Hi. I am attaching here the demsg output.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-geip-mc10k1-rel1.0-L4T-R21.4 EMBIEN - 5.8 (elop@elop-ThinkCentre-M92p) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #1 SMP PREEMPT Fri Feb 16 11:58:57 IST 2018
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: mc10k1, model: GE MC10K1 NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: bc900000 - bdafffff
[ 0.000000] 2nd Framebuffer: bdb00000 - bdefffff
[ 0.000000] Carveout: bdf00000 - fdefffff
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 128 MiB at a7800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] On node 0 totalpages: 247552
[ 0.000000] free_area_init_node: node 0, pgdat c0c59b80, node_mem_map c0e09000
[ 0.000000] Normal zone: 1520 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 194560 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2510 pages used for memmap
[ 0.000000] HighMem zone: 52992 pages, LIFO batch:15
[ 0.000000] DTS File Name: arch/arm/boot/dts/tegra124-mc10k1-pm375.dts
[ 0.000000] Tegra12: CPU Speedo value 2235, Soc Speedo value 2187, Gpu Speedo value 2064
[ 0.000000] Tegra12: CPU Speedo ID 8, Soc Speedo ID 4, Gpu Speedo ID 6
[ 0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[ 0.000000] Tegra Revision: A01 SKU: 0x80 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 708000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 708000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 456000000
[ 0.000000] Lowering se maximum rate from 600000000 to 456000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 456000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 136000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 136000000
[ 0.000000] Lowering sdmmc4 maximum rate from 200000000 to 136000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2116500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1210mV, scaling disabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1100mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df1000 s15360 r8192 d13312 u36864
[ 0.000000] pcpu-alloc: s15360 r8192 d13312 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 246032
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 967MB = 967MB total
[ 0.000000] Memory: 827156k/827156k available, 1236204k reserved, 211968K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0aafe30 (10912 kB)
[ 0.000000] .init : 0xc0ab0000 - 0xc0b2dc00 ( 503 kB)
[ 0.000000] .data : 0xc0b2e000 - 0xc0c6f940 (1287 kB)
[ 0.000000] .bss : 0xc0c6f940 - 0xc0cf7b4c ( 545 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.002837] Calibrating delay loop (skipped), value calculated using timer frequency… lpj=12000
[ 0.002891] pid_max: default: 32768 minimum: 301
[ 0.003177] Mount-cache hash table entries: 512
[ 0.023471] Initializing cgroup subsys debug
[ 0.023509] Initializing cgroup subsys freezer
[ 0.023585] CPU: Testing write buffer coherency: ok
[ 0.023658] ftrace: allocating 29564 entries in 58 pages
[ 0.061133] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.061174] Setting up static identity map for 0xc07adf50 - 0xc07adff4
[ 0.065143] ftrace: Allocated trace_printk buffers
[ 0.072779] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.075785] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.078827] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.079008] Brought up 4 CPUs
[ 0.079083] SMP: Total of 4 processors activated.
[ 0.079100] CPU: All CPU(s) started in SVC mode.
[ 0.080097] devtmpfs: initialized
[ 0.088798] pinctrl core: initialized pinctrl subsystem
[ 0.089140] regulator-dummy: no parameters
[ 0.091936] NET: Registered protocol family 16
[ 0.094281] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.095561] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.096600] console [pstore-1] enabled
[ 0.096638] ramoops: attached 0x200000@0xbc700000, ecc: 0/0
[ 0.097005] cpuidle: using governor ladder
[ 0.097026] cpuidle: using governor menu
[ 0.100777] ardbeg_camera_auxdata: update camera lookup table.
[ 0.109203] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.109594] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.116196] Wake16 for irq=34
[ 0.118573] Wake58 for irq=81
[ 0.118621] Wake41 for irq=129
[ 0.118639] Wake43 for irq=129
[ 0.118684] Wake40 for irq=53
[ 0.118701] Wake42 for irq=53
[ 0.122746] board_info: id:sku:fab:major:minor = 0x0177:0x100a:0x00:0x05:0x00
[ 0.122826] board_info: id:sku:fab:major:minor = 0x0177:0x100a:0x00:0x05:0x00
[ 0.122848] Board Type: MC10K1A
[ 0.122862] GE Tracking version: $Change$
[ 0.122943] disp1 pclk=154700000
[ 0.122951] disp2 pclk=297000000
[ 0.122959] Selecting UARTD as the debug console
[ 0.123001] The debug console clock name is uartd
[ 0.123140] MC10K1A: Override portmap: 0x201
[ 0.123160] MC10K1A: xHCI: SS0 & USB2 P1 Enabled
[ 0.123432] ardbeg_modem_init: modem_id = 0
[ 0.125725] Clear bootloader IO dpd settings
[ 0.125945] Loading GE MC10K1 Rev4 EMC tables.
[ 0.126203] tegra: pll_m is selected as scalable EMC clock source
[ 0.126246] Lowering emc maximum rate from 1200000000 to 792000000
[ 0.126274] tegra: validated EMC DFS table
[ 0.126398] ardbeg_edp_init: CPU regulator 11000 mA
[ 0.403555] ardbeg_edp_init: GPU regulator 11400 mA
[ 0.403838] swapper/0 isomgr_init(): iso emc max clk=792000KHz
[ 0.403858] swapper/0 isomgr_init(): max_iso_bw=6336000KB<6>[ 0.404215] ardbeg_touch_init init raydium touch
[ 0.404362] Raydium - touch platform_id : 8
[ 0.430344] platform tegradc.0: IOVA linear map 0xbc900000(1200000)
[ 0.433585] platform tegradc.0: IOVA linear map 0xbdb00000(400000)
[ 0.437751] platform tegradc.0: IOVA linear map 0xbdf00000(40000000)
[ 0.442738] platform tegradc.1: IOVA linear map 0xbc900000(1200000)
[ 0.445967] platform tegradc.1: IOVA linear map 0xbdb00000(400000)
[ 0.450132] platform tegradc.1: IOVA linear map 0xbdf00000(40000000)
[ 0.450413] FUSE: cp_rev 0 ft_rev 0
[ 0.450584] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.450977] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.451006] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.451309] mc-err: Started MC error interface!
[ 0.461361] bio: create slab at 0
[ 0.463211] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[ 0.463247] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[ 0.463277] of_get_named_gpio_flags: can’t parse gpios property
[ 0.463380] vdd-ac-bat: 8400 mV
[ 0.463531] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.463565] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.463593] of_get_named_gpio_flags: can’t parse gpios property
[ 0.463682] vdd-3v3-aon: 3300 mV
[ 0.463834] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[ 0.463868] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[ 0.463898] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[ 0.463933] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[ 0.463962] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[ 0.463992] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[ 0.464021] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[ 0.464050] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[ 0.464080] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[ 0.464109] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[ 0.464152] of_get_named_gpio_flags: can’t parse gpios property
[ 0.464236] reg-3v3-supply: 3300 mV
[ 0.465801] vgaarb: loaded
[ 0.466381] SCSI subsystem initialized
[ 0.466584] libata version 3.00 loaded.
[ 0.466765] usbcore: registered new interface driver usbfs
[ 0.466830] usbcore: registered new interface driver hub
[ 0.466935] usbcore: registered new device driver usb
[ 0.467164] of_get_named_gpio_flags exited with status 20
[ 0.467182] of_get_named_gpio_flags exited with status 21
[ 0.467420] of_get_named_gpio_flags exited with status 157
[ 0.467438] of_get_named_gpio_flags exited with status 158
[ 0.468162] of_get_named_gpio_flags exited with status 217
[ 0.468180] of_get_named_gpio_flags exited with status 218
[ 0.468405] of_get_named_gpio_flags exited with status 172
[ 0.468422] of_get_named_gpio_flags exited with status 173
[ 0.468667] of_get_named_gpio_flags exited with status 206
[ 0.468683] of_get_named_gpio_flags exited with status 207
[ 0.469855] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[ 0.469885] as3722 4-0040: Final OTP version 1V21
[ 0.475190] gpiochip_find_base: found new base at 1016
[ 0.475277] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.475311] GPIO chip as3722-gpio: created GPIO range 0->7 ==> as3722-pinctrl PIN 0->7
[ 0.475479] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.475538] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.475589] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.475640] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.475672] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.475702] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.475758] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.475788] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.475819] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.475848] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.475879] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.475908] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.475938] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.476000] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.476030] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.476060] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.476090] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.476123] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.476155] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.476185] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.476215] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.476245] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.476275] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.476305] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.476335] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.476365] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.476417] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.476447] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.476498] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.476528] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.476558] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.476587] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.476617] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.476664] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.476696] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.476726] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.476756] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.476812] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.476842] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.476924] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.476954] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.476984] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.477034] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.477082] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.477112] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.477142] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.477191] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.477221] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.477273] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.477320] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.477350] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.477425] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.477455] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.477485] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.478401] vdd-cpu: 650 <–> 1300 mV at 1000 mV 3500 mA
[ 0.479144] vdd-core: applied init 1000000uV constraint
[ 0.479736] vdd-core: 700 <–> 1350 mV at 1000 mV 3500 mA
[ 0.480915] vddio-ddr: at 1350 mV
[ 0.481231] as3722-sd3: no parameters
[ 0.481797] avdd-pll-pex: 1050 mV
[ 0.482979] vdd-1v8: at 1800 mV
[ 0.483319] vdd-gpu: applied init 1000000uV constraint
[ 0.484188] vdd-gpu: 650 <–> 1200 mV at 1000 mV 3500 mA
[ 0.484678] avdd-pll: at 1050 mV at 300 mA
[ 0.485935] vdd-cam: 1800 mV at 150 mA
[ 0.486587] avdd-dsi-csi: at 1200 mV at 150 mA
[ 0.487798] vdd-rtc: 800 mV at 150 mA
[ 0.488258] avdd-cam: 2800 mV at 150 mA
[ 0.488735] vdd-1v2-cam: 1175 mV at 150 mA
[ 0.489105] vddio-sdmmc-2: 1800 <–> 3300 mV at 150 mA
[ 0.489588] vdd-1v1-cam: 1275 mV at 150 mA
[ 0.490532] avdd-spi: 3300 mV at 150 mA
[ 0.491018] vdd-2v7-cam: 2800 mV at 150 mA
[ 0.491505] vpp-fuse: 1800 mV at 150 mA
[ 0.492116] of_get_named_gpio_flags: can’t parse gpios property
[ 0.492128] of_get_named_gpio_flags: can’t parse gpios property
[ 0.492593] Linux video capture interface: v2.00
[ 0.492649] pps_core: LinuxPPS API ver. 1 registered
[ 0.492669] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.492710] PTP clock support registered
[ 0.493752] Advanced Linux Sound Architecture Driver Initialized.
[ 0.494381] of_get_named_gpio_flags exited with status 108
[ 0.494500] usb0-vbus: 5000 mV
[ 0.494683] of_get_named_gpio_flags exited with status 109
[ 0.494799] usb1-usb2-vbus: 5000 mV
[ 0.494990] of_get_named_gpio_flags exited with status 86
[ 0.495095] vdd-hdmi: 5000 mV
[ 0.495261] of_get_named_gpio_flags exited with status 63
[ 0.495360] avdd-hdmi-pll: 3300 mV
[ 0.495409] avdd-hdmi-pll: supplied by avdd-pll-pex
[ 0.495578] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[ 0.495622] of_get_named_gpio_flags exited with status 122
[ 0.495725] vdd-lcd-bl: 3300 mV
[ 0.495911] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[ 0.495954] of_get_named_gpio_flags exited with status 58
[ 0.496069] vdd-lcd-bl-en: 5000 mV
[ 0.496218] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[ 0.496247] of_get_named_gpio_flags: can’t parse gpios property
[ 0.496338] reg-5v0-supply: 5000 mV
[ 0.496497] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[ 0.496531] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[ 0.496561] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[ 0.496609] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[ 0.496640] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[ 0.496671] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[ 0.496700] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[ 0.496730] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[ 0.496760] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[ 0.496813] of_get_named_gpio_flags: can’t parse gpios property
[ 0.496917] reg-1v8-supply: 1800 mV
[ 0.497199] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[ 0.497242] of_get_named_gpio_flags exited with status 138
[ 0.497351] reg-dcdc-1v2: 1200 mV
[ 0.497519] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[ 0.497552] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[ 0.497593] of_get_named_gpio_flags exited with status 1018
[ 0.498121] as3722-gpio2-supply: 3300 mV
[ 0.498316] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[ 0.498360] of_get_named_gpio_flags exited with status 1020
[ 0.498811] as3722-gpio4-supply: 3300 mV
[ 0.498999] of_get_named_gpio_flags exited with status 136
[ 0.499105] sdmmc-en-supply: 3300 mV
[ 0.499268] of_get_named_gpio_flags exited with status 138
[ 0.499360] vdd-cdc-1v2-aud: 1200 mV
[ 0.499511] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[ 0.499545] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[ 0.499576] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[ 0.499603] of_get_named_gpio_flags: can’t parse gpios property
[ 0.499693] reg-aon-1v8: 1800 mV
[ 0.499848] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[ 0.499878] of_get_named_gpio_flags: can’t parse gpios property
[ 0.499984] reg-aon-1v2: 1200 mV
[ 0.502884] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is connected
[ 0.506137] tegra: started io power detection dynamic control
[ 0.506162] tegra: NO_IO_POWER setting 0x0
[ 0.506187] Switching to clocksource arch_sys_counter
[ 0.526499] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.526692] nvmap_page_pool_init: Total MB RAM: 935
[ 0.526715] nvmap_page_pool_init: nvmap page pool size: 29944 pages (116 MB)
[ 0.526852] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.527025] iram: dma coherent mem declare 0x40001000,258048
[ 0.527868] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.527981] generic-0: dma coherent mem declare 0xbdf00000,1073741824
[ 0.532440] misc nvmap: created heap generic-0 base 0xbdf00000 size (1048576KiB)
[ 0.532603] nvmap:inner cache maint threshold=2097152
[ 0.541836] Wake39 for irq=52
[ 0.541926] tegra-otg tegra-otg: otg transceiver registered
[ 0.542302] NET: Registered protocol family 2
[ 0.542993] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.543195] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.543405] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.543465] TCP: reno registered
[ 0.543489] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.543543] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.543869] NET: Registered protocol family 1
[ 0.544261] RPC: Registered named UNIX socket transport module.
[ 0.544286] RPC: Registered udp transport module.
[ 0.544304] RPC: Registered tcp transport module.
[ 0.544323] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.544348] PCI: CLS 0 bytes, default 64
[ 0.544601] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.549640] host1x host1x: initialized
[ 0.550836] CPU PMU: probing PMU on CPU 0
[ 0.550870] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.551482] tegra_throttle : init passed
[ 0.551588] Tegra cpuquiet initialized: disabled
[ 0.551720] cpu-tegra: init EDP limit: 2116 MHz
[ 0.555036] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.556192] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.556937] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.557741] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.562490] bounce pool size: 64 pages
[ 0.567224] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.568230] NTFS driver 2.1.30 [Flags: R/O].
[ 0.568748] fuse init (API version 7.22)
[ 0.569573] msgmni has been set to 1457
[ 0.574918] io scheduler noop registered (default)
[ 0.575947] of_get_named_gpio_flags: can’t parse gpios property
[ 0.575986] of_get_named_gpio_flags: can’t parse gpios property
[ 0.576016] of_get_named_gpio_flags: can’t parse gpios property
[ 0.606380] PCI host bridge to bus 0000:00
[ 0.606478] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 0.606572] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 0.606672] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 0.606759] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.606936] pci 0000:00:00.0: [10de:0e12] type 01 class 0x060400
[ 0.607201] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.607987] PCI: bus0: Fast back to back transfers disabled
[ 0.608083] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.608756] pci 0000:01:00.0: [1172:e001] type 00 class 0xff0000
[ 0.608860] pci 0000:01:00.0: reg 10: [mem 0x00000000-0x0fffffff 64bit pref]
[ 0.608927] pci 0000:01:00.0: reg 18: [mem 0x00000000-0x00007fff]
[ 0.611491] PCI: bus1: Fast back to back transfers disabled
[ 0.611593] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.611649] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[ 0.612602] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.612698] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.612793] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 0.613181] aer 0000:00:00.0:pcie02: service driver aer loaded
[ 0.613788] PCI host bridge to bus 0000:02
[ 0.613877] pci_bus 0000:02: root bus resource [mem 0x32100000-0x3fffffff]
[ 0.613968] pci_bus 0000:02: root bus resource [mem 0x12100000-0x320fffff pref]
[ 0.614065] pci_bus 0000:02: root bus resource [io 0x10000-0x1ffff]
[ 0.614150] pci_bus 0000:02: No busn resource found for root bus, will use [bus 02-ff]
[ 0.614380] pci 0000:02:00.0: [10de:0e13] type 01 class 0x060400
[ 0.614635] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.615408] PCI: bus2: Fast back to back transfers disabled
[ 0.615503] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.616126] pci 0000:03:00.0: [8086:1533] type 00 class 0x020000
[ 0.616220] pci 0000:03:00.0: reg 10: [mem 0x00000000-0x000fffff]
[ 0.616385] pci 0000:03:00.0: reg 18: [io 0x0000-0x001f]
[ 0.616454] pci 0000:03:00.0: reg 1c: [mem 0x00000000-0x00003fff]
[ 0.616577] pci 0000:03:00.0: reg 30: [mem 0x00000000-0x000fffff pref]
[ 0.616790] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.619422] PCI: bus3: Fast back to back transfers disabled
[ 0.619524] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[ 0.619578] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 03
[ 0.620459] pcieport 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.620555] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 0.620648] pcie_pme 0000:02:00.0:pcie01: service driver pcie_pme loaded
[ 0.621041] aer 0000:02:00.0:pcie02: service driver aer loaded
[ 0.621408] pcieport 0000:02:00.0: BAR 8: assigned [mem 0x32100000-0x322fffff]
[ 0.621521] pcieport 0000:02:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff pref]
[ 0.621625] pcieport 0000:02:00.0: BAR 7: assigned [io 0x10000-0x10fff]
[ 0.621730] pci 0000:03:00.0: BAR 0: assigned [mem 0x32100000-0x321fffff]
[ 0.621835] pci 0000:03:00.0: BAR 6: assigned [mem 0x12100000-0x121fffff pref]
[ 0.621936] pci 0000:03:00.0: BAR 3: assigned [mem 0x32200000-0x32203fff]
[ 0.622035] pci 0000:03:00.0: BAR 2: assigned [io 0x10000-0x1001f]
[ 0.622132] pcieport 0000:02:00.0: PCI bridge to [bus 03]
[ 0.622215] pcieport 0000:02:00.0: bridge window [io 0x10000-0x10fff]
[ 0.622367] pcieport 0000:02:00.0: bridge window [mem 0x32100000-0x322fffff]
[ 0.622470] pcieport 0000:02:00.0: bridge window [mem 0x12100000-0x121fffff pref]
[ 0.622620] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x20000000-0x2fffffff 64bit pref]
[ 0.622726] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32300000-0x323fffff]
[ 0.622834] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x2fffffff 64bit pref]
[ 0.622965] pci 0000:01:00.0: BAR 2: assigned [mem 0x32300000-0x32307fff]
[ 0.623061] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 0.623148] pcieport 0000:00:00.0: bridge window [mem 0x32300000-0x323fffff]
[ 0.623247] pcieport 0000:00:00.0: bridge window [mem 0x20000000-0x2fffffff 64bit pref]
[ 0.623450] PCIE: No Link speed change happened
[ 0.625064] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 0.625499] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 0.627953] tsec tsec: initialized
[ 0.632115] isp isp.0: initialized
[ 0.634793] isp isp.1: initialized
[ 0.639308] falcon vic03.0: initialized
[ 0.642439] falcon msenc: initialized
[ 0.645370] tegradc tegradc.0: DSI: HS clock rate is 464500
[ 0.649884] p,wuxga-10-1 panel dt support not available
[ 0.931780] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[ 1.021622] tegradc tegradc.0: DSI pad calibration done
[ 1.029090] tegradc tegradc.0: probed
[ 1.030733] tegradc tegradc.0: fb registered
[ 1.030799] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 1.034936] tegradc tegradc.1: probed
[ 1.035843] tegradc tegradc.1: fb registered
[ 1.052104] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 1.054456] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.058837] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[ 3.487768] console [ttyS0] enabled
[ 3.492950] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[ 3.501774] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 3.510597] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 3.520129] EGCDev: Initializing the EGCDev LKM
[ 3.524811] EGCDev: registered correctly with major number 241
[ 3.530926] EGCDev: device class registered correctly
[ 3.536119] EGCDev: device class created correctly
[ 3.558017] loop: module loaded
[ 3.561794] at24 1-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
[ 3.570130] tegra_profiler: Branch: Dev
[ 3.574185] tegra_profiler: Version: 1.103
[ 3.578397] tegra_profiler: Samples version: 34
[ 3.583053] tegra_profiler: IO version: 18
[ 3.587295] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 3.593198] tegra_profiler: auth: init
[ 3.598171] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 3.606137] DDR mapped to address 0x20000000
[ 3.610618] DDR mapped for len 0x10000000
[ 3.614821] REG mapped to address 0x32300000
[ 3.619430] REG mapped for len 0x8000
[ 3.623331] REG mapped to io address 0xf0010000
[ 3.728494] Test Pattern status (f0014104) = 0x1
[ 3.733631] Test Pattern control (f0014100) = 0x1
[ 3.738548] ALpha Blender register
[ 3.842381] Test Pattern status (f0014104) = 0x1
[ 3.847193] AB (f0014004) = 0x0
[ 3.851555] egcfb probe 4 .
[ 3.854469] egcfb_probe vop_convert control0 (f00147b0) = 0x0
[ 3.860409] egcfb_probe vop_convert control1 (f00147c0) = 0x0
[ 3.892696] EGC FB 1 par->virt_addr = e7900000 par->phys_addr = a7900000
[ 3.899554] DESC MEM 0 (0xe67a38c0) mapped to Phy Addr (0xa67a38c0) for len = 0x60
[ 3.908046] egcfb2 registered.
[ 3.911239] egc-framebuffer egc-framebuffer: fb2: egcfb registered!
[ 3.917636] egcfb probe 4 .
[ 3.920537] egcfb_probe vop_convert control0 (f00147b0) = 0x0
[ 3.926475] egcfb_probe vop_convert control1 (f00147c0) = 0x0
[ 3.960764] EGC FB 0 par->virt_addr = e8b00000 par->phys_addr = a8b00000
[ 3.967621] DESC MEM 0 (0xe67a37c0) mapped to Phy Addr (0xa67a37c0) for len = 0x60
[ 3.976132] egcfb3 registered.
[ 3.979324] egc-framebuffer egc-framebuffer: fb3: egcfb registered!
[ 3.988367] egc-char egc-char: EGCDev Registered with major number = 241 minor = 0
[ 3.997562] tegra-sata tegra-sata.0: version 1.0
[ 3.997625] of_get_named_gpio_flags: can’t parse gpios property
[ 3.999356] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 4.008677] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 4.020926] scsi0 : tegra-sata
[ 4.025328] scsi1 : tegra-sata
[ 4.029123] ata1: SATA max UDMA/133 irq 55
[ 4.033373] ata2: DUMMY
[ 4.041709] tun: Universal TUN/TAP device driver, 1.6
[ 4.046895] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.053828] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.0.3-k
[ 4.061021] igb: Copyright (c) 2007-2013 Intel Corporation.
[ 4.148683] igb 0000:03:00.0: added PHC on eth0
[ 4.153380] igb 0000:03:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 4.160483] igb 0000:03:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 00:20:ce:fe:01:0f
[ 4.167842] igb 0000:03:00.0: eth0: PBA No: 000300-000
[ 4.173104] igb 0000:03:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 4.181437] usbcore: registered new interface driver asix
[ 4.187107] usbcore: registered new interface driver ax88179_178a
[ 4.193435] usbcore: registered new interface driver cdc_ether
[ 4.199536] usbcore: registered new interface driver smsc95xx
[ 4.205627] usbcore: registered new interface driver cdc_subset
[ 4.211866] usbcore: registered new interface driver cdc_ncm
[ 4.217708] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.224936] tegra USB phy - inst[1] platform info:
[ 4.229934] port_otg: no
[ 4.232572] has_hostpc: yes
[ 4.235484] phy_interface: USB_PHY_INTF_UTMI
[ 4.239856] op_mode: TEGRA_USB_OPMODE_HOST
[ 4.244049] qc2_voltage: 0
[ 4.246848] vbus_gpio: -1
[ 4.249640] hot_plug: disabled
[ 4.252822] remote_wakeup: enabled
[ 4.258680] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 4.264788] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 4.272870] Wake40 for irq=53
[ 4.275891] Wake42 for irq=53
[ 4.279031] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 4.290382] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[ 4.296740] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.303699] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.311058] usb usb1: Product: Tegra EHCI Host Controller
[ 4.316667] usb usb1: Manufacturer: Linux 3.10.40-geip-mc10k1-rel1.0-L4T-R21.4 EMBIEN - 5.8 ehci_hcd
[ 4.325970] usb usb1: SerialNumber: tegra-ehci.1
[ 4.332373] hub 1-0:1.0: USB hub found
[ 4.336497] hub 1-0:1.0: 1 port detected
[ 4.341380] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.341629] tegra USB phy - inst[2] platform info:
[ 4.341640] port_otg: no
[ 4.341648] has_hostpc: yes
[ 4.341657] phy_interface: USB_PHY_INTF_UTMI
[ 4.341666] op_mode: TEGRA_USB_OPMODE_HOST
[ 4.341674] qc2_voltage: 0
[ 4.341681] vbus_gpio: -1
[ 4.341689] hot_plug: disabled
[ 4.341697] remote_wakeup: enabled
[ 4.343988] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 4.344061] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 4.344379] Wake41 for irq=129
[ 4.344389] Wake43 for irq=129
[ 4.344455] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 4.350386] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[ 4.350633] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.350658] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.350678] usb usb2: Product: Tegra EHCI Host Controller
[ 4.350698] usb usb2: Manufacturer: Linux 3.10.40-geip-mc10k1-rel1.0-L4T-R21.4 EMBIEN - 5.8 ehci_hcd
[ 4.350716] usb usb2: SerialNumber: tegra-ehci.2
[ 4.352455] hub 2-0:1.0: USB hub found
[ 4.352514] hub 2-0:1.0: 1 port detected
[ 4.353731] ehci-pci: EHCI PCI platform driver
[ 4.354706] tegra_xusb_read_usb_calib: usb_calib0 = 0x0305838b
[ 4.356196] usbcore: registered new interface driver usb-storage
[ 4.356858] usbcore: registered new interface driver usbserial
[ 4.356983] usbcore: registered new interface driver option
[ 4.357084] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.357508] usbcore: registered new interface driver pl2303
[ 4.357625] usbserial: USB Serial support registered for pl2303
[ 4.357668] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 4.358113] tegra USB phy - inst[0] platform info:
[ 4.358122] port_otg: yes
[ 4.358129] has_hostpc: yes
[ 4.358137] phy_interface: USB_PHY_INTF_UTMI
[ 4.358145] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 4.358153] qc2_voltage: 0
[ 4.358160] vbus_pmu_irq: 0
[ 4.358168] vbus_gpio: -1
[ 4.358175] charging: enabled
[ 4.358183] remote_wakeup: disabled
[ 4.362894] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 4.371082] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 4.371105] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 4.377731] i2c /dev entries driver
[ 4.381161] tegra_dtv_probe: probing dtv.
[ 4.382785] setup_stream: bufsize = 4096, bufnum = 4DESC MEM 0 (0xe6003740) mapped to Phy Addr (0xa6003740) for len = 0x80
[ 4.382836] Init next idx = 0, cur_idx = 0
[ 4.382851] egcvideo0: EGC Video Device 1.0
[ 4.383415] DESC MEM 0 (0xe6003640) mapped to Phy Addr (0xa6003640) for len = 0x80
[ 4.383467] Init next idx = 0, cur_idx = 0
[ 4.383481] egcvideo1: EGC Video Device 1.0
[ 4.384388] usbcore: registered new interface driver uvcvideo
[ 4.384396] USB Video Class driver (1.1.1)
[ 4.386941] zram: Created 1 device(s) …
[ 4.390613] sdhci: Secure Digital Host Controller Interface driver
[ 4.390621] sdhci: Copyright(c) Pierre Ossman
[ 4.390630] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.391790] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 4.392246] sdhci-tegra sdhci-tegra.3: Speedo value 2187
[ 4.392342] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1100, boot_mv 1100, min_or_mv 1100
[ 4.513393] otg state changed: SUSPEND → HOST
[ 4.514157] tegra USB phy - inst[0] platform info:
[ 4.514166] port_otg: yes
[ 4.514174] has_hostpc: yes
[ 4.514182] phy_interface: USB_PHY_INTF_UTMI
[ 4.514191] op_mode: TEGRA_USB_OPMODE_HOST
[ 4.514199] qc2_voltage: 0
[ 4.514207] vbus_gpio: -1
[ 4.514214] hot_plug: disabled
[ 4.514222] remote_wakeup: enabled
[ 4.654375] usb 2-1: new full-speed USB device number 2 using tegra-ehci
[ 4.673582] usb 2-1: New USB device found, idVendor=0451, idProduct=2046
[ 4.673609] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.675972] hub 2-1:1.0: USB hub found
[ 4.676638] hub 2-1:1.0: 4 ports detected
[ 4.723069] mmc0: no vqmmc regulator found
[ 4.727366] mmc0: no vmmc regulator found
[ 4.731591] mmc0: Invalid maximum block size, assuming 512 bytes
[ 4.737855] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 4.772386] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 4.782485] sdhci-tegra sdhci-tegra.2: Speedo value 2187
[ 4.788244] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1100, boot_mv 1100, min_or_mv 1100
[ 4.801048] mmc1: no vqmmc regulator found
[ 4.805361] mmc1: no vmmc regulator found
[ 4.809477] mmc1: Invalid maximum block size, assuming 512 bytes
[ 4.850793] mmc0: new high speed DDR MMC card at address 0001
[ 4.815713] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 4.856817] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 4.857399] mmcblk mmc0:0001: Card claimed for testing.
[ 4.857929] mmcblk0: mmc0:0001 VM010B 3.60 GiB
[ 4.874907] gpio wake56 for gpio=170
[ 4.878211] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 4.894643] tegra-se tegra12-se: tegra_se_probe: complete
[ 4.909186] usbcore: registered new interface driver usbhid
[ 4.914907] usbhid: USB HID core driver
[ 4.920195] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 5.009008] usbcore: registered new interface driver snd-usb-audio
[ 5.016739] oprofile: using timer interrupt.
[ 5.021472] GACT probability NOT on
[ 5.025093] Mirror/redirect action on
[ 5.028863] u32 classifier
[ 5.031663] Actions configured
[ 5.035172] Netfilter messages via NETLINK v0.30.
[ 5.040240] nf_conntrack version 0.5.0 (14972 buckets, 59888 max)
[ 5.047746] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.054834] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.061873] xt_time: kernel timezone is -0000
[ 5.067432] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.073388] arp_tables: (C) 2002 David S. Miller
[ 5.078232] TCP: cubic registered
[ 5.082228] NET: Registered protocol family 10
[ 5.089607] mip6: Mobile IPv6
[ 5.093124] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.099335] sit: IPv6 over IPv4 tunneling driver
[ 5.107069] NET: Registered protocol family 17
[ 5.111747] NET: Registered protocol family 15
[ 5.116550] NET: Registered protocol family 35
[ 5.121465] NET: Registered protocol family 37
[ 5.126046] NET: Registered protocol family 41
[ 5.134964] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 5.221417] Registering SWP/SWPB emulation handler
[ 5.226344] last reset is due to power on reset
[ 5.226344]
[ 5.232500] Disabling clocks left on by bootloader:
[ 5.237430] audio_2x
[ 5.239983] audio
[ 5.242285] audio4
[ 5.244649] audio3
[ 5.247013] audio2
[ 5.249375] audio1
[ 5.251732] audio0
[ 5.254368] hdmi_audio
[ 5.257087] entropy
[ 5.259586] dsi2-fixed
[ 5.262300] dsi1-fixed
[ 5.265061] nor
[ 5.267171] trace
[ 5.269469] sdmmc3_ddr
[ 5.272332] cclk_lp
[ 5.274799] pll_x_out0
[ 5.277545] pll_m_out1
[ 5.280596] tegra_dvfs: vdd_cpu connected to regulator
[ 5.286034] tegra_dvfs: vdd_core connected to regulator
[ 5.291523] tegra_dvfs: vdd_gpu connected to regulator
[ 5.301423] cpu_cold cooling device is registered
[ 5.306974] Tegra CPU DFLL is initialized with use_dfll = 0
[ 5.312827] CPU rate: 204 MHz
[ 5.316137] cpu_hot cooling device is registered
[ 5.516703] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[ 5.522821] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[ 5.530851] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[ 5.542379] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[ 5.548649] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.555569] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.562916] usb usb3: Product: Tegra EHCI Host Controller
[ 5.568421] usb usb3: Manufacturer: Linux 3.10.40-geip-mc10k1-rel1.0-L4T-R21.4 EMBIEN - 5.8 ehci_hcd
[ 5.577681] usb usb3: SerialNumber: tegra-ehci.0
[ 5.584032] hub 3-0:1.0: USB hub found
[ 5.587958] hub 3-0:1.0: 1 port detected
[ 6.293469] tegra dvfs: tegra sysfs cap interface is initialized
[ 6.299911] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 6.308482] tegra_actmon.emc: Completed initialization (0)
[ 6.314852] tegra_actmon.avp: Completed initialization (0)
[ 6.320948] tegra_mon.cpu_emc: Completed initialization (0)
[ 6.336549] reg-aon-1v2: incomplete constraints, leaving on
[ 6.342285] reg-aon-1v8: incomplete constraints, leaving on
[ 6.348195] vdd-cdc-1v2-aud: incomplete constraints, leaving on
[ 6.354235] sdmmc-en-supply: incomplete constraints, leaving on
[ 6.360468] reg-dcdc-1v2: incomplete constraints, leaving on
[ 6.366496] reg-5v0-supply: incomplete constraints, leaving on
[ 6.372458] avdd-hdmi-pll: incomplete constraints, leaving on
[ 6.378462] vpp-fuse: incomplete constraints, leaving on
[ 6.383935] vdd-2v7-cam: incomplete constraints, leaving on
[ 6.389626] avdd-spi: incomplete constraints, leaving on
[ 6.395051] vdd-1v1-cam: incomplete constraints, leaving on
[ 6.400735] vddio-sdmmc-2: incomplete constraints, leaving on
[ 6.406587] vdd-1v2-cam: incomplete constraints, leaving on
[ 6.412294] avdd-cam: incomplete constraints, leaving on
[ 6.417721] vdd-cam: incomplete constraints, leaving on
[ 6.423060] as3722-sd3: incomplete constraints, leaving on
[ 6.428650] reg-3v3-supply: incomplete constraints, leaving on
[ 6.434586] vdd-3v3-aon: incomplete constraints, leaving on
[ 6.440397] vdd-ac-bat: incomplete constraints, leaving on
[ 6.446021] regulator-dummy: incomplete constraints, leaving on
[ 6.454701] of_get_named_gpio_flags exited with status 128
[ 6.454857] gpio wake51 for gpio=128
[ 6.459342] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input0
[ 6.468623] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:00:16 UTC (946684816)
[ 7.216104] ALSA device list:
[ 7.219204] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 7.227086] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 7.236541] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 7.527480] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40358
[ 7.535410] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40343
[ 7.535812] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40334
[ 7.536148] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40312
[ 7.536760] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40317
[ 7.537086] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40315
[ 7.537485] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40314
[ 7.537813] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40243
[ 7.538217] EXT4-fs (mmcblk0p1): ext4_orphan_cleanup: deleting unreferenced inode 40353
[ 7.538801] EXT4-fs (mmcblk0p1): 9 orphan inodes deleted
[ 7.544305] EXT4-fs (mmcblk0p1): recovery complete
[ 7.581895] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.590551] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.597623] devtmpfs: mounted
[ 7.601975] Freeing unused kernel memory: 500K (c0ab0000 - c0b2d000)
[ 8.329859] init: plymouth-upstart-bridge main process (117) terminated with status 1
[ 8.338077] init: plymouth-upstart-bridge main process ended, respawning
[ 8.462403] init: plymouth-upstart-bridge main process (127) terminated with status 1
[ 8.470593] init: plymouth-upstart-bridge main process ended, respawning
[ 8.484946] init: ureadahead main process (120) terminated with status 5
[ 8.611067] init: plymouth-upstart-bridge main process (131) terminated with status 1
[ 8.619576] init: plymouth-upstart-bridge main process ended, respawning
[ 12.732332] init: idmapd main process (282) terminated with status 1
[ 12.732560] init: idmapd main process ended, respawning
[ 12.771601] systemd-udevd[303]: starting version 204
[ 13.777482] Tegra cpuquiet clusterswitch enabled
[ 14.017137] tegra-xhci tegra-xhci: Firmware File: tegra_xusb_firmware (134656 Bytes)
[ 14.017563] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x80080000 mapped 0xf00b9000 (134656 Bytes)
[ 14.018704] tegra-xhci tegra-xhci: XUSB device id = 0xfa3 (T124+)
[ 14.071286] tegra-xhci tegra-xhci: Firmware timestamp: 2014-09-16 02:10:07 UTC, Falcon state 0x20
[ 14.071346] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 14.071368] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 4
[ 14.072225] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 14.072319] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 14.072325] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.072330] usb usb4: Product: Nvidia xHCI Host Controller
[ 14.072336] usb usb4: Manufacturer: Linux 3.10.40-geip-mc10k1-rel1.0-L4T-R21.4 EMBIEN - 5.8 tegra-xhci
[ 14.072341] usb usb4: SerialNumber: tegra-xhci
[ 14.072679] xHCI xhci_add_endpoint called for root hub
[ 14.072686] xHCI xhci_check_bandwidth called for root hub
[ 14.072763] hub 4-0:1.0: USB hub found
[ 14.072778] hub 4-0:1.0: 6 ports detected
[ 14.084281] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 14.084301] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 5
[ 14.084390] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 14.084397] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.084403] usb usb5: Product: Nvidia xHCI Host Controller
[ 14.084410] usb usb5: Manufacturer: Linux 3.10.40-geip-mc10k1-rel1.0-L4T-R21.4 EMBIEN - 5.8 tegra-xhci
[ 14.084416] usb usb5: SerialNumber: tegra-xhci
[ 14.084778] xHCI xhci_add_endpoint called for root hub
[ 14.084784] xHCI xhci_check_bandwidth called for root hub
[ 14.084873] hub 5-0:1.0: USB hub found
[ 14.084890] hub 5-0:1.0: 2 ports detected
[ 14.094294] Wake58 for irq=81
[ 14.168835] init: idmapd main process (401) terminated with status 1
[ 14.168870] init: idmapd main process ended, respawning
[ 14.214116] init: bluetooth main process (389) terminated with status 1
[ 14.214151] init: bluetooth main process ended, respawning
[ 14.552964] init: idmapd main process (485) terminated with status 1
[ 14.552998] init: idmapd main process ended, respawning
[ 14.703869] init: bluetooth main process (499) terminated with status 1
[ 14.703909] init: bluetooth main process ended, respawning
[ 14.766210] init: idmapd main process (527) terminated with status 1
[ 14.766235] init: idmapd main process ended, respawning
[ 15.471996] init: bluetooth main process (653) terminated with status 1
[ 15.472038] init: bluetooth main process ended, respawning
[ 15.476771] init: idmapd main process (781) terminated with status 1
[ 15.476806] init: idmapd main process ended, respawning
[ 15.628297] init: bluetooth main process (844) terminated with status 1
[ 15.628331] init: bluetooth main process ended, respawning
[ 15.630753] init: idmapd main process (847) terminated with status 1
[ 15.630789] init: idmapd main process ended, respawning
[ 15.857964] init: bluetooth main process (897) terminated with status 1
[ 15.857991] init: bluetooth main process ended, respawning
[ 15.870144] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.897846] init: idmapd main process (920) terminated with status 1
[ 15.897874] init: idmapd main process ended, respawning
[ 15.994639] init: bluetooth main process (978) terminated with status 1
[ 15.994670] init: bluetooth main process ended, respawning
[ 15.999710] init: idmapd main process (993) terminated with status 1
[ 15.999749] init: idmapd main process ended, respawning
[ 16.474296] init: idmapd main process (1148) terminated with status 1
[ 16.474340] init: idmapd main process ended, respawning
[ 16.586147] init: bluetooth main process (1147) terminated with status 1
[ 16.586186] init: bluetooth main process ended, respawning
[ 16.841143] init: idmapd main process (1312) terminated with status 1
[ 16.841166] init: idmapd main process ended, respawning
[ 17.070254] init: bluetooth main process (1338) terminated with status 1
[ 17.070286] init: bluetooth main process ended, respawning
[ 17.567302] init: idmapd main process (1520) terminated with status 1
[ 17.567339] init: idmapd main process ended, respawning
[ 17.704564] init: plymouth-upstart-bridge main process ended, respawning
[ 17.706650] init: bluetooth main process (1609) terminated with status 1
[ 17.706688] init: bluetooth main process ended, respawning
[ 17.817729] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[ 17.875236] init: idmapd main process (1682) terminated with status 1
[ 17.875331] init: idmapd main process ended, respawning
[ 17.914442] MC10K1 - rc.local: Disabled pause frame support and reset eth0
[ 17.972998] init: bluetooth main process (1699) terminated with status 1
[ 17.973040] init: bluetooth main process ended, respawning
[ 18.072631] init: plymouth-stop pre-start process (1746) terminated with status 1
[ 18.125341] init: idmapd main process (1757) terminated with status 1
[ 18.125386] init: idmapd main process ended, respawning
[ 18.205259] init: bluetooth main process (1768) terminated with status 1
[ 18.205287] init: bluetooth respawning too fast, stopped
[ 18.238870] init: idmapd main process (1793) terminated with status 1
[ 18.238895] init: idmapd main process ended, respawning
[ 18.347137] init: idmapd main process (1815) terminated with status 1
[ 18.347163] init: idmapd main process ended, respawning
[ 18.407977] init: idmapd main process (1828) terminated with status 1
[ 18.408001] init: idmapd main process ended, respawning
[ 18.472586] init: idmapd main process (1841) terminated with status 1
[ 18.472612] init: idmapd main process ended, respawning
[ 18.533821] init: idmapd main process (1854) terminated with status 1
[ 18.533856] init: idmapd main process ended, respawning
[ 18.596826] init: idmapd main process (1867) terminated with status 1
[ 18.596849] init: idmapd main process ended, respawning
[ 18.672131] init: idmapd main process (1886) terminated with status 1
[ 18.672164] init: idmapd main process ended, respawning
[ 18.713344] init: idmapd main process (1899) terminated with status 1
[ 18.713367] init: idmapd respawning too fast, stopped
[ 18.788302] egc_as_share_list_add Adding addr 0xe552f480 for pid = 1639
[ 19.470276] egc_as_share_list_add Adding addr 0xe4157940 for pid = 1973
[ 22.482663] egc_as_share_list_add Adding addr 0xe528acc0 for pid = 2163
[ 23.348271] HDMI: No HDMI device connected
[ 25.236923] egc_as_share_list_add Adding addr 0xe3d26cc0 for pid = 2403
[ 30.381782] Tegra cpuquiet clusterswitch disabled
[ 30.381875] cluster/immediate → 1
[ 30.381927] cluster/force → 1
[ 30.381977] cluster/active → G
[ 40.028976] egc_as_share_list_add Adding addr 0xd9a26b40 for pid = 2665
[ 40.176235] egc_as_share_list_add Adding addr 0xc79f0440 for pid = 2706
[ 40.555794] egc_as_share_list_add Adding addr 0xc6b27b40 for pid = 2665
[ 40.555942] egc_as_share_list_add Adding addr 0xc5c16400 for pid = 2665
[ 40.593440] Configuring Channel 2 x= 1000, y = 60, w = 800, h = 500
[ 40.593452] Offset 4: Before Config 0x0
[ 40.593457] Offset 8: Before Config 0x0
[ 40.593461] Offset c: Before Config 0x0
[ 40.593468] Resolution: Written 0x1f40320 got back 0x0
[ 40.593494] Configuring Channel 3 x= 100, y = 580, w = 800, h = 500
[ 40.593500] Offset 4: Before Config 0x0
[ 40.593505] Offset 8: Before Config 0x0
[ 40.593509] Offset c: Before Config 0x0
[ 40.593515] Resolution: Written 0x1f40320 got back 0x0
[ 40.696647] Configuring Channel 0 x= 0, y = 0, w = 1920, h = 1080
[ 40.696656] Offset 4: Before Config 0x0
[ 40.696661] Offset 8: Before Config 0x0
[ 40.696665] Offset c: Before Config 0x0
[ 40.696672] Resolution: Written 0x4380780 got back 0x0
[ 40.794264] EGCDev: Device has been opened 1 time(s)
[ 40.794272] EGCDev: Device has been opened 2 time(s)
[ 40.794312] Configuring Channel 2 x= 0, y = 0, w = 1920, h = 1080
[ 40.794316] Configuring Channel 3 x= 0, y = 0, w = 1920, h = 1080
[ 40.794320] Offset 4: Before Config 0x0
[ 40.794323] Offset 8: Before Config 0x0
[ 40.794326] Offset c: Before Config 0x0
[ 40.794335] Offset 4: Before Config 0x0
[ 40.794342] Offset 8: Before Config 0x0
[ 40.794347] Offset c: Before Config 0x0
[ 40.829216] Configuring Channel 1 x= 100, y = 60, w = 800, h = 500
[ 40.829225] Offset 4: Before Config 0x0
[ 40.829231] Offset 8: Before Config 0x0
[ 40.829260] Offset c: Before Config 0x0
[ 40.829268] Resolution: Written 0x1f40320 got back 0x0
[ 40.838261] Resolution: Written 0x4380780 got back 0x0
[ 40.838278] Resolution: Written 0x4380780 got back 0x0
[ 40.897925] EGCDev: Device has been opened 3 time(s)
[ 40.897939] Configuring Channel 0 x= 0, y = 0, w = 1920, h = 1080
[ 40.897944] Offset 4: Before Config 0x0
[ 40.897949] Offset 8: Before Config 0x0
[ 40.897953] Offset c: Before Config 0x0
[ 40.919251] Resolution: Written 0x4380780 got back 0x0
[ 41.030264] EGCDev: Device has been opened 4 time(s)
[ 41.030276] Configuring Channel 1 x= 0, y = 0, w = 1920, h = 1080
[ 41.030281] Offset 4: Before Config 0x0
[ 41.030285] Offset 8: Before Config 0x0
[ 41.030288] Offset c: Before Config 0x0
[ 41.041254] Resolution: Written 0x4380780 got back 0x0
[ 41.050265] Configuring Channel 3 x= 0, y = 0, w = 1920, h = 1080
[ 41.050267] Configuring Channel 2 x= 0, y = 0, w = 1920, h = 1080
[ 41.050271] Offset 4: Before Config 0x0
[ 41.050274] Offset 8: Before Config 0x0
[ 41.050277] Offset c: Before Config 0x0
[ 41.050284] Offset 4: Before Config 0x0
[ 41.050288] Offset 8: Before Config 0x0
[ 41.050292] Offset c: Before Config 0x0
[ 41.061252] Resolution: Written 0x4380780 got back 0x0
[ 41.061255] Resolution: Written 0x4380780 got back 0x0
[ 41.131261] Configuring Channel 0 x= 0, y = 0, w = 1920, h = 1080
[ 41.131267] Offset 4: Before Config 0x0
[ 41.131271] Offset 8: Before Config 0x0
[ 41.131275] Offset c: Before Config 0x0
[ 41.143047] Resolution: Written 0x4380780 got back 0x0
[ 41.253263] Configuring Channel 1 x= 0, y = 0, w = 1920, h = 1080
[ 41.253270] Offset 4: Before Config 0x0
[ 41.253274] Offset 8: Before Config 0x0
[ 41.253277] Offset c: Before Config 0x0
[ 41.262249] EGCDev: Device has been opened 5 time(s)
[ 41.262251] EGCDev: Device has been opened 6 time(s)
[ 41.264257] Resolution: Written 0x4380780 got back 0x0
[ 41.343259] EGCDev: Device has been opened 7 time(s)
[ 41.465886] EGCDev: Device has been opened 8 time(s)
[ 137.184009] init: plymouth-stop pre-start process (2943) terminated with status 1
