I tried to link the atlantic driver to my network interface in the device tree.
Network interface wasn’t showing up anymore. Would you have any other idea?
This is what I get with dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (root@janick-jetPack) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #4 SMP PREEMPT Tue Sep 26 15:48:10 CEST 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x1025693a18 SMBIOS=0xffff0000 SMBIOS 3.0=0x1005e10000 MEMATTR=0x1006c05018 ESRT=0x1005de7b18 RNG=0x10070bf398 MEMRESERVE=0x1006c06f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000001005de7b18 to 0x0000001005de7b50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001009000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000001003627fff]
[ 0.000000] node 0: [mem 0x0000001003628000-0x0000001003853fff]
[ 0.000000] node 0: [mem 0x0000001003854000-0x000000100551ffff]
[ 0.000000] node 0: [mem 0x0000001005520000-0x00000010055bffff]
[ 0.000000] node 0: [mem 0x00000010055c0000-0x0000001005dfffff]
[ 0.000000] node 0: [mem 0x0000001005e00000-0x0000001005e1ffff]
[ 0.000000] node 0: [mem 0x0000001005e20000-0x0000001006a2ffff]
[ 0.000000] node 0: [mem 0x0000001006a30000-0x0000001006a4ffff]
[ 0.000000] node 0: [mem 0x0000001006a50000-0x0000001006adffff]
[ 0.000000] node 0: [mem 0x0000001006ae0000-0x0000001006b7ffff]
[ 0.000000] node 0: [mem 0x0000001006b80000-0x0000001006bdffff]
[ 0.000000] node 0: [mem 0x0000001006be0000-0x0000001006bfffff]
[ 0.000000] node 0: [mem 0x0000001006c00000-0x0000001006c1ffff]
[ 0.000000] node 0: [mem 0x0000001006c20000-0x0000001006c3ffff]
[ 0.000000] node 0: [mem 0x0000001006c40000-0x0000001006d6ffff]
[ 0.000000] node 0: [mem 0x0000001006d70000-0x0000001006f4ffff]
[ 0.000000] node 0: [mem 0x0000001006f50000-0x0000001006fdffff]
[ 0.000000] node 0: [mem 0x0000001006fe0000-0x000000100707ffff]
[ 0.000000] node 0: [mem 0x0000001007080000-0x00000010070affff]
[ 0.000000] node 0: [mem 0x00000010070b0000-0x00000010070bffff]
[ 0.000000] node 0: [mem 0x00000010070c0000-0x000000100710ffff]
[ 0.000000] node 0: [mem 0x0000001007110000-0x000000100733ffff]
[ 0.000000] node 0: [mem 0x0000001007340000-0x00000010073cffff]
[ 0.000000] node 0: [mem 0x00000010073d0000-0x000000100741ffff]
[ 0.000000] node 0: [mem 0x0000001007420000-0x000000100744ffff]
[ 0.000000] node 0: [mem 0x0000001007450000-0x00000010074effff]
[ 0.000000] node 0: [mem 0x00000010074f0000-0x000000100753ffff]
[ 0.000000] node 0: [mem 0x0000001007540000-0x00000010075dffff]
[ 0.000000] node 0: [mem 0x00000010075e0000-0x0000001007abffff]
[ 0.000000] node 0: [mem 0x0000001007ac0000-0x0000001007c9ffff]
[ 0.000000] node 0: [mem 0x0000001007ca0000-0x000000102930ffff]
[ 0.000000] node 0: [mem 0x0000001029310000-0x000000102935ffff]
[ 0.000000] node 0: [mem 0x0000001029360000-0x000000102d1fffff]
[ 0.000000] node 0: [mem 0x000000102d210000-0x000000102d21ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0 totalpages: 16445968
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 249088 pages used for memmap
[ 0.000000] Normal zone: 15921680 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16188688
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb pcie_aspm=off
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 63771660K/65783872K available (18240K kernel code, 3166K rwdata, 7168K rodata, 3968K init, 1416K bss, 1487924K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000761] Console: colour dummy device 80x25
[ 0.000946] printk: console [tty0] enabled
[ 0.000995] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001006] pid_max: default: 32768 minimum: 301
[ 0.001112] LSM: Security Framework initializing
[ 0.001145] Yama: becoming mindful.
[ 0.001168] SELinux: Initializing.
[ 0.001322] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001414] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003864] rcu: Hierarchical SRCU implementation.
[ 0.003980] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004615] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-brla4-agx-orin.dts
[ 0.004626] DTB Build time: Apr 18 2024 09:37:48
[ 0.006058] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006337] Remapping and enabling EFI services.
[ 0.006894] smp: Bringing up secondary CPUs ...
[ 0.035635] Detected PIPT I-cache on CPU1
[ 0.035672] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035713] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064397] Detected PIPT I-cache on CPU2
[ 0.064408] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064425] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093050] Detected PIPT I-cache on CPU3
[ 0.093059] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093072] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.123753] Detected PIPT I-cache on CPU4
[ 0.123774] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.123798] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152472] Detected PIPT I-cache on CPU5
[ 0.152482] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152496] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181127] Detected PIPT I-cache on CPU6
[ 0.181136] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181150] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.209793] Detected PIPT I-cache on CPU7
[ 0.209802] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.209816] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.240501] Detected PIPT I-cache on CPU8
[ 0.240524] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.240549] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269217] Detected PIPT I-cache on CPU9
[ 0.269227] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.269242] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.298502] Detected PIPT I-cache on CPU10
[ 0.298512] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.298527] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.327767] Detected PIPT I-cache on CPU11
[ 0.327778] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.327792] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.327847] smp: Brought up 1 node, 12 CPUs
[ 0.327919] SMP: Total of 12 processors activated.
[ 0.327924] CPU features: detected: Privileged Access Never
[ 0.327927] CPU features: detected: LSE atomic instructions
[ 0.327929] CPU features: detected: User Access Override
[ 0.327932] CPU features: detected: 32-bit EL0 Support
[ 0.327936] CPU features: detected: Common not Private translations
[ 0.327938] CPU features: detected: RAS Extension Support
[ 0.327941] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.327945] CPU features: detected: CRC32 instructions
[ 0.327947] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.345075] spectre-bhb mitigation disabled by command line option
[ 0.345077] spectre-bhb mitigation disabled by command line option
[ 0.345079] spectre-bhb mitigation disabled by command line option
[ 0.345082] spectre-bhb mitigation disabled by command line option
[ 0.360976] CPU: All CPU(s) started at EL2
[ 0.364494] devtmpfs: initialized
[ 0.383522] Registered cp15_barrier emulation handler
[ 0.383534] Registered setend emulation handler
[ 0.383540] KASLR enabled
[ 0.383666] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.383681] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.386779] pinctrl core: initialized pinctrl subsystem
[ 0.387269] SMBIOS 3.0.0 present.
[ 0.387277] DMI: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 4.1-33958178 08/01/2023
[ 0.387627] NET: Registered protocol family 16
[ 0.388511] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.388716] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.388913] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.388941] audit: initializing netlink subsys (disabled)
[ 0.389043] audit: type=2000 audit(0.388:1): state=initialized audit_enabled=0 res=1
[ 0.389244] thermal_sys: Registered thermal governor 'step_wise'
[ 0.389245] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.389252] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.391798] cpuidle: using governor menu
[ 0.391924] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.392038] ASID allocator initialised with 32768 entries
[ 0.392140] Serial: AMBA PL011 UART driver
[ 0.393995] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.394022] Tegra reboot handler registered.
[ 0.413829] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.413847] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.413855] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.413861] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.413868] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.413875] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.413882] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.413887] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.413894] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.413900] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.413906] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.413912] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.413918] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.413924] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.413930] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.413936] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.413943] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.413952] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.413998] mc-err: mcerr ops are set to t23x
[ 0.414723] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 85, base_baud = 0) is a SBSA
[ 1.686905] printk: console [ttyAMA0] enabled
[ 1.695603] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.702317] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.709016] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.715715] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.724612] ACPI: Interpreter disabled.
[ 1.729590] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.734457] vbusA-cvb: supplied by vdd-5v-sys
[ 1.738920] vbusB-cvb: supplied by vdd-5v-sys
[ 1.743651] iommu: Default domain type: Translated
[ 1.748580] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.754884] SCSI subsystem initialized
[ 1.758708] usbcore: registered new interface driver usbfs
[ 1.764204] usbcore: registered new interface driver hub
[ 1.769521] usbcore: registered new device driver usb
[ 1.774747] mc: Linux media interface: v0.10
[ 1.779022] videodev: Linux video capture interface: v2.00
[ 1.784652] pps_core: LinuxPPS API ver. 1 registered
[ 1.789616] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.798753] PTP clock support registered
[ 1.802894] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.810060] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.817701] Registered efivars operations
[ 1.822263] FPGA manager framework
[ 1.825683] Advanced Linux Sound Architecture Driver Initialized.
[ 1.832060] Bluetooth: Core ver 2.22
[ 1.835642] NET: Registered protocol family 31
[ 1.840087] Bluetooth: HCI device and connection manager initialized
[ 1.846444] Bluetooth: HCI socket layer initialized
[ 1.851320] Bluetooth: L2CAP socket layer initialized
[ 1.856391] Bluetooth: SCO socket layer initialized
[ 1.861767] camchar: rtcpu character device driver loaded
[ 1.867405] clocksource: Switched to clocksource arch_sys_counter
[ 2.028952] VFS: Disk quotas dquot_6.6.0
[ 2.032923] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.040348] pnp: PnP ACPI: disabled
[ 2.045818] la/ptsa driver initialized.
[ 2.049724] NET: Registered protocol family 2
[ 2.054288] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.064032] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.072804] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 2.081374] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.089295] TCP: Hash tables configured (established 524288 bind 65536)
[ 2.096018] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.103084] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.110699] NET: Registered protocol family 1
[ 2.115325] RPC: Registered named UNIX socket transport module.
[ 2.121253] RPC: Registered udp transport module.
[ 2.125957] RPC: Registered tcp transport module.
[ 2.130657] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.137107] PCI: CLS 0 bytes, default 64
[ 2.141175] Trying to unpack rootfs image as initramfs...
[ 2.283584] Freeing initrd memory: 10196K
[ 2.289725] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.297647] kvm [1]: IPA Size Limit: 48 bits
[ 2.301937] kvm [1]: GICv3: no GICV resource entry
[ 2.306728] kvm [1]: disabling GICv2 emulation
[ 2.311184] kvm [1]: GIC system register CPU interface enabled
[ 2.317124] kvm [1]: vgic interrupt IRQ9
[ 2.321201] kvm [1]: VHE mode initialized successfully
[ 2.327060] Initialise system trusted keyrings
[ 2.331620] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.340241] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.346404] NFS: Registering the id_resolver key type
[ 2.351473] Key type id_resolver registered
[ 2.355653] Key type id_legacy registered
[ 2.359696] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.366405] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.373811] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.390009] NET: Registered protocol family 38
[ 2.394457] Key type asymmetric registered
[ 2.398551] Asymmetric key parser 'x509' registered
[ 2.403444] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.410900] io scheduler mq-deadline registered
[ 2.415432] io scheduler kyber registered
[ 2.423569] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.429173] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.434761] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.440345] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.446686] efifb: probing for efifb
[ 2.450298] efifb: framebuffer at 0x1039e00000, using 34560k, total 34560k
[ 2.457185] efifb: mode is 3840x2160x32, linelength=16384, pages=1
[ 2.463363] efifb: scrolling: redraw
[ 2.466934] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.483586] Console: switching to colour frame buffer device 480x135
[ 2.500741] fb0: EFI VGA frame buffer device
[ 2.506663] tegra_dc_assign_hw_data: no matching compatible node
[ 2.512687] tegradccommon module_init failed
[ 2.516965] tegradc module_init failed
[ 2.520970] EINJ: ACPI disabled.
[ 2.525746] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.532641] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.537792] tegra-pmc: ### PMC reset level: L1
[ 2.542241] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.548513] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.254496] printk: console [ttyTCU0] enabled
[ 4.263649] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.271687] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.276558] arm-smmu 12000000.iommu: stage 1 translation
[ 4.282124] arm-smmu 12000000.iommu: stage 2 translation
[ 4.287668] arm-smmu 12000000.iommu: nested translation
[ 4.293132] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.300558] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.309624] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.316335] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.323031] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.330565] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.337284] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.342114] arm-smmu 10000000.iommu: stage 1 translation
[ 4.347666] arm-smmu 10000000.iommu: stage 2 translation
[ 4.353211] arm-smmu 10000000.iommu: nested translation
[ 4.358676] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.366099] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.375110] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.381825] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.388530] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.395663] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.402289] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.407032] arm-smmu 8000000.iommu: stage 1 translation
[ 4.412494] arm-smmu 8000000.iommu: stage 2 translation
[ 4.417948] arm-smmu 8000000.iommu: nested translation
[ 4.423315] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.430661] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.439589] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.446211] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.452830] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.460156] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.470760] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.476813] tegra_profiler: auth: init
[ 4.480966] nvsciipc: loaded module
[ 4.486120] tun: Universal TUN/TAP device driver, 1.6
[ 4.491761] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.499190] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.504689] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.509796] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.515897] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.521448] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.527348] PPP generic driver version 2.4.2
[ 4.531788] PPP BSD Compression module registered
[ 4.536625] PPP Deflate Compression module registered
[ 4.541839] PPP MPPE Compression module registered
[ 4.546786] usbcore: registered new interface driver r8152
[ 4.552440] usbcore: registered new interface driver asix
[ 4.557998] usbcore: registered new interface driver ax88179_178a
[ 4.564277] usbcore: registered new interface driver cdc_ether
[ 4.570295] usbcore: registered new interface driver net1080
[ 4.576121] usbcore: registered new interface driver cdc_subset
[ 4.582206] usbcore: registered new interface driver zaurus
[ 4.587958] usbcore: registered new interface driver cdc_ncm
[ 4.593802] usbcore: registered new interface driver aqc111
[ 4.599640] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.606011] ohci-pci: OHCI PCI platform driver
[ 4.610589] ohci-platform: OHCI generic platform driver
[ 4.616264] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.622563] usbcore: registered new interface driver uas
[ 4.628052] usbcore: registered new interface driver usb-storage
[ 4.634388] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.640536] mousedev: PS/2 mouse device common for all mice
[ 4.646285] usbcore: registered new interface driver xpad
[ 4.653696] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.658923] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.665369] i2c /dev entries driver
[ 4.669016] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.674908] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.680631] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.686325] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.692022] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.697714] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.703405] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.709148] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.717799] device-mapper: uevent: version 1.0.3
[ 4.722636] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.732511] sdhci: Secure Digital Host Controller Interface driver
[ 4.738863] sdhci: Copyright(c) Pierre Ossman
[ 4.743355] Synopsys Designware Multimedia Card Interface Driver
[ 4.749600] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.755827] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.755886] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.756232] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.776342] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[ 4.785351] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.791243] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.806547] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.815208] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 2024-06-27T13:18:03 UTC (1719494283)
[ 4.824894] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.969732] hid: raw HID events driver (C) Jiri Kosina
[ 5.976042] usbcore: registered new interface driver usbhid
[ 5.981810] usbhid: USB HID core driver
[ 5.987217] tegra-dce d800000.dce: Adding to iommu group 5
[ 5.994773] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 6.003389] tegra234-aon c000000.aon: Adding to iommu group 6
[ 6.010079] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.012755] c000000.aon:hsp: probed
[ 6.019119] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.031632] tegra234-aon c000000.aon: init done
[ 6.032054] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.037651] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.045709] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.054128] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 6.061658] tegra23x-psc e860000.psc: init done
[ 6.072287] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 6.072290] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.072300] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.078715] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.088556] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.099557] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.109744] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.120746] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.126539] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 6.126542] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.126553] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.136534] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.147492] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.158170] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.221145] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.234345] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.248357] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.262634] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.276321] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (124)
[ 6.284592] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.294404] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 6.294407] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 6.296598] t19x_cache tegra-cache: probed
[ 6.322117] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.337907] optee: probing for conduit method.
[ 6.343971] optee: revision 3.21 (d8269f24)
[ 6.402747] optee: dynamic shared memory is enabled
[ 6.415062] optee: initialized driver
[ 6.435525] nvpmodel: initialized successfully
[ 6.441654] tegra_hv: get_hvd: not initialized yet
[ 6.448055] user_ivc_mempool: hypervisor not present
[ 6.455343] usbcore: registered new interface driver snd-usb-audio
[ 6.464011] u32 classifier
[ 6.468265] input device check on
[ 6.473506] Actions configured
[ 6.478607] Initializing XFRM netlink socket
[ 6.484887] NET: Registered protocol family 10
[ 6.492569] Segment Routing with IPv6
[ 6.497905] NET: Registered protocol family 17
[ 6.503961] NET: Registered protocol family 15
[ 6.510054] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.525560] Bluetooth: RFCOMM socket layer initialized
[ 6.532411] Bluetooth: RFCOMM ver 1.11
[ 6.537780] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.545374] Bluetooth: HIDP socket layer initialized
[ 6.552648] 9pnet: Installing 9P2000 support
[ 6.558632] Key type dns_resolver registered
[ 6.565681] registered taskstats version 1
[ 6.571423] Loading compiled-in X.509 certificates
[ 6.590145] Loaded X.509 cert 'Build time autogenerated kernel key: 50e0d26972b2b426c1d8e68ff69867bd74ef6e3e'
[ 6.602488] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.617373] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.627677] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.641891] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.650356] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.664544] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.698899] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.714998] simple-framebuffer chosen:framebuffer: framebuffer at 0x1039e00000, 0x21c0000 bytes, mapped to 0x(____ptrval____)
[ 6.728235] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=3840x2160x32, linelength=16384
[ 6.739450] checking generic (1039e00000 21c0000) vs hw (1039e00000 21c0000)
[ 6.739452] fb0: switching to simple from EFI VGA
[ 6.746170] Console: switching to colour dummy device 80x25
[ 6.763130] Console: switching to colour frame buffer device 480x135
[ 6.780525] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[ 6.788104] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.816497] host1x 13e40000.host1x: initialized
[ 6.821578] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.829786] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.841835] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.849986] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.862002] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.870135] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.882157] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.890275] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.902272] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.910408] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.922398] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.930569] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.942580] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.950713] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.962715] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.970850] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.982865] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.991050] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 7.003033] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 7.011173] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 7.023183] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 7.031316] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 7.043281] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 7.051432] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.063413] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 7.071586] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.083582] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 7.091703] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.103689] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 7.111813] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.123789] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 7.131918] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.143940] falcon 15340000.vic: Adding to iommu group 30
[ 7.154921] falcon 15340000.vic: initialized
[ 7.159699] falcon 15380000.nvjpg: Adding to iommu group 31
[ 7.168661] falcon 15380000.nvjpg: initialized
[ 7.173395] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 7.182133] falcon 15540000.nvjpg1: initialized
[ 7.186958] falcon 154c0000.nvenc: Adding to iommu group 33
[ 7.196653] falcon 154c0000.nvenc: initialized
[ 7.201384] falcon 15a50000.ofa: Adding to iommu group 34
[ 7.210266] falcon 15a50000.ofa: initialized
[ 7.214836] nvdec 15480000.nvdec: Adding to iommu group 35
[ 7.226168] nvdec 15480000.nvdec: initialized
[ 7.230804] tsec 15500000.tsec: Adding to iommu group 36
[ 7.240457] tsec 15500000.tsec: initialized
[ 7.247732] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.264973] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.279135] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 7.283810] gpio-398 (power-led): hogged as output/low
[ 7.289161] gpio-349 (status-led): hogged as output/high
[ 7.295465] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.302482] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.309498] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.316125] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.322623] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.328844] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.336527] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 7.345530] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.355200] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.361599] driver not enabled, cannot register any devices
[ 7.367529] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 7.375716] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 7.383820] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.393888] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.400729] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.410707] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.417520] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.427504] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.434349] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 7.443144] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.454536] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 7.463276] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.474679] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 7.483457] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.494847] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 7.503589] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.514978] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 7.523771] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.535170] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 7.543926] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.555326] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 7.564098] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.575502] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 7.584269] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.595681] pva 16000000.pva0: Adding to iommu group 48
[ 7.620780] pva 16000000.pva0: initialized
[ 7.633817] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 7.648731] nvdla 15880000.nvdla0: initialized
[ 7.655050] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 7.669181] nvdla 158c0000.nvdla1: initialized
[ 7.675462] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.682472] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.690005] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.696650] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.703407] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.710060] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 24, base_baud = 0) is a TEGRA_UART
[ 7.719884] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.726388] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 83, base_baud = 0) is a TEGRA_UART
[ 7.736244] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.742732] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 84, base_baud = 0) is a TEGRA_UART
[ 7.758845] pca953x 1-0020: using no AI
[ 7.764227] gpiochip2: registered GPIOs 308 to 315 on 1-0020
[ 7.770248] pca953x 1-0021: using no AI
[ 7.775465] gpiochip3: registered GPIOs 300 to 307 on 1-0021
[ 7.793455] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.818763] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2012000 KHz, changing to: 2035200 KHz
[ 7.831528] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 7.845540] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 7.858946] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.867994] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.878819] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.879863] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.894143] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.904251] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.914347] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.918803] mmc0: CQHCI version 5.10
[ 7.933660] irq: IRQ308: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.942738] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 308
[ 7.958156] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.031410] tegra194-pcie 14100000.pcie: Link up
[ 8.038930] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.047149] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.054235] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.065532] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.077817] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.087188] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.094972] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.106393] pci 0001:01:00.0: [12d8:b404] type 01 class 0x060400
[ 8.115459] pci 0001:01:00.0: supports D1 D2
[ 8.121292] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.133757] pci 0001:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 8.143831] mmc0: Command Queue Engine enabled
[ 8.144374] pci 0001:02:01.0: [12d8:b404] type 01 class 0x060400
[ 8.150044] mmc0: periodic cache flush enabled
[ 8.150051] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.159326] pci 0001:02:01.0: supports D1 D2
[ 8.164700] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.172278] pci 0001:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.178560] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 8.185577] pci 0001:02:02.0: [12d8:b404] type 01 class 0x060400
[ 8.211283] pci 0001:02:02.0: supports D1 D2
[ 8.217147] pci 0001:02:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.226347] pci 0001:02:03.0: [12d8:b404] type 01 class 0x060400
[ 8.235434] pci 0001:02:03.0: supports D1 D2
[ 8.241298] pci 0001:02:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.251755] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.253631] pci 0001:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 8.270234] pci 0001:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 8.280010] pci 0001:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 8.293637] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
[ 8.305797] pci_bus 0001:04: busn_res: [bus 04-ff] end is updated to 04
[ 8.317874] pci_bus 0001:05: busn_res: [bus 05-ff] end is updated to 05
[ 8.326101] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 05
[ 8.334347] pci 0001:02:01.0: PCI bridge to [bus 03]
[ 8.340955] pci 0001:02:02.0: PCI bridge to [bus 04]
[ 8.347544] pci 0001:02:03.0: PCI bridge to [bus 05]
[ 8.354133] pci 0001:01:00.0: PCI bridge to [bus 02-05]
[ 8.360972] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.367731] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.377863] pci 0001:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 128
[ 8.387962] pci 0001:02:01.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 128
[ 8.398049] pci 0001:02:02.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 128
[ 8.408142] pci 0001:02:03.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 128
[ 8.418430] pcieport 0001:00:00.0: Adding to iommu group 9
[ 8.425639] pcieport 0001:00:00.0: PME: Signaling with IRQ 62
[ 8.433522] pcieport 0001:00:00.0: AER: enabled with IRQ 62
[ 8.440943] pcieport 0001:01:00.0: Adding to iommu group 9
[ 8.451857] pcieport 0001:02:01.0: Adding to iommu group 9
[ 8.462556] pcieport 0001:02:02.0: Adding to iommu group 9
[ 8.473136] pcieport 0001:02:03.0: Adding to iommu group 9
[ 8.484142] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.493242] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.501740] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.511744] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.521731] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.639523] tegra194-pcie 14160000.pcie: Link up
[ 8.646590] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.654686] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.661629] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.673037] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.685189] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.694411] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.702038] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.713029] pci 0004:01:00.0: [1bcd:0920] type 00 class 0x010802
[ 8.720703] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.729306] pci 0004:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[ 8.742387] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.751127] pci 0004:01:00.0: BAR 6: assigned [mem 0x2428000000-0x242801ffff pref]
[ 8.760273] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428020000-0x2428023fff 64bit]
[ 8.769585] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.776318] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.785016] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.795104] pci 0004:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 8.805364] pcieport 0004:00:00.0: Adding to iommu group 10
[ 8.812655] pcieport 0004:00:00.0: PME: Signaling with IRQ 64
[ 8.820433] pcieport 0004:00:00.0: AER: enabled with IRQ 64
[ 8.827797] nvme 0004:01:00.0: Adding to iommu group 10
[ 8.834896] nvme nvme0: pci function 0004:01:00.0
[ 8.841096] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.841723] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.857438] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.865929] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 8.875944] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 8.885924] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 8.896067] nvme nvme0: missing or invalid SUBNQN field.
[ 8.914412] nvme nvme0: allocated 64 MiB host memory buffer.
[ 9.258649] nvme nvme0: 8/0/0 default/read/poll queues
[ 9.268100] nvme0n1: p1
[ 10.004827] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 10.012491] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 10.020607] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 10.027530] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 10.038927] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.051048] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 10.060264] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.067914] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 10.082139] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 10.088836] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.099068] pcieport 0005:00:00.0: Adding to iommu group 11
[ 10.106324] pcieport 0005:00:00.0: PME: Signaling with IRQ 66
[ 10.114012] pcieport 0005:00:00.0: AER: enabled with IRQ 66
[ 10.121283] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 10.128643] pci 0005:00:00.0: Removing from iommu group 11
[ 10.135589] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 10.144067] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 10.150293] vdd-dp: supplied by vdd-3v3-sys
[ 10.156062] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 10.163711] irq: IRQ325: trimming hierarchy from :pmc@c360000
[ 10.172665] tegra194-isp5 14800000.isp: initialized
[ 10.178980] driver not enabled, cannot register any devices
[ 10.190657] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.198297] driver not enabled, cannot register any devices
[ 10.205392] (NULL device *): fops function table already registered
[ 10.213983] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.221633] driver not enabled, cannot register any devices
[ 10.244398] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 10.255422] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 10.262236] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 10.272035] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 10.282920] tegra-xusb 3610000.xhci: irq 241, io mem 0x03610000
[ 10.290419] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 10.300184] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.308895] usb usb1: Product: xHCI Host Controller
[ 10.315209] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 10.322733] usb usb1: SerialNumber: 3610000.xhci
[ 10.329066] hub 1-0:1.0: USB hub found
[ 10.334200] hub 1-0:1.0: 4 ports detected
[ 10.339701] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 10.346548] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 10.355630] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 10.364405] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 10.374182] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.382893] usb usb2: Product: xHCI Host Controller
[ 10.389178] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 10.396702] usb usb2: SerialNumber: 3610000.xhci
[ 10.402990] hub 2-0:1.0: USB hub found
[ 10.408119] hub 2-0:1.0: 4 ports detected
[ 10.415566] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.415875] nvethernet 2310000.ethernet: Adding to iommu group 51
[ 10.429881] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 10.435684] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 308
[ 10.439289] nvethernet 2310000.ethernet: failed to read MDIO address
[ 10.455114] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 10.463250] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 10.473620] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 10.595555] usb 1-2: new full-speed USB device number 2 using tegra-xusb
[ 10.731464] nvethernet 2310000.ethernet: Ethernet MAC address: 00:a0:10:02:c4:40
[ 10.740831] -->macsec_probe()
[ 10.740842] nvethernet 2310000.ethernet: macsec param in DT is missing or disabled
[ 10.749862] <--macsec_probe()
[ 10.749864] nvethernet 2310000.ethernet: Macsec not supported/Not enabled in DT
[ 10.757929] usb 1-2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[ 10.760426] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 10.768503] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.778330] nvethernet 6810000.ethernet: Adding to iommu group 52
[ 10.786920] usb 1-2: Product: USB Receiver
[ 10.786923] usb 1-2: Manufacturer: Logitech
[ 10.795064] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 10.804203] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.0/0003:046D:C52B.0001/input/input0
[ 10.806099] nvethernet 6810000.ethernet: failed to read MDIO address
[ 10.836544] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 10.844714] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 10.875626] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-2/input0
[ 10.893344] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input1
[ 10.906800] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input2
[ 10.979620] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.1/0003:046D:C52B.0002/input/input3
[ 10.993896] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-2/input1
[ 11.010924] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-2/input2
[ 11.151553] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 11.236555] nvethernet 6810000.ethernet: Ethernet MAC address: 00:a0:10:02:c4:3f
[ 11.246071] -->macsec_probe()
[ 11.246087] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 11.255246] <--macsec_probe()
[ 11.255248] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 11.268611] nvethernet 6810000.ethernet: eth1 (HW ver: 31) created with 10 DMA channels
[ 11.278785] irq: IRQ327: trimming hierarchy from :pmc@c360000
[ 11.286148] irq: IRQ328: trimming hierarchy from :interrupt-controller@f400000-1
[ 11.295239] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[ 11.304134] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 11.312463] tegra-se-nvhost 15810000.se: initialized
[ 11.313501] usb 1-4: New USB device found, idVendor=0424, idProduct=2517, bcdDevice= 0.02
[ 11.329038] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 11.331150] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 11.338895] hub 1-4:1.0: USB hub found
[ 11.345805] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 11.351616] hub 1-4:1.0: 7 ports detected
[ 11.359283] tegra-se-nvhost 15820000.se: initialized
[ 11.374760] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 11.382646] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 11.390674] tegra-se-nvhost 15840000.se: initialized
[ 11.398666] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 11.406961] tegra_actmon d230000.actmon: in actmon_register()...
[ 11.414741] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 11.422196] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 11.432015] hvc_sysfs: hypervisor is not present
[ 11.563407] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.567152] ALSA device list:
[ 11.575129] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.579678] No soundcards found.
[ 11.582613] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 11.591380] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.617569] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.629284] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.629839] Freeing unused kernel memory: 3968K
[ 11.647190] Run /init as init process
[ 11.652438] with arguments:
[ 11.652439] /init
[ 11.652440] with environment:
[ 11.652441] HOME=/
[ 11.652441] TERM=linux
[ 11.652442] mminit_loglevel=4
[ 11.659536] usb 1-4.5: new full-speed USB device number 4 using tegra-xusb
[ 11.664814] Root device found: mmcblk0p1
[ 11.681479] Found dev node: /dev/mmcblk0p1
[ 11.713863] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.724264] Check if configured for BURNIN
[ 11.738826] IP file for BURNIN not found
[ 11.747557] Rootfs mounted over mmcblk0p1
[ 11.763776] Switching from initrd to actual rootfs
[ 11.786748] usb 1-4.5: New USB device found, idVendor=046d, idProduct=c548, bcdDevice= 5.01
[ 11.796969] usb 1-4.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.806032] usb 1-4.5: Product: USB Receiver
[ 11.811955] usb 1-4.5: Manufacturer: Logitech
[ 11.824041] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.5/1-4.5:1.0/0003:046D:C548.0004/input/input6
[ 11.895811] hid-generic 0003:046D:C548.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.5/input0
[ 11.913200] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.5/1-4.5:1.1/0003:046D:C548.0005/input/input7
[ 11.928166] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.5/1-4.5:1.1/0003:046D:C548.0005/input/input8
[ 11.945481] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[ 11.993231] systemd[1]: systemd 245.4-4ubuntu3.23 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 12.003612] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.5/1-4.5:1.1/0003:046D:C548.0005/input/input9
[ 12.018593] systemd[1]: Detected architecture arm64.
[ 12.033903] hid-generic 0003:046D:C548.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.5/input1
[ 12.057384] hid-generic 0003:046D:C548.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-4.5/input2
[ 12.096530] systemd[1]: Set hostname to <agx811>.
[ 12.264761] random: crng init done
[ 12.325046] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 12.339976] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 12.351279] systemd[1]: Created slice system-modprobe.slice.
[ 12.360939] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.371144] systemd[1]: Created slice User and Session Slice.
[ 12.380701] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.392271] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.405575] systemd[1]: Reached target User and Group Name Lookups.
[ 12.415628] systemd[1]: Reached target Slices.
[ 12.423799] systemd[1]: Reached target Mounting snaps.
[ 12.432674] systemd[1]: Reached target Swap.
[ 12.440851] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.451255] systemd[1]: Listening on Syslog Socket.
[ 12.459966] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.470515] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.480990] systemd[1]: Listening on Journal Audit Socket.
[ 12.490301] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.500130] systemd[1]: Listening on Journal Socket.
[ 12.508976] systemd[1]: Listening on udev Control Socket.
[ 12.518207] systemd[1]: Listening on udev Kernel Socket.
[ 12.528311] systemd[1]: Mounting Huge Pages File System...
[ 12.538617] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.549593] systemd[1]: Mounting RPC Pipe File System...
[ 12.559702] systemd[1]: Mounting Kernel Debug File System...
[ 12.570081] systemd[1]: Mounting Kernel Trace File System...
[ 12.580752] systemd[1]: Starting Journal Service...
[ 12.590611] systemd[1]: Starting Set the console keyboard layout...
[ 12.601664] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 12.615257] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 12.625939] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 12.637087] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.648089] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 12.659172] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 12.670214] systemd[1]: Starting Load Kernel Module ramoops...
[ 12.679917] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 12.692422] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 12.704101] systemd[1]: Started Nameserver information manager.
[ 12.713977] systemd[1]: Reached target Network (Pre).
[ 12.723506] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 12.734649] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 12.755633] systemd[1]: Starting Load Kernel Modules...
[ 12.765516] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.776951] systemd[1]: Starting udev Coldplug all Devices...
[ 12.779114] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 12.795795] systemd[1]: Started Journal Service.
[ 12.853310] systemd-journald[326]: Received client request to flush runtime journal.
[ 12.959494] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 12.959759] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000001038e00000,16777216
[ 12.959762] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 12.959768] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 12.959770] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 12.959773] nvmap_page_pool_init: Total RAM pages: 16077528
[ 12.959775] nvmap_page_pool_init: nvmap page pool size: 2009691 pages (3754 MB)
[ 12.960248] nvmap_background_zero_thread: PP zeroing thread starting.
[ 12.960342] misc nvmap: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 12.963357] misc nvmap: created heap fsi base 0x0000001038e00000 size (16384KiB)
[ 13.280071] loop: module loaded
[ 14.587144] nvethernet 2310000.ethernet lan2: renamed from eth0
[ 14.595659] nvidia: loading out-of-tree module taints kernel.
[ 14.605815] nv_platform 13800000.display: Adding to iommu group 56
[ 14.610893] platform 13800000.display:nvdisplay-niso: Adding to iommu group 57
[ 14.632868] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:41 PDT 2023
[ 14.648166] nvethernet 6810000.ethernet lan1: renamed from eth1
[ 14.669484] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 14.684972] irq: IRQ329: trimming hierarchy from :pmc@c360000
[ 14.693066] cpu-throttle-alert cooling device registered.
[ 14.694314] nct1008_nct72 4-004c: starting parse dt
[ 14.704583] gpu-throttle-alert cooling device registered.
[ 14.706647] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 14.707381] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[ 14.708138] nvvrs11 4-0020: NVVRS11 Model Rev: 0x81
[ 14.708141] nvvrs11 4-0020: NVVRS11 probe successful
[ 14.708566] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[ 14.708852] nvvrs11 4-0022: NVVRS11 Model Rev: 0x81
[ 14.708853] nvvrs11 4-0022: NVVRS11 probe successful
[ 14.713676] cv0-throttle-alert cooling device registered.
[ 14.713719] cv1-throttle-alert cooling device registered.
[ 14.713781] cv2-throttle-alert cooling device registered.
[ 14.721636] nct1008_nct72 4-004c: success parsing dt
[ 14.728416] soc0-throttle-alert cooling device registered.
[ 14.734741] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 14.735012] irq: IRQ331: trimming hierarchy from :pmc@c360000
[ 14.735478] rt5640 8-001c: Device with ID register 0xffff1d30 is not rt5640/39
[ 14.741479] soc1-throttle-alert cooling device registered.
[ 14.783780] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 14.788082] soc2-throttle-alert cooling device registered.
[ 14.795552] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 14.804787] hot-surface-alert cooling device registered.
[ 14.828907] nvadsp 2993000.adsp: Adding to iommu group 58
[ 14.847287] nct1008_nct72 4-004c: initial LOC temp: 42000
[ 14.853973] nvadsp 2993000.adsp: in probe()...
[ 14.861353] nct1008_nct72 4-004c: initial EXT temp: 43250
[ 14.868421] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 14.874575] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 14.894190] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 15.020583] tegra-asoc: sound: Adding to iommu group 58
[ 15.053787] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 58
[ 15.062677] tegra210_adsp_audio_probe: platform probe started
[ 15.070605] tegra-hda 3510000.hda: Adding to iommu group 59
[ 15.070786] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 15.086982] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 15.087960] cdi_tsc c6a0000.tsc_sig_gen: CDI TSC probing...
[ 15.096072] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 15.102969] cdi_tsc_probe: Initializing the driver
[ 15.111665] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 15.117883] cdi_tsc_probe: Successfully initialized the tsc char driver
[ 15.127023] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 15.131819] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input10
[ 15.155550] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 15.155558] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 15.155558] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 15.155646] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 15.196447] cryptd: max_cpu_qlen set to 1000
[ 15.267809] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input11
[ 15.340322] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input12
[ 15.431887] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input13
[ 15.496232] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-2/input2
[ 15.498640] tegra210-adsp tegra210-adsp: Loaded app wire
[ 15.518030] tegra210-adsp tegra210-adsp: Loaded app apm
[ 15.524729] tegra210-adsp tegra210-adsp: Loaded app adma
[ 15.531499] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 15.538535] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 0000000062396b6f
[ 15.574553] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 15.634391] input: Logitech Wireless Device PID:4003 Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0007/input/input14
[ 15.651362] input: Logitech Wireless Device PID:4003 Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0007/input/input15
[ 15.668801] input: Logitech Wireless Device PID:4003 System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0007/input/input16
[ 15.686096] hid-generic 0003:046D:4003.0007: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4003] on usb-3610000.xhci-2/input2:2
[ 16.017858] input: Logitech K270 as /devices/platform/3610000.xhci/usb1/1-2/1-2:1.2/0003:046D:C52B.0003/0003:046D:4003.0007/input/input20
[ 16.032174] logitech-hidpp-device 0003:046D:4003.0007: input,hidraw1: USB HID v1.11 Keyboard [Logitech K270] on usb-3610000.xhci-2/input2:2
[ 16.352042] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 16.575091] nvethernet 6810000.ethernet lan1: Macsec: Reduced MTU: 8966 Max: 16383
[ 16.977591] irq: IRQ332: trimming hierarchy from :interrupt-controller@f400000-1
[ 16.978145] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 17.233299] nvgpu: 17000000.ga10b tpc_pg_mask_store:1070 [INFO] no value change, same mask already set
[ 17.236321] pstore: Using crash dump compression: deflate
[ 17.236580] printk: console [ramoops-1] enabled
[ 17.236582] pstore: Registered ramoops as persistent store backend
[ 17.236584] ramoops: using 0x200000@0x102d270000, ecc: 0
[ 17.420158] nvgpu: 17000000.ga10b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 17.728237] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[ 18.235243] mdio_bus 2310000.ethernet: phy has invalid PHY address
[ 18.245753] mdio_bus 2310000.ethernet: scan phy phy at address 0
[ 19.064737] irq: IRQ333: trimming hierarchy from :interrupt-controller@f400000-1
[ 19.089226] zram: Added device: zram0
[ 19.089429] zram: Added device: zram1
[ 19.089936] zram: Added device: zram2
[ 19.090615] zram: Added device: zram3
[ 19.091168] zram: Added device: zram4
[ 19.091897] zram: Added device: zram5
[ 19.092138] zram: Added device: zram6
[ 19.092701] zram: Added device: zram7
[ 19.094537] zram: Added device: zram8
[ 19.094987] zram: Added device: zram9
[ 19.097007] zram: Added device: zram10
[ 19.101105] zram: Added device: zram11
[ 19.140640] zram0: detected capacity change from 0 to 2743898112
[ 19.191531] Adding 2679584k swap on /dev/zram0. Priority:5 extents:1 across:2679584k SS
[ 19.194853] zram1: detected capacity change from 0 to 2743898112
[ 19.231511] Adding 2679584k swap on /dev/zram1. Priority:5 extents:1 across:2679584k SS
[ 19.234191] zram2: detected capacity change from 0 to 2743898112
[ 19.291460] Adding 2679584k swap on /dev/zram2. Priority:5 extents:1 across:2679584k SS
[ 19.294003] zram3: detected capacity change from 0 to 2743898112
[ 19.343478] Adding 2679584k swap on /dev/zram3. Priority:5 extents:1 across:2679584k SS
[ 19.346064] zram4: detected capacity change from 0 to 2743898112
[ 19.407441] Adding 2679584k swap on /dev/zram4. Priority:5 extents:1 across:2679584k SS
[ 19.410170] zram5: detected capacity change from 0 to 2743898112
[ 19.439561] Adding 2679584k swap on /dev/zram5. Priority:5 extents:1 across:2679584k SS
[ 19.442155] zram6: detected capacity change from 0 to 2743898112
[ 19.487448] Adding 2679584k swap on /dev/zram6. Priority:5 extents:1 across:2679584k SS
[ 19.490058] zram7: detected capacity change from 0 to 2743898112
[ 19.535445] Adding 2679584k swap on /dev/zram7. Priority:5 extents:1 across:2679584k SS
[ 19.538340] zram8: detected capacity change from 0 to 2743898112
[ 19.599450] Adding 2679584k swap on /dev/zram8. Priority:5 extents:1 across:2679584k SS
[ 19.602067] zram9: detected capacity change from 0 to 2743898112
[ 19.651519] Adding 2679584k swap on /dev/zram9. Priority:5 extents:1 across:2679584k SS
[ 19.654507] zram10: detected capacity change from 0 to 2743898112
[ 19.703430] Adding 2679584k swap on /dev/zram10. Priority:5 extents:1 across:2679584k SS
[ 19.706650] zram11: detected capacity change from 0 to 2743898112
[ 19.759510] Adding 2679584k swap on /dev/zram11. Priority:5 extents:1 across:2679584k SS
[ 21.091020] audit: type=1326 audit(1719494299.772:2): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1522 comm="cupsd" exe="/snap/cups/1053/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffff9112910c code=0x50000
[ 21.466413] audit: type=1326 audit(1719494300.148:3): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1522 comm="cupsd" exe="/snap/cups/1053/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compat=0 ip=0xffff9112910c code=0x50000
[ 21.489843] audit: type=1326 audit(1719494300.168:4): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1534 comm="cups-browsed" exe="/snap/cups/1053/sbin/cups-browsed" sig=0 arch=c00000b7 syscall=274 compat=0 ip=0xffff96ea1c28 code=0x50000
[ 24.842001] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 137.015229] capability: warning: `husarnet-daemon' uses 32-bit capabilities (legacy support in use)
[ 138.327799] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:42 PDT 2023
[ 138.999432] NVRM nvAssertFailedNoLog: Assertion failed: minRequiredIsoBandwidthKBPS <= clientBwValues[DISPLAY_ICC_BW_CLIENT_EXT].minRequiredIsoBandwidthKBPS @ kern_disp_0402.c:111
[ 138.999448] CPU: 5 PID: 7 Comm: kworker/u24:0 Tainted: G OE 5.10.120-tegra #4
[ 138.999452] Hardware name: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 4.1-33958178 08/01/2023
[ 138.999469] Workqueue: dce-async-ipc-wq dce_client_async_event_work
[ 138.999475] Call trace:
[ 138.999489] dump_backtrace+0x0/0x1d0
[ 138.999496] show_stack+0x2c/0x40
[ 138.999503] dump_stack+0xd8/0x138
[ 138.999616] os_dump_stack+0x18/0x20 [nvidia]
[ 138.999722] tlsEntryGet+0x130/0x138 [nvidia]
[ 138.999827] kdispArbAndAllocDisplayBandwidth_v04_02+0x274/0x288 [nvidia]
[ 138.999930] kdispInvokeDisplayModesetCallback_KERNEL+0xa8/0xf0 [nvidia]
[ 139.000033] dceclientHandleAsyncRpcCallback+0x17c/0x2f0 [nvidia]
[ 139.000135] initVGXSpecificRegistry+0x1dc/0x300 [nvidia]
[ 139.000140] dce_client_async_event_work+0x88/0x190
[ 139.000147] process_one_work+0x1c0/0x4a0
[ 139.000151] worker_thread+0x50/0x420
[ 139.000155] kthread+0x148/0x170
[ 139.000159] ret_from_fork+0x10/0x18
[ 144.551820] logitech-hidpp-device 0003:046D:4003.0007: HID++ 2.0 device connected.
[ 148.135517] NVRM nvAssertFailedNoLog: Assertion failed: minRequiredIsoBandwidthKBPS <= clientBwValues[DISPLAY_ICC_BW_CLIENT_EXT].minRequiredIsoBandwidthKBPS @ kern_disp_0402.c:111
[ 151.337732] fuse: init (API version 7.32)
[ 212.695549] cpufreq: cpu0,cur:1182000,set:729600,set ndiv:57
[ 549.715239] usb 1-2: USB disconnect, device number 2
[ 556.839814] usb 2-2: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 556.863922] usb 2-2: New USB device found, idVendor=04e8, idProduct=61fb, bcdDevice= 1.00
[ 556.863931] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 556.863935] usb 2-2: Product: PSSD T7 Shield
[ 556.863938] usb 2-2: Manufacturer: Samsung
[ 556.863942] usb 2-2: SerialNumber: S76ZNS0W209940B
[ 556.872130] scsi host0: uas
[ 556.874741] scsi 0:0:0:0: Direct-Access Samsung PSSD T7 Shield 0 PQ: 0 ANSI: 6
[ 556.884334] sd 0:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 556.892443] sd 0:0:0:0: [sda] Write Protect is off
[ 556.897402] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 556.897850] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 556.907459] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 559.067431] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 559.067447] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x88 88 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00
[ 559.083656] scsi host0: uas_eh_device_reset_handler start
[ 559.212042] usb 2-2: reset SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 559.237386] scsi host0: uas_eh_device_reset_handler success
[ 560.174783] sda: sda1 sda2
[ 560.177452] sd 0:0:0:0: [sda] Attached SCSI disk
[ 560.392356] FAT-fs (sda2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 568.771419] usb 1-4.6: new full-speed USB device number 5 using tegra-xusb
[ 568.883361] usb 1-4.6: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[ 568.883369] usb 1-4.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 568.883374] usb 1-4.6: Product: USB Receiver
[ 568.883377] usb 1-4.6: Manufacturer: Logitech
[ 568.903314] logitech-djreceiver 0003:046D:C52B.000A: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-4.6/input2
[ 569.030176] input: Logitech K270 as /devices/platform/3610000.xhci/usb1/1-4/1-4.6/1-4.6:1.2/0003:046D:C52B.000A/0003:046D:4003.000B/input/input21
[ 569.030691] logitech-hidpp-device 0003:046D:4003.000B: input,hidraw1: USB HID v1.11 Keyboard [Logitech K270] on usb-3610000.xhci-4.6/input2:2
[ 593.159916] logitech-hidpp-device 0003:046D:4003.000B: HID++ 2.0 device connected.
And the stuff related to my NIC
Best regards
Julien
