Hello Greg,
Here it is
U-Boot SPL 2014.10-rc2-00002-g105d2f3 (Jun 25 2015 - 15:19:50)
U-Boot 2014.10-rc2-00002-g105d2f3 (Jun 25 2015 - 15:19:50)
TEGRA124
Board: NVIDIA Jetson TK1
I2C: ready
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x12000000-0x12010000
tegra-pcie: non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie: prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
ïù…Öµpcie: probing port 0, using 2 lanes
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
tegra-pcie: probing port 1, using 1 lanes
In: serial
Out: serial
Err: serial
Net: RTL8169#0
Error: RTL8169#0 address not set.
Hit any key to stop autoboot: 2 1 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
813 bytes read in 278 ms (2 KiB/s)
Jetson-TK1 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/zImage
5943808 bytes read in 185 ms (30.6 MiB/s)
append: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
Retrieving file: /boot/tegra124-jetson_tk1-pm375-000-c00-00.dtb
59637 bytes read in 56 ms (1 MiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x5ab200 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 820118f4
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-dbg (root@tegra-ubuntu) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04) ) #2 SMP PREEMPT Sat Oct 17 16:21:58 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f8500000 - f96fffff
[ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/boot/dts/tegra124-jetson_tk1-pm375-000-c00-00.dts
[ 0.000000] Tegra12: CPU Speedo value 2216, Soc Speedo value 2143, Gpu Speedo value 1996
[ 0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[ 0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[ 0.000000] Lowering se maximum rate from 600000000 to 480000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 480000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2218500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df3000 s15360 r8192 d13312 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 490768
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1923MB = 1923MB total
[ 0.000000] Memory: 1920996k/1920996k available, 142364k reserved, 1190908K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0af1778 (11174 kB)
[ 0.000000] .init : 0xc0af2000 - 0xc0b73c00 ( 519 kB)
[ 0.000000] .data : 0xc0b74000 - 0xc0ccfb90 (1391 kB)
[ 0.000000] .bss : 0xc0ccfb90 - 0xc0d6aa4c ( 620 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.002948] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.003003] pid_max: default: 32768 minimum: 301
[ 0.003336] Mount-cache hash table entries: 512
[ 0.026089] Initializing cgroup subsys debug
[ 0.026129] Initializing cgroup subsys freezer
[ 0.026209] CPU: Testing write buffer coherency: ok
[ 0.026275] ftrace: allocating 30358 entries in 60 pages
[ 0.065271] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.065317] Setting up static identity map for 0xc07dda48 - 0xc07ddaf4
[ 0.069269] ftrace: Allocated trace_printk buffers
[ 0.076935] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.079947] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.083009] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.083210] Brought up 4 CPUs
[ 0.083271] SMP: Total of 4 processors activated.
[ 0.083286] CPU: All CPU(s) started in SVC mode.
[ 0.084472] devtmpfs: initialized
[ 0.093153] pinctrl core: initialized pinctrl subsystem
[ 0.093574] regulator-dummy: no parameters
[ 0.094366] NET: Registered protocol family 16
[ 0.096931] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.098267] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.099332] console [pstore-1] enabled
[ 0.099369] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[ 0.099767] cpuidle: using governor ladder
[ 0.099789] cpuidle: using governor menu
[ 0.103573] ardbeg_camera_auxdata: update camera lookup table.
[ 0.112798] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.113215] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.120227] Wake16 for irq=34
[ 0.122748] Wake58 for irq=81
[ 0.122799] Wake41 for irq=129
[ 0.122818] Wake43 for irq=129
[ 0.122864] Wake40 for irq=53
[ 0.122881] Wake42 for irq=53
[ 0.127276] board_info: id:sku:fab:major:minor = 0xffff:0xffff:0xff:0x40:0xff
[ 0.127360] board_info: id:sku:fab:major:minor = 0xffff:0xffff:0xff:0x40:0xff
[ 0.127444] Selecting UARTD as the debug console
[ 0.127489] The debug console clock name is uartd
[ 0.127953] ardbeg_modem_init: modem_id = 0
[ 0.127976] Shield ERS 0xffff
[ 0.130056] PMU board id 0x0177 is not supported
[ 0.130621] Clear bootloader IO dpd settings
[ 0.130889] emc dvfs table not present
[ 0.130968] ardbeg_edp_init: CPU regulator 11000 mA
[ 0.409886] ardbeg_edp_init: GPU regulator 11400 mA
[ 0.410831] swapper/0 isomgr_init(): iso emc max clk=1200000KHz
[ 0.410852] swapper/0 isomgr_init(): max_iso_bw=9600000KB[ 0.411215] ardbeg_touch_init init raydium touch
[ 0.411359] Raydium - touch platform_id : 8
[ 0.518436] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[ 0.521833] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[ 0.526954] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[ 0.530326] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[ 0.530462] *** MPU START *** mpuirq_init...
[ 0.530561] *** MPU END *** mpuirq_init...
[ 0.530901] soctherm THERMTRIP not supported on PMU (BOARD_E375)
[ 0.531091] tegra11_soctherem_oc_int_init(): OC interrupts enabled successful
[ 0.531516] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.531547] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.531961] mc-err: Started MC error interface!
[ 0.542665] bio: create slab <bio-0> at 0
[ 0.544623] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[ 0.544660] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[ 0.544796] vdd-ac-bat: 8400 mV
[ 0.544960] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.544993] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.545120] vdd-3v3-aon: 3300 mV
[ 0.545275] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[ 0.545308] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[ 0.545339] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[ 0.545377] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[ 0.545408] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[ 0.545439] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[ 0.545470] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[ 0.545501] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[ 0.545531] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[ 0.545562] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[ 0.545702] reg-3v3-supply: 3300 mV
[ 0.547359] vgaarb: loaded
[ 0.548014] SCSI subsystem initialized
[ 0.548410] usbcore: registered new interface driver usbfs
[ 0.548476] usbcore: registered new interface driver hub
[ 0.548587] usbcore: registered new device driver usb
[ 0.551768] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[ 0.551798] as3722 4-0040: Final OTP version 1V21
[ 0.557393] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.557599] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.557661] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.557715] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.557748] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.557779] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.557811] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.557871] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.557904] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.557935] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.557967] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.557999] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.558030] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.558085] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.558154] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.558186] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.558218] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.558249] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.558284] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.558318] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.558349] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.558381] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.558413] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.558445] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.558477] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.558509] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.558540] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.558599] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.558631] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.558687] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.558719] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.558750] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.558782] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.558813] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.558844] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.558876] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.558907] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.558939] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.558999] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.559031] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.559141] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.559174] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.559205] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.559262] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.559315] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.559347] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.559378] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.559435] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.559467] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.559526] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.559585] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.559617] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.559696] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.559728] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.559759] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.560705] vdd-cpu: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.561489] vdd-core: applied init 1000000uV constraint
[ 0.562089] vdd-core: 700 <--> 1350 mV at 1000 mV 3500 mA
[ 0.563319] vddio-ddr: at 1350 mV
[ 0.563647] as3722-sd3: no parameters
[ 0.564235] avdd-pll-pex: 1050 mV
[ 0.565452] vdd-1v8: at 1800 mV
[ 0.565794] vdd-gpu: applied init 1000000uV constraint
[ 0.566671] vdd-gpu: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.567202] avdd-pll: at 1050 mV at 300 mA
[ 0.568482] vdd-cam: 1800 mV at 150 mA
[ 0.569157] avdd-dsi-csi: at 1200 mV at 150 mA
[ 0.570401] vdd-rtc: 800 mV at 150 mA
[ 0.570889] avdd-cam: 2800 mV at 150 mA
[ 0.571403] vdd-1v2-cam: 1175 mV at 150 mA
[ 0.571777] vddio-sdmmc-2: 1800 <--> 3300 mV at 150 mA
[ 0.572298] vdd-1v1-cam: 1275 mV at 150 mA
[ 0.573285] avdd-spi: 3300 mV at 150 mA
[ 0.573796] vdd-2v7-cam: 2800 mV at 150 mA
[ 0.574313] vpp-fuse: 1800 mV at 150 mA
[ 0.575413] Linux video capture interface: v2.00
[ 0.576559] Advanced Linux Sound Architecture Driver Initialized.
[ 0.577040] ardbeg_wifi_power: 1
[ 0.677403] usb0-vbus: 5000 mV
[ 0.677732] usb1-usb2-vbus: 5000 mV
[ 0.678050] vdd-hdmi: 5000 mV
[ 0.678355] avdd-hdmi-pll: 3300 mV
[ 0.678407] avdd-hdmi-pll: supplied by avdd-pll-pex
[ 0.678582] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[ 0.678728] vdd-lcd-bl: 3300 mV
[ 0.678889] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[ 0.679065] vdd-lcd-bl-en: 5000 mV
[ 0.679224] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[ 0.679371] reg-5v0-supply: 5000 mV
[ 0.679541] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[ 0.679576] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[ 0.679607] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[ 0.679655] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[ 0.679687] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[ 0.679718] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[ 0.679750] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[ 0.679781] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[ 0.679812] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[ 0.679959] reg-1v8-supply: 1800 mV
[ 0.680285] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[ 0.680442] reg-dcdc-1v2: 1200 mV
[ 0.680624] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[ 0.680659] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[ 0.681238] as3722-gpio2-supply: 3300 mV
[ 0.681447] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[ 0.681978] as3722-gpio4-supply: 3300 mV
[ 0.682292] sdmmc-en-supply: 3300 mV
[ 0.682563] vdd-cdc-1v2-aud: 1200 mV
[ 0.682726] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[ 0.682762] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[ 0.682795] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[ 0.682919] reg-aon-1v8: 1800 mV
[ 0.683108] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[ 0.683240] reg-aon-1v2: 1200 mV
[ 0.686295] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[ 0.689630] tegra: started io power detection dynamic control
[ 0.689657] tegra: NO_IO_POWER setting 0x0
[ 0.689684] Switching to clocksource arch_sys_counter
[ 0.711717] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.711960] nvmap_page_pool_init: Total MB RAM: 1891
[ 0.711984] nvmap_page_pool_init: nvmap page pool size: 60543 pages (236 MB)
[ 0.712157] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.712339] iram: dma coherent mem declare 0x40001000,258048
[ 0.713200] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.713373] nvmap:inner cache maint threshold=2097152
[ 0.723439] Wake39 for irq=52
[ 0.723533] tegra-otg tegra-otg: otg transceiver registered
[ 0.723933] NET: Registered protocol family 2
[ 0.724694] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.724922] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.725115] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.725175] TCP: reno registered
[ 0.725201] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.725257] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.725642] NET: Registered protocol family 1
[ 0.726078] RPC: Registered named UNIX socket transport module.
[ 0.726103] RPC: Registered udp transport module.
[ 0.726122] RPC: Registered tcp transport module.
[ 0.726141] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.726440] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.732106] host1x host1x: initialized
[ 0.733372] CPU PMU: probing PMU on CPU 0
[ 0.733408] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.734082] tegra_throttle : init passed
[ 0.734215] Tegra cpuquiet initialized: disabled
[ 0.734362] cpu-tegra: init EDP limit: 2218 MHz
[ 0.735295] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.735672] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.735932] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.736171] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.737881] bounce pool size: 64 pages
[ 0.739398] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.739691] NTFS driver 2.1.30 [Flags: R/O].
[ 0.739853] fuse init (API version 7.22)
[ 0.740095] msgmni has been set to 1457
[ 0.741503] io scheduler noop registered (default)
[ 0.949992] PCIE: port 0: link down, retrying
[ 1.150139] PCIE: port 0: link down, retrying
[ 1.350280] PCIE: port 0: link down, retrying
[ 1.350303] PCIE: port 0: link down, ignoring
[ 1.355470] PCI host bridge to bus 0000:00
[ 1.355501] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 1.355531] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 1.355562] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 1.355589] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 1.355993] PCI: bus0: Fast back to back transfers disabled
[ 1.356021] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.357799] PCI: bus1: Fast back to back transfers disabled
[ 1.358150] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 1.358179] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.358433] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[ 1.358468] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
[ 1.358501] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.358533] pci 0000:01:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
[ 1.358579] pci 0000:01:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
[ 1.358624] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.358654] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 1.358679] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.358708] pcieport 0000:00:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 1.358762] pcieport 0000:00:00.0: bridge window [mem 0x12100000-0x121fffff 64bit pref]
[ 1.358805] PCIE: No Link speed change happened
[ 1.359369] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 1.359478] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 1.360423] tsec tsec: initialized
[ 1.361974] isp isp.0: initialized
[ 1.362994] isp isp.1: initialized
[ 1.364597] falcon vic03.0: initialized
[ 1.365814] falcon msenc: initialized
[ 1.366651] tegradc tegradc.0: DSI: HS clock rate is 464500
[ 1.368132] p,wuxga-10-1 panel dt support not available
[ 1.647671] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[ 1.736929] tegradc tegradc.0: DSI pad calibration done
[ 1.744084] tegradc tegradc.0: probed
[ 1.744607] tegradc tegradc.0: fb registered
[ 1.744630] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 1.750521] gpio wake4 for gpio=111
[ 2.749780] tegra-i2c tegra12-i2c.3: --- register dump for debugging ----
[ 2.749812] tegra-i2c tegra12-i2c.3: I2C_CNFG - 0x2c00
[ 2.749836] tegra-i2c tegra12-i2c.3: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 2.749862] tegra-i2c tegra12-i2c.3: I2C_FIFO_CONTROL - 0xe0
[ 2.749886] tegra-i2c tegra12-i2c.3: I2C_FIFO_STATUS - 0x800040
[ 2.749909] tegra-i2c tegra12-i2c.3: I2C_INT_MASK - 0xed
[ 2.749932] tegra-i2c tegra12-i2c.3: I2C_INT_STATUS - 0x0
[ 2.749955] tegra-i2c tegra12-i2c.3: msg->len - 1
[ 2.749976] tegra-i2c tegra12-i2c.3: is_msg_write - 1
[ 2.749998] tegra-i2c tegra12-i2c.3: next_msg->len - 128
[ 2.750020] tegra-i2c tegra12-i2c.3: is_next_msg_write - 0
[ 2.750043] tegra-i2c tegra12-i2c.3: buf_remaining - 128
[ 2.750070] tegra-i2c tegra12-i2c.3: i2c transfer timed out, addr 0x0050, data 0x00
[ 2.751103] tegradc tegradc.1: probed
[ 2.755807] Console: switching to colour frame buffer device 80x30
[ 2.760406] tegradc tegradc.1: fb registered
[ 2.761903] hdmi_state_machine_worker (tid edb06580): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 2.764850] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 2.768717] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 2.772653] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.775584] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[ 2.807787] hdmi_state_machine_worker (tid edb06580): state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 2.807792] hdmi_disable_l: audio_switch 0
[ 2.807794] hdmi_disable_l: hpd_switch 0
[ 2.807800] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 2.817785] hdmi_state_machine_worker (tid edb06580): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 2.817790] hdmi_disable_l: audio_switch 0
[ 2.817793] hdmi_disable_l: hpd_switch 0
[ 2.817798] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.170025] console [ttyS0] enabled
[ 5.175736] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[ 5.187193] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 5.198935] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 5.216140] loop: module loaded
[ 5.221642] nct1008_nct72 1-004c: Error [-517] in getting the regulator handle for vdd
[ 5.233947] nct1008_nct72: probe of 1-004c failed with error -5
[ 5.242696] tegra_profiler: Branch: Dev
[ 5.248838] tegra_profiler: Version: 1.103
[ 5.255164] tegra_profiler: Samples version: 34
[ 5.261907] tegra_profiler: IO version: 18
[ 5.268171] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 5.275853] tegra_profiler: auth: init
[ 5.282063] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 5.292070] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 5.305409] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 5.319284] scsi0 : tegra-sata
[ 5.324764] scsi1 : tegra-sata
[ 5.329980] ata1: SATA max UDMA/133 irq 55
[ 5.336022] ata2: DUMMY
[ 5.342129] tun: Universal TUN/TAP device driver, 1.6
[ 5.349064] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 5.357341] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 5.367545] r8169 0000:01:00.0 eth0: RTL8168g/8111g at 0xf0000000, 00:00:00:00:00:00, XID 0c000800 IRQ 641
[ 5.380774] r8169 0000:01:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 5.393105] usbcore: registered new interface driver asix
[ 5.400397] usbcore: registered new interface driver ax88179_178a
[ 5.408333] usbcore: registered new interface driver cdc_ether
[ 5.415967] usbcore: registered new interface driver smsc95xx
[ 5.423489] usbcore: registered new interface driver cdc_subset
[ 5.431198] usbcore: registered new interface driver cdc_ncm
[ 5.438585] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.447046] tegra USB phy - inst[1] platform info:
[ 5.453577] port_otg: no
[ 5.457787] has_hostpc: yes
[ 5.462195] phy_interface: USB_PHY_INTF_UTMI
[ 5.468049] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.473671] qc2_voltage: 0
[ 5.477831] vbus_gpio: -1
[ 5.481884] hot_plug: disabled
[ 5.486403] remote_wakeup: enabled
[ 5.492774] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 5.500251] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 5.510921] Wake40 for irq=53
[ 5.515355] Wake42 for irq=53
[ 5.519764] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 5.532781] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[ 5.540148] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.548301] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.558157] usb usb1: Product: Tegra EHCI Host Controller
[ 5.564998] usb usb1: Manufacturer: Linux 3.10.40-dbg ehci_hcd
[ 5.572320] usb usb1: SerialNumber: tegra-ehci.1
[ 5.578958] hub 1-0:1.0: USB hub found
[ 5.584259] hub 1-0:1.0: 1 port detected
[ 5.590005] tegra USB phy - inst[2] platform info:
[ 5.596263] port_otg: no
[ 5.600222] has_hostpc: yes
[ 5.604449] phy_interface: USB_PHY_INTF_UTMI
[ 5.610178] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.615724] qc2_voltage: 0
[ 5.619861] vbus_gpio: -1
[ 5.623912] hot_plug: disabled
[ 5.628401] remote_wakeup: enabled
[ 5.634656] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 5.642086] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 5.644797] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.659490] Wake41 for irq=129
[ 5.664056] Wake43 for irq=129
[ 5.668598] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 5.681780] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[ 5.689269] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.697642] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.707768] usb usb2: Product: Tegra EHCI Host Controller
[ 5.714681] usb usb2: Manufacturer: Linux 3.10.40-dbg ehci_hcd
[ 5.722041] usb usb2: SerialNumber: tegra-ehci.2
[ 5.728652] hub 2-0:1.0: USB hub found
[ 5.733942] hub 2-0:1.0: 1 port detected
[ 5.739695] ehci-pci: EHCI PCI platform driver
[ 5.745917] tegra_xusb_read_usb_calib: usb_calib0 = 0x0285038b
[ 5.753535] usbcore: registered new interface driver usb-storage
[ 5.761235] usbcore: registered new interface driver usbserial
[ 5.768664] usbcore: registered new interface driver option
[ 5.775791] usbserial: USB Serial support registered for GSM modem (1-port)
[ 5.784457] usbcore: registered new interface driver pl2303
[ 5.791703] usbserial: USB Serial support registered for pl2303
[ 5.799308] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 5.810081] tegra USB phy - inst[0] platform info:
[ 5.816552] port_otg: yes
[ 5.820798] has_hostpc: yes
[ 5.825181] phy_interface: USB_PHY_INTF_UTMI
[ 5.831102] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 5.836997] qc2_voltage: 0
[ 5.841366] vbus_pmu_irq: 0
[ 5.845719] vbus_gpio: -1
[ 5.849849] charging: enabled
[ 5.854262] remote_wakeup: disabled
[ 5.861920] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 5.875213] nvi_probe: Probe name mpu9250
[ 5.980872] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 5.994084] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.002292] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.015399] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.023476] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.024787] otg state changed: SUSPEND --> PERIPHERAL
[ 6.043014] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.051108] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.064114] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.072071] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.084932] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.092701] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.105429] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.113094] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.125770] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.133375] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.145959] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.153517] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.161022] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.173551] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.181022] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.193501] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.200887] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.213177] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.220406] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.232548] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.239702] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.251861] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.258998] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.271133] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.278196] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.290199] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.297186] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.309182] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.316167] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.323164] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.331169] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.339161] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.347138] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.355160] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.363138] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.371127] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.379124] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.387107] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.395078] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.403083] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.411055] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.419041] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.427031] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.435011] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.442978] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.450971] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.458939] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.466913] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.474937] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.482912] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.490899] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.498908] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.506903] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.514883] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.522902] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.530885] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.538887] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.546897] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.554917] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.562899] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.570919] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.578899] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.586893] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.594900] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.602894] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.610873] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.618894] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.626876] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.634864] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.642877] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.649866] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.656878] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.668814] inv_dev 0-0069: nvi_pm 0=>6 ERR=-121
[ 6.673939] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.680977] inv_dev 0-0069: nvi_dev_init I2C ID READ ERR
[ 6.727850] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.735156] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.747428] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.754737] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.767010] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.774293] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.786571] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.793889] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.806178] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.813478] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.825773] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.833073] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.845364] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.852650] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.864951] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.872240] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.884528] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.891824] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.899098] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.906412] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.918614] inv_dev 0-0069: nvi_pm 0=>6 ERR=-121
[ 6.924047] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.936423] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.943704] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.955933] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.963065] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.975210] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.982341] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 6.994487] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.001633] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.013772] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.020925] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.033063] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.040210] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.052348] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.059485] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.071625] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.078765] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.085915] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.093070] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x69
[ 7.100131] inv_dev 0-0069: nvi_pm 0=>3 ERR=-121
[ 7.105450] i2c i2c-0: nvi_probe failed -121
[ 7.110357] inv_dev: probe of 0-0069 failed with error -5
[ 7.118939] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 7.126456] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 7.135111] i2c /dev entries driver
[ 7.140294] virtual_init
[ 7.145342] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 7.152688] tegra_dtv_probe: probing dtv.
[ 7.157664] setup_stream: bufsize = 4096, bufnum = 4
[ 7.162831] ar0832_init: ++
[ 7.167920] i2c-core: driver [max77387] using legacy suspend method
[ 7.175261] i2c-core: driver [max77387] using legacy resume method
[ 7.182608] i2c-core: driver [as364x] using legacy suspend method
[ 7.189834] i2c-core: driver [as364x] using legacy resume method
[ 7.197112] [IMX135] sensor driver loading
[ 7.202476] [IMX179] sensor driver loading
[ 7.207802] [IMX185] sensor driver loading
[ 7.213131] [imx132] sensor driver loading
[ 7.218479] [AR0330] sensor driver loading
[ 7.223853] [ar0261] sensor driver loading
[ 7.229209] [AR1335] sensor driver loading
[ 7.234579] [ov4689] sensor driver loading
[ 7.240706] usbcore: registered new interface driver uvcvideo
[ 7.247810] USB Video Class driver (1.1.1)
[ 7.254042] zram: Created 1 device(s) ...
[ 7.260327] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[ 7.268351] tegra_wdt_probe done
[ 7.273163] sdhci: Secure Digital Host Controller Interface driver
[ 7.280678] sdhci: Copyright(c) Pierre Ossman
[ 7.286350] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.293734] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 7.307412] sdhci-tegra sdhci-tegra.3: Speedo value 2143
[ 7.314179] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 7.326513] mmc0: no vqmmc regulator found
[ 7.332082] mmc0: no vmmc regulator found
[ 7.337558] mmc0: Invalid maximum block size, assuming 512 bytes
[ 7.345085] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 7.356317] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 7.365547] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 7.373113] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 7.380686] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 7.388309] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 7.395924] sdhci: Power: 0x00000000 | Blk gap: 0x00000000
[ 7.403562] sdhci: Wake-up: 0x00000000 | Clock: 0x00000000
[ 7.411181] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 7.418757] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 7.426306] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 7.433839] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f77
[ 7.441342] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 7.448800] sdhci: Host ctl2: 0x00003000
[ 7.454342] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 7.461784] sdhci: ===========================================
[ 7.492781] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 7.492809] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 7.512320] sdhci-tegra sdhci-tegra.2: Speedo value 2143
[ 7.519310] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 7.532133] mmc1: no vqmmc regulator found
[ 7.537983] mmc1: no vmmc regulator found
[ 7.543660] mmc1: Invalid maximum block size, assuming 512 bytes
[ 7.551390] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[ 7.551391] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 7.551399] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 7.551406] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 7.551410] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 7.551415] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 7.551419] sdhci: Power: 0x00000000 | Blk gap: 0x00000000
[ 7.551423] sdhci: Wake-up: 0x00000000 | Clock: 0x00000000
[ 7.551426] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 7.551431] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 7.551435] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 7.551440] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f73
[ 7.551444] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 7.551448] sdhci: Host ctl2: 0x00003000
[ 7.551452] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 7.551455] sdhci: ===========================================
[ 7.575788] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 7.684404] gpio wake56 for gpio=170
[ 7.689997] sdhci-tegra sdhci-tegra.0: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 7.704045] sdhci-tegra sdhci-tegra.0: Speedo value 2143
[ 7.710964] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 7.723677] mmc2: no vqmmc regulator found
[ 7.729468] mmc2: no vmmc regulator found
[ 7.729476] mmc2: Invalid maximum block size, assuming 512 bytes
[ 7.729504] sysedp_create_consumer: unable to create sdhci-tegra.0, no consumer_data for sdhci-tegra.0 found
[ 7.729504] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 7.729511] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 7.729516] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 7.729520] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 7.729525] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 7.729530] sdhci: Power: 0x00000000 | Blk gap: 0x00000000
[ 7.729534] sdhci: Wake-up: 0x00000000 | Clock: 0x00000000
[ 7.729539] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 7.729544] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 7.729548] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 7.729553] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f73
[ 7.729557] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 7.729560] sdhci: Host ctl2: 0x00003000
[ 7.729564] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 7.729567] sdhci: ===========================================
[ 7.760950] mmc2: Internal clock never stabilised.
[ 7.760953] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 7.760961] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 7.760969] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 7.760976] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 7.760983] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 7.760990] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 7.760997] sdhci: Wake-up: 0x00000000 | Clock: 0x00000401
[ 7.761004] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 7.761012] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 7.761019] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 7.761026] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f73
[ 7.761033] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 7.761038] sdhci: Host ctl2: 0x00003000
[ 7.761045] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 7.761047] sdhci: ===========================================
[ 7.772785] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 7.776250] tegra-se tegra12-se: tegra_se_probe: complete
[ 7.778962] usbcore: registered new interface driver usbhid
[ 7.778965] usbhid: USB HID core driver
[ 7.779464] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 7.858464] usbcore: registered new interface driver snd-usb-audio
[ 7.859231] MAX98090 driver built on Oct 17 2015 at 16:12:58
[ 7.863498] tegra_offload_platform probe successfull.
[ 7.863502] succefully registered offload ops
[ 7.863923] tegra30_avp_audio_platform_probe successful.
[ 7.863931] tegra-snd-rt5639 tegra-snd-rt5639.0: Fail gpio_request AUDIO_LDO1
[ 8.065394] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.073714] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.092862] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.100948] mmc0: BKOPS_EN bit is not set
[ 8.106758] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.115129] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.123390] rt5639 0-001c: read 0xfd=0xffffffff
[ 8.129792] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.138514] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.147174] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.155776] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.163941] mmc0: new high speed DDR MMC card at address 0001
[ 8.171537] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.171567] mmcblk mmc0:0001: Card claimed for testing.
[ 8.171809] mmcblk0: mmc0:0001 SEM16G 14.6 GiB
[ 8.171975] mmcblk0rpmb: mmc0:0001 SEM16G partition 3 4.00 MiB
[ 8.179868] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 8.181972] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 8.214672] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.222788] mmc1: mmc_rescan_try_freq: trying to init card at 300000 Hz
[ 8.222989] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.223165] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.223338] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.223510] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.223681] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.223880] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.224051] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.224222] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.224393] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.224563] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.224731] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.224915] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.225083] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.225249] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.225418] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.225586] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.225769] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.225937] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.226103] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.226269] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.226433] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.226598] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.226779] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.226948] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.227115] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.227280] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.227447] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.227614] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.227786] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.227954] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.228123] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.228288] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.228454] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.228620] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.228791] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.228960] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.229127] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.229294] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.229460] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.229546] rt5639 0-001c: Failed to set private addr: -121
[ 8.229638] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.229801] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.235133] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 8.235147] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 8.236199] gpio wake49 for gpio=143
[ 8.236364] rt5639 0-001c: rt5639_headset_detect jack_type = 1
[ 8.236770] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 8.237494] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-spdif mapping ok
[ 8.238326] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-i2s.3 mapping ok
[ 8.239173] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> dit-hifi mapping ok
[ 8.240071] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> dit-hifi mapping ok
[ 8.240827] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 8.240931] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 8.241033] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 8.241651] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mapping ok
[ 8.242348] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 8.242451] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 8.242552] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 8.243187] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 8.246696] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input0
[ 8.248542] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[ 8.248542] oprofile: using timer interrupt.
[ 8.738223] GACT probability NOT on
[ 8.744286] Mirror/redirect action on
[ 8.750397] u32 classifier
[ 8.755465] Actions configured
[ 8.761168] Netfilter messages via NETLINK v0.30.
[ 8.768467] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 8.777276] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 8.786522] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 8.794941] xt_time: kernel timezone is -0000
[ 8.795777] mmc1: mmc_rescan_try_freq: trying to init card at 200000 Hz
[ 8.810568] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.818198] arp_tables: (C) 2002 David S. Miller
[ 8.824993] TCP: cubic registered
[ 8.830566] NET: Registered protocol family 10
[ 8.837911] mip6: Mobile IPv6
[ 8.842868] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 8.850654] sit: IPv6 over IPv4 tunneling driver
[ 8.851777] mmc1: mmc_rescan_try_freq: trying to init card at 101661 Hz
[ 8.866669] NET: Registered protocol family 17
[ 8.873012] NET: Registered protocol family 15
[ 8.879331] NET: Registered protocol family 35
[ 8.885595] NET: Registered protocol family 37
[ 8.891629] NET: Registered protocol family 41
[ 8.898967] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 8.906790] mmc2: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 8.942426] Registering SWP/SWPB emulation handler
[ 8.948915] last reset is due to power on reset
[ 8.948915]
[ 8.958225] Disabling clocks left on by bootloader:
[ 8.964746] audio_2x
[ 8.968792] audio
[ 8.972502] audio4
[ 8.976240] audio3
[ 8.979904] audio2
[ 8.983492] audio1
[ 8.987028] audio0
[ 8.990598] hdmi_audio
[ 8.994418] entropy
[ 8.997942] dsi2-fixed
[ 9.001678] dsi1-fixed
[ 9.005373] nor
[ 9.008380] trace
[ 9.011497] sdmmc3_ddr
[ 9.015097] cclk_lp
[ 9.018410] pll_x_out0
[ 9.022001] pll_m_out1
[ 9.025703] tegra_dvfs: vdd_cpu connected to regulator
[ 9.031868] tegra_dvfs: vdd_core connected to regulator
[ 9.038077] tegra_dvfs: vdd_gpu connected to regulator
[ 9.044984] CPU rate: 696 MHz
[ 9.330112] tegra dvfs: tegra sysfs cap interface is initialized
[ 9.337128] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 9.345239] tegra_actmon.emc: Completed initialization (0)
[ 9.351900] tegra_actmon.avp: Completed initialization (0)
[ 9.358405] tegra_mon.cpu_emc: Completed initialization (0)
[ 9.368151] reg-aon-1v2: incomplete constraints, leaving on
[ 9.374690] reg-aon-1v8: incomplete constraints, leaving on
[ 9.381220] vdd-cdc-1v2-aud: incomplete constraints, leaving on
[ 9.388162] sdmmc-en-supply: incomplete constraints, leaving on
[ 9.395120] reg-dcdc-1v2: incomplete constraints, leaving on
[ 9.401878] reg-5v0-supply: incomplete constraints, leaving on
[ 9.408865] avdd-hdmi-pll: incomplete constraints, leaving on
[ 9.415816] usb0-vbus: incomplete constraints, leaving on
[ 9.422464] vpp-fuse: incomplete constraints, leaving on
[ 9.429078] vdd-2v7-cam: incomplete constraints, leaving on
[ 9.436002] avdd-spi: incomplete constraints, leaving on
[ 9.442718] vdd-1v1-cam: incomplete constraints, leaving on
[ 9.449751] vddio-sdmmc-2: incomplete constraints, leaving on
[ 9.457003] vdd-1v2-cam: incomplete constraints, leaving on
[ 9.464129] avdd-cam: incomplete constraints, leaving on
[ 9.471044] vdd-cam: incomplete constraints, leaving on
[ 9.477880] as3722-sd3: incomplete constraints, leaving on
[ 9.484999] reg-3v3-supply: incomplete constraints, leaving on
[ 9.492500] vdd-3v3-aon: incomplete constraints, leaving on
[ 9.499748] vdd-ac-bat: incomplete constraints, leaving on
[ 9.506889] regulator-dummy: incomplete constraints, leaving on
[ 9.515329] gpio wake51 for gpio=128
[ 9.520833] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input1
[ 9.530072] akm89xx 0-000c: akm_probe
[ 9.585767] akm89xx 0-000c: akm_remove
[ 9.591257] akm89xx: probe of 0-000c failed with error -11
[ 9.598635] bmpX80 0-0077: bmp_probe
[ 9.614173] bmpX80 0-0077: bmp_remove
[ 9.619599] bmpX80: probe of 0-0077 failed with error -11
[ 9.627180] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:00:19 UTC (946684819)
[ 9.640003] ALSA device list:
[ 9.644729] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 9.651933] #1: tegra-rt5639
[ 9.657876] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 9.670374] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 10.035069] EXT4-fs (mmcblk0p1): recovery complete
[ 10.042907] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.054795] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 10.066598] devtmpfs: mounted
[ 10.071872] Freeing unused kernel memory: 516K (c0af2000 - c0b73000)
[ 10.350597] init: plymouth-upstart-bridge main process (117) terminated with status 1
[ 10.362893] init: plymouth-upstart-bridge main process ended, respawning
[ 10.415583] init: plymouth-upstart-bridge main process (127) terminated with status 1
[ 10.427652] init: plymouth-upstart-bridge main process ended, respawning
[ 10.441346] init: ureadahead main process (120) terminated with status 5
[ 10.482551] init: plymouth-upstart-bridge main process (131) terminated with status 1
[ 10.494827] init: plymouth-upstart-bridge main process ended, respawning
[ 12.447275] systemd-udevd[354]: could not open moddep file '/lib/modules/3.10.40-dbg/modules.dep.bin'
serial.txt (65.2 KB)
