Jetson tk1 boot issue
I have recently purchased a Jetson tk1 . Board is connected to a HDMI monitor and a keyboard.
Board shows the boot messages on the monitor , But unable to show the login screen. I have re-flashed the board with latest OS . But still the system failed to start the login shell.
A freshly flashed system will show some text during boot using one video mode, and then as full boot has finished, switch to another video graphics mode. It wouldn’t be unusual if video auto configuration failed for your particular monitor. I would not be surprised if the system is up and running and you just can’t see the login screen.
One option to see what is going on is to use ssh to log in from another computer. Can you see a DHCP request or network address assignment from your router? If so, ssh in and log in as user ubuntu, pass ubuntu (you can switch to a root shell via “sudo -s”). Then you can check the dmesg for anything related to video failure, as well as the log from “/var/log/Xorg.0.log”.
Alternately the serial console (9-Pin D-Sub connector) tends to survive almost anything and is already logged in as user “ubuntu”. The connection setting is 115200 8N1.
i have tried with serial console. it is also shows the same boot message. but there is no login or shell
Can you use your serial console program and log the boot text? Then paste this (use the code block icon “</>” in the upper right to format the text to use a scroll bar) or attach as a file (can’t do this until the post is actually there, then hovering the mouse over the quote mark in the upper right reveals a paper clip icon which can be used to attaching files) to look at.
Be sure to hit the “enter” key on the serial console once or twice to be sure if no prompt occurs. If possible, do this with flow control off (software flow control) and also with flow control CTS/RTS (a hardware flow control…this should be valid and more reliable than software flow control on a TK1, but it is unlikely to change what happens in this case…it’s just being a bit more certain).
Also, did you flash on command line, or did you use JetPack?
I am using flash command line.
OTF key is successfully generated and Unencrypted key is written to VDE
NvTsecKeyEncryption: entry
NvInitKeyEncryption: entry
TsecInit: entry: MemSize=1700
KeyEncryption: exit
NvInitKeyEncryption: exit
NvTsecKeyEncryption: exit
The proc BoardInfo: 0x0177:0x0000:0x03:0x45:0x00
FastbootAddAtag: setting ATAG (0)
Board Id Read Time: 0 us
Power Rail enable Time: 7649 us
Miscellaneous avp time: 15342  us
Bootloader (AosInit) time: 2422 us
Bootloader Main Init time: 201974 us
BlockDevMgrInit time: 3497 us
PartMgrInit time: 1 us
StorMgrInit time: 4 us
FsMgrInit time: 1 us
Partition Table load: 79707 us
Display init time: 565281 us
Kernel read time: 131 msec
Load Kernel Size:   5912576 Bytes
Bl Kernel ReadSpeed: 45134000 Bytes/sec
Pre-Kernel Jump time: 91872 us
Jumping to kernel at (time stamp): 1759120 us
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.24-gf455cd4 (buildbrain@mobile-u64-532) (gcc version 4.5.3 (crosstool-NG hg_unknown@20110628.165246) ) #1 SMP PREEMPT Wed Jun 18 11:20:52 PDT 2014
[    0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[    0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[    0.000000] Found vpr, start=0xf6900000 size=9700000
[    0.000000] Found tsec, start=0xf4900000 size=2000000[    0.000000] Found tegra_fbmem: 01f60000@ad012000
[    0.000000] Tegra reserved memory:
[    0.000000] LP0:                    f46ff000 - f46ff80f
[    0.000000] Bootloader framebuffer: ad012000 - aef71fff
[    0.000000] Bootloader framebuffer2: 00000000 - 00000000
[    0.000000] Framebuffer:            ef000000 - f01fffff
[    0.000000] 2nd Framebuffer:        f0200000 - f45fffff
[    0.000000] Carveout:               00000000 - 00000000
[    0.000000] Vpr:                    f6900000 - ffffffff
[    0.000000] Tsec:                   f4900000 - f68fffff
[    0.000000] cma: CMA: reserved 16 MiB at ac000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/boot/dts/tegra124-pm375.dts
[    0.000000] Tegra12: CPU Speedo value 2276, Soc Speedo value 2159, Gpu Speedo value 2045
[    0.000000] Tegra12: CPU Speedo ID 1, Soc Speedo ID 1, Gpu Speedo ID 1
[    0.000000] Tegra12: CPU Process ID 1,Soc Process ID 1,Gpu Process ID 1
[    0.000000] Tegra Revision: A01 SKU: 0x81 CPU Process: 1 Core Process: 1
[    0.000000] tegra: PLLP fixed rate: 408000000
[    0.000000] pll_d2: val=00583201 m=1 n=50 p_div=5 input_rate=12000000
[    0.000000] pll_c4: val=00583201 m=1 n=50 p_div=5 input_rate=12000000
[    0.000000] pll_dp: val=00583201 m=1 n=50 p_div=5 input_rate=12000000
[    0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1092000000
[    0.000000] Lowering sbus maximum rate from 408000000 to 384000000
[    0.000000] Lowering vic03 maximum rate from 900000000 to 828000000
[    0.000000] Lowering tsec maximum rate from 900000000 to 828000000
[    0.000000] Lowering msenc maximum rate from 600000000 to 528000000
[    0.000000] Lowering se maximum rate from 600000000 to 528000000
[    0.000000] Lowering vde maximum rate from 600000000 to 528000000
[    0.000000] Lowering host1x maximum rate from 500000000 to 444000000
[    0.000000] Lowering vi maximum rate from 700000000 to 600000000
[    0.000000] Lowering isp maximum rate from 700000000 to 600000000
[    0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[    0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[    0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[    0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[    0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[    0.000000] Lowering nor maximum rate from 127000000 to 102000000
[    0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[    0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[    0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[    0.000000] Lowering cpu_g maximum rate from 3000000000 to 2320500000
[    0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[    0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[    0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[    0.000000] Switching to timer-based delay loop
[    0.000000] tegra_powergate_init: DONE
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1cb5000 s15040 r8192 d13632 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 453136
[    0.000000] Kernel command line: fbcon=map:1 tegraid=40.1.1.0.0 mem=1862M@2048M memtype=255 vpr=151M@3945M tsec=32M@3913M otf_key=7de40c1bbbf4e1e399dc4cb67e2df318 ddr_die=2048M@2048M section=256M commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,3 console=tty1 usbcore.old_scheme_first=1 lp0_vec=2064@0xf46ff000 tegra_fbmem=32899072@0xad012000 core_edp_mv=1150 core_edp_ma=4000 pmuboard=0x0177:0x0000:0x03:0x45:0x00 power_supply=Adapter audio_codec=rt5640 board_info=0x0177:0x0000:0x03:0x45:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt gpt_sector=49151 modem_id=0 android.kerneltype=normal
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1776MB = 1776MB total
[    0.000000] Memory: 1739624k/1739624k available, 167064k reserved, 1040384K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbe800000 - 0xbfe00000   (  22 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0ab1688   (10918 kB)
[    0.000000]       .init : 0xc0ab2000 - 0xc0b2eac0   ( 499 kB)
[    0.000000]       .data : 0xc0b30000 - 0xc0c6f76c   (1278 kB)
[    0.000000]        .bss : 0xc0c6f76c - 0xc0cf707c   ( 543 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:960
[    0.000000] the number of interrupt controllers found is 5
[    0.000000] Architected local timer running at 12.00MHz (phys).
[    0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[    0.000000] Ignoring duplicate/late registration of read_current_timer delay
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.003729] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[    0.003798] pid_max: default: 32768 minimum: 301
[    0.004095] Mount-cache hash table entries: 512
[    0.018484] Initializing cgroup subsys debug
[    0.018528] Initializing cgroup subsys freezer
[    0.018633] CPU: Testing write buffer coherency: ok
[    0.018706] ftrace: allocating 31844 entries in 63 pages
[    0.059758] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.059807] Setting up static identity map for 0xc07a71b8 - 0xc07a7254
[    0.063808] ftrace: Allocated trace_printk buffers
[    0.071509] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.074541] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.077582] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.077775] Brought up 4 CPUs
[    0.077837] SMP: Total of 4 processors activated.
[    0.077854] CPU: All CPU(s) started in SVC mode.
[    0.078713] devtmpfs: initialized
[    0.086001] CPA: inner cache maint threshold=2097152
[    0.087876] pinctrl core: initialized pinctrl subsystem
[    0.088194] regulator-dummy: no parameters
[    0.088888] NET: Registered protocol family 16
[    0.091452] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.091784] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[    0.092461] cpuidle: using governor ladder
[    0.092481] cpuidle: using governor menu
[    0.096017] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[    0.110391] Wake16 for irq=34
[    0.112220] Wake58 for irq=81
[    0.112257] Wake41 for irq=129
[    0.112273] Wake43 for irq=129
[    0.112307] Wake40 for irq=53
[    0.112321] Wake42 for irq=53
[    0.113279] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x03:0x45:0x00
[    0.113364] Selecting UARTD as the debug console
[    0.113407] The debug console clock name is uartd
[    0.113786] ardbeg_modem_init: modem_id = 0
[    0.115361] laguna_as3722_regulator_init: i2c_register_board_info
[    0.115940] Clear bootloader IO dpd settings
[    0.115993] Loading jetson TK1 EMC tables.
[    0.116233] tegra: pll_m is selected as scalable EMC clock source
[    0.116275] Lowering emc maximum rate from 1200000000 to 924000000
[    0.116300] tegra: validated EMC DFS table
[    0.116399] laguna_edp_init: CPU regulator 15000 mA
[    0.454419] laguna_edp_init: GPU regulator 8000 mA
[    0.454455] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[    0.454473] swapper/0 isomgr_init(): max_iso_bw=6504960KB[    0.478424] platform tegradc.0: IOVA linear map 0xef000000(1200000)
[    0.482656] platform tegradc.0: IOVA linear map 0xf0200000(4400000)
[    0.490317] platform tegradc.0: IOVA linear map 0xad012000(1f60000)
[    0.493605] platform tegradc.0: IOVA linear map 0xf6900000(9700000)
[    0.495815] platform tegradc.1: IOVA linear map 0xef000000(1200000)
[    0.500047] platform tegradc.1: IOVA linear map 0xf0200000(4400000)
[    0.507699] platform tegradc.1: IOVA linear map 0xad012000(1f60000)
[    0.510986] platform tegradc.1: IOVA linear map 0xf6900000(9700000)
[    0.511533] soctherm THERMTRIP is not supported on this PMIC
[    0.511782] tegra11_soctherem_oc_int_init(): OC interrupts enabled successful
[    0.512280] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.512309] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.512484] mc-err: Started MC error interface!
[    0.522841] bio: create slab <bio-0> at 0
[    0.525323] vgaarb: loaded
[    0.525981] SCSI subsystem initialized
[    0.526390] usbcore: registered new interface driver usbfs
[    0.526458] usbcore: registered new interface driver hub
[    0.526577] usbcore: registered new device driver usb
[    0.528735] as3722 4-0040: AS3722 with revision 0x1 found
[    0.533659] as3722_sd0: 700 <--> 1300 mV at 1000 mV 3500 mA normal standby
[    0.534761] as3722_sd1: 700 <--> 1350 mV at 1150 mV 2500 mA normal standby
[    0.535108] as3722_sd2: 1350 mV normal standby
[    0.535423] as3722-sd3: no parameters
[    0.535861] as3722_sd4: 1050 mV normal standby
[    0.536492] as3722_sd5: 1800 mV normal standby
[    0.536961] as3722_sd6: applied init 1000000uV constraint
[    0.537554] as3722_sd6: 650 <--> 1200 mV at 1000 mV 3500 mA normal standby
[    0.537905] as3722_ldo0: 1050 <--> 1225 mV at 1050 mV at 300 mA normal standby
[    0.537961] as3722_ldo0: supplied by as3722_sd2
[    0.539429] as3722_ldo1: 1800 mV at 150 mA normal standby
[    0.540296] as3722_ldo2: 1200 mV at 150 mA normal standby
[    0.540354] as3722_ldo2: supplied by as3722_sd5
[    0.541362] as3722_ldo3: 800 mV at 150 mA normal standby
[    0.541841] as3722_ldo4: 2700 mV at 150 mA normal standby
[    0.542311] as3722_ldo5: 1200 mV at 150 mA normal standby
[    0.542363] as3722_ldo5: supplied by as3722_sd5
[    0.542733] as3722_ldo6: 1800 <--> 3300 mV at 150 mA normal standby
[    0.543203] as3722_ldo7: 1050 mV at 150 mA normal standby
[    0.543261] as3722_ldo7: supplied by as3722_sd5
[    0.544391] as3722_ldo9: 3300 mV at 150 mA normal standby
[    0.544864] as3722_ldo10: 2700 mV at 150 mA normal standby
[    0.545352] as3722_ldo11: 1800 mV at 150 mA normal standby
[    0.546336] Linux video capture interface: v2.00
[    0.547377] Advanced Linux Sound Architecture Driver Initialized.
[    0.548256] fixed_reg_battery: 8400 mV normal standby
[    0.548556] fixed_reg_aon_1v8: 1800 mV normal standby
[    0.548852] fixed_reg_aon_3v3: 3300 mV normal standby
[    0.549115] fixed_reg_aon_1v2: 1200 mV normal standby
[    0.549407] fixed_reg_vdd_hdmi_5v0: 5000 mV normal standby
[    0.549697] fixed_reg_vdd_hdmi: 3300 mV normal standby
[    0.549753] fixed_reg_vdd_hdmi: supplied by as3722_sd4
[    0.550038] fixed_reg_vdd_lcd_bl: 3300 mV normal standby
[    0.550300] fixed_reg_lcd_bl_en: 5000 mV normal standby
[    0.550573] fixed_reg_3v3: 3300 mV normal standby
[    0.550959] fixed_reg_5v0: 5000 mV normal standby
[    0.551225] fixed_reg_dcdc_1v8: 1800 mV normal standby
[    0.551918] fixed_reg_as3722_gpio2: 3300 mV normal standby
[    0.552647] fixed_reg_lcd: 3300 mV normal standby
[    0.552922] fixed_reg_sdmmc_en: 3300 mV normal standby
[    0.553195] fixed_reg_vdd_cdc_1v2_aud_pm375: 1200 mV normal standby
[    0.553472] fixed_reg_usb2_vbus_pm359: 5000 mV normal standby
[    0.553796] fixed_reg_usb0_usb1_vbus_pm359: 5000 mV normal standby
[    0.556014] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[    0.559413] tegra: started io power detection dynamic control
[    0.559437] tegra: NO_IO_POWER setting 0x0
[    0.559457] Switching to clocksource arch_sys_counter
[    0.580170] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.580335] nvmap uc page pool size=54875 pages
[    0.603366] nvmap pool = uc, highmem=25600, pool_size=54875,totalram=439002, freeram=410529, totalhigh=260096, freehigh=234364
[    0.604068] nvmap wc page pool size=54875 pages
[    0.627027] nvmap pool = wc, highmem=25600, pool_size=54875,totalram=439002, freeram=384830, totalhigh=260096, freehigh=208665
[    0.628348] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[    0.631971] misc nvmap: created heap vpr base 0xf6900000 size (154624KiB)
[    0.632114] nvmap:inner cache maint threshold=2097152
[    0.641607] Wake39 for irq=52
[    0.641702] tegra-otg tegra-otg: otg transceiver registered
[    0.642018] NET: Registered protocol family 2
[    0.642693] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.642894] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.643093] TCP: Hash tables configured (established 8192 bind 8192)
[    0.643151] TCP: reno registered
[    0.643173] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.643226] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.643508] NET: Registered protocol family 1
[    0.643902] RPC: Registered named UNIX socket transport module.
[    0.643925] RPC: Registered udp transport module.
[    0.643942] RPC: Registered tcp transport module.
[    0.643959] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.648957] host1x host1x: initialized
[    0.650171] CPU PMU: probing PMU on CPU 0
[    0.650203] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[    0.651073] tegra_throttle : init passed
[    0.651163] Tegra cpuquiet initialized: disabled
[    0.651288] cpu-tegra: init EDP limit: 2320 MHz
[    0.652226] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    0.652565] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    0.652834] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[    0.653088] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.654862] bounce pool size: 64 pages
[    0.656134] NTFS driver 2.1.30 [Flags: R/O].
[    0.656276] fuse init (API version 7.22)
[    0.656498] msgmni has been set to 1397
[    0.658047] io scheduler noop registered (default)
[    0.859424] PCIE: port 0: link down, retrying
[    1.059468] PCIE: port 0: link down, retrying
[    1.259507] PCIE: port 0: link down, retrying
[    1.259539] PCIE: port 0: link down, ignoring
[    1.264699] PCI host bridge to bus 0000:00
[    1.264725] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[    1.264751] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[    1.264779] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[    1.264802] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[    1.265209] PCI: bus0: Fast back to back transfers disabled
[    1.265236] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.267576] PCI: bus1: Fast back to back transfers disabled
[    1.267920] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    1.267947] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    1.268207] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[    1.268240] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
[    1.268270] pcieport 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    1.268299] pci 0000:01:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
[    1.268347] pci 0000:01:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
[    1.268392] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    1.268421] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[    1.268444] pcieport 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    1.268471] pcieport 0000:00:00.0:   bridge window [mem 0x32100000-0x321fffff]
[    1.268500] pcieport 0000:00:00.0:   bridge window [mem 0x12100000-0x121fffff 64bit pref]
[    1.268567] PCIE: No Link speed change happened
[    1.269007] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[    1.269120] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[    1.270814] msenc msenc: initialized
[    1.271689] tsec tsec: initialized
[    1.273745] isp isp.0: initialized
[    1.274732] isp isp.1: initialized
[    1.276292] vic03 vic03.0: initialized
[    1.277983] gk20a gk20a.0: initialized
[    1.278806] tegradc tegradc.0: DSI: Failed to get chip info
[    1.278899] tegradc tegradc.0: DSI: HS clock rate is 464500
[    1.280616] p,wuxga-10-1 panel dt support not available
[    1.562983] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[    1.651723] tegradc tegradc.0: DSI pad calibration done
[    1.658274] tegradc tegradc.0: probed
[    1.658672] tegradc tegradc.0: probed
[    1.658903] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[    1.680870] gpio wake4 for gpio=111
[    1.709686] tegradc tegradc.1: nominal-pclk:85506000 parent:342000000 div:4.0 pclk:85500000 84650940~93201540
[    1.710943] tegradc tegradc.1: hdmi: can't set audio to 44100 at 85506000 pix_clock
[    1.711053] tegradc tegradc.1: probed
[    1.745965] Console: switching to colour frame buffer device 170x48
[    1.777601] tegradc tegradc.1: probed
[    1.777978] tegradc tegradc.1: nominal-pclk:85506000 parent:342000000 div:4.0 pclk:85500000 84650940~93201540
[    1.812353] hdmi_state_machine_worker (tid ebad8580): state 0 (Reset), hpd 1, pending_hpd_evt 1
[    1.812807] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 0 (Reset)
[    1.816357] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[    1.817349] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.818926] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[    1.855033] hdmi_state_machine_worker (tid ebad8580): state 0 (Reset), hpd 1, pending_hpd_evt 0
[    1.855037] hdmi_disable_l: audio_switch 0
[    1.855039] hdmi_disable_l: hpd_switch 0
[    1.855045] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.868737] hdmi_state_machine_worker (tid ebad8580): state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    1.868743] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    1.936031] hdmi_state_machine_worker (tid ebad8580): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    1.983139] panel size 41 by 23
[    3.556718] console [ttyS0] enabled
[    3.557309] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[    3.557636] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[    3.557947] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[    3.561902] loop: module loaded
[    3.562198] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[    3.569695] gpio wake35 for gpio=70
[    3.569762] nct1008_nct72 0-004c: nct1008_probe: initialized
[    3.570918] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[    3.581793] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    3.586320] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[    3.587641] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[    3.587653] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pio slum part sadm sds apst
[    3.588882] scsi0 : tegra-sata
[    3.589262] scsi1 : tegra-sata
[    3.589479] ata1: SATA max UDMA/133 irq 55
[    3.589483] ata2: DUMMY
[    3.591459] tun: Universal TUN/TAP device driver, 1.6
[    3.591462] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.591700] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    3.594776] r8169 0000:01:00.0 eth0: RTL8168g/8111g at 0xf017c000, 00:04:4b:2c:20:a0, XID 0c000800 IRQ 641
[    3.594786] r8169 0000:01:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    3.594953] PPP generic driver version 2.4.2
[    3.595298] PPP BSD Compression module registered
[    3.595306] PPP Deflate Compression module registered
[    3.595330] PPP MPPE Compression module registered
[    3.595342] NET: Registered protocol family 24
[    3.595452] usbcore: registered new interface driver asix
[    3.595554] usbcore: registered new interface driver ax88179_178a
[    3.595619] usbcore: registered new interface driver cdc_ether
[    3.595709] usbcore: registered new interface driver smsc95xx
[    3.595774] usbcore: registered new interface driver cdc_subset
[    3.595866] usbcore: registered new interface driver cdc_ncm
[    3.595889] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.596092] tegra USB phy - inst[1] platform info:
[    3.596095] port_otg: no
[    3.596098] has_hostpc: yes
[    3.596101] phy_interface: USB_PHY_INTF_UTMI
[    3.596103] op_mode: TEGRA_USB_OPMODE_HOST
[    3.596106] vbus_gpio: -1
[    3.596109] hot_plug: disabled
[    3.596112] remote_wakeup: enabled
[    3.597935] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[    3.597971] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[    3.598144] Wake40 for irq=53
[    3.598149] Wake42 for irq=53
[    3.598180] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[    3.601579] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[    3.601717] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.601726] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.601734] usb usb1: Product: Tegra EHCI Host Controller
[    3.601741] usb usb1: Manufacturer: Linux 3.10.24-gf455cd4 ehci_hcd
[    3.601749] usb usb1: SerialNumber: tegra-ehci.1
[    3.602644] hub 1-0:1.0: USB hub found
[    3.602672] hub 1-0:1.0: 1 port detected
[    3.603271] tegra USB phy - inst[2] platform info:
[    3.603276] port_otg: no
[    3.603281] has_hostpc: yes
[    3.603286] phy_interface: USB_PHY_INTF_UTMI
[    3.603290] op_mode: TEGRA_USB_OPMODE_HOST
[    3.603295] vbus_gpio: -1
[    3.603300] hot_plug: disabled
[    3.603305] remote_wakeup: enabled
[    3.605096] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[    3.605137] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[    3.605300] Wake41 for irq=129
[    3.605306] Wake43 for irq=129
[    3.605335] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[    3.609587] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[    3.609720] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.609730] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.609738] usb usb2: Product: Tegra EHCI Host Controller
[    3.609745] usb usb2: Manufacturer: Linux 3.10.24-gf455cd4 ehci_hcd
[    3.609752] usb usb2: SerialNumber: tegra-ehci.2
[    3.610586] hub 2-0:1.0: USB hub found
[    3.610612] hub 2-0:1.0: 1 port detected
[    3.611324] ehci-pci: EHCI PCI platform driver
[    3.611782] tegra_xusb_read_usb_calib: usb_calib0 = 0x02c6038b
[    3.612062] usbcore: registered new interface driver cdc_acm
[    3.612065] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.612110] usbcore: registered new interface driver cdc_wdm
[    3.612188] usbcore: registered new interface driver usb-storage
[    3.612297] usbcore: registered new interface driver usbserial
[    3.612352] usbcore: registered new interface driver option
[    3.612397] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.612556] usbcore: registered new interface driver pl2303
[    3.612602] usbserial: USB Serial support registered for pl2303
[    3.612625] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[    3.612843] tegra USB phy - inst[0] platform info:
[    3.612847] port_otg: yes
[    3.612851] has_hostpc: yes
[    3.612856] phy_interface: USB_PHY_INTF_UTMI
[    3.612862] op_mode: TEGRA_USB_OPMODE_DEVICE
[    3.612866] vbus_pmu_irq: 0
[    3.612871] vbus_gpio: -1
[    3.612876] charging: disabled
[    3.612881] remote_wakeup: disabled
[    3.616149] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[    3.616353] otg state changed: SUSPEND --> PERIPHERAL
[    3.618269] usbcore: registered new interface driver xpad
[    3.688314] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[    3.688322] as3722-rtc as3722-rtc.1: RTC interrupt 917
[    3.850498] i2c /dev entries driver
[    3.853874] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[    3.854489] tegra_dtv_probe: probing dtv.
[    3.854861] setup_stream: bufsize = 4096, bufnum = 4
[    3.854862] ar0832_init: ++
[    3.855233] i2c-core: driver [max77387] using legacy suspend method
[    3.855236] i2c-core: driver [max77387] using legacy resume method
[    3.855287] i2c-core: driver [as364x] using legacy suspend method
[    3.855290] i2c-core: driver [as364x] using legacy resume method
[    3.855447] [IMX135] sensor driver loading
[    3.855495] [IMX179] sensor driver loading
[    3.855563] [imx132] sensor driver loading
[    3.855612] [ar0261] sensor driver loading
[    3.855746] usbcore: registered new interface driver uvcvideo
[    3.855748] USB Video Class driver (1.1.1)
[    3.886351] device-mapper: uevent: version 1.0.3
[    3.894581] ata1: SATA link down (SStatus 0 SControl 300)
[    3.906101] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    3.914598] usb 2-1: new low-speed USB device number 2 using tegra-ehci
[    3.921431] sdhci: Secure Digital Host Controller Interface driver
[    3.921434] sdhci: Copyright(c) Pierre Ossman
[    3.921436] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.921779] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[    3.921941] sdhci-tegra sdhci-tegra.3: Speedo value 2159
[    3.921948] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[    3.921981] mmc0: no vqmmc regulator found
[    3.921998] mmc0: no vmmc regulator found
[    3.922002] mmc0: Invalid maximum block size, assuming 512 bytes
[    3.947560] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[    3.947561] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[    3.953828] sdhci-tegra sdhci-tegra.2: Speedo value 2159
[    3.953836] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[    3.953867] mmc1: no vqmmc regulator found
[    3.953883] mmc1: no vmmc regulator found
[    3.953888] mmc1: Invalid maximum block size, assuming 512 bytes
[    3.975557] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[    3.975558] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[    3.975660] gpio wake56 for gpio=170
[    3.975727] gpio wake56 for gpio=170
[    3.975730] Enabling wake56
[    3.978903] tegra-se tegra12-se: tegra_se_probe: complete
[    3.982399] usbcore: registered new interface driver usbhid
[    3.982403] usbhid: USB HID core driver
[    4.051911] usb 2-1: New USB device found, idVendor=03f0, idProduct=034a
[    4.051921] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.051929] usb 2-1: Product: HP Elite USB Keyboard
[    4.051935] usb 2-1: Manufacturer: Chicony
[    4.102750] input: Chicony HP Elite USB Keyboard as /devices/platform/tegra-ehci.2/usb2/2-1/2-1:1.0/input/input0
[    4.103057] hid-generic 0003:03F0:034A.0001: input: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-tegra-ehci.2-1/input0
[    4.156982] input: Chicony HP Elite USB Keyboard as /devices/platform/tegra-ehci.2/usb2/2-1/2-1:1.1/input/input1
[    4.157219] hid-generic 0003:03F0:034A.0002: input: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-tegra-ehci.2-1/input1
[    4.251468] mmc0: BKOPS_EN bit is not set
[    4.325237] usbcore: registered new interface driver snd-usb-audio
[    4.325889] MAX98090 driver built on Jun 18 2014 at 11:18:29
[    4.449163] mmc0: new high speed DDR MMC card at address 0001
[    4.449413] mmcblk mmc0:0001: Card claimed for testing.
[    4.449639] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[    4.449789] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[    4.572148]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[    4.637862] rt5639 0-001c: read 0xfd=0x6
[    5.285838] rt5639 0-001c: ASoC: mux INR Mux has no paths
[    5.285852] rt5639 0-001c: ASoC: mux INL Mux has no paths
[    5.286599] gpio wake49 for gpio=143
[    5.861584] rt5639 0-001c: rt5639_headset_detect RT5639_PWR_ANLG1(0x63) = 0xa814
[    5.863382] rt5639 0-001c: rt5639_headset_detect RT5639_IRQ_CTRL2(0xbe) = 0x0
[    5.948023] rt5639 0-001c: rt5639_headset_detect jack_type = 2
[    5.948428] tegra-snd-rt5639 tegra-snd-rt5639.0:  rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[    5.949102] tegra-snd-rt5639 tegra-snd-rt5639.0:  dit-hifi <-> tegra30-spdif mapping ok
[    5.949973] tegra-snd-rt5639 tegra-snd-rt5639.0:  dit-hifi <-> tegra30-i2s.3 mapping ok
[    5.950713] tegra-snd-rt5639 tegra-snd-rt5639.0:  rt5639-aif1 <-> dit-hifi mapping ok
[    5.951426] tegra-snd-rt5639 tegra-snd-rt5639.0:  dit-hifi <-> dit-hifi mapping ok
[    5.954364] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input2
[    5.956156] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[    5.956157] oprofile: using timer interrupt.
[    5.965541] GACT probability NOT on
[    5.965548] Mirror/redirect action on
[    5.965554] u32 classifier
[    5.965556]     Actions configured
[    5.965562] Netfilter messages via NETLINK v0.30.
[    5.965620] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    6.001097] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    6.001099] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    6.020125] xt_time: kernel timezone is -0000
[    6.020434] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.020620] arp_tables: (C) 2002 David S. Miller
[    6.020659] TCP: cubic registered
[    6.135479] NET: Registered protocol family 10
[    6.192932] mip6: Mobile IPv6
[    6.192970] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    6.193143] sit: IPv6 over IPv4 tunneling driver
[    6.194176] NET: Registered protocol family 17
[    6.194206] NET: Registered protocol family 15
[    6.194234] NET: Registered protocol family 35
[    6.223093] NET: Registered protocol family 37
[    6.223097] NET: Registered protocol family 41
[    6.250906] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    6.287377] Registering SWP/SWPB emulation handler
[    6.287384] last reset is due to software reset
[    6.287384]
[    6.295602] Disabling clocks left on by bootloader:
[    6.295607]    audio_2x
[    6.295625]    audio
[    6.295634]    audio4
[    6.295642]    audio3
[    6.295649]    audio2
[    6.295657]    audio1
[    6.295664]    audio0
[    6.295898]    hdmi_audio
[    6.295909]    entropy
[    6.295934]    dsi2-fixed
[    6.295940]    dsi1-fixed
[    6.295992]    trace
[    6.296008]    bsev
[    6.296122]    cclk_lp
[    6.296142]    pll_x_out0
[    6.296149]    pll_u_12M
[    6.296181]    pll_m_out1
[    6.333846] tegra_dvfs: registered vdd_cpu simon notifier
[    6.334249] Tegra CPU DFLL is initialized with use_dfll = 1
[    6.334309] CPU rate: 696 MHz
[    6.451558] cpu_cold cooling device is registered
[    6.480975] cpu_hot cooling device is registered
[    6.792807] handle_check_edid_l: audio_switch 1
[    6.803181] Display connected, hpd_switch 1
[    6.813246] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 4 (Enabled)
[    7.088828] hdmi_state_machine_worker (tid ebad8580): state 4 (Enabled), hpd 1, pending_hpd_evt 0
[    7.104774] tegra dvfs: tegra sysfs cap interface is initialized
[    7.117377] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[    7.130290] tegra dvfs: registered vdd_gpu simon notifier
[    7.142256] tegra_actmon.emc: Completed initialization (0)
[    7.154300] tegra_actmon.avp: Completed initialization (0)
[    7.166078] tegra_mon.cpu_emc: Completed initialization (0)
[    7.180727] as3722_ldo11: disabling
[    7.190581] as3722_ldo10: disabling
[    7.200299] as3722_ldo9: disabling
[    7.209760] as3722_ldo7: disabling
[    7.219139] as3722_ldo6: disabling
[    7.228362] as3722_ldo5: disabling
[    7.237447] as3722_ldo4: disabling
[    7.246502] as3722_ldo1: disabling
[    7.255641] as3722-sd3: disabling
[    7.265536] gpio wake51 for gpio=128
[    7.275045] input: gpio-keys.2 as /devices/platform/gpio-keys.2/input/input3
[    7.288633] as3722-rtc as3722-rtc.1: setting system clock to 2000-02-01 00:31:08 UTC (949365068)
[    7.303944] ALSA device list:
[    7.312798]   #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[    7.324291]   #1: tegra-rt5639
[    7.334378] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[    7.349478] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[    7.372328] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.387029] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    7.403728] devtmpfs: mounted
[    7.693881] init: plymouth-upstart-bridge main process (114) terminated with status 1
[    7.709779] init: plymouth-upstart-bridge main process ended, respawning
[    7.763989] init: plymouth-upstart-br
I see kernel version 3.10.24-gf455cd4. The latest should be 3.10.40-ga7da876, so your sample rootfs may not be current (the latest R21.5 is much higher quality than previous releases). We’re probably looking at some overlooked detail in setting up the sample rootfs.
The log shows the point of failure is just before it mounts file systems. So here’s what I’d suggest…reflash, but look closely at how the rootfs directory is set up. To start with, any downloads should be from R21.5, found here:
https://developer.nvidia.com/linux-tegra-r215
You need the driver package and sample rootfs for command line. Be sure your host PC runs a native Linux file system, e.g., ext4 found with “df -H -T”. Unpack the driver package, this produces the “Linux_for_Tegra/” directory under which all else is done.
cd to the rootfs directory, and unpack the sample rootfs:
sudo tar xjf /where/ever/it/is/Tegra_Linux_Sample-Root-Filesystem_R21.5.0_armhf.tbz2
cd ..
sudo ./apply_binaries.sh
# Make sure the Jetson is in recovery mode, e.g., see it with "lsusb -d 0955:7140".
sudo ./flash.sh -S 14580MiB jetson-tk1 mmcblk0p1
This should do it…because of your kernel version in that boot log I suspect there was some form of version mismatch going on or an incomplete rootfs.
I have tried with latest version. But The same output.
U-Boot 2014.10-rc2-g3127911 (Jun 07 2016 - 21:00:01)
TEGRA124
Board: NVIDIA Jetson TK1
I2C:   ready
DRAM:  2 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie:   I/O: 0x12000000-0x12010000
tegra-pcie:   non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie:   prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
tegra-pcie: probing port 0, using 2 lanes
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
tegra-pcie: probing port 1, using 1 lanes
In:    serial
Out:   serial
Err:   serial
Net:   RTL8169#0
Warning: RTL8169#0 using MAC address from net device
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
827 bytes read in 160 ms (4.9 KiB/s)
Jetson-TK1 eMMC boot options
1:      primary kernel
Enter choice: 1:        primary kernel
Retrieving file: /boot/zImage
6227528 bytes read in 193 ms (30.8 MiB/s)
append: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
Retrieving file: /boot/tegra124-jetson_tk1-pm375-000-c00-00.dtb
59661 bytes read in 87 ms (668.9 KiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x5f0648 ]
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Using Device Tree in place at 82000000, end 8201190c
Starting kernel ...
[    0.000000] Linux version 3.10.40-ga7da876 (buildbrain@mobile-u64-234) (gcc version 4.5.3 (crosstool-NG hg_unknown@20110628.165246) ) #1 SMP PREEMPT Tue Jun 7 21:05:06 PDT 2016
[    0.000000] Bootloader framebuffer: 00000000 - 00000000
[    0.000000] Framebuffer:            f8500000 - f96fffff
[    0.000000] 2nd Framebuffer:        f9700000 - fdefffff
[    0.000000] Vpr:                    00000000 - 00000000
[    0.000000] cma: CMA: reserved 16 MiB at ae800000
[    0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/boot/dts/tegra124-jetson_tk1-pm375-000-c00-00.dts
[    0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[    0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[    0.000000] Lowering sbus maximum rate from 420000000 to 384000000
[    0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[    0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1df3000 s15168 r8192 d13504 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 490768
[    0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
[    0.000000] Memory: 1923MB = 1923MB total
[    0.000000] Memory: 1920996k/1920996k available, 142364k reserved, 1190908K highmem
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0b5b6cc   (11598 kB)
[    0.000000]       .init : 0xc0b5c000 - 0xc0bd8b40   ( 499 kB)
[    0.000000]       .data : 0xc0bda000 - 0xc0d3b058   (1413 kB)
[    0.000000]        .bss : 0xc0d3b058 - 0xc0dd5f8c   ( 620 kB)
[    0.003841] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[    0.003913] pid_max: default: 32768 minimum: 301
[    0.004210] Mount-cache hash table entries: 512
[    0.027202] Initializing cgroup subsys debug
[    0.027246] Initializing cgroup subsys freezer
[    0.027330] CPU: Testing write buffer coherency: ok
[    0.027402] ftrace: allocating 33483 entries in 66 pages
[    0.069603] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.069648] Setting up static identity map for 0xc08242b8 - 0xc0824354
[    0.073640] ftrace: Allocated trace_printk buffers
[    0.081340] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.084350] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.087394] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.087588] Brought up 4 CPUs
[    0.087653] SMP: Total of 4 processors activated.
[    0.087670] CPU: All CPU(s) started in SVC mode.
[    0.088544] devtmpfs: initialized
[    0.097518] pinctrl core: initialized pinctrl subsystem
[    0.097846] regulator-dummy: no parameters
[    0.098550] NET: Registered protocol family 16
[    0.100926] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.102191] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[    0.103628] console [pstore-1] enabled
[    0.103667] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[    0.104059] cpuidle: using governor ladder
[    0.104083] cpuidle: using governor menu
[    0.107983] ardbeg_camera_auxdata: update camera lookup table.
[    0.116931] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[    0.117324] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[    0.124287] Wake16 for irq=34
[    0.126797] Wake58 for irq=81
[    0.126847] Wake41 for irq=129
[    0.126867] Wake43 for irq=129
[    0.126914] Wake40 for irq=53
[    0.126933] Wake42 for irq=53
[    0.131242] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x45:0x44:0x00
[    0.131366] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x45:0x44:0x00
[    0.131452] Selecting UARTD as the debug console
[    0.131500] The debug console clock name is uartd
[    0.131912] ardbeg_modem_init: modem_id = 0
[    0.134623] Clear bootloader IO dpd settings
[    0.134864] Loading jetson TK1 EMC tables.
[    0.135116] tegra: pll_m is selected as scalable EMC clock source
[    0.135179] Lowering emc maximum rate from 1200000000 to 924000000
[    0.135208] tegra: validated EMC DFS table
[    0.135340] ardbeg_edp_init: CPU regulator 12500 mA
[    0.400282] ardbeg_edp_init: GPU regulator 11400 mA
[    0.401272] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[    0.401294] swapper/0 isomgr_init(): max_iso_bw=7392000KB[    0.401670] ardbeg_touch_init init raydium touch
[    0.401829] Raydium - touch platform_id :  8
[    0.484723] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[    0.488036] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[    0.493079] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[    0.496390] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[    0.496823] FUSE: cp_rev 0 ft_rev 0
[    0.497017] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[    0.497464] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.497497] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.497735] mc-err: Started MC error interface!
[    0.508544] bio: create slab <bio-0> at 0
[    0.510476] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[    0.510513] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[    0.510646] vdd-ac-bat: 8400 mV
[    0.510786] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[    0.510820] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[    0.510955] vdd-3v3-aon: 3300 mV
[    0.511128] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[    0.511162] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[    0.511195] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[    0.511232] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[    0.511263] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[    0.511294] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[    0.511325] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[    0.511356] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[    0.511387] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[    0.511419] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[    0.511552] reg-3v3-supply: 3300 mV
[    0.513210] vgaarb: loaded
[    0.513833] SCSI subsystem initialized
[    0.514235] usbcore: registered new interface driver usbfs
[    0.514304] usbcore: registered new interface driver hub
[    0.514423] usbcore: registered new device driver usb
[    0.517345] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[    0.517375] as3722 4-0040: Final OTP version 1V21
[    0.522209] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[    0.522414] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.522475] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.522528] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.522561] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.522594] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.522625] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.522684] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.522716] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.522748] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.522780] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.522812] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[    0.522843] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.522875] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[    0.522941] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.522974] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.523006] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.523037] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.523072] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.523107] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.523138] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.523192] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[    0.523226] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[    0.523258] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[    0.523290] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[    0.523322] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[    0.523353] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[    0.523411] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.523443] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.523497] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.523529] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.523560] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.523592] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.523622] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[    0.523654] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.523686] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[    0.523717] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.523749] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.523808] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.523839] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.523930] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.523962] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.523994] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[    0.524049] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.524101] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.524132] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.524164] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.524239] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.524272] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.524330] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.524386] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.524418] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.524494] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.524525] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.524557] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.525482] vdd-cpu: 650 <--> 1300 mV at 1000 mV 3500 mA
[    0.526266] vdd-core: applied init 1150000uV constraint
[    0.526871] vdd-core: 700 <--> 1350 mV at 1150 mV 3500 mA
[    0.528081] vddio-ddr: at 1350 mV
[    0.528424] as3722-sd3: no parameters
[    0.529006] avdd-pll-pex: 1050 mV
[    0.530218] vdd-1v8: at 1800 mV
[    0.530589] vdd-gpu: applied init 1000000uV constraint
[    0.531472] vdd-gpu: 650 <--> 1200 mV at 1000 mV 3500 mA
[    0.531989] avdd-pll: at 1050 mV at 300 mA
[    0.533288] vdd-cam: 1800 mV at 150 mA
[    0.533983] avdd-dsi-csi: at 1200 mV at 150 mA
[    0.535233] vdd-rtc: 800 mV at 150 mA
[    0.535733] avdd-cam: 2800 mV at 150 mA
[    0.536233] vdd-1v2-cam: 1175 mV at 150 mA
[    0.536631] vddio-sdmmc-2: 1800 <--> 3300 mV at 150 mA
[    0.537137] vdd-1v1-cam: 1275 mV at 150 mA
[    0.538103] avdd-spi: 3300 mV at 150 mA
[    0.538610] vdd-2v7-cam: 2800 mV at 150 mA
[    0.539123] vpp-fuse: 1800 mV at 150 mA
[    0.540230] Linux video capture interface: v2.00
[    0.541304] Advanced Linux Sound Architecture Driver Initialized.
[    0.541773] ardbeg_wifi_power: 1
[    0.642447] usb0-vbus: 5000 mV
[    0.642756] usb1-usb2-vbus: 5000 mV
[    0.643047] vdd-hdmi: 5000 mV
[    0.643352] avdd-hdmi-pll: 3300 mV
[    0.643403] avdd-hdmi-pll: supplied by avdd-pll-pex
[    0.643572] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[    0.643719] vdd-lcd-bl: 3300 mV
[    0.643879] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[    0.644032] vdd-lcd-bl-en: 5000 mV
[    0.644212] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[    0.644333] reg-5v0-supply: 5000 mV
[    0.644501] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[    0.644536] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[    0.644569] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[    0.644618] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[    0.644650] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[    0.644682] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[    0.644714] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[    0.644745] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[    0.644777] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[    0.644921] reg-1v8-supply: 1800 mV
[    0.645263] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[    0.645418] reg-dcdc-1v2: 1200 mV
[    0.645609] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[    0.645644] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[    0.646241] as3722-gpio2-supply: 3300 mV
[    0.646449] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[    0.646972] as3722-gpio4-supply: 3300 mV
[    0.647286] sdmmc-en-supply: 3300 mV
[    0.647549] vdd-cdc-1v2-aud: 1200 mV
[    0.647706] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[    0.647741] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[    0.647774] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[    0.647896] reg-aon-1v8: 1800 mV
[    0.648059] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[    0.648186] reg-aon-1v2: 1200 mV
[    0.651266] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[    0.654673] tegra: started io power detection dynamic control
[    0.654700] tegra: NO_IO_POWER setting 0x0
[    0.654726] Switching to clocksource arch_sys_counter
[    0.676255] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.676450] nvmap_page_pool_init: Total MB RAM: 1891
[    0.676475] nvmap_page_pool_init: nvmap page pool size: 60543 pages (236 MB)
[    0.676647] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.676839]  iram: dma coherent mem declare 0x40001000,258048
[    0.677654] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[    0.677858] nvmap:inner cache maint threshold=2097152
[    0.687728] Wake39 for irq=52
[    0.687848] tegra-otg tegra-otg: otg transceiver registered
[    0.688210] NET: Registered protocol family 2
[    0.688885] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.689093] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.689296] TCP: Hash tables configured (established 8192 bind 8192)
[    0.689358] TCP: reno registered
[    0.689384] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.689440] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.689733] NET: Registered protocol family 1
[    0.690142] RPC: Registered named UNIX socket transport module.
[    0.690169] RPC: Registered udp transport module.
[    0.690189] RPC: Registered tcp transport module.
[    0.690210] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.690500] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[    0.696228] host1x host1x: initialized
[    0.697478] CPU PMU: probing PMU on CPU 0
[    0.697513] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[    0.698166] tegra_throttle : init passed
[    0.698288] Tegra cpuquiet initialized: disabled
[    0.698427] cpu-tegra: init EDP limit: 2065 MHz
[    0.699431] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    0.699837] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    0.700079] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[    0.700327] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.701891] bounce pool size: 64 pages
[    0.703385] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.703682] NTFS driver 2.1.30 [Flags: R/O].
[    0.703989] fuse init (API version 7.22)
[    0.704227] msgmni has been set to 1457
[    0.705659] io scheduler noop registered (default)
[    0.906954] PCIE: port 0: link down, retrying
[    1.107003] PCIE: port 0: link down, retrying
[    1.307051] PCIE: port 0: link down, retrying
[    1.307073] PCIE: port 0: link down, ignoring
[    1.312234] PCI host bridge to bus 0000:00
[    1.312263] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[    1.312293] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[    1.312324] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[    1.312351] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[    1.312734] PCI: bus0: Fast back to back transfers disabled
[    1.312764] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.314846] PCI: bus1: Fast back to back transfers disabled
[    1.315181] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    1.315211] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    1.315463] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[    1.315498] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
[    1.315532] pcieport 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    1.315564] pci 0000:01:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
[    1.315612] pci 0000:01:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
[    1.315657] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    1.315690] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[    1.315716] pcieport 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    1.315745] pcieport 0000:00:00.0:   bridge window [mem 0x32100000-0x321fffff]
[    1.315777] pcieport 0000:00:00.0:   bridge window [mem 0x12100000-0x121fffff 64bit pref]
[    1.315841] PCIE: No Link speed change happened
[    1.316403] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[    1.316512] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[    1.317402] tsec tsec: initialized
[    1.318944] isp isp.0: initialized
[    1.319932] isp isp.1: initialized
[    1.321514] falcon vic03.0: initialized
[    1.322731] falcon msenc: initialized
[    1.323555] tegradc tegradc.0: DSI: HS clock rate is 464500
[    1.324929] p,wuxga-10-1 panel dt support not available
[    1.604712] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[    1.693970] tegradc tegradc.0: DSI pad calibration done
[    1.701118] tegradc tegradc.0: probed
[    1.701595] tegradc tegradc.0: fb registered
[    1.701617] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[    1.707482] gpio wake4 for gpio=111
[    1.735415] tegradc tegradc.1: nominal-pclk:85506000 parent:342000000 div:4.0 pclk:85500000 84650940~93201540
[    1.736718] tegradc tegradc.1: probed
[    1.748651] Console: switching to colour frame buffer device 170x48
[    1.758391] tegradc tegradc.1: fb registered
[    1.758503] hdmi_state_machine_worker (tid edb0c080): state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[    1.758683] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[    1.761857] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[    1.762678] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.764116] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[    1.799903] hdmi_state_machine_worker (tid edb0c080): state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    1.799910] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    1.871452] hdmi_state_machine_worker (tid edb0c080): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    1.920340] panel size 41 by 23
[    4.072455] console [ttyS0] enabled
[    4.072592] tegradc tegradc.1: nominal-pclk:85506000 parent:342000000 div:4.0 pclk:85500000 84650940~93201540
[    4.073119] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[    4.073434] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[    4.073742] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[    4.079868] loop: module loaded
[    4.080173] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[    4.084030] gpio wake35 for gpio=70
[    4.084096] nct1008_nct72 0-004c: nct1008_probe: initialized
[    4.084722] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[    4.085805] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    4.087806] tegra_profiler: Branch: Dev
[    4.087808] tegra_profiler: Version: 1.103
[    4.087812] tegra_profiler: Samples version: 34
[    4.087814] tegra_profiler: IO version: 18
[    4.087821] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[    4.088008] tegra_profiler: auth: init
[    4.088403] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[    4.089901] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[    4.089913] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[    4.091153] scsi0 : tegra-sata
[    4.091547] scsi1 : tegra-sata
[    4.091767] ata1: SATA max UDMA/133 irq 55
[    4.091770] ata2: DUMMY
[    4.093842] tun: Universal TUN/TAP device driver, 1.6
[    4.093846] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.094099] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    4.096621] r8169 0000:01:00.0 eth0: RTL8168g/8111g at 0xf0000000, 00:04:4b:2c:20:a0, XID 0c000800 IRQ 641
[    4.096629] r8169 0000:01:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    4.096772] usbcore: registered new interface driver asix
[    4.096841] usbcore: registered new interface driver ax88179_178a
[    4.096877] usbcore: registered new interface driver cdc_ether
[    4.096927] usbcore: registered new interface driver smsc95xx
[    4.096964] usbcore: registered new interface driver cdc_subset
[    4.097040] usbcore: registered new interface driver cdc_ncm
[    4.097056] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.097266] tegra USB phy - inst[1] platform info:
[    4.097269] port_otg: no
[    4.097277] has_hostpc: yes
[    4.097280] phy_interface: USB_PHY_INTF_UTMI
[    4.097283] op_mode: TEGRA_USB_OPMODE_HOST
[    4.097285] qc2_voltage: 0
[    4.097289] vbus_gpio: -1
[    4.097291] hot_plug: disabled
[    4.097294] remote_wakeup: enabled
[    4.098848] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[    4.098879] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[    4.098977] Wake40 for irq=53
[    4.098980] Wake42 for irq=53
[    4.099003] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[    4.102832] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[    4.102921] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.102928] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.102935] usb usb1: Product: Tegra EHCI Host Controller
[    4.102940] usb usb1: Manufacturer: Linux 3.10.40-ga7da876 ehci_hcd
[    4.102946] usb usb1: SerialNumber: tegra-ehci.1
[    4.103485] hub 1-0:1.0: USB hub found
[    4.103504] hub 1-0:1.0: 1 port detected
[    4.103889] tegra USB phy - inst[2] platform info:
[    4.103892] port_otg: no
[    4.103895] has_hostpc: yes
[    4.103898] phy_interface: USB_PHY_INTF_UTMI
[    4.103900] op_mode: TEGRA_USB_OPMODE_HOST
[    4.103903] qc2_voltage: 0
[    4.103905] vbus_gpio: -1
[    4.103907] hot_plug: disabled
[    4.103910] remote_wakeup: enabled
[    4.105362] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[    4.105384] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[    4.105474] Wake41 for irq=129
[    4.105477] Wake43 for irq=129
[    4.105497] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[    4.108836] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[    4.108914] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.108921] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.108926] usb usb2: Product: Tegra EHCI Host Controller
[    4.108932] usb usb2: Manufacturer: Linux 3.10.40-ga7da876 ehci_hcd
[    4.108937] usb usb2: SerialNumber: tegra-ehci.2
[    4.109422] hub 2-0:1.0: USB hub found
[    4.109440] hub 2-0:1.0: 1 port detected
[    4.109847] ehci-pci: EHCI PCI platform driver
[    4.110121] tegra_xusb_read_usb_calib: usb_calib0 = 0x02c6038b
[    4.110367] usbcore: registered new interface driver usb-storage
[    4.110472] usbcore: registered new interface driver usbserial
[    4.110511] usbcore: registered new interface driver option
[    4.110543] usbserial: USB Serial support registered for GSM modem (1-port)
[    4.110646] usbcore: registered new interface driver pl2303
[    4.110676] usbserial: USB Serial support registered for pl2303
[    4.110689] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[    4.110863] tegra USB phy - inst[0] platform info:
[    4.110865] port_otg: yes
[    4.110868] has_hostpc: yes
[    4.110870] phy_interface: USB_PHY_INTF_UTMI
[    4.110873] op_mode: TEGRA_USB_OPMODE_DEVICE
[    4.110875] qc2_voltage: 0
[    4.110878] vbus_pmu_irq: 0
[    4.110880] vbus_gpio: -1
[    4.110883] charging: enabled
[    4.110885] remote_wakeup: disabled
[    4.113668] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[    4.150956] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[    4.150964] as3722-rtc as3722-rtc.1: RTC interrupt 449
[    4.242891] i2c /dev entries driver
[    4.244139] virtual_init
[    4.246206] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[    4.247033] tegra_dtv_probe: probing dtv.
[    4.247402] setup_stream: bufsize = 4096, bufnum = 4
[    4.247402] ar0832_init: ++
[    4.247762] i2c-core: driver [max77387] using legacy suspend method
[    4.247765] i2c-core: driver [max77387] using legacy resume method
[    4.247834] i2c-core: driver [as364x] using legacy suspend method
[    4.247837] i2c-core: driver [as364x] using legacy resume method
[    4.247988] [IMX135] sensor driver loading
[    4.248036] [IMX179] sensor driver loading
[    4.248082] [IMX185] sensor driver loading
[    4.248131] [imx132] sensor driver loading
[    4.248177] [AR0330] sensor driver loading
[    4.248225] [ar0261] sensor driver loading
[    4.248273] [AR1335] sensor driver loading
[    4.248320] [ov4689] sensor driver loading
[    4.249205] usbcore: registered new interface driver uvcvideo
[    4.249208] USB Video Class driver (1.1.1)
[    4.250114] zram: Created 1 device(s) ...
[    4.251322] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[    4.251503] WDT heartbeat enabled on probe
[    4.251506] tegra_wdt_probe done
[    4.251848] sdhci: Secure Digital Host Controller Interface driver
[    4.251850] sdhci: Copyright(c) Pierre Ossman
[    4.251853] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.252217] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[    4.252375] sdhci-tegra sdhci-tegra.3: Speedo value 2159
[    4.252384] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[    4.264826] otg state changed: SUSPEND --> PERIPHERAL
[    4.396848] ata1: SATA link down (SStatus 0 SControl 300)
[    4.420844] usb 2-1: new full-speed USB device number 2 using tegra-ehci
[    4.491425] usb 2-1: New USB device found, idVendor=03eb, idProduct=0902
[    4.491434] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    4.491440] usb 2-1: Product: USB 2.0 Hub
[    4.497482] hub 2-1:1.0: USB hub found
[    4.503159] hub 2-1:1.0: 4 ports detected
[    4.900466] usb 2-1.1: new low-speed USB device number 3 using tegra-ehci
[    4.975877] usb 2-1.1: New USB device found, idVendor=03f0, idProduct=034a
[    4.975885] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.975891] usb 2-1.1: Product: HP Elite USB Keyboard
[    4.975897] usb 2-1.1: Manufacturer: Chicony
[    5.066615] usb 2-1.2: new full-speed USB device number 4 using tegra-ehci
[    5.129737] usb 2-1.2: not running at top speed; connect to a high speed hub
[    5.259329] usb 2-1.2: New USB device found, idVendor=046d, idProduct=0825
[    5.259349] handle_check_edid_l: audio_switch 1
[    5.259366] Display connected, hpd_switch 1
[    5.259371] handle_check_edid_l: setting audio and infoframes
[    5.259385] tegradc tegradc.1: hdmi: can't set audio to 44100 at 85506000 pix_clock
[    5.259422] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 4 (Enabled)
[    5.259456] hdmi_state_machine_worker (tid edb0c080): state 4 (Enabled), hpd 1, pending_hpd_evt 0
[    5.326998] usb 2-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[    5.327004] usb 2-1.2: SerialNumber: A4D7B6C0
[    5.327298] mmc0: no vqmmc regulator found
[    5.327315] mmc0: no vmmc regulator found
[    5.327319] mmc0: Invalid maximum block size, assuming 512 bytes
[    5.328778] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
[    5.355569] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[    5.355570] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[    5.363748] sdhci-tegra sdhci-tegra.2: Speedo value 2159
[    5.363756] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[    5.442876] input: UVC Camera (046d:0825) as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.2/2-1.2:1.0/input/input0
[    5.457075] mmc1: no vqmmc regulator found
[    5.465007] mmc1: no vmmc regulator found
[    5.472849] mmc1: Invalid maximum block size, assuming 512 bytes
[    5.482679] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found[    5.505801] mmc0: BKOPS_EN bit is not set
[    5.518986] sdhci-tegra sdhci-tegra.3: Found T2T coeffs data
[    5.523841] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[    5.524035] gpio wake56 for gpio=170
[    5.528181] tegra-se tegra12-se: tegra_se_probe: complete
[    5.556677] usb 2-1.3: new full-speed USB device number 5 using tegra-ehci
[    5.556743] sdhci-tegra sdhci-tegra.3: 200MHz tap hole coeffs found
[    5.564618] input: Chicony HP Elite USB Keyboard as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.1/2-1.1:1.0/input/input1
[    5.564881] hid-generic 0003:03F0:034A.0001: input: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-tegra-ehci.2-1.1/input0
[    5.576914] input: Chicony HP Elite USB Keyboard as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.1/2-1.1:1.1/input/input2
[    5.577123] hid-generic 0003:03F0:034A.0002: input: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-tegra-ehci.2-1.1/input1
[    5.577201] usbcore: registered new interface driver usbhid
[    5.577204] usbhid: USB HID core driver
[    5.577660] tegra-hier-ictlr tegra-hier-ictlr: probed
[    5.695540] usb 2-1.3: New USB device found, idVendor=046d, idProduct=c52e
[    5.706799] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.718457] usb 2-1.3: Product: USB Receiver
[    5.727104] usb 2-1.3: Manufacturer: Logitech
[    5.741378] input: Logitech USB Receiver as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.3/2-1.3:1.0/input/input3
[    5.756256] hid-generic 0003:046D:C52E.0003: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-tegra-ehci.2-1.3/input0
[    5.777860] input: Logitech USB Receiver as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.3/2-1.3:1.1/input/input4
[    5.793119] hid-generic 0003:046D:C52E.0004: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-tegra-ehci.2-1.3/input1
[    5.885526] usb 2-1.4: new full-speed USB device number 6 using tegra-ehci
[    5.915537] usb 2-1.4: not running at top speed; connect to a high speed hub
[    5.946540] usb 2-1.4: New USB device found, idVendor=148f, idProduct=5370
[    5.958217] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.970305] usb 2-1.4: Product: 802.11 n WLAN
[    5.979398] usb 2-1.4: Manufacturer: Ralink
[    5.988304] usb 2-1.4: SerialNumber: 1.0
[    6.102343] **********Auto tuning windows*************
[    6.112171] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[    6.122291] win[0]: 1(0) - 81(1)
[    6.122295] win[1]: 88(0) - 167(1)
[    6.122300] win[2]: 175(0) - 255(1)
[    6.122308] ***************************************
[    6.122315] ********tuning windows after inserting holes*****
[    6.122318] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[    6.122322] win[0]:1(0) - 45(2)
[    6.122326] win[1]:47(2) - 81(1)
[    6.122329] win[2]:88(0) - 131(2)
[    6.122333] win[3]:133(2) - 167(1)
[    6.122337] win[4]:175(0) - 217(2)
[    6.122341] win[5]:219(2) - 255(1)
[    6.122343] ***********************************************
[    6.122348] **********Tuning values*********
[    6.122350] **estimated values**
[    6.122355] T2T_Vmax 60, T2T_Vmin 84, 1'st_hole_Vmax 44, UI_Vmax 83
[    6.122357] **Calculated values**
[    6.122361] T2T_Vmax 58, 1'st_hole_Vmax 46, UI_Vmax 86
[    6.122364] T2T_Vmin 58, 1'st_hole_Vmin 46, UI_Vmin 86
[    6.122366] ***********************************
[    6.122373] ***********final tuning windows**********
[    6.122376] win[0]: 18 - 36
[    6.122379] win[1]: 57 - 64
[    6.122382] win[2]: 105 - 116
[    6.122385] win[3]: 149 - 150
[    6.122388] win[4]: 192 - 196
[    6.122392] win[5]: 241 - 238
[    6.122394] ********************************
[    6.122399] best tap win - (18-36), best tap value 27 prev_best_tap 0
[    6.665838] **********Auto tuning windows*************
[    6.673891] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[    6.682278] win[0]: 1(0) - 81(1)
[    6.688376] win[1]: 88(0) - 168(1)
[    6.694604] win[2]: 175(0) - 255(1)
[    6.700910] ***************************************
[    6.700916] ********tuning windows after inserting holes*****
[    6.700918] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[    6.700923] win[0]:1(0) - 46(2)
[    6.700932] win[1]:48(2) - 81(1)
[    6.700935] win[2]:88(0) - 133(2)
[    6.700939] win[3]:135(2) - 168(1)
[    6.700942] win[4]:175(0) - 220(2)
[    6.700946] win[5]:222(2) - 255(1)
[    6.700948] ***********************************************
[    6.700951] **********Tuning values*********
[    6.700953] **estimated values**
[    6.700958] T2T_Vmax 60, T2T_Vmin 84, 1'st_hole_Vmax 44, UI_Vmax 83
[    6.700960] **Calculated values**
[    6.700964] T2T_Vmax 57, 1'st_hole_Vmax 47, UI_Vmax 87
[    6.700968] T2T_Vmin 57, 1'st_hole_Vmin 47, UI_Vmin 87
[    6.700970] ***********************************
[    6.700976] ***********final tuning windows**********
[    6.700979] win[0]: 18 - 37
[    6.700982] win[1]: 58 - 64
[    6.700985] win[2]: 105 - 118
[    6.700989] win[3]: 151 - 151
[    6.700992] win[4]: 192 - 199
[    6.700995] win[5]: 244 - 238
[    6.700997] ********************************
[    6.701002] best tap win - (18-37), best tap value 27 prev_best_tap 27
[    6.701012] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 27
[    6.742041] mmc0: new HS200 MMC card at address 0001
[    6.742258] mmcblk mmc0:0001: Card claimed for testing.
[    6.742470] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[    6.742622] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[    6.814298]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    7.389565] set resolution quirk: cval->res = 384
[    7.397241] usbcore: registered new interface driver snd-usb-audio
[    7.406434] MAX98090 driver built on Jun  7 2016 at 21:02:54
[    7.415315] tegra_offload_platform probe successfull.
[    7.423286] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[    7.696433] rt5639 0-001c: read 0xfd=0x6
[    7.719547] rt5639 0-001c: ASoC: mux INR Mux has no paths
[    7.727678] rt5639 0-001c: ASoC: mux INL Mux has no paths
[    7.736438] gpio wake49 for gpio=143
[    8.744908] rt5639 0-001c: rt5639_headset_detect RT5639_PWR_ANLG1(0x63) = 0xa814
[    8.755308] rt5639 0-001c: rt5639_headset_detect RT5639_IRQ_CTRL2(0xbe) = 0x0
[    8.827336] rt5639 0-001c: rt5639_headset_detect jack_type = 2
[    8.836221] tegra-snd-rt5639 tegra-snd-rt5639.0:  rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[    8.847625] tegra-snd-rt5639 tegra-snd-rt5639.0:  dit-hifi <-> tegra30-spdif mapping ok
[    8.858855] tegra-snd-rt5639 tegra-snd-rt5639.0:  dit-hifi <-> tegra30-i2s.3 mapping ok
[    8.870099] tegra-snd-rt5639 tegra-snd-rt5639.0:  rt5639-aif1 <-> dit-hifi mapping ok
[    8.881282] tegra-snd-rt5639 tegra-snd-rt5639.0:  dit-hifi <-> dit-hifi mapping ok
[    8.891950] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[    8.902100] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[    8.912052] tegra-snd-rt5639 tegra-snd-rt5639.0:  snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[    8.924185] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mapping ok
[    8.934614] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[    8.944936] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[    8.955127] tegra-snd-rt5639 tegra-snd-rt5639.0:  snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[    8.967484] tegra-snd-rt5639 tegra-snd-rt5639.0:  rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[    8.981852] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card2/input5
[    8.995227] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[    9.004737] oprofile: using timer interrupt.
[    9.015382] GACT probability NOT on
[    9.021923] Mirror/redirect action on
[    9.028622] u32 classifier
[    9.034365]     Actions configured
[    9.040836] Netfilter messages via NETLINK v0.30.
[    9.048684] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    9.058331] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    9.068513] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    9.077872] xt_time: kernel timezone is -0000
[    9.085842] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.094648] arp_tables: (C) 2002 David S. Miller
[    9.102660] TCP: cubic registered
[    9.109482] NET: Registered protocol family 10
[    9.118208] mip6: Mobile IPv6
[    9.124461] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    9.133240] sit: IPv6 over IPv4 tunneling driver
[    9.142090] NET: Registered protocol family 17
[    9.149824] NET: Registered protocol family 15
[    9.157574] NET: Registered protocol family 35
[    9.165290] NET: Registered protocol family 37
[    9.172841] NET: Registered protocol family 41
[    9.181639] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    9.215970] Registering SWP/SWPB emulation handler
[    9.223809] last reset is due to power on reset
[    9.223809]
[    9.235770] Disabling clocks left on by bootloader:
[    9.243587]    audio_2x
[    9.249006]    audio
[    9.254106]    audio4
[    9.259238]    audio3
[    9.264338]    audio2
[    9.269480]    audio1
[    9.274442]    audio0
[    9.279460]    hdmi_audio
[    9.284735]    entropy
[    9.289716]    dsi2-fixed
[    9.294918]    dsi1-fixed
[    9.300127]    nor
[    9.304738]    trace
[    9.309423]    sdmmc4_ddr
[    9.314444]    sdmmc3_ddr
[    9.319426]    cclk_lp
[    9.324141]    pll_x_out0
[    9.329050]    pll_m_out1
[    9.334007] tegra_dvfs: vdd_cpu connected to regulator
[    9.341453] tegra_dvfs: vdd_core connected to regulator
[    9.348895] tegra_dvfs: vdd_gpu connected to regulator
[    9.357395] cpu_cold cooling device is registered
[    9.364295] cpu_hot cooling device is registered
[    9.364379] Tegra CPU DFLL is initialized with use_dfll = 1
[    9.364440] CPU rate: 696 MHz
[    9.544944] tegra dvfs: tegra sysfs cap interface is initialized
[    9.552910] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[    9.561823] tegra_actmon.emc: Completed initialization (0)
[    9.569471] tegra_actmon.avp: Completed initialization (0)
[    9.576884] tegra_mon.cpu_emc: Completed initialization (0)
[    9.586944] reg-aon-1v2: incomplete constraints, leaving on
[    9.594323] reg-aon-1v8: incomplete constraints, leaving on
[    9.601729] sdmmc-en-supply: incomplete constraints, leaving on
[    9.609477] reg-dcdc-1v2: incomplete constraints, leaving on
[    9.616963] reg-5v0-supply: incomplete constraints, leaving on
[    9.624681] usb0-vbus: incomplete constraints, leaving on
[    9.631981] vpp-fuse: incomplete constraints, leaving on
[    9.639138] vdd-2v7-cam: incomplete constraints, leaving on
[    9.646624] avdd-spi: incomplete constraints, leaving on
[    9.653844] vdd-1v1-cam: incomplete constraints, leaving on
[    9.661587] vddio-sdmmc-2: incomplete constraints, leaving on
[    9.669409] vdd-1v2-cam: incomplete constraints, leaving on
[    9.677098] avdd-cam: incomplete constraints, leaving on
[    9.684522] vdd-cam: incomplete constraints, leaving on
[    9.691837] as3722-sd3: incomplete constraints, leaving on
[    9.699369] vdd-3v3-aon: incomplete constraints, leaving on
[    9.707048] vdd-ac-bat: incomplete constraints, leaving on
[    9.714647] regulator-dummy: incomplete constraints, leaving on
[    9.723485] gpio wake51 for gpio=128
[    9.729403] input: gpio-keys.3 as /devices/platform/gpio-keys.3/input/input6
[    9.739461] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 01:19:05 UTC (946689545)
[    9.751472] ALSA device list:
[    9.756345]   #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[    9.763719]   #1: USB Device 0x46d:0x825 at usb-tegra-ehci.2-1.2, full speed
[    9.772925]   #2: tegra-rt5639
[    9.779082] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[    9.791404] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[    9.847360] EXT4-fs (mmcblk0p1): recovery complete
[    9.855950] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    9.866993] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    9.879613] devtmpfs: mounted
[    9.885933] Freeing unused kernel memory: 496K (c0b5c000 - c0bd8000)
[   10.145775] init: plymouth-upstart-bridge main process (119) terminated with status 1
[   10.157674] init: plymouth-upstart-bridge main process ended, respawning
[   10.206249] init: plymouth-upstart-bridge main process (129) terminated with status 1
[   10.218056] init: plymouth-upstart-bridge main process ended, respawning
[   10.229971] init: ureadahead main process (122) terminated with status 5
[   10.276808] init: plymouth-upstart-bridge main process (132) terminated with status 1
[   10.288660] init: plymouth-upstart-bridge main process ended, respawning
This latest log shows a correct kernel, and I believe your flash procedure was probably correct. Once more though, it fails when it should mount the ext4 file system. Can you check your host’s “/etc/mke2fs.conf” (post a copy of the ext4 part of the conf file)? It is very likely the ext4 section contains 64-bit extensions which we can get around by editing flash.sh.
My host os is Debian GNU/Linux 8 ( Jessie) . mke2fs conf is
[defaults]
	base_features = sparse_super,filetype,resize_inode,dir_index,ext_attr
	default_mntopts = acl,user_xattr
	enable_periodic_fsck = 0
	blocksize = 4096
	inode_size = 256
	inode_ratio = 16384
[fs_types]
	ext3 = {
		features = has_journal
	ext4 = {
		features = has_journal,extent,huge_file,flex_bg,uninit_bg,dir_nlink,extra_isize
		auto_64-bit_support = 1
		inode_size = 256
	ext4dev = {
		inode_size = 256
		options = test_fs=1
	small = {
		blocksize = 1024
		inode_size = 128
		inode_ratio = 4096
	floppy = {
		blocksize = 1024
		inode_size = 128
		inode_ratio = 8192
	big = {
		inode_ratio = 32768
	huge = {
		inode_ratio = 65536
	news = {
		inode_ratio = 4096
	largefile = {
		inode_ratio = 1048576
		blocksize = -1
	largefile4 = {
		inode_ratio = 4194304
		blocksize = -1
	hurd = {
	     blocksize = 4096
	     inode_size = 128
I have tried with ubuntu 14.04 and flashed the kit using jetpack. It is working perfectly.
It is interesting that the mke2fs.conf does not show any of the problematic 64-bit extensions. There may be some other file system creation issue on the host which failed to mount the partition, but I guess since your Ubuntu 14.04 install worked there is no reason to dig deeper.
