Hi, not sure what I did, but after actively working on a Jetson Tegra K1 board for a few months,
I noticed that one day it would not work with any HDMI monitor (i.e. no signal found)and the eth0 would
no longer show up in ifconfig anymore (checked with my RS-232 debug cable).
Can anybody check my boot up log and see if there’s something that can be done to fix this?
Or is this a hardware error?
I tried to reflash the OS but it didn’t help as I think the issue is either around
hardware and the bootloading.
Here’s the RS-232 log bootup:
ubuntu@tegra-ubuntu:~$
U-Boot SPL 2014.10-rc2-00006-g565af3f (Feb 02 2015 - 17:46:25)
U-Boot 2014.10-rc2-00006-g565af3f (Feb 02 2015 - 17:46:25)
TEGRA124
Board: NVIDIA Jetson TK1
I2C: ready
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x12000000-0x12010000
tegra-pcie: non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie: prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
ERROR: tegra-pcie: failed to power on PHY: -110
at /dvs/git/dirty/git-master_linux/3rdparty/u-boot/drivers/pci/pci_tegra.c:740/tegra_pcie_enable_controller()
ERROR: tegra-pcie: failed to enable controller
at /dvs/git/dirty/git-master_linux/3rdparty/u-boot/drivers/pci/pci_tegra.c:1055/process_nodes()
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
813 bytes read in 301 ms (2 KiB/s)
Jetson-TK1 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/zImage
6168336 bytes read in 191 ms (30.8 MiB/s)
append: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00t
Retrieving file: /boot/tegra124-jetson_tk1-pm375-000-c00-00.dtb
57167 bytes read in 149 ms (374 KiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x5e1f10 ]
Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 82010f4e
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-gc017b03 (buildbrain@mobile-u64-720) (gcc version 4.5.3 (crosstool-NG hg_unknown@20110628.165246) ) #1 SMP PREEMPT Mon Feb 2 17:50:48 PST 2015
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f8500000 - f96fffff
[ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/boot/dts/tegra124-jetson_tk1-pm375-000-c00-00.dts
[ 0.000000] Tegra12: CPU Speedo value 2362, Soc Speedo value 2304, Gpu Speedo value 2112
[ 0.000000] Tegra12: CPU Speedo ID 1, Soc Speedo ID 1, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 1,Soc Process ID 1,Gpu Process ID 1
[ 0.000000] Tegra Revision: A01 SKU: 0x81 CPU Process: 1 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1092000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 384000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 828000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 828000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 528000000
[ 0.000000] Lowering se maximum rate from 600000000 to 528000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 528000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 444000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2320500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df2000 s15360 r8192 d13312 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 490768
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=t
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1923MB = 1923MB total
[ 0.000000] Memory: 1921000k/1921000k available, 142360k reserved, 1190908K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b3cd00 (11476 kB)
[ 0.000000] .init : 0xc0b3d000 - 0xc0bbbc00 ( 507 kB)
[ 0.000000] .data : 0xc0bbc000 - 0xc0d14ef0 (1380 kB)
[ 0.000000] .bss : 0xc0d14ef0 - 0xc0d9fccc ( 556 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.003786] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.003856] pid_max: default: 32768 minimum: 301
[ 0.004155] Mount-cache hash table entries: 512
[ 0.026342] Initializing cgroup subsys debug
[ 0.026388] Initializing cgroup subsys freezer
[ 0.026473] CPU: Testing write buffer coherency: ok
[ 0.026544] ftrace: allocating 33073 entries in 65 pages
[ 0.067870] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.067915] Setting up static identity map for 0xc080bc30 - 0xc080bcd4
[ 0.071913] ftrace: Allocated trace_printk buffers
[ 0.077588] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080595] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.083638] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.083831] Brought up 4 CPUs
[ 0.083895] SMP: Total of 4 processors activated.
[ 0.083912] CPU: All CPU(s) started in SVC mode.
[ 0.084771] devtmpfs: initialized
[ 0.093949] pinctrl core: initialized pinctrl subsystem
[ 0.094268] regulator-dummy: no parameters
[ 0.094972] NET: Registered protocol family 16
[ 0.097359] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.098664] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.100041] console [pstore-1] enabled
[ 0.100082] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[ 0.100460] cpuidle: using governor ladder
[ 0.100484] cpuidle: using governor menu
[ 0.104363] ardbeg_camera_auxdata: update camera lookup table.
[ 0.113339] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.113736] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.120457] Wake16 for irq=34
[ 0.122892] Wake58 for irq=81
[ 0.122941] Wake41 for irq=129
[ 0.122961] Wake43 for irq=129
[ 0.123004] Wake40 for irq=53
[ 0.123022] Wake42 for irq=53
[ 0.127314] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x03:0x45:0x00
[ 0.127414] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x03:0x45:0x00
[ 0.127497] Selecting UARTD as the debug console
[ 0.127544] The debug console clock name is uartd
[ 0.127954] ardbeg_modem_init: modem_id = 0
[ 0.130594] Clear bootloader IO dpd settings
[ 0.130827] Loading jetson TK1 EMC tables.
[ 0.131086] tegra: pll_m is selected as scalable EMC clock source
[ 0.131130] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.131158] tegra: validated EMC DFS table
[ 0.131288] ardbeg_edp_init: CPU regulator 11000 mA
[ 0.483214] ardbeg_edp_init: GPU regulator 10500 mA
[ 0.484210] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.484233] swapper/0 isomgr_init(): max_iso_bw=7392000KB[ 0.484599] ardbeg_touch_init init raydium touch
[ 0.484751] Raydium - touch platform_id : 8
[ 0.567018] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[ 0.569927] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[ 0.574336] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[ 0.577234] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[ 0.577838] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.578271] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.578303] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.578543] mc-err: Started MC error interface!
[ 0.589344] bio: create slab at 0
[ 0.591293] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[ 0.591330] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[ 0.591464] vdd-ac-bat: 8400 mV
[ 0.591602] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.591637] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.591764] vdd-3v3-aon: 3300 mV
[ 0.591939] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[ 0.591974] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[ 0.592006] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[ 0.592044] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[ 0.592075] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[ 0.592105] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[ 0.592135] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[ 0.592166] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[ 0.592197] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[ 0.592229] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[ 0.592362] reg-3v3-supply: 3300 mV
[ 0.594022] vgaarb: loaded
[ 0.594646] SCSI subsystem initialized
[ 0.595060] usbcore: registered new interface driver usbfs
[ 0.595128] usbcore: registered new interface driver hub
[ 0.595258] usbcore: registered new device driver usb
[ 0.598122] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[ 0.598153] as3722 4-0040: Final OTP version 1V21
[ 0.603197] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.603403] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.603463] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.603517] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.603549] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.603582] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.603614] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.603672] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.603704] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.603736] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.603767] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.603799] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.603830] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.603862] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.603928] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.603960] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.604014] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.604047] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.604081] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.604116] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.604147] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.604179] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.604211] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.604243] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.604276] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.604307] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.604339] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.604395] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.604427] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.604482] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.604514] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.604545] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.604577] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.604609] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.604641] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.604672] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.604704] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.604735] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.604793] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.604825] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.604911] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.604943] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.604975] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.605048] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.605101] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.605133] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.605164] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.605217] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.605249] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.605310] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.605366] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.605398] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.605473] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.605504] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.605536] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.606451] vdd-cpu: 650 ↔ 1300 mV at 1000 mV 3500 mA
[ 0.607239] vdd-core: applied init 1000000uV constraint
[ 0.607841] vdd-core: 700 ↔ 1350 mV at 1000 mV 3500 mA
[ 0.609032] vddio-ddr: at 1350 mV
[ 0.609377] as3722-sd3: no parameters
[ 0.609960] avdd-pll-pex: 1050 mV
[ 0.611177] vdd-1v8: at 1800 mV
[ 0.611516] vdd-gpu: applied init 1000000uV constraint
[ 0.612395] vdd-gpu: 650 ↔ 1200 mV at 1000 mV 3500 mA
[ 0.612898] avdd-pll: at 1050 mV at 300 mA
[ 0.614174] vdd-cam: 1800 mV at 150 mA
[ 0.614845] avdd-dsi-csi: at 1200 mV at 150 mA
[ 0.616095] vdd-rtc: 800 mV at 150 mA
[ 0.616597] avdd-cam: 2800 mV at 150 mA
[ 0.617088] vdd-1v2-cam: 1175 mV at 150 mA
[ 0.617473] vddio-sdmmc-2: 1800 ↔ 3300 mV at 150 mA
[ 0.617973] vdd-1v1-cam: 1275 mV at 150 mA
[ 0.618948] avdd-spi: 3300 mV at 150 mA
[ 0.619450] vdd-2v7-cam: 2800 mV at 150 mA
[ 0.619959] vpp-fuse: 1800 mV at 150 mA
[ 0.621059] Linux video capture interface: v2.00
[ 0.622191] Advanced Linux Sound Architecture Driver Initialized.
[ 0.622663] ardbeg_wifi_power: 1
[ 0.723225] usb0-vbus: 5000 mV
[ 0.723533] usb1-usb2-vbus: 5000 mV
[ 0.723818] vdd-hdmi: 5000 mV
[ 0.724127] avdd-hdmi-pll: 3300 mV
[ 0.724177] avdd-hdmi-pll: supplied by avdd-pll-pex
[ 0.724355] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[ 0.724498] vdd-lcd-bl: 3300 mV
[ 0.724679] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[ 0.724835] vdd-lcd-bl-en: 5000 mV
[ 0.725015] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[ 0.725136] reg-5v0-supply: 5000 mV
[ 0.725312] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[ 0.725348] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[ 0.725380] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[ 0.725429] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[ 0.725461] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[ 0.725493] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[ 0.725525] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[ 0.725558] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[ 0.725589] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[ 0.725733] reg-1v8-supply: 1800 mV
[ 0.726074] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[ 0.726228] reg-dcdc-1v2: 1200 mV
[ 0.726412] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[ 0.726447] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[ 0.727041] as3722-gpio2-supply: 3300 mV
[ 0.727257] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[ 0.727786] as3722-gpio4-supply: 3300 mV
[ 0.728098] sdmmc-en-supply: 3300 mV
[ 0.728360] vdd-cdc-1v2-aud: 1200 mV
[ 0.728521] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[ 0.728556] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[ 0.728589] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[ 0.728714] reg-aon-1v8: 1800 mV
[ 0.728883] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[ 0.729031] reg-aon-1v2: 1200 mV
[ 0.732051] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[ 0.735470] tegra: started io power detection dynamic control
[ 0.735496] tegra: NO_IO_POWER setting 0x0
[ 0.735522] Switching to clocksource arch_sys_counter
[ 0.757271] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.757462] nvmap_page_pool_init: Total MB RAM: 1891
[ 0.757486] nvmap_page_pool_init: nvmap page pool size: 60512 pages (236 MB)
[ 0.848474] nvmap_page_pool_init: highmem=25600, pool_size=60512,totalram=484346, freeram=455658, totalhigh=297727, freehigh=272057
[ 0.849240] iram: dma coherent mem declare 0x40001000,258048
[ 0.850055] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.850209] nvmap:inner cache maint threshold=2097152
[ 0.859895] Wake39 for irq=52
[ 0.859988] tegra-otg tegra-otg: otg transceiver registered
[ 0.860341] NET: Registered protocol family 2
[ 0.861019] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.861224] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.861426] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.861487] TCP: reno registered
[ 0.861512] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.861568] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.861870] NET: Registered protocol family 1
[ 0.862270] RPC: Registered named UNIX socket transport module.
[ 0.862296] RPC: Registered udp transport module.
[ 0.862315] RPC: Registered tcp transport module.
[ 0.862335] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.862644] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.868009] host1x host1x: initialized
[ 0.869269] CPU PMU: probing PMU on CPU 0
[ 0.869305] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.869953] tegra_throttle : init passed
[ 0.870061] Tegra cpuquiet initialized: disabled
[ 0.870195] cpu-tegra: init EDP limit: 2320 MHz
[ 0.871196] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.871612] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.871852] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.872092] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.873625] bounce pool size: 64 pages
[ 0.875056] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.875340] NTFS driver 2.1.30 [Flags: R/O].
[ 0.875504] fuse init (API version 7.22)
[ 0.875768] msgmni has been set to 1457
[ 0.877206] io scheduler noop registered (default)
[ 0.908109] Tegra PCIe error: timeout waiting for PLL
[ 0.908193] tegra_pcie_enable_pads unable to initalize pads
[ 0.908217] PCIE: enable pads failed
[ 0.909220] tegra-pcie: probe of pcie-controller.1 failed with error -16
[ 0.909734] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 0.909846] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 0.910663] tsec tsec: initialized
[ 0.912137] isp isp.0: initialized
[ 0.913129] isp isp.1: initialized
[ 0.914717] falcon vic03.0: initialized
[ 0.915935] falcon msenc: initialized
[ 0.916757] tegradc tegradc.0: DSI: HS clock rate is 464500
[ 0.918234] p,wuxga-10-1 panel dt support not available
[ 1.199120] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[ 1.287798] tegradc tegradc.0: DSI pad calibration done
[ 1.294951] tegradc tegradc.0: probed
[ 1.295413] tegradc tegradc.0: fb registered
[ 1.295438] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 1.301304] gpio wake4 for gpio=111
[ 1.327454] Reserved SVD code 0
[ 1.329536] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 1.330871] tegradc tegradc.1: probed
[ 1.351775] Console: switching to colour frame buffer device 240x67
[ 1.370696] tegradc tegradc.1: fb registered
[ 1.370807] hdmi_state_machine_worker (tid edb8fac0): state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.370987] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.374273] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 1.375102] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.376478] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[ 1.412334] hdmi_state_machine_worker (tid edb8fac0): state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.412340] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.483880] hdmi_state_machine_worker (tid edb8fac0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.532787] Reserved SVD code 0
[ 1.532806] panel size 70 by 39
[ 3.555589] console [ttyS0] enabled
[ 3.555754] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 3.556173] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[ 3.556465] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 3.556772] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 3.558801] (null): coherent DMA mask is unset
[ 3.558812] gk20a gk20a.0: failed to allocate secure buffer -12
[ 3.562448] loop: module loaded
[ 3.562782] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 3.566620] gpio wake35 for gpio=70
[ 3.566688] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 3.567328] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 3.568475] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 3.570416] tegra_profiler: Branch: Dev
[ 3.570419] tegra_profiler: Version: 1.88
[ 3.570423] tegra_profiler: Samples version: 31
[ 3.570426] tegra_profiler: IO version: 16
[ 3.570432] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 3.570471] tegra_profiler: power_clk: init
[ 3.570618] tegra_profiler: auth: init
[ 3.570993] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 3.572493] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 3.572506] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 3.573746] scsi0 : tegra-sata
[ 3.574136] scsi1 : tegra-sata
[ 3.574357] ata1: SATA max UDMA/133 irq 55
[ 3.574361] ata2: DUMMY
[ 3.576385] tun: Universal TUN/TAP device driver, 1.6
[ 3.576389] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.576704] usbcore: registered new interface driver asix
[ 3.576751] usbcore: registered new interface driver ax88179_178a
[ 3.576792] usbcore: registered new interface driver cdc_ether
[ 3.576847] usbcore: registered new interface driver smsc95xx
[ 3.576886] usbcore: registered new interface driver cdc_subset
[ 3.576962] usbcore: registered new interface driver cdc_ncm
[ 3.576980] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.577200] tegra USB phy - inst[1] platform info:
[ 3.577203] port_otg: no
[ 3.577206] has_hostpc: yes
[ 3.577209] phy_interface: USB_PHY_INTF_UTMI
[ 3.577212] op_mode: TEGRA_USB_OPMODE_HOST
[ 3.577214] qc2_voltage: 0
[ 3.577217] vbus_gpio: -1
[ 3.577221] hot_plug: disabled
[ 3.577224] remote_wakeup: enabled
[ 3.578804] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 3.578831] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 3.578933] Wake40 for irq=53
[ 3.578937] Wake42 for irq=53
[ 3.578960] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 3.580892] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[ 3.584622] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[ 3.584714] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.584722] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.584728] usb usb1: Product: Tegra EHCI Host Controller
[ 3.584734] usb usb1: Manufacturer: Linux 3.10.40-gc017b03 ehci_hcd
[ 3.584740] usb usb1: SerialNumber: tegra-ehci.1
[ 3.585275] hub 1-0:1.0: USB hub found
[ 3.585295] hub 1-0:1.0: 1 port detected
[ 3.585687] tegra USB phy - inst[2] platform info:
[ 3.585690] port_otg: no
[ 3.585693] has_hostpc: yes
[ 3.585696] phy_interface: USB_PHY_INTF_UTMI
[ 3.585699] op_mode: TEGRA_USB_OPMODE_HOST
[ 3.585702] qc2_voltage: 0
[ 3.585704] vbus_gpio: -1
[ 3.585706] hot_plug: disabled
[ 3.585709] remote_wakeup: enabled
[ 3.587187] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 3.587209] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 3.587301] Wake41 for irq=129
[ 3.587304] Wake43 for irq=129
[ 3.587325] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 3.592616] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[ 3.592697] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.592704] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.592711] usb usb2: Product: Tegra EHCI Host Controller
[ 3.592717] usb usb2: Manufacturer: Linux 3.10.40-gc017b03 ehci_hcd
[ 3.592722] usb usb2: SerialNumber: tegra-ehci.2
[ 3.593193] hub 2-0:1.0: USB hub found
[ 3.593211] hub 2-0:1.0: 1 port detected
[ 3.593622] ehci-pci: EHCI PCI platform driver
[ 3.593901] tegra_xusb_read_usb_calib: usb_calib0 = 0x0285838a
[ 3.594158] usbcore: registered new interface driver usb-storage
[ 3.594264] usbcore: registered new interface driver usbserial
[ 3.594301] usbcore: registered new interface driver option
[ 3.594333] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.594439] usbcore: registered new interface driver pl2303
[ 3.594469] usbserial: USB Serial support registered for pl2303
[ 3.594483] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 3.594690] tegra USB phy - inst[0] platform info:
[ 3.594694] port_otg: yes
[ 3.594696] has_hostpc: yes
[ 3.594699] phy_interface: USB_PHY_INTF_UTMI
[ 3.594702] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 3.594705] qc2_voltage: 0
[ 3.594707] vbus_pmu_irq: 0
[ 3.594710] vbus_gpio: -1
[ 3.594713] charging: enabled
[ 3.594716] remote_wakeup: disabled
[ 3.597568] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 3.634086] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 3.634094] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 3.690348] i2c /dev entries driver
[ 3.691499] virtual_init
[ 3.693717] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 3.694547] tegra_dtv_probe: probing dtv.
[ 3.694972] setup_stream: bufsize = 4096, bufnum = 4
[ 3.694973] ar0832_init: ++
[ 3.695384] i2c-core: driver [max77387] using legacy suspend method
[ 3.695388] i2c-core: driver [max77387] using legacy resume method
[ 3.695443] i2c-core: driver [as364x] using legacy suspend method
[ 3.695446] i2c-core: driver [as364x] using legacy resume method
[ 3.695640] [IMX135] sensor driver loading
[ 3.695694] [IMX179] sensor driver loading
[ 3.695747] [imx132] sensor driver loading
[ 3.695800] [AR0330] sensor driver loading
[ 3.695852] [ar0261] sensor driver loading
[ 3.696610] usbcore: registered new interface driver uvcvideo
[ 3.696613] USB Video Class driver (1.1.1)
[ 3.697619] zram: Created 1 device(s) …
[ 3.699057] sdhci: Secure Digital Host Controller Interface driver
[ 3.699060] sdhci: Copyright(c) Pierre Ossman
[ 3.699063] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.699481] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 3.699675] sdhci-tegra sdhci-tegra.3: Speedo value 2304
[ 3.699684] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 3.746631] otg state changed: SUSPEND → PERIPHERAL
[ 3.878636] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.679302] handle_check_edid_l: audio_switch 1
[ 4.687849] Display connected, hpd_switch 1
[ 4.696033] handle_check_edid_l: setting audio and infoframes
[ 4.705905] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 4 (Enabled)
[ 4.719369] hdmi_state_machine_worker (tid edb8fac0): state 4 (Enabled), hpd 1, pending_hpd_evt 0
[ 4.732901] mmc0: no vqmmc regulator found
[ 4.732919] mmc0: no vmmc regulator found
[ 4.732924] mmc0: Invalid maximum block size, assuming 512 bytes
[ 4.756621] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 4.756621] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 4.757553] sdhci-tegra sdhci-tegra.2: Speedo value 2304
[ 4.757561] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 4.844560] mmc1: no vqmmc regulator found
[ 4.853125] mmc1: no vmmc regulator found
[ 4.861531] mmc1: Invalid maximum block size, assuming 512 bytes
[ 4.872012] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found[ 4.873857] mmc0: BKOPS_EN bit is not set
[ 4.879251] sdhci-tegra sdhci-tegra.3: Found T2T coeffs data
[ 4.879259] sdhci-tegra sdhci-tegra.3: 200MHz tap hole coeffs found
[ 4.935628] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 4.952713] gpio wake56 for gpio=170
[ 4.964792] tegra-se tegra12-se: tegra_se_probe: complete
[ 4.977477] usbcore: registered new interface driver usbhid
[ 4.987900] usbhid: USB HID core driver
[ 4.996983] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 5.395212] usbcore: registered new interface driver snd-usb-audio
[ 5.406856] MAX98090 driver built on Feb 2 2015 at 17:48:09
[ 5.418113] tegra_offload_platform probe successfull.[ 5.423062] Auto tuning windows***
[ 5.423065] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.423071] win[0]: 0(0) - 61(1)
[ 5.423079] win[1]: 66(0) - 130(1)
[ 5.423083] win[2]: 135(0) - 199(1)
[ 5.423086] win[3]: 204(0) - 255(1)
[ 5.423089] ***************************************
[ 5.423099] ***tuning windows after inserting holes
[ 5.423101] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 5.423105] win[0]:-3(0) - 31(2)
[ 5.423110] win[1]:33(2) - 61(1)
[ 5.423113] win[2]:66(0) - 100(2)
[ 5.423117] win[3]:102(2) - 130(1)
[ 5.423121] win[4]:135(0) - 169(2)
[ 5.423124] win[5]:171(2) - 199(1)
[ 5.423128] win[6]:204(0) - 238(2)
[ 5.423132] win[7]:240(2) - 255(1)
[ 5.423134] ***********************************************
[ 5.423139] *Tuning values
[ 5.423142] estimated values
[ 5.423146] T2T_Vmax 56, T2T_Vmin 77, 1’st_hole_Vmax 48, UI_Vmax 89
[ 5.423149] Calculated values
[ 5.423153] T2T_Vmax 72, 1’st_hole_Vmax 32, UI_Vmax 69
[ 5.423157] T2T_Vmin 72, 1’st_hole_Vmin 32, UI_Vmin 69
[ 5.423159] ***********************************
[ 5.423165] *final tuning windows
[ 5.423169] win[0]: 10 - 24
[ 5.423172] win[1]: 41 - 48
[ 5.423175] win[2]: 79 - 88
[ 5.423178] win[3]: 115 - 117
[ 5.423181] win[4]: 148 - 153
[ 5.423184] win[5]: 188 - 186
[ 5.423187] win[6]: 217 - 217
[ 5.423190] win[7]: 255 - 242
[ 5.423192] ********************************
[ 5.423197] best tap win - (10-24), best tap value 17
[ 5.423207] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 17
[ 5.425736] mmc0: new HS200 MMC card at address 0001
[ 5.425971] mmcblk mmc0:0001: Card claimed for testing.
[ 5.426174] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[ 5.426314] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[ 5.791310] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 5.792172] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[ 6.055238] rt5639 0-001c: read 0xfd=0x6
[ 6.077781] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 6.087601] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 6.098336] gpio wake49 for gpio=143
[ 7.108623] rt5639 0-001c: rt5639_headset_detect RT5639_PWR_ANLG1(0x63) = 0xa814
[ 7.120659] rt5639 0-001c: rt5639_headset_detect RT5639_IRQ_CTRL2(0xbe) = 0x0
[ 7.194458] rt5639 0-001c: rt5639_headset_detect jack_type = 2
[ 7.204875] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 ↔ tegra30-i2s.1 mapping ok
[ 7.218064] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi ↔ tegra30-spdif mapping ok
[ 7.231054] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi ↔ tegra30-i2s.3 mapping ok
[ 7.243986] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 ↔ dit-hifi mapping ok
[ 7.256739] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi ↔ dit-hifi mapping ok
[ 7.268982] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 7.280286] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 7.291455] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai ↔ tegra-offload-pcm mapping ok
[ 7.305071] compress asoc: snd-soc-dummy-dai ↔ tegra-offload-compr mapping ok
[ 7.316912] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 7.328208] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 7.339341] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai ↔ tegra-offload-pcm mapping ok
[ 7.352925] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 ↔ tegra30-i2s.1 mapping ok
[ 7.368405] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input0
[ 7.382941] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[ 7.392469] oprofile: using timer interrupt.
[ 7.404814] GACT probability NOT on
[ 7.412155] Mirror/redirect action on
[ 7.419573] u32 classifier
[ 7.426025] Actions configured
[ 7.433170] Netfilter messages via NETLINK v0.30.
[ 7.441736] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 7.452139] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 7.463018] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 7.473041] xt_time: kernel timezone is -0000
[ 7.481618] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.490990] arp_tables: (C) 2002 David S. Miller
[ 7.499639] TCP: cubic registered
[ 7.507096] NET: Registered protocol family 10
[ 7.516300] mip6: Mobile IPv6
[ 7.523404] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 7.533096] sit: IPv6 over IPv4 tunneling driver
[ 7.542869] NET: Registered protocol family 17
[ 7.551636] NET: Registered protocol family 15
[ 7.560324] NET: Registered protocol family 35
[ 7.569028] NET: Registered protocol family 37
[ 7.577533] NET: Registered protocol family 41
[ 7.587303] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 7.623119] Registering SWP/SWPB emulation handler
[ 7.632033] last reset is due to power on reset
[ 7.632033]
[ 7.646144] Disabling clocks left on by bootloader:
[ 7.655101] audio_2x
[ 7.661649] audio
[ 7.667904] audio4
[ 7.674238] audio3
[ 7.680565] audio2
[ 7.686914] audio1
[ 7.693237] audio0
[ 7.699639] hdmi_audio
[ 7.706315] entropy
[ 7.712743] dsi2-fixed
[ 7.719370] dsi1-fixed
[ 7.725899] nor
[ 7.731733] trace
[ 7.737710] sdmmc4_ddr
[ 7.744066] sdmmc3_ddr
[ 7.750409] cclk_lp
[ 7.756436] pll_x_out0
[ 7.762652] pll_m_out1
[ 7.768869] tegra_dvfs: vdd_cpu connected to regulator
[ 7.777575] tegra_dvfs: vdd_core connected to regulator
[ 7.786435] tegra_dvfs: vdd_gpu connected to regulator
[ 7.796054] tegra_dvfs: registered vdd_cpu simon notifier
[ 7.805559] cpu_cold cooling device is registered
[ 7.813816] Tegra CPU DFLL is initialized with use_dfll = 1
[ 7.813926] cpu_hot cooling device is registered
[ 7.831193] CPU rate: 696 MHz
[ 8.100412] tegra dvfs: tegra sysfs cap interface is initialized
[ 8.109855] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 8.119713] tegra dvfs: registered vdd_gpu simon notifier
[ 8.129040] tegra_actmon.emc: Completed initialization (0)
[ 8.138103] tegra_actmon.avp: Completed initialization (0)
[ 8.147066] tegra_mon.cpu_emc: Completed initialization (0)
[ 8.158684] reg-aon-1v2: incomplete constraints, leaving on
[ 8.167539] reg-aon-1v8: incomplete constraints, leaving on
[ 8.176312] sdmmc-en-supply: incomplete constraints, leaving on
[ 8.185550] reg-dcdc-1v2: incomplete constraints, leaving on
[ 8.194538] reg-5v0-supply: incomplete constraints, leaving on
[ 8.203701] usb0-vbus: incomplete constraints, leaving on
[ 8.212379] vpp-fuse: incomplete constraints, leaving on
[ 8.220911] vdd-2v7-cam: incomplete constraints, leaving on
[ 8.229664] avdd-spi: incomplete constraints, leaving on
[ 8.238167] vdd-1v1-cam: incomplete constraints, leaving on
[ 8.246958] vddio-sdmmc-2: incomplete constraints, leaving on
[ 8.255950] vdd-1v2-cam: incomplete constraints, leaving on
[ 8.264794] avdd-cam: incomplete constraints, leaving on
[ 8.273385] vdd-cam: incomplete constraints, leaving on
[ 8.281881] as3722-sd3: incomplete constraints, leaving on
[ 8.290619] vdd-3v3-aon: incomplete constraints, leaving on
[ 8.299446] vdd-ac-bat: incomplete constraints, leaving on
[ 8.308169] regulator-dummy: incomplete constraints, leaving on
[ 8.318119] gpio wake51 for gpio=128
[ 8.325190] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input1
[ 8.336342] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 01:07:46 UTC (946688866)
[ 8.349094] ALSA device list:
[ 8.355539] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 8.364400] #1: tegra-rt5639
[ 8.371993] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 8.384255] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 8.905169] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 8.914187] EXT4-fs (mmcblk0p1): recovery complete
[ 8.934510] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.946448] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 8.959320] devtmpfs: mounted
[ 8.966371] Freeing unused kernel memory: 504K (c0b3d000 - c0bbb000)
[ 9.201173] init: plymouth-upstart-bridge main process (118) terminated with status 1
[ 9.213261] init: plymouth-upstart-bridge main process ended, respawning
[ 9.266655] init: plymouth-upstart-bridge main process (128) terminated with status 1
[ 9.278658] init: plymouth-upstart-bridge main process ended, respawning
[ 9.294191] init: ureadahead main process (121) terminated with status 5
[ 9.336240] init: plymouth-upstart-bridge main process (132) terminated with status 1
[ 9.348338] init: plymouth-upstart-bridge main process ended, respawning
- Starting Mount filesystems on boot[ OK ]
- Starting Signal sysvinit that the rootfs is mounted[ OK ]
- Starting Clean /tmp directory[ OK ]
- Stopping Clean /tmp directory[ OK ]
- Starting Populate and link to /run filesystem[ OK ]
- Stopping Populate and link to /run filesystem[ OK ]
- Stopping Track if upstart is running in a container[ OK ]
- Starting Initialize or finalize resolvconf[ OK ]
- Starting Signal sysvinit that virtual filesystems are mounted[ OK ]
- Starting Signal sysvinit that local filesystems are mounted[ OK ]
- Starting Bridge udev events into upstart[ OK ]
- Starting Signal sysvinit that remote filesystems are mounted[ OK ]
- Stopping Mount filesystems on boot[ OK ]
- Starting flush early job output to logs[ OK ]
- Starting D-Bus system message bus[ OK ]
- Starting device node and kernel event manager[ OK ]
- Stopping flush early job output to logs[ OK ]
- Starting NVIDIA specific init script[ OK ]
- Starting load modules from /etc/modules[ OK ]
- Starting cold plug devices[ OK ]
- Starting log initial device creation[ OK ]
- Starting SystemD login management service[ OK ]
- Stopping NVIDIA specific init script[ OK ]
- Stopping load modules from /etc/modules[ OK ]
- Starting bluetooth daemon[ OK ]
- Starting system logging daemon[ OK ]
- Stopping NVIDIA specific first-boot script[ OK ]
- Starting userspace bootsplash[ OK ]
- Starting Send an event to indicate plymouth is up[ OK ]
- Stopping userspace bootsplash[ OK ]
- Starting mDNS/DNS-SD daemon[ OK ]
- Stopping Send an event to indicate plymouth is up[ OK ]
- Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated[ OK ]
- Stopping Reload cups, upon starting avahi-daemon to make sure remote queues are populated[ OK ]
- Starting configure network device security[ OK ]
- Starting CUPS printing spooler/server[ OK ]
- Starting configure network device[ OK ]
- Stopping cold plug devices[ OK ]
- Starting Mount network filesystems[ OK ]
- Starting Failsafe Boot Delay[ OK ]
- Stopping log initial device creation[ OK ]
- Starting cups-browsed - Bonjour remote printer browsing daemon[ OK ]
- Starting enable remaining boot-time encrypted block devices[ OK ]
- Stopping Mount network filesystems[ OK ]
- Stopping Failsafe Boot Delay[ OK ]
- Starting configure virtual network devices[ OK ]
[ OK ]rting early crypto disks… - Starting System V initialisation compatibility[ OK ]
- Starting modem connection manager[ OK ]
[ OK ]ting up X socket directories… - Stopping System V initialisation compatibility[ OK ]
- Starting network connection manager[ OK ]
- speech-dispatcher disabled; edit /etc/default/speech-dispatcher
[ OK ]rting NTP server ntpd
saned disabled; edit /etc/default/saned - Starting System V runlevel compatibility[ OK ]
- Starting OpenSSH server[ OK ]
- Starting regular background program processing daemon[ OK ]
- Starting save kernel messages[ OK ]
- Starting crash report submission daemon[ OK ]
- Stopping System V runlevel compatibility[ OK ]
- Stopping save kernel messages[ OK ]
Ubuntu 14.04.1 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: ubuntu (automatic login)
Last login: Sat Jan 1 00:59:15 UTC 2000 on ttyS0
Welcome to Ubuntu 14.04.1 LTS (GNU/Linux 3.10.40-gc017b03 armv7l)
- Documentation: https://help.ubuntu.com/
0 packages can be updated.
0 updates are security updates.
And here in ifconfig, the eth0 no longer shows up:
ubuntu@tegra-ubuntu:~$ ifconfig -a
dummy0 Link encap:Ethernet HWaddr 2e:10:dc:e8:5d:75
BROADCAST NOARP MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
ip6tnl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1452 Metric:1
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:592 errors:0 dropped:0 overruns:0 frame:0
TX packets:592 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:47008 (47.0 KB) TX bytes:47008 (47.0 KB) ±----------------------------+
rmnetctl Link encap:IPIP Tunnel HWaddr | Cannot open /dev/ttyUSB0! |
NOARP MTU:1500 Metric:1 | |
RX packets:0 errors:0 dropped:0 overruns:0 frame:0 ±----------------------------+
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
Henry
