[code][ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-553) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Jul 20 00:49:07 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fbc00000
[ 0.000000] On node 0 totalpages: 2051072
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519408 pages, LIFO batch:31
[ 0.000000] Normal zone: 23933 pages used for memmap
[ 0.000000] Normal zone: 1531664 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1edb9a000 s31232 r8192 d30208 u69632
[ 0.000000] pcpu-alloc: s31232 r8192 d30208 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2018947
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0320717048544 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7282872K/8204288K available (10976K kernel code, 1817K rwdata, 5712K rodata, 1164K init, 682K bss, 167752K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
.init : 0xffffffc0010cd000 - 0xffffffc0011f0000 ( 1164 KB)
.text : 0xffffffc000080000 - 0xffffffc0010cd000 ( 16692 KB)
.data : 0xffffffc001211000 - 0xffffffc0013d7430 ( 1818 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009858] Console: colour dummy device 80x25
[ 0.014515] console [tty0] enabled
[ 0.018070] bootconsole [uart0] disabled
[ 0.022173] kmemleak: Kernel memory leak detector disabled
[ 0.022183] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022195] pid_max: default: 32768 minimum: 301
[ 0.022234] Security Framework initialized
[ 0.022263] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022271] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022622] Initializing cgroup subsys freezer
[ 0.022633] Initializing cgroup subsys debug
[ 0.022769] CPU0 ipc=752
[ 0.022777] CPU1 ipc=1024
[ 0.022784] CPU2 ipc=1024
[ 0.022792] CPU3 ipc=752
[ 0.022800] CPU4 ipc=752
[ 0.022808] CPU5 ipc=752
[ 0.022838] ASID allocator initialised with 65536 entries
[ 0.046279] tegra-id: chipid=21817.
[ 0.046292] tegra-id: opt_subrevision=1.
[ 0.046300] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046940] DTS File Name: /home/jetpak3.1-kernel/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046960] DTB Build time: Nov 16 2017 13:45:10
[ 0.062595] CPU1: Booted secondary processor [4e0f0030]
[ 0.074089] CPU2: Booted secondary processor [4e0f0030]
[ 0.085795] CPU3: Booted secondary processor [411fd073]
[ 0.097804] CPU4: Booted secondary processor [411fd073]
[ 0.109809] CPU5: Booted secondary processor [411fd073]
[ 0.109871] Brought up 6 CPUs
[ 0.109921] SMP: Total of 6 processors activated.
[ 0.109932] CPU: All CPU(s) started at EL2
[ 0.110411] devtmpfs: initialized
[ 0.136755] Initilizing CustomIPI irq domain
[ 0.136945] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.144451] pinctrl core: initialized pinctrl subsystem
[ 0.144824] regulator-dummy: no parameters
[ 0.144929] Initializing plugin-manager
[ 0.144983] Plugin module not found
[ 0.145197] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.145208] Error in parsing node /plugin-manager/soc-prod-a01-fragment: -22
[ 0.145413] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.145423] Error in parsing node /plugin-manager/soc-prod-a02-fragment: -22
[ 0.145602] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.145611] Error in parsing node /plugin-manager/fragement@0: -22
[ 0.145789] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.145799] Error in parsing node /plugin-manager/fragement@1: -22
[ 0.145976] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.145985] Error in parsing node /plugin-manager/fragement@2: -22
[ 0.146165] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.146174] Error in parsing node /plugin-manager/fragement@4: -22
[ 0.146355] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.146364] Error in parsing node /plugin-manager/fragement@6: -22
[ 0.146542] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.146551] Error in parsing node /plugin-manager/fragement@7: -22
[ 0.146729] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.146739] Error in parsing node /plugin-manager/fragement@8: -22
[ 0.146918] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.146926] Error in parsing node /plugin-manager/fragement@9: -22
[ 0.147106] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.147115] Error in parsing node /plugin-manager/fragement@10: -22
[ 0.147295] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.147304] Error in parsing node /plugin-manager/fragment-sdwake-p3310-1000-300: -22
[ 0.147487] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.147496] Error in parsing node /plugin-manager/fragement-pmon-p3310-1000-300: -22
[ 0.147678] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.147687] Error in parsing node /plugin-manager/fragement-pmon-p3310-1000-800: -22
[ 0.147870] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.147879] Error in parsing node /plugin-manager/fragment-devslp@0: -22
[ 0.148060] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.148069] Error in parsing node /plugin-manager/fragment-e3325-xusb: -22
[ 0.148248] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.148257] Error in parsing node /plugin-manager/fragment-500-pcie-config: -22
[ 0.148440] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.148449] Error in parsing node /plugin-manager/fragment-comms-a00-chip: -22
[ 0.148631] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.148641] Error in parsing node /plugin-manager/fragment-500-xusb-config: -22
[ 0.148824] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.148834] Error in parsing node /plugin-manager/fragment-500-e3325-pcie: -22
[ 0.149015] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.149024] Error in parsing node /plugin-manager/fragment-e3320-dp: -22
[ 0.149202] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.149211] Error in parsing node /plugin-manager/fragment-p3310-c00-comm: -22
[ 0.149402] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.149412] Error in parsing node /plugin-manager/fragment-p3310-c00-pmic: -22
[ 0.149594] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.149603] Error in parsing node /plugin-manager/fragment-p3310-c01: -22
[ 0.149784] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.149793] Error in parsing node /plugin-manager/fragment-p3310-c03: -22
[ 0.149977] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.149986] Error in parsing node /plugin-manager/fragment-e2614-common@0: -22
[ 0.150168] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.150178] Error in parsing node /plugin-manager/fragment-e2614-a00@1: -22
[ 0.150356] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.150365] Error in parsing node /plugin-manager/fragment-e2614-b00@2: -22
[ 0.150544] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.150554] Error in parsing node /plugin-manager/fragment-e3320-a00@1: -22
[ 0.150734] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.150744] Error in parsing node /plugin-manager/fragment-e3320-a01@1: -22
[ 0.150924] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.150934] Error in parsing node /plugin-manager/fragment-e1639-sharp-25x16@2: -22
[ 0.151116] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.151125] Error in parsing node /plugin-manager/fragment-e1824-a00@3: -22
[ 0.151311] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.151320] Error in parsing node /plugin-manager/fragment-e3326@0: -22
[ 0.151512] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.151521] Error in parsing node /plugin-manager/fragment-e3323@0: -22
[ 0.151700] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.151710] Error in parsing node /plugin-manager/fragment-p3310-c00-camera: -22
[ 0.151926] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.151935] Error in parsing node /plugin-manager/fragment-e3333@0: -22
[ 0.152148] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.152157] Error in parsing node /plugin-manager/fragment-e3322@0: -22
[ 0.152341] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.152351] Error in parsing node /plugin-manager/fragment-imx185@0: -22
[ 0.152536] chosen/plugin-manager does’nt have ids, nct and odm-data
[ 0.152545] Error in parsing node /plugin-manager/fragment-imx274@0: -22
[ 0.153506] Adding domain adsp-pd to PM domain ape-pd
[ 0.155896] NET: Registered protocol family 16
[ 0.156703] console [pstore-1] enabled
[ 0.156714] pstore: Registered ramoops as persistent store backend
[ 0.156726] ramoops: attached 0x200000@0xffe00000, ecc: 0/0
[ 0.165353] cpuidle: using governor ladder
[ 0.169796] cpuidle: using governor menu
[ 0.170967] bpmp: waiting for handshake
[ 0.170980] bpmp: handshake completed
[ 0.171020] bpmp: synchronizing channels
[ 0.171050] bpmp: channels synchronized
[ 0.171060] bpmp: mail init ok
[ 0.171380] vdso: 2 pages (1 code @ ffffffc001219000, 1 data @ ffffffc001218000)
[ 0.171410] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.172334] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.173809] tegra_powergate_init: DONE
[ 0.173827] DTS File Name: /home/jetpak3.1-kernel/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.173853] DTB Build time: Nov 16 2017 13:45:10
[ 0.174750] Tegra reboot handler registered.
[ 0.175792] Registering Tegra186 clocks (this may take a while)…done
[ 0.177949] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.177965] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.177977] arm-smmu 12000000.iommu: stage 1 translation
[ 0.177989] arm-smmu 12000000.iommu: stage 2 translation
[ 0.177999] arm-smmu 12000000.iommu: nested translation
[ 0.178013] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.178030] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.178047] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.178060] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.178071] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.227056] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.232327] iommu: Adding device 3460000.sdhci to group 0
[ 0.233132] iommu: Adding device 3400000.sdhci to group 1
[ 0.236584] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.237016] iommu: Adding device 3160000.i2c to group 3
[ 0.237385] iommu: Adding device c240000.i2c to group 4
[ 0.237729] iommu: Adding device 3180000.i2c to group 5
[ 0.238062] iommu: Adding device 3190000.i2c to group 6
[ 0.238510] iommu: Adding device 31b0000.i2c to group 7
[ 0.238853] iommu: Adding device 31c0000.i2c to group 8
[ 0.239192] iommu: Adding device c250000.i2c to group 9
[ 0.239537] iommu: Adding device 31e0000.i2c to group 10
[ 0.241524] iommu: Adding device 3210000.spi to group 11
[ 0.241818] iommu: Adding device c260000.spi to group 12
[ 0.242149] iommu: Adding device 3240000.spi to group 13
[ 0.242911] iommu: Adding device 3100000.serial to group 14
[ 0.243228] iommu: Adding device 3110000.serial to group 15
[ 0.243525] iommu: Adding device c280000.serial to group 16
[ 0.243863] iommu: Adding device 3130000.serial to group 17
[ 0.245031] iommu: Adding device 2490000.ether_qos to group 18
[ 0.245600] iommu: Adding device b000000.rtcpu to group 19
[ 0.246053] iommu: Adding device c1a0000.aon to group 20
[ 0.246922] Wake73 for irq=42
[ 0.247289] iommu: Adding device smmu_test to group 21
[ 0.247850] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.247888] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.247921] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.247982] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.248015] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.248048] mc-err: Set intmask: 0xf3140
[ 0.248309] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.249115] Wake76 for irq=199
[ 0.249143] Wake77 for irq=199
[ 0.249162] Wake78 for irq=199
[ 0.249180] Wake79 for irq=199
[ 0.249197] Wake80 for irq=199
[ 0.249215] Wake81 for irq=199
[ 0.249232] Wake82 for irq=199
[ 0.249371] iommu: Adding device 3530000.xhci to group 22
[ 0.249713] iommu: Adding device 3550000.xudc to group 23
[ 0.250518] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.250546] tegra-pmc: ### PMC reset source: Power on reset
[ 0.250568] tegra-pmc: ### PMC reset level: L0
[ 0.250611] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.250896] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.250932] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.251092] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.251120] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.251612] iommu: Adding device 13e10000.host1x to group 24
[ 0.251880] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.252127] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.252369] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.252612] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.252829] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.253080] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.253311] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.253615] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.254027] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.254617] iommu: Adding device 15700000.vi to group 34
[ 0.254963] iommu: Adding device 15600000.isp to group 35
[ 0.255269] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.255491] iommu: Adding device 15340000.vic to group 37
[ 0.255715] iommu: Adding device 154c0000.nvenc to group 38
[ 0.255913] iommu: Adding device 15480000.nvdec to group 39
[ 0.256232] iommu: Adding device 15380000.nvjpg to group 40
[ 0.256544] iommu: Adding device 15500000.tsec to group 41
[ 0.256739] iommu: Adding device 15100000.tsecb to group 42
[ 0.257455] iommu: Adding device 15810000.se to group 43
[ 0.257661] iommu: Adding device 15820000.se to group 44
[ 0.257853] iommu: Adding device 15830000.se to group 45
[ 0.258067] iommu: Adding device 15840000.se to group 46
[ 0.258571] iommu: Adding device 17000000.gp10b to group 47
[ 0.259998] tegra-reset 5000000.clock: registered 193 resets.
[ 0.261994] iommu: Adding device d000000.bpmp to group 48
[ 0.262243] bpmp: ping status is 0
[ 0.262444] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[ 0.262828] bpmp d000000.bpmp: probe ok
[ 0.265292] iommu: Adding device 2600000.dma to group 49
[ 0.266080] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.266135] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.266186] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.266313] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.268241] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.268349] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.269264] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.269501] iommu: Adding device sound to group 51
[ 0.271392] iommu: Adding device 3510000.hda to group 52
[ 0.272747] iommu: Adding device adsp_audio to group 53
[ 0.274293] iommu: Adding device 2993000.adsp to group 54
[ 0.283188] vdd-ac-bat: 5000 mV
[ 0.285317] vdd-1v8-ap: 1800 mV
[ 0.286518] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.286905] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.304880] SCSI subsystem initialized
[ 0.305059] libata version 3.00 loaded.
[ 0.305264] usbcore: registered new interface driver usbfs
[ 0.305325] usbcore: registered new interface driver hub
[ 0.305427] usbcore: registered new device driver usb
[ 0.309447] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.309889] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.309993] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.311378] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.311505] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.324008] media: Linux media interface: v0.10
[ 0.324079] Linux video capture interface: v2.00
[ 0.328054] pps_core: LinuxPPS API ver. 1 registered
[ 0.328086] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.328133] PTP clock support registered
[ 0.330160] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.332070] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.332273] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.332368] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.338765] vddio-ddr: at 1125 mV
[ 0.342611] avdd_dsi_csi: 1200 mV
[ 0.346605] vdd-1v8: 1800 mV
[ 0.350606] vdd-3v3-sys: 3300 mV
[ 0.351660] spmic-ldo0: at 1800 mV
[ 0.352421] spmic-ldo1: at 800 mV
[ 0.358603] vddio-3v3: 3300 mV
[ 0.359216] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.361800] vdd-rtc: at 800 mV
[ 0.362462] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.365797] spmic-ldo6: at 1500 mV
[ 0.369799] vdd-pex-1v05: 1000 mV
[ 0.370331] dvdd-pex: 1000 mV
[ 0.370591] max77620 4-003c: max77620 probe successful
[ 0.370831] Advanced Linux Sound Architecture Driver Initialized.
[ 0.371787] en-vdd-sd: 3300 mV
[ 0.372416] en-vdd-cam: 1800 mV
[ 0.373812] vdd-hdmi: 5000 mV
[ 0.373984] vdd-usb0-5v: 5000 mV
[ 0.374148] vdd-usb1-5v: 5000 mV
[ 0.377813] en-vdd-ts-1v8: 1800 mV
[ 0.381812] en-vdd-ts-hv-3v3: 3300 mV
[ 0.382319] en-vdd-disp-3v3: 3300 mV
[ 0.382826] en-mdm-pwr-3v7: 3700 mV
[ 0.383338] en-vdd-disp-1v8: 1800 mV
[ 0.383854] en-vdd-cam-hv-2v8: 2800 mV
[ 0.384376] en-vdd-cam-1v2: 1200 mV
[ 0.384903] vdd-fan: 5000 mV
[ 0.385008] vdd-3v3: 3300 mV
[ 0.385732] dis-vdd-1v2: 1200 mV
[ 0.385848] en-vdd-vcm-2v8: 2800 mV
[ 0.386367] vdd-usb2-5v: 5000 mV
[ 0.386474] vdd-sys-bl: 3300 mV
[ 0.387006] en-vdd-sys: 1200 mV
[ 0.388540] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.390224] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 0.390621] clocksource: Switched to clocksource arch_sys_counter
[ 0.409982] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.410290] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.410788] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000ae000000, size=0x2a000000
[ 0.410986] cma: enabled page replacement for spfn=ae000, epfn=d8000
[ 0.410999] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[ 0.411014] nvmap_page_pool_init: Total RAM pages: 2009134
[ 0.411029] nvmap_page_pool_init: nvmap page pool size: 251141 pages (981 MB)
[ 0.411104] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.411291] misc nvmap: created heap vpr base 0x00000000ae000000 size (688128KiB)
[ 0.415784] Wake76 for irq=199
[ 0.415796] Wake77 for irq=199
[ 0.415806] Wake78 for irq=199
[ 0.415815] Wake79 for irq=199
[ 0.415824] Wake80 for irq=199
[ 0.415833] Wake81 for irq=199
[ 0.415842] Wake82 for irq=199
[ 0.416579] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.416778] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.416894] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.416972] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.417367] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.417509] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.417650] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.417799] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.418092] isomgr_init(): iso emc max clk=1866000KHz
[ 0.418103] isomgr_init(): max_iso_bw=26870400KB
[ 0.418181] NET: Registered protocol family 2
[ 0.418491] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.418739] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.419034] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.419090] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.419142] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.419302] NET: Registered protocol family 1
[ 0.419518] RPC: Registered named UNIX socket transport module.
[ 0.419531] RPC: Registered udp transport module.
[ 0.419541] RPC: Registered tcp transport module.
[ 0.419552] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.419572] PCI: CLS 0 bytes, default 128
[ 0.433582] host1x 13e10000.host1x: initialized
[ 0.434379] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.436504] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.436598] audit: initializing netlink subsys (disabled)
[ 0.436626] audit: type=2000 audit(0.424:1): initialized
[ 0.442937] io scheduler noop registered (default)
[ 0.445813] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.446978] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.448047] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.449096] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.452469] tsec 15500000.tsec: initialized
[ 0.453590] tsec 15100000.tsecb: initialized
[ 0.455928] nvdec 15480000.nvdec: initialized
[ 0.459583] falcon 15340000.vic: initialized
[ 0.460579] falcon 154c0000.nvenc: initialized
[ 0.461559] falcon 15380000.nvjpg: initialized
[ 0.462349] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.462867] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.463368] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.463868] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.464370] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.464863] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.465356] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.465852] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.468465] DC OR NODE connected to /host1x/sor1
[ 0.468624] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.468671] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.468712] tegradc 15210000.nvdisplay: Display dc.ffffff80022c0000 registered with id=0
[ 0.468718] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.468722] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.476112] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.476131] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.476146] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.476189] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.476203] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.476420] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.478558] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.478827] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.478847] PD DISP0 index2 UP
[ 0.478946] kfuse 3830000.kfuse: initialized
[ 0.479680] PD DISP1 index3 UP
[ 0.479835] PD DISP2 index4 UP
[ 0.480146] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.480630] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.482484] console [ttyS0] disabled
[ 0.482528] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.506038] Unsupported HDMI VIC 64, ignoring
[ 0.506046] PD DISP2 index4 DOWN
[ 0.506203] PD DISP1 index3 DOWN
[ 0.506347] PD DISP0 index2 DOWN
[ 0.508352] tegradc 15210000.nvdisplay: probed
[ 2.956396] console [ttyS0] enabled
[ 2.958353] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.959412] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.959659] serial-tegra 3130000.serial: RX in PIO mode
[ 2.960547] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.965478] Console: switching to colour frame buffer device 180x56
[ 2.970341] brd: module loaded
[ 2.974716] loop: module loaded
[ 2.974949] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.974966] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.974970] nct1008_nct72 7-004c: starting parse dt
[ 2.975055] nct1008_nct72 7-004c: success parsing dt
[ 2.975166] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.049337] tegradc 15210000.nvdisplay: fb registered
[ 3.061865] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.067204] PD DISP0 index2 UP
[ 3.071297] PD DISP1 index3 UP
[ 3.072036] tmp451: Enabled overheat logging at 104.00C
[ 3.072118] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.072149] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.074340] THERMAL EST: found 3 subdevs
[ 3.074342] THERMAL EST num_resources: 0
[ 3.074345] [THERMAL EST subdev 0]
[ 3.074348] [THERMAL EST subdev 1]
[ 3.074351] [THERMAL EST subdev 2]
[ 3.074552] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 3.074554] THERMAL EST: thz register success.
[ 3.074647] THERMAL EST: end of probe, return err: 0
[ 3.074817] tegra_profiler: Branch: Dev
[ 3.074818] tegra_profiler: Version: 1.109
[ 3.074819] tegra_profiler: Samples version: 37
[ 3.074820] tegra_profiler: IO version: 21
[ 3.074824] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.074826] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.074828] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.074830] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 3.074833] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.074834] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 3.074836] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.074838] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.074840] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.074841] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.074843] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.074844] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.074962] tegra_profiler: auth: init
[ 3.077665] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.077672] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.078293] scsi host0: tegra_ahci
[ 3.078516] scsi host1: tegra_ahci
[ 3.078651] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 3.078653] ata2: DUMMY
[ 3.079376] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.079728] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.080040] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.080667] tun: Universal TUN/TAP device driver, 1.6
[ 3.080668] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.080789] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 3.080790] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 3.080818] igb: Intel® Gigabit Ethernet Network Driver - version 5.3.0-k
[ 3.080819] igb: Copyright © 2007-2014 Intel Corporation.
[ 3.081618] PPP generic driver version 2.4.2
[ 3.081708] PPP BSD Compression module registered
[ 3.081712] PPP Deflate Compression module registered
[ 3.081727] PPP MPPE Compression module registered
[ 3.081736] NET: Registered protocol family 24
[ 3.081778] usbcore: registered new interface driver r8152
[ 3.081805] usbcore: registered new interface driver asix
[ 3.081827] usbcore: registered new interface driver ax88179_178a
[ 3.081848] usbcore: registered new interface driver cdc_ether
[ 3.081877] usbcore: registered new interface driver smsc95xx
[ 3.081899] usbcore: registered new interface driver net1080
[ 3.081920] usbcore: registered new interface driver cdc_subset
[ 3.081941] usbcore: registered new interface driver zaurus
[ 3.081977] usbcore: registered new interface driver cdc_ncm
[ 3.082139] Wake76 for irq=199
[ 3.082140] Wake77 for irq=199
[ 3.082141] Wake78 for irq=199
[ 3.082143] Wake79 for irq=199
[ 3.082144] Wake80 for irq=199
[ 3.082144] Wake81 for irq=199
[ 3.082145] Wake82 for irq=199
[ 3.082188] tegra-xotg xotg: usb2 phy is not available yet
[ 3.082657] usbcore: registered new interface driver usb-storage
[ 3.082702] usbcore: registered new interface driver usbserial
[ 3.082724] usbcore: registered new interface driver ftdi_sio
[ 3.082741] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.082761] usbcore: registered new interface driver option
[ 3.082775] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.082794] usbcore: registered new interface driver pl2303
[ 3.082807] usbserial: USB Serial support registered for pl2303
[ 3.082957] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.084816] eqos_get_mac_address_dtb: bad mac address at /chosen/nvidia,ether-mac: null.
[ 3.084818] ether-mac read from DT failed -99
[ 3.085294] libphy: dwc_phy: probed
[ 3.085710] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.147658] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 3.147801] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.216276] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.218421] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.218434] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.218573] i2c /dev entries driver
[ 3.219354] gspca_main: v2.14.0 registered
[ 3.219391] usbcore: registered new interface driver gspca_zc3xx
[ 3.219618] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.221382] FAN dev name: pwm-fan
[ 3.221430] FAN:gpio request success.
[ 3.221435] FAN: can’t find tach_gpio
[ 3.221454] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.221590] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 3.221594] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.221598] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.221880] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.221883] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.221886] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.221889] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.221892] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.221895] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.221898] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.221901] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.221905] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.221908] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.222613] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[ 3.222809] device-mapper: uevent: version 1.0.3
[ 3.222964] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.223276] sdhci: Secure Digital Host Controller Interface driver
[ 3.223277] sdhci: Copyright© Pierre Ossman
[ 3.223281] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.223553] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.223828] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.224056] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.224518] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.224634] hidraw: raw HID events driver © Jiri Kosina
[ 3.226065] usbcore: registered new interface driver usbhid
[ 3.226066] usbhid: USB HID core driver
[ 3.229523] nvadsp 2993000.adsp: in probe()…
[ 3.230996] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.231027] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.231253] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.233900] Denver: backdoor interface is NOT available.
[ 3.235997] coresight-tmc 8030000.etf: TMC initialized
[ 3.238144] coresight-tmc 8050000.etr: TMC initialized
[ 3.238608] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.239219] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.239776] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.240274] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.240754] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.241496] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.242148] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.242800] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.243432] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.243464] Module initialized successfully
[ 3.247540] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.249167] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.249415] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.249796] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.249846] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.249888] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.249932] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.249971] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.250013] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.250055] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.250200] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.250203] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.250921] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.250924] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.250926] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.250929] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.250931] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.250933] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.250936] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.250965] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.255732] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.256641] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.256751] camchar: rtcpu character device driver loaded
[ 3.261825] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.262229] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.262458] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.263107] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.263138] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.263166] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.263192] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.263226] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.263252] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.263279] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.263306] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.263338] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.263361] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.263392] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.263417] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.263447] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.263474] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.263501] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.263552] **** A57 ECC: Enabled
[ 3.263555] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.263708] parse_throttle_dt_data: Num cap clks = 4
[ 3.263712] parse_throttle_dt_data: clk=mcpu type=1
[ 3.263714] parse_throttle_dt_data: clk=bcpu type=2
[ 3.263722] parse_throttle_dt_data: clk=gpu type=4
[ 3.263724] parse_throttle_dt_data: clk=emc type=3
[ 3.264287] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.264391] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.267763] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.268056] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.270655] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.270902] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.271176] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.306640] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.306872] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.306926] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.307014] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.307039] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.307248] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.346669] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.346699] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.352633] mmc0: MAN_BKOPS_EN bit is not set
[ 3.359872] mmc0: Skipping tuning since strobe enabled
[ 3.367352] mmc0: periodic cache flush enabled
[ 3.367360] mmc0: new HS400 MMC card at address 0001
[ 3.367612] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.367713] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.367814] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.367911] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.369061] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 3.398664] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.411076] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.609069] mmc1 tuning done saved tap delay=63
[ 3.609072] mmc1: hw tuning done …
[ 3.609080] mmc1: tuning_window[0]: 0xffffffff
[ 3.609086] mmc1: tuning_window[1]: 0xfffff8ff
[ 3.609092] mmc1: tuning_window[2]: 0xff1fffff
[ 3.609097] mmc1: tuning_window[3]: 0x7fffffff
[ 3.609103] mmc1: tuning_window[4]: 0x0
[ 3.609140] mmc1: tuning_window[5]: 0x0
[ 3.609145] mmc1: tuning_window[6]: 0x0
[ 3.609151] mmc1: tuning_window[7]: 0x0
[ 3.609155] sdhci: Tap value: 63 | Trim value: 5
[ 3.609159] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.616110] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.616158] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.660123] PD DISP2 index4 UP
[ 4.666313] Parent Clock set for DC plld2
[ 4.675718] tegradc 15210000.nvdisplay: hdmi: pclk:106700K, set prod-setting:prod_c_150M
[ 4.703091] tegra-se-nvhost 15810000.se: initialized
[ 4.710419] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.718769] tegra-se-nvhost 15820000.se: initialized
[ 4.725926] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.734221] tegra-se-nvhost 15830000.se: initialized
[ 4.741203] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.749524] tegra-se-nvhost 15840000.se: initialized
[ 4.756695] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.767934] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.779993] cpufreq: platform driver Initialization: pass
[ 4.786910] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 4.794762] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.802173] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.812963] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.823435] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ccc17
[ 4.824696] Unsupported HDMI VIC 64, ignoring
[ 4.837291] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 4.838905] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.839616] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 4.840561] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.843102] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.843234] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.844429] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.844433] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.848468] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.851189] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.851928] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.853165] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.853949] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.854941] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.854948] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.854950] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.860900] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.860900] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.861078] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.869554] OPE platform probe
[ 4.869678] OPE platform probe successful
[ 4.876259] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 4.954360] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.954460] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.954567] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.954688] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.954780] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.954891] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.954985] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.955080] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.955170] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.955266] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.955358] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.955468] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.955562] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.955651] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.955743] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.955837] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.955958] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.956049] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.956144] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.956241] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.960147] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.960239] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.960268] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.960309] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.994874] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.995563] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 4.995567] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.996100] GACT probability NOT on
[ 4.996126] Mirror/redirect action on
[ 4.996137] u32 classifier
[ 4.996138] Actions configured
[ 4.996157] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.996875] ipip: IPv4 over IPv4 tunneling driver
[ 4.997191] Initializing XFRM netlink socket
[ 4.997504] NET: Registered protocol family 10
[ 4.998240] ip6_tables: © 2000-2006 Netfilter Core Team
[ 4.998298] NET: Registered protocol family 17
[ 4.998311] NET: Registered protocol family 15
[ 4.998334] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.998339] 8021q: 802.1Q VLAN Support v1.8
[ 4.998655] Registered cp15_barrier emulation handler
[ 4.998672] Registered setend emulation handler
[ 5.000107] registered taskstats version 1
[ 5.004483] isp 15600000.isp: initialized
[ 5.008552] nvcsi 150c0000.nvcsi: initialized
[ 5.009438] Wake76 for irq=199
[ 5.009439] Wake77 for irq=199
[ 5.009440] Wake78 for irq=199
[ 5.009440] Wake79 for irq=199
[ 5.009441] Wake80 for irq=199
[ 5.009442] Wake81 for irq=199
[ 5.009442] Wake82 for irq=199
[ 5.009716] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 5.009717] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 5.034903] spi-tegra114 3210000.spi: Static pin configuration used
[ 5.035042] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 5.035044] xhci-tegra 3530000.xhci: Falling back to user helper
[ 5.035503] spi-tegra114 c260000.spi: Static pin configuration used
[ 5.036195] spi-tegra114 3240000.spi: Static pin configuration used
[ 5.036901] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 5.036937] tegra-xotg xotg: update_id_state: ID grounded
[ 5.036941] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 5.036954] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 5.038695] tegra-xotg xotg: otg: gadget gadget registered
[ 5.038697] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 5.038699] tegra-xotg xotg: otg: host not registered yet
[ 5.038700] tegra-xotg xotg: otg: start OTG finite state machine
[ 5.038739] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.038774] tegra-xotg xotg: FSM: can’t move to a_idle, host isn’t ready
[ 5.039297] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.039492] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 5.039570] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 5.039627] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 5.039747] input: gpio-keys as /devices/gpio-keys/input/input3
[ 5.073340] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 02:56:53 UTC (946695413)
[ 5.103822] bpmp: mounted debugfs mirror
[ 5.104335] [dram-timers] DRAM derating cdev registered.
[ 5.108179] spmic-ldo0: disabling
[ 5.108362] spmic-ldo1: disabling
[ 5.108524] en-vdd-sd: disabling
[ 5.108526] en-vdd-cam: disabling
[ 5.108528] vdd-usb0-5v: disabling
[ 5.108530] vdd-usb1-5v: disabling
[ 5.108532] en-vdd-disp-3v3: disabling
[ 5.108534] en-mdm-pwr-3v7: disabling
[ 5.108535] en-vdd-disp-1v8: disabling
[ 5.108537] en-vdd-cam-hv-2v8: disabling
[ 5.108538] en-vdd-cam-1v2: disabling
[ 5.108540] vdd-fan: disabling
[ 5.108541] vdd-3v3: disabling
[ 5.108543] en-vdd-vcm-2v8: disabling
[ 5.108544] vdd-usb2-5v: disabling
[ 5.108545] vdd-sys-bl: disabling
[ 5.108547] en-vdd-sys: disabling
[ 5.114527] ALSA device list:
[ 5.114529] #0: tegra-hda at 0x3518000 irq 400
[ 5.114530] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.115806] tegra-vi4 15700000.vi: initialized
[ 5.116943] tegra-vi4 15700000.vi: all channel register failed
[ 12.468905] random: nonblocking pool is initialized
[ 12.647442] tegradc 15210000.nvdisplay: hdmi: plugged
[ 12.652164] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.652177] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 12.653860] devtmpfs: mounted
[ 12.654135] Freeing unused kernel memory: 1164K (ffffffc0010cd000 - ffffffc0011f0000)
[ 12.654158] Freeing alternatives memory: 96K (ffffffc0011f0000 - ffffffc001208000)
[ 12.700232] systemd[1]: System time before build time, advancing clock.
[ 12.726036] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 12.747316] systemd[1]: Detected architecture arm64.
[ 12.761559] systemd[1]: Set hostname to .
[ 12.868751] systemd[1]: Reached target User and Group Name Lookups.
[ 12.878300] systemd[1]: Listening on Syslog Socket.
[ 12.886342] systemd[1]: Created slice User and Session Slice.
[ 12.895248] systemd[1]: Reached target Swap.
[ 12.902687] systemd[1]: Listening on Journal Socket.
[ 12.910831] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 12.920980] systemd[1]: Reached target Encrypted Volumes.
[ 12.930805] systemd[1]: Listening on Journal Audit Socket.
[ 12.939149] systemd[1]: Listening on udev Control Socket.
[ 12.947355] systemd[1]: Listening on udev Kernel Socket.
[ 12.955242] systemd[1]: Reached target Remote File Systems (Pre).
[ 12.963886] systemd[1]: Reached target Remote File Systems.
[ 12.972253] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.982665] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.991561] systemd[1]: Created slice System Slice.
[ 12.999412] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 13.015785] systemd[1]: Started Braille Device Support.
[ 13.027434] systemd[1]: Starting Journal Service…
[ 13.035646] systemd[1]: Created slice system-getty.slice.
[ 13.045057] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 13.055966] systemd[1]: Mounting Debug File System…
[ 13.065766] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 13.078296] systemd[1]: Reached target Slices.
[ 13.088952] systemd[1]: Starting Load Kernel Modules…
[ 13.097490] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 13.099385] systemd[1]: Mounted Debug File System.
[ 13.113471] systemd[1]: Started Journal Service.
[ 13.195697] systemd-journald[260]: Received request to flush runtime journal from PID 1
[ 13.295925] cfg80211: World regulatory domain updated:
[ 13.303077] cfg80211: DFS Master region: unset
[ 13.307714] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 13.321238] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.331205] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.331207] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.331209] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 13.331211] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 13.331213] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 13.331215] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.331216] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 13.421249] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 13.431843] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 13.432358] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 13.434580] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 13.490531] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 13.581026] dhd_module_init in
[ 13.585745] tegra_net_perf_init: cannot get wifi sclk
[ 13.592546] found wifi platform device bcmdhd_wlan
[ 13.600170] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 13.600178] wifi_platform_get_country_code_map: could not get country_code_map
[ 13.600180] wifi_plat_dev_drv_probe:platform country code map is not available
[ 13.600189] Power-up adapter ‘DHD generic adapter’
[ 13.600194] wifi_platform_set_power = 1
[ 13.802644] wifi_platform_bus_enumerate device present 1
[ 13.820539] wifi_platform_bus_enumerate device present 0
[ 13.820929] F1 signature read @0x18000000=0x17214354
[ 13.824631] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 13.825146] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 13.825203] wifi_platform_prealloc: failed to alloc static mem section 7
[ 13.825210] wifi_platform_get_mac_addr
[ 13.825315] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 13.826578] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 13.827009] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 13.827234] wl_create_event_handler(): thread:wl_event_handler:1e6 started
[ 13.827240] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e1a61a70
[ 13.827340] dhd_attach(): thread:dhd_watchdog_thread:1e7 started
[ 13.827381] dhd_attach(): thread:dhd_dpc:1e8 started
[ 13.827422] dhd_attach(): thread:dhd_rxf:1e9 started
[ 13.827427] dhd_deferred_work_init: work queue initialized
[ 13.827583] Dongle Host Driver, version 1.201.82 ®
Compiled in drivers/net/wireless/bcmdhd on Jul 20 2017 at 00:47:12
[ 13.827844] tegra_sysfs_register
[ 13.827869] Register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 13.827871] dhd_prot_ioctl : bus is down. we have nothing to do
[ 13.827960] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 63
[ 13.829000] wifi_platform_set_power = 0
[ 13.884774] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 14.288926] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 14.504584] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 14.506634] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 14.506652] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 14.507451] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 14.507473] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 14.507588] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 14.507590] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.507592] usb usb1: Product: xHCI Host Controller
[ 14.507594] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 14.507595] usb usb1: SerialNumber: 3530000.xhci
[ 14.507860] hub 1-0:1.0: USB hub found
[ 14.507881] hub 1-0:1.0: 4 ports detected
[ 14.526656] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 14.526666] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 14.526773] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 14.526776] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.526778] usb usb2: Product: xHCI Host Controller
[ 14.526779] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 14.526781] usb usb2: SerialNumber: 3530000.xhci
[ 14.527009] hub 2-0:1.0: USB hub found
[ 14.527027] hub 2-0:1.0: 3 ports detected
[ 14.527375] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 14.538828] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 14.690679] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 14.692693] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 14.826631] usb 1-1: new high-speed USB device number 2 using xhci-tegra
[ 14.963822] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608
[ 14.963824] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 14.963826] usb 1-1: Product: USB2.0 Hub
[ 14.964316] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 14.964677] hub 1-1:1.0: USB hub found
[ 14.964950] hub 1-1:1.0: 4 ports detected
[ 15.092739] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 15.242640] usb 1-1.1: new low-speed USB device number 3 using xhci-tegra
[ 15.336605] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2113
[ 15.336608] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 15.336611] usb 1-1.1: Product: Dell KB216 Wired Keyboard
[ 15.336829] usb 1-1.1: ep 0x81 - rounding interval to 128 microframes, ep desc says 192 microframes
[ 15.336849] usb 1-1.1: ep 0x82 - rounding interval to 256 microframes, ep desc says 384 microframes
[ 15.340812] input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2113.0001/input/input4
[ 15.394887] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3530000.xhci-1.1/input0
[ 15.399889] input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-1/1-1.1/1-1.1:1.1/0003:413C:2113.0002/input/input5
[ 15.454775] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3530000.xhci-1.1/input1
[ 15.494789] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 15.526641] usb 1-1.2: new low-speed USB device number 4 using xhci-tegra
[ 15.617908] usb 1-1.2: New USB device found, idVendor=0461, idProduct=4d81
[ 15.617912] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 15.617915] usb 1-1.2: Product: USB Optical Mouse
[ 15.618067] usb 1-1.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 15.620811] input: USB Optical Mouse as /devices/3530000.xhci/usb1/1-1/1-1.2/1-1.2:1.0/0003:0461:4D81.0003/input/input6
[ 15.620921] hid-generic 0003:0461:4D81.0003: input,hidraw2: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3530000.xhci-1.2/input0
[ 15.899327] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 15.901346] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 15.901353] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 15.901527] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 16.174364] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 16.174367] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 16.875348] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 16.882495]
[ 16.899295] wl_android_wifi_on
