I recently installed Jetpack 4.4 from a Jetson Xavier NX SOM with a B01 Nano Carrier and everything appears except the wifi does not want to enable, the bluetooth appears to be enabled on the same card. The driver appears to load but I am unable to enable the radio on the Intel 8265 (This previously worked on the a Jetson Nano running on an A01 carrier).
cat /etc/nv_tegra_release
R32 (release), REVISION: 4.2, GCID: 20074772, BOARD: t186ref, EABI: aarch64, DATE: Thu Apr 9 01:26:40 UTC 2020
$ dmesg|grep iwlwifi
[ 6.184937] iwlwifi 0005:01:00.0: enabling device (0000 → 0002)
[ 6.197543] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 6.197797] iwlwifi 0005:01:00.0: Falling back to user helper
[ 9.686449] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 9.686657] iwlwifi 0005:01:00.0: Falling back to user helper
[ 10.443593] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 10.443789] iwlwifi 0005:01:00.0: Falling back to user helper
[ 10.509974] iwlwifi 0005:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 10.510167] iwlwifi 0005:01:00.0: Falling back to user helper
[ 10.524498] iwlwifi 0005:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 10.569204] iwlwifi 0005:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 10.576547] iwlwifi 0005:01:00.0: L1 Disabled - LTR Enabled
[ 10.579501] iwlwifi 0005:01:00.0: L1 Disabled - LTR Enabled
[ 10.634885] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 10.635779] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
1 wlan phy0 unblocked blocked
Hi zanyfool,
I found this error too, and the /var/log/syslog shows rfkill blocked the wlan0, but I haven’t found solution now.
/var/log/syslog
nx kernel: [ 7.152622] iwlwifi 0004:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
nx kernel: [ 7.156735] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
nx kernel: [ 7.157490] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
nx bluetoothd[6080]: src/rfkill.c:rfkill_event() RFKILL event idx 1 type 1 op 0 soft 0 hard 1
nx kernel: [ 7.211363] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
nx kernel: [ 7.212333] thermal thermal_zone6: failed to read out thermal zone (-5)
nx kernel: [ 7.212497] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
nx NetworkManager[4492]: <info> [1588221565.3954] wifi-nl80211: (wlan0): using nl80211 for WiFi device control
nx NetworkManager[4492]: <info> [1588221565.3967] device (wlan0): driver supports Access Point (AP) mode
nx systemd-udevd[6168]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
nx NetworkManager[4492]: <info> [1588221565.4095] manager: (wlan0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/7)
nx NetworkManager[4492]: <info> [1588221565.4155] rfkill1: found WiFi radio killswitch (at /sys/devices/14160000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
nx NetworkManager[4492]: <info> [1588221565.4170] manager: rfkill: WiFi now disabled by radio killswitch
nx NetworkManager[4492]: <info> [1588221565.4271] supplicant: wpa_supplicant running
nx NetworkManager[4492]: <info> [1588221565.4529] devices added (path: /sys/devices/14160000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/net/wlan0, iface: wlan0)
nx NetworkManager[4492]: <info> [1588221565.4530] device added (path: /sys/devices/14160000.pcie/pci0004:00/0004:00:00.0/0004:01:00.0/net/wlan0, iface: wlan0): no ifupdown configuration found.
nx NetworkManager[4492]: <info> [1588221565.4537] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
nx kernel: [ 7.276007] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
nvidia@nx:/usr/sbin$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
3: phy2: Wireless LAN
Soft blocked: no
Hard blocked: yes
This issue is duplicated with this one. We are still checking.
Intel Dual Band Wireless-AC 8265 module did not work on NX by default, as we test it. ( the module works well on Nano.)
Does NX (Jetpack 4.4) support Intel Dual Band Wireless-AC 8265?
If yes, what should we do to make it work?
If not, is there any patch or document to make it work?
Thank you,
Could you guys also share your full dmesg?
Hi WayneWWW,
I have uploaded Xaveir NX with Intel 8265 WIFI/BT module dmesg log.
nx.intel8265.wifi.failed.0504.log (62.4 KB)
Thanks for sharing. I can confirm it is duplicated with the link I posted.
Will update once we find the cause.
Please try this patch
diff --git a/common/tegra194-fixed-regulator-p3668.dtsi b/common/tegra194-fixed-regulator-p3668.dtsi
index 6fb7fe17718d..747973e05485 100644
--- a/common/tegra194-fixed-regulator-p3668.dtsi
+++ b/common/tegra194-fixed-regulator-p3668.dtsi
@@ -51,7 +51,7 @@
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
- gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 2) GPIO_ACTIVE_HIGH>;
+ gpio = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 2) GPIO_ACTIVE_LOW>;
- enable-active-high;
+ regulator-boot-on;
diff --git a/common/tegra194-p3668-common.dtsi b/common/tegra194-p3668-common.dtsi
index cf1195d2ea72..d4824d44d84e 100644
--- a/common/tegra194-p3668-common.dtsi
+++ b/common/tegra194-p3668-common.dtsi
@@ -133,7 +133,6 @@
usb2-2 {
mode = "host";
- vbus-supply = <&p3509_vdd_usb2_5v>;
status = "okay";
usb3-2 {
The patch didn’t work for me. It is possible I didn’t apply it correctly.
I did try the following and was able to enable the wifi.
I modified (1) removed from common/tegra194-fixed-regulator-p3668.dtsi:
And (2) modified:
hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-platforms to replace wifi-enable with:
gpio@c2f0000 {
wifi-disable {
gpio-hog;
output-low;
gpios = <TEGRA194_AON_GPIO(CC, 2) 0>;
label = "wifi-disable";
status = "okay";
After these changes, the wifi card was enabled at boot.
Hi zanyfool ,
I don’t think you need to remove the original wifi-enable pin. As you can see, they are different gpio pins.
Also, could you try this patch too?
index 6fb7fe17718d..1a9ae738ac3e 100644
@@ -51,7 +51,8 @@
+ enable-at-boot;
@@ -133,7 +133,6 @@
usb2-2 {
mode = "host";
status = "okay";
usb3-2 {
Hi WayneWWW,
I have tried your last patch, it doesn’t work. I modified as below and Intel8265 works fine.
--- a/l4t-r32.4.2.src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-fixed-regulator-p3668.dtsi
+++ b/l4t-r32.4.2.src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-fixed-regulator-p3668.dtsi
@@ -50,8 +50,25 @@
regulator-name = "vdd-usb2-5v";
+ enable-active-low;
--- a/l4t-r32.4.2.src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3668-common.dtsi
+++ b/l4t-r32.4.2.src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3668-common.dtsi
@@ -296,6 +334,13 @@
label = "pex_refclk_sel_high";
status = "disabled";
+ wifi-disable {
+ gpio-hog;
+ output-low;
+ gpios = <TEGRA194_AON_GPIO(CC, 2) 0>;
+ label = "wifi-disable";
+ status = "okay";
Hi Ciya.Jiang,
Is it necessary to set below part? I think the second part you’ve done in tegra194-p3668-common.dtsi should work.
Could you help verify?
@@ -50,8 +50,25 @@
}; **This part may not needed**
Hi WayneWWW,
This part is needed, but “enable-active-low;” is not needed.
@@ -50,8 +50,25 @@
}; **This part must needed**
Hi Ciya.Jiang ,
It seems
and
are a conflict. Because the “0” in the second case is set it back to GPIO_ACTIVE_HIGH again.
Anyway, I will check it.
At least I can confirm the solution works . I made the patch with both parts (and with enable-active-low;) and it works fine for me . Thank you so much for the solutions. you made my day. :)
Also want to ask if anyone has bluetooth issue here after apply the patch above?
