dmesg (part 1 of 2):
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-922) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jul 16 17:09:53 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@9607b000
[ 0.000000] Found lut_mem2: 00002008@96078000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2053117
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 521725 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f676a000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2020917
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607b000 lut_mem2=0x2008@0x96078000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29512(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7960920K/8212468K available (15230K kernel code, 2914K rwdata, 6628K rodata, 8576K init, 609K bss, 186012K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a118808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a118808 - 0xffffff800a1b0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001614] Console: colour dummy device 80x25
[ 0.001619] console [tty0] enabled
[ 0.001622] bootconsole [uart8250] disabled
[ 0.001629] kmemleak: Kernel memory leak detector disabled
[ 0.001638] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001646] pid_max: default: 32768 minimum: 301
[ 0.001954] Security Framework initialized
[ 0.002107] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002112] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002699] ftrace: allocating 46935 entries in 184 pages
[ 0.125770] sched-energy: Sched-energy-costs installed from DT
[ 0.125781] ASID allocator initialised with 65536 entries
[ 0.163908] tegra-id: chipid=21817.
[ 0.163914] tegra-id: opt_subrevision=1.
[ 0.163931] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.163939] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.163945] DTB Build time: Jul 16 2019 17:14:35
[ 0.209662] CPU1: Booted secondary processor [4e0f0030]
[ 0.241295] CPU2: Booted secondary processor [4e0f0030]
[ 0.273087] CPU3: Booted secondary processor [411fd073]
[ 0.305073] CPU4: Booted secondary processor [411fd073]
[ 0.337068] CPU5: Booted secondary processor [411fd073]
[ 0.337121] Brought up 6 CPUs
[ 0.337125] SMP: Total of 6 processors activated.
[ 0.337129] CPU features: detected feature: 32-bit EL0 Support
[ 0.337878] CPU: All CPU(s) started at EL2
[ 0.337926] alternatives: patching kernel code
[ 0.347294] devtmpfs: initialized
[ 0.384634] Initilizing CustomIPI irq domain
[ 0.384873] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.384883] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.385674] pinctrl core: initialized pinctrl subsystem
[ 0.385870] OS set in device tree is not L4T.
[ 0.386021] regulator-dummy: no parameters
[ 0.386165] Initializing plugin-manager
[ 0.386223] Plugin module not found
[ 0.386259] Plugin-manager status disabled
[ 0.388020] NET: Registered protocol family 16
[ 0.388736] pstore: using zlib compression
[ 0.388749] console [pstore-1] enabled
[ 0.388751] pstore: Registered ramoops as persistent store backend
[ 0.388755] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.404685] cpuidle: using governor menu
[ 0.406150] bpmp: waiting for handshake
[ 0.406153] bpmp: handshake completed
[ 0.406167] bpmp: synchronizing channels
[ 0.406184] bpmp: channels synchronized
[ 0.406187] bpmp: mail init ok
[ 0.408222] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.408227] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.408231] arm-smmu 12000000.iommu: stage 1 translation
[ 0.408234] arm-smmu 12000000.iommu: stage 2 translation
[ 0.408237] arm-smmu 12000000.iommu: nested translation
[ 0.408243] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.408248] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.408252] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.408257] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.408260] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.410361] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.410373] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.412851] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.414724] Registering BPMP clocks...
[ 0.414814] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.417003] tegra_powergate_init: DONE
[ 0.417012] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.417017] DTB Build time: Jul 16 2019 17:14:35
[ 0.419071] Tegra reboot handler registered.
[ 0.420565] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.420631] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.420644] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.420647] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.420650] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.420811] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.420822] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.421168] iommu: Adding device 3460000.sdhci to group 0
[ 0.421847] iommu: Adding device 3400000.sdhci to group 1
[ 0.422906] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.422918] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.423356] iommu: Adding device 3160000.i2c to group 3
[ 0.423781] iommu: Adding device c240000.i2c to group 4
[ 0.424122] iommu: Adding device 3180000.i2c to group 5
[ 0.424462] iommu: Adding device 3190000.i2c to group 6
[ 0.424884] iommu: Adding device 31b0000.i2c to group 7
[ 0.425235] iommu: Adding device 31c0000.i2c to group 8
[ 0.425571] iommu: Adding device c250000.i2c to group 9
[ 0.425903] iommu: Adding device 31e0000.i2c to group 10
[ 0.427393] iommu: Adding device 3210000.spi to group 11
[ 0.427727] iommu: Adding device c260000.spi to group 12
[ 0.428055] iommu: Adding device 3240000.spi to group 13
[ 0.428743] iommu: Adding device 3100000.serial to group 14
[ 0.429095] iommu: Adding device 3110000.serial to group 15
[ 0.429428] iommu: Adding device c280000.serial to group 16
[ 0.429758] iommu: Adding device 3130000.serial to group 17
[ 0.431093] iommu: Adding device 2490000.ether_qos to group 18
[ 0.431113] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.431778] iommu: Adding device b000000.rtcpu to group 19
[ 0.433980] iommu: Adding device 13e10000.host1x to group 20
[ 0.434287] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.434584] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.434893] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.435191] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.435485] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.435787] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.436098] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.436396] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.436858] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.437524] iommu: Adding device 15700000.vi to group 30
[ 0.437874] iommu: Adding device 15600000.isp to group 31
[ 0.438330] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.438436] platform 15210000.nvdisplay: OF IOVA linear map 0x9607b000 size (0x800000)
[ 0.438478] platform 15210000.nvdisplay: OF IOVA linear map 0x96078000 size (0x2008)
[ 0.438977] iommu: Adding device 15340000.vic to group 33
[ 0.439194] iommu: Adding device 154c0000.nvenc to group 34
[ 0.439407] iommu: Adding device 15480000.nvdec to group 35
[ 0.439745] iommu: Adding device 15380000.nvjpg to group 36
[ 0.439968] iommu: Adding device 15500000.tsec to group 37
[ 0.440175] iommu: Adding device 15100000.tsecb to group 38
[ 0.440840] iommu: Adding device 15810000.se to group 39
[ 0.441056] iommu: Adding device 15820000.se to group 40
[ 0.441290] iommu: Adding device 15830000.se to group 41
[ 0.441498] iommu: Adding device 15840000.se to group 42
[ 0.442371] iommu: Adding device smmu_test to group 43
[ 0.442968] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c10000
[ 0.442979] mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2c20000
[ 0.442990] mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2c30000
[ 0.443000] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.443013] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.443019] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.443030] mc-err: mcerr ops are set to t18x
[ 0.443169] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.444245] iommu: Adding device 3530000.xhci to group 44
[ 0.444258] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.444702] iommu: Adding device 3550000.xudc to group 45
[ 0.444713] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.445432] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.445437] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.445998] iommu: Adding device 17000000.gp10b to group 46
[ 0.447040] tegra-reset 5000000.clock: registered 193 resets.
[ 0.449225] iommu: Adding device d000000.bpmp to group 47
[ 0.449426] bpmp: ping status is 0
[ 0.449525] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.451862] bpmp d000000.bpmp: probe ok
[ 0.454977] iommu: Adding device 2600000.dma to group 48
[ 0.456243] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.456266] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.456288] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.456309] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.456333] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.456354] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.456376] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.456566] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.460298] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.460460] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.462062] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.462076] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.462394] iommu: Adding device sound to group 50
[ 0.462746] iommu: Adding device 3510000.hda to group 51
[ 0.470183] iommu: Adding device c1a0000.aon to group 52
[ 0.470622] vdd-ac-bat: 5000 mV
[ 0.472316] vdd-1v8-ap: 1800 mV
[ 0.497325] random: fast init done
[ 0.514342] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.520451] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.520950] SCSI subsystem initialized
[ 0.521266] libata version 3.00 loaded.
[ 0.521508] usbcore: registered new interface driver usbfs
[ 0.521560] usbcore: registered new interface driver hub
[ 0.521698] usbcore: registered new device driver usb
[ 0.525748] GPIO line 241 (touch-rails) hogged as output/high
[ 0.526028] GPIO line 242 (touch-rails) hogged as output/high
[ 0.526433] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.527593] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.527952] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.540648] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.545870] vddio-ddr: at 1125 mV
[ 0.549690] avdd_dsi_csi: 1200 mV
[ 0.553699] vdd-1v8: 1800 mV
[ 0.557701] vdd-3v3-sys: 3300 mV
[ 0.559145] spmic-ldo0: at 1800 mV
[ 0.560128] spmic-ldo1: at 800 mV
[ 0.565709] vddio-3v3: 3300 mV
[ 0.566496] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.569693] vdd-rtc: at 800 mV
[ 0.570652] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.573707] spmic-ldo6: at 1500 mV
[ 0.577705] vdd-pex-1v00: 1000 mV
[ 0.578618] dvdd-pex: 1000 mV
[ 0.579226] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.579417] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.579710] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.582260] max77620 4-003c: max77620 probe successful
[ 0.582895] media: Linux media interface: v0.10
[ 0.582990] Linux video capture interface: v2.00
[ 0.586286] pps_core: LinuxPPS API ver. 1 registered
[ 0.586294] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.586312] PTP clock support registered
[ 0.586883] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.586931] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.590917] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.598778] trusty trusty: trusty version: Built: 16:57:40 Jul 16 2019
[ 0.598819] trusty trusty: selected api version: 3 (requested 3)
[ 0.600060] Advanced Linux Sound Architecture Driver Initialized.
[ 0.600822] Bluetooth: Core ver 2.22
[ 0.600925] NET: Registered protocol family 31
[ 0.600931] Bluetooth: HCI device and connection manager initialized
[ 0.600942] Bluetooth: HCI socket layer initialized
[ 0.600951] Bluetooth: L2CAP socket layer initialized
[ 0.600976] Bluetooth: SCO socket layer initialized
[ 0.602107] en-vdd-sd: 3300 mV
[ 0.602742] en-vdd-cam: 1800 mV
[ 0.605708] vdd-hdmi: 5000 mV
[ 0.606180] vdd-usb0-5v: 5000 mV
[ 0.606591] vdd-usb1-5v: 5000 mV
[ 0.609704] en-vdd-ts-1v8: 1800 mV
[ 0.613695] en-vdd-ts-hv-3v3: 3300 mV
[ 0.614381] en-vdd-disp-3v3: 3300 mV
[ 0.614950] en-mdm-pwr-3v7: 3700 mV
[ 0.615513] en-vdd-disp-1v8: 1800 mV
[ 0.616074] en-vdd-cam-hv-2v8: 2800 mV
[ 0.616695] en-vdd-cam-1v2: 1200 mV
[ 0.617258] vdd-fan: 5000 mV
[ 0.617546] vdd-3v3: 3300 mV
[ 0.618278] dis-vdd-1v2: 1200 mV
[ 0.618624] en-vdd-vcm-2v8: 2800 mV
[ 0.619243] vdd-usb2-5v: 5000 mV
[ 0.619573] vdd-sys-bl: 3300 mV
[ 0.620225] en-vdd-sys: 1200 mV
[ 0.623777] camchar: rtcpu character device driver loaded
[ 0.624603] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.626683] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.628207] clocksource: Switched to clocksource arch_sys_counter
[ 0.669402] VFS: Disk quotas dquot_6.6.0
[ 0.669640] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.670252] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.671243] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.671253] nvmap_page_pool_init: Total RAM pages: 2006614
[ 0.671259] nvmap_page_pool_init: nvmap page pool size: 250826 pages (979 MB)
[ 0.671474] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.675087] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.686689] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.686879] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.687327] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.687424] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.687566] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.687696] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.687904] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.688176] la/ptsa driver initialized.
[ 0.688190] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.688235] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.689383] NET: Registered protocol family 2
[ 0.691354] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.692165] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.693032] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.693086] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.693211] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.694118] NET: Registered protocol family 1
[ 0.695231] RPC: Registered named UNIX socket transport module.
[ 0.695237] RPC: Registered udp transport module.
[ 0.695242] RPC: Registered tcp transport module.
[ 0.695247] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.695257] PCI: CLS 0 bytes, default 64
[ 0.695493] Trying to unpack rootfs image as initramfs...
[ 0.880586] Freeing initrd memory: 5432K
[ 0.903072] host1x 13e10000.host1x: initialized
[ 0.905062] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.909908] audit: initializing netlink subsys (disabled)
[ 0.909952] audit: type=2000 audit(0.800:1): initialized
[ 0.910744] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.927205] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.933874] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.935468] 9p: Installing v9fs 9p2000 file system support
[ 0.940070] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.940191] io scheduler noop registered
[ 0.940842] io scheduler cfq registered (default)
[ 0.945986] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.952340] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 0.956672] iommu: Adding device 2993000.adsp to group 54
[ 0.957845] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.961347] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.965699] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.967296] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.968631] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.969895] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.972677] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.973803] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.974223] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.974388] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.974572] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.974604] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.977704] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.979320] tsec 15500000.tsec: initialized
[ 0.980825] tsec 15100000.tsecb: initialized
[ 0.985060] nvdec 15480000.nvdec: initialized
[ 0.993060] falcon 15340000.vic: initialized
[ 0.994773] falcon 154c0000.nvenc: initialized
[ 0.996352] falcon 15380000.nvjpg: initialized
[ 0.999880] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.001612] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.003310] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.004978] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.006640] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.008326] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.009963] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.011498] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.015449] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.015464] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.015503] tegradccommon 15200000.dc_common: dma mapping done
[ 1.018216] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.018263] generic_infoframe_type: 0x87
[ 1.018349] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.018377] tegradc 15210000.nvdisplay: Display dc.ffffff800b690000 registered with id=0
[ 1.027833] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.029608] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.029615] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.029621] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.029676] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.029920] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.029931] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.030184] kfuse 3830000.kfuse: initialized
[ 1.031710] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.033256] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.036849] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.036895] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.038627] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.041940] tegradc 15210000.nvdisplay: probed
[ 1.046634] console [ttyS0] disabled
[ 1.046695] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.046756] console [ttyS0] enabled
[ 1.048743] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.049939] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.050199] serial-tegra 3130000.serial: RX in PIO mode
[ 1.051176] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.052426] Console: switching to colour frame buffer device 240x67
[ 1.052456] [drm] Initialized
[ 1.052639] tegradc 15210000.nvdisplay: fb registered
[ 1.052825] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.053486] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.053576] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.053649] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.061062] Parent Clock set for DC plld2
[ 1.104025] brd: module loaded
[ 1.121729] loop: module loaded
[ 1.121850] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.121989] tegra_profiler: auth: init
[ 1.122673] THERMAL EST: found 3 subdevs
[ 1.122680] THERMAL EST num_resources: 0
[ 1.122686] [THERMAL EST subdev 0]
[ 1.122694] [THERMAL EST subdev 1]
[ 1.122700] [THERMAL EST subdev 2]
[ 1.122999] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.123003] THERMAL EST: thz register success.
[ 1.123315] nct1008_nct72 7-004c: starting parse dt
[ 1.123398] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.123403] nct1008_nct72 7-004c: success parsing dt
[ 1.123498] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.126927] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.127314] THERMAL EST: end of probe, return err: 0
[ 1.127416] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.127426] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.128446] hisi_sas: driver version v1.6
[ 1.132749] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.132763] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.133676] scsi host0: tegra_ahci
[ 1.134710] scsi host1: tegra_ahci
[ 1.134880] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.134886] ata2: DUMMY
[ 1.141105] libphy: Fixed MDIO Bus: probed
[ 1.141554] tun: Universal TUN/TAP device driver, 1.6
[ 1.141559] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.142804] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.142808] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.142844] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.142846] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.142889] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.142891] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.142922] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.142924] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.144264] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.147317] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c5 48 41
[ 1.147424] libphy: dwc_phy: probed
[ 1.147753] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.150104] PPP generic driver version 2.4.2
[ 1.150369] PPP BSD Compression module registered
[ 1.150375] PPP Deflate Compression module registered
[ 1.150395] PPP MPPE Compression module registered
[ 1.150401] NET: Registered protocol family 24
[ 1.150458] usbcore: registered new interface driver r8152
[ 1.150492] usbcore: registered new interface driver asix
[ 1.150519] usbcore: registered new interface driver ax88179_178a
[ 1.150542] usbcore: registered new interface driver cdc_ether
[ 1.150583] usbcore: registered new interface driver net1080
[ 1.150606] usbcore: registered new interface driver cdc_subset
[ 1.150630] usbcore: registered new interface driver zaurus
[ 1.150668] usbcore: registered new interface driver cdc_ncm
[ 1.150807] VFIO - User Level meta-driver version: 0.3
[ 1.153275] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.153280] Extcon AUX1(HDMI) enable
[ 1.155845] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.156428] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.156742] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.156763] ehci-pci: EHCI PCI platform driver
[ 1.156801] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.156815] ohci-pci: OHCI PCI platform driver
[ 1.156852] ohci-platform: OHCI generic platform driver
[ 1.162726] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.164561] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eadad800 id
[ 1.165319] usbcore: registered new interface driver uas
[ 1.165366] usbcore: registered new interface driver usb-storage
[ 1.165452] usbcore: registered new interface driver usbserial
[ 1.167015] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 1.170337] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.171553] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.171625] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.174117] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.174469] mousedev: PS/2 mouse device common for all mice
[ 1.174540] usbcore: registered new interface driver xpad
[ 1.188416] nct1008_nct72 7-004c: initial LOC temp: 23000
[ 1.188728] nct1008_nct72 7-004c: initial EXT temp: 35750
[ 1.189337] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.189733] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.189917] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.192433] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.192467] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.193325] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.193367] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.193640] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.193648] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.193655] usb usb1: Product: xHCI Host Controller
[ 1.193660] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.193666] usb usb1: SerialNumber: 3530000.xhci
[ 1.194139] hub 1-0:1.0: USB hub found
[ 1.194258] hub 1-0:1.0: 4 ports detected
[ 1.194707] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.194720] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.194931] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.194938] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.194943] usb usb2: Product: xHCI Host Controller
[ 1.194949] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.194954] usb usb2: SerialNumber: 3530000.xhci
[ 1.195361] hub 2-0:1.0: USB hub found
[ 1.195456] hub 2-0:1.0: 3 ports detected
[ 1.287943] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.298675] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.300182] Wake73 for irq=42
[ 1.301440] rtc rtc1: alarm rtc device
[ 1.301487] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.301513] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.301689] i2c /dev entries driver
[ 1.303576] ov5693 2-0036: probing v4l2 sensor.
[ 1.304663] ov5693 2-0036: tegracam sensor driver:ov5693_v2.0.6
[ 1.327239] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.327241] Extcon AUX1(HDMI) disable
[ 1.354238] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.354743] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.359579] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.396620] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.451481] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.528404] usb 1-2: new full-speed USB device number 2 using tegra-xusb
[ 1.553470] usb 1-2: New USB device found, idVendor=04b3, idProduct=301a
[ 1.553488] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.553508] usb 1-2: Product: USB 1.1 2port downstream low power hub
[ 1.553518] usb 1-2: Manufacturer: Lite-On Technology
[ 1.560061] hub 1-2:1.0: USB hub found
[ 1.560604] hub 1-2:1.0: 3 ports detected
[ 1.802370] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.860388] usb 1-2.1: new full-speed USB device number 3 using tegra-xusb
[ 1.889482] usb 1-2.1: New USB device found, idVendor=04b3, idProduct=301b
[ 1.889503] usb 1-2.1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 1.889521] usb 1-2.1: Product: USB Productivity Option Keyboard( has the hub in # 1 )
[ 1.889529] usb 1-2.1: Manufacturer: Lite-On Technology
[ 2.118471] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.153327] parse_throttle_dt_data: Num cap clks = 4
[ 2.153361] parse_throttle_dt_data: clk=mcpu type=1
[ 2.153376] parse_throttle_dt_data: clk=bcpu type=2
[ 2.153490] parse_throttle_dt_data: clk=gpu type=4
[ 2.153502] parse_throttle_dt_data: clk=emc type=3
[ 2.159888] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.166829] FAN dev name: pwm-fan
[ 2.167181] FAN:gpio request success.
[ 2.167241] FAN: can't find tach_gpio
[ 2.167506] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.169258] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 2.169283] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.171526] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.171533] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.171540] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.171543] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.171546] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.171550] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.171554] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.171560] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.171567] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.171570] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.176888] device-mapper: uevent: version 1.0.3
[ 2.178728] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.202979] cpufreq: platform driver Initialization: pass
[ 2.203552] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 2.203664] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 2.204415] sdhci: Secure Digital Host Controller Interface driver
[ 2.204417] sdhci: Copyright(c) Pierre Ossman
[ 2.204419] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.205815] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.206243] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.207671] CMDQ: cmdq_platfm_init successful
[ 2.208226] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.208789] CQE: CMD_TIMING bit set for R1B DCMD
[ 2.210555] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.214331] tegradc 15210000.nvdisplay: unblank
[ 2.214563] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.214610] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.215634] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 2.215779] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 2.216179] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.216182] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 2.217876] Parent Clock set for DC plld2
[ 2.219571] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 2.221115] tegradc 15210000.nvdisplay: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 2.222338] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 2.222343] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 2.224702] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.225642] tegra-se-nvhost 15810000.se: initialized
[ 2.226663] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.227455] tegra-se-nvhost 15820000.se: initialized
[ 2.228508] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.229329] tegra-se-nvhost 15830000.se: initialized
[ 2.229861] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.230714] tegra-se-nvhost 15840000.se: initialized
[ 2.231583] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.231842] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.233949] input: Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 ) as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:04B3:301B.0001/input/input0
[ 2.252283] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.256522] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.257659] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 2.257661] Extcon AUX1(HDMI) enable
[ 2.268357] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 2.268410] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.292854] hid-generic 0003:04B3:301B.0001: input,hidraw0: USB HID v1.10 Keyboard [Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 )] on usb-3530000.xhci-2.1/input0
[ 2.293791] input: Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 ) as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:04B3:301B.0002/input/input1
[ 2.317799] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 2.335461] mmc0: periodic cache flush enabled
[ 2.335472] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.335910] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.336155] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.336364] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.336562] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.339138] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 2.352487] hid-generic 0003:04B3:301B.0002: input,hidraw1: USB HID v1.10 Device [Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 )] on usb-3530000.xhci-2.1/input1
[ 2.352538] usbcore: registered new interface driver usbhid
[ 2.352541] usbhid: USB HID core driver
[ 2.359087] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.361864] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 2.362302] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.362513] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 2.362982] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 2.364175] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 2.364269] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 2.364322] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 2.364368] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 2.364471] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 2.364820] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 2.364822] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.365833] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 2.367452] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.367952] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.368150] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.368269] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.368631] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.368634] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 2.368637] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.368693] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.368696] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 2.368698] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.368755] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.368758] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 2.368760] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.368813] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.368816] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 2.368818] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.368872] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.368874] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 2.368877] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.368937] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.368942] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 2.368944] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.368999] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369005] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 2.369007] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.369063] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369069] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 2.369071] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.369127] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369132] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 2.369135] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.369188] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369191] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 2.369194] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.369251] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369257] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 2.369260] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.369326] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369332] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 2.369334] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.369392] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369398] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 2.369400] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.369475] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369481] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 2.369484] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.369540] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.369545] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 2.369548] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.369623] tegra18_a57_serr_init: on CPU 2 a Denver Core
[ 2.369707] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 2.370356] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.370817] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.370921] denver_knobs_init:MTS_VERSION:43068234
[ 2.373000] nvpmodel: initialized successfully
[ 2.375686] trusty-virtio trusty:virtio: initializing
[ 2.375950] trusty_ipc virtio0: vring0: va(pa) ffffffc1e5024000(0) qsz 32 notifyid 1
[ 2.375960] trusty_ipc virtio0: vring1: va(pa) ffffffc1e5026000(0) qsz 32 notifyid 2
[ 2.376091] trusty-virtio trusty:virtio: initializing done
[ 2.376191] trusty_ipc virtio0: is online
[ 2.378052] usbcore: registered new interface driver snd-usb-audio
[ 2.399609] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input2
[ 2.399807] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input3
[ 2.478659] OPE platform probe
[ 2.478728] OPE platform probe successful
[ 2.481504] tegra-asoc: sound: This is a dummy codec
[ 2.543222] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.543304] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.543382] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.543457] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.543560] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.543639] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.543713] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.543791] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.543877] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.543981] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.544061] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.544139] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.544277] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.544369] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.544452] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.544546] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.544626] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.544702] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.544780] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.544858] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.570760] u32 classifier
[ 2.570763] Actions configured
[ 2.570848] Initializing XFRM netlink socket
[ 2.572578] NET: Registered protocol family 10
[ 2.573891] NET: Registered protocol family 17
[ 2.573903] NET: Registered protocol family 15
[ 2.574118] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.574195] Bluetooth: RFCOMM socket layer initialized
[ 2.574206] Bluetooth: RFCOMM ver 1.11
[ 2.574211] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.574218] Bluetooth: HIDP socket layer initialized
[ 2.574257] 9pnet: Installing 9P2000 support
[ 2.574307] Key type dns_resolver registered
[ 2.574552] Registered cp15_barrier emulation handler
[ 2.574578] Registered setend emulation handler
[ 2.576077] registered taskstats version 1
[ 2.580786] isp 15600000.isp: initialized
[ 2.586149] nvcsi 150c0000.nvcsi: initialized
[ 2.591819] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 2.591909] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 2.591975] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 2.592129] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.594091] tegra-vi4 15700000.vi: initialized
[ 2.595181] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 2.595194] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 2.612241] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.624954] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:18 UTC (946688418)
[ 2.626613] mmcblk mmc0:0001: Card claimed for testing.
[ 2.662202] bpmp: mounted debugfs mirror
[ 2.664251] bwmgr: missing cdev-type property
[ 2.670011] spmic-ldo0: disabling
[ 2.670205] spmic-ldo1: disabling
[ 2.670385] en-vdd-sd: disabling
[ 2.670388] en-vdd-cam: disabling
[ 2.670391] vdd-usb0-5v: disabling
[ 2.670393] vdd-usb1-5v: disabling
[ 2.670396] en-vdd-disp-3v3: disabling
[ 2.670398] en-mdm-pwr-3v7: disabling
[ 2.670401] en-vdd-disp-1v8: disabling
[ 2.670403] en-vdd-cam-hv-2v8: disabling
[ 2.670405] en-vdd-cam-1v2: disabling
[ 2.670407] vdd-fan: disabling
[ 2.670409] vdd-3v3: disabling
[ 2.670412] en-vdd-vcm-2v8: disabling
[ 2.670415] vdd-sys-bl: disabling
[ 2.670417] en-vdd-sys: disabling
[ 2.670420] ALSA device list:
[ 2.670423] #0: tegra-hda at 0x3518000 irq 383
[ 2.670425] #1: tegra-snd-t186ref-mobile-rt565x
[ 3.019661] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.426007] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.428042] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.634000] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.634342] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 4.267457] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 4.267460] Extcon HDMI: HPD enabled
[ 4.267471] tegradc 15210000.nvdisplay: hdmi: plugged
[ 4.269305] Freeing unused kernel memory: 8576K
[ 4.303853] L4T-INITRD Build DATE: Sat Jan 1 01:00:20 UTC 2000
[ 4.311841] Root device found: mmcblk0p1
[ 4.314229] Found dev node: /dev/mmcblk0p1
[ 4.320668] Wake76 for irq=199
[ 4.320674] Wake77 for irq=199
[ 4.320676] Wake78 for irq=199
[ 4.320678] Wake79 for irq=199
[ 4.320681] Wake80 for irq=199
[ 4.320683] Wake81 for irq=199
[ 4.320685] Wake82 for irq=199
[ 4.320717] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.320723] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.424458] usb usb2: usb_suspend_both: status 0
[ 4.520548] random: crng init done
[ 4.643630] EXT4-fs (mmcblk0p1): 17 orphan inodes deleted
[ 4.643633] EXT4-fs (mmcblk0p1): recovery complete
[ 4.648243] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 4.649421] Rootfs mounted over mmcblk0p1
[ 4.673789] Switching from initrd to actual rootfs
[ 4.793888] systemd[1]: System time before build time, advancing clock.
[ 4.821128] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.866235] cgroup: cgroup2: unknown option "nsdelegate"
[ 4.889992] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.893093] systemd[1]: Detected architecture arm64.
[ 4.984653] systemd[1]: Set hostname to <jetson>.
[ 5.066689] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.066715] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 5.248409] systemd[1]: Reached target User and Group Name Lookups.
[ 5.249057] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.252496] systemd[1]: Created slice User and Session Slice.
[ 5.260550] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.262229] systemd[1]: Created slice System Slice.
[ 5.291980] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 5.302579] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 5.679151] systemd-journald[2309]: Received request to flush runtime journal from PID 1
[ 6.359205] using random self ethernet address
[ 6.372339] using random host ethernet address
[ 6.426812] Mass Storage Function, version: 2009/09/11
[ 6.426818] LUN: removable file: (no medium)
[ 6.454772] using random self ethernet address
[ 6.460672] using random host ethernet address
[ 6.516666] rndis0: HOST MAC b6:d1:3b:ce:03:d4
[ 6.516737] rndis0: MAC b6:d1:3b:ce:03:d5
[ 6.521540] usb0: HOST MAC b6:d1:3b:ce:03:d6
[ 6.526270] usb0: MAC b6:d1:3b:ce:03:d7
[ 6.526299] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.533666] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.533688] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.533726] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.535296] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.535322] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.540702] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.540727] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.541739] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.546712] l4tbr0: port 1(rndis0) entered blocking state
[ 6.546719] l4tbr0: port 1(rndis0) entered disabled state
[ 6.546896] device rndis0 entered promiscuous mode
[ 6.580580] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.586397] l4tbr0: port 2(usb0) entered blocking state
[ 6.586402] l4tbr0: port 2(usb0) entered disabled state
[ 6.588245] device usb0 entered promiscuous mode
[ 6.593311] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.661621] nvgpu: 17000000.gp10b railgate_enable_store:283 [INFO] railgate is disabled.
[ 7.288963] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.369152] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 7.371388] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.443064] CPU1: shutdown
[ 7.445860] psci: CPU1 killed.
[ 7.472596] zram: Added device: zram0
[ 7.476562] zram: Added device: zram1
[ 7.479479] zram: Added device: zram2
[ 7.479833] zram: Added device: zram3
[ 7.484579] zram: Added device: zram4
[ 7.485914] zram: Added device: zram5
[ 7.514920] CPU2: shutdown
[ 7.517735] psci: CPU2 killed.
[ 7.523542] zram0: detected capacity change from 0 to 686120960
[ 7.553389] Adding 670036k swap on /dev/zram0. Priority:5 extents:1 across:670036k SS
[ 7.559629] zram1: detected capacity change from 0 to 686120960
[ 7.587225] Adding 670036k swap on /dev/zram1. Priority:5 extents:1 across:670036k SS
[ 7.591375] zram2: detected capacity change from 0 to 686120960
[ 7.604501] Adding 670036k swap on /dev/zram2. Priority:5 extents:1 across:670036k SS
[ 7.609658] zram3: detected capacity change from 0 to 686120960
[ 7.619334] Adding 670036k swap on /dev/zram3. Priority:5 extents:1 across:670036k SS
[ 7.622295] zram4: detected capacity change from 0 to 686120960
[ 7.633515] Adding 670036k swap on /dev/zram4. Priority:5 extents:1 across:670036k SS
[ 7.638517] zram5: detected capacity change from 0 to 686120960
[ 7.651830] Adding 670036k swap on /dev/zram5. Priority:5 extents:1 across:670036k SS
[ 10.014966] tegradc 15210000.nvdisplay: blank - powerdown
[ 10.079247] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 10.079255] Extcon AUX1(HDMI) disable
[ 10.105324] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 10.105477] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 10.106418] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 10.106807] tegradc 15210000.nvdisplay: unblank
[ 10.110312] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 10.110407] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 10.110485] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 10.111908] Parent Clock set for DC plld2
[ 10.115274] tegradc 15210000.nvdisplay: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 10.116569] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 10.116576] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 10.158590] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 10.158594] Extcon AUX1(HDMI) enable
[ 10.160665] tegradc 15210000.nvdisplay: unblank
[ 10.167744] tegra_nvdisp_program_final_bw_settings: LA/PTSA failed w/ bw=1060400 KB/s,freq=20400000 Hz
[ 10.655065] fuse init (API version 7.26)
[ 61.552844] tegradc 15210000.nvdisplay: blank - powerdown
[ 61.609271] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 61.609273] Extcon AUX1(HDMI) disable
[ 61.631173] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 61.631253] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 61.631709] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 61.754185] tegradc 15210000.nvdisplay: blank - powerdown
[ 61.754204] tegradc 15210000.nvdisplay: unblank
[ 61.754844] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 61.754940] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 61.755024] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 61.756506] Parent Clock set for DC plld2
[ 61.759735] tegradc 15210000.nvdisplay: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 61.760960] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 61.760966] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 61.799115] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 61.799117] Extcon AUX1(HDMI) enable
[ 61.799162] tegradc 15210000.nvdisplay: unblank
[ 61.812078] tegra_nvdisp_program_final_bw_settings: LA/PTSA failed w/ bw=1060400 KB/s,freq=20400000 Hz
[ 66.334554] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 66.334566] Bluetooth: BNEP socket layer initialized
[ 66.650600] tegradc 15210000.nvdisplay: unblank
[ 99.684281] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 99.709882] usb 1-2.3: unable to read config index 0 descriptor/all
[ 99.716390] usb 1-2.3: can't read configurations, error -71
[ 101.084277] usb 1-2.3: new low-speed USB device number 6 using tegra-xusb
[ 101.085880] usb 1-2.3: Device not responding to setup address.
[ 101.297921] usb 1-2.3: Device not responding to setup address.
[ 101.508423] usb 1-2.3: device not accepting address 6, error -71
[ 101.592324] usb 1-2.3: new low-speed USB device number 7 using tegra-xusb
[ 101.593869] usb 1-2.3: Device not responding to setup address.
[ 101.805889] usb 1-2.3: Device not responding to setup address.
[ 102.016418] usb 1-2.3: device not accepting address 7, error -71
[ 102.022798] usb 1-2-port3: attempt power cycle
[ 102.624424] usb 1-2.3: new low-speed USB device number 8 using tegra-xusb
[ 102.727774] usb 1-2.3: New USB device found, idVendor=04b3, idProduct=3108
[ 102.727798] usb 1-2.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 102.741264] input: HID 04b3:3108 as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:04B3:3108.0003/input/input5
[ 102.741519] hid-generic 0003:04B3:3108.0003: input,hidraw2: USB HID v1.00 Mouse [HID 04b3:3108] on usb-3530000.xhci-2.3/input0
[ 203.141172] tegradc 15210000.nvdisplay: blank - powerdown
[ 203.194733] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 203.194738] Extcon AUX1(HDMI) disable
[ 203.219363] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 203.219470] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 203.220091] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 203.235060] tegradc 15210000.nvdisplay: blank - powerdown
[ 203.235083] tegradc 15210000.nvdisplay: unblank
[ 203.235724] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 203.235820] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 203.235901] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 203.237312] Parent Clock set for DC plld2
[ 203.240589] tegradc 15210000.nvdisplay: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 203.241836] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 203.241844] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 203.278471] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 203.278474] Extcon AUX1(HDMI) enable
[ 206.429922] tegradc 15210000.nvdisplay: blank - powerdown
[ 206.495116] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 206.495121] Extcon AUX1(HDMI) disable
[ 206.527064] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 206.528902] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 206.531632] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 206.531875] tegradc 15210000.nvdisplay: unblank
[ 206.535331] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 206.535503] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 206.535632] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 206.544899] Parent Clock set for DC plld2
[ 206.550582] tegradc 15210000.nvdisplay: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 206.551882] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 206.551891] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 206.587904] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 206.587907] Extcon AUX1(HDMI) enable
[ 206.587980] tegradc 15210000.nvdisplay: unblank
[ 206.603089] tegra_nvdisp_program_final_bw_settings: LA/PTSA failed w/ bw=1060400 KB/s,freq=20400000 Hz
[ 219.043442] tegradc 15210000.nvdisplay: blank - powerdown
