Hi,guys.
We are using JTX1 for our products.
We need to change 8Gb DRAM to our custom 6Gb DRAM chip.
I follow below link.(for Tegra TK1)
https://devtalk.nvidia.com/default/topic/903645/4gb-sdram-custom-board-use-micron-m741k512m16ha-chip-not-working/
1.I changed BCT file.
P2180_A00_LP4_DSC_204Mhz.cfg
SDRAM[0].McEmemCfg = 0x00001000; //4GB
to
SDRAM[0].McEmemCfg = 0x00000800; //2GB
2.I changed kernel boot parameters.
ddr_die=1024M@1024M ddr_die=1024M@1024M
3.I disabled DVFS and recompile the kernel.
CONFIG_PM_DEVFREQ=n
TEGRA_EMC_SCALING_ENABLE=n
TEGRA_CPU_DVFS=n
TEGRA_GPU_DVFS=n
CONFIG_TEGRA_DVFS_RAIL_CONNECT_ALL=n
But our jetson won’t boot up.
Our custom 8Gb DRAM is working.
Boot log
[ 9.513758] KERNEL: PMC reset status reg: 0x3
[ 9.520081] tegra_actmon.emc: Completed initialization (0)
[ 9.527714] tegra_actmon.avp: Completed initialization (0)
[ 9.782217] tegra dvfs: tegra sysfs cap interface is initialized
[ 9.790280] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 9.800168] Set maximum possible CPU frequency 1734000
[ 9.806692] ALSA device list:
[ 9.810673] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 9.816973] #1: tegra-snd-t210ref-mobile-rt565x
[ 9.822878] md: Waiting for all devices to be available before autodetect
[ 9.830715] md: If you don't use raid, use raid=noautodetect
[ 9.837664] md: Autodetecting RAID arrays.
[ 9.842808] md: Scanned 0 and added 0 devices.
[ 9.848265] md: autorun ...
[ 9.852042] md: ... autorun DONE.
[ 9.857431] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 9.867360] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 9.880026] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.889159] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.898143] devtmpfs: mounted
[ 9.902256] Freeing unused kernel memory: 432K (ffffffc00109e000 - ffffffc00110a000)
[ 9.911098] Freeing alternatives memory: 52K (ffffffc00110b000 - ffffffc001118000)
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
[ 10.051191] init: plymouth-upstart-bridge main process (140) terminated with status 1
[ 10.060295] init: plymouth-upstart-bridge main process ended, respawning
[ 10.084284] init: plymouth-upstart-bridge main process (150) terminated with status 1
[ 10.093363] init: plymouth-upstart-bridge main process ended, respawning
[ 10.102120] init: ureadahead main process (143) terminated with status 5
[ 10.125944] init: plymouth-upstart-bridge main process (153) terminated with status 1
[ 10.135153] init: plymouth-upstart-bridge main process ended, respawning
[ 10.578699] Bad mode in Synchronous Abort handler detected, code 0x86000006
[ 10.586991] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 3.10.96+ #1
[ 10.594421] task: ffffffc05d810c80 ti: ffffffc05d814000 task.ti: ffffffc05d814000
[ 10.603279] PC is at 0x0
[ 10.607203] LR is at cpuidle_enter_state+0x4c/0xcc
[ 10.613405] pc : [<0000000000000000>] lr : [<ffffffc000750c7c>] pstate: 800001c5
[ 10.622259] sp : ffffffc05d817ef0
[ 10.627042] x29: ffffffc05d817ef0 x28: 0000004080000000
[ 10.633837] x27: ffffffc000080200 x26: 000000008007d000
[ 10.640606] x25: 000000008007b000 x24: ffffffc001307c18
[ 10.647362] x23: ffffffc01fe595c8 x22: 000000027606acd1
[ 10.654122] x21: 0000000000000001 x20: ffffffc01fe595c8
[ 10.660871] x19: ffffffc01fe592b0 x18: 0000007fd84b1580
[ 10.667611] x17: 0000007fa9e1c14c x16: ffffffc0001942e8
[ 10.674350] x15: 0000007fa9efc5a0 x14: 0000000000000001
[ 10.681077] x13: 0000004400000000 x12: 6db6db6db6db6db7
[ 10.687790] x11: ffffffc05bc4b328 x10: 000000001ed51000
[ 10.694503] x9 : 0000000000000000 x8 : 000000003b9aca00
[ 10.701217] x7 : 00000000193d6f0e x6 : 002ec2f27fcf2c00
[ 10.707929] x5 : 0000000000000018 x4 : 0000000034155555
[ 10.714629] x3 : 0000000000000000 x2 : 0000000000000001
[ 10.721337] x1 : ffffffc01fe595c8 x0 : ffffffc01fe592b0
[ 10.728039]
[ 10.728039] LR: 0xffffffc000750bfc:
[ 10.735692] 0bfc d63f0040 14000009 51000421 3100043f 54fffe81 12800240 14000004 12800240
[ 10.745368] 0c1c 14000002 12800240 f9400bf3 a8c27bfd d65f03c0 a9bd7bfd 910003fd a90153f3
[ 10.755052] 0c3c a9025bf5 aa0003f3 aa0103f4 2a0203f5 97e6960d aa0003f6 93407ea1 8b010420
[ 10.764753] 0c5c d37ef400 cb010000 8b000e80 f9403003 2a1503e2 aa1403e1 aa1303e0 d63f0060
[ 10.774451] 0c7c 2a0003f4 97e69600 aa0003f5 97e79edc d50342ff cb1602a0 97e57295 d2884802
[ 10.784152] 0c9c f2a001e2 9b020400 b2407be1 eb01001f 9a81d000 b9000a60 37f80194 93407e82
[ 10.793866] 0cbc d37ff843 8b020064 8b040e64 f9401081 8b20c020 f9001080 f9400c81 91000421
[ 10.803599] 0cdc f9000c81 14000002 b9000a7f 2a1403e0 a94153f3 a9425bf5 a8c37bfd d65f03c0
[ 10.813355]
Does anyone else have good idea?Does JTX support to change memory size? 4GB only?
Which memory part are you using for 6Gb ?
Here is the change list for 4GB CFG to 3GB.
3GB
SDRAM[0].McEmemAdrCfgDev0 = 0x000d0302;
SDRAM[0].McEmemAdrCfgDev1 = 0x000d0302;
SDRAM[0].McEmemCfg = 0x00000c00;
4GB
SDRAM[0].McEmemAdrCfgDev0 = 0x00070302;
SDRAM[0].McEmemAdrCfgDev1 = 0x00070302;
For kernel boot parameters:
3GB
ddr_die=1536M@2048M ddr_die=1536M@3584M
4GB
ddr_die=2048M@2048M ddr_die=2048M@4096M
Thank you edli1983.
Sorry, I made mistake, 3GB is correct.
I tried the settings you told me.
3GB
3GB
and I got below error during TegraBoot.
[0000.159] [TegraBoot] (version 23.00.2015.14-mobile-3a15407d)
[0000.165] Processing in cold boot mode Bootloader 2
[0000.169] A01 Bootrom Patch rev = 63
[0000.173] Power-up reason: software reset
[0000.176] No Battery Present
[0000.179] Platform has Ddr4 type ram
[0000.183] max77620 disabling SD1 Remote Sense
[0000.187] Setting Ddr voltage to 1125mv
[0000.191] Serial Number of Pmic Max77663: 0x208b3
[0000.199] Entering ramdump check
[0000.202] Get RamDumpCarveOut = 0x0
[0000.205] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.210] Last reboot was clean, booting normally!
[0000.215] Sdram initialization is successful
[0000.219] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.224] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.250] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.276] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.281] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.286] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.291] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.297] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.312] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.317] Platform-DebugCarveout: 0
[0000.321] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.351] Using GPT Primary to query partitions
[0000.356] Loading Tboot-CPU binary
[0000.405] Verifying bootloader in OdmNonSecureSBK mode
[0000.415] Bootloader load address is 0xa0000000, entry address is8
[0000.424] Bootloader downloaded successfully.
[0000.428] Downloaded Tboot-CPU binary to 0xa0000258
[0000.434] MAX77620_GPIO1 Configured.
[0000.438] MAX77620_GPIO5 Configured.
[0000.441] CPU power rail is up
[0000.444] CPU clock enabled
[0000.448] Performing RAM repair
[0000.451] Updating A64 Warmreset Address to 0xa00002e9
[0000.468] Bootloader DTB Load Address: 0x83000000
[0000.484] Kernel DTB Load Address: 0x83080000
[0000.489] Loading cboot binary
[0000.583] Verifying bootloader in OdmNonSecureSBK mode
[0000.676] Bootloader load address is 0x8010fda8, entry address is0
[0000.685] Bootloader downloaded successfully.
[0000.690] GPT: Partition NOT found !
[0000.693] Find Partition via GPT Failed
[0000.697] function NvTbootGetBinaryOffsets: 0x845208 error
[0000.702] Error in NvTbootLoadBinary: 0x845208 !
[0000.706] Next binary entry address: 0x80110000
[0000.711] BoardId: 2180
[0000.737] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0000.745] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to sle
[0000.753] NvTbootI2c: Read failed for slave 0xa2, offset 0x00 with error code 0x00045001
[0000.761] Display board id read failed
[0000.765] dram memory type is 3
[0000.769] WB0 init successful
[0000.795] Bpmp Firmware magic Id mismatch
[0000.799] Failed to load Bpmp Fw !
[0000.802] Error is b
Regards,
majin216
The error should not be related to the changes. Would you please double check your software setup.
Do you have an available 4GB memory JTX1 to verify the changes and image?
Yes, Our JTX is modified with HSIO Grypper socket.
I can swap DRAM chips easily.
I’ve followed L4TDocs.
After I edited P2180_A00_LP4_DSC_204Mhz.cfg and extlinux.conf,
I always run the command
$sudo ./flash.sh jetson-tx1 mmcblk0p1
Another 8Gb(512Mx32 Dual Die 4GB) chips are working with 3GB settings.
I confirmed memory capacity is limited to 3GB correctly on L4T R23.2.
But when I swapped with 6Gb(384Mx32 Dual Die 3GB) chips,
JTX is always stopped at “Bpmp Firmware magic ID mismatch”.
Regards,
majin216
We also have 6Gb Quad Die samples and I swapped.
I tried below settings and JTX booted up.
SDRAM[0].McEmemAdrCfgDev0 = 0x000c0302;
SDRAM[0].McEmemAdrCfgDev1 = 0x000c0302;
SDRAM[0].McEmemCfg = 0x00001800;
ddr_die=3072M@3072M ddr_die=3072M@6144M
Would you please provide the exactly memory part number you tried ? Thanks
OK.
Here are the lists I tried
Part Number FBGA Code NumOfDie Density ToalMem
MT53B512M32D2NP-062 WT:C D9TFW(Micron 8Gbit) 2 512M x32 4096MB Boot OK
MT53B768M32D4NQ-062 AIT:B D9VBN(Micron 6Gbit) 4 768M x32 6144MB Boot OK
MT53B384M32D2NP-062 AIT:B D9VBK(Micron 6Gbit) 2 384M x32 3072MB Boot NG
Regards,
majin216
I’m continueing to solve this issue.
I found that our chip has CS0 only. (not 2rank device.)
I changed MC_EMEM_ADR_CFG_0 to 0=N1.
Here is the log.
[0087.094] Starting CPU & Halting co-processor
[0089.194]
[0089.195] Debug Init done
[0089.198] Marked DTB cacheable
[0089.200] Bootloader DTB loaded at 0x83000000
[0089.205] DeviceTree Init done
[0089.222] Pinmux applied successfully
[0089.227] gicd_base: 0x50041000
[0089.231] gicc_base: 0x50042000
[0089.234] Interrupts Init done
[0089.239] Using base:0x60005008 & irq:33 for tick-timer
[0089.244] Using base:0x60005000 for delay-timer
[0089.249] platform_init_timer: DONE
[0089.252] Timer(tick) Init done
[0089.257] osc freq = 38400 khz
[0089.260]
[0089.261] welcome to cboot
[0089.264]
[0089.265] Cboot Version: 23.00.2015.14-t210-9e52ee3e
[0089.270] calling constructors
[0089.273] initializing heap
[0089.276] initializing threads
[0089.279] initializing timers
[0089.281] creating bootstrap completion thread
[0089.286] top of bootstrap2()
[0089.289] CPU: ARM Cortex A57
[0089.292] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0089.296] initializing platform
[0089.323] config for ddr50 mode completed
[0089.326] sdmmc bdev is already initialized
[0089.331] of_register: registering tegra_udc to of_hal
[0089.336] of_register: registering inv20628-driver to of_hal
[0089.341] of_register: registering ads1015-driver to of_hal
[0089.347] of_register: registering lp8557-bl-driver to of_hal
[0089.353] of_register: registering bq2419x_charger to of_hal
[0089.358] of_register: registering cpc to of_hal
[0089.363] of_register: registering bq27441_fuel_gauge to of_hal
[0089.378] gpio framework initialized
[0089.381] of_register: registering tca9539_gpio to of_hal
[0089.387] of_register: registering tca9539_gpio to of_hal
[0089.392] of_register: registering i2c_bus_driver to of_hal
[0089.398] of_register: registering i2c_bus_driver to of_hal
[0089.403] of_register: registering i2c_bus_driver to of_hal
[0089.409] pmic framework initialized
[0089.412] of_register: registering max77620_pmic to of_hal
[0089.418] regulator framework initialized
[0089.422] initializing target
[0089.430] gpio_driver_register: register 'tegra_gpio_driver' driver
[0089.440] fixed regulator driver initialized
[0089.509] initializing OF layer
[0089.514] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0089.536] I2C Bus Init done
[0089.539] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0089.551] I2C Bus Init done
[0089.553] of_children_init: Ops found for compatible string ti,tca9539
[0089.565] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0089.570] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0089.577] of_children_init: Ops found for compatible string ti,tca9539
[0089.588] tca9539_init: i2c bus: 2, slave addr: 0xee
[0089.593] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0089.600] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0089.612] I2C Bus Init done
[0089.615] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0089.627] I2C Bus Init done
[0089.630] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0089.642] I2C Bus Init done
[0089.645] of_children_init: Ops found for compatible string maxim,max77620
[0089.658] max77620_init using irq 118
[0089.662] register 'maxim,max77620' pmic
[0089.666] gpio_driver_register: register 'max77620-gpio' driver
[0089.672] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0089.685] I2C Bus Init done
[0089.688] of_children_init: Ops found for compatible string nvidia,tegra210-udc
[0089.696] calling apps_init()
[0089.702] Found 18 GPT partitions in "sdmmc3_user"
[0089.706] Proceeding to flashing Server
[0089.710] usbdcd_reinit Initialize driver to use already enumerated device
[0089.717] nv3p_priv_usbf_open USB configuration success
[0089.723] Cboot Version 2.0.1.0
[0089.727] Writing GPT partition
[0089.731] Erasing Boot device
[0089.760] Erasing Storage Device
[0090.466] Sanitizing Storage Device
[0090.681] Writing protective mbr
[0090.685] Writing primary GPT
[0090.691] Writing secondary GPT
[0090.696] Found 18 GPT partitions in "sdmmc3_user"
[0090.702] Writing NVC partition
[0090.705] bct_init bctinit
[0090.707] bct_init bctinit
[0090.715] bct_init bctinit
[0090.718] bct_init bctinit
[0090.721] bct_init bctinit
[0090.744] partition NVC write successful.
[0090.749] Writing APP partition
[0119.655] max77620_clear_syswdt clearing watchdog
[0149.657] max77620_clear_syswdt clearing watchdog
[0179.661] max77620_clear_syswdt clearing watchdog
[0202.185] partition APP write successful.
[0202.190] Writing TBC partition
[0202.199] partition TBC write successful.
[0202.204] Writing EBT partition
[0202.229] partition EBT write successful.
[0202.234] Writing BPF partition
[0202.242] partition BPF write successful.
[0202.246] Writing WB0 partition
[0202.251] partition WB0 write successful.
[0202.256] Writing RP1 partition
[0202.272] partition RP1 write successful.
[0202.277] Writing TOS partition
[0202.285] partition TOS write successful.
[0202.290] Writing DTB partition
[0202.306] partition DTB write successful.
[0202.312] Cboot Version 2.0.1.0
[0202.316] Writing BCT partition
[0202.320] bct_init bctinit
[0202.411] partition BCT write successful.
[0202.417] Cboot Version 2.0.1.0
[0202.422] Change state to cold boot mode
[0202.426] Flushing data to stroage
[0000.219] SecureOs Carveout Base=0xbf800000 Size=0x00800000
[0000.224] GSC1 Carveout Base=0xbf700000 Size=0x00100000
[0000.250] GSC2 Carveout Base=0xbf600000 Size=0x00100000
[0000.276] GSC3 Carveout Base=0xbf500000 Size=0x00100000
[0000.281] GSC4 Carveout Base=0xbf400000 Size=0x00100000
[0000.286] GSC5 Carveout Base=0xbf300000 Size=0x00100000
[0000.291] BpmpFw Carveout Base=0xbf2c0000 Size=0x00040000
[0000.297] Lp0 Carveout Base=0xbf2bf000 Size=0x00001000
[0000.312] RamDump Carveout Base=0xbf23f000 Size=0x00080000
[0000.321] Nck Carveout Base=0xbf03f000 Size=0x00200000
[0000.415] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.676] Bootloader load address is 0x8010fda8, entry address is 0x80110000
[0000.745] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0000.795] Bpmp FW successfully loaded
[0000.798] Set NvDecSticky Bits
[0000.802] GSC1 address : bf700000
[0000.805] GSC2 address : bf600000
[0000.809] GSC3 address : bf500000
[0000.813] GSC4 address : bf400000
[0000.817] GSC5 address : bf300000
[0000.820] GSC MC Settings done
[0000.823] TOS old plaintext Image length 61440
[0000.830] *** Secure OS image signature not verified ***
[0000.835] Loading and Validation of Secure OS Successful
[0000.840] NvTbootPackSdramParams: start.
[0000.845] NvTbootPackSdramParams: done.
[0000.848] Tegraboot started after 138001 us
[0000.852] Basic modules init took 329024 us
[0000.856] Sec Bootdevice Read Time = 193 ms, Read Size = 8459 KB
[0000.862] Next stage binary read took 12207 us
[0000.866] Carveout took 251468 us
[0000.870] CPU initialization took 138563 us
[0000.874] Total time taken by TegraBoot 731262 us
[0000.878] Starting CPU & Halting co-processor
64b[0001.014] LPDDR4 Training: Number of tables = 10
[0001.018] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.024] EMC Training Failed
[0001.027] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.033] EMC Training Failed
[0001.035] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.047] EMC Training Failed
[0001.049] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.072] EMC Training Failed
[0001.075] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.096] EMC Training Failed
[0001.099] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.118] EMC Training Failed
[0001.121] Switching to 800000 KHz Success
[0001.155] LPDDR4 Training: Number of tables = 10
It looks all EMC training failed, but I think that’s strange.
I’d like to know appropriate settings for 1CS(1rank) chip,please.
Regards,
majin216
Finally, I succeeded to boot up my jetson with 3GB DRAM chip.
I had misunderstanding.
Indeed, our chip is dual die chip.
But our chip has single rank, 1CS.
So, I changed BCT settings below
SDRAM[0].EmcAdrCfg = 0x00000000;
SDRAM[0].McEmemAdrCfg = 0x00000000;
Thank you and sorry my english is very cheap.
Are you from Micron supplier ? Samsung and Hynix also have LPDDR4 memory could work on JTX1.
