WiFi Board 8265 driver not loading
I have installed a 8265 WiFi module in my Jetson Nano and it worked perfect at the beginning. However after a couple of months without issue suddenly the WiFi is not recognized.
It seems that the board is recognized but there are issues with the driver. I have tried with a new SD Card and installing again the original image and the issue persists.
I also tried the workaround provided in the link Wifi M.2 Intel 3168NGW loading but can not use it - #15 by softreaper and it doesn’t work either. extlinux.conf file is the one below.
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet pcie_aspm=off
I include printouts
iwconfig
eth0 no wireless extensions.
dummy0 no wireless extensions.
rndis0 no wireless extensions.
usb0 no wireless extensions.
l4tbr0 no wireless extensions.
lo no wireless extensions.
lshw -C network
*-network
description: Network controller
product: Wireless 8265 / 8275
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: 78
width: 64 bits
clock: 33MHz
capabilities: cap_list
configuration: driver=iwlwifi latency=0
resources: irq:408 memory:13000000-13001fff
lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1)
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1)
01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
dmesg | grep -i firm
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 1.573889] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 7.499436] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 7.687502] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 7.711394] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 7.728563] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 7.749432] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 7.769316] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 7.904924] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 9.514188] Bluetooth: hci0: Waiting for firmware download to complete
[ 9.514348] Bluetooth: hci0: Firmware loaded in 1969376 usecs
REgards,
Alberto
@Albertograbit
Have you ever update the kenrel? Could you share your kernel Image version by ‘uname -a’ ?
Sorry I was not able to answer before!!
I have in fact upgraded to new Deepstream5.0 and the issue remains. The printout for ‘uname -a’ is:
Linux grabit2 4.9.140-tegra #1 SMP PREEMPT Wed Apr 8 18:10:49 PDT 2020 aarch64 aarch64 aarch64 GNU/Linux
Regards,
Alberto
Have you ever upgraded the kernel or changed any driver related stuff?
No, I have not done any of those
Actually such description is more like a hardware issue and you also said there is no external driver change.
Could you paste full dmesg? Also, the result of sudo rfkill -list
I paste both below although sudo rfkill -list doesn’t work. I guess you mean sudo rfkill list
dmesg
[ 1.884260] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.890552] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 1.890625] tegra_dvfs: vdd-gpu-vts: registered
[ 1.897359] pcieport 0000:00:01.0: broadcast error_detected message
[ 1.897363] pcieport 0000:00:01.0: AER: Device recovery failed
[ 1.897606] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.898207] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.898683] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.915359] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.915368] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 1.925681] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 1.926771] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.934175] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 1.940265] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:21 UTC (946688421)
[ 1.940349] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.940355] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.940358] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.940377] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 1.941234] vi 54080000.vi: vi_probe: ++
[ 1.950783] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 1.960384] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 1.966529] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966535] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966538] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966543] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966546] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966551] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966554] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966558] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966562] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966566] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966569] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966574] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966577] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966582] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966585] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966590] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966593] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966597] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966600] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966605] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966608] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966612] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966615] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966619] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966622] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966626] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966629] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966633] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966636] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966640] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966644] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966648] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966650] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966655] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966657] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966662] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966665] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966669] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966672] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966676] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966679] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966683] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966686] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966690] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966693] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966697] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966700] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966705] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966708] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966712] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966715] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966719] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966722] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.966726] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966729] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966733] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966736] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966740] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966743] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966757] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.966760] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.966765] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.969007] vi 54080000.vi: initialized
[ 1.973302] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.973310] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 1.984609] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 1.985059] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.986712] Disable partitions left on by BL
[ 1.986715] disb
[ 1.986774] bwmgr: missing cdev-type property
[ 1.986901] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.986905] DRAM derating cdev registered.
[ 1.987888] vdd-fan: disabling
[ 1.987890] vdd-usb-vbus: disabling
[ 1.987892] vdd-usb-vbus2: disabling
[ 1.987902] avdd-io-edp-1v05: disabling
[ 1.993071] ALSA device list:
[ 1.993074] #0: tegra-hda at 0x70038000 irq 83
[ 1.993076] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.994148] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 1.994173] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.994177] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.994179] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.994181] usb 1-2: Manufacturer: Generic
[ 1.995286] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.996372] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 1.996376] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000081/00002000
[ 1.996378] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 1.996381] pcieport 0000:00:01.0: [ 7] Bad DLLP
[ 1.996495] hub 1-2:1.0: USB hub found
[ 1.997428] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.997433] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.997436] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.998516] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.998519] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 1.998525] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 1.998528] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 1.998571] hub 1-2:1.0: 4 ports detected
[ 1.999596] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 1.999601] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 1.999605] pcieport 0000:00:01.0: can’t find device of ID0010
[ 1.999608] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.000678] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.000681] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.000684] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.000696] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000700] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000703] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.000706] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000709] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000712] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000715] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.000718] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000721] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000725] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000727] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000731] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000733] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000737] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000739] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000743] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000745] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000749] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.000751] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.000755] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.001821] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.001826] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.001829] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.001832] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.002917] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.002923] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.002926] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.002936] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.003993] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.003999] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.004002] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.004005] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.006160] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.006165] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.006168] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.006170] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.010476] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.010479] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.014605] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.014611] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.014614] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.014617] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.014621] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.014625] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.015675] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.015681] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.015684] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.015695] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.016736] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.016742] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.016744] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.016747] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.017794] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.017800] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.017802] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.017805] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.018868] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.018873] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.018876] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.018879] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.019929] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.019961] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.019963] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.019966] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.019970] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.019973] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.019976] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.019979] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.021030] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.021036] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.021038] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.021041] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.021064] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.021068] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.021070] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.021074] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.022113] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.022118] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.022121] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.022124] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.026312] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.026318] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.026320] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.026323] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.034699] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.034704] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.034707] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.034709] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.035767] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.035773] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.035776] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.035778] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.035802] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.035806] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.036863] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.036869] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.036871] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.036874] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.036886] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.036889] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.036892] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.036895] pcieport 0000:00:01.0: can’t find device of ID0010
[ 2.037940] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.037946] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.037948] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.037951] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.039008] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.039014] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.039016] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.039019] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.040067] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.040072] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.040075] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.040077] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.042169] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.042175] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.042177] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.042180] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.052682] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.052687] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.052690] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.052692] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.054794] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.054800] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.054802] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.054813] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.055854] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.055860] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.055863] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.055865] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.056913] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.056918] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.056921] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.056923] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.057977] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.057982] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.057985] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.057987] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.060114] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.060119] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.060122] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.060124] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.062220] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.062226] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.062228] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.062231] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.075858] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 2.075864] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.075866] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.075869] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.076916] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.076922] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.076925] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.076927] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.077981] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.077987] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.077989] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.077992] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.079049] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 2.079054] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 2.079057] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 2.079059] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 2.123275] mmc0: Applying tuning correction
[ 2.123288] mmc0: Tap value after applying correction 55
[ 2.123305] mmc0: hw tuning done …
[ 2.123347] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 2.123637] mmcblk0: mmc0:aaaa SN128 119 GiB
[ 2.127910] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.130772] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.142828] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 2.152589] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 2.152592] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.166822] usb 1-2: usb_suspend_both: status 0
[ 2.846002] Freeing unused kernel memory: 8576K
[ 2.866333] Root device found: mmcblk0p1
[ 2.867419] Found dev node: /dev/mmcblk0p1
[ 3.269296] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 3.269299] EXT4-fs (mmcblk0p1): recovery complete
[ 3.285435] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.286162] Rootfs mounted over mmcblk0p1
[ 3.310427] Switching from initrd to actual rootfs
[ 3.533103] systemd[1]: System time before build time, advancing clock.
[ 3.555523] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.567691] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.595541] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.596287] systemd[1]: Detected architecture arm64.
[ 3.619328] systemd[1]: Set hostname to .
[ 3.746777] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.746789] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.938609] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.940603] systemd[1]: Created slice User and Session Slice.
[ 3.940719] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.940834] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.941013] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.942835] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.943677] systemd[1]: Created slice System Slice.
[ 3.944038] systemd[1]: Listening on Journal Audit Socket.
[ 4.039828] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.129584] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 4.501488] Adding 6291452k swap on /mnt/swapfile. Priority:-1 extents:7 across:6856700k SS
[ 4.529346] systemd-journald[1969]: Received request to flush runtime journal from PID 1
[ 5.252130] Intel(R) Wireless WiFi driver for Linux
[ 5.252133] Copyright(c) 2003- 2015 Intel Corporation
[ 5.252269] iwlwifi 0000:01:00.0: enabling device (0000 → 0002)
[ 5.270609] Timeout waiting for hardware access (CSR_GP_CNTRL 0xffffffff)
[ 5.270664] ------------[ cut here ]------------
[ 5.275312] WARNING: CPU: 0 PID: 2813 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/drivers/net/wireless/intel/iwlwifi/pcie/trans.c:1860 iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 5.292234] Modules linked in: iwlwifi(+) cfg80211 spidev nvgpu bluedroid_pm ip_tables x_tables
[ 5.292256] CPU: 0 PID: 2813 Comm: systemd-udevd Not tainted 4.9.140-tegra #1
[ 5.292258] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 5.292261] task: ffffffc0f5793800 task.stack: ffffffc0f5788000
[ 5.292290] PC is at iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 5.292312] LR is at iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 5.292315] pc : [] lr : [] pstate: 404000c5
[ 5.292317] sp : ffffffc0f578b990
[ 5.292319] x29: ffffffc0f578b990 x28: 0000000000000018
[ 5.292325] x27: 0000000000000484 x26: ffffffc0ef19fdc4
[ 5.292330] x25: ffffff800124ee70 x24: ffffff8001249f00
[ 5.292335] x23: ffffffc0ef198238 x22: ffffffc0f9ba30a0
[ 5.292340] x21: ffffffc0f578ba38 x20: ffffffc0ef19fec0
[ 5.292345] x19: ffffffc0ef198018 x18: 0000000000000030
[ 5.292349] x17: 0000000000000001 x16: 0000000000000007
[ 5.292354] x15: ffffffffffffffff x14: ffffff800a1391e0
[ 5.292359] x13: 0000000000000000 x12: 0000000000000006
[ 5.292363] x11: 0000000000000002 x10: 00000000000003e1
[ 5.292368] x9 : 0000000000000001 x8 : ffffffc0fefa87ff
[ 5.292373] x7 : 0000000000000000 x6 : 000000000ca271a5
[ 5.292377] x5 : 0000000000000000 x4 : ffffffc0fefb5be8
[ 5.292382] x3 : ffffffc0fefb5be8 x2 : 0000000000000007
[ 5.292387] x1 : ffffffc0f5793800 x0 : 000000000000003d
[ 5.292393] —[ end trace 234ae59e99aa08fc ]—
[ 5.297003] Call trace:
[ 5.297030] [] iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 5.297053] [] iwl_trans_pcie_alloc+0x670/0xa20 [iwlwifi]
[ 5.297076] [] iwl_parse_nvm_data+0x894/0xa58 [iwlwifi]
[ 5.297084] [] pci_device_probe+0xa4/0x140
[ 5.297090] [] driver_probe_device+0xd8/0x408
[ 5.297093] [] __driver_attach+0xdc/0x128
[ 5.297097] [] bus_for_each_dev+0x5c/0xa8
[ 5.297100] [] driver_attach+0x30/0x40
[ 5.297103] [] bus_add_driver+0x20c/0x2a8
[ 5.297107] [] driver_register+0x6c/0x110
[ 5.297111] [] __pci_register_driver+0x50/0x60
[ 5.297134] [] iwl_pci_register_driver+0x24/0x68 [iwlwifi]
[ 5.297155] [] init_module+0x64/0xa8 [iwlwifi]
[ 5.297160] [] do_one_initcall+0x44/0x130
[ 5.297165] [] do_init_module+0x64/0x1a8
[ 5.297170] [] load_module+0x10a4/0x12d8
[ 5.297173] [] SyS_finit_module+0xd8/0xf0
[ 5.297176] [] __sys_trace_return+0x0/0x4
[ 5.506555] random: crng init done
[ 5.509961] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.603330] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 5.613733] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.766633] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.766639] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.964861] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 5.974965] iwlwifi 0000:01:00.0: Falling back to user helper
[ 5.984716] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 5.994420] iwlwifi 0000:01:00.0: Falling back to user helper
[ 6.001460] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 6.010868] iwlwifi 0000:01:00.0: Falling back to user helper
[ 6.054297] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 6.095688] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.130140] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 6.130145] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.130149] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 6.130153] usb 2-1: Manufacturer: Generic
[ 6.135542] hub 2-1:1.0: USB hub found
[ 6.136951] hub 2-1:1.0: 4 ports detected
[ 6.275483] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0xFFFC
[ 6.277581] iwlwifi 0000:01:00.0: L1 Disabled - LTR Disabled
[ 6.277681] iwlwifi 0000:01:00.0: L1 Disabled - LTR Disabled
[ 6.298827] usb 2-1: usb_suspend_both: status 0
[ 6.298968] usb usb2: usb_suspend_both: status 0
[ 6.975394] iwlwifi 0000:01:00.0: Could not load the [0] uCode section
[ 6.982060] iwlwifi 0000:01:00.0: Failed to start INIT ucode: -5
[ 7.317474] using random self ethernet address
[ 7.327727] using random host ethernet address
[ 7.696317] usbcore: registered new interface driver btusb
[ 7.701418] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 7.702432] Bluetooth: hci0: Device revision is 16
[ 7.702436] Bluetooth: hci0: Secure boot is enabled
[ 7.702439] Bluetooth: hci0: OTP lock is enabled
[ 7.702441] Bluetooth: hci0: API lock is enabled
[ 7.702443] Bluetooth: hci0: Debug lock is disabled
[ 7.702447] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 7.718406] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 7.937689] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.937700] Bluetooth: BNEP socket layer initialized
[ 8.386212] Mass Storage Function, version: 2009/09/11
[ 8.386219] LUN: removable file: (no medium)
[ 8.395898] using random self ethernet address
[ 8.404445] using random host ethernet address
[ 8.453690] rndis0: HOST MAC 06:ac:f7:27:b4:dc
[ 8.453810] rndis0: MAC 06:ac:f7:27:b4:dd
[ 8.455446] usb0: HOST MAC 06:ac:f7:27:b4:de
[ 8.455540] usb0: MAC 06:ac:f7:27:b4:df
[ 8.455568] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.467367] l4tbr0: port 1(rndis0) entered blocking state
[ 8.467372] l4tbr0: port 1(rndis0) entered disabled state
[ 8.467872] device rndis0 entered promiscuous mode
[ 8.478647] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.559791] l4tbr0: port 2(usb0) entered blocking state
[ 8.559796] l4tbr0: port 2(usb0) entered disabled state
[ 8.561013] device usb0 entered promiscuous mode
[ 8.577244] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.584086] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.585135] eth0: 0xffffff800a38e000, 00:04:4b:e6:4c:65, IRQ 406
[ 8.718102] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.862793] iwlwifi 0000:01:00.0: Failed to run INIT ucode: -5
[ 8.868696] iwlwifi 0000:01:00.0: L1 Disabled - LTR Disabled
[ 9.123101] zram: Added device: zram0
[ 9.123601] zram: Added device: zram1
[ 9.124993] zram: Added device: zram2
[ 9.125435] zram: Added device: zram3
[ 9.147901] zram0: detected capacity change from 0 to 519606272
[ 9.188461] Adding 507424k swap on /dev/zram0. Priority:5 extents:1 across:507424k SS
[ 9.194253] zram1: detected capacity change from 0 to 519606272
[ 9.225077] Adding 507424k swap on /dev/zram1. Priority:5 extents:1 across:507424k SS
[ 9.234891] zram2: detected capacity change from 0 to 519606272
[ 9.245507] Adding 507424k swap on /dev/zram2. Priority:5 extents:1 across:507424k SS
[ 9.251530] zram3: detected capacity change from 0 to 519606272
[ 9.263713] Adding 507424k swap on /dev/zram3. Priority:5 extents:1 across:507424k SS
[ 9.318142] Bluetooth: hci0: Waiting for firmware download to complete
[ 9.318394] Bluetooth: hci0: Firmware loaded in 1584134 usecs
[ 9.318508] Bluetooth: hci0: Waiting for device to boot
[ 9.335412] Bluetooth: hci0: Device booted in 16555 usecs
[ 9.348594] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 9.351560] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 10.774432] tegradc tegradc.0: blank - powerdown
[ 10.774442] tegradc tegradc.1: blank - powerdown
[ 43.604034] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 43.604112] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 43.604173] tegra-xudc-new 700d0000.xudc: device mode off: 0
[ 43.604248] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 0
[ 43.604342] tegra-xudc-new 700d0000.xudc: active: 1 => 0
[ 43.604414] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 43.616490] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 46.555467] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 46.560149] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 46.571394] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000081/00002000
[ 46.580066] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 46.586309] pcieport 0000:00:01.0: [ 7] Bad DLLP
[ 46.592534] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 46.592619] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 46.605280] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 46.616807] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 46.623648] pcieport 0000:00:01.0: broadcast error_detected message
[ 46.623657] pcieport 0000:00:01.0: AER: Device recovery failed
[ 46.623662] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 46.623670] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 46.635449] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 46.643839] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 46.650672] pcieport 0000:00:01.0: broadcast error_detected message
[ 46.650675] pcieport 0000:00:01.0: AER: Device recovery failed
[ 46.650680] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 46.650687] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 46.663014] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 46.674290] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 46.681127] pcieport 0000:00:01.0: broadcast error_detected message
[ 46.681132] pcieport 0000:00:01.0: AER: Device recovery failed
[ 46.681136] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 46.681148] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 46.691373] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000081/00002000
[ 46.699765] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 46.705898] pcieport 0000:00:01.0: [ 7] Bad DLLP
[ 46.712552] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 46.712619] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 46.712627] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 46.713218] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 46.713225] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 46.713232] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 46.713241] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 46.966413] android_work: did not send uevent (0 0 (null))
[ 46.999933] android_work: sent uevent USB_STATE=CONNECTED
[ 47.037689] configfs-gadget gadget: high-speed config #1: c
[ 47.037732] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 47.037751] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 47.037768] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 47.037881] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 47.037899] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 47.037915] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 47.038072] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 47.038128] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 47.038162] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 47.038181] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 47.038424] android_work: sent uevent USB_STATE=CONFIGURED
[ 47.378244] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.382487] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 47.392714] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 47.401081] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 47.407313] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.407325] tegra-pcie 1003000.pcie: PCIE: Response decoding error, signature: 10010049
[ 47.415406] tegra-pcie 1003000.pcie: PCIE: Response decoding error, signature: 11010011
[ 47.423428] tegra-pcie 1003000.pcie: PCIE: Response decoding error, signature: 11010015
[ 47.431482] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.431486] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.431496] tegra-pcie 1003000.pcie: PCIE: Response decoding error, signature: 10010049
[ 47.439676] tegra-pcie 1003000.pcie: PCIE: Response decoding error, signature: 11010011
[ 47.447775] tegra-pcie 1003000.pcie: PCIE: Response decoding error, signature: 11010015
[ 47.455789] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.455793] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.455840] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.455845] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.455891] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.455894] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.455950] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.455953] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.455997] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456000] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456043] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456046] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456089] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456092] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456135] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456138] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456181] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456184] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456227] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456230] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456273] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456276] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456320] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456323] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456366] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456369] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456412] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456415] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456466] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456469] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456514] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456517] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456560] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456563] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456606] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456609] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456652] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456655] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456698] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456701] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 47.456744] pcieport 0000:00:01.0: can’t find device of ID0010
[ 47.456747] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.456754] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.468490] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.476868] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.483667] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.483671] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.483676] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.483684] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.495424] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.503794] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.510598] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.510602] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.510607] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.510614] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.523491] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.531858] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.538681] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.538686] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.538690] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.538698] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.550480] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.558882] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.565683] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.565687] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.565692] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.565699] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.577452] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.585845] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.592643] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.592647] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.592651] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.592658] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.604436] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.613112] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.619993] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.619998] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.620003] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.620014] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.631827] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.640205] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.647021] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.647025] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.647029] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.647036] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.679526] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.687961] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.694787] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.694791] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.694796] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.694803] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.725427] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.733803] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.740663] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.740667] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.740671] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.740679] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.771707] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.780088] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.786911] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.786915] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.786919] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.786927] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.817290] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.825652] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.832450] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.832454] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.832458] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.832465] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.863954] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.872315] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.879138] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.879143] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.879147] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.879159] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.890985] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.899367] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.906170] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.906174] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.906178] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.906185] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.917927] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.926295] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.933095] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.933098] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.933102] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.933110] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.944861] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.953216] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.960014] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.960018] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.960022] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.960030] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.971862] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 47.980218] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 47.987024] pcieport 0000:00:01.0: broadcast error_detected message
[ 47.987028] pcieport 0000:00:01.0: AER: Device recovery failed
[ 47.987032] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 47.987040] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 47.998845] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.007215] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.014039] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.014043] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.014047] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.014054] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.025870] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.034234] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.041336] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.041340] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.041345] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.041352] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.053251] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.061637] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.068480] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.068483] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.068487] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.068495] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.080369] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.088783] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.095701] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.095706] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.095710] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.095746] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.107541] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.116084] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.122933] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.122937] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.122941] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.122950] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.134737] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.143142] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.150025] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.150031] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.150035] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.150056] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.161872] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.170265] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.177149] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.177165] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.177169] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.177192] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.189097] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.197557] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.204424] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.204429] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.204434] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.204441] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.216200] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.224580] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.231487] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.231550] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.231601] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.231675] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.243422] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.252153] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.258983] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.259009] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.259014] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.259023] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.270916] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.279328] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.286166] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.286169] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.286173] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.286180] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.297984] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.306410] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.313245] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.313250] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.313281] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.313319] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.325109] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.333485] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.340348] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.340352] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.340369] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.340379] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.352370] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.360744] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.367614] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.367618] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.367626] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.367634] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.379409] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.387778] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.394604] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.394608] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.394612] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.394619] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.406492] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.414974] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.421846] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.421850] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.421854] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.421874] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.433695] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.442071] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.448925] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.448929] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.448933] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.448955] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.460729] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.469186] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.476023] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.476027] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.476031] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.476053] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.487836] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.496259] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.503071] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.503075] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.503079] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.503100] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.514957] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.523366] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.530221] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.530225] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.530266] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.530305] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.542071] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.550464] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.557307] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.557311] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.557316] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.557336] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.569134] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.577559] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.584409] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.584413] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.584417] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.584424] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.596198] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.604562] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.611650] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.611671] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.611675] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.611682] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.623467] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.631926] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.638775] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.638779] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.638783] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.638790] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.650575] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.658985] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.665836] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.665840] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.665844] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.665851] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.677658] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.686031] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.692878] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.692882] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.692886] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.692893] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.704648] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.713060] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.719875] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.719879] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.719883] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.719890] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.731705] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.740122] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.746957] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.746961] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.746965] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.746972] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.758742] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.767148] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.773962] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.773966] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.773969] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.773977] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.785740] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.794166] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.800994] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.801011] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.801015] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.801022] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.812789] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.821157] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.827986] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.827990] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.827994] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.828002] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.839790] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.848162] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.854994] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.854998] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.855002] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.855010] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.866786] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.875176] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.881986] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.881990] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.881994] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.882001] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.893770] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.902140] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.908969] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.908973] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.908976] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.908983] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.920819] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.929479] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.936323] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.936328] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.936333] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.936341] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.948142] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.956519] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.963379] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.963384] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.963388] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.963396] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 48.975161] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 48.983560] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 48.990382] pcieport 0000:00:01.0: broadcast error_detected message
[ 48.990386] pcieport 0000:00:01.0: AER: Device recovery failed
[ 48.990390] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 48.990398] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.002260] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.010642] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.017455] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.017459] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.017463] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.017471] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.029226] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.037608] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.044475] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.044479] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.044483] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.044494] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.056593] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.064955] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.071753] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.071757] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.071761] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.071769] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.083508] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.091861] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.098680] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.098684] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.098688] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.098696] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.110459] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.118834] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.125653] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.125657] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.125661] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.125669] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.137438] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.145811] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.152629] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.152633] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.152637] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.152645] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.164429] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.172790] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.179637] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.179641] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.179646] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.179654] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.191411] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.200983] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.207785] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.207789] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.207793] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.207801] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.219539] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.227918] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.234717] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.234721] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.234725] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 49.234733] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 49.246470] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 49.254825] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 49.261638] pcieport 0000:00:01.0: broadcast error_detected message
[ 49.261642] pcieport 0000:00:01.0: AER: Device recovery failed
[ 49.261646] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.261656] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Transmitter ID)
[ 49.272133] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=000011c1/00002000
[ 49.280535] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 49.286659] pcieport 0000:00:01.0: [ 6] Bad TLP
[ 49.292766] pcieport 0000:00:01.0: [ 7] Bad DLLP
[ 49.298865] pcieport 0000:00:01.0: [ 8] RELAY_NUM Rollover
[ 49.304968] pcieport 0000:00:01.0: [12] Replay Timer Timeout
[ 49.311070] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311079] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311083] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311090] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311093] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311101] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311104] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311113] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311118] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311127] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311136] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311145] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311148] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311155] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311158] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311165] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311169] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311176] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311179] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311187] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311192] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311200] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311204] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311212] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311215] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311222] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311225] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311233] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311236] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311244] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311249] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311257] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311260] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311267] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311270] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311277] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311281] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311289] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311293] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311300] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311304] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311312] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311315] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311322] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311326] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311333] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311336] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311344] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311347] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311355] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311359] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311367] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311372] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311379] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311382] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311390] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311395] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311402] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311406] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311414] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311418] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311425] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311429] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311437] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311442] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311449] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311453] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311460] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311465] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311472] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311476] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311484] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311489] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311495] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311500] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311507] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311512] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311519] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311523] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311531] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311535] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311542] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311546] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311554] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311558] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311565] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311569] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311577] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311581] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311589] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311593] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311600] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311604] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311613] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311616] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311622] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311625] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311633] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311636] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311645] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311648] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311655] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311659] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311666] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311669] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311676] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311679] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 49.311686] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311689] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311697] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311700] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 49.311707] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311710] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311717] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311720] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311727] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311730] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311737] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311740] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311747] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311751] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311757] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311760] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311767] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311770] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311777] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311780] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311787] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311790] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311797] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311800] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311808] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311811] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311818] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311821] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311827] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311831] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311838] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311841] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311848] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311851] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311858] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311861] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311868] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311871] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311878] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311880] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311887] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311890] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311897] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311900] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311907] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311910] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311917] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311920] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311927] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311930] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311937] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311940] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311947] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311950] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311957] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311960] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311967] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311970] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311977] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311980] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311986] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311989] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.311996] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.311999] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.312006] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.312009] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.312016] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.312018] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.312025] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.312028] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.312035] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.312038] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.312045] pcieport 0000:00:01.0: can’t find device of ID0010
[ 49.312048] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 49.312054] pcieport 0000:00:01.0: can’t find device of ID0010
[ 52.751746] l4tbr0: port 1(rndis0) entered blocking state
[ 52.751751] l4tbr0: port 1(rndis0) entered forwarding state
[ 52.752399] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 52.752416] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
sudo rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
There is no wifi in rfkill and lots of AER error. Are you able to see the device in lspci?
Have you tried any other m.2 device?
lpsci detected the device. I have changed the WiFi board with a new one that I just received and now it works fine. I will monitor for some days and come back to you if I have further issues
