Command output:
dmesg --follow
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4255) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Oct 16 12:25:00 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2033152
[ 0.000000] DMA zone: 7192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 460288 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd06000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2001384
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29060(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7192436K/8132608K available (15294K kernel code, 2936K rwdata, 6644K rodata, 8576K init, 611K bss, 186508K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13e008 ( 2937 KB)
[ 0.000000] .bss : 0xffffff800a13e008 - 0xffffff800a1d6f7c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000807] Console: colour dummy device 80x25
[ 0.000819] console [tty0] enabled
[ 0.000827] bootconsole [tegra_comb_uart0] disabled
[ 0.000842] kmemleak: Kernel memory leak detector disabled
[ 0.000860] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000876] pid_max: default: 32768 minimum: 301
[ 0.001954] Security Framework initialized
[ 0.002534] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002545] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004142] ftrace: allocating 47119 entries in 185 pages
[ 0.400401] sched-energy: Sched-energy-costs installed from DT
[ 0.400420] ASID allocator initialised with 65536 entries
[ 0.435537] tegra-id: chipid=21917.
[ 0.435549] tegra-id: opt_subrevision=1.
[ 0.435576] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.435601] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.435611] DTB Build time: Oct 16 2020 12:31:12
[ 0.483672] CPU1: Booted secondary processor [4e0f0040]
[ 0.515740] CPU2: Booted secondary processor [4e0f0040]
[ 0.547837] CPU3: Booted secondary processor [4e0f0040]
[ 0.580094] CPU4: Booted secondary processor [4e0f0040]
[ 0.612188] CPU5: Booted secondary processor [4e0f0040]
[ 0.612438] Brought up 6 CPUs
[ 0.612448] SMP: Total of 6 processors activated.
[ 0.612457] CPU features: detected feature: Privileged Access Never
[ 0.612463] CPU features: detected feature: LSE atomic instructions
[ 0.612501] CPU features: detected feature: User Access Override
[ 0.612507] CPU features: detected feature: 32-bit EL0 Support
[ 0.613934] CPU: All CPU(s) started at EL2
[ 0.614001] alternatives: patching kernel code
[ 0.620362] devtmpfs: initialized
[ 0.656756] Initilizing CustomIPI irq domain
[ 0.657017] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.657031] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.666979] pinctrl core: initialized pinctrl subsystem
[ 0.667191] OS set in device tree is not L4T.
[ 0.667478] regulator-dummy: no parameters
[ 0.667725] Initializing plugin-manager
[ 0.667773] Plugin module not found
[ 0.667819] Plugin-manager status disabled
[ 0.669027] NET: Registered protocol family 16
[ 0.670143] pstore: using zlib compression
[ 0.670168] console [pstore-1] enabled
[ 0.670176] pstore: Registered ramoops as persistent store backend
[ 0.670185] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.682868] cpuidle: using governor menu
[ 0.683994] bpmp: waiting for handshake
[ 0.684007] bpmp: handshake completed
[ 0.684028] bpmp: synchronizing channels
[ 0.684039] bpmp: channels synchronized
[ 0.684048] bpmp: mail init ok
[ 0.686525] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.686715] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.686722] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.686728] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.686734] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.686741] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.686772] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.686781] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.686787] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.686794] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.686800] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.689603] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.689636] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.692318] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.693405] tegra_aon_clk_init: ok
[ 0.693420] Registering BPMP clocks…
[ 0.693532] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.694128] Serial: AMBA PL011 UART driver
[ 0.694276] tegra_powergate_init: DONE
[ 0.694376] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.694391] DTB Build time: Oct 16 2020 12:31:12
[ 0.696947] Tegra reboot handler registered.
[ 0.703725] iommu: Adding device 14160000.pcie to group 0
[ 0.704300] iommu: Adding device 141a0000.pcie to group 1
[ 0.705500] iommu: Adding device 2490000.ether_qos to group 2
[ 0.706154] iommu: Adding device 3100000.serial to group 3
[ 0.706592] iommu: Adding device 3110000.serial to group 4
[ 0.706952] iommu: Adding device 3140000.serial to group 5
[ 0.707507] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.707724] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.707747] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.707767] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.707775] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.707819] tegra-pmc: PMC Prod config success
[ 0.707996] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.708009] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.708306] iommu: Adding device 3400000.sdhci to group 6
[ 0.708751] iommu: Adding device 3210000.spi to group 7
[ 0.709097] iommu: Adding device 3230000.spi to group 8
[ 0.709433] iommu: Adding device 3270000.spi to group 9
[ 0.710346] iommu: Adding device 3160000.i2c to group 10
[ 0.710685] iommu: Adding device c240000.i2c to group 11
[ 0.711056] iommu: Adding device 3180000.i2c to group 12
[ 0.711486] iommu: Adding device 3190000.i2c to group 13
[ 0.711909] iommu: Adding device 31b0000.i2c to group 14
[ 0.712292] iommu: Adding device 31c0000.i2c to group 15
[ 0.712894] iommu: Adding device c250000.i2c to group 16
[ 0.713261] iommu: Adding device 31e0000.i2c to group 17
[ 0.713963] iommu: Adding device sound to group 18
[ 0.714432] iommu: Adding device 3510000.hda to group 19
[ 0.714936] iommu: Adding device bc00000.rtcpu to group 20
[ 0.716589] iommu: Adding device 13e10000.host1x to group 21
[ 0.716977] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.717299] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.717649] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.717973] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.718297] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.718759] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.719102] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.719453] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.719893] iommu: Adding device 15340000.vic to group 30
[ 0.720216] iommu: Adding device 15380000.nvjpg to group 31
[ 0.720448] iommu: Adding device 15500000.tsec to group 32
[ 0.720690] iommu: Adding device 15100000.tsecb to group 33
[ 0.720940] iommu: Adding device 15480000.nvdec to group 34
[ 0.721179] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.721427] iommu: Adding device 154c0000.nvenc to group 36
[ 0.721662] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.722041] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.722413] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.722898] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.726949] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.727062] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.727848] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.727921] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.729398] iommu: Adding device 15c10000.vi to group 42
[ 0.729575] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.729948] iommu: Adding device 14800000.isp to group 43
[ 0.730868] iommu: Adding device 16000000.pva0 to group 44
[ 0.731365] iommu: Adding device 16800000.pva1 to group 45
[ 0.731728] iommu: Adding device 15810000.se to group 46
[ 0.732092] iommu: Adding device 15820000.se to group 47
[ 0.732350] iommu: Adding device 15830000.se to group 48
[ 0.732651] iommu: Adding device 15840000.se to group 49
[ 0.732884] iommu: Adding device c1a0000.aon to group 50
[ 0.734575] iommu: Adding device d000000.bpmp to group 51
[ 0.734881] bpmp: ping status is 0
[ 0.735015] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.738386] bpmp d000000.bpmp: probe ok
[ 0.739645] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.740039] iommu: Adding device smmu_test to group 52
[ 0.741212] mc: mapped MMIO address: 0xffffff800a590000 → 0x2c10000
[ 0.741238] mc: mapped MMIO address: 0xffffff800a5b0000 → 0x2c20000
[ 0.741429] mc: mapped MMIO address: 0xffffff800a5d0000 → 0x2c30000
[ 0.741489] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c40000
[ 0.741514] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c50000
[ 0.741548] mc: mapped MMIO address: 0xffffff800b010000 → 0x2b80000
[ 0.741576] mc: mapped MMIO address: 0xffffff800b030000 → 0x2b90000
[ 0.741607] mc: mapped MMIO address: 0xffffff800b050000 → 0x2ba0000
[ 0.741628] mc: mapped MMIO address: 0xffffff800b070000 → 0x2bb0000
[ 0.741648] mc: mapped MMIO address: 0xffffff800b090000 → 0x1700000
[ 0.741670] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1710000
[ 0.741689] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1720000
[ 0.741709] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1730000
[ 0.741727] mc: mapped MMIO address: 0xffffff800b110000 → 0x1740000
[ 0.741762] mc: mapped MMIO address: 0xffffff800b130000 → 0x1750000
[ 0.741781] mc: mapped MMIO address: 0xffffff800b150000 → 0x1760000
[ 0.741802] mc: mapped MMIO address: 0xffffff800b170000 → 0x1770000
[ 0.741878] mc-err: mcerr ops are set to t19x
[ 0.747330] iommu: Adding device 2600000.dma to group 53
[ 0.751746] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.752932] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.752971] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.753008] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.753243] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.758864] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.758927] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.758964] GPIO line 266 (w-disable1) hogged as output/high
[ 0.758995] GPIO line 264 (w-disable2) hogged as output/high
[ 0.759279] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.761074] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.761088] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.761680] iommu: Adding device 3550000.xudc to group 54
[ 0.762325] iommu: Adding device 3610000.xhci to group 55
[ 0.764098] arm64_ras arm64_ras: probed
[ 0.764498] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.764543] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.764621] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.764696] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.764759] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.764810] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.764988] carmel_ras_enable: RAS enabled on cpu0
[ 0.765159] carmel_ras_enable: RAS enabled on cpu1
[ 0.765363] carmel_ras_enable: RAS enabled on cpu2
[ 0.765551] carmel_ras_enable: RAS enabled on cpu3
[ 0.765735] carmel_ras_enable: RAS enabled on cpu4
[ 0.765909] carmel_ras_enable: RAS enabled on cpu5
[ 0.765968] carmel_ras carmel_ras: probed
[ 0.766986] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.767443] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.768192] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.768921] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.769698] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.770055] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.771166] vdd-ac-bat: 5000 mV
[ 0.771544] vdd-sdmmc1-sw: 3300 mV
[ 0.771827] vdd-1v8-sd: 1800 mV
[ 0.772089] vdd-3v3-cvb: 3300 mV
[ 0.772345] vdd-1v8-cvb: 1800 mV
[ 0.772671] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.772711] vdd-epb-1v0: 1000 mV
[ 0.773032] avdd-cam-2v8: 2800 mV
[ 0.773331] vdd-fan: 5000 mV
[ 0.773593] vdd-hdmi-5v0: 5000 mV
[ 0.773848] vdd_sys_en: 1200 mV
[ 0.808115] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.812936] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.813255] SCSI subsystem initialized
[ 0.813477] libata version 3.00 loaded.
[ 0.813677] usbcore: registered new interface driver usbfs
[ 0.813731] usbcore: registered new interface driver hub
[ 0.813831] usbcore: registered new device driver usb
[ 0.825108] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.827977] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.835921] vdd-1v0: at 1000 mV
[ 0.839979] vdd-1v8-hs: at 1800 mV
[ 0.843965] vdd-1v8-ls: at 1800 mV
[ 0.847983] vdd-1v8-ao: at 1800 mV
[ 0.852001] vddio-ddr-1v1: at 1100 mV
[ 0.855775] vdd-rtc: at 800 mV
[ 0.856989] spmic-ldo1: at 2375 mV
[ 0.863818] vdd-ao-3v3: at 3300 mV
[ 0.871879] vddio-emmc-3v3: at 3300 mV
[ 0.873158] spmic-ldo4: at 1587 mV
[ 0.879886] vdd-usb-3v3: at 3300 mV
[ 0.887946] vddio-sdmmc1-3v3: at 3300 mV
[ 0.891948] vdd-csi-1v2: at 1200 mV
[ 0.893461] spmic-ldo8: at 1800 mV
[ 0.898266] GPIO line 246 (gpio_default) hogged as output/high
[ 0.899692] GPIO line 247 (gpio_default) hogged as output/high
[ 0.900107] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.900490] max77620 4-003c: max77620 probe successful
[ 0.901135] media: Linux media interface: v0.10
[ 0.901246] Linux video capture interface: v2.00
[ 0.902714] pps_core: LinuxPPS API ver. 1 registered
[ 0.902721] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.902791] PTP clock support registered
[ 0.903122] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.903359] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.903388] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.906213] trusty trusty: trusty version: Built: 11:31:49 Jun 14 2021
[ 0.906274] trusty trusty: selected api version: 3 (requested 3)
[ 0.907723] Advanced Linux Sound Architecture Driver Initialized.
[ 0.908267] Bluetooth: Core ver 2.22
[ 0.908307] NET: Registered protocol family 31
[ 0.908313] Bluetooth: HCI device and connection manager initialized
[ 0.908324] Bluetooth: HCI socket layer initialized
[ 0.908333] Bluetooth: L2CAP socket layer initialized
[ 0.908357] Bluetooth: SCO socket layer initialized
[ 0.911380] camchar: rtcpu character device driver loaded
[ 0.911906] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.912053] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.913216] clocksource: Switched to clocksource arch_sys_counter
[ 0.955016] VFS: Disk quotas dquot_6.6.0
[ 0.955105] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.955415] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.956594] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.956669] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.956919] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.956927] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.956940] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.956948] nvmap_page_pool_init: Total RAM pages: 1986525
[ 0.956954] nvmap_page_pool_init: nvmap page pool size: 248315 pages (969 MB)
[ 0.957109] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.957633] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.959417] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 0.971506] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.971693] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.971869] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 0.972054] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 0.972251] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.973583] la/ptsa driver initialized.
[ 0.973909] NET: Registered protocol family 2
[ 0.974751] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.975146] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.975752] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.975799] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.975920] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.976380] NET: Registered protocol family 1
[ 0.977021] RPC: Registered named UNIX socket transport module.
[ 0.977027] RPC: Registered udp transport module.
[ 0.977032] RPC: Registered tcp transport module.
[ 0.977036] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.977046] PCI: CLS 0 bytes, default 64
[ 0.977348] Trying to unpack rootfs image as initramfs…
[ 1.168342] Freeing initrd memory: 5432K
[ 1.182576] random: fast init done
[ 1.186938] host1x 13e10000.host1x: initialized
[ 1.188447] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.193131] audit: initializing netlink subsys (disabled)
[ 1.193180] audit: type=2000 audit(0.816:1): initialized
[ 1.193872] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.201714] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.202938] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.203490] 9p: Installing v9fs 9p2000 file system support
[ 1.207983] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.208144] io scheduler noop registered
[ 1.208355] io scheduler cfq registered (default)
[ 1.211836] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.245942] iommu: Adding device 2993000.adsp to group 56
[ 1.352597] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.353559] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.366208] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.366611] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.367153] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.367575] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.367959] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.371069] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.371259] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.373899] tsec 15500000.tsec: initialized
[ 1.375583] tsec 15100000.tsecb: initialized
[ 1.379241] nvdec 15480000.nvdec: initialized
[ 1.381868] nvdec 15140000.nvdec1: initialized
[ 1.387274] falcon 15340000.vic: initialized
[ 1.389055] falcon 15380000.nvjpg: initialized
[ 1.391050] falcon 154c0000.nvenc: initialized
[ 1.392977] falcon 15a80000.nvenc1: initialized
[ 1.396998] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.399187] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.400711] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.402142] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.403627] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.405023] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.406386] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.407708] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.411335] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.416791] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.417193] scare-pigeon 14b00000.isp-thi: initialized
[ 1.423194] pva 16000000.pva0: initialized
[ 1.429041] pva 16800000.pva1: initialized
[ 1.433988] nvdla 15880000.nvdla0: initialized
[ 1.438801] nvdla 158c0000.nvdla1: initialized
[ 1.440299] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.440313] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.440362] tegradccommon 15200000.dc_common: dma mapping done
[ 1.440852] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.440884] generic_infoframe_type: 0x87
[ 1.440953] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.440986] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.444481] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.444490] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.444496] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.444719] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.444730] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.447418] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.447428] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.450490] tegradc 15200000.nvdisplay: probed
[ 1.451138] Console: switching to colour frame buffer device 80x30
[ 1.451177] tegradc 15200000.nvdisplay: fb registered
[ 1.451437] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.451841] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.451872] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.451946] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.451979] tegradc 15210000.nvdisplay: Display dc.ffffff800be10000 registered with id=1
[ 1.452156] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.452166] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.461175] tegradc 15210000.nvdisplay: probed
[ 1.461509] tegradc 15210000.nvdisplay: fb registered
[ 1.464985] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.464993] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.465005] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.465017] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.465032] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.465037] Extcon DP: HPD disabled
[ 1.465041] hpd: hpd_switch 0
[ 1.465047] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.465058] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.465067] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.465389] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.465402] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.465660] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.465772] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.465915] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.465924] tegra_cec 3960000.tegra_cec: probed
[ 1.474364] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.474950] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.474959] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.475241] kfuse 3830000.kfuse: initialized
[ 1.480969] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.483259] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.484394] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.485097] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.486334] console [ttyTCU0] enabled
[ 1.486620] [drm] Initialized
[ 1.497699] brd: module loaded
[ 1.502512] loop: module loaded
[ 1.502596] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.502754] tegra_profiler: auth: init
[ 1.503272] THERMAL EST: found 3 subdevs
[ 1.503280] THERMAL EST num_resources: 0
[ 1.503294] [THERMAL EST subdev 0]
[ 1.503302] [THERMAL EST subdev 1]
[ 1.503309] [THERMAL EST subdev 2]
[ 1.503327] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.503601] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.503606] THERMAL EST: thz register success.
[ 1.503748] THERMAL EST: end of probe, return err: 0
[ 1.504333] sd: No Scsi addr parsed to reserve index
[ 1.504367] hisi_sas: driver version v1.6
[ 1.513817] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.513826] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.513835] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.514146] 1 ofpart partitions found on MTD device spi6.0
[ 1.514153] Creating 1 MTD partitions on “spi6.0”:
[ 1.514170] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.516190] libphy: Fixed MDIO Bus: probed
[ 1.516746] tun: Universal TUN/TAP device driver, 1.6
[ 1.516751] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.517571] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.517577] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.517616] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.517620] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.517653] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.517658] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.517698] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.517703] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.761146] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 15 e9 a8
[ 1.761394] libphy: dwc_phy: probed
[ 1.763646] PPP generic driver version 2.4.2
[ 1.764045] PPP BSD Compression module registered
[ 1.764052] PPP Deflate Compression module registered
[ 1.764072] PPP MPPE Compression module registered
[ 1.764078] NET: Registered protocol family 24
[ 1.764122] usbcore: registered new interface driver r8152
[ 1.764153] usbcore: registered new interface driver asix
[ 1.764186] usbcore: registered new interface driver ax88179_178a
[ 1.764212] usbcore: registered new interface driver cdc_ether
[ 1.764237] usbcore: registered new interface driver net1080
[ 1.764264] usbcore: registered new interface driver cdc_subset
[ 1.764288] usbcore: registered new interface driver zaurus
[ 1.764324] usbcore: registered new interface driver cdc_ncm
[ 1.764741] VFIO - User Level meta-driver version: 0.3
[ 1.765971] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.765993] ehci-pci: EHCI PCI platform driver
[ 1.766034] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.766045] ohci-pci: OHCI PCI platform driver
[ 1.766072] ohci-platform: OHCI generic platform driver
[ 1.770856] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.772711] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4cccc00 id
[ 1.773317] usbcore: registered new interface driver uas
[ 1.773362] usbcore: registered new interface driver usb-storage
[ 1.773467] usbcore: registered new interface driver usbserial
[ 1.775093] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.775128] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.775147] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.775882] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.775926] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 1.776142] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.776150] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.776157] usb usb1: Product: xHCI Host Controller
[ 1.776163] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.776170] usb usb1: SerialNumber: 3610000.xhci
[ 1.776574] hub 1-0:1.0: USB hub found
[ 1.776622] hub 1-0:1.0: 4 ports detected
[ 1.777179] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.777192] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.777203] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.777526] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.777534] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.777540] usb usb2: Product: xHCI Host Controller
[ 1.777547] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.777553] usb usb2: SerialNumber: 3610000.xhci
[ 1.778030] hub 2-0:1.0: USB hub found
[ 1.778073] hub 2-0:1.0: 4 ports detected
[ 1.778868] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.778958] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.779905] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 1.779927] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 1.780135] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 1.780145] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.780766] mousedev: PS/2 mouse device common for all mice
[ 1.780874] usbcore: registered new interface driver xpad
[ 1.912428] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.914056] Wake73 for irq=42
[ 1.915294] rtc rtc1: alarm rtc device
[ 1.915311] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.915334] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.915473] i2c /dev entries driver
[ 1.917609] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.917953] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.917961] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.918422] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.941865] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 1.941928] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.942155] imx219 9-0010: board setup failed
[ 1.942409] imx219: probe of 9-0010 failed with error -121
[ 1.942864] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.966122] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 1.966173] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.966382] imx219 10-0010: board setup failed
[ 1.966629] imx219: probe of 10-0010 failed with error -121
[ 1.967624] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 1.974513] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 1.978692] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 1.978715] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 1.978722] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 1.978804] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 1.978883] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 1.978890] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 1.979153] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 1.979204] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 1.979213] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 1.979508] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 1.979562] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 1.979570] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 1.979916] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 1.980005] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 1.980012] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 1.980272] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 1.980759] FAN dev name: pwm-fan
[ 1.980806] FAN:gpio request success.
[ 1.980817] FAN: can’t find tach_gpio
[ 1.980837] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 1.980875] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 1.981056] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.981063] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.981668] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.981676] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 1.981685] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 1.981691] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 1.981697] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.981704] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.981710] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.981717] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.981723] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.981730] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.982722] device-mapper: uevent: version 1.0.3
[ 1.983134] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.986618] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 1.987623] cpuidle: Initializing cpuidle driver
[ 1.988564] sdhci: Secure Digital Host Controller Interface driver
[ 1.988570] sdhci: Copyright(c) Pierre Ossman
[ 1.988575] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.988882] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.989890] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.991630] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[ 1.996049] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.997101] tegra-se-nvhost 15810000.se: initialized
[ 1.998453] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.999078] tegra-se-nvhost 15820000.se: initialized
[ 2.000303] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.000925] tegra-se-nvhost 15830000.se: initialized
[ 2.001711] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.002368] tegra-se-nvhost 15840000.se: initialized
[ 2.003381] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.003625] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.004997] usbcore: registered new interface driver usbhid
[ 2.005002] usbhid: USB HID core driver
[ 2.009004] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.010116] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.010546] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.011282] denver_knobs_init:MTS_VERSION:51035886
[ 2.011438] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.012087] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.012474] t19x_cache tegra-cache: probed
[ 2.014761] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.014769] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.015395] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.015758] PLL_AON clock registered
[ 2.017579] Clocks initialized successfully
[ 2.019154] nvpmodel: initialized successfully
[ 2.020386] trusty-virtio trusty:virtio: initializing
[ 2.020620] trusty_ipc virtio0: vring0: va¶ ffffffc1f2bbc000(0) qsz 32 notifyid 1
[ 2.020633] trusty_ipc virtio0: vring1: va¶ ffffffc1f2bbe000(0) qsz 32 notifyid 2
[ 2.020763] trusty-virtio trusty:virtio: initializing done
[ 2.021079] trusty_ipc virtio0: is online
[ 2.021735] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.022078] usbcore: registered new interface driver snd-usb-audio
[ 2.034696] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.034933] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.035142] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.035401] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.045348] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.045411] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.101249] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.129816] OPE platform probe
[ 2.129947] OPE platform probe successful
[ 2.140264] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.140273] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.140279] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.140283] usb 1-2: Manufacturer: Generic
[ 2.141615] hub 1-2:1.0: USB hub found
[ 2.142843] hub 1-2:1.0: 4 ports detected
[ 2.211565] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.211671] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.211777] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.211889] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.211999] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.212106] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.212210] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.212294] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.212374] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.212459] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.212539] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.212625] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.212704] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.212871] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.213000] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.213124] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.213251] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.213339] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.213421] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.213508] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.243208] u32 classifier
[ 2.243214] Actions configured
[ 2.243280] Initializing XFRM netlink socket
[ 2.243818] NET: Registered protocol family 10
[ 2.244569] NET: Registered protocol family 17
[ 2.244583] NET: Registered protocol family 15
[ 2.244637] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.244726] Bluetooth: RFCOMM socket layer initialized
[ 2.244747] Bluetooth: RFCOMM ver 1.11
[ 2.244754] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.244762] Bluetooth: HIDP socket layer initialized
[ 2.244799] 9pnet: Installing 9P2000 support
[ 2.244836] Key type dns_resolver registered
[ 2.245047] Registered cp15_barrier emulation handler
[ 2.245067] Registered setend emulation handler
[ 2.246781] registered taskstats version 1
[ 2.247269] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.248524] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.248546] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.248556] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.248566] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.264984] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.357266] tegra-pcie-dw 14160000.pcie: link is up
[ 2.357561] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.357570] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.357578] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.357584] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.357589] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.357617] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.357792] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.358030] iommu: Adding device 0004:00:00.0 to group 58
[ 2.358397] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.358535] pci 0004:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 2.358540] pci 0004:01:00.0: reg 0x10: [io size 0x0100]
[ 2.358700] pci 0004:01:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit]
[ 2.359436] pci 0004:01:00.0: supports D1 D2
[ 2.359441] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.359758] iommu: Adding device 0004:01:00.0 to group 59
[ 2.375910] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.375916] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.375925] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.376007] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.376035] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.376041] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.376049] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.376067] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.376126] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.376321] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.376326] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.376333] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.376416] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.377929] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.383223] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.383243] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.383251] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.383258] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 2.403389] mmc0: hw tuning done …
[ 2.403422] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[ 2.403910] mmcblk0: mmc0:59b4 ED2S5 119 GiB
[ 2.407441] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.485291] tegra_cec 3960000.tegra_cec: Can’t find physical addresse.
[ 2.485298] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.521249] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.542396] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 2.542402] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.542408] usb 1-3: Product: Bluetooth Radio
[ 2.542411] usb 1-3: Manufacturer: Realtek
[ 2.542416] usb 1-3: SerialNumber: 00e04c000001
[ 2.717248] usb 1-2: usb_suspend_both: status 0
[ 2.896723] tegra-pcie-dw 141a0000.pcie: link is down
[ 2.896834] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.896842] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.896849] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.896855] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.896859] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.896887] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.897064] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.897325] iommu: Adding device 0005:00:00.0 to group 60
[ 2.897574] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.897596] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.897811] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.897818] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.897902] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.898045] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.898088] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 2.898169] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 2.898238] iommu: Removing device 0005:00:00.0 from group 60
[ 2.898262] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 2.899789] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 2.909458] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 2.914707] tegra194-isp5 14800000.isp: initialized
[ 2.921637] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 2.924407] tegra194-vi5 15c10000.vi: initialized
[ 2.928466] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 2.928535] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 2.929358] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.011285] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 3.011607] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.011827] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 3.012060] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 3.012416] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 3.012485] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 3.012710] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 3.012715] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.013849] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 3.014285] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 3.014356] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 3.014480] input: gpio-keys as /devices/gpio-keys/input/input4
[ 3.046284] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:20 UTC (946688420)
[ 3.046749] mmcblk mmc0:59b4: Card claimed for testing.
[ 3.084077] bpmp: mounted debugfs mirror
[ 3.091058] vdd-1v8-sd: disabling
[ 3.091066] vdd-1v8-cvb: disabling
[ 3.091070] vdd-epb-1v0: disabling
[ 3.091073] avdd-cam-2v8: disabling
[ 3.091076] vdd-fan: disabling
[ 3.091080] vdd_sys_en: disabling
[ 3.091090] ALSA device list:
[ 3.091094] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 3.091097] #1: jetson-xaviernx-ape
[ 3.092948] Freeing unused kernel memory: 8576K
[ 3.132288] Root device found: mmcblk0p1
[ 3.133555] Found dev node: /dev/mmcblk0p1
[ 3.175130] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.176022] Rootfs mounted over mmcblk0p1
[ 3.200954] Switching from initrd to actual rootfs
[ 3.394226] systemd[1]: System time before build time, advancing clock.
[ 3.418465] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.423226] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.440457] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.441056] systemd[1]: Detected architecture arm64.
[ 3.447197] systemd[1]: Set hostname to .
[ 3.561752] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.561764] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.703868] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.704159] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.704247] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.704275] systemd[1]: Reached target Swap.
[ 3.704299] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.704322] systemd[1]: Reached target User and Group Name Lookups.
[ 3.704898] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.707758] systemd[1]: Created slice User and Session Slice.
[ 3.782611] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.845494] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.091537] systemd-journald[2311]: Received request to flush runtime journal from PID 1
[ 4.886098] using random self ethernet address
[ 4.886237] using random host ethernet address
[ 4.963288] random: crng init done
[ 4.963408] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.299795] rtl88x2ce 0004:01:00.0: enabling device (0000 → 0003)
[ 5.941752] Wake76 for irq=199
[ 5.941759] Wake77 for irq=199
[ 5.941764] Wake78 for irq=199
[ 5.941768] Wake79 for irq=199
[ 5.941771] Wake80 for irq=199
[ 5.941773] Wake81 for irq=199
[ 5.941776] Wake82 for irq=199
[ 5.941833] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 5.941840] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.270162] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 6.275335] Mass Storage Function, version: 2009/09/11
[ 6.275344] LUN: removable file: (no medium)
[ 6.280754] usbcore: registered new interface driver btusb
[ 6.282425] using random self ethernet address
[ 6.282556] using random host ethernet address
[ 6.301086] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 6.301094] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 6.301097] rtk_btcoex: create workqueue
[ 6.302328] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 6.302427] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 6.302432] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 6.302435] rtk_btusb: patch_add
[ 6.302439] rtk_btusb: auto suspend is disabled
[ 6.302443] rtk_btusb: pid = 0x3549
[ 6.302447] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 6.302457] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 6.303734] rtk_btusb: btusb_probe: done
[ 6.303749] rtk_btusb: btusb_open start
[ 6.303752] rtk_btusb: btusb_open hdev->promisc ==0
[ 6.303754] rtk_btusb: download_patch start
[ 6.303758] rtk_btusb: chip type value: 0x73
[ 6.303761] rtk_btusb: HCI reset.
[ 6.303789] usbcore: registered new interface driver rtk_btusb
[ 6.307226] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 6.307238] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.307243] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 6.307247] usb 2-3: Manufacturer: Generic
[ 6.314510] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 6.314516] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 6.314520] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.314525] rtk_btusb: load_firmware start
[ 6.314528] rtk_btusb: lmp_version = 0x8822
[ 6.314532] rtk_btusb: config filename rtl8822cu_config
[ 6.317905] hub 2-3:1.0: USB hub found
[ 6.319710] hub 2-3:1.0: 4 ports detected
[ 6.390364] rtk_btusb: no bdaddr file /opt/bdaddr
[ 6.390372] rtk_btusb: 55 ab 23 87 00 00
[ 6.390386] rtk_btusb: Config file length 6, new length 6
[ 6.390389] rtk_btusb: fw name is rtl8822cu_fw
[ 6.395977] rndis0: HOST MAC 26:08:2f:b4:6d:70
[ 6.396352] rndis0: MAC 26:08:2f:b4:6d:71
[ 6.396872] usb0: HOST MAC 26:08:2f:b4:6d:72
[ 6.396903] usb0: MAC 26:08:2f:b4:6d:73
[ 6.396930] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.397903] rtk_btusb: This is not 8723a, use new patch style!
[ 6.398061] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 6.399517] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 6.399526] rtk_btusb: load_firmware: New gEVersion 3
[ 6.399530] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 6.399535] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 6.399538] rtk_btusb: fw_version = 0x98a42f7
[ 6.399544] rtk_btusb: number_of_total_patch = 3
[ 6.399548] rtk_btusb: chipID 4
[ 6.399551] rtk_btusb: patch_length 0x55f0
[ 6.399554] rtk_btusb: start_offset 0x00005d00
[ 6.399558] rtk_btusb: Svn version: 21761
[ 6.399562] rtk_btusb: Coexistence: BTCOEX_20190509-0d0d
[ 6.399565] rtk_btusb: buf_len = 0x55f6
[ 6.399579] rtk_btusb: fw: exists, config file: exists
[ 6.399583] rtk_btusb: load_firmware done
[ 6.399605] rtk_btusb: download_data start
[ 6.404397] l4tbr0: port 1(rndis0) entered blocking state
[ 6.404404] l4tbr0: port 1(rndis0) entered disabled state
[ 6.405105] device rndis0 entered promiscuous mode
[ 6.414029] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.420527] l4tbr0: port 2(usb0) entered blocking state
[ 6.420536] l4tbr0: port 2(usb0) entered disabled state
[ 6.420722] device usb0 entered promiscuous mode
[ 6.431647] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.479457] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.479503] Bluetooth: BNEP socket layer initialized
[ 6.512535] rtk_btusb: download_data done
[ 6.512543] rtk_btusb: HCI reset.
[ 6.523520] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[ 6.523529] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[ 6.523532] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.523550] rtk_btusb: Rtk patch end 0
[ 6.523556] rtk_btusb: btusb_open set HCI_RUNNING
[ 6.523588] rtk_btcoex: Open BTCOEX
[ 6.523592] rtk_btusb: btusb_open end
[ 6.525521] rtk_btcoex: BTCOEX hci_rev 0x098a
[ 6.525537] rtk_btcoex: BTCOEX lmp_subver 0x42f7
[ 6.545539] rtk_btusb: btusb_notify: hci0 evt 3
[ 6.793860] android_work: did not send uevent (0 0 (null))
[ 6.826839] android_work: sent uevent USB_STATE=CONNECTED
[ 6.897268] usb 2-3: usb_suspend_both: status 0
[ 6.897466] usb usb2: usb_suspend_both: status 0
[ 7.025458] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 7.384654] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.549849] configfs-gadget gadget: high-speed config #1: c
[ 7.549890] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 7.549908] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 7.549922] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 7.550030] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 7.550045] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 7.550057] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 7.550088] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 7.550150] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 7.550184] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 7.550250] android_work: sent uevent USB_STATE=CONFIGURED
[ 7.698094] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 7.705903] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.706132] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 7.749603] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.044582] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.191629] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.984978] zram: Added device: zram0
[ 8.985851] zram: Added device: zram1
[ 8.986619] zram: Added device: zram2
[ 8.992757] zram: Added device: zram3
[ 8.993583] zram: Added device: zram4
[ 8.998018] zram: Added device: zram5
[ 9.029629] zram0: detected capacity change from 0 to 679264256
[ 9.592017] Adding 663340k swap on /dev/zram0. Priority:5 extents:1 across:663340k SS
[ 9.599746] zram1: detected capacity change from 0 to 679264256
[ 9.613712] Adding 663340k swap on /dev/zram1. Priority:5 extents:1 across:663340k SS
[ 9.616681] zram2: detected capacity change from 0 to 679264256
[ 9.630244] Adding 663340k swap on /dev/zram2. Priority:5 extents:1 across:663340k SS
[ 9.633531] zram3: detected capacity change from 0 to 679264256
[ 9.647212] Adding 663340k swap on /dev/zram3. Priority:5 extents:1 across:663340k SS
[ 9.651070] zram4: detected capacity change from 0 to 679264256
[ 9.664401] Adding 663340k swap on /dev/zram4. Priority:5 extents:1 across:663340k SS
[ 9.667003] zram5: detected capacity change from 0 to 679264256
[ 9.680456] Adding 663340k swap on /dev/zram5. Priority:5 extents:1 across:663340k SS
[ 11.041878] l4tbr0: port 1(rndis0) entered blocking state
[ 11.041889] l4tbr0: port 1(rndis0) entered forwarding state
[ 11.042079] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 11.042129] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 11.162764] Bridge firewalling registered
[ 11.204101] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 11.573942] Netfilter messages via NETLINK v0.30.
[ 11.576877] ctnetlink v0.93: registering with nfnetlink.
[ 11.684284] tegradc 15200000.nvdisplay: blank - powerdown
[ 11.684299] tegradc 15210000.nvdisplay: blank - powerdown
[ 11.742082] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 12.686013] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
