We have developed a new board based on the Jetson design. Our design is almost the same as the jetson board except for the memories which are a little bit different. The problem we are having is that when booting two errors specifically arise a i2c error and a fatal error at a mmc2 driver. THe mmc2 error says it is a timeout. Please if you have any clue how I can debug/fix this. The linux is the stock l4t 21.4. I have attached the log
[ 1.740347] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 1.746212] gpio wake4 for gpio=111
[ 2.745498] tegra-i2c tegra12-i2c.3: --- register dump for debugging ----
[ 2.745529] tegra-i2c tegra12-i2c.3: I2C_CNFG - 0x2c00
[ 2.745554] tegra-i2c tegra12-i2c.3: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 2.745580] tegra-i2c tegra12-i2c.3: I2C_FIFO_CONTROL - 0xe0
[ 2.745604] tegra-i2c tegra12-i2c.3: I2C_FIFO_STATUS - 0x800040
[ 2.745628] tegra-i2c tegra12-i2c.3: I2C_INT_MASK - 0xed
[ 2.745651] tegra-i2c tegra12-i2c.3: I2C_INT_STATUS - 0x0
[ 2.745673] tegra-i2c tegra12-i2c.3: msg->len - 1
[ 2.745695] tegra-i2c tegra12-i2c.3: is_msg_write - 1
[ 2.745717] tegra-i2c tegra12-i2c.3: next_msg->len - 128
[ 2.745739] tegra-i2c tegra12-i2c.3: is_next_msg_write - 0
[ 2.745762] tegra-i2c tegra12-i2c.3: buf_remaining - 128
[ 2.745789] tegra-i2c tegra12-i2c.3: i2c transfer timed out, addr 0x0050, data 0x00
[ 2.746844] tegradc tegradc.1: probed
[ 2.751264] Console: switching to colour frame buffer device 80x30
[ 2.755567] tegradc tegradc.1: fb registered
[ 2.756990] hdmi_state_machine_worker (tid edb0a580): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 10.232502] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.244107] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 10.254937] devtmpfs: mounted
[ 10.260048] Freeing unused kernel memory: 508K (c0b4c000 - c0bcb000)
[ 10.506819] init: plymouth-upstart-bridge main process (120) terminated with status 1
[ 10.518494] init: plymouth-upstart-bridge main process ended, respawning
[ 10.570178] init: plymouth-upstart-bridge main process (130) terminated with status 1
[ 10.581982] init: plymouth-upstart-bridge main process ended, respawning
[ 10.595290] init: ureadahead main process (123) terminated with status 5
[ 10.630341] init: plymouth-upstart-bridge main process (134) terminated with status 1
[ 10.642380] init: plymouth-upstart-bridge main process ended, respawning
* Starting Mount filesystems on boot[ OK ]
* Starting Signal sysvinit that the rootfs is mounted[ OK ]
* Starting Clean /tmp directory[ OK ]
* Starting Populate and link to /run filesystem[ OK ]
* Stopping Populate and link to /run filesystem[ OK ]
* Stopping Clean /tmp directory[ OK ]
* Stopping Track if upstart is running in a container[ OK ]
* Starting Initialize or finalize resolvconf[ OK ]
* Starting Signal sysvinit that virtual filesystems are mounted[ OK ]
* Starting Signal sysvinit that local filesystems are mounted[ OK ]
* Starting Bridge udev events into upstart[ OK ]
* Starting Signal sysvinit that remote filesystems are mounted[ OK ]
* Stopping Mount filesystems on boot[ OK ]
* Starting NFSv4 id <-> name mapper[ OK ]
* Starting flush early job output to logs[ OK ]
* Starting D-Bus system message bus[ OK ]
* Starting device node and kernel event manager[ OK ]
* Stopping flush early job output to logs[ OK ]
* Starting NVIDIA specific init script[ OK ]
* Starting load modules from /etc/modules[ OK ]
* Starting cold plug devices[ OK ]
* Starting log initial device creation[ OK ]
* Starting SystemD login management service[ OK ]
* Stopping NVIDIA specific init script[ OK ]
* Stopping load modules from /etc/modules[ OK ]
* Starting bluetooth daemon[ OK ]
* Stopping rpcsec_gss daemon[ OK ]
* Starting system logging daemon[ OK ]
* Stopping NVIDIA specific first-boot script[ OK ]
* Starting configure network device security[ OK ]
* Starting userspace bootsplash[ OK ]
* Starting configure network device[ OK ]
* Starting mDNS/DNS-SD daemon[ OK ]
* Stopping userspace bootsplash[ OK ]
* Starting Send an event to indicate plymouth is up[ OK ]
* Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated[ OK ]
* Stopping Send an event to indicate plymouth is up[ OK ]
* Stopping Reload cups, upon starting avahi-daemon to make sure remote queues are populated[ OK ]
* Starting CUPS printing spooler/server[ OK ]
* Stopping cold plug devices[ OK ]
* Stopping log initial device creation[ OK ]
* Starting enable remaining boot-time encrypted block devices[ OK ]
* Starting Mount network filesystems[ OK ]
* Starting Upstart job to start rpcbind on boot only[ OK ]
* Starting Failsafe Boot Delay[ OK ]
* Stopping Upstart job to start rpcbind on boot only[ OK ]
* Starting cups-browsed - Bonjour remote printer browsing daemon[ OK ]
* Stopping Mount network filesystems[ OK ]
* Starting configure virtual network devices[ OK ]
* Starting RPC portmapper replacement[ OK ]
* Starting NSM status monitor[ OK ]
* Starting Bridge file events into upstart[ OK ]
* Starting Bridge socket events into upstart[ OK ]
[ 18.617853] mmc2: Timeout waiting for hardware interrupt.
[ 18.641102] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 18.664557] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 18.687475] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 18.710040] sdhci: Argument: 0x00000c00 | Trn mode: 0x00000000
[ 18.733047] sdhci: Present: 0x01fb00f1 | Host ctl: 0x00000001
[ 18.756583] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 18.780661] sdhci: Wake-up: 0x00000000 | Clock: 0x00000405
[ 18.805185] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 18.829612] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 18.854132] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 18.879152] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f73
[ 18.904814] sdhci: Cmd: 0x0000341a | Max curr: 0x00000000
[ 18.931072] sdhci: Host ctl2: 0x00003000
[ 18.955392] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 18.982265] sdhci: ===========================================
