rootfs image as initramfs...
[    1.237269] Freeing initrd memory: 5432K
[    1.255343] random: fast init done
[    1.259741] host1x 13e10000.host1x: initialized
[    1.261251] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.265764] audit: initializing netlink subsys (disabled)
[    1.265813] audit: type=2000 audit(0.884:1): initialized
[    1.266623] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.277833] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.279187] ntfs: driver 2.1.32 [Flags: R/W].
[    1.279862] 9p: Installing v9fs 9p2000 file system support
[    1.284952] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.285116] io scheduler noop registered
[    1.285348] io scheduler cfq registered (default)
[    1.288819] gic 2a41000.agic-controller: GIC IRQ controller registered
[    1.324037] iommu: Adding device 2993000.adsp to group 55
[    1.437488] iommu: Adding device aconnect@2a41000:adsp_audio to group 56
[    1.438486] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    1.451343] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.451778] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.452440] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.452859] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.453269] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.456160] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.456414] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    1.459269] tsec 15500000.tsec: initialized
[    1.460998] tsec 15100000.tsecb: initialized
[    1.464975] nvdec 15480000.nvdec: initialized
[    1.467442] nvdec 15140000.nvdec1: initialized
[    1.473444] falcon 15340000.vic: initialized
[    1.475527] falcon 15380000.nvjpg: initialized
[    1.477383] falcon 154c0000.nvenc: initialized
[    1.479336] falcon 15a80000.nvenc1: initialized
[    1.483177] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    1.484691] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    1.485936] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    1.487297] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    1.488619] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    1.489944] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    1.491306] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    1.492659] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    1.496190] t194-nvcsi 15a00000.nvcsi: initialized
[    1.501295] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    1.501748] scare-pigeon 14b00000.isp-thi: initialized
[    1.507696] pva 16000000.pva0: initialized
[    1.513728] pva 16800000.pva1: initialized
[    1.519010] nvdla 15880000.nvdla0: initialized
[    1.523764] nvdla 158c0000.nvdla1: initialized
[    1.525208] tegradccommon 15200000.dc_common: host1x channel mapped
[    1.525221] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    1.525265] tegradccommon 15200000.dc_common: dma mapping done
[    1.525976] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=75
[    1.525986] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[    1.526199] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    1.526230] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    1.526478] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    1.526485] tegra_cec 3960000.tegra_cec: probed
[    1.527027] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[    1.527069] generic_infoframe_type: 0x87
[    1.527135] tegradc 15200000.nvdisplay: DT parsed successfully
[    1.527168] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[    1.531733] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[    1.531743] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[    1.531748] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 179200000 Hz
[    1.531973] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    1.531982] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    1.535027] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[    1.535035] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    1.538710] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    1.539548] tegradc 15200000.nvdisplay: probed
[    1.539670] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    1.539678] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    1.540002] kfuse 3830000.kfuse: initialized
[    1.540174] Console: switching to colour frame buffer device 80x30
[    1.540223] tegradc 15200000.nvdisplay: fb registered
[    1.540550] gpio tegra-gpio wake63 for gpio=97(M:1)
[    1.542154] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[    1.542238] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[    1.542358] tegradc 15210000.nvdisplay: DT parsed successfully
[    1.542386] tegradc 15210000.nvdisplay: Display dc.ffffff800be90000 registered with id=1
[    1.542582] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[    1.542592] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[    1.551533] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.553768] tegradc 15210000.nvdisplay: probed
[    1.554102] tegradc 15210000.nvdisplay: fb registered
[    1.554151] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 45, base_baud = 0) is a TEGRA_UART
[    1.555410] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 46, base_baud = 0) is a TEGRA_UART
[    1.556259] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 47, base_baud = 0) is a TEGRA_UART
[    1.557456] console [ttyTCU0] enabled
[    1.557609] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.557617] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.557629] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.557641] tegradc 15210000.nvdisplay: blank - powerdown
[    1.557656] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    1.557661] Extcon DP: HPD disabled
[    1.557665] hpd: hpd_switch 0
[    1.557671] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.557682] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.557691] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.557861] [drm] Initialized
[    1.571380] brd: module loaded
[    1.577167] loop: module loaded
[    1.577268] tegra_profiler: version: 1.141, samples/io: 48/28
[    1.577464] tegra_profiler: auth: init
[    1.578143] THERMAL EST: found 3 subdevs
[    1.578150] THERMAL EST num_resources: 0
[    1.578161] [THERMAL EST subdev 0]
[    1.578169] [THERMAL EST subdev 1]
[    1.578177] [THERMAL EST subdev 2]
[    1.578186] THERMAL EST: Found 2 profiles, default profile is quiet
[    1.578530] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.578535] THERMAL EST: thz register success.
[    1.578672] THERMAL EST: end of probe, return err: 0
[    1.579367] sd: No Scsi addr parsed to reserve index
[    1.579397] hisi_sas: driver version v1.6
[    1.589366] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[    1.589374] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[    1.589384] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[    1.589679] 1 ofpart partitions found on MTD device spi6.0
[    1.589686] Creating 1 MTD partitions on "spi6.0":
[    1.589703] 0x000000000000-0x000002000000 : "Whole_flash0"
[    1.592505] libphy: Fixed MDIO Bus: probed
[    1.593213] tun: Universal TUN/TAP device driver, 1.6
[    1.593218] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.593941] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.593946] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.594004] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.594009] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.594061] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.594065] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.594108] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    1.594113] Copyright(c) 1999 - 2017 Intel Corporation.
[    1.838556] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5 a0 da
[    1.838822] libphy: dwc_phy: probed
[    1.841665] PPP generic driver version 2.4.2
[    1.841961] PPP BSD Compression module registered
[    1.841970] PPP Deflate Compression module registered
[    1.842015] PPP MPPE Compression module registered
[    1.842021] NET: Registered protocol family 24
[    1.842077] usbcore: registered new interface driver r8152
[    1.842120] usbcore: registered new interface driver asix
[    1.842192] usbcore: registered new interface driver ax88179_178a
[    1.842237] usbcore: registered new interface driver cdc_ether
[    1.842274] usbcore: registered new interface driver net1080
[    1.842307] usbcore: registered new interface driver cdc_subset
[    1.842337] usbcore: registered new interface driver zaurus
[    1.842381] usbcore: registered new interface driver cdc_ncm
[    1.842686] VFIO - User Level meta-driver version: 0.3
[    1.844069] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.844091] ehci-pci: EHCI PCI platform driver
[    1.844128] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.844138] ohci-pci: OHCI PCI platform driver
[    1.844177] ohci-platform: OHCI generic platform driver
[    1.848751] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[    1.850594] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4d06800 id
[    1.850884] usbcore: registered new interface driver uas
[    1.850945] usbcore: registered new interface driver usb-storage
[    1.851025] usbcore: registered new interface driver usbserial
[    1.853880] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[    1.853929] tegra-xusb 3610000.xhci: xHCI Host Controller
[    1.853952] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    1.854667] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[    1.854740] tegra-xusb 3610000.xhci: irq 461, io mem 0x03610000
[    1.855012] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.855020] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.855027] usb usb1: Product: xHCI Host Controller
[    1.855034] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.855040] usb usb1: SerialNumber: 3610000.xhci
[    1.855582] hub 1-0:1.0: USB hub found
[    1.855651] hub 1-0:1.0: 4 ports detected
[    1.856191] tegra-xusb 3610000.xhci: xHCI Host Controller
[    1.856204] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    1.856214] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    1.856530] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.856539] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.856548] usb usb2: Product: xHCI Host Controller
[    1.856577] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.856583] usb usb2: SerialNumber: 3610000.xhci
[    1.857000] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    1.857079] tegra-xudc-new 3550000.xudc: device count: 1
[    1.857112] hub 2-0:1.0: USB hub found
[    1.857175] hub 2-0:1.0: 4 ports detected
[    1.858071] tegra-xudc-new 3550000.xudc: vbus state: 1
[    1.858095] tegra-xudc-new 3550000.xudc: device mode on: 0
[    1.858359] tegra-xudc-new 3550000.xudc: active: 0 => 1
[    1.858370] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[    1.859132] mousedev: PS/2 mouse device common for all mice
[    1.859236] usbcore: registered new interface driver xpad
[    1.990128] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.991948] Wake73 for irq=42
[    1.993412] rtc rtc1: alarm rtc device
[    1.993442] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    1.993479] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    1.993614] i2c /dev entries driver
[    1.996306] i2c i2c-2: Added multiplexed i2c bus 9
[    1.996746] i2c i2c-2: Added multiplexed i2c bus 10
[    1.996755] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    1.997273] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    2.020898] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    2.020961] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    2.021207] imx219 9-0010: board setup failed
[    2.021411] imx219: probe of 9-0010 failed with error -121
[    2.021942] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    2.045199] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    2.045291] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    2.045521] imx219 10-0010: board setup failed
[    2.045711] imx219: probe of 10-0010 failed with error -121
[    2.047479] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[    2.054480] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[    2.058655] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[    2.058686] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[    2.058693] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[    2.058790] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[    2.058926] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[    2.058934] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[    2.059235] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[    2.059296] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[    2.059330] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[    2.059602] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[    2.059662] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[    2.059670] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[    2.060038] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[    2.060110] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[    2.060117] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[    2.060387] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[    2.060849] FAN dev name: pwm-fan
[    2.060904] FAN:gpio request success.
[    2.060914] FAN: can't find tach_gpio
[    2.060925] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    2.060954] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    2.061170] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    2.061207] pwm_fan_driver pwm-fan: tach period: 1000
[    2.061830] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    2.061839] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    2.061846] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    2.061853] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    2.061859] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    2.061866] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    2.061872] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    2.061879] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    2.061885] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    2.061912] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    2.063276] device-mapper: uevent: version 1.0.3
[    2.063806] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.067639] tegra194_cpufreq_probe: platform driver Initialization: pass
[    2.068662] cpuidle: Initializing cpuidle driver
[    2.069715] sdhci: Secure Digital Host Controller Interface driver
[    2.069721] sdhci: Copyright(c) Pierre Ossman
[    2.069725] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.071114] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    2.073050] CMDQ: cmdq_platfm_init successful
[    2.077787] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    2.078887] tegra-se-nvhost 15810000.se: initialized
[    2.080090] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    2.081111] tegra-se-nvhost 15820000.se: initialized
[    2.082276] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    2.083027] tegra-se-nvhost 15830000.se: initialized
[    2.083755] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    2.084599] tegra-se-nvhost 15840000.se: initialized
[    2.085528] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    2.085790] hidraw: raw HID events driver (C) Jiri Kosina
[    2.088315] usbcore: registered new interface driver usbhid
[    2.088319] usbhid: USB HID core driver
[    2.092472] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[    2.093597] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    2.094189] tegra186-aondbg aondbg: aondbg driver probe() OK
[    2.095012] denver_knobs_init:MTS_VERSION:48073932
[    2.095203] tegra19x_actmon d230000.actmon: in actmon_register()...
[    2.095808] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[    2.096250] t19x_cache tegra-cache: probed
[    2.098554] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    2.098564] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    2.099210] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[    2.100922] nvpmodel: initialized successfully
[    2.102032] trusty-virtio trusty:virtio: initializing
[    2.102243] trusty_ipc virtio0: vring0: va(pa)  ffffffc1f2ba8000(0) qsz 32 notifyid 1
[    2.102254] trusty_ipc virtio0: vring1: va(pa)  ffffffc1f2baa000(0) qsz 32 notifyid 2
[    2.102401] trusty-virtio trusty:virtio: initializing done
[    2.102715] trusty_ipc virtio0: is online
[    2.103450] tegra-hda 3510000.hda: Override SDO lines to 4
[    2.103791] usbcore: registered new interface driver snd-usb-audio
[    2.114907] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    2.117793] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    2.118044] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    2.118300] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[    2.118526] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[    2.160838] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    2.173727] mmc0: periodic cache flush enabled
[    2.173746] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    2.174367] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    2.174661] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    2.174903] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    2.179168] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    2.182341]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    2.182904] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    2.188232] OPE platform probe
[    2.188351] OPE platform probe successful
[    2.211604] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[    2.211611] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.211616] usb 1-2: Product: 4-Port USB 2.1 Hub
[    2.211621] usb 1-2: Manufacturer: Generic
[    2.212577] hub 1-2:1.0: USB hub found
[    2.213179] hub 1-2:1.0: 4 ports detected
[    2.268385] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    2.268505] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    2.268626] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    2.268728] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    2.268826] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    2.268932] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    2.269049] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    2.269170] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    2.269301] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    2.269428] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    2.269565] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    2.269673] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    2.269780] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    2.269884] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    2.269989] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    2.270108] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    2.270235] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    2.270349] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    2.270472] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    2.270559] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    2.301088] u32 classifier
[    2.301094]     Actions configured
[    2.301186] Initializing XFRM netlink socket
[    2.301800] NET: Registered protocol family 10
[    2.302631] NET: Registered protocol family 17
[    2.302662] NET: Registered protocol family 15
[    2.302729] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.302872] Bluetooth: RFCOMM socket layer initialized
[    2.302893] Bluetooth: RFCOMM ver 1.11
[    2.302900] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.302907] Bluetooth: HIDP socket layer initialized
[    2.302935] 9pnet: Installing 9P2000 support
[    2.302997] Key type dns_resolver registered
[    2.303245] Registered cp15_barrier emulation handler
[    2.303269] Registered setend emulation handler
[    2.305085] registered taskstats version 1
[    2.305633] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[    2.306876] OF: PCI: host bridge /pcie@141a0000 ranges:
[    2.306904] OF: PCI:    IO 0x3a100000..0x3a1fffff -> 0x3a100000
[    2.306918] OF: PCI:   MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[    2.306924] OF: PCI:   MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    2.334888] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    2.354948] usb 1-2: usb_suspend_both: status 0
[    2.357580] usb 1-3: New USB device found, idVendor=8087, idProduct=0029
[    2.357586] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.418876] tegra-pcie-dw 141a0000.pcie: link is up
[    2.419097] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[    2.419126] pci_bus 0005:00: root bus resource [bus 00-ff]
[    2.419132] pci_bus 0005:00: root bus resource [io  0x0000-0xfffff] (bus address [0x3a100000-0x3a1fffff])
[    2.419138] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    2.419143] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    2.419169] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    2.419318] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    2.419576] iommu: Adding device 0005:00:00.0 to group 57
[    2.419962] pci 0005:01:00.0: [8086:2723] type 00 class 0x028000
[    2.420091] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    2.420750] pci 0005:01:00.0: PME# supported from D0 D3hot D3cold
[    2.421038] iommu: Adding device 0005:01:00.0 to group 58
[    2.431805] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[    2.431816] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[    2.431882] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    2.431890] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f400fffff]
[    2.431907] pci 0005:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    2.431955] pci 0005:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  128
[    2.432288] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[    2.432294] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[    2.432300] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[    2.432392] aer 0005:00:00.0:pcie002: service driver aer loaded
[    2.443411] tegra-cbb 14040000.cv-noc: noc_secure_irq = 87, noc_nonsecure_irq = 86>
[    2.448166] tegra194-isp5 14800000.isp: initialized
[    2.456120] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[    2.461854] tegra194-vi5 15c10000.vi: initialized
[    2.466688] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[    2.466764] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[    2.467586] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    2.549472] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[    2.549773] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    2.550006] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[    2.550207] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[    2.550601] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[    2.550660] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[    2.550943] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (63)
[    2.550970] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    2.552234] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[    2.552732] gpio tegra-gpio wake67 for gpio=48(G:0)
[    2.552802] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[    2.552943] input: gpio-keys as /devices/gpio-keys/input/input4
[    2.554905] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[    2.554911] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    2.583964] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[    2.584463] mmcblk mmc0:0001: Card claimed for testing.
[    2.625013] bpmp: mounted debugfs mirror
[    2.631586] vdd-sdmmc1-sw: disabling
[    2.631597] vdd-1v8-sd: disabling
[    2.631606] vdd-1v8-cvb: disabling
[    2.631613] vdd-epb-1v0: disabling
[    2.631620] avdd-cam-2v8: disabling
[    2.631627] vdd-fan: disabling
[    2.631636] vdd_sys_en: disabling
[    2.631648] ALSA device list:
[    2.631654]   #0: tegra-hda-galen-t194 at 0x3518000 irq 62
[    2.631659]   #1: jetson-xaviernx-ape
[    2.633818] Freeing unused kernel memory: 8576K
[    2.666163] Root device found: mmcblk0p1
[    2.667666] Found dev node: /dev/mmcblk0p1
[    2.807550] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[    2.807561] EXT4-fs (mmcblk0p1): recovery complete
[    2.812564] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    2.813772] Rootfs mounted over mmcblk0p1
[    2.833610] Switching from initrd to actual rootfs
[    2.942338] systemd[1]: System time before build time, advancing clock.
[    2.964495] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.968559] cgroup: cgroup2: unknown option "nsdelegate"
[    2.976429] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.977089] systemd[1]: Detected architecture arm64.
[    2.984098] systemd[1]: Set hostname to <nvidia-desktop>.
[    3.066270] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    3.066283] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    3.204345] random: systemd: uninitialized urandom read (16 bytes read)
[    3.207200] systemd[1]: Created slice User and Session Slice.
[    3.207362] random: systemd: uninitialized urandom read (16 bytes read)
[    3.208467] systemd[1]: Created slice System Slice.
[    3.208548] random: systemd: uninitialized urandom read (16 bytes read)
[    3.209644] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    3.209945] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.210170] systemd[1]: Listening on udev Control Socket.
[    3.264503] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    3.334770] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:291  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    3.622765] systemd-journald[2325]: Received request to flush runtime journal from PID 1
[    4.338334] using random self ethernet address
[    4.338466] using random host ethernet address
[    5.029482] random: crng init done
[    5.029590] random: 7 urandom warning(s) missed due to ratelimiting
[    5.088799] Mass Storage Function, version: 2009/09/11
[    5.088809] LUN: removable file: (no medium)
[    5.095534] using random self ethernet address
[    5.095675] using random host ethernet address
[    5.120119] rndis0: HOST MAC 62:d7:f7:de:b2:00
[    5.120350] rndis0: MAC 62:d7:f7:de:b2:01
[    5.122087] usb0: HOST MAC 62:d7:f7:de:b2:02
[    5.122131] usb0: MAC 62:d7:f7:de:b2:03
[    5.122158] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[    5.128213] l4tbr0: port 1(rndis0) entered blocking state
[    5.128225] l4tbr0: port 1(rndis0) entered disabled state
[    5.129683] device rndis0 entered promiscuous mode
[    5.136225] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    5.143351] l4tbr0: port 2(usb0) entered blocking state
[    5.143360] l4tbr0: port 2(usb0) entered disabled state
[    5.144481] device usb0 entered promiscuous mode
[    5.153940] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    5.239503] ras_fhi_disable: FHI 468 disabled
[    5.240177] CPU2: shutdown
[    5.240283] psci: CPU2 killed.
[    5.311457] ras_fhi_disable: FHI 469 disabled
[    5.312118] CPU3: shutdown
[    5.312222] psci: CPU3 killed.
[    5.320231] android_work: did not send uevent (0 0           (null))
[    5.367477] ras_fhi_disable: FHI 470 disabled
[    5.368320] CPU4: shutdown
[    5.368420] psci: CPU4 killed.
[    5.393191] android_work: sent uevent USB_STATE=CONNECTED
[    5.411457] ras_fhi_disable: FHI 471 disabled
[    5.412516] CPU5: shutdown
[    5.412623] psci: CPU5 killed.
[    5.414411] nvgpu: 17000000.gv11b                 tpc_pg_mask_store:843  [INFO]  no value change, same mask already set
[    5.448478] android_work: sent uevent USB_STATE=DISCONNECTED
[    5.469512] compat: loading out-of-tree module taints kernel.
[    5.541104] android_work: sent uevent USB_STATE=CONNECTED
[    5.542395] configfs-gadget gadget: high-speed config #1: c
[    5.542425] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[    5.542438] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[    5.542449] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[    5.542524] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[    5.542536] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[    5.542547] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[    5.542574] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[    5.542594] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[    5.542613] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[    5.542676] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[    5.543049] android_work: sent uevent USB_STATE=CONFIGURED
[    5.550599] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[    5.550616] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[    5.550728] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[    5.550938] tegra-xudc-new 3550000.xudc: ep 13 disabled
[    5.551042] tegra-xudc-new 3550000.xudc: ep 8 disabled
[    5.569180] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[    5.569195] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[    5.643094] zram: Added device: zram0
[    5.647335] zram: Added device: zram1
[    5.691617] zram0: detected capacity change from 0 to 2037280768
[    5.744958] Adding 1989528k swap on /dev/zram0.  Priority:5 extents:1 across:1989528k SS
[    5.769715] zram1: detected capacity change from 0 to 2037280768
[    5.798522] Adding 1989528k swap on /dev/zram1.  Priority:5 extents:1 across:1989528k SS
[    6.030757] Wake76 for irq=199
[    6.030764] Wake77 for irq=199
[    6.030767] Wake78 for irq=199
[    6.030770] Wake79 for irq=199
[    6.030773] Wake80 for irq=199
[    6.030775] Wake81 for irq=199
[    6.030778] Wake82 for irq=199
[    6.030837] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[    6.030842] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[    6.057936] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.062710] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.076516] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.351365] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[    6.381019] usb 2-3: New USB device found, idVendor=0bda, idProduct=0411
[    6.381027] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.381032] usb 2-3: Product: 4-Port USB 3.1 Hub
[    6.381036] usb 2-3: Manufacturer: Generic
[    6.391645] gpio tegra-gpio wake20 for gpio=52(G:4)
[    6.394239] hub 2-3:1.0: USB hub found
[    6.395345] hub 2-3:1.0: 4 ports detected
[    6.397592] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.460204] Intel(R) Wireless WiFi driver for Linux
[    6.460210] Copyright(c) 2003- 2015 Intel Corporation
[    6.559788] usb 2-3: usb_suspend_both: status 0
[    6.562580] usb usb2: usb_suspend_both: status 0
[    6.705660] usbcore: registered new interface driver btusb
[    6.956227] tegradc 15200000.nvdisplay: blank - powerdown
[    6.956239] tegradc 15210000.nvdisplay: blank - powerdown
[    7.769300] fuse init (API version 7.26)
[    8.040903] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control off
[    8.041522] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.771449] l4tbr0: port 2(usb0) entered blocking state
[   12.771457] l4tbr0: port 2(usb0) entered forwarding state
[   12.771526] l4tbr0: port 1(rndis0) entered blocking state
[   12.771531] l4tbr0: port 1(rndis0) entered forwarding state
[   12.783121] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[   12.783151] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[   67.419244] thermal thermal_zone6: failed to read out thermal zone (-61)
[   67.529604] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  130.363071] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
reference en:users:drivers:iwlwifi:debugging [Linux Wireless]
I guess there are some GPIO on our M.2 connector which accidentally disables this card on Intel’s design.
Need to consult with internal team to check the pinout.
from 207529 – firewire load error wifi ax 200
2020-05-07 08:39:27 UTC
The firwmare is loading correctly.
    This is your problem.
    Check why your board is reporting that the radio is disabled.
Yes, this comment from bugzilla is correct.
This should be due to some pin is accidentally being pull down on NX carrier board. Still checking with our team to figure out which pin…
Could you try this patch and see if it can work?
diff --git a/common/tegra194-fixed-regulator-p3668.dtsi b/common/tegra194-fixed-regulator-p3668.dtsi
index 6fb7fe17718d..747973e05485 100644
--- a/common/tegra194-fixed-regulator-p3668.dtsi
+++ b/common/tegra194-fixed-regulator-p3668.dtsi
@@ -51,7 +51,7 @@
                        regulator-min-microvolt = <5000000>;
                        regulator-max-microvolt = <5000000>;
-                       gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 2) GPIO_ACTIVE_HIGH>;
+                       gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 2) GPIO_ACTIVE_LOW>;
-                       enable-active-high;
+                       regulator-boot-on;
diff --git a/common/tegra194-p3668-common.dtsi b/common/tegra194-p3668-common.dtsi
index cf1195d2ea72..d4824d44d84e 100644
--- a/common/tegra194-p3668-common.dtsi
+++ b/common/tegra194-p3668-common.dtsi
@@ -133,7 +133,6 @@
                        usb2-2 {
                                mode = "host";
-                               vbus-supply = <&p3509_vdd_usb2_5v>;
                                status = "okay";
                        usb3-2 {
@WayneWWW, where do I find the file tegra194-fixed-regulator-p3668.dtsi file?
At the Host PC? at NX device? both or neither of the two?
does it need to download and build the kernel from sources?
Attempt1 natively at NX:
    sudo mkfs.ext4 /dev/sda1
    mount /dev/sda1 /media
    cd /media
    sudo chown -R nvidia ../media
    wget https://developer.nvidia.com/embedded/L4T/r32_Release_v4.2/Sources/T186/public_sources.tbz2
    tar -xjf public_sources.tbz2
     cd Linux_for_Tegra/
     cd source/
    cd public/
    tar -xjf kernel_src.tbz2
   mkdir /media/outdir
   TEGRA_KERNEL_OUT=/media/outdir
   cd kernel/
nvidia@nvidia-desktop:/media/Linux_for_Tegra/source/public/kernel$ ls
kernel-4.9  nvgpu  nvidia
 cd kernel-4.9
cd kernel
cd ..
mkdir -p $TEGRA_KERNEL_OUT
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j 6
cd /media/Linux_for_Tegra/source/public/hardware/nvidia/platform/t19x/jakku/kernel-dts/common
found and edited these two files;
probably now I shall rebuild kernel again with:
continuing the attempt:
locate kernel/Image
/path/ nstallation_folder/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra/kernel/Image
#substituting it with
$TEGRA_KERNEL_OUT/arch/arm64/boot/Image
also substituting
Linux_for_Tegra/kernel/dtb/
with
$TEGRA_KERNEL_OUT/arch/arm64/boot/dts/
that I am doing at the Host PC or at the NX device?
reference https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/kernel_custom.html
given I am building the kernel natively;
will the steps 5-8 below reffer to the Host_PC or to the extracted kernel soursec public folder?
6.Replace the contents of Linux_for_Tegra/kernel/dtb/ with the contents of:
7.Execute the following commands to install the kernel modules:
$ sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install \
    INSTALL_MOD_PATH=<top>/Linux_for_Tegra/rootfs/
8.Optionally, archive the installed kernel modules using the following comm
If it refers to the extracted folder then it has path missed;
But if it refers to the host PC, how do I execute from NX with the pointer [/Linux_for_Tegra/rootfs/]
In my case after extraction the folder Linux for Tegra at NX device has only one subfolder sources, within it a subfolder public,
 cd /media/
nvidia@nvidia-desktop:/media$ cd Linux_for_Tegra/
nvidia@nvidia-desktop:/media/Linux_for_Tegra$ ls
source
nvidia@nvidia-desktop:/media/Linux_for_Tegra$ cd source/
nvidia@nvidia-desktop:/media/Linux_for_Tegra/source$ cd public/
nvidia@nvidia-desktop:/media/Linux_for_Tegra/source/public$ ls
atf_src.tbz2                     gst-nvarguscamera_src.tbz2           kernel_src.tbz2                      nvsample_cudaprocess_src.tbz2.sha1sum
atf_src.tbz2.sha1sum             gst-nvarguscamera_src.tbz2.sha1sum   kernel_src.tbz2.sha1sum              opencv_gst_samples_src.tbz2
dtc-1.4.0.tar.bz2                gst-nvv4l2camera_src.tbz2            libgstnvvideosinks_src.tbz2          opencv_gst_samples_src.tbz2.sha1sum
dtc-1.4.0.tar.bz2.sha1sum        gst-nvv4l2camera_src.tbz2.sha1sum    libgstnvvideosinks_src.tbz2.sha1sum  public_sources_sha.txt
FreeRTOSV8.1.2_src.tbz2          gst-nvvideo4linux2_src.tbz2          nvbuild.sh                           trusty_src.tbz2
FreeRTOSV8.1.2_src.tbz2.sha1sum  gst-nvvideo4linux2_src.tbz2.sha1sum  nvcommon_build.sh                    trusty_src.tbz2.sha1sum
gstegl_src.tbz2                  gstomx1_src.tbz2                     nvgstapps_src.tbz2                   u-boot_src.tbz2
gstegl_src.tbz2.sha1sum          gstomx1_src.tbz2.sha1sum             nvgstapps_src.tbz2.sha1sum           u-boot_src.tbz2.sha1sum
gstjpeg_src.tbz2                 hardware                             nv_public_src_build.sh               v4l2_libs_src.tbz2
gstjpeg_src.tbz2.sha1sum         kernel                               nvsample_cudaprocess_src.tbz2        v4l2_libs_src.tbz2.sha1sum
Or if I overrided at Host PC dts folder with dtb content I can skip these steps and just try flashing?
Hi Andrey1984,
Every kernel compilation steps on the document are doing cross compile on the host.
And I guess the folder name misled you.
The one which has rootfs is the one you are using for flashing. I am not sure why even the source code folder is named as Linux_for_Tegra now…
Also,
“TEGRA_KERNEL_OUT”: this means the kernel build out folder to put your kernel binary.
BTW, if that patch does not work. Please also try.
index 6fb7fe17718d..1a9ae738ac3e 100644
@@ -51,7 +51,8 @@
+                       enable-at-boot;
@@ -133,7 +133,6 @@
                        usb2-2 {
                                mode = "host";
                                status = "okay";
                        usb3-2 {
In my case I am not doing cross-compile
as you can see I am building it at NX natively;
The question is if it is redundant for patching to copy resulting Image file and dtb folder content to the host PC? Or other steps will be also required until I can flash the board so that the patch is aapplied? If other steps will also be required - which exactly steps? considering it is not cross-compiling scenario. but performed at NX natively? Could you extend, please?
how do I check after re-flashing if the patch has been applied? is there a way to monitor it? grep it from the system somehow?
