Jetson AGX Xavier with 3rd party carrier board blank screen after initial configuration
I’m testing a 3rd party carrier board with a Jetson AGX Xavier 32GB module. I can flash the module with the 3rd party firmware and I can go through the initial configuration using the GUI over an HDMI connection. However, after the initial configuration, the monitor goes blank instead of displaying the Linux desktop. If I power cycle the board, I see the NVIDIA logo at boot, the initial kernel diagnostics messages, then the screen goes blank. The board is still responsive, and I can still ssh into it. The dmesg output is below. Any suggestions on how to troubleshoot the issue?
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (donmichael@HMECD001406) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Sep 25 10:13:46 IST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069c000
[ 0.000000] Found lut_mem: 00002008@a0696000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 8322045
[ 0.000000] DMA zone: 7152 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 457725 pages, LIFO batch:31
[ 0.000000] Normal zone: 122880 pages used for memmap
[ 0.000000] Normal zone: 7864320 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc7ffc36000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8192013
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0696000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29164(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Memory: 31916908K/33288180K available (15358K kernel code, 2940K rwdata, 6592K rodata, 8576K init, 636K bss, 617608K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009600000 ( 6656 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f008 ( 2941 KB)
[ 0.000000] .bss : 0xffffff800a13f008 - 0xffffff800a1de11c ( 637 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf20000000 ( 512 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc800000000 ( 32768 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001185] Console: colour dummy device 80x25
[ 0.001197] console [tty0] enabled
[ 0.001205] bootconsole [tegra_comb_uart0] disabled
[ 0.001219] kmemleak: Kernel memory leak detector disabled
[ 0.001239] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.001255] pid_max: default: 32768 minimum: 301
[ 0.002323] Security Framework initialized
[ 0.002942] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.002955] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.004973] ftrace: allocating 47367 entries in 186 pages
[ 0.403862] sched-energy: Sched-energy-costs installed from DT
[ 0.403882] ASID allocator initialised with 65536 entries
[ 0.442348] tegra-id: chipid=21917.
[ 0.442360] tegra-id: opt_subrevision=1.
[ 0.442388] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.442423] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000-eCAM130A_CUXVR.dts
[ 0.442433] DTB Build time: Sep 30 2020 12:29:27
[ 0.489912] CPU1: Booted secondary processor [4e0f0040]
[ 0.522079] CPU2: Booted secondary processor [4e0f0040]
[ 0.554170] CPU3: Booted secondary processor [4e0f0040]
[ 0.586427] CPU4: Booted secondary processor [4e0f0040]
[ 0.618503] CPU5: Booted secondary processor [4e0f0040]
[ 0.650829] CPU6: Booted secondary processor [4e0f0040]
[ 0.682931] CPU7: Booted secondary processor [4e0f0040]
[ 0.683205] Brought up 8 CPUs
[ 0.683215] SMP: Total of 8 processors activated.
[ 0.683224] CPU features: detected feature: Privileged Access Never
[ 0.683230] CPU features: detected feature: LSE atomic instructions
[ 0.683236] CPU features: detected feature: User Access Override
[ 0.683242] CPU features: detected feature: 32-bit EL0 Support
[ 0.685129] CPU: All CPU(s) started at EL2
[ 0.685201] alternatives: patching kernel code
[ 0.694474] devtmpfs: initialized
[ 0.756388] Initilizing CustomIPI irq domain
[ 0.756664] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.756679] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.771343] pinctrl core: initialized pinctrl subsystem
[ 0.771614] OS set in device tree is not L4T.
[ 0.771990] regulator-dummy: no parameters
[ 0.772245] Initializing plugin-manager
[ 0.772300] Plugin module not found
[ 0.772331] Plugin-manager status disabled
[ 0.773949] NET: Registered protocol family 16
[ 0.775624] pstore: using zlib compression
[ 0.775643] console [pstore-1] enabled
[ 0.775648] pstore: Registered ramoops as persistent store backend
[ 0.775654] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[ 0.790262] cpuidle: using governor menu
[ 0.791687] bpmp: waiting for handshake
[ 0.791723] bpmp: handshake completed
[ 0.791741] bpmp: synchronizing channels
[ 0.791755] bpmp: channels synchronized
[ 0.791766] bpmp: mail init ok
[ 0.795174] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.795450] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.795456] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.795463] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.795468] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.795474] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.795484] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.795513] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.795520] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.795527] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.795532] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.799392] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e64000)
[ 0.799421] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.802072] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.805240] tegra_aon_clk_init: ok
[ 0.805256] Registering BPMP clocks…
[ 0.805361] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.806294] Serial: AMBA PL011 UART driver
[ 0.806446] tegra_powergate_init: DONE
[ 0.806527] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000-eCAM130A_CUXVR.dts
[ 0.806542] DTB Build time: Sep 30 2020 12:29:27
[ 0.810299] Tegra reboot handler registered.
[ 0.818205] iommu: Adding device 14180000.pcie to group 0
[ 0.818966] iommu: Adding device 14100000.pcie to group 1
[ 0.819662] iommu: Adding device 14140000.pcie to group 2
[ 0.820392] iommu: Adding device 14160000.pcie to group 3
[ 0.821058] iommu: Adding device 141a0000.pcie to group 4
[ 0.822621] iommu: Adding device 2490000.ether_qos to group 5
[ 0.823170] iommu: Adding device 3100000.serial to group 6
[ 0.823731] iommu: Adding device 3110000.serial to group 7
[ 0.824180] iommu: Adding device 3140000.serial to group 8
[ 0.824612] iommu: Adding device c290000.serial to group 9
[ 0.825316] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.825502] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.825525] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.825532] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.825540] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.825590] tegra-pmc: PMC Prod config success
[ 0.825789] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.825802] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.826159] iommu: Adding device 3460000.sdhci to group 10
[ 0.826707] iommu: Adding device 3400000.sdhci to group 11
[ 0.827222] iommu: Adding device 2450000.ufshci to group 12
[ 0.827813] iommu: Adding device 3210000.spi to group 13
[ 0.828475] iommu: Adding device c260000.spi to group 14
[ 0.829636] iommu: Adding device 3160000.i2c to group 15
[ 0.830078] iommu: Adding device c240000.i2c to group 16
[ 0.830532] iommu: Adding device 3180000.i2c to group 17
[ 0.830961] iommu: Adding device 3190000.i2c to group 18
[ 0.831503] iommu: Adding device 31b0000.i2c to group 19
[ 0.831980] iommu: Adding device 31c0000.i2c to group 20
[ 0.832432] iommu: Adding device c250000.i2c to group 21
[ 0.832875] iommu: Adding device 31e0000.i2c to group 22
[ 0.833742] iommu: Adding device sound to group 23
[ 0.834312] iommu: Adding device 3510000.hda to group 24
[ 0.835019] iommu: Adding device bc00000.rtcpu to group 25
[ 0.837211] iommu: Adding device 13e10000.host1x to group 26
[ 0.837683] iommu: Adding device 13e10000.host1x:ctx0 to group 27
[ 0.838075] iommu: Adding device 13e10000.host1x:ctx1 to group 28
[ 0.838498] iommu: Adding device 13e10000.host1x:ctx2 to group 29
[ 0.838977] iommu: Adding device 13e10000.host1x:ctx3 to group 30
[ 0.839447] iommu: Adding device 13e10000.host1x:ctx4 to group 31
[ 0.839896] iommu: Adding device 13e10000.host1x:ctx5 to group 32
[ 0.840330] iommu: Adding device 13e10000.host1x:ctx6 to group 33
[ 0.840778] iommu: Adding device 13e10000.host1x:ctx7 to group 34
[ 0.841352] iommu: Adding device 15340000.vic to group 35
[ 0.841761] iommu: Adding device 15380000.nvjpg to group 36
[ 0.842112] iommu: Adding device 15500000.tsec to group 37
[ 0.842471] iommu: Adding device 15100000.tsecb to group 38
[ 0.842815] iommu: Adding device 15480000.nvdec to group 39
[ 0.843098] iommu: Adding device 15140000.nvdec1 to group 40
[ 0.843395] iommu: Adding device 154c0000.nvenc to group 41
[ 0.843708] iommu: Adding device 15a80000.nvenc1 to group 42
[ 0.844433] iommu: Adding device 15880000.nvdla0 to group 43
[ 0.845036] iommu: Adding device 158c0000.nvdla1 to group 44
[ 0.845966] iommu: Adding device 15200000.nvdisplay to group 45
[ 0.846145] platform 15200000.nvdisplay: IOVA linear map 0x00000000a069c000(800000)
[ 0.846157] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0696000(3000)
[ 0.850084] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.850161] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.850904] iommu: Adding device 15210000.nvdisplay to group 46
[ 0.850963] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.853283] iommu: Adding device 15c10000.vi to group 47
[ 0.853450] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.853845] iommu: Adding device 14800000.isp to group 48
[ 0.854892] iommu: Adding device 16000000.pva0 to group 49
[ 0.855452] iommu: Adding device 16800000.pva1 to group 50
[ 0.855844] iommu: Adding device 15810000.se to group 51
[ 0.856314] iommu: Adding device 15820000.se to group 52
[ 0.856605] iommu: Adding device 15830000.se to group 53
[ 0.856890] iommu: Adding device 15840000.se to group 54
[ 0.857226] iommu: Adding device c1a0000.aon to group 55
[ 0.859461] iommu: Adding device d000000.bpmp to group 56
[ 0.859783] bpmp: ping status is 0
[ 0.859934] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[ 0.863094] bpmp d000000.bpmp: probe ok
[ 0.864681] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.865196] iommu: Adding device smmu_test to group 57
[ 0.866483] mc: mapped MMIO address: 0xffffff800a5c0000 → 0x2c10000
[ 0.866518] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c20000
[ 0.866541] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c30000
[ 0.866560] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c40000
[ 0.866582] mc: mapped MMIO address: 0xffffff800b010000 → 0x2c50000
[ 0.866600] mc: mapped MMIO address: 0xffffff800b030000 → 0x2b80000
[ 0.866643] mc: mapped MMIO address: 0xffffff800b050000 → 0x2b90000
[ 0.866661] mc: mapped MMIO address: 0xffffff800b070000 → 0x2ba0000
[ 0.866678] mc: mapped MMIO address: 0xffffff800b090000 → 0x2bb0000
[ 0.866695] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1700000
[ 0.866734] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1710000
[ 0.866753] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1720000
[ 0.866773] mc: mapped MMIO address: 0xffffff800b110000 → 0x1730000
[ 0.866793] mc: mapped MMIO address: 0xffffff800b130000 → 0x1740000
[ 0.866834] mc: mapped MMIO address: 0xffffff800b150000 → 0x1750000
[ 0.866851] mc: mapped MMIO address: 0xffffff800b170000 → 0x1760000
[ 0.866869] mc: mapped MMIO address: 0xffffff800b190000 → 0x1770000
[ 0.866970] mc-err: mcerr ops are set to t19x
[ 0.873950] iommu: Adding device 2600000.dma to group 58
[ 0.879983] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 0.880033] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.880077] GPIO line 412 (host_led) hogged as output/high
[ 0.880114] GPIO line 437 (uart_en) hogged as output/high
[ 0.880150] GPIO line 444 (uart_mode2) hogged as output/high
[ 0.880185] GPIO line 443 (uart_mode0) hogged as output/low
[ 0.880219] GPIO line 440 (uart_slew) hogged as output/low
[ 0.880288] GPIO line 490 (lvds_pwdn) hogged as output/high
[ 0.880329] GPIO line 288 (mmc_pwr_en) hogged as output/high
[ 0.880368] GPIO line 338 (daq_rst) hogged as output/high
[ 0.880406] GPIO line 347 (camera-control-output-low) hogged as output/low
[ 0.880442] GPIO line 350 (camera-control-output-low) hogged as output/low
[ 0.880476] GPIO line 446 (camera-control-output-low) hogged as output/low
[ 0.880786] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.888521] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.888806] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.891069] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.891080] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.891866] iommu: Adding device 3550000.xudc to group 59
[ 0.892663] iommu: Adding device 3610000.xhci to group 60
[ 0.895435] arm64_ras arm64_ras: probed
[ 0.895882] ras_fhi_enable: FHI 480 enabled on CPU0
[ 0.895927] ras_fhi_enable: FHI 481 enabled on CPU1
[ 0.895995] ras_fhi_enable: FHI 482 enabled on CPU2
[ 0.896058] ras_fhi_enable: FHI 483 enabled on CPU3
[ 0.896119] ras_fhi_enable: FHI 484 enabled on CPU4
[ 0.896184] ras_fhi_enable: FHI 485 enabled on CPU5
[ 0.896241] ras_fhi_enable: FHI 486 enabled on CPU6
[ 0.896339] ras_fhi_enable: FHI 487 enabled on CPU7
[ 0.896581] carmel_ras_enable: RAS enabled on cpu0
[ 0.896775] carmel_ras_enable: RAS enabled on cpu1
[ 0.896983] carmel_ras_enable: RAS enabled on cpu2
[ 0.897170] carmel_ras_enable: RAS enabled on cpu3
[ 0.897365] carmel_ras_enable: RAS enabled on cpu4
[ 0.897558] carmel_ras_enable: RAS enabled on cpu5
[ 0.897751] carmel_ras_enable: RAS enabled on cpu6
[ 0.897938] carmel_ras_enable: RAS enabled on cpu7
[ 0.898038] carmel_ras carmel_ras: probed
[ 0.899984] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 489, noc_nonsecure_irq = 488>
[ 0.900676] tegra-cbb c600000.aon-noc: noc_secure_irq = 491, noc_nonsecure_irq = 490>
[ 0.901754] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 493, noc_nonsecure_irq = 492>
[ 0.902748] tegra-cbb be00000.rce-noc: noc_secure_irq = 495, noc_nonsecure_irq = 494>
[ 0.903902] tegra-cbb b600000.sce-noc: noc_secure_irq = 497, noc_nonsecure_irq = 496>
[ 0.904366] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.907703] vdd-3v3-cvb: 3300 mV
[ 0.908006] vdd-1v8-cvb: 1800 mV
[ 0.908298] vdd-1v8-sd: 1800 mV
[ 0.908770] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.908812] vdd-epb-1v0: 1000 mV
[ 0.909139] vdd-sdmmc1-sw: 3300 mV
[ 0.909526] avdd-cam-2v8: 2800 mV
[ 0.909845] vdd-sata-1v5: 1500 mV
[ 0.910130] vdd-1v8-slt: 1800 mV
[ 0.910408] vdd-3v3-slt: 3300 mV
[ 0.910744] vdd-fan: 5000 mV
[ 0.911187] vdd-hdmi-5v0: 5000 mV
[ 0.911554] vdd_sys_en: 1200 mV
[ 0.912041] vdd-5v-sata: 5000 mV
[ 0.912394] vdd-ac-bat: 1800 mV
[ 0.912580] vdd-5v-sata: supplied by vdd-ac-bat
[ 0.943986] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.948744] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.948987] SCSI subsystem initialized
[ 0.949241] libata version 3.00 loaded.
[ 0.949441] usbcore: registered new interface driver usbfs
[ 0.949481] usbcore: registered new interface driver hub
[ 0.949597] usbcore: registered new device driver usb
[ 0.961689] tegra-i2c c250000.i2c: no acknowledge from address 0x22
[ 0.961736] pca953x 7-0022: failed reading register
[ 0.961852] pca953x: probe of 7-0022 failed with error -121
[ 0.961937] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.964744] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.971572] vdd-1v0: at 1000 mV
[ 0.975606] vdd-1v8-hs: at 1800 mV
[ 0.979625] vdd-1v8-ls: at 1800 mV
[ 0.983617] vdd-1v8-ao: at 1800 mV
[ 0.987658] vddio-ddr-1v1: at 1100 mV
[ 0.991433] vdd-rtc: at 800 mV
[ 0.992561] spmic-ldo1: at 2375 mV
[ 0.999445] vdd-ao-3v3: at 3300 mV
[ 1.007477] vddio-emmc-3v3: at 3300 mV
[ 1.008542] spmic-ldo4: at 1587 mV
[ 1.015509] vdd-usb-3v3: at 3300 mV
[ 1.023540] vddio-sdmmc1-3v3: at 3300 mV
[ 1.027575] vdd-csi-1v2: at 1200 mV
[ 1.028610] spmic-ldo8: at 1800 mV
[ 1.033085] GPIO line 246 (gpio_default) hogged as output/high
[ 1.034038] GPIO line 247 (gpio_default) hogged as output/high
[ 1.034322] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.034646] max77620 4-003c: max77620 probe successful
[ 1.035158] media: Linux media interface: v0.10
[ 1.035196] Linux video capture interface: v2.00
[ 1.036482] pps_core: LinuxPPS API ver. 1 registered
[ 1.036489] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.036504] PTP clock support registered
[ 1.036754] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.037005] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.037060] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.039565] trusty trusty: trusty version: Built: 21:16:17 Jun 25 2020
[ 1.039627] trusty trusty: selected api version: 3 (requested 3)
[ 1.040587] Advanced Linux Sound Architecture Driver Initialized.
[ 1.041072] Bluetooth: Core ver 2.22
[ 1.041107] NET: Registered protocol family 31
[ 1.041112] Bluetooth: HCI device and connection manager initialized
[ 1.041122] Bluetooth: HCI socket layer initialized
[ 1.041130] Bluetooth: L2CAP socket layer initialized
[ 1.041192] Bluetooth: SCO socket layer initialized
[ 1.044086] camchar: rtcpu character device driver loaded
[ 1.045266] clocksource: Switched to clocksource arch_sys_counter
[ 1.088972] VFS: Disk quotas dquot_6.6.0
[ 1.089063] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.089510] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.090838] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.090905] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.091169] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.091177] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.091189] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.091196] nvmap_page_pool_init: Total RAM pages: 8167643
[ 1.091202] nvmap_page_pool_init: nvmap page pool size: 1020955 pages (3988 MB)
[ 1.091353] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.092018] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.093728] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.105683] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.105877] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.106077] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.106257] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.106447] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.106550] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 1.106650] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 1.107845] la/ptsa driver initialized.
[ 1.108183] NET: Registered protocol family 2
[ 1.109114] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.110497] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.111095] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.111151] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.111619] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.112395] NET: Registered protocol family 1
[ 1.113001] RPC: Registered named UNIX socket transport module.
[ 1.113007] RPC: Registered udp transport module.
[ 1.113011] RPC: Registered tcp transport module.
[ 1.113015] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.113027] PCI: CLS 0 bytes, default 64
[ 1.113311] Trying to unpack rootfs image as initramfs…
[ 1.295395] Freeing initrd memory: 5432K
[ 1.316147] host1x 13e10000.host1x: initialized
[ 1.318197] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.323057] audit: initializing netlink subsys (disabled)
[ 1.323094] audit: type=2000 audit(0.940:1): initialized
[ 1.323795] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.332502] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.333755] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.334394] 9p: Installing v9fs 9p2000 file system support
[ 1.339164] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.339332] io scheduler noop registered
[ 1.339558] io scheduler cfq registered (default)
[ 1.343062] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.346995] iommu: Adding device 2993000.adsp to group 61
[ 1.354171] random: fast init done
[ 1.401675] iommu: Adding device aconnect@2a41000:adsp_audio to group 62
[ 1.402609] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.414794] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.415298] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.415970] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.416429] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.419523] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.419719] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.419732] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=8350000, max_bw=8350000
[ 1.423122] tsec 15500000.tsec: initialized
[ 1.424913] tsec 15100000.tsecb: initialized
[ 1.429484] nvdec 15480000.nvdec: initialized
[ 1.432157] nvdec 15140000.nvdec1: initialized
[ 1.438570] falcon 15340000.vic: initialized
[ 1.440722] falcon 15380000.nvjpg: initialized
[ 1.442964] falcon 154c0000.nvenc: initialized
[ 1.445010] falcon 15a80000.nvenc1: initialized
[ 1.448866] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.451342] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.453043] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.454671] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.456356] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.457979] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.459600] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.461082] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.464878] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.470350] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.470877] scare-pigeon 14b00000.isp-thi: initialized
[ 1.480834] pva 16000000.pva0: initialized
[ 1.511871] pva 16800000.pva1: initialized
[ 1.541999] nvdla 15880000.nvdla0: initialized
[ 1.572090] nvdla 158c0000.nvdla1: initialized
[ 1.573641] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.573654] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.573706] tegradccommon 15200000.dc_common: dma mapping done
[ 1.573922] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=87
[ 1.573932] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.574159] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.574215] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.574478] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.574487] tegra_cec 3960000.tegra_cec: probed
[ 1.575317] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.575384] generic_infoframe_type: 0x87
[ 1.575504] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.575556] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.579552] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.579561] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.579566] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.579801] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.579812] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.581446] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.588255] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.588263] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.588755] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.589648] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.589661] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.590169] kfuse 3830000.kfuse: initialized
[ 1.592545] tegradc 15200000.nvdisplay: probed
[ 1.596677] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.599424] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 53, base_baud = 0) is a TEGRA_UART
[ 1.600620] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 54, base_baud = 0) is a TEGRA_UART
[ 1.601611] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 55, base_baud = 0) is a TEGRA_UART
[ 1.602980] c290000.serial: ttyTHS6 at MMIO 0xc290000 (irq = 56, base_baud = 0) is a TEGRA_UART
[ 1.604274] console [ttyTCU0] enabled
[ 1.604607] [drm] Initialized
[ 1.618099] brd: module loaded
[ 1.623922] loop: module loaded
[ 1.624019] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.624187] tegra_profiler: auth: init
[ 1.624626] nct1008_nct72 4-004c: starting parse dt
[ 1.624763] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 1.624781] nct1008_nct72 4-004c: success parsing dt
[ 1.624981] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 1.625018] THERMAL EST: found 3 subdevs
[ 1.625026] THERMAL EST num_resources: 0
[ 1.625032] [THERMAL EST subdev 0]
[ 1.625052] [THERMAL EST subdev 1]
[ 1.625067] [THERMAL EST subdev 2]
[ 1.625089] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.625593] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.625598] THERMAL EST: thz register success.
[ 1.625778] THERMAL EST: end of probe, return err: 0
[ 1.626558] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 1.626570] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 1.627437] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 462
[ 1.627454] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 1.634834] Console: switching to colour frame buffer device 240x67
[ 1.634968] tegradc 15200000.nvdisplay: fb registered
[ 1.635275] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 1.635935] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.637545] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.642715] sd: No Scsi addr parsed to reserve index
[ 1.642757] hisi_sas: driver version v1.6
[ 1.653529] Parent Clock set for DC plld3
[ 1.655998] libphy: Fixed MDIO Bus: probed
[ 1.657340] tun: Universal TUN/TAP device driver, 1.6
[ 1.657346] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.657580] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 1.657611] CAN device driver interface
[ 1.658620] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 1.660094] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
[ 1.660219] Release 3.2.0 from 19.12.2014
[ 1.660631] net can0: mttcan device registered (regs=ffffff800a4fc000, irq=71)
[ 1.662543] Message RAM Configuration
| base addr |0x0c322000|
[ 1.662663] Release 3.2.0 from 19.12.2014
[ 1.663016] net can1: mttcan device registered (regs=ffffff800a59e000, irq=72)
[ 1.663641] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.663646] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.663716] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.663721] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.663760] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.663765] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.663808] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.663813] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.672550] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 13 4c b1
[ 1.672652] libphy: dwc_phy: probed
[ 1.674652] PPP generic driver version 2.4.2
[ 1.674807] PPP BSD Compression module registered
[ 1.674813] PPP Deflate Compression module registered
[ 1.674830] PPP MPPE Compression module registered
[ 1.674836] NET: Registered protocol family 24
[ 1.674883] usbcore: registered new interface driver r8152
[ 1.674919] usbcore: registered new interface driver asix
[ 1.674966] usbcore: registered new interface driver ax88179_178a
[ 1.674997] usbcore: registered new interface driver cdc_ether
[ 1.675049] usbcore: registered new interface driver net1080
[ 1.675076] usbcore: registered new interface driver cdc_subset
[ 1.675104] usbcore: registered new interface driver zaurus
[ 1.675138] usbcore: registered new interface driver cdc_ncm
[ 1.675348] VFIO - User Level meta-driver version: 0.3
[ 1.676493] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.676509] ehci-pci: EHCI PCI platform driver
[ 1.676547] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.676572] ohci-pci: OHCI PCI platform driver
[ 1.676603] ohci-platform: OHCI generic platform driver
[ 1.681725] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[ 1.685094] usbcore: registered new interface driver uas
[ 1.685131] usbcore: registered new interface driver usb-storage
[ 1.685205] usbcore: registered new interface driver usbserial
[ 1.686899] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.686939] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.686989] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.687685] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.687727] tegra-xusb 3610000.xhci: irq 475, io mem 0x03610000
[ 1.687906] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.687913] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.687920] usb usb1: Product: xHCI Host Controller
[ 1.687926] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.687932] usb usb1: SerialNumber: 3610000.xhci
[ 1.688364] hub 1-0:1.0: USB hub found
[ 1.688406] hub 1-0:1.0: 4 ports detected
[ 1.688888] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.688898] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.688908] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.689308] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.689317] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.689323] usb usb2: Product: xHCI Host Controller
[ 1.689329] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.689335] usb usb2: SerialNumber: 3610000.xhci
[ 1.689797] hub 2-0:1.0: USB hub found
[ 1.689841] hub 2-0:1.0: 4 ports detected
[ 1.690087] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.690127] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 1.690908] mousedev: PS/2 mouse device common for all mice
[ 1.690972] usbcore: registered new interface driver xpad
[ 1.692422] nct1008_nct72 4-004c: initial LOC temp: 32000
[ 1.693507] nct1008_nct72 4-004c: initial EXT temp: 36500
[ 1.695702] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 1.696818] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 1.718287] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.718886] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.718899] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.744512] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 1.744545] Extcon AUX2(HDMI) enable
[ 1.745065] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.745101] generic_infoframe_type: 0x87
[ 1.745175] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.745219] tegradc 15210000.nvdisplay: Display dc.ffffff800d1e0000 registered with id=1
[ 1.745535] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.745544] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.748466] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.748474] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.752350] tegra-i2c 31b0000.i2c: no acknowledge from address 0x50
[ 1.754518] tegradc 15210000.nvdisplay: probed
[ 1.754911] tegradc 15210000.nvdisplay: fb registered
[ 1.755169] gpio tegra-gpio wake60 for gpio=96(M:0)
[ 1.789419] usb usb1: usb_suspend_both: status 0
[ 1.823747] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.825280] Wake73 for irq=42
[ 1.826540] rtc rtc1: alarm rtc device
[ 1.826582] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.826626] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.826748] i2c /dev entries driver
[ 1.828625] pca954x 2-0070: vcc-pullup regulator not found
[ 1.828641] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[ 1.828647] pca954x 2-0070: device detect skipped.
[ 1.829079] i2c i2c-2: Added multiplexed i2c bus 30
[ 1.829425] i2c i2c-2: Added multiplexed i2c bus 31
[ 1.829804] i2c i2c-2: Added multiplexed i2c bus 32
[ 1.829996] i2c i2c-2: Added multiplexed i2c bus 33
[ 1.830436] i2c i2c-2: Added multiplexed i2c bus 34
[ 1.830887] i2c i2c-2: Added multiplexed i2c bus 35
[ 1.831196] i2c i2c-2: Added multiplexed i2c bus 36
[ 1.831469] i2c i2c-2: Added multiplexed i2c bus 37
[ 1.831477] pca954x 2-0070: registered 8 multiplexed busses for I2C switch pca9548
[ 1.833371] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 1.840371] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 1.894501] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 1.894544] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 1.894552] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 1.894774] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 1.894855] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 1.894862] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 1.895216] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 1.895275] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 1.895282] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 1.895646] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 1.895702] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 1.895709] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 1.896161] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 1.896238] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 1.896245] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 1.896636] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 1.897327] FAN dev name: pwm-fan
[ 1.897379] FAN:gpio request success.
[ 1.897389] FAN: can’t find tach_gpio
[ 1.897402] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 1.897435] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 1.897702] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.897709] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.898303] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.898315] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 1.898349] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.898357] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.898363] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.898369] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.898376] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.898382] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.898389] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.898396] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.899464] device-mapper: uevent: version 1.0.3
[ 1.899865] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.903900] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 1.905197] cpuidle: Initializing cpuidle driver
[ 1.906331] sdhci: Secure Digital Host Controller Interface driver
[ 1.906335] sdhci: Copyright(c) Pierre Ossman
[ 1.906338] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.908887] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.911008] CMDQ: cmdq_platfm_init successful
[ 1.911539] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.914561] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.916019] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.920102] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.921736] tegra-se-nvhost 15810000.se: initialized
[ 1.922996] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.924352] tegra-se-nvhost 15820000.se: initialized
[ 1.925175] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.926106] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.926146] tegra-se-nvhost 15830000.se: initialized
[ 1.926686] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.927525] tegra-se-nvhost 15840000.se: initialized
[ 1.928264] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.928442] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.929490] usbcore: registered new interface driver usbhid
[ 1.929492] usbhid: USB HID core driver
[ 1.934981] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 1.935825] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.936229] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.936939] denver_knobs_init:MTS_VERSION:50168445
[ 1.937134] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 1.937904] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.938201] t19x_cache tegra-cache: probed
[ 1.944211] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 1.944217] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 1.944664] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 1.944981] PLL_AON clock registered
[ 1.945329] Clocks initialized successfully
[ 1.946673] nvpmodel: initialized successfully
[ 1.947646] trusty-virtio trusty:virtio: initializing
[ 1.947856] trusty_ipc virtio0: vring0: va¶ ffffffc7c79d6000(0) qsz 32 notifyid 1
[ 1.947863] trusty_ipc virtio0: vring1: va¶ ffffffc7d82dc000(0) qsz 32 notifyid 2
[ 1.947979] trusty-virtio trusty:virtio: initializing done
[ 1.948106] trusty_ipc virtio0: is online
[ 1.948589] tegra-hda 3510000.hda: Override SDO lines to 4
[ 1.948928] usbcore: registered new interface driver snd-usb-audio
[ 1.950677] sgtl5000 7-000a: sgtl5000 revision 0x11
[ 1.953290] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.962466] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 1.962530] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.967494] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.967664] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.967843] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 1.968003] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 1.968720] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 1.968723] Extcon AUX2(HDMI) disable
[ 1.994128] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.996189] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 2.008840] tegradc 15200000.nvdisplay: unblank
[ 2.010306] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 2.010486] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 2.013081] Parent Clock set for DC plld3
[ 2.019880] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 2.022995] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 2.023012] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 2.039028] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 2.053212] mmc0: periodic cache flush enabled
[ 2.053229] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.053817] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 2.058073] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 2.058312] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 2.058514] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 2.060942] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 2.060948] Extcon AUX2(HDMI) enable
[ 2.063069] OPE platform probe
[ 2.063152] OPE platform probe successful
[ 2.068062] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37 p38 p39 p40 p41 p42
[ 2.126563] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 2.126685] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 2.126787] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 2.126897] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 2.127018] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 2.127111] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 2.127237] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 2.127346] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 2.127474] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 2.127570] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 2.127644] tegra-asoc: sound: ADMAIF11 ↔ ADMAIF11 mapping ok
[ 2.127717] tegra-asoc: sound: ADMAIF12 ↔ ADMAIF12 mapping ok
[ 2.127792] tegra-asoc: sound: ADMAIF13 ↔ ADMAIF13 mapping ok
[ 2.127862] tegra-asoc: sound: ADMAIF14 ↔ ADMAIF14 mapping ok
[ 2.127927] tegra-asoc: sound: ADMAIF15 ↔ ADMAIF15 mapping ok
[ 2.127995] tegra-asoc: sound: ADMAIF16 ↔ ADMAIF16 mapping ok
[ 2.128076] tegra-asoc: sound: ADMAIF17 ↔ ADMAIF17 mapping ok
[ 2.128150] tegra-asoc: sound: ADMAIF18 ↔ ADMAIF18 mapping ok
[ 2.128234] tegra-asoc: sound: ADMAIF19 ↔ ADMAIF19 mapping ok
[ 2.128318] tegra-asoc: sound: ADMAIF20 ↔ ADMAIF20 mapping ok
[ 2.152090] u32 classifier
[ 2.152096] Actions configured
[ 2.152197] Initializing XFRM netlink socket
[ 2.152728] NET: Registered protocol family 10
[ 2.153477] NET: Registered protocol family 17
[ 2.153486] NET: Registered protocol family 15
[ 2.153533] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.153534] can: controller area network core (rev 20120528 abi 9)
[ 2.153596] NET: Registered protocol family 29
[ 2.153607] can: raw protocol (rev 20120528)
[ 2.153609] can: broadcast manager protocol (rev 20161123 t)
[ 2.153614] can: netlink gateway (rev 20130117) max_hops=1
[ 2.153819] Bluetooth: RFCOMM socket layer initialized
[ 2.153830] Bluetooth: RFCOMM ver 1.11
[ 2.153837] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.153844] Bluetooth: HIDP socket layer initialized
[ 2.153865] 9pnet: Installing 9P2000 support
[ 2.153899] Key type dns_resolver registered
[ 2.154115] Registered cp15_barrier emulation handler
[ 2.154133] Registered setend emulation handler
[ 2.155466] registered taskstats version 1
[ 2.155907] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 2.157394] OF: PCI: host bridge /pcie@14180000 ranges:
[ 2.157420] OF: PCI: IO 0x38100000…0x381fffff → 0x38100000
[ 2.157434] OF: PCI: MEM 0x1b40000000…0x1bffffffff → 0x40000000
[ 2.157446] OF: PCI: MEM 0x1800000000…0x1b3fffffff → 0x1800000000
[ 2.269296] tegra-pcie-dw 14180000.pcie: link is up
[ 2.269516] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 2.269522] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.269536] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 2.269545] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 2.269548] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 2.269571] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.269693] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.269864] iommu: Adding device 0000:00:00.0 to group 63
[ 2.270211] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[ 2.270329] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 2.271342] iommu: Adding device 0000:01:00.0 to group 64
[ 2.282635] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[ 2.282658] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[ 2.282720] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 2.282726] pci 0000:00:00.0: bridge window [mem 0x1b40000000-0x1b400fffff]
[ 2.282743] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.282786] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 2.283084] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.283087] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.283092] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.283183] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 2.283626] nvme nvme0: pci function 0000:01:00.0
[ 2.283687] nvme 0000:01:00.0: enabling device (0000 → 0002)
[ 2.283849] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 2.284842] OF: PCI: host bridge /pcie@14100000 ranges:
[ 2.284873] OF: PCI: IO 0x30100000…0x301fffff → 0x30100000
[ 2.284887] OF: PCI: MEM 0x1230000000…0x123fffffff → 0x40000000
[ 2.284899] OF: PCI: MEM 0x1200000000…0x122fffffff → 0x1200000000
[ 2.589324] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.653856] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.653861] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.796652] tegra-pcie-dw 14100000.pcie: link is down
[ 2.796867] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 2.796884] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 2.796898] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 2.796907] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 2.796910] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 2.796936] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 2.797097] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.797363] iommu: Adding device 0001:00:00.0 to group 65
[ 2.797677] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 2.797698] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.797940] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.797945] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.798017] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 2.798195] pcie_pme 0001:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.798264] aer 0001:00:00.0:pcie002: unloading service driver aer
[ 2.798366] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 2.798426] iommu: Removing device 0001:00:00.0 from group 65
[ 2.798452] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 2.800056] tegra-pcie-dw 14100000.pcie: PCIe link is not up…!
[ 2.800533] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 2.801471] OF: PCI: host bridge /pcie@14140000 ranges:
[ 2.801498] OF: PCI: IO 0x34100000…0x341fffff → 0x34100000
[ 2.801533] OF: PCI: MEM 0x12b0000000…0x12bfffffff → 0x40000000
[ 2.801545] OF: PCI: MEM 0x1280000000…0x12afffffff → 0x1280000000
[ 2.909301] tegra-pcie-dw 14140000.pcie: link is up
[ 2.909587] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 2.909596] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 2.909609] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 2.909619] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 2.909621] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 2.909646] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 2.909807] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.910036] iommu: Adding device 0003:00:00.0 to group 65
[ 2.910450] pci 0003:01:00.0: [8086:1533] type 00 class 0x020000
[ 2.910558] pci 0003:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
[ 2.910663] pci 0003:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 2.910716] pci 0003:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 2.911406] pci 0003:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.911724] iommu: Adding device 0003:01:00.0 to group 66
[ 2.922276] pci 0003:00:00.0: BAR 14: assigned [mem 0x12b0000000-0x12b00fffff]
[ 2.922280] pci 0003:00:00.0: BAR 13: assigned [io 0x200000-0x200fff]
[ 2.922284] pci 0003:01:00.0: BAR 0: assigned [mem 0x12b0000000-0x12b007ffff]
[ 2.922311] pci 0003:01:00.0: BAR 3: assigned [mem 0x12b0080000-0x12b0083fff]
[ 2.922334] pci 0003:01:00.0: BAR 2: assigned [io 0x200000-0x20001f]
[ 2.922358] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 2.922361] pci 0003:00:00.0: bridge window [io 0x200000-0x200fff]
[ 2.922367] pci 0003:00:00.0: bridge window [mem 0x12b0000000-0x12b00fffff]
[ 2.922383] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.922437] pci 0003:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 2.922677] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.922680] pci 0003:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.922684] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.922806] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 2.923039] igb 0003:01:00.0: enabling device (0000 → 0002)
[ 2.957349] pps_core: source ptp0 got cdev (248:0)
[ 2.957354] pps pps0: new PPS source ptp0
[ 2.957359] igb 0003:01:00.0: added PHC on eth1
[ 2.957361] igb 0003:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 2.957365] igb 0003:01:00.0: eth1: (PCIe:2.5Gb/s:Width x1) 00:06:d5:2f:40:0c
[ 2.957460] igb 0003:01:00.0: eth1: PBA No: 000300-000
[ 2.957463] igb 0003:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 2.957760] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.958469] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.958494] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.958513] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.958524] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 3.473786] tegra-pcie-dw 14160000.pcie: link is down
[ 3.473972] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 3.473978] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 3.473992] pci_bus 0004:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x36100000-0x361fffff])
[ 3.474001] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 3.474004] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 3.474027] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 3.474160] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.474343] iommu: Adding device 0004:00:00.0 to group 67
[ 3.474617] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 3.474638] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 3.474852] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.474857] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 3.474983] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 3.475142] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 3.475182] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 3.475271] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 3.475335] iommu: Removing device 0004:00:00.0 from group 67
[ 3.475361] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 3.476895] tegra-pcie-dw 14160000.pcie: PCIe link is not up…!
[ 3.477639] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 3.478502] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 3.478528] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 3.478546] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 3.478575] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 3.992759] tegra-pcie-dw 141a0000.pcie: link is down
[ 3.992964] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 3.992971] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 3.992976] pci_bus 0005:00: root bus resource [io 0x400000-0x4fffff] (bus address [0x3a100000-0x3a1fffff])
[ 3.992981] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 3.992984] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 3.993021] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 3.993159] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.993397] iommu: Adding device 0005:00:00.0 to group 67
[ 3.993720] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 3.993739] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 3.993973] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.993979] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 3.994115] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 4.007898] tegra-cbb 14040000.cv-noc: noc_secure_irq = 101, noc_nonsecure_irq = 100>
[ 4.012101] tegra194-isp5 14800000.isp: initialized
[ 4.018054] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 4.020503] tegra194-vi5 15c10000.vi: initialized
[ 4.024454] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–4 bound
[ 4.024519] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–3 bound
[ 4.024582] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 4.024625] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 4.025352] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.070649] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 4.070652] Extcon HDMI: HPD enabled
[ 4.070665] tegradc 15200000.nvdisplay: hdmi: plugged
[ 4.098351] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 4.098676] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.098874] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 4.099041] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 4.099341] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 4.099405] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 4.099612] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (74)
[ 4.099616] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.100558] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 4.100957] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 4.101038] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 4.101171] input: gpio-keys as /devices/gpio-keys/input/input4
[ 4.134416] tegra_rtc c2a0000.rtc: setting system clock to 2021-01-26 22:27:04 UTC (1611700024)
[ 4.134922] mmcblk mmc0:0001: Card claimed for testing.
[ 4.178214] bpmp: mounted debugfs mirror
[ 4.183739] vdd-1v8-sd: disabling
[ 4.183745] vdd-epb-1v0: disabling
[ 4.183748] avdd-cam-2v8: disabling
[ 4.183751] vdd-sata-1v5: disabling
[ 4.183754] vdd-3v3-slt: disabling
[ 4.183757] vdd-fan: disabling
[ 4.183760] vdd_sys_en: disabling
[ 4.183767] ALSA device list:
[ 4.183770] #0: tegra-hda-galen-t194 at 0x3518000 irq 73
[ 4.183773] #1: tegra-snd-t19x-mobile-rt565x
[ 4.185342] Freeing unused kernel memory: 8576K
[ 4.217641] Root device found: mmcblk0p1
[ 4.218856] Found dev node: /dev/mmcblk0p1
[ 4.243669] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.244452] Rootfs mounted over mmcblk0p1
[ 4.262244] Switching from initrd to actual rootfs
[ 4.377277] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.379841] cgroup: cgroup2: unknown option “nsdelegate”
[ 4.386848] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.387426] systemd[1]: Detected architecture arm64.
[ 4.392564] systemd[1]: Set hostname to .
[ 4.488629] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.488641] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.617371] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.617405] systemd[1]: Reached target Swap.
[ 4.617770] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.618120] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.618170] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.620669] systemd[1]: Created slice System Slice.
[ 4.621168] systemd[1]: Listening on Journal Socket.
[ 4.624127] systemd[1]: Mounting POSIX Message Queue File System…
[ 4.642326] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 4.659787] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.993451] systemd-journald[2495]: Received request to flush runtime journal from PID 1
[ 5.080860] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 5.548425] #### in spidev_init
[ 5.548638] #### in spidev_probe
[ 5.548729] #### in spidev_probe after warn
[ 5.550494] #### in spidev_probe
[ 5.550623] #### in spidev_probe after warn
[ 5.570612] ar1335: loading out-of-tree module taints kernel.
[ 5.570780] ar1335: loading out-of-tree module taints kernel.
[ 5.572026] [ar1335]: probing v4l2 sensor.
[ 5.586758] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.589083] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.590165] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.591491] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.592792] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.593354] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.597336] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.598683] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.599720] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.600451] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.601510] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.602853] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.603294] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.603638] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.603989] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.604281] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.604556] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.604845] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.608362] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.614942] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.620927] ar1335 30-003c: AR1335 H/W module not present
[ 5.633644] [ar1335]: probing v4l2 sensor.
[ 5.642139] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.644113] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.644520] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.645237] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.664197] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.666314] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.667838] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.670660] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.682534] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.683750] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.705406] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.706188] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.707339] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.708471] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.716478] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.724010] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.728061] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.735378] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.739963] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.747750] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.753859] ar1335 32-003c: AR1335 H/W module not present
[ 5.758273] [ar1335]: probing v4l2 sensor.
[ 5.766622] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.768077] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.770395] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.777435] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.784383] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.792469] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.797465] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.804706] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.808963] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.815082] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.822210] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.828752] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.835507] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.842277] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.846320] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.852925] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.859943] Wake76 for irq=199
[ 5.859945] Wake77 for irq=199
[ 5.859947] Wake78 for irq=199
[ 5.859948] Wake79 for irq=199
[ 5.859949] Wake80 for irq=199
[ 5.859950] Wake81 for irq=199
[ 5.859951] Wake82 for irq=199
[ 5.859987] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 5.859990] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 5.864527] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.865806] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.871718] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.878034] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.887260] random: crng init done
[ 5.888066] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.888634] ar1335 34-003c: AR1335 H/W module not present
[ 5.888803] [ar1335]: probing v4l2 sensor.
[ 5.936925] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.938287] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.939773] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.940810] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.941838] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.942827] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.944020] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.945818] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.949636] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.956550] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.957478] usb usb2: usb_suspend_both: status 0
[ 5.963605] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.968032] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 5.977541] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.025886] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.034027] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.044188] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.045647] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.046997] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.048298] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.049741] tegra-i2c 3180000.i2c: no acknowledge from address 0x70
[ 6.050837] ar1335 35-003c: AR1335 H/W module not present
[ 6.465946] ras_fhi_disable: FHI 484 disabled
[ 6.466508] CPU4: shutdown
[ 6.467591] psci: CPU4 killed.
[ 6.518828] ras_fhi_disable: FHI 485 disabled
[ 6.525229] CPU5: shutdown
[ 6.531442] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.545454] psci: Retrying again to check for CPU kill
[ 6.545470] psci: CPU5 killed.
[ 6.609841] ras_fhi_disable: FHI 486 disabled
[ 6.610286] CPU6: shutdown
[ 6.622244] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 6.626542] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.629289] psci: Retrying again to check for CPU kill
[ 6.629302] psci: CPU6 killed.
[ 6.651337] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 6.686940] ras_fhi_disable: FHI 487 disabled
[ 6.692899] CPU7: shutdown
[ 6.709277] psci: Retrying again to check for CPU kill
[ 6.709292] psci: CPU7 killed.
[ 6.710730] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 6.727987] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 8.189329] tegra-xusb 3610000.xhci: entering ELPG
[ 8.196244] tegra-xusb 3610000.xhci: entering ELPG done
[ 8.693789] zram: Added device: zram0
[ 8.694759] zram: Added device: zram1
[ 8.695708] zram: Added device: zram2
[ 8.696166] zram: Added device: zram3
[ 8.720811] zram0: detected capacity change from 0 to 4183625728
[ 8.740511] Adding 4085568k swap on /dev/zram0. Priority:5 extents:1 across:4085568k SS
[ 8.745929] zram1: detected capacity change from 0 to 4183625728
[ 8.763903] Adding 4085568k swap on /dev/zram1. Priority:5 extents:1 across:4085568k SS
[ 8.780376] zram2: detected capacity change from 0 to 4183625728
[ 8.795098] Adding 4085568k swap on /dev/zram2. Priority:5 extents:1 across:4085568k SS
[ 8.799574] zram3: detected capacity change from 0 to 4183625728
[ 8.815356] Adding 4085568k swap on /dev/zram3. Priority:5 extents:1 across:4085568k SS
[ 9.389996] igb 0003:01:00.0 eth1: igb: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 9.497710] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 9.954894] tegradc 15200000.nvdisplay: blank - powerdown
[ 10.007260] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 10.007263] Extcon AUX2(HDMI) disable
[ 10.037790] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 10.039039] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 10.039480] tegradc 15200000.nvdisplay: unblank
[ 10.041625] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 10.041805] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 10.050692] Parent Clock set for DC plld3
[ 10.056082] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 10.057780] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 10.057790] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 10.093175] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 10.093180] Extcon AUX2(HDMI) enable
[ 10.093323] tegradc 15200000.nvdisplay: unblank
[ 10.093338] tegradc 15210000.nvdisplay: blank - powerdown
[ 10.652314] fuse init (API version 7.26)
hello andrea,
it seems like display issue according to those kernel messages.
may I know what’s the display monitor you’re using, what’s the supported resolutions, are you able to replace it with another monitor for verification.
thanks
Hi @JerryChang, it’s a Samsung S27D390H (1920 x 1080). Please note that the same monitor works during the initial configuration (when you have to create the account, …), so I’m puzzled why it stops working after the initial configuration.
I don’t have another HDMI monitor to try.
@JerryChang I was able to borrow an Acer 32" monitor, same resolution, from a colleague. Same results. I suspect a wrong software configuration. What can I check?
This log says the hdmi monitor is unblank. So the driver is detecting and try to unblank the screen.
Do you see anything on the monitor after configuraiton? For example, the boot log or console.
Have you tried re-flash the board? If issue is still, share us the xorg log (/var/log/Xorg.0.log) and syslog (var/log/syslog)
@WayneWWW yes, after the initial configuration the screen goes blank, but I can open a TTY console with Ctrl-Alt-F3. If I reboot the system, I can see the initial NVIDIA logo and the initial console messages, then the screen goes blank when the graphical desktop is supposed to start. TTY consoles still work, so I suspect a bad configuration of the graphical desktop. I’m attaching the xorg log and syslog.
Xorg.0.log (15.8 KB) syslog (221.6 KB)
I guess that 3rdparty firmware does not provide you the full rootfs file as jetpack.
Several error is seen in your syslog.
jetbox gnome-session-binary[6756]: WARNING: Unable to find required component ‘org.gnome.Shell’
Jan 28 09:46:59 jetbox gnome-session-binary[6756]: WARNING: GsmSessionSave: Failed to create directory /var/lib/gdm3/.config/gnome-session/saved-session: Permission denied
Jan 28 09:46:59 jetbox gnome-session-binary[6756]: WARNING: Unable to find required component ‘org.gnome.SettingsDaemon.A11ySettings’
and this error is abnormal too. Though not related to graphic.
an 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: /opt/nvidia/l4t-usb-device-mode/nv-l4t-usb-device-mode-stop.sh: line 34: l4t/UDC: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/configs/c.1/strings/0x409’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/functions/ncm.usb0/’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/functions/ecm.usb0/’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/functions/mass_storage.0/’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/functions/acm.GS0/’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/functions/rndis.usb0/’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/configs/c.1/’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t/strings/0x409’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: rmdir: failed to remove ‘l4t’: No such file or directory
Jan 28 09:59:31 jetbox nv-l4t-usb-device-mode-stop.sh[7072]: l4tbr0: ERROR while getting interface flags: No such device
Please confirm with the 3rdparty vendor if they have any special installation package that is missing. Or you forgot to apply them as root.
@WayneWWW unfortunately their support has been almost non-existent. Their only answer was that they can’t replicate the problem. So I’m trying to troubleshoot the issue myself, and see if I can fix it using publicly available packages.
@WayneWWW so I made some progress (and some regress). I did a sudo apt update and sudo apt upgrade, now the Gnome desktop shows properly, but the USB ports stopped working: devices are not detected, and some USB ports don’t even provide power (I have an optical mouse and the tracking light doesn’t turn on when connecting it to some ports).
So, I guess that the original firmware that they provide has something funky in the Gnome files, but the updates break the USB ports.
Ok, I think I solved the original problem. I refreshed the board with the original image provided by the carrier board manufacturer and went through the initial configuration. I then completely removed X using apt and then reinstalled it with sudo apt install ubuntu-desktop. Now everything seems to work properly, however I’m a bit wary about updating it, as I’m afraid the update will break the USB ports again.
I guess the reason behind this whole problem is
  1. The vendor does not provide the full rootfs to you. Thus, when you run apt upgrade, it installs the upgrade provided by NV. And the file is back, desktop is also back.
  2. However, the apt upgrade is actually for nvidia devkit only. Because NV does not know what kind of carrier board the vendor will manufacture, there is no way for us to cover all the cases.
    Thus, some configuration like kernel or dtb file from vendors are gone when you install it. These new kernel/dtb are not compatible with your carrier board and cause usb gone.
